The scatterlist is used uninitialized in kfifo_dma_in_prepare(). This
triggers the following bug if CONFIG_DEBUG_SG=y:
kernel BUG at include/linux/scatterlist.h:65!
invalid opcode: 0000 [#1] PREEMPT SMP
Call Trace:
[<ffffffff810a1eab>] setup_sgl+0x6b/0xe0
[<ffffffffa03d7000>] ? example_init+0x0/0x265 [dma_example]
[<ffffffff810a2021>] __kfifo_dma_in_prepare+0x21/0x30
[<ffffffffa03d7124>] example_init+0x124/0x265 [dma_example]
[<ffffffff810f9c55>] ? trace_module_notify+0x25/0x370
[<ffffffff81110c6e>] ? free_pages_prepare+0x11e/0x1e0
[<ffffffff8106f2b1>] ? get_parent_ip+0x11/0x50
[<ffffffff810b65fd>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff814beade>] ? mutex_unlock+0xe/0x10
[<ffffffff810f9c71>] ? trace_module_notify+0x41/0x370
[<ffffffff810a77d5>] ? __blocking_notifier_call_chain+0x45/0x80
[<ffffffff81137b7a>] ? vfree+0x2a/0x30
[<ffffffff810a6ac3>] ? up_read+0x23/0x40
[<ffffffff810a77f5>] ? __blocking_notifier_call_chain+0x65/0x80
[<ffffffff810001e3>] do_one_initcall+0x43/0x180
[<ffffffff810c577a>] sys_init_module+0xba/0x200
[<ffffffff8103819b>] system_call_fastpath+0x16/0x1b
RIP [<ffffffff810a1e31>] setup_sgl_buf+0x1a1/0x1b0
RSP <ffff88006720dc98>
---[ end trace a72b979fd3c1d3a5 ]---
Add the proper initialization to avoid the bug.
Signed-off-by: Andrea Righi <arighi@develer.com>
Acked-by: Stefani Seibold <stefani@seibold.net>
Provide a static array of expected items that kfifo should contain at the
end of the test to validate it.
Cc: Stefani Seibold <stefani@seibold.net>
Cc: Greg KH <greg@kroah.com>
Add a testcase for kfifo_skip() to the byte stream fifo example.
kfifo_skip() is currently broken, due to the missing of the internal
helper function. Add it.
Screen is completely corrupted since 2.6.34. Bisection revealed that it's
caused by commit 6175ddf06b61720 ("x86: Clean up mem*io functions.").
H. Peter Anvin explained that memcpy_toio() does not copy data in 32bit
chunks anymore on x86.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: <stable@kernel.org> [2.6.34.x, 2.6.35.x]
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kprobes/x86: Fix the return address of multiple kretprobes
perf tools: Fix build error on read only source.
perf, x86: Fix Intel-nhm PMU programming errata workaround
Fix the return address of subsequent kretprobes when multiple
kretprobes are set on the same function.
For example:
# cd /sys/kernel/debug/tracing
# echo "r:event1 sys_symlink" > kprobe_events
# echo "r:event2 sys_symlink" >> kprobe_events
# echo 1 > events/kprobes/enable
# ln -s /tmp/foo /tmp/bar
(without this patch)
# cat trace
ln-897 [000] 20404.133727: event1: (kretprobe_trampoline+0x0/0x4c <- sys_symlink)
ln-897 [000] 20404.133747: event2: (system_call_fastpath+0x16/0x1b <- sys_symlink)
(with this patch)
# cat trace
ln-740 [000] 13799.491076: event1: (system_call_fastpath+0x16/0x1b <- sys_symlink)
ln-740 [000] 13799.491096: event2: (system_call_fastpath+0x16/0x1b <- sys_symlink)
Signed-off-by: KUMANO Syuhei <kumano.prog@gmail.com>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
LKML-Reference: <1281853084.3254.11.camel@camp10-laptop>
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/urgent
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
NFS: Fix an Oops in the NFSv4 atomic open code
NFS: Fix the selection of security flavours in Kconfig
NFS: fix the return value of nfs_file_fsync()
rpcrdma: Fix SQ size calculation when memreg is FRMR
xprtrdma: Do not truncate iova_start values in frmr registrations.
nfs: Remove redundant NULL check upon kfree()
nfs: Add "lookupcache" to displayed mount options
NFS: allow close-to-open cache semantics to apply to root of NFS filesystem
SUNRPC: fix NFS client over TCP hangs due to packet loss (Bug 16494)
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
USB HID: Add ID for eGalax Multitouch used in JooJoo tablet
HID: hiddev: fix memory corruption due to invalid intfdata
HID: hiddev: protect against disconnect/NULL-dereference race
HID: picolcd: correct ordering of framebuffer freeing
HID: picolcd: testing the wrong variable
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Fix build error: conflicting types for ‘sys_execve’
Fix the declaration of sys_execve() in asm-generic/syscalls.h to have
various consts applied to its pointers.
arch/ia64/kernel/process.c:636: error: conflicting types for ‘sys_execve’
commit d7627467b7a8dd6944885290a03a07ceb28c10eb
Make do_execve() take a const filename pointer
Missed the declaration of sys_execve in the ia64 asm/unistd.h (perhaps
because there is no reason for it to be there ... it might be a left over
from the COMPAT code?). Just delete the conflicting version.
Signed-off-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: brlock vfsmount_lock
fs: scale files_lock
lglock: introduce special lglock and brlock spin locks
tty: fix fu_list abuse
fs: cleanup files_lock locking
fs: remove extra lookup in __lookup_hash
fs: fs_struct rwlock to spinlock
apparmor: use task path helpers
fs: dentry allocation consolidation
fs: fix do_lookup false negative
mbcache: Limit the maximum number of cache entries
hostfs ->follow_link() braino
hostfs: dumb (and usually harmless) tpyo - strncpy instead of strlcpy
remove SWRITE* I/O types
kill BH_Ordered flag
vfs: update ctime when changing the file's permission by setfacl
cramfs: only unlock new inodes
fix reiserfs_evict_inode end_writeback second call
This fixes a build breakage introduced by commit 4c2ef25fe0b8 ("mmc: fix
all hangs related to mmc/sd card insert/removal during suspend/resume")
Cc: David Brownell <david-b@pacbell.net>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: linux-mmc@vger.kernel.org
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Maxim Levitsky <maximlevitsky@gmail.com>
Parts of the build process were generating files outside the specified
O= directory, causing the build to fail on systems where the sources are
in a read only file system.
Fix it by using $(OUTPUT) on these locations.
Also check that $(OUTPUT) actually exists, just like the top level
kernel Makefile does. Otherwise the failure message emitted is
completely misleading.
LKML-Reference: <20100817140841.0859362C03A@msa106.auone-net.jp>
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
perf tools: Fix build on POSIX shells
latencytop: Fix kconfig dependency warnings
perf annotate tui: Fix exit and RIGHT keys handling
tracing: Sanitize value returned from write(trace_marker, "...", len)
tracing/events: Convert format output to seq_file
tracing: Extend recordmcount to better support Blackfin mcount
tracing: Fix ring_buffer_read_page reading out of page boundary
tracing: Fix an unallocated memory access in function_graph
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: emu10k1 - delay the PCM interrupts (add pcm_irq_delay parameter)
ALSA: hda - Fix ALC680 base model capture
ASoC: Remove DSP mode support for WM8776
ALSA: hda - Add quirk for Dell Vostro 1220
ALSA: riptide - Fix detection / load of firmware files
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68knommu: include sched.h in ColdFire/SPI driver
m68knommu: formatting of pointers in printk()
m68knommu: arch/m68k/include/asm/ide.h fix for nommu
* 'for-linus' of git://neil.brown.name/md:
md raid-1/10 Fix bio_rw bit manipulations again
md: provide appropriate return value for spare_active functions.
md: Notify sysfs when RAID1/5/10 disk is In_sync.
Update recovery_offset even when external metadata is used.
* 'merge-devicetree' of git://git.secretlab.ca/git/linux-2.6:
spi.h: missing kernel-doc notation, please fix
of: fix missing headers for of_address_to_resource() in MTD and SysACE drivers
of: Fix missing includes
ata: update for of_device to platform_device replacement
microblaze: Fix of: eliminate of_device->node and dev_archdata->{of,prom}_node
microblaze: Fix of/address: Merge all of the bus translation code
booting-without-of: Remove nonexistent chapters from TOC, fix numbering
Adam Lackorzynski reports:
with 2.6.35.2 I'm getting this reproducible Oops:
[ 110.825396] BUG: unable to handle kernel NULL pointer dereference at
(null)
[ 110.828638] IP: [<ffffffff811247b7>] encode_attrs+0x1a/0x2a4
[ 110.828638] PGD be89f067 PUD bf18f067 PMD 0
[ 110.828638] Oops: 0000 [#1] SMP
[ 110.828638] last sysfs file: /sys/class/net/lo/operstate
[ 110.828638] CPU 2
[ 110.828638] Modules linked in: rtc_cmos rtc_core rtc_lib amd64_edac_mod
i2c_amd756 edac_core i2c_core dm_mirror dm_region_hash dm_log dm_snapshot
sg sr_mod usb_storage ohci_hcd mptspi tg3 mptscsih mptbase usbcore nls_base
[last unloaded: scsi_wait_scan]
[ 110.828638]
[ 110.828638] Pid: 11264, comm: setchecksum Not tainted 2.6.35.2 #1
[ 110.828638] RIP: 0010:[<ffffffff811247b7>] [<ffffffff811247b7>]
[ 110.828638] RSP: 0000:ffff88003bf5b878 EFLAGS: 00010296
[ 110.828638] RAX: ffff8800bddb48a8 RBX: ffff88003bf5bb18 RCX:
0000000000000000
[ 110.828638] RDX: ffff8800be258800 RSI: 0000000000000000 RDI:
ffff88003bf5b9f8
[ 110.828638] RBP: 0000000000000000 R08: ffff8800bddb48a8 R09:
0000000000000004
[ 110.828638] R10: 0000000000000003 R11: ffff8800be779000 R12:
ffff8800be258800
[ 110.828638] R13: ffff88003bf5b9f8 R14: ffff88003bf5bb20 R15:
ffff8800be258800
[ 110.828638] FS: 0000000000000000(0000) GS:ffff880041e00000(0063)
knlGS:00000000556bd6b0
[ 110.828638] CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b
[ 110.828638] CR2: 0000000000000000 CR3: 00000000be8ef000 CR4:
00000000000006e0
[ 110.828638] DR0: 0000000000000000 DR1: 0000000000000000 DR2:
0000000000000000
[ 110.828638] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7:
0000000000000400
[ 110.828638] Process setchecksum (pid: 11264, threadinfo
ffff88003bf5a000, task ffff88003f232210)
[ 110.828638] Stack:
[ 110.828638] 0000000000000000 ffff8800bfbcf920 0000000000000000
0000000000000ffe
[ 110.828638] <0> 0000000000000000 0000000000000000 0000000000000000
0000000000000000
0000000000000000
[ 110.828638] Call Trace:
[ 110.828638] [<ffffffff81124c1f>] ? nfs4_xdr_enc_setattr+0x90/0xb4
[ 110.828638] [<ffffffff81371161>] ? call_transmit+0x1c3/0x24a
[ 110.828638] [<ffffffff813774d9>] ? __rpc_execute+0x78/0x22a
[ 110.828638] [<ffffffff81371a91>] ? rpc_run_task+0x21/0x2b
[ 110.828638] [<ffffffff81371b7e>] ? rpc_call_sync+0x3d/0x5d
[ 110.828638] [<ffffffff8111e284>] ? _nfs4_do_setattr+0x11b/0x147
[ 110.828638] [<ffffffff81109466>] ? nfs_init_locked+0x0/0x32
[ 110.828638] [<ffffffff810ac521>] ? ifind+0x4e/0x90
[ 110.828638] [<ffffffff8111e2fb>] ? nfs4_do_setattr+0x4b/0x6e
[ 110.828638] [<ffffffff8111e634>] ? nfs4_do_open+0x291/0x3a6
[ 110.828638] [<ffffffff8111ed81>] ? nfs4_open_revalidate+0x63/0x14a
[ 110.828638] [<ffffffff811056c4>] ? nfs_open_revalidate+0xd7/0x161
[ 110.828638] [<ffffffff810a2de4>] ? do_lookup+0x1a4/0x201
[ 110.828638] [<ffffffff810a4733>] ? link_path_walk+0x6a/0x9d5
[ 110.828638] [<ffffffff810a42b6>] ? do_last+0x17b/0x58e
[ 110.828638] [<ffffffff810a5fbe>] ? do_filp_open+0x1bd/0x56e
[ 110.828638] [<ffffffff811cd5e0>] ? _atomic_dec_and_lock+0x30/0x48
[ 110.828638] [<ffffffff810a9b1b>] ? dput+0x37/0x152
[ 110.828638] [<ffffffff810ae063>] ? alloc_fd+0x69/0x10a
[ 110.828638] [<ffffffff81099f39>] ? do_sys_open+0x56/0x100
[ 110.828638] [<ffffffff81027a22>] ? ia32_sysret+0x0/0x5
[ 110.828638] Code: 83 f1 01 e8 f5 ca ff ff 48 83 c4 50 5b 5d 41 5c c3 41
57 41 56 41 55 49 89 fd 41 54 49 89 d4 55 48 89 f5 53 48 81 ec 18 01 00 00
<8b> 06 89 c2 83 e2 08 83 fa 01 19 db 83 e3 f8 83 c3 18 a8 01 8d
[ 110.828638] RIP [<ffffffff811247b7>] encode_attrs+0x1a/0x2a4
[ 110.828638] RSP <ffff88003bf5b878>
[ 112.840396] ---[ end trace 95282e83fd77358f ]---
We need to ensure that the O_EXCL flag is turned off if the user doesn't
set O_CREAT.
Cc: stable@kernel.org
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
With some hardware combinations, the PCM interrupts are acknowledged
before the period boundary from the emu10k1 chip. The midlevel PCM code
gets confused and the playback stream is interrupted.
It seems that the interrupt processing shift by 2 samples is enough
to fix this issue. This default value does not harm other,
non-affected hardware.
More information: Kernel bugzilla bug#16300
[A copmile warning fixed by tiwai]
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Use a brlock for the vfsmount lock. It must be taken for write whenever
modifying the mount hash or associated fields, and may be taken for read when
performing mount hash lookups.
A new lock is added for the mnt-id allocator, so it doesn't need to take
the heavy vfsmount write-lock.
The number of atomics should remain the same for fastpath rlock cases, though
code would be slightly slower due to per-cpu access. Scalability is not not be
much improved in common cases yet, due to other locks (ie. dcache_lock) getting
in the way. However path lookups crossing mountpoints should be one case where
scalability is improved (currently requiring the global lock).
The slowpath is slower due to use of brlock. On a 64 core, 64 socket, 32 node
Altix system (high latency to remote nodes), a simple umount microbenchmark
(mount --bind mnt mnt2 ; umount mnt2 loop 1000 times), before this patch it
took 6.8s, afterwards took 7.1s, about 5% slower.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Improve scalability of files_lock by adding per-cpu, per-sb files lists,
protected with an lglock. The lglock provides fast access to the per-cpu lists
to add and remove files. It also provides a snapshot of all the per-cpu lists
(although this is very slow).
One difficulty with this approach is that a file can be removed from the list
by another CPU. We must track which per-cpu list the file is on with a new
variale in the file struct (packed into a hole on 64-bit archs). Scalability
could suffer if files are frequently removed from different cpu's list.
However loads with frequent removal of files imply short interval between
adding and removing the files, and the scheduler attempts to avoid moving
processes too far away. Also, even in the case of cross-CPU removal, the
hardware has much more opportunity to parallelise cacheline transfers with N
cachelines than with 1.
A worst-case test of 1 CPU allocating files subsequently being freed by N CPUs
degenerates to contending on a single lock, which is no worse than before. When
more than one CPU are allocating files, even if they are always freed by
different CPUs, there will be more parallelism than the single-lock case.
Testing results:
On a 2 socket, 8 core opteron, I measure the number of times the lock is taken
to remove the file, the number of times it is removed by the same CPU that
added it, and the number of times it is removed by the same node that added it.
Booting: locks= 25049 cpu-hits= 23174 (92.5%) node-hits= 23945 (95.6%)
kbuild -j16 locks=2281913 cpu-hits=2208126 (96.8%) node-hits=2252674 (98.7%)
dbench 64 locks=4306582 cpu-hits=4287247 (99.6%) node-hits=4299527 (99.8%)
So a file is removed from the same CPU it was added by over 90% of the time.
It remains within the same node 95% of the time.
Tim Chen ran some numbers for a 64 thread Nehalem system performing a compile.
throughput
2.6.34-rc2 24.5
+patch 24.9
us sys idle IO wait (in %)
2.6.34-rc2 51.25 28.25 17.25 3.25
+patch 53.75 18.5 19 8.75
So significantly less CPU time spent in kernel code, higher idle time and
slightly higher throughput.
Single threaded performance difference was within the noise of microbenchmarks.
That is not to say penalty does not exist, the code is larger and more memory
accesses required so it will be slightly slower.
Cc: Tim Chen <tim.c.chen@linux.intel.com>
This patch introduces "local-global" locks (lglocks). These can be used to:
- Provide fast exclusive access to per-CPU data, with exclusive access to
another CPU's data allowed but possibly subject to contention, and to provide
very slow exclusive access to all per-CPU data.
- Or to provide very fast and scalable read serialisation, and to provide
very slow exclusive serialisation of data (not necessarily per-CPU data).
Brlocks are also implemented as a short-hand notation for the latter use
case.
Thanks to Paul for local/global naming convention.
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
tty code abuses fu_list, which causes a bug in remount,ro handling.
If a tty device node is opened on a filesystem, then the last link to the inode
removed, the filesystem will be allowed to be remounted readonly. This is
because fs_may_remount_ro does not find the 0 link tty inode on the file sb
list (because the tty code incorrectly removed it to use for its own purpose).
This can result in a filesystem with errors after it is marked "clean".
Taking idea from Christoph's initial patch, allocate a tty private struct
at file->private_data and put our required list fields in there, linking
file and tty. This makes tty nodes behave the same way as other device nodes
and avoid meddling with the vfs, and avoids this bug.
The error handling is not trivial in the tty code, so for this bugfix, I take
the simple approach of using __GFP_NOFAIL and don't worry about memory errors.
This is not a problem because our allocator doesn't fail small allocs as a rule
anyway. So proper error handling is left as an exercise for tty hackers.
[ Arguably filesystem's device inode would ideally be divorced from the
driver's pseudo inode when it is opened, but in practice it's not clear whether
that will ever be worth implementing. ]
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Lock tty_files with a new spinlock, tty_files_lock; provide helpers to
manipulate the per-sb files list; unexport the files_lock spinlock.
Acked-by: Andi Kleen <ak@linux.intel.com>
Optimize lookup for create operations, where no dentry should often be
common-case. In cases where it is not, such as unlink, the added overhead
is much smaller than the removed.
Also, move comments about __d_lookup racyness to the __d_lookup call site.
d_lookup is intuitive; __d_lookup is what needs commenting. So in that same
vein, add kerneldoc comments to __d_lookup and clean up some of the comments:
- We are interested in how the RCU lookup works here, particularly with
renames. Make that explicit, and point to the document where it is explained
in more detail.
- RCU is pretty standard now, and macros make implementations pretty mindless.
If we want to know about RCU barrier details, we look in RCU code.
- Delete some boring legacy comments because we don't care much about how the
code used to work, more about the interesting parts of how it works now. So
comments about lazy LRU may be interesting, but would better be done in the
LRU or refcount management code.
struct fs_struct.lock is an rwlock with the read-side used to protect root and
pwd members while taking references to them. Taking a reference to a path
typically requires just 2 atomic ops, so the critical section is very small.
Parallel read-side operations would have cacheline contention on the lock, the
dentry, and the vfsmount cachelines, so the rwlock is unlikely to ever give a
real parallelism increase.
Replace it with a spinlock to avoid one or two atomic operations in typical
path lookup fastpath.
There are 2 duplicate copies of code in dentry allocation in path lookup.
Consolidate them into a single function.
In do_lookup, if we initially find no dentry, we take the directory i_mutex and
re-check the lookup. If we find a dentry there, then we revalidate it if
needed. However if that revalidate asks for the dentry to be invalidated, we
return -ENOENT from do_lookup. What should happen instead is an attempt to
allocate and lookup a new dentry.
This is probably not noticed because it is rare. It is only reached if a
concurrent create races in first (in which case, the dentry probably won't be
invalidated anyway), or if the racy __d_lookup has failed due to a
false-negative (which is very rare).
Fix this by removing code and have it use the normal reval path.
Limit the maximum number of mb_cache entries depending on the number of
hash buckets: if the only limit to the number of cache entries is the
available memory the hash chains can grow very long, taking a long time
to search.
At least partially solves https://bugzilla.lustre.org/show_bug.cgi?id=22771.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
we want the assignment to err done inside the if () to be
visible after it, so (re)declaring err inside if () body
is wrong.
... not harmless in this case - we have a string in the end of buffer
already.
Fix the Errata AAK100/AAP53/BD53 workaround, the officialy documented
workaround we implemented in:
11164cd: perf, x86: Add Nehelem PMU programming errata workaround
doesn't actually work fully and causes a stuck PMU state
under load and non-functioning perf profiling.
A functional workaround was found by trial & error.
Affects all Nehalem-class Intel PMUs.
Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com>
LKML-Reference: <1281073148.2125.63.camel@ymzhang.sh.intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: <stable@kernel.org> # .35.x
commit 7b6d91daee5cac6402186ff224c3af39d79f4a0e changed the behaviour
of a few variables in raid1 and raid10 from flags to bit-sets, but
left them as type 'bool' so they did not work.
Change them (back) to unsigned long.
(historical note: see 1ef04fefe2241087d9db7e9615c3f11b516e36cf)
Signed-off-by: NeilBrown <neilb@suse.de>
Reported-by: Jiri Slaby <jslaby@suse.cz> and many others
These flags aren't real I/O types, but tell ll_rw_block to always
lock the buffer instead of giving up on a failed trylock.
Instead add a new write_dirty_buffer helper that implements this semantic
and use it from the existing SWRITE* callers. Note that the ll_rw_block
code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which
this patch fixes.
In the ufs code clean up the helper that used to call ll_rw_block
to mirror sync_dirty_buffer, which is the function it implements for
compound buffers.
Instead of abusing a buffer_head flag just add a variant of
sync_dirty_buffer which allows passing the exact type of write
flag required.
generic_acl_set didn't update the ctime of the file when its permission was
changed.
Steps to reproduce:
# touch aaa
# stat -c %Z aaa
1275289822
# setfacl -m 'u::x,g::x,o::x' aaa
# stat -c %Z aaa
1275289822 <- unchanged
But, according to the spec of the ctime, vfs must update it.
Port of ext3 patch by Miao Xie <miaox@cn.fujitsu.com>.
CC: Al Viro <viro@zeniv.linux.org.uk>
Commit 77b8a75f5bb introduced a warning at fs/inode.c:692 unlock_new_inode(),
caused by unlock_new_inode() being called on existing inodes as well.
This patch changes setup_inode() to only call unlock_new_inode() for I_NEW
inodes.
Signed-off-by: Alexander Shishkin <virtuoso@slind.org>
reiserfs_evict_inode calls end_writeback two times hitting
kernel BUG at fs/inode.c:298 becase inode->i_state is I_CLEAR already.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Added comments in kernel-doc notation for previously added struct fields.
Signed-off-by: Ernst Schwab <eschwab@online.de>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Using the coldfire qspi driver, I get the following error:
drivers/spi/coldfire_qspi.c: In function 'mcfqspi_irq_handler':
drivers/spi/coldfire_qspi.c:166: error: 'TASK_NORMAL' undeclared (first use in this function)
drivers/spi/coldfire_qspi.c:166: error: (Each undeclared identifier is reported only once
It is solved by adding the following include to coldfire_sqpi.c:
#include <linux/sched.h>
Fix suggested by Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
arch/m68knommu/kernel/process.c: formatting of pointers in printk()
Use %p instead of %08x in printk().
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
The arch/m68k/include/asm/ide.h produces errors when the IDE driver is compiled for my 523x uClinux system under kernel. The header makes some redefines of operators not defined in the arch/m68k/include/asm/io_no.h header. There are no separate mmio and iospace defines.
Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
