sched.h inclusion is definitely not needed like in 32-bit version,
remove it, fixup compilation.
Only difference for 32 and 64 bit version is dma64_addr_t and rest is same.
Also fixed the following 'make includecheck' warning:
arch/sparc/include/asm/types.h: asm-generic/int-ll64.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Besides creating the uncompressed vmlinux image for sparc64, also
create a compressed zImage. This is more consistent with other
architectures and required to make the 'deb-pkg' target work.
Signed-off-by: Jurij Smakov <jurij@wooyd.org>
Signed-off-by: Frans Pop <elendil@planet.nl>
The triggered field of struct poll_wqueues introduced in commit
5f820f648c92a5ecc771a96b3c29aa6e90013bba ("poll: allow f_op->poll to
sleep").
It was first set to 1 in pollwake() (now __pollwake() ), tested and
later set to 0 in poll_schedule_timeout(), but not initialized before.
As a result when the process needs to sleep, triggered was likely to be
non-zero even if pollwake() is not called before the first
poll_schedule_timeout(), meaning schedule_hrtimeout_range() would not be
called and an extra loop calling all ->poll() would be done.
This patch initialize triggered to 0 in poll_initwait() so the ->poll()
are not called twice before the process goes to sleep when it needs to.
Signed-off-by: Guillaume Knispel <gknispel@proformatique.com>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: stable@kernel.org
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes:
GFS2: Fix permissions on "recover" file
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (38 commits)
V4L/DVB (12441): siano: read buffer overflow
V4L/DVB (12440): Use kzalloc for frontend states to have struct dvb_frontend properly
V4L/DVB (12438): Read buffer overflow
V4L/DVB (12437): dvb: siano uses/depends on INPUT
V4L/DVB (12436): stk-webcam: read buffer overflow
V4L/DVB (12432): em28xx: fix regression in Empire DualTV digital tuning
V4L/DVB (12429): v4l2-ioctl: fix G_STD and G_PARM default handlers
V4L/DVB (12428): hdpvr: add missing initialization of current_norm
V4L/DVB (12424): soc-camera: fix recursive locking in .buf_queue()
V4L/DVB (12422): media/zr364xx: fix build errors
V4L/DVB (12405): em28xx-cards: move register 0x13 setting to the proper place
V4L/DVB (12411): em28xx: Fix artifacts with Silvercrest webcam
V4L/DVB (12410): em28xx: Move the non-board dependent part to be outside em28xx_pre_card_setup()
V4L/DVB (12407): em28xx: Adjust Silvercrest xtal frequency
V4L/DVB (12406): em28xx: fix: don't do image interlacing on webcams
V4L/DVB (12403): em28xx: properly reports some em2710 chips
V4L/DVB (12402): em28xx: fix: some em2710 chips use a different vendor ID
V4L/DVB (12401): m9v011: add vflip/hflip controls to control mirror/upside down
V4L/DVB (12400): em28xx: Allow changing fps on webcams
V4L/DVB (12399): mt9v011: Add support for controlling frame rates
Although this file is only ever written and not read by
userspace, it seems that the utils are opening this
file O_RDWR, so we need to allow that.
Also fixes the whitespace which seemed to be broken.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: David Teigland <teigland@redhat.com>
With mode DEVICE_MODE_RAW_TUNER a read occurs past the end of smscore_fw_lkup[].
Subsequently an attempt is made to load the firmware from the resulting
filename.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
properly
This patch changes most frontend drivers to allocate their state structure via
kzalloc and not kmalloc. This is done to properly initialize the
embedded "struct dvb_frontend frontend" field, that they all have.
The visible effect of this struct being uninitalized is, that the member "id"
that is used to set the name of kernel thread is totally random.
Some board drivers (for example cx88-dvb) set this "id" via
videobuf_dvb_alloc_frontend but most do not.
So I at least get random id values for saa7134, flexcop and ttpci based cards.
It looks like this in dmesg:
DVB: registering adapter 1 frontend -10551321 (ST STV0299 DVB-S)
The related kernel thread then also gets a strange name
like "kdvb-ad-1-fe--1".
Cc: Michael Krufky <mkrufky@linuxtv.org>
Cc: Steven Toth <stoth@linuxtv.org>
Cc: Timothy Lee <timothy.lee@siriushk.com>
Cc: Igor M. Liplianin <liplianin@me.by>
Signed-off-by: Matthias Schwarzott <zzam@gentoo.org>
Acked-by: Andreas Oberritter <obi@linuxtv.org>
parport[n] is checked before n < MAX_CAMS
siano uses input_*() functions so it should depend on INPUT
to prevent build errors:
ERROR: "input_event" [drivers/media/dvb/siano/sms1xxx.ko] undefined!
ERROR: "input_register_device" [drivers/media/dvb/siano/sms1xxx.ko] undefined!
ERROR: "input_free_device" [drivers/media/dvb/siano/sms1xxx.ko] undefined!
ERROR: "input_unregister_device" [drivers/media/dvb/siano/sms1xxx.ko] undefined!
ERROR: "input_allocate_device" [drivers/media/dvb/siano/sms1xxx.ko] undefined!
Cc: Uri Shkolnik <uris@siano-ms.com>
It tested the value of stk_sizes[i].m before checking whether i was in range.
Cc: Hans Verkuil <hverkuil@xs4all.nl>
Cc: Trent Piepho <xyzzy@speakeasy.org>
Restore support for digital tuning caused by regression during introduction
of disable_i2c_gate parameter to zl10353 driver.
Thanks to user "Xwang" for reporting the problem and testing the fix
Cc: Xwang <xwang1976@email.it>
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
The v4l core supplies default handlers for G_STD and G_PARM. However, both
default handlers are buggy.
This patch fixes the following:
1) If no g_std is supplied and current_norm == 0, then this driver does not
support TV video standards (e.g. a radio or webcam driver). Return
-EINVAL. This ensures that there is no bogus VIDIOC_G_STD support for
such drivers.
2) The default VIDIOC_G_PARM handler used current_norm instead of first
checking if the driver supported g_std and calling that to get the norm.
It also didn't check if current_norm was 0, since in that case the driver
does not support TV standards (or no standard was set at all) and the
default handler should return -EINVAL.
Note that I am very unhappy with these default handlers: I think they
basically behave like some very strange and unexpected side-effect.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Drivers should either set current_norm or supply a g_std callback.
The hdpvr driver does neither. Since it initializes to a 60 Hz format
I've initialized the current_norm to NTSC | PAL_M | PAL_60 which is the
60 Hz subset of tvnorms.
Cc: Janne Grunau <j@jannau.net>
The .buf_queue() V4L2 driver method is called under
spinlock_irqsave(q->irqlock,...), don't take the lock again inside the
function.
Reported-by: Antonio Ospite <ospite@studenti.unina.it>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Fix build errors in zr364xx by adding selects:
zr364xx.c:(.text+0x195ed7): undefined reference to `videobuf_streamon'
zr364xx.c:(.text+0x196030): undefined reference to `videobuf_dqbuf'
zr364xx.c:(.text+0x1960c4): undefined reference to `videobuf_qbuf'
zr364xx.c:(.text+0x196123): undefined reference to `videobuf_querybuf'
zr364xx.c:(.text+0x196182): undefined reference to `videobuf_reqbufs'
zr364xx.c:(.text+0x196224): undefined reference to `videobuf_queue_is_busy'
zr364xx.c:(.text+0x196390): undefined reference to `videobuf_vmalloc_free'
zr364xx.c:(.text+0x196571): undefined reference to `videobuf_iolock'
zr364xx.c:(.text+0x196678): undefined reference to `videobuf_mmap_mapper'
zr364xx.c:(.text+0x196760): undefined reference to `videobuf_poll_stream'
zr364xx.c:(.text+0x19689a): undefined reference to `videobuf_read_one'
zr364xx.c:(.text+0x1969ec): undefined reference to `videobuf_mmap_free'
zr364xx.c:(.text+0x197862): undefined reference to `videobuf_queue_vmalloc_init'
zr364xx.c:(.text+0x197a28): undefined reference to `videobuf_streamoff'
zr364xx.c:(.text+0x198203): undefined reference to `videobuf_to_vmalloc'
zr364xx.c:(.text+0x198603): undefined reference to `videobuf_streamoff'
drivers/built-in.o: In function `free_buffer':
zr364xx.c:(.text+0x19930c): undefined reference to `videobuf_vmalloc_free'
drivers/built-in.o: In function `zr364xx_open':
zr364xx.c:(.text+0x19a7de): undefined reference to `videobuf_queue_vmalloc_init'
drivers/built-in.o: In function `read_pipe_completion':
zr364xx.c:(.text+0x19b17f): undefined reference to `videobuf_to_vmalloc'
Register 0x13 seems to be a sort of image control, maybe gamma, white
level or black level. Lower values produce better images, while higher
values increases the contrast and shifts colors to green. 0xff produces
a black image. This register is not Silvercrest-specific, so its code
should be moved to a better place.
If this register is left alone, a random value can be found at the
register, producing weird results.
While here, let's remove register 0x0d, as it had no noticed effect at
the image.
Silvercrest mt9v011 sensor produces a 640x480 image. However,
previously, the code were getting only half of the lines and merging two
consecutive frames to "produce" a 640x480 image.
With the addition of progressive mode, now em28xx is working with a full
image. However, when the number of lines is bigger than 240, the
beginning of some odd lines are filled with blank.
After lots of testing, and physically checking the device for a Xtal, it
was noticed experimentally that mt9v011 is using em28xx XCLK as its
clock. Due to that, changing XCLK value changes the maximum speed of the
stream.
At the tests, it were possible to produce up to 32 fps, using a 30 MHz
XCLK. However, at that rate, the artifacts happen even at 320x240. Lower
values of XCLK produces artifacts only at 640x480.
At some values of xclk (for example XCLKK = 6 MHz, 640x480), it is
possible to see an invalid sucession of artifacts with this pattern:
.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
..xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
...xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
....xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
(where the dots represent the blanked pixels)
So, it seems that a waveform in the format of a ramp is interferring at
the image.
The cause of this interference is currently unknown. Some possibilities
are:
- electrical interference (maybe this device is broken?);
- some issue at mt9v011 programming;
- some bug at em28xx chip.
So, for now, let's be conservative and use a value of XCLK that we know
for sure that it won't cause artifacts.
As I'm waiting for more of such devices with different em28xx chipset
revisions, I'll have the opportunity to double check the issue with
other pieces of hardware.
Later patches can vary XCLK depending on the vertical resolutions, if a
proper fix is not discovered.
em28xx_pre_card_setup() is meant to contain board-specific initialization. Also,
as autodetection sometimes occur only after having i2c bus enabled, this
function may need to be called later.
Moving those setups to happen outside the function avoids calling it twice without
need and without duplicating output lines at dmesg.
We don't know the xtal frequency of Silvercrest, but we need to have
some value in order to allow controlling the frame rate frequency. The
value is probably still wrong, since the manufacturer announces this
device as being capable of 30fps, but the maximum we can get is
13.5 fps.
Due to historical reasons, em28xx driver gets two consecutive frames and
fold them into an unique framing, doing interlacing. While this works
fine for TV images, this produces two bad effects with webcams:
1) webcam images are progressive. Merging two consecutive images produce
interlacing artifacts on the image;
2) since the driver needs to get two frames, it reduces the maximum
frame rate by two.
As reported by hermann pitton <hermann-pitton@arcor.de>, some devices
has a different chip id for em2710 (likely the older ones):
em28xx: New device @ 480 Mbps (eb1a:2710, interface 0, class 0)
em28xx #0: Identified as EM2710/EM2750/EM2751 webcam grabber (card=22)
em28xx #0: em28xx chip ID = 17
Thanks to hermann pitton <hermann-pitton@arcor.de> for pointing this new
variation.
Tested-by: hermann pitton <hermann-pitton@arcor.de>
em28xx doesn't have temporal scaling. However, on webcams, sensors are
capable of changing the output rate. So, VIDIOC_[G|S]_PARM ioctls should
be passed to the sensor for it to properly set frame rate.
Implement g_parm/s_parm ioctls. Those are used to check the current
frame rate (in fps) and to set it to a value. In practice, there are
only 15 possible different speeds, due to chip limits.
A user discovered that the Geniatech x8000 encountered a regression when
the xc3028 power management was introduced. The xc3028 never recovers after
setting the powerdown register, which is probably because the xc3028 reset
GPIO is not properly configured. Since I do not have access to the hardware
and thus cannot determine the correct GPIO configuration, just disable xc3028
power management on this board, which fixes the regression.
Thanks to user "ritec" for reporting the issue and testing the fix.
Cc: rictec <rictec@netcabo.pt>
The introduction of the zl10353 i2c gate control broke support for the
Geniatech board (which is not behind an i2 gate). Add the needed parameter.
WinTV-HVR1120 DVB-T/Hybrid
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
WinTV-HVR1150 ATSC/QAM-Hybrid
Remove the following build warning:
sms-cards.c: In function 'sms_board_event':
sms-cards.c:120: warning: unused variable 'board'
Thanks to Hans Verkuil for pointing this out.
The problem code has been #if 0'd for now, this will likely be
used again in the future, once the event interface is complete.
type" messages
The iSight sends non-UVC status events through the interrupt endpoint. Those
invalid events are reported to the kernel log, resulting in a log flood.
Only log the events when the UVC_TRACE_STATUS flag is set.
Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be>
ViMicro devices
Commit 50144aeeb702ea105697ae5249f059ea3990b838 broke the Samsung NC10
netbook webcam. Instead of applying the FIX_BANDWIDTH quirk to all ViMicro
devices, list the devices explicitly.
The current GPIO configuration breaks all Hauppauge devices.
The code being removed affects Hauppauge devices only,
and is the cause of the breakage.
MAINTAINERS | 8 ++++++++
Signed-off-by: Brian Johnson <brijohn@gmail.com>
Acked-by: Jean-Francois Moine <moinejf@free.fr>
Moving BOOT fixes problem.
Signed-off-by: Nils Kassube <kassube@gmx.net>
Acked-by: Antti Palosaari <crope@iki.fi>
Currently, the VIDIOC_S_STD ioctl just returns -EINVAL regardless of
the norm passed. This patch sets cx23885_mpeg_template.tvnorms and
cx23885_mpeg_template.current_norm so that the VIDIOC_S_STD will work.
Thanks to Joseph Yasi for pointing this out, even though this particular
fix was already pushed into a development repository, merge priority of
this changeset has been escalated as a result of Joseph posting this
identical patch.
Signed-off-by: Joseph A. Yasi <joe.yasi@gmail.com>
Reviewed-by: Steven Toth <stoth@kernellabs.com>
back is reliable
Current tip is broken and does not switch back to DVB-T correctly
Signed-off-by: Sohail Syyed <linuxtv@hubstar.net>
Signed-off-by: Steven Toth <stoth@kernellabs.com>
This device uses msp34xx and uses 2.048 MHz frequency for I2S
communication.
Thanks to Angelo Cano <acano@fastmail.fm> for pointing the issues with
this device and proposing an approach for fixing the issue.
Tested-by: Angelo Cano <acano@fastmail.fm>
Fixes stack corruption bug present in dump_regs function of zl10353 and
qt1010 drivers: the buffer buf was one byte smaller than required -
there are 4 chars for address prefix, 16 * 3 chars for dump of 16 eeprom
bytes per line and 1 byte for zero ending the string required, i.e. 53
bytes, but only 52 were provided.
The one byte missing in stack based buffer buf can cause stack
corruption possibly leading to kernel oops, as discovered originally
with af9015 driver (af9015: fix stack corruption bug).
Signed-off-by: Jan Nikitenko <jan.nikitenko@gmail.com>
Some mt9v011 webcams report 0x8332 chip version, instead of 0x8243. From
the revision history at the mt9v011 datasheet, it seems that the chip
version has changed from the first release of the chip.
Thanks-to hermann pitton <hermann-pitton@arcor.de> for pointing this to
me, on his tests with a Silvercrest webcam.
This mistakenly tested against sizeof(freqs) instead of the array size. Due to
the mask the only illegal value possible was 3.
Reported-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Andy Walls <awalls@radix.net>
This mistakenly tests against sizeof(freqs) instead of the array size. Due to
mclk_get_divisor uses pcdev->soc_host.dev, make sure it is initialized.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
free_irq() can remove an irqaction while the corresponding interrupt
is in progress, but free_irq() sets action->thread to NULL
unconditionally, which might lead to a NULL pointer dereference in
handle_IRQ_event() when the hard interrupt context tries to wake up
the handler thread.
Prevent this by moving the thread stop after synchronize_irq(). No
need to set action->thread to NULL either as action is going to be
freed anyway.
This fixes a boot crash reported against preempt-rt which uses the
mainline irq threads code to implement full irq threading.
[ tglx: removed local irqthread variable ]
* 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf_counter: Report the cloning task as parent on perf_counter_fork()
perf_counter: Fix an ipi-deadlock
perf: Rework/fix the whole read vs group stuff
perf_counter: Fix swcounter context invariance
perf report: Don't show unresolved DSOs and symbols when -S/-d is used
perf tools: Add a general option to enable raw sample records
perf tools: Add a per tracepoint counter attribute to get raw sample
perf_counter: Provide hw_perf_counter_setup_online() APIs
perf list: Fix large list output by using the pager
perf_counter, x86: Fix/improve apic fallback
perf record: Add missing -C option support for specifying profile cpu
perf tools: Fix dso__new handle() to handle deleted DSOs
perf tools: Fix fallback to cplus_demangle() when bfd_demangle() is not available
perf report: Show the tid too in -D
perf record: Fix .tid and .pid fill-in when synthesizing events
perf_counter, x86: Fix generic cache events on P6-mobile CPUs
perf_counter, x86: Fix lapic printk message
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Fix handling of bad requeue syscall pairing
futex: Fix compat_futex to be same as futex for REQUEUE_PI
locking, sched: Give waitqueue spinlocks their own lockdep classes
futex: Update futex_q lock_ptr on requeue proxy lock
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix oops in identify_cpu() on CPUs without CPUID
x86: Clear incorrectly forced X86_FEATURE_LAHF_LM flag
x86, mce: therm_throt - change when we print messages
x86: Add reboot quirk for every 5 series MacBook/Pro
