This makes things easier to track down, especially in modules.
sunsab_init_one() needs to be __devinit, not __init
1) Need to unregister 2 ports per of_device.
2) Need to of_iounmap() 1 mapping per of_device.
3) Need to free up the IRQ only after all devices
have been unregistered.
Happily, life is much simpler on 32-bit sparc systems.
The "intr" property, preferred over the "interrupts"
property is used-as. Some minor translations of this
value happen on sun4d systems.
The stage is now set to rewrite the sparc serial driver
probing to use the of_driver framework, and then to convert
all SBUS, EBUS, and ISA drivers in-kind so that we can nuke
all those special bus frameworks.
Do IRQ determination generically by parsing the PROM properties,
and using IRQ controller drivers for final resolution.
One immediate positive effect is that all of the IRQ frobbing
in the EBUS, ISA, and PCI controller layers has been eliminated.
We just look up the of_device and use the properly computed
value.
The PCI controller irq_build() routines are gone and no longer
used. Unfortunately sbus_build_irq() has to remain as there is
a direct reference to this in the sunzilog driver. That can be
killed off once the sparc32 side of this is written and the
sunzilog driver is transformed into an "of" bus driver.
This needs to be a unique interrupt source because we do
not have a register or similar to poll to make sure the
IRQ is really for us. We do not have any dev_id to pass
in anyways, and the generic IRQ layer is now enforcing
that when SA_SHIRQ is specified, dev_id must be non-NULL.
On sparc64 we don't need to do this because the resource
values are large enough to encode the full physical address.
The idea is to fully construct the device register and
interrupt values into these of_device objects, and convert
all of SBUS, EBUS, ISA drivers to use this new stuff.
Much ideas and code taken from Ben H.'s powerpc work.
Totally unused.
We need to traverse the list of global IRQ translaters,
so storing it in the per-bus structures was useless.
Signed-off-by: Florin Malita <fmalita@gmail.com>
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Get rid of osb->uuid, osb->proc_sub_dir, and osb->osb_id. Those fields were
unused, or could easily be removed. As a result, we also no longer need
MAX_OSB_ID or ocfs2_globals_lock.
ocfs2_initialize_super() should be copying from the beginning of the uuid.
Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
dlm_lockres_master_requery() became global without any external usage.
Print a warning to the user when a node with a different dead count joins
the region.
Give gcc the chance to compile out the debug logging code in ocfs2.
This saves some size at the expense of being able to debug the code.
The configfs_example module was missing a ->release().
This fixes pxa2xx_udc.c to include asm/arch/udc.h again to fix current
build breakage.
Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com>
[ forwarded by David Brownell <david-b@pacbell.net> ]
[ fixed to apply properly by Linus ]
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits)
[PATCH] devfs: Remove it from the feature_removal.txt file
[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.
[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV
[PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed
[PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed
[PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed
[PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed
[PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed
[PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree
[PATCH] devfs: Remove devfs_remove() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree
[PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree
[PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree
[PATCH] devfs: Remove devfs support from the sound subsystem
[PATCH] devfs: Remove devfs support from the ide subsystem.
[PATCH] devfs: Remove devfs support from the serial subsystem
[PATCH] devfs: Remove devfs from the init code
[PATCH] devfs: Remove devfs from the partition code
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart:
[AGPGART] Make AGP depend on PCI
[AGPGART] remove unused variable
[AGPGART] Fix pci_register_driver checking in amd64-agp
[AGPGART] Compile fix for ati-agp
[AGPGART] Suspend/Resume support for nVidia nForce AGP.
[AGPGART] Suspend/Resume improvements for ATI AGP
[AGPGART] Whitespace cleanups for ati-agp
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (33 commits)
[MIPS] Add missing backslashes to macro definitions.
[MIPS] Death list of board support to be removed after 2.6.18.
[MIPS] Remove BSD and Sys V compat data types.
[MIPS] ioc3.h: Uses u8, so include <linux/types.h>.
[MIPS] 74K: Assume it will also have an AR bit in config7
[MIPS] Treat CPUs with AR bit as physically indexed.
[MIPS] Oprofile: Support VSMP on 34K.
[MIPS] MIPS32/MIPS64 S-cache fix and cleanup
[MIPS] excite: PCI makefile needs to use += if it wants a chance to work.
[MIPS] excite: plat_setup -> plat_mem_setup.
[MIPS] au1xxx: export dbdma functions
[MIPS] au1xxx: dbdma, no sleeping under spin_lock
[MIPS] au1xxx: fix PSC_SMBTXRX_RSR.
[MIPS] Early printk for IP27.
[MIPS] Fix handling of 0 length I & D caches.
[MIPS] Typo fixes.
[MIPS] MIPS32/MIPS64 secondary cache management
[MIPS] Fix FIXADDR_TOP for TX39/TX49.
[MIPS] Remove first timer interrupt setup in wrppmc_timer_setup()
[MIPS] Fix configuration of R2 CPU features and multithreading.
As usual fixes would be prefered.
