Not needed since the driver split.
Signed-off-by: Don Fry <donald.h.fry@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Define bitmap for calibration
The driver should take the ownership of the uCode as default setting
for later operations after interface up.
Signed-off-by: Kenny Hsu <kenny.hsu@intel.com>
The first assignment of TX_CMD_FLG_SEQ_CTL_MSK for
ack-expected mgmt frames is overwritten later in
the function, so it's useless. Also, probe response
frames, BACK request and others there are mutually
exclusive so can be moved into an else branch.
Those comments were missed in a previous commit.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Modify the comments for iwl_cfg, no functional changes
Another clean up work after driver split
After driver split, no need to make the code so complex
Most of the functions in iwl-agn-hcmd are move to other files, no point to
keep the file anymore.
The upper layer receives a pointer to an iwl_rx_mem_buffer. I would prefer the
upper layer to receive a pointer to an iwl_rx_packet, but this is impossible
since the Rx path needs to add the address of the page to the skb.
I may find a solution later.
All the pre_rx_handler and notification code has been moved to the upper layer.
Since all the irq / tasklet is now handled in the transport layer, it should
give an API to ensure that all the irq / tasklet have finished running. This
will allow the upper layer to release all its resources.
PCIe doesn't provide any ISR registration API, whereas other buses do.
Hence, we need to move the tasklet and irq to the transport layer to allow this
flexibility.
Split the Tx datapath in two parts:
* the first deals with the Tx cmd composition
* the second attaches the skb + Tx cmd to the queues
When suspending with all netdevs down, the device
is stopped but we still call a number of driver
callbacks that the driver might not expect. The
same happens during resume, we might call a few
callbacks without starting the driver. Fix this
by checking open_count around more things and
exiting quickly if it is 0.
Also, while at this I noticed that the coverage
class isn't reprogrammed after resume, so add
that.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Acked-By: christian Lamparter <chunkeey@googlemail.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
ieee80211_iter_keys() currently returns keys in
the backward order they were installed in, which
is a bit confusing. Add them to the tail of the
key list to make sure iterations go in the same
order that keys were originally installed in.
When the driver wants to pre-program the TKIP
RX phase 1 key, it needs to be able to obtain
it for the peer's TA. Add API to allow it to
generate it.
The generation uses a dummy on-stack context
since it doesn't know the RX queue.
For unicast the hardware sometimes reports MIC errors even though the
frame that it received actually contains a valid MIC - on some chips this
can happen frequently enough to trigger TKIP countermeasures.
Fix this issue by not reporting MIC errors for unicast frames with a
valid key, letting mac80211 validate the MIC instead.
Additionally, strip the MIC for all frames that the hardware considers
valid to avoid wasting CPU cycles re-validating it.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Eliminate spaces before tabs. Eliminate typedefs. Add spaces around
operators.
Following oops was seen on SMP machine
>BUG: unable to handle kernel NULL pointer dereference at 00000012
>IP: [<f8c56691>] mwl8k_tx+0x20e/0x561 [mwl8k]
>*pde = 00000000
>Oops: 0000 [#1] SMP
>Modules linked in: mwl8k mac80211 cfg80211 [last unloaded: cfg80211]
As ieee80211_tx_info->control.sta may be NULL during ->tx call, avoiding sta
dereference in such scenario with the following patch.
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
Some chips may support different lengths of user-supplied IEs with a
single scheduled scan command than with a single normal scan command.
To support this, this patch creates a separate hardware description
element that describes the maximum size of user-supplied information
element data supported in scheduled scans.
Signed-off-by: Luciano Coelho <coelho@ti.com>
Some chips can scan more SSIDs with a single scheduled scan command
than with a single normal scan command (eg. wl12xx chips).
element that describes the amount of SSIDs supported in scheduled
scans.
Since we now have the necessary API in place to support
GTK rekeying, applications will need to know whether it
is supported by a device. Add a pseudo-trigger that is
used only to advertise that capability. Also, add some
new triggers that match what iwlagn devices can do.
In WoWLAN, devices may use crypto keys for TX/RX
and could also implement GTK rekeying. If the
driver isn't able to retrieve replay counters and
similar information from the device upon resume,
or if the device isn't responsive due to platform
issues, it isn't safe to keep the connection up
as GTK rekey messages from during the sleep time
could be replayed against it.
The only protection against that is disconnecting
from the AP. Modifying mac80211 to do that while
it is resuming would be very complex and invasive
in the case that the driver requires a reconfig,
so do it after it has resumed completely. In that
case, however, packets might be replayed since it
can then only happen after TX/RX are up again, so
mark keys for interfaces that need to disconnect
as "tainted" and drop all packets that are sent
or received with those keys.
is_valid_ether_addr itself checks for is_zero_ether_addr
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
Currently, setting only legacy bitrates on 2.4GHz band
are supported. Mode 802.11b/g/bg is enabled based on
bitrates selection. If only CCK bitrates selected then
802.11b mode is enabled. If only OFDM bitrates are
selected then 802.11g mode is enabled. For both: CCK
and OFDM rates 802.11bg mixed mode is enabled.
Instead of using ieee80211_stop_queue, check the configured tx queue
limit before calling ieee80211_get_buffered_bc.
While 32 KHz sleep clock might provide some power saving benefits,
it is also a major source of stability issues, on OpenWrt it produced
some reproducible data bus errors on register accesses on several
different MIPS platforms.
All the Atheros drivers that I can find do not enable this feature,
so it makes sense to leave it disabled in ath5k as well.
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
enabling the sleep clock alters the AR5K_USEC_32 field, but disabling
it didn't restore it.
During scans the full calibration usually does not make much sense,
PAPD probing and IQ calibration should be deferred until there is
enough time to complete them. Adding 100 ms to the initial full
calibration delay should be enough to do this.
Fixes a division by zero when setting distance before activating the
device for the first time.
AR2413 uses the same reference clock as AR5413
Might fix some stability issues on newer chips
rfgain probe is only necessary for OFDM operation on AR5111 and AR5112.
Decryping frames on key_miss handling shouldn't be done for Michael
MIC failed frames as h/w would have already decrypted such frames
successfully anyway.
Also leaving CRC and PHY error(where the frame is going to be dropped
anyway), we are left to prcoess Decrypt error for which s/w decrypt is
selected anway and so having key_miss as a separate check doesn't serve
anything. So making key_miss handling mutually exlusive with other RX
status handling makes much more sense.
This patch addresses an issue with STA not reporting MIC failure events
resulting in STA being disconnected immediately.
Cc: stable@kernel.org
Signed-off-by: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Multiple quoted strings are concatenated without comma separators.
Make the array const while there.
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Fix the compile warning cause by [IWL_TM_ATTR_MAX - 1]
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Belkin's Connect N150 Wireless USB Adapter, model F7D1101 version 2, uses ID 0x945b.
Chipset info: rt: 3390, rf: 000b, rev: 3213.
I have just bought one, which started to work perfectly after the ID was added through this patch.
Signed-off-by: Eduardo Bacchi Kienetz <eduardo@kienetz.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Acked-by: Pavel Roskin <proski@gnu.org>
A typo causes routine rtl92cu_phy_rf6052_set_cck_txpower() to test the
same condition twice. The problem was found using cppcheck-1.49, and the
proper fix was verified against the pre-mac80211 version of the code.
Reported-by: David Binderman <dcb314@hotmail.com>
Cc: stable <stable@kernel.org> [back to 2.6.39]
When commands time out, corruption ensues. As lbs_complete_command()
is called without locking, the command node is mistakenly freed twice.
Also fixed up locking here in a few other places.
The nature of command timeout may be that the card didn't even
acknowledge receipt of the request. Detect this case and reset dnld_sent
so that other commands don't hang forever.
When cmdnodes are moved between the free list and the pending list,
their list heads should be reinitialized. Fixed this.
Sometimes commands are completed without actually submitting them or
removing them from cmdpendingq. We must remember to remove them from
cmdpendingq in these cases, so handle this in lbs_complete_command().
Harmless signals generated during suspend/resume were interrupting
lbs_cmd. Convert to an uninterruptible sleep to avoid this.
lbs_thread must be woken up every time there is some new work to do.
I found that when 2 commands are queued, ther completion of the first
command would not wake up lbs_thread to submit the second. Poke lbs_thread
at the end of lbs_complete_command() to fix this.
Signed-off-by: Daniel Drake <dsd@laptop.org>
We don't have multiple RX queues, so there's no use
in allocating multiple, use alloc_netdev_mqs() to
allocate multiple TX but only one RX queue.
I changed the TKIP key functions, but forgot to
update the documentation includes, fix that.
Looks like I forgot to document the "gfp" parameter
to cfg80211_gtk_rekey_notify, add it.
The SoCs like the bcm4716 do not have a sprom on the bcma bus like a
pcie device. It stores the values in some partition on flash memory.
For ssb this informations are read out in the bcm47xx arch code,
something like that should also be implemented for bcma. Without this
patch bcma panics on SoCs.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Problems located in the two functions lbs_set_reg() and lbs_get_reg():
- The offset field of struct cmd_ds_reg_access was not filled in
- The test on the return code of lbs_cmd_with_response() in function
lbs_get_reg() was inverted
Signed-off-by: Olivier Sobrie <olivier@sobrie.be>
