The code to print out TX failure reasons is
AGN specific, so it can be in the AGN module.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
By duplicating a little bit of code between 3945
and agn, we can move a lot of code into an agn
specific station management file and thus reduce
the amount of code in core that is dead to 3945.
before:
212886 3872 96 216854 34f16 iwlcore.ko
620542 10448 304 631294 9a1fe iwlagn.ko
314013 3264 196 317473 4d821 iwl3945.ko
after:
202857 3872 92 206821 327e5 iwlcore.ko
629102 10448 308 639858 9c372 iwlagn.ko
314240 3264 196 317700 4d904 iwl3945.ko
delta:
-10029 iwlcore.ko
8560 iwlagn.ko
227 iwl3945.ko
so it's a net win even if you have both loaded,
likely because a lot of EXPORT_SYMBOLs go away.
All drivers share the same implementation, so
there's no need to call this via a function
pointer nor to export it.
Rename iwl_mac_beacon_update to iwlcore_beacon_update
and make the calling convention a bit different. The
old name with _mac_ indicated that it was a mac80211
callback, but that's no longer true.
The core module doesn't need to carry around
the code for chain settings that is used for
HT drivers (agn) only.
There's no need to go via the indirect function
call from within the 3945 subdriver.
The different drivers need to do different things
after a scan, so create a post_scan hook to allow
them to do this.
iwl_commit_rxon really should be named
iwlagn_commit_rxon, so rename it.
The following commit removed DISABLE_REGWRITE_BUFFER ops. The unnecessary
REGWRITE_BUFFER_FLUSH was not removed properly which is causing failure on
hw reset.
Author: Felix Fietkau <nbd@openwrt.org>
Date: Tue Oct 5 12:03:42 2010 +0200
ath9k_hw: clean up register write buffering
Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com>
There's no need for the WDS peer address
to not be const, so make it const.
Bill Jordan's patch to allow setting the WDS
peer crossed with my patch removing all the
boilerplate code in nl80211, and consequently
he didn't make use of it yet. Fix that.
The recent scan overhaul broke locking
because now we can jump to code that
attempts to unlock, while we don't have
the mutex held. Fix this by holding the
mutex around all the relevant code.
Reported-by: Ben Greear <greearb@candelatech.com>
In the NVS/INI-parameters for the driver/firmware there is the FEM
(front end module) selection option, which may configure the hardware FEM
via autodetection or manual selection. So far, there has been support for
manual selection only.
Add support for FEM autodetection.
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-2.6
This reverts commit 5ed3bc7288487bd4f891f420a07319e0b538b4fe.
It turns-out that not all drivers are calling ieee80211_tx_status from a
compatible context. Revert this for now and try again later...
This reverts commit 030725d2c7c1fafec7ede618647bf30ed79601f0.
This commit relies on commit 5ed3bc7288487bd4f891f420a07319e0b538b4fe
("mac80211: use netif_receive_skb in ieee80211_tx_status callpath")
Unfortunately not all drivers are calling ieee80211_tx_status from a
compatible context, so that commit needs to be reverted in 2.6.36.
Adding MODULE_FIRMWARE define for 130 series of devices
130 series device should use firmware name with 130 in it.
net/mac80211/scan.c: In function ‘ieee80211_scan_cancel’:
net/mac80211/scan.c:794: warning: ‘finish’ may be used uninitialized in this function
When multiple interfaces are actively trying
to associate with the same BSS, they may both
find that the BSS isn't there and then try to
unlink it. This can cause errors since the
unlinking code can't currently deal with items
that have already been unlinked.
Normally this doesn't happen as most people
don't try to use multiple station interfaces
that associate at the same time too.
Fix this by using the list entry as a flag to
see if the item is still on a list.
Cc: stable@kernel.org
Tested-by: Hun-Kyi Wynn <hkwynn@candelatech.com>
This information is already available in mac80211, we just need to export it
via cfg80211 and nl80211.
Signed-off-by: Bruno Randolf <br1@einfach.org>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
This reverts commit 7acc7c683a747689aaaaad4fce1683fc3f85e552. It was
applied to avoid possible warning in ieee80211_restart_hw, however
reason of the warning were races in mac80211, currently hopefully fixed.
Not reseting device when performing scan is bad for two reasons.
When forcing reset from iwl_check_stuck_queue(), in case of fail,
reset will be repeated until scan finish. But since firmware is in bad
shape, scan only finish after scan_check work (about 7s). So we will
delay the reset, what is not good behaviour.
When forcing reset from iwl_recover_from_statistics(), we will not
repeat the reset, so we will not perform reset at all when needed.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
We nulify local->scan_req on failure in __ieee80211_start_scan, so
__ieee80211_scan_completed will not call cfg80211_scan_done. Fix that.
When performing hw scan and not abort it, __ieee80211_scan_completed()
is currently called from scan work, so does not need to reschedule work
to call drv_hw_scan().
This is partial revert and fix for commit
85f72bc839705294b32b6c16b491c0422f0a71b3 "mac80211: only cancel
software-based scans on suspend"
When cfg80211 request the scan and mac80211 perform some management work,
we defer the scan request. We do not canceling such requests when calling
ieee80211_scan_cancel(), because of SCAN_SW_SCANNING bit check just
before the call. So fix that problem.
Another problem, which commit 85f72bc839705294b32b6c16b491c0422f0a71b3
tries to solve, is we can not cancel HW scan. Hence patch make
ieee80211_scan_cancel() ignore HW scan (see code comments). Keeping
local->mtx lock assures that the deferred scan will not become
"working" HW scan.
We are taking local->mtx inside __ieee80211_scan_completed(), but just
before call to that function we drop the lock. Dropping/taking lock is not
good, because can lead to hard to understand race conditions.
Patch split scan_completed() code into two functions, first must be called
with local->mtx taken and second without it.
Use goto instruction to call __ieee80211_scan_completed only ones in
ieee80211_scan_work. This is prepare for the next patch.
It's already set in PHY common code.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Yikes! The error return keeps a netdev reference
and the rdev mutex locked, fix that!
This adds API to allow adding per-station GTKs,
updates mac80211 to support it, and also allows
drivers to remove a key from hwaccel again when
this may be necessary due to multiple GTKs.
When roaming while we have active BA session,
we can end up transmitting delBA frames to
the old AP while we're already on the new AP's
channel, which can cause warnings.
Simply avoid sending those frames, but still
tear down the internal session state, since
they are not really necessary anyway as we
will implicitly disassociate when sending the
association to the new AP.
Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com>
drv_config callback is called only after the ack for the nullframe
is received and so driver need not do anything special for this.
So remove NULLFUNC_COMPLETED, PS_ENABLED flags and bf_isnullfunc
flags from ath9k as mac80211 already handles them properly.
After the last rounds of cleanup, these functions are now functionally
equivalent and can thus be merged.
Also get rid of some excessive (and redundant) debug messages.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
The code gets more concise and readable when making the new ANI functions
fall back to the old ones if ANI v2 is disabled. This also makes further code
cleanup easier.
Split out the PHY error counter update from ath9k_hw_ani_monitor_*, reuse
it in ath9k_hw_proc_mib_event (merged from ath9k_hw_proc_mib_event_old
and ath9k_hw_proc_mib_event_new).
ANI state is kept per channel, so instead of keeping an array of ANI states
with an arbitrary size of 255, move the ANI state into the channel struct.
Move some config settings that are not per-channel out of
the per-channel struct to save some memory.
With those changes, ath9k_ani_restart_old and ath9k_ani_restart_new can
be merged into a single function.
Throughout the code, DISABLE_REGWRITE_BUFFER is always called right after
REGWRITE_BUFFER_FLUSH. Since that's unlikely to change any time soon, that
makes keeping those ops separate rather pointless, as it only increases
code size and line number counts.
The cycle counters are used by ANI to determine the amount of time that the
radio spent not receiving or transmitting. They're also used for debugging
purposes if the baseband watchdog on AR9003 detects a lockup.
In the future, we want to use these counters to determine the medium utilization
and export this information via survey. For that, we need to make sure that
the counter is only accessed from one place, which also ensures that
wraparounds won't occur at inconvenient points in time.
The calibration actual calibration flags are only used by the per chip family
source files, so it makes more sense to define them in those files instead
of globally. That way the code has to test for less flags.
Also instead of using a separate callback for testing whether a particular
calibration type is supported, simply adjust ah->supp_cals in the calibration
init which is called right after the hardware reset, before any of the
calibrations are run.
We never delete the addBA response timer, which
is typically fine, but if the station it belongs
to is deleted very quickly after starting the BA
session, before the peer had a chance to reply,
the timer may fire after the station struct has
been freed already. Therefore, we need to delete
the timer in a suitable spot -- best when the
session is being stopped (which will happen even
then) in which case the delete will be a no-op
most of the time.
I've reproduced the scenario and tested the fix.
This fixes the crash reported at
http://mid.gmane.org/4CAB6F96.6090701@candelatech.com
wireless-testing
commit 37e5bf6535a4d697fb9fa6f268a8354a612cbc00
Author: Luis R. Rodriguez <lrodriguez@atheros.com>
Date: Sat Jun 12 00:33:40 2010 -0400
ath9k_hw: fix clock rate calculations for ANI
This commit accidentally broke clock rate calculation by doubling the
calculated clock rate
add new structures and defines need to identify 130 devices.
iwl5000_tx_resp really should be iwlagn_tx_resp, rename it.
some structure belong to _agn devices, not just 5000. Fix it.
