Our current TKIP code races against itself on TX
since we can process multiple packets at the same
time on different ACs, but they all share the TX
context for TKIP. This can lead to bad IVs etc.
Also, the crypto offload helper code just obtains
the P1K/P2K from the cache, and can update it as
well, but there's no guarantee that packets are
really processed in order.
To fix these issues, first introduce a spinlock
that will protect the IV16/IV32 values in the TX
context. This first step makes sure that we don't
assign the same IV multiple times or get confused
in other ways.
Secondly, change the way the P1K cache works. I
add a field "p1k_iv32" that stores the value of
the IV32 when the P1K was last recomputed, and
if different from the last time, then a new P1K
is recomputed. This can cause the P1K computation
to flip back and forth if packets are processed
out of order. All this also happens under the new
spinlock.
Finally, because there are argument differences,
split up the ieee80211_get_tkip_key() API into
ieee80211_get_tkip_p1k() and ieee80211_get_tkip_p2k()
and give them the correct arguments.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/luca/wl12xx
Split tx_queue_count to count per-AC skb's queued, instead of relying on
the skb-queue len. The skb queues used were only valid in STA-mode, as
AP-mode uses per-link queues.
This fixes a major regression in AP-mode, caused by the patch
"wl12xx: implement Tx watermarks per AC". With that patch applied, we
effectively had no regulation of Tx queues in AP-mode. Therefore a
sustained high rate of Tx could cause exhaustion of the skb memory pool.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
Implementing this callback function will cause mac80211 refrain from
going to powersave state when there are still untransmitted TX frames
in the queues.
This would exactly mimic the behaviour of the legacy vendor driver which
also doesn't go in powersave mode if there are still TX frames that are not
transmitted.
This should make powersaving and rt2x00 a better couple.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Sitecom WLA4000 (USB ID 0x0df6:0x0060) is an RT3072 chipset.
Sitecom WLA5000 (USB ID 0x0df6:0x0062) is an RT3572 chipset.
Reported-by: Wim Vander Schelden <wim@fixnum.org>
Currently a lot of actions that can be done without the queue's tx lock
being held are done inside the locked area.
Move them out to have a leaner and meaner code that operates while the
tx lock is being held.
The functions that create the tx descriptor structure do not operate on
a queue entry at all. Signal this fact in the code by not providing a
queue entry as a parameter, but the rt2x00 device structure and the skb
directly.
This patch is a preparation for reducing the time a queue is locked for
a tx operation.
The rt2x00 driver gets frequent occurrences of the following error message
when operating under load:
phy0 -> rt2x00queue_write_tx_frame: Error - Arrived at non-free entry in the
non-full queue 2.
This is caused by simultaneous attempts from mac80211 to send a frame via
rt2x00, which are not properly serialized inside rt2x00queue_write_tx_frame,
causing the second frame to fail sending with the above mentioned error
message.
Fix this by introducing a per-queue spinlock to serialize the TX operations
on that queue.
Reported-by: Andreas Hartmann <andihartmann@01019freenet.de>
We must not init it like clientmode one, it would break device (tested
by Hauke on BCM4718). Add stub hostmode driver for now.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
The SDIO aggregation buffer size has been modified to an optimum
value which gives good throughput results.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
There is a stray "undefined" string in the array, get rid of it.
Cc: "John W. Linville" <linville@tuxdriver.com>
This adds the necessary mac80211 APIs to support
GTK rekey offload, mirroring the functionality
from cfg80211.
In certain circumstances, like WoWLAN scenarios,
devices may implement (partial) GTK rekeying on
the device to avoid waking up the host for it.
In order to successfully go through GTK rekeying,
the KEK, KCK and the replay counter are required.
Add API to let the supplicant hand the parameters
to the driver which may store it for future GTK
rekey operations.
Note that, of course, if GTK rekeying is done by
the device, the EAP frame must not be passed up
to userspace, instead a rekey event needs to be
sent to let userspace update its replay counter.
When in suspend/wowlan, devices might implement crypto
offload differently (more features), and might require
reprogramming keys for the WoWLAN (as it is the case
for Intel devices that use another uCode image). Thus
allow the driver to iterate all keys in this context.
The PCIE capability offset is saved during PCI bus walking. It will
remove an unnecessary search in the PCI configuration space if this
value is referenced instead of reacquiring it.
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
The SSB code reads PCI subsystem IDs from the PCI configuration registers while
they are already stored by the PCI subsystem in the 'subsystem_{vendor|device}'
fields of 'struct pci_dev'...
The SSB code reads PCI revision ID from the PCI configuration register while
it's already stored by the PCI subsystem in the 'revision' field of 'struct
pci_dev'...
This adds a memory barrier to ensure the writes to the ring memory
are committed before the DMA ring pointer is updated.
We do a similar thing on the TX side already.
Signed-off-by: Michael Buesch <m@bues.ch>
Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org>
Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org>
This socket protocol is used to perform data exchange with NFC
targets.
The NFC generic netlink interface exports the NFC control operations
to the user space.
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
The NFC subsystem core is responsible for providing the device driver
interface. It is also responsible for providing an interface to the control
operations and data exchange.
If the driver can't support WoWLAN in the current
state, this patch allows it to return 1 from the
suspend callback to do the normal deconfiguration
instead of using suspend/resume calls. Note that
if it does this, resume won't be called.
The SSB code reads PCI revision ID register as 16-bit entity while the register
is actually 8-bit only (the next 8 bits are the programming interface register).
Fix the read and make the 'rev' field of 'struct ssb_boardinfo' 8-bit as well,
to match the register size.
In routine rtl92de_hw_init(), there are two places where a failure is
not handled correctly.
Reported-by: Dan Carpenter <error27@gmail.com>
There are a number of loops to implement delays. These are replaced with
single calls to mdelay().
The need for a fix was noted by Andrew Morton <akpm@linux-foundation.org>.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
Tests of a boolean against "true" are not needed as non-zero is sufficient..
This should be unnecessary if synchronize_irq is used.
Signed-off-by: Mike McCormack <mikem@ring3k.org>
Prepare rtl8192de for the removal of irq_enaqbled.
ERROR: "__bad_udelay" [drivers/net/wireless/rtlwifi/rtl8192de/rtl8192de.ko] undefined!
mlme.c
l.757 ieee80211_dynamic_ps_enable_work(11)
variable dereferenced before check 'sdata'
mesh_pathtbl.c
l.650 mesh_path_del(20) double lock 'bottom_half'
l.663 mesh_path_del(33) double unlock 'bottom_half'
This patch imports all shared header changes
from carl9170fw.git.
* update copyright boilerplate
* add some more strategic __aligned(4).
* WoWLAN
If the 'driver_initiated' function argument to
__cfg80211_stop_sched_scan() is not 0 then we'll return an
uninitialized 'err' from the function.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Based on inputs from Johannes Berg <johannes@sipsolutions.net>
from http://article.gmane.org/gmane.linux.kernel.wireless.general/68193
and http://article.gmane.org/gmane.linux.kernel.wireless.general/71702
In xmit path, devices that do full hardware crypto (including
MMIC and ICV) need no tailroom. For such devices, tailroom
reservation can be skipped if all the keys are programmed into
the hardware (i.e software crypto is not used for any of the
keys) and none of the keys wants software to generate Michael
MIC and IV.
v2: Added check for IV along with MMIC.
Reported-by: Fabio Rossi <rossi.f@inwind.it>
Tested-by: Fabio Rossi <rossi.f@inwind.it>
Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com>
Cc: Mohammed Shafi Shajakhan <mshajakhan@atheros.com>
v3: Fixing races to avoid WARNING: at net/mac80211/wpa.c:397
ccmp_encrypt_skb+0xc4/0x1f0
Tested-by: Andreas Hartmann <andihartmann@01019freenet.de>
v4: Added links with message ID
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
Sometimes we only get the Tx power level via op->config when the FW is
off. Record the received power level when this happens and use it to
initialize the firmware during boot.
Set the maximum FW supported power levels for 11a channels.
After implementing cancel_hw_scan(), there is no more need to
flush scan_complete_work on suspend.
scan_complete_work enqueues a new scan_work, that might lead
to the following warning (if the device was already suspended):
WARNING: at drivers/mmc/core/core.c:169 mmc_wait_for_req+0x1ac/0x2c8()
Backtrace:
[<c004b50c>] (dump_backtrace+0x0/0x110)
[<c04fda50>] (dump_stack+0x0/0x1c)
[<c008f700>] (warn_slowpath_common+0x0/0x6c)
[<c008f76c>] (warn_slowpath_null+0x0/0x2c)
[<c034b058>] (mmc_wait_for_req+0x0/0x2c8)
[<c034f804>] (mmc_io_rw_extended+0x0/0x1e4)
[<c0350b5c>] (sdio_io_rw_ext_helper+0x0/0x1ac)
[<c0350e00>] (sdio_memcpy_fromio+0x0/0x2c)
[<bf194464>] (wl1271_sdio_raw_read+0x0/0x1bc [wl12xx_sdio])
[<bf15ac14>] (wl1271_cmd_wait_for_event_or_timeout+0x0/0x19c [wl12xx])
[<bf15adb0>] (wl1271_cmd_wait_for_event+0x0/0x30 [wl12xx])
[<bf15b7dc>] (wl1271_cmd_disconnect+0x0/0x14c [wl12xx])
[<bf158fd0>] (wl1271_unjoin+0x0/0x48 [wl12xx])
[<bf159070>] (wl1271_op_config+0x0/0x490 [wl12xx])
[<bf105084>] (ieee80211_hw_config+0x0/0x14c [mac80211])
[<bf113120>] (ieee80211_recalc_idle+0x0/0x4c [mac80211])
[<bf109a70>] (__ieee80211_scan_completed+0x0/0x1ac [mac80211])
[<bf109fd4>] (ieee80211_scan_work+0x0/0x484 [mac80211])
[<c00a197c>] (worker_thread+0x0/0x1e8)
[<c00a5874>] (kthread+0x0/0x90)
Signed-off-by: Eliad Peller <eliad@wizery.com>
define wl1271_scan_stop() to cancel an ongoing hw scan.
Configure the device (to wowlan) only if the sta/ap
is associated/started.
Skip manual device power on in case runtime PM is enabled for
our device.
This eliminates a secondary & redundant SDIO init sequence.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Each AC is stopped when its queue is filled up to the high watermark,
and restarted when its queue it lower than the low watermark. This
ensures congested ACs are not able to starve other ACs.
