2008-04-29eCryptfs: integrate eCryptfs device handle into the module.Michael Halcrow
Update the versioning information. Make the message types generic. Add an outgoing message queue to the daemon struct. Make the functions to parse and write the packet lengths available to the rest of the module. Add functions to create and destroy the daemon structs. Clean up some of the comments and make the code a little more consistent with itself. [akpm@linux-foundation.org: printk fixes] Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29eCryptfs: introduce device handle for userspace daemon communicationsMichael Halcrow
A regular device file was my real preference from the get-go, but I went with netlink at the time because I thought it would be less complex for managing send queues (i.e., just do a unicast and move on). It turns out that we do not really get that much complexity reduction with netlink, and netlink is more heavyweight than a device handle. In addition, the netlink interface to eCryptfs has been broken since 2.6.24. I am assuming this is a bug in how eCryptfs uses netlink, since the other in-kernel users of netlink do not seem to be having any problems. I have had one report of a user successfully using eCryptfs with netlink on 2.6.24, but for my own systems, when starting the userspace daemon, the initial helo message sent to the eCryptfs kernel module results in an oops right off the bat. I spent some time looking at it, but I have not yet found the cause. The netlink interface breaking gave me the motivation to just finish my patch to migrate to a regular device handle. If I cannot find out soon why the netlink interface in eCryptfs broke, I am likely to just send a patch to disable it in 2.6.24 and 2.6.25. I would like the device handle to be the preferred means of communicating with the userspace daemon from 2.6.26 on forward. This patch: Functions to facilitate reading and writing to the eCryptfs miscellaneous device handle. This will replace the netlink interface as the preferred mechanism for communicating with the userspace eCryptfs daemon. Each user has his own daemon, which registers itself by opening the eCryptfs device handle. Only one daemon per euid may be registered at any given time. The eCryptfs module sends a message to a daemon by adding its message to the daemon's outgoing message queue. The daemon reads the device handle to get the oldest message off the queue. Incoming messages from the userspace daemon are immediately handled. If the message is a response, then the corresponding process that is blocked waiting for the response is awakened. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ecryptfs: add missing lock around notify_changeMiklos Szeredi
Callers of notify_change() need to hold i_mutex. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ecryptfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29remove ecryptfs_header_cache_0Adrian Bunk
Remove the no longer used ecryptfs_header_cache_0. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29xen: make blkif_getgeo staticHarvey Harrison
Introduced between 2.6.25-rc2 and -rc3 drivers/block/xen-blkfront.c:139:5: warning: symbol 'blkif_getgeo' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29vt: fix background color on line feedJan Engelhardt
A command that causes a line feed while a background color is active, such as perl -e 'print "x" x 60, "\e[44m", "x" x 40, "\e[0m\n"' and perl -e 'print "x" x 40, "\e[44m\n", "x" x 40, "\e[0m\n"' causes the line that was started as a result of the line feed to be completely filled with the currently active background color instead of the default color. When scrolling, part of the current screen is memcpy'd/memmove'd to the new region, and the new line(s) that will appear as a result are cleared using memset. However, the lines are cleared with vc->vc_video_erase_char, causing them to be colored with the currently active background color. This is different from X11 terminal emulators which always paint the new lines with the default background color (e.g. `xterm -bg black`). The clear operation (\e[1J and \e[2J) also use vc_video_erase_char, so a new vc->vc_scrl_erase_char is introduced with contains the erase character used for scrolling, which is built from vc->vc_def_color instead of vc->vc_color. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29directly use kmalloc() and kfree() in init/initramfs.cThomas Petazzoni
Instead of using the malloc() and free() wrappers needed by the lib/inflate.c code for allocations, simply use kmalloc() and kfree() in the initramfs code. This is needed for a further lib/inflate.c-related cleanup patch that will remove the malloc() and free() functions. Take that opportunity to remove the useless kmalloc() return value cast. Based on work done by Matt Mackall. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29isolate ratelimit from printk.c for other useDave Young
Due to the rcupreempt.h WARN_ON trigged, I got 2G syslog file. For some serious complaining of kernel, we need repeat the warnings, so here I isolate the ratelimit part of printk.c to a standalone file. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29vfs: fix unconditional write_super() call in file_fsync()OGAWA Hirofumi
We need to check ->s_dirt before calling write_super(). It became the cause of an unneeded write. This bug was noticed by Sudhanshu Saxena. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29xattr: add missing consts to function argumentsDavid Howells
Add missing consts to xattr function arguments. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29vfs: remove lives_below_in_same_fs()Jan Blunck
Remove lives_below_in_same_fs() since is_subdir() from fs/dcache.c is providing the same functionality. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29fs/inode.c: use hlist_for_each_entry()Matthias Kaehlcke
fs/inode.c: use hlist_for_each_entry() in find_inode() and find_inode_fast() [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29vfs: skip inodes without pages to free in drop_pagecache_sb()Jan Kara
Many inodes have no pagecache, so we can avoid lots of lock-takings. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29vfs: fix lock inversion in drop_pagecache_sb()Jan Kara
Fix longstanding lock inversion in drop_pagecache_sb by dropping inode_lock before calling __invalidate_mapping_pages(). We just have to make sure inode won't go away from under us by keeping reference to it and putting the reference only after we have safely resumed the scan of the inode list. A bit tricky but not too bad... Signed-off-by: Jan Kara <jack@suse.cz> Cc: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: David Chinner <dgc@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29swiotlb: use iommu_is_span_boundary helper functionFUJITA Tomonori
iommu_is_span_boundary in lib/iommu-helper.c was exported for PARISC IOMMUs (commit 3715863aa142c4f4c5208f5f3e5e9bac06006d2f). SWIOTLB can use it instead of the homegrown function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29lib/swiotlb.c: cleanupsAndrew Morton
There's a pointlessly braced block of code in there. Remove the braces and save a tabstop. Cc: Andi Kleen <ak@suse.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jan Beulich <jbeulich@novell.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29firmware loader: printk when requesting firmwareCiaran McCreesh
Before requesting firmware, printk a message saying what we're requesting. This makes it easier to see what's going on, and provides an explanation for the huge silent delay that one would otherwise get after accidentally building ipw2200 as a non-module. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29MAINTAINERS: clarify status of MN10300 mailing list as moderatedRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29fdpic: check that the size returned by kernel_read() is what we asked forDavid Howells
Check that the size of the read returned by kernel_read() is what we asked for. If it isn't, then reject the binary as being a badly formatted. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29smb.h: uses struct timespec but didn't include linux/time.hIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29update checkpatch.pl to version 0.18Andy Whitcroft
This version brings a few fixes for the extern checks, and a couple of new checks. Of note: - false is now recognised as a 0 assignment in static/external assignments, - printf format strings including %L are reported, - a number of fixes for the extern in .c file detector which had temporarily lost its ability to detect variables; undetected due to the loss of its test. Andy Whitcroft (8): Version: 0.18 false should trip 0 assignment checks tests: reinstate missing tests tests: allow specification of the file extension for a test fix extern checks for variables check for and report %Lu, %Ld, and %Li ensure we only start a statement on lines with some content extern spacing Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29update checkpatch.pl to version 0.17Andy Whitcroft
This version brings improvements to external declaration detection, fixes to quote tracking, fixes to unary tracking, some clarification of wording, and the usual slew of fixes for false positives. Of note: - much better unary tracking across preprocessor directives - UTF8 checks highlight the character at fault - widening of mutex detection Andy Whitcroft (17): Version: 0.17 values: __attribute__ carries through the previous type quotes: should only follow "positive" lines clarify the indent tabs over spaces wording loosen NR_CPUS check for array range initialisers detect external function declarations without an extern prefix function declaration arguments should be with the identifier DEFINE_MUTEX should report in line with struct mutex NR_CPUS is valid in preprocessor statements comment detection should not start on the @@ line types: add support for #undef tighten mutex/completion reports to usage allow export of function pointers values: preprocessor #define is out of line maintain values values: #define does not always have parentheses unary '*' may be const utf8 checks should report location of the invalid character Wolfram Sang (1): make checkpatch.pl really skip <asm/irq.h> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29scripts/Lindent: support gnu indent v2.2.10Joe Perches
The new version of indent supports positioning labels in column 1 using "-il0" http://www.nabble.com/Release-2.2.10-of-GNU-Indent-td15990700.html Add "-il0" if indent version >= 2.2.10 Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29drivers/misc: elide a non-zero test on a result that is never 0Julia Lawall
The function thermal_cooling_device_register always returns either a valid pointer or a value made with ERR_PTR, so a test for non-zero on the result will always succeed. The problem was found using the following semantic match. (http://www.emn.fr/x-info/coccinelle/) //<smpl> @a@ expression E, E1; statement S,S1; position p; @@ E = thermal_cooling_device_register(...) ... when != E = E1 if@p (E) S else S1 @n@ position a.p; expression E,E1; statement S,S1; @@ E = NULL ... when != E = E1 if@p (E) S else S1 @depends on !n@ expression E; statement S,S1; position a.p; @@ * if@p (E) S else S1 //</smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Thomas Sujith <sujith.thomas@intel.com> Cc: Len Brown <len.brown@intel.com> Cc: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29lists: add "const" qualifier to first arg of list_splice() operationsRobert P. J. Day
Since neither the list_splice() nor __list_splice() routines modify their first argument, might as well declare them "const". [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kbuild: move files that don't check __KERNEL__Robert P. J. Day
Move files that don't check __KERNEL__ from unifdef-y to header-y. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kbuild: remove duplicate, conflicting entry for oom.hRobert P. J. Day
oom.h is already tagged for unifdef'ing, so its entry as a simple exportable header should be deleted. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29fs/binfmt_aout.c: use printk_ratelimit()S.Caglar Onur
Use printk_ratelimit() instead of jiffies based arithmetic, suggested by Geert Uytterhoeven Signed-off-by: S.Caglar Onur <caglar@pardus.org.tr> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Remove superfluous include of string.h from percpu.hRobert P. J. Day
There's nothing in percpu.h that requires an explicit inclusion of string.h. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: explicitly include required header files under kernel/Robert P. J. Day
Following an experimental deletion of the unnecessary directive #include <linux/slab.h> from the header file <linux/percpu.h>, these files under kernel/ were exposed as needing to include one of <linux/slab.h> or <linux/gfp.h>, so explicit includes were added where necessary. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29binfmt_misc.c: avoid potential kernel stack overflowPavel Emelyanov
This can be triggered with root help only, but... Register the ":text:E::txt::/root/cat.txt:' rule in binfmt_misc (by root) and try launching the cat.txt file (by anyone) :) The result is - the endless recursion in the load_misc_binary -> open_exec -> load_misc_binary chain and stack overflow. There's a similar problem with binfmt_script, and there's a sh_bang memner on linux_binprm structure to handle this, but simply raising this in binfmt_misc may break some setups when the interpreter of some misc binaries is a script. So the proposal is to turn sh_bang into a bit, add a new one (the misc_bang) and raise it in load_misc_binary. After this, even if we set up the misc -> script -> misc loop for binfmts one of them will step on its own bang and exit. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kthread: call wake_up_process() without the lock being heldDmitry Adamushko
From the POV of synchronization, there should be no need to call wake_up_process() with the 'kthread_create_lock' being held. Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29codafs: fix build warningAndrew Morton
powerpc: fs/coda/coda_linux.c: In function 'coda_iattr_to_vattr': fs/coda/coda_linux.c:137: warning: large integer implicitly truncated to unsigned type Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29drivers/block/floppy.c: replace init_module&cleanup_module with ↵Jon Schindler
module_init&module_exit Replace init_module and cleanup_module with static functions and module_init/module_exit. Signed-off-by: Jon Schindler <jkschind@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29sysrq: add show-backtrace-on-all-cpus functionRik van Riel
SysRQ-P is not always useful on SMP systems, since it usually ends up showing the backtrace of a CPU that is doing just fine, instead of the backtrace of the CPU that is having problems. This patch adds SysRQ show-all-cpus(L), which shows the backtrace of every active CPU in the system. It skips idle CPUs because some SMP systems are just too large and we already know what the backtrace of the idle task looks like. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Rik van Riel <riel@redhat.com> Randy Dunlap <randy.dunlap@oracle.com> Cc: <lwoodman@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29drivers/misc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-29firmware: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Doug Warzecha <Douglas_Warzecha@dell.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proper extern for late_time_initAdrian Bunk
Add a proper extern for late_time_init in include/linux/init.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29exec: remove argv_len from struct linux_binprmTetsuo Handa
I noticed that 2.6.24.2 calculates bprm->argv_len at do_execve(). But it doesn't update bprm->argv_len after "remove_arg_zero() + copy_strings_kernel()" at load_script() etc. audit_bprm() is called from search_binary_handler() and search_binary_handler() is called from load_script() etc. Thus, I think the condition check if (bprm->argv_len > (audit_argv_kb << 10)) return -E2BIG; in audit_bprm() might return wrong result when strlen(removed_arg) != strlen(spliced_args). Why not update bprm->argv_len at load_script() etc. ? By the way, 2.6.25-rc3 seems to not doing the condition check. Is the field bprm->argv_len no longer needed? Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Ollie Wild <aaw@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Remove the macro get_personalityWANG Cong
Remove the macro get_personality, use ->personality instead. Cc: Christoph Hellwig <hch@infradead.org Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Misc: phantom, consistent whitespacejan sonnek
Make it consistent with the rest of the header. Signed-off-by: jan sonnek <xsonnek@gmail.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Misc, phantom, fix pollJiri Slaby
Return ERR even if there are pending data, but hw is not running. Do not decrement count in poll, do it in ioctl, where data are actually read. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Misc: phantom, add compat ioctlJiri Slaby
Openhaptics uses pointers in _IOC() macros, implement compat for them. Also add _IOC alternatives which are not 32/64 bit dependent (structures passed through aren't yet) -- libphantom will use them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proper __do_softirq() prototypeAdrian Bunk
Add a proper prototype for __do_softirq() in include/linux/interrupt.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29fs/affs/file.c: use BUG_ONJulia Lawall
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no side-effects to allow a definition of BUG_ON that drops the code completely. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ disable unlikely @ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (unlikely(E)) { BUG(); } + BUG_ON(E); ) @@ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (E) { BUG(); } + BUG_ON(E); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Simplify initcall_debug outputBjorn Helgaas
print_fn_descriptor_symbol() prints the address if we don't have a symbol, so no need to print both. Also, combine printing return value with elapsed time. Changes this: Calling initcall 0xc05b7a70: pci_mmcfg_late_insert_resources+0x0/0x50() initcall 0xc05b7a70: pci_mmcfg_late_insert_resources+0x0/0x50() returned 1. initcall 0xc05b7a70 ran for 0 msecs: pci_mmcfg_late_insert_resources+0x0/0x50() initcall at 0xc05b7a70: pci_mmcfg_late_insert_resources+0x0/0x50(): returned with error code 1 to this: calling pci_mmcfg_late_insert_resources+0x0/0x50() initcall pci_mmcfg_late_insert_resources+0x0/0x50() returned 1 after 0 msecs initcall pci_mmcfg_late_insert_resources+0x0/0x50() returned with error code 1 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29lib/inflate.c: handle failed malloc()Jim Meyering
lib/inflate.c (inflate_dynamic): Don't deref NULL upon failed malloc. Signed-off-by: Jim Meyering <meyering@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29hfsplus: handle match_strdup failureJim Meyering
fs/hfsplus/options.c (hfsplus_parse_options): Handle match_strdup failure. Signed-off-by: Jim Meyering <meyering@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
