Linux 3.1.9
Makefile
Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648
Bug 886806
Original commit: http://git-master/r/59905
Change-Id: Ia8d64f3810d6157c6029180cd9a3cf98c2d3cb4c
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/74896
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Add regulator changes needed to support TPS65090.
bug 909648
Change-Id: Ia88e6706051f7a7e920b01c656f64385b98fc33a
Signed-off-by: venu byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/73144
Reviewed-on: http://git-master/r/74895
This PMIC MFD driver provides-
PMIC register read/write access
support for interrupt handling.
bug 909648
Change-Id: I7f1a22e055b08b9cd31e987c94589c2a8c857d73
Reviewed-on: http://git-master/r/73135
Reviewed-on: http://git-master/r/74894
(see bug for Excel with the new spec)
Bug 844268
Change-Id: I7a3bdd674b987c2edd540de7764e01338f66c0ac
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/74094
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/74893
Added dtv device to cardhu board
Fixed Bug 904626
Fixed Bug 881303
Change-Id: If1560cc8101403720c46b318c76326621c889154
Signed-off-by: Adam Jiang <chaoj@nvidia.com>
Reviewed-on: http://git-master/r/68145
Reviewed-by: Simone Willett <swillett@nvidia.com>
Reviewed-on: http://git-master/r/74892
Tegra2/3 has a dedicated Digital TV interface for receiving serial TS
stream. This is the initial version for the DTV interface. The driver
provided a device node as /dev/tegra_dtv and enabled several ioctls to
configure hardware. User land applications could get serial TS data via
system call read() on the device node. The read() operation is blocked
io.
Fixed Bug 904626
Fixed Bug 881303
Change-Id: Iad4629bed3c4c959b9178b387b084cdeaf7c3f69
Reviewed-on: http://git-master/r/66625
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/74891
Added dtv interface device to Tegra3 platform.
Fixed Bug 904626
Fixed Bug 881303
Change-Id: Id2a4e6f015d3edf1ecd0e76f5586ae2ec00ed380
Reviewed-on: http://git-master/r/66627
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Reviewed-on: http://git-master/r/74890
In evdev_read() the local variable retval is not initialized.
If this variable is not initialized then in case of NONBLOCK READ
retval will have invalid value.
Bug: 922453
Change-Id: I534cbfacf8a0514fcb5bc481a98d0e94a4d73b04
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/74898
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Tested-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-by: Yogish Kulkarni <yogishk@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
MMC_STATE_ULTRAHIGHSPEED is used to report the speed
mode of the UHS cards.
Bug 920089
Reviewed-on: http://git-master/r/73987
Change-Id: I521e4d52ee63d6a83cb801d6fb45ec7e2b627d65
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-on: http://git-master/r/74582
Table 6-2: CCCR bit Definitions, address 00h. Part E1 SDIO Simplified
Specification Version 3.00, Feb. 25, 2011.
This patch has been tested with Marvell WLAN device SD8797.
Reviewed-on: http://git-master/r/72877
Change-Id: I1ea3b63bde2bbe8532459205f61feffae3e30f0a
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Reviewed-on: http://git-master/r/74581
This patch adds support for sdio UHS cards per the version 3.0
spec.
UHS mode is only enabled for version 3.0 cards when both the
host and the controller support UHS modes.
1.8v signaling support is removed if both the card and the
host do not support UHS. This is done to maintain
compatibility and some system/card combinations break when
1.8v signaling is enabled when the host does not support UHS.
Reviewed-on: http://git-master/r/72876
Change-Id: I8d7dbaf1d1cbff8e9f13526d39e69b2a00eca2fa
Signed-off-by: Philip Rakity <prakity@marvell.com>
Signed-off-by: Aaron Lu <Aaron.lu@amd.com>
Reviewed-by: Arindam Nath <arindam.nath@amd.com>
Tested-by: Bing Zhao <bzhao@marvell.com>
Reviewed-on: http://git-master/r/74580
Verify the handle during conversion from user space to kernel space.
Change-Id: I7cfcc791a792f20b2df195719e28a245ba820b4e
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/74467
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
commit 093019cf1b18dd31b2c3b77acce4e000e2cbc9ce upstream.
Commit fa8b18ed didn't prevent the integer overflow and possible
memory corruption. "count" can go negative and bypass the check.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit fa8b18edd752a8b4e9d1ee2cd615b82c93cf8bba upstream.
This prevents in-memory corruption and possible panics if the on-disk
ACL is badly corrupted.
[Not upstream s it was fixed differently there for 3.3 with a much more
"intrusive" rework of the driver - gregkh]
There is a race condition involving acm_tty_hangup() and acm_tty_close()
where hangup() would attempt to access tty->driver_data without proper
locking and NULL checking after close() has potentially already set it
to NULL. One possibility to (sporadically) trigger this behavior is to
perform a suspend/resume cycle with a running WWAN data connection.
This patch addresses the issue by introducing a NULL check for
tty->driver_data in acm_tty_hangup() protected by open_mutex and exiting
gracefully when hangup() is invoked on a device that has already been
closed.
Signed-off-by: Thilo-Alexander Ginkel <thilo@ginkel.com>
commit 9ae89b0296e275d5a556068b40b7c2557a556a85 upstream.
mpt2sas_base_detach() call was removed from _scsih_remove() while
doing some code shuffling. Mainly when we work on adding code for
scsih_shutdown(). I have added back mpt2sas_base_detach() which will
get callled from _scsih_remove().
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 79cfbdfa87e84992d509e6c1648a18e1d7e68c20 upstream.
The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down()
functions depend on the value of the 'tasks_frozen' argument passed to them
(which indicates whether tasks have been frozen or not).
(Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN,
CPU_DEAD, CPU_DEAD_FROZEN).
Thus, it is essential that while the callbacks for those notifications are
running, the state of the system with respect to the tasks being frozen or
not remains unchanged, *throughout that duration*. Hence there is a need for
synchronizing the CPU hotplug code with the freezer subsystem.
Since the freezer is involved only in the Suspend/Hibernate call paths, this
patch hooks the CPU hotplug code to the suspend/hibernate notifiers
PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent
the race between CPU hotplug and freezer, thus ensuring that CPU hotplug
notifications will always be run with the state of the system really being
what the notifications indicate, _throughout_ their execution time.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit f7d9821a6a9c83450ac35e76d3709e32fd38b76f upstream.
If slave device already has a receive handler registered, then the
error unwind of bonding device enslave function is broken.
The following will leave a pointer to freed memory in the slave
device list, causing a later kernel panic.
# modprobe dummy
# ip li add dummy0-1 link dummy0 type macvlan
# modprobe bonding
# echo +dummy0 >/sys/class/net/bond0/bonding/slaves
The fix is to detach the slave (which removes it from the list)
in the unwind path.
Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
commit 6c15d74defd38e7e7f8805392578b7a1d508097e upstream.
At this point if skb->len happens to be 2, the subsequant skb_pull(skb, 4)
call won't work and the skb->len won't be decreased and won't ever reach 0,
resulting in an infinite loop.
With an ASIX 88772 under heavy load, without this patch, rx_fixup() reaches
an infinite loop in less than a minute. With this patch applied,
no infinite loop even after hours of heavy load.
Signed-off-by: Aurelien Jacobs <aurel@gnuage.org>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
commit a8c1f65c79cbbb2f7da782d4c9d15639a9b94b27 upstream.
Commit 5b7c84066733c5dfb0e4016d939757b38de189e4 ('ipv4: correct IGMP
behavior on v3 query during v2-compatibility mode') added yet another
case for query parsing, which can result in max_delay = 0. Substitute
a value of 1, as in the usual v3 case.
Reported-by: Simon McVittie <smcv@debian.org>
References: http://bugs.debian.org/654876
commit c61875977458637226ab093a35d200f2d5789787 upstream.
Problems with NVIDIA's OHCI host controllers persist. After looking
carefully through the spec, I finally realized that when a controller
is reset it then automatically goes into a SUSPEND state in which it
is completely quiescent (no DMA and no IRQs) and from which it will
not awaken until the system puts it into the OPERATIONAL state.
Therefore there's no need to worry about controllers being in the
RESET state for extended periods, or remaining in the OPERATIONAL
state during system shutdown. The proper action for device
initialization is to put the controller into the RESET state (if it's
not there already) and then to issue a software reset. Similarly, the
proper action for device shutdown is simply to do a software reset.
This patch (as1499) implements such an approach. It simplifies
initialization and shutdown, and allows the NVIDIA shutdown-quirk code
to be removed.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Andre "Osku" Schmidt <andre.osku.schmidt@googlemail.com>
Tested-by: Arno Augustin <Arno.Augustin@web.de>
commit 18b7ede5f7ee2092aedcb578d3ac30bd5d4fc23c upstream.
[ removed the dwc3 portion of the patch as it didn't apply to
older kernels - gregkh]
According to USB 3.0 Specification Table 9-22, if
bmAttributes [4:0] are set to zero, it means "no
streams supported", but the way this helper was
defined on Linux, we will *always* have one stream
which might cause several problems.
For example on DWC3, we would tell the controller
endpoint has streams enabled and yet start transfers
with Stream ID set to 0, which would goof up the host
side.
While doing that, convert the macro to an inline
function due to the different checks we now need.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 3c8c9316710b83e906e425024153bf0929887b59 upstream.
Add support for Chinese Noname HSPA USB modem which is apparently
manufactured by a company called ZD Incorporated (based on texts in the
Windows drivers).
This product is available at least from Dealextreme (SKU 80032) and
possibly in India with name Olive V-MW250. It is based on Qualcomm
MSM6280 chip.
I needed to also add "options usb-storage quirks=0685:7000:i" in modprobe
configuration because udevd or the kernel keeps poking the embedded
fake-cd-rom which fails and causes the device to reset. There might be
a better way to accomplish the same. usb_modeswitch is not needed with
this device.
Signed-off-by: Janne Snabb <snabb@epipe.com>
commit 5b061623355d8f69327a24838b0aa05e435ae5d5 upstream.
Add VendorID/ProductID for USB 3G dongle Model VT1000 of Viettel.
Signed-off-by: VU Tuan Duc <ducvt@viettel.com.vn>
commit 71d85724bdd947a3b42a88d08af79f290a1a767b upstream.
I encountered a result of COMP_2ND_BW_ERR while improving how the pwc
webcam driver handles not having the full usb1 bandwidth available to
itself.
I created the following test setup, a NEC xhci controller with a
single TT USB 2 hub plugged into it, with a usb keyboard and a pwc webcam
plugged into the usb2 hub. This caused the following to show up in dmesg
when trying to stream from the pwc camera at its highest alt setting:
xhci_hcd 0000:01:00.0: ERROR: unexpected command completion code 0x23.
usb 6-2.1: Not enough bandwidth for altsetting 9
And usb_set_interface returned -EINVAL, which caused my pwc code to not
do the right thing as it expected -ENOSPC.
This patch makes the xhci driver properly handle COMP_2ND_BW_ERR and makes
usb_set_interface return -ENOSPC as expected.
This should be backported to stable kernels as old as 2.6.32.
commit bc677d5b64644c399cd3db6a905453e611f402ab upstream.
Add a new field num_mapped_sgs to struct urb so that we have a place to
store the number of mapped entries and can also retain the original
value of entries in num_sgs. Previously, usb_hcd_map_urb_for_dma()
would overwrite this with the number of mapped entries, which would
break dma_unmap_sg() because it requires the original number of entries.
This fixes warnings like the following when using USB storage devices:
WARNING: at lib/dma-debug.c:902 check_unmap+0x4e4/0x695()
ehci_hcd 0000:00:12.2: DMA-API: device driver frees DMA sg list with different entry count [map count=4] [unmap count=1]
Modules linked in: ohci_hcd ehci_hcd
Pid: 0, comm: kworker/0:1 Not tainted 3.2.0-rc2+ #319
Call Trace:
<IRQ> [<ffffffff81036d3b>] warn_slowpath_common+0x80/0x98
[<ffffffff81036de7>] warn_slowpath_fmt+0x41/0x43
[<ffffffff811fa5ae>] check_unmap+0x4e4/0x695
[<ffffffff8105e92c>] ? trace_hardirqs_off+0xd/0xf
[<ffffffff8147208b>] ? _raw_spin_unlock_irqrestore+0x33/0x50
[<ffffffff811fa84a>] debug_dma_unmap_sg+0xeb/0x117
[<ffffffff8137b02f>] usb_hcd_unmap_urb_for_dma+0x71/0x188
[<ffffffff8137b166>] unmap_urb_for_dma+0x20/0x22
[<ffffffff8137b1c5>] usb_hcd_giveback_urb+0x5d/0xc0
[<ffffffffa0000d02>] ehci_urb_done+0xf7/0x10c [ehci_hcd]
[<ffffffffa0001140>] qh_completions+0x429/0x4bd [ehci_hcd]
[<ffffffffa000340a>] ehci_work+0x95/0x9c0 [ehci_hcd]
---[ end trace f29ac88a5a48c580 ]---
Mapped at:
[<ffffffff811faac4>] debug_dma_map_sg+0x45/0x139
[<ffffffff8137bc0b>] usb_hcd_map_urb_for_dma+0x22e/0x478
[<ffffffff8137c494>] usb_hcd_submit_urb+0x63f/0x6fa
[<ffffffff8137d01c>] usb_submit_urb+0x2c7/0x2de
[<ffffffff8137dcd4>] usb_sg_wait+0x55/0x161
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 08e87d0d773dc9ca5faf4c3306e238ed0ea129b0 upstream.
Hi, below patch adds the USB-ID of the serial adapters sold by
Multiplex RC (www.multiplex-rc.de).
Signed-off-by: Malte Schröder <maltesch@gmx.de>
Cc: stable <stable@vger.kernel.org>
commit 694c6301e515bad574af74b6552134c4d9dcb334 upstream.
Fix regression introduced by commit 507ca9bc047666 ([PATCH] USB: add
ability for usb-serial drivers to determine if their write urb is
currently being used.) which inverted the logic in write_room so that it
returns zero when the write urb is actually free.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 772aed45b604c5ff171f0f12c12392d868333f79 upstream.
In musb_init_controller() there's a pm_runtime_put(), but there's no
pm_runtime_get(), which creates a mismatch that causes the driver to
sleep when it shouldn't.
This was introduced in 7acc619[1], but it wasn't triggered in my setup
until 18a2689[2] was merged to Linus' branch at point df0914[3]. IOW;
when PM is working as it was supposed to.
However, it seems most of the time this is used in a way that keeps the
counter above 0, so nobody noticed. Also, it seems to depend on the
configuration used in versions before 3.1, but not later (or in it).
I found the problem by loading isp1704_charger before any usb gadgets:
http://article.gmane.org/gmane.linux.kernel/1226122
All versions after 2.6.39 are affected.
[1] usb: musb: Idle path retention and offmode support for OMAP3
[2] OMAP2+: musb: hwmod adaptation for musb registration
[3] Merge branch 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
Cc: Hema HK <hemahk@ti.com>
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com>
commit 35284b3d2f68a8a3703745e629999469f78386b5 upstream.
The Guillemot Webcam Hercules Dualpix Exchange camera
has been reported with a second ID.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
the feature to fix an oops
commit 1a3a026ba1b6bbfe0b7f79ab38cf991d691e7c9a upstream.
Echo vendor and product number of a non usb-storage device to
usb-storage driver's new_id, then plug in the device to host and you
will find following oops msg, the root cause is usb_stor_probe1()
refers invalid id entry if giving a dynamic id, so just disable the
feature.
[ 3105.018012] general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC
[ 3105.018062] CPU 0
[ 3105.018075] Modules linked in: usb_storage usb_libusual bluetooth
dm_crypt binfmt_misc snd_hda_codec_analog snd_hda_intel snd_hda_codec
snd_hwdep hp_wmi ppdev sparse_keymap snd_pcm snd_seq_midi snd_rawmidi
snd_seq_midi_event snd_seq snd_timer snd_seq_device psmouse snd
serio_raw tpm_infineon soundcore i915 snd_page_alloc tpm_tis
parport_pc tpm tpm_bios drm_kms_helper drm i2c_algo_bit video lp
parport usbhid hid sg sr_mod sd_mod ehci_hcd uhci_hcd usbcore e1000e
usb_common floppy
[ 3105.018408]
[ 3105.018419] Pid: 189, comm: khubd Tainted: G I 3.2.0-rc7+
#29 Hewlett-Packard HP Compaq dc7800p Convertible Minitower/0AACh
[ 3105.018481] RIP: 0010:[<ffffffffa045830d>] [<ffffffffa045830d>]
usb_stor_probe1+0x2fd/0xc20 [usb_storage]
[ 3105.018536] RSP: 0018:ffff880056a3d830 EFLAGS: 00010286
[ 3105.018562] RAX: ffff880065f4e648 RBX: ffff88006bb28000 RCX: 0000000000000000
[ 3105.018597] RDX: ffff88006f23c7b0 RSI: 0000000000000001 RDI: 0000000000000206
[ 3105.018632] RBP: ffff880056a3d900 R08: 0000000000000000 R09: ffff880067365000
[ 3105.018665] R10: 00000000000002ac R11: 0000000000000010 R12: ffff6000b41a7340
[ 3105.018698] R13: ffff880065f4ef60 R14: ffff88006bb28b88 R15: ffff88006f23d270
[ 3105.018733] FS: 0000000000000000(0000) GS:ffff88007a200000(0000)
knlGS:0000000000000000
[ 3105.018773] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 3105.018801] CR2: 00007fc99c8c4650 CR3: 0000000001e05000 CR4: 00000000000006f0
[ 3105.018835] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 3105.018870] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 3105.018906] Process khubd (pid: 189, threadinfo ffff880056a3c000,
task ffff88005677a400)
[ 3105.018945] Stack:
[ 3105.018959] 0000000000000000 0000000000000000 ffff880056a3d8d0
0000000000000002
[ 3105.019011] 0000000000000000 ffff880056a3d918 ffff880000000000
0000000000000002
[ 3105.019058] ffff880056a3d8d0 0000000000000012 ffff880056a3d8d0
0000000000000006
[ 3105.019105] Call Trace:
[ 3105.019128] [<ffffffffa0458cd4>] storage_probe+0xa4/0xe0 [usb_storage]
[ 3105.019173] [<ffffffffa0097822>] usb_probe_interface+0x172/0x330 [usbcore]
[ 3105.019211] [<ffffffff815fda67>] driver_probe_device+0x257/0x3b0
[ 3105.019243] [<ffffffff815fdd43>] __device_attach+0x73/0x90
[ 3105.019272] [<ffffffff815fdcd0>] ? __driver_attach+0x110/0x110
[ 3105.019303] [<ffffffff815fb93c>] bus_for_each_drv+0x9c/0xf0
[ 3105.019334] [<ffffffff815fd6c7>] device_attach+0xf7/0x120
[ 3105.019364] [<ffffffff815fc905>] bus_probe_device+0x45/0x80
[ 3105.019396] [<ffffffff815f98a6>] device_add+0x876/0x990
[ 3105.019434] [<ffffffffa0094e42>] usb_set_configuration+0x822/0x9e0 [usbcore]
[ 3105.019479] [<ffffffffa00a3492>] generic_probe+0x62/0xf0 [usbcore]
[ 3105.019518] [<ffffffffa0097a46>] usb_probe_device+0x66/0xb0 [usbcore]
[ 3105.019555] [<ffffffff815fda67>] driver_probe_device+0x257/0x3b0
[ 3105.019589] [<ffffffff815fdd43>] __device_attach+0x73/0x90
[ 3105.019617] [<ffffffff815fdcd0>] ? __driver_attach+0x110/0x110
[ 3105.019648] [<ffffffff815fb93c>] bus_for_each_drv+0x9c/0xf0
[ 3105.019680] [<ffffffff815fd6c7>] device_attach+0xf7/0x120
[ 3105.019709] [<ffffffff815fc905>] bus_probe_device+0x45/0x80
[ 3105.021040] usb usb6: usb auto-resume
[ 3105.021045] usb usb6: wakeup_rh
[ 3105.024849] [<ffffffff815f98a6>] device_add+0x876/0x990
[ 3105.025086] [<ffffffffa0088987>] usb_new_device+0x1e7/0x2b0 [usbcore]
[ 3105.025086] [<ffffffffa008a4d7>] hub_thread+0xb27/0x1ec0 [usbcore]
[ 3105.025086] [<ffffffff810d5200>] ? wake_up_bit+0x50/0x50
[ 3105.025086] [<ffffffffa00899b0>] ? usb_remote_wakeup+0xa0/0xa0 [usbcore]
[ 3105.025086] [<ffffffff810d49b8>] kthread+0xd8/0xf0
[ 3105.025086] [<ffffffff81939884>] kernel_thread_helper+0x4/0x10
[ 3105.025086] [<ffffffff8192a8c0>] ? _raw_spin_unlock_irq+0x50/0x80
[ 3105.025086] [<ffffffff8192b1b4>] ? retint_restore_args+0x13/0x13
[ 3105.025086] [<ffffffff810d48e0>] ? __init_kthread_worker+0x80/0x80
[ 3105.025086] [<ffffffff81939880>] ? gs_change+0x13/0x13
[ 3105.025086] Code: 00 48 83 05 cd ad 00 00 01 48 83 05 cd ad 00 00
01 4c 8b ab 30 0c 00 00 48 8b 50 08 48 83 c0 30 48 89 45 a0 4c 89 a3
40 0c 00 00 <41> 0f b6 44 24 10 48 89 55 a8 3c ff 0f 84 b8 04 00 00 48
83 05
[ 3105.025086] RIP [<ffffffffa045830d>] usb_stor_probe1+0x2fd/0xc20
[usb_storage]
[ 3105.025086] RSP <ffff880056a3d830>
[ 3105.060037] hub 6-0:1.0: hub_resume
[ 3105.062616] usb usb5: usb auto-resume
[ 3105.064317] ehci_hcd 0000:00:1d.7: resume root hub
[ 3105.094809] ---[ end trace a7919e7f17c0a727 ]---
[ 3105.130069] hub 5-0:1.0: hub_resume
[ 3105.132131] usb usb4: usb auto-resume
[ 3105.132136] usb usb4: wakeup_rh
[ 3105.180059] hub 4-0:1.0: hub_resume
[ 3106.290052] usb usb6: suspend_rh (auto-stop)
[ 3106.290077] usb usb4: suspend_rh (auto-stop)
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
commit 59bf5cf94f0fa3b08fb1258b52649077b7d0914d upstream.
We were sending data on the stack when uploading firmware, which causes
some machines fits, and is not allowed. Fix this by using the buffer we
already had around for this very purpose.
Reported-by: Wouter M. Koolen <wmkoolen@cwi.nl>
Tested-by: Wouter M. Koolen <wmkoolen@cwi.nl>
commit e7c8e8605d0bafc705ff27f9da98a1668427cc0f upstream.
On some failures, the country_code field of an acm structure is freed
without freeing the acm structure itself. Elsewhere, operations including
memcpy and kfree are performed on the country_code field. The patch sets
the country_code field to NULL when it is freed, and likewise sets the
country_code_size field to 0.
Acked-by: Oliver Neukum <oneukum@suse.de>
commit d2eb8c359309ec45d6bf5b147303ab8e13be86ea upstream.
During BKL removal in 2.6.38, conversion of files from in-ICB format to normal
format got broken. We call ->writepage with i_data_sem held but udf_get_block()
also acquires i_data_sem thus creating A-A deadlock.
We fix the problem by dropping i_data_sem before calling ->writepage() which is
safe since i_mutex still protects us against any changes in the file. Also fix
pagelock - i_data_sem lock inversion in udf_expand_file_adinicb() by dropping
i_data_sem before calling find_or_create_page().
Reported-by: Matthias Matiak <netzpython@mail-on.us>
Tested-by: Matthias Matiak <netzpython@mail-on.us>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream.
If we mount a hierarchy with a specified name, the name is unique,
and we can use it to mount the hierarchy without specifying its
set of subsystem names. This feature is documented is
Documentation/cgroups/cgroups.txt section 2.3
Here's an example:
# mount -t cgroup -o cpuset,name=myhier xxx /cgroup1
# mount -t cgroup -o name=myhier xxx /cgroup2
But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a
(cgroup: make the mount options parsing more accurate)
This fixes the regression.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
commit dbf1115d3f8c7052788aa4e6e46abd27f3b3eeba upstream.
Patch to fix a spinlock lockup in the driver that sometimes happens when the
tasklet starts.
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
Signed-off-by: Dave Bender <codehero@gmail.com>
Tested-by: Dave Bender <codehero@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Alan Cox <alan@linux.intel.com>
commit d8cae98cddd286e38db1724dda1b0e7b467f9237 upstream.
The documentation for usbmon is out of date; the usbfs "devices" file
now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This
patch (as1505) updates the documentation accordingly, and also
mentions that the necessary information can be found by running lsusb.
CC: Pete Zaitcev <zaitcev@redhat.com>
commit 33c104d415e92a51aaf638dc3d93920cfa601e5c upstream.
WARN_ON_ONCE(IS_RDONLY(inode)) tends to trip when filesystem hits error and is
remounted read-only. This unnecessarily scares users (well, they should be
scared because of filesystem error, but the stack trace distracts them from the
right source of their fear ;-). We could as well just remove the WARN_ON but
it's not hard to fix it to not trip on filesystem with errors and not use more
cycles in the common case so that's what we do.
commit a9e36da655e54545c3289b2a0700b5c443de0edd upstream.
This patch fixes a crash in reiserfs_delete_xattrs during umount.
When shrink_dcache_for_umount clears the dcache from
generic_shutdown_super, delayed evictions are forced to disk. If an
evicted inode has extended attributes associated with it, it will
need to walk the xattr tree to locate and remove them.
But since shrink_dcache_for_umount will BUG if it encounters active
dentries, the xattr tree must be released before it's called or it will
crash during every umount.
This patch forces the evictions to occur before generic_shutdown_super
by calling shrink_dcache_sb first. The additional evictions caused
by the removal of each associated xattr file and dir will be automatically
handled as they're added to the LRU list.
CC: reiserfs-devel@vger.kernel.org
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit a06d789b424190e9f59da391681f908486db2554 upstream.
When jqfmt mount option is not specified on remount, we mistakenly clear
s_jquota_fmt value stored in superblock. Fix the problem.
commit 49908a1b25d448d68fd26faca260e1850201575f upstream.
A update is made to the sched:sched_switch event that adds some
logic to the first parameter of the __print_flags() that shows the
state of tasks. This change cause perf to fail parsing the flags.
A simple fix is needed to have the parser be able to process ops
within the argument.
Reported-by: Andrew Vagin <avagin@openvz.org>
commit eddfb675256f49d14e8c5763098afe3eb2c93701 upstream.
Prevent a receive data corruption by ensuring that the write to update
the rcvhdrheadn register to generate an interrupt is at the very end
of the receive processing.
Signed-off-by: Ramkrishna Vepa <ram.vepa@qlogic.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@qlogic.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit e8303a3b2196272c3eb994d0fd1a189a958a2bdd upstream.
Adds the device id needed for the USB Ethernet Adapter delivered by
ASUS with their Zenbook.
Acked-by: Grant Grundler <grundler@chromium.org>
commit e4f387d8db3ba3c2dae4d8bdfe7bb5f4fe1bcb0d upstream.
Unpaired calling of probe_hcall_entry and probe_hcall_exit might happen
as following, which could cause incorrect preempt count.
__trace_hcall_entry => trace_hcall_entry -> probe_hcall_entry =>
get_cpu_var => preempt_disable
__trace_hcall_exit => trace_hcall_exit -> probe_hcall_exit =>
put_cpu_var => preempt_enable
where:
A => B and A -> B means A calls B, but
=> means A will call B through function name, and B will definitely be
called.
-> means A will call B through function pointer, so B might not be
called if the function pointer is not set.
So error happens when only one of probe_hcall_entry and probe_hcall_exit
get called during a hcall.
This patch tries to move the preempt count operations from
probe_hcall_entry and probe_hcall_exit to its callers.
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit 37fb9a0231ee43d42d069863bdfd567fca2b61af upstream.
When re-enabling interrupts we have code to handle edge sensitive
decrementers by resetting the decrementer to 1 whenever it is negative.
If interrupts were disabled long enough that the decrementer wrapped to
positive we do nothing. This means interrupts can be delayed for a long
time until it finally goes negative again.
While we hope interrupts are never be disabled long enough for the
decrementer to go positive, we have a very good test team that can
drive any kernel into the ground. The softlockup data we get back
from these fails could be seconds in the future, completely missing
the cause of the lockup.
We already keep track of the timebase of the next event so use that
to work out if we should trigger a decrementer exception.
commit 3f1764945eaac532c20ab1f23afa352a40f797b2 upstream.
Commit 80900d0140a7648587982c8f299830e900e49165 accidently broke
the ABI for testmode commands. Restore the ABI again.
Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
commit f6efe96edd9c41c624c8f4ddbc4930c1a2d8f1e1 upstream.
An nvs with malformed contents could cause the processing of the
calibration data to read beyond the end of the buffer. Prevent this
from happening by adding bound checking.
Reviewed-by: Luciano Coelho <coelho@ti.com>
commit 2131d3c2f99b081806fdae7662c92fe6acda52af upstream.
Check for out of bound FEM index to prevent reading beyond ini
memory end.
