2006-01-03[ALSA] Remove xxx_t typedefs: PowerMacTakashi Iwai
Remove xxx_t typedefs from the PowerMac driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: USB-USX2YTakashi Iwai
Modules: USB USX2Y Remove xxx_t typedefs from the USB-USX2Y driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: USB-AudioTakashi Iwai
Modules: USB generic driver Remove xxx_t typedefs from the USB-Audio driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCMCIA PDaudioCFTakashi Iwai
Modules: PDAudioCF driver Remove xxx_t typedefs from the PCMCIA PDaudioCF driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI VIA82xxTakashi Iwai
Modules: VIA82xx driver,VIA82xx-modem driver Remove xxx_t typedefs from the PCI VIA82xx and modem drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI SonicvibesTakashi Iwai
Modules: SonicVibes driver Remove xxx_t typedefs from the PCI Sonicvibes driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI RME96Takashi Iwai
Modules: RME96 driver Remove xxx_t typedefs from the PCI RME96 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI RME32Takashi Iwai
Modules: RME32 driver Remove xxx_t typedefs from the PCI RME32 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI Maestro3Takashi Iwai
Modules: Maestro3 driver Remove xxx_t typedefs from the PCI Maestro3 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI Intel8x0Takashi Iwai
Modules: Intel8x0 driver,Intel8x0-modem driver Remove xxx_t typedefs from the PCI Intel8x0 and modem drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI FM801Takashi Iwai
Modules: FM801 driver Remove xxx_t typedefs from the PCI FM801 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ES1968Takashi Iwai
Modules: ES1968 driver Remove xxx_t typedefs from the PCI ES1968 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ES1938Takashi Iwai
Modules: ES1938 driver Remove xxx_t typedefs from the PCI ES1938 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ENS137xTakashi Iwai
Modules: ENS1370/1+ driver Remove xxx_t typedefs from the PCI ENS137x drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI CS4281Takashi Iwai
Modules: CS4281 driver Remove xxx_t typedefs from the PCI CS4281 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI CMIPCITakashi Iwai
Modules: CMIPCI driver Remove xxx_t typedefs from the PCI CMIPCI driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI BT87xTakashi Iwai
Modules: BT87x driver Remove xxx_t typedefs from the PCI BT87x driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI AZT3328Takashi Iwai
Modules: AZT3328 driver Remove xxx_t typedefs from the PCI AZT3328 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ATIIXPTakashi Iwai
Modules: ATIIXP driver,ATIIXP-modem driver Remove xxx_t typedefs from the PCI ATIIXP and modem drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ALS4000Takashi Iwai
Modules: ALS4000 driver Remove xxx_t typedefs from the PCI ALS4000 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI AD1889Takashi Iwai
Modules: AD1889 driver Remove xxx_t typedefs from the PCI AD1889 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI NM256Takashi Iwai
Modules: NM256 driver Remove xxx_t typedefs from the PCI NM256 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI miXartTakashi Iwai
Modules: MIXART driver Remove xxx_t typedefs from the PCI miXart driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI KORG1212Takashi Iwai
Modules: KORG1212 driver Remove xxx_t typedefs from the PCI KORG1212 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ICE1724Takashi Iwai
Modules: ICE1724 driver,ICE1712 driver Remove xxx_t typedefs from the PCI ICE1724 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ICE1712Takashi Iwai
Modules: ICE1712 driver Remove xxx_t typedefs from the PCI ICE1712 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: HDA-IntelTakashi Iwai
Modules: HDA Intel driver Remove xxx_t typedefs from the HDA-Intel driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: HD-Audio codecTakashi Iwai
Modules: HDA Codec driver,HDA generic driver Remove xxx_t typedefs from the HD-Audio codec support codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI CS5535Takashi Iwai
Modules: CS5535 driver Remove xxx_t typedefs from the PCI CS5535 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ALI5451Takashi Iwai
Modules: ALI5451 driver Remove xxx_t typedefs from the PCI ALI5451 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI CA0106Takashi Iwai
Modules: CA0106 driver Remove xxx_t typedefs from the PCI CA0106 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI AU88x0Takashi Iwai
Modules: au88x0 driver Remove xxx_t typedefs from the PCI AU88x0 drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI YMFPCITakashi Iwai
Modules: YMFPCI driver Remove xxx_t typedefs from the PCI YMFPCI driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI TridentTakashi Iwai
Modules: Trident driver Remove xxx_t typedefs from the PCI Trident driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI RME9652Takashi Iwai
Modules: RME9652 driver Remove xxx_t typedefs from the PCI RME9652 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI HDSP-MADITakashi Iwai
Modules: HDSPM driver,RME9652 driver Remove xxx_t typedefs from the PCI HDSP-MADI driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI HDSPTakashi Iwai
Modules: RME HDSP driver Remove xxx_t typedefs from the PCI HDSP driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI emu10k1xTakashi Iwai
Modules: EMU10K1/EMU10K2 driver Remove xxx_t typedefs from the PCI emu10k1x driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI emu10k1Takashi Iwai
Modules: EMU10K1/EMU10K2 driver Remove xxx_t typedefs from the PCI emu10k1 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI CS46xxTakashi Iwai
Modules: CS46xx driver Remove xxx_t typedefs from the PCI CS46xx driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: VXdriverTakashi Iwai
Remove xxx_t typedefs from the VXdriver codes (vx_core support, vx222 and vxpocket). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: AK4531 codecTakashi Iwai
Modules: AK4531 codec Remove xxx_t typedefs from the AK4531 codec support code. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA SB/AD-cloneTakashi Iwai
Modules: ALS100 driver,AZT2320 driver,DT019x driver,Sound Galaxy driver Remove xxx_t typedefs from the ISA SB/AD-clone drivers (als100, azt2320, dt019x, sgalaxy). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA SoundScapeTakashi Iwai
Modules: Sound Scape driver Remove xxx_t typedefs from the ISA SoundScape driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA OPL3SA2Takashi Iwai
Modules: OPL3SA2 driver Remove xxx_t typedefs from the ISA OPL3SA2 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA ES18xxTakashi Iwai
Modules: ES18xx driver Remove xxx_t typedefs from the ISA ES18xx driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA CMI8330Takashi Iwai
Modules: CMI8330 driver Remove xxx_t typedefs from the ISA CMI8330 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA WavefrontTakashi Iwai
Modules: Wavefront drivers Remove xxx_t typedefs from the ISA Wavefront driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA Opti9xxTakashi Iwai
Modules: Opti9xx drivers Remove xxx_t typedefs from the ISA Opti 9xx drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA GUSTakashi Iwai
Remove xxx_t typedefs from the ISA GUS drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
