2008-10-15KVM: Separate irq ack notification out of arch/x86/kvm/irq.cXiantao Zhang
Moving irq ack notification logic as common, and make it shared with ia64 side. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Change is_mmio_pfn to kvm_is_mmio_pfn, and make it common for all archsXiantao Zhang
Add a kvm_ prefix to avoid polluting kernel's name space. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Move device assignment logic to common codeXiantao Zhang
To share with other archs, this patch moves device assignment logic to common parts. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Device Assignment: Move vtd.c from arch/x86/kvm/ to virt/kvm/Zhang xiantao
Preparation for kvm/ia64 VT-d support. Signed-off-by: Zhang xiantao <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: VMX: enable invlpg exiting if EPT is disabledMarcelo Tosatti
Manually disabling EPT via module option fails to re-enable INVLPG exiting. Reported-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86: Silence various LAPIC-related host kernel messagesJan Kiszka
KVM-x86 dumps a lot of debug messages that have no meaning for normal operation: - INIT de-assertion is ignored - SIPIs are sent and received - APIC writes are unaligned or < 4 byte long (Windows Server 2003 triggers this on SMP) Degrade them to true debug messages, keeping the host kernel log clean for real problems. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: Device Assignment: Map mmio pages into VT-d page tableWeidong Han
Assigned device could DMA to mmio pages, so also need to map mmio pages into VT-d page table. Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: PIC: enhance IPI avoidanceMarcelo Tosatti
The PIC code makes little effort to avoid kvm_vcpu_kick(), resulting in unnecessary guest exits in some conditions. For example, if the timer interrupt is routed through the IOAPIC, IRR for IRQ 0 will get set but not cleared, since the APIC is handling the acks. This means that everytime an interrupt < 16 is triggered, the priority logic will find IRQ0 pending and send an IPI to vcpu0 (in case IRQ0 is not masked, which is Linux's case). Introduce a new variable isr_ack to represent the IRQ's for which the guest has been signalled / cleared the ISR. Use it to avoid more than one IPI per trigger-ack cycle, in addition to the avoidance when ISR is set in get_priority(). Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: add "oos_shadow" parameter to disable oosMarcelo Tosatti
Subject says it all. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: speed up mmu_unsync_walkMarcelo Tosatti
Cache the unsynced children information in a per-page bitmap. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: out of sync shadow coreMarcelo Tosatti
Allow guest pagetables to go out of sync. Instead of emulating write accesses to guest pagetables, or unshadowing them, we un-write-protect the page table and allow the guest to modify it at will. We rely on invlpg executions to synchronize individual ptes, and will synchronize the entire pagetable on tlb flushes. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: mmu_convert_notrap helperMarcelo Tosatti
Need to convert shadow_notrap_nonpresent -> shadow_trap_nonpresent when unsyncing pages. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: awareness of new kvm_mmu_zap_page behaviourMarcelo Tosatti
kvm_mmu_zap_page will soon zap the unsynced children of a page. Restart list walk in such case. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: mmu_parent_walkMarcelo Tosatti
Introduce a function to walk all parents of a given page, invoking a handler. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: x86: trap invlpgMarcelo Tosatti
With pages out of sync invlpg needs to be trapped. For now simply nuke the entry. Untested on AMD. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: sync roots on mmu reloadMarcelo Tosatti
2008-10-15KVM: MMU: mode specific sync_pageMarcelo Tosatti
Examine guest pagetable and bring the shadow back in sync. Caller is responsible for local TLB flush before re-entering guest mode. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: do not write-protect large mappingsMarcelo Tosatti
There is not much point in write protecting large mappings. This can only happen when a page is shadowed during the window between is_largepage_backed and mmu_lock acquision. Zap the entry instead, so the next pagefault will find a shadowed page via is_largepage_backed and fallback to 4k translations. Simplifies out of sync shadow. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: move local TLB flush to mmu_set_spteMarcelo Tosatti
Since the sync page path can collapse flushes. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: split mmu_set_spteMarcelo Tosatti
Split the spte entry creation code into a new set_spte function. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: MMU: flush remote TLBs on large->normal entry overwriteMarcelo Tosatti
It is necessary to flush all TLB's when a large spte entry is overwritten with a normal page directory pointer. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15x86: pvclock: fix shadowed variable warningHarvey Harrison
arch/x86/kernel/pvclock.c:102:6: warning: symbol 'tsc_khz' shadows an earlier one include/asm/tsc.h:18:21: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: ia64: add support for Tukwila processorsXiantao Zhang
In Tukwila processor, VT-i has been enhanced in its implementation, it is often called VT-i2 techonology. With VTi-2 support, virtulization performance should be improved. In this patch, we added the related stuff to support kvm/ia64 for Tukwila processors. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: ia64: Implement a uniform vps interfaceXiantao Zhang
An uniform entry kvm_vps_entry is added for vps_sync_write/read, vps_resume_handler/guest, and branches to differnt PAL service according to the offset. Singed-off-by: Anthony Xu <anthony.xu@intel.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: Remove useless intel-iommu.h header inclusionWeidong Han
Currently "#include <linux/intel-iommu.h>" is not needed in virt/kvm/kvm_main.c. Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: Don't destroy vcpu in case vcpu_setup failsGlauber Costa
One of vcpu_setup responsibilities is to do mmu initialization. However, in case we fail in kvm_arch_vcpu_reset, before we get the chance to init mmu. OTOH, vcpu_destroy will attempt to destroy mmu, triggering a bug. Keeping track of whether or not mmu is initialized would unnecessarily complicate things. Rather, we just make return, making sure any needed uninitialization is done before we return, in case we fail. Signed-off-by: Glauber Costa <glommer@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: don't enter guest after SIPI was received by a CPUGleb Natapov
The vcpu should process pending SIPI message before entering guest mode again. kvm_arch_vcpu_runnable() returns true if the vcpu is in SIPI state, so we can't call it here. Signed-off-by: Gleb Natapov <gleb@qumranet.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15MAINTAINERS: Update Avi Kivity's email addressAvi Kivity
2008-10-15KVM: x86.c make kvm_load_realmode_segment staticHarvey Harrison
Noticed by sparse: arch/x86/kvm/x86.c:3591:5: warning: symbol 'kvm_load_realmode_segment' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: switch to get_user_pages_fastMarcelo Tosatti
Convert gfn_to_pfn to use get_user_pages_fast, which can do lockless pagetable lookups on x86. Kernel compilation on 4-way guest is 3.7% faster on VMX. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: opencode gfn_to_page in kvm_vm_faultMarcelo Tosatti
kvm_vm_fault is invoked with mmap_sem held in read mode. Since gfn_to_page will be converted to get_user_pages_fast, which requires this lock NOT to be held, switch to opencoded get_user_pages. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: Device Assignment: Free device structures if IRQ allocation failsAmit Shah
When an IRQ allocation fails, we free up the device structures and disable the device so that we can unregister the device in the userspace and not expose it to the guest at all. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: Device Assignment with VT-dBen-Ami Yassour
Based on a patch by: Kay, Allen M <allen.m.kay@intel.com> This patch enables PCI device assignment based on VT-d support. When a device is assigned to the guest, the guest memory is pinned and the mapping is updated in the VT-d IOMMU. [Amit: Expose KVM_CAP_IOMMU so we can check if an IOMMU is present and also control enable/disable from userspace] Signed-off-by: Kay, Allen M <allen.m.kay@intel.com> Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com> Signed-off-by: Amit Shah <amit.shah@qumranet.com> Acked-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15VT-d: Changes to support KVMKay, Allen M
This patch extends the VT-d driver to support KVM [Ben: fixed memory pinning] [avi: move dma_remapping.h as well] Signed-off-by: Kay, Allen M <allen.m.kay@intel.com> Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com> Signed-off-by: Amit Shah <amit.shah@qumranet.com> Acked-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86 emulator: Use DstAcc for 'and'Guillaume Thouvenin
For instruction 'and al,imm' we use DstAcc instead of doing the emulation directly into the instruction's opcode. Signed-off-by: Guillaume Thouvenin <guillaume.thouvenin@ext.bull.net> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86 emulator: Add cmp al, imm and cmp ax, imm instructions (ocodes 3c, 3d)Guillaume Thouvenin
Add decode entries for these opcodes; execution is already implemented. Signed-off-by: Guillaume Thouvenin <guillaume.thouvenin@ext.bull.net> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86 emulator: Add DstAcc operand typeGuillaume Thouvenin
Add DstAcc operand type. That means that there are 4 bits now for DstMask. "In the good old days cpus would have only one register that was able to fully participate in arithmetic operations, typically called A for Accumulator. The x86 retains this tradition by having special, shorter encodings for the A register (like the cmp opcode), and even some instructions that only operate on A (like mul). SrcAcc and DstAcc would accommodate these instructions by decoding A into the corresponding 'struct operand'." -- Avi Kivity Signed-off-by: Guillaume Thouvenin <guillaume.thouvenin@ext.bull.net> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15x86: Move FEATURE_CONTROL bits to msr-index.hSheng Yang
For MSR_IA32_FEATURE_CONTROL is already there. Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: VMX: Rename IA32_FEATURE_CONTROL bitsSheng Yang
2008-10-15MAINTAINERS: add entry for the KVM AMD moduleJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86 emulator: fix jmp r/m64 instructionAvi Kivity
jmp r/m64 doesn't require the rex.w prefix to indicate the operand size is 64 bits. Set the Stack attribute (even though it doesn't involve the stack, really) to indicate this. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: VMX: Cleanup stalled INTR_INFO readJan Kiszka
Commit 1c0f4f5011829dac96347b5f84ba37c2252e1e08 left a useless access of VM_ENTRY_INTR_INFO_FIELD in vmx_intr_assist behind. Clean this up. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: ppc: kvmppc_44x_shadow_release() does not require mmap_sem to be lockedHollis Blanchard
And it gets in the way of get_user_pages_fast(). Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86: unhalt vcpu0 on resetMarcelo Tosatti
Since "KVM: x86: do not execute halted vcpus", HLT by vcpu0 before system reset by the IO thread will hang the guest. Mark vcpu as runnable in such case. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86 emulator: Add call near absolute instruction (opcode 0xff/2)Mohammed Gamal
Add call near absolute instruction. Signed-off-by: Mohammed Gamal <m.gamal005@gmail.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86: do not execute halted vcpusMarcelo Tosatti
Offline or uninitialized vcpu's can be executed if requested to perform userspace work. Follow Avi's suggestion to handle halted vcpu's in the main loop, simplifying kvm_emulate_halt(). Introduce a new vcpu->requests bit to indicate events that promote state from halted to running. Also standardize vcpu wake sites. Signed-off-by: Marcelo Tosatti <mtosatti <at> redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: x86 emulator: Add in/out instructions (opcodes 0xe4-0xe7, 0xec-0xef)Mohammed Gamal
The patch adds in/out instructions to the x86 emulator. The instruction was encountered while running the BIOS while using the invalid guest state emulation patch. Signed-off-by: Mohammed Gamal <m.gamal005@gmail.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Add statistics for guest irq injectionsAvi Kivity
These can help show whether a guest is making progress or not. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: MMU: Modify kvm_shadow_walk.entry to accept u64 addrSheng Yang
EPT is 4 level by default in 32pae(48 bits), but the addr parameter of kvm_shadow_walk->entry() only accept unsigned long as virtual address, which is 32bit in 32pae. This result in SHADOW_PT_INDEX() overflow when try to fetch level 4 index. Fix it by extend kvm_shadow_walk->entry() to accept 64bit addr in parameter. Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: ia64: Implement kvm_arch_vcpu_ioctl_{set,get}_mpstateXiantao Zhang
Two ioctl arch functions are added to set vcpu's smp state. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
