If a function declares a variable to access a structure element,
use it consistently.
(cherry picked from commit d7ddf15414dd598b9b875664e6b7aebe6c988f5d)
This reverts commit 28531a1ff5ca27c0ab7e2f99bbb0058858b72aa5.
Building kernels before linux-4.7 with gcc-8 results in many build failures
when gcc triggers a check that was meant to catch broken compilers:
/tmp/ccCGMQmS.s:648: Error: .err encountered
According to the discussion in the gcc bugzilla, a local "register
asm()" variable is still supposed to be the correct way to force an
inline assembly to use a particular register, but marking it 'const'
lets the compiler do optimizations that break that, i.e the compiler is
free to treat the variable as either 'const' or 'register' in that case.
Upstream commit 9f73bd8bb445 ("ARM: uaccess: remove put_user() code
duplication") fixed this problem in linux-4.8 as part of a larger change,
but seems a little too big to be backported to 4.4.
Let's take the simplest fix and change only the one broken line in the
same way as newer kernels.
Suggested-by: Bernd Edlinger <bernd.edlinger@hotmail.de>
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=85745
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=86673
(cherry picked from commit 0ca85fc310e8c24cba10ed241a0188795e177683)
/tmp/ccmcXtfu.s: Assembler messages:
/tmp/ccmcXtfu.s:1441: Error: .err encountered
arch/arm/include/asm/uaccess.h
gcc-7 has an "optimization" pass that completely screws up, and
generates the code expansion for the (impossible) case of calling
ilog2() with a zero constant, even when the code gcc compiles does not
actually have a zero constant.
And we try to generate a compile-time error for anybody doing ilog2() on
a constant where that doesn't make sense (be it zero or negative). So
now gcc7 will fail the build due to our sanity checking, because it
created that constant-zero case that didn't actually exist in the source
code.
There's a whole long discussion on the kernel mailing about how to work
around this gcc bug. The gcc people themselevs have discussed their
"feature" in
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785
but it's all water under the bridge, because while it looked at one
point like it would be solved by the time gcc7 was released, that was
not to be.
So now we have to deal with this compiler braindamage.
And the only simple approach seems to be to just delete the code that
tries to warn about bad uses of ilog2().
So now "ilog2()" will just return 0 not just for the value 1, but for
any non-positive value too.
It's not like I can recall anybody having ever actually tried to use
this function on any invalid value, but maybe the sanity check just
meant that such code never made it out in public.
Reported-by: Laura Abbott <labbott@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
(cherry picked from commit 474c90156c8dcc2fa815e6716cc9394d7930cb9c)
tools/include/linux/log2.h
File does not exist in the 3.1 kernel, change dropped.
This helps with the move to GCC 8.
| include/linux/log2.h:22:1: error: ignoring attribute 'noreturn' because it conflicts with attribute 'const' [-Werror=attributes]
| int ____ilog2_NaN(void);
On a system running glibc trunk perf doesn't build:
CC builtin-sched.o
builtin-sched.c: In function ‘get_cpu_usage_nsec_parent’: builtin-sched.c:399:16: error: storage size of ‘ru’ isn’t known builtin-sched.c:403:2: error: implicit declaration of function ‘getrusage’ [-Werror=implicit-function-declaration]
Fix it by including sys/resource.h.
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Link: http://lkml.kernel.org/r/20120404084527.GA294@x4
(cherry picked from commit 7b78f13603c6fcb64e020a0bbe31a651ea2b657b)
Leave reset line setup to the capacitive touch drivers.
This commit adds support for the 2nd CSI Camera Module 5MP OV5640 with
SCCB_ID of 0x3d connected to Apalis T30 Mezzanine V2.0A on X4 aka
CSI_2_CSI-2/2x.
(cherry picked from commit 22a2065b9a3fa6ad458e3100b66c4acaa05f2466)
In order to avoid any floating SD card detect pins as may e.g. happen on
Ixora V1.1A pull them all up.
Adds compile time option to enable support for
Toradex Capacitive Touch Adapter.
Let the kernel print some debug messages when a user program
crashes due to an exception.
We already use them for openat() and friends, but fchdir() also wants to
be able to use O_PATH file descriptors. This should make it comparable
to the O_SEARCH of Solaris. In particular, O_PATH allows you to access
(not-quite-open) a directory you don't have read persmission to, only
execute permission.
Noticed during development of multithread support for ksh93.
Reported-by: ольга крыжановская <olga.kryzhanovska@gmail.com>
Cc: stable@kernel.org # O_PATH introduced in 3.0+
(cherry picked from commit 332a2e1244bd08b9e3ecd378028513396a004a24)
We already use them for openat() and friends, but fstat() also wants to
be able to use O_PATH file descriptors. This should make it more
directly comparable to the O_SEARCH of Solaris.
Note that you could already do the same thing with "fstatat()" and an
empty path, but just doing "fstat()" directly is simpler and faster, so
there is no reason not to just allow it directly.
See also commit 332a2e1244bd, which did the same thing for fchdir, for
the same reasons.
(cherry picked from commit 55815f70147dcfa3ead5738fd56d3574e2e3c1c2)
Use the *_light() versions that properly avoid doing the file user count
updates when they are unnecessary.
(cherry picked from commit e994defb7b6813ba6fa7a2a36e86d2455ad1dc35)
Add user crypto to defconfigs.
The upcomming crypto user configuration api needs to identify
crypto instances. This patch adds a flag that is set if the
algorithm is an instance that is build from templates.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
(cherry picked from commit 64a947b1337b93061da7c7af1f6ce6b2431b70ae)
The upcomming crypto usrerspace configuration api needs
to remove the spawns on top on an algorithm, so export
crypto_remove_final.
(cherry picked from commit 22e5b20be72e2e166c3ba915b01a59a8eb2dc71f)
The list_empty case in crypto_alg_match() will return without calling
up_read() on crypto_alg_sem. We could do the "goto out" routine, but the
function will clearly do the right thing with that test simply removed.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
(cherry picked from commit fb223c32b4d3ee593c8dce07e983680d06abe387)
We need to default match to 0 as otherwise it may lead to a false
positive.
(cherry picked from commit e6ea64ece7f4c14294b2fce5403b1e71eab87f1e)
(cherry picked from commit 540b97c1dd9ee68112269be322d901f1edc1a282)
(cherry picked from commit 07a5fa4abd8b6965d4585d3b110f89bdf5612aff)
(cherry picked from commit 792608e9c215141fa4b870b7b2a23767a1ef12f4)
(cherry picked from commit a55465dca7befd31f4ffa54508d4e2d1e701b8dc)
(cherry picked from commit b735d0a91556fd9fd5bbeeebd7d327c2d92c36c8)
(cherry picked from commit 6ad414fe710d4fd3a8c8c6c2ad8fefcfcc207968)
(cherry picked from commit 3e29c1095a091f606a26c04a6542061c9e5f1d6b)
(cherry picked from commit 29ffc87640e2a5bf0ab98bfeed8d6fc78b2d848e)
(cherry picked from commit 50496a1fab6c6a90b77da4b247321a88e632bd46)
(cherry picked from commit 6238cbaec429c98d1a280014839c934107c7c8f6)
(cherry picked from commit f4d663ce6357e533f107ce3789bd8848c94bea81)
(cherry picked from commit 6c5a86f529a9e9ca4c9aca5fa477e9557d4a3d3d)
We add a report function pointer to struct crypto_type. This function
pointer is used from the crypto userspace configuration API to report
crypto algorithms to userspace.
(cherry picked from commit b6aa63c09ba3b150a1030f9c95c7647361e7910e)
crypto_remove_spawns.
(cherry picked from commit 89b596ba22d79dd5616616a9975192e1c2bea0fe)
This patch adds a basic userspace configuration API for the crypto layer.
With this it is possible to instantiate, remove and to show crypto
algorithms from userspace.
(cherry picked from commit a38f7907b926e4c6c7d389ad96cc38cec2e5a9e9)
Incresed PWM base clock to 25.5MHz. This results in maximum 99.6Khz
PWM out frequency which can be further divided by an integer divider.
Integrate Atmel MXT multitouch controller driver which is interfaced
over I2C bus. The driver supports the 7" multitouch variant available
from Logic Technologies.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Update mxt driver to upstream version.
With gcc 7 the following compile time error occurs:
| .../drivers/usb/gadget/tegra_udc.c:2565:17: error: 'out' directive writing 3 bytes into a region of size between 2 and 11 [-Werror=format-overflow=]
| sprintf(name, "ep%dout", i);
| .../drivers/usb/gadget/tegra_udc.c:2565:3: note: 'sprintf' output between 7 and 16 bytes into a destination of size 14
The last end point will never be greater than 32 but the compiler can
not find this out from the code. Work around this by passing a format
specifier to interpreat i as a signed char.
