Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
multicomponent support added/changed some device name but added some typos,
breaking existing OpenRD Client support.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
This patch modify dai link
- platform_name: sh_fsi/sh_fsi2 are used for FSI driver
- codec_name: ak4642/ak4643 are used for ak4642 driver
This is quick hack. I should modify it more wisely in future
Export s3c_device_pcm for all S3C24xx-devices, not
only for S3C2440;
Fix device name for s3c_device_iis;
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Disable some codec modules in standby mode, completely disable
codec in off mode to save some power.
Fix suspend/resume: mark mixer regs as dirty on resume to
restore mixer values, otherwise driver produces no sound
(master is muted by default).
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Swapping the bias level enumeration is only meant to help debugging. It is
easier if number 0 means bias off and bigger number means bigger bias level.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
This patch fixes up the au1x audio platform after the multi-component
merge:
- compile fixes and updates to get DB1200 platform audio working again,
- removal of global variables in AC97/I2S/DMA(PCM) modules.
The AC97 part is limited to one instance only for now due to issues
with getting at driver data in the soc_ac97_ops.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
Currently output controls are not uniform. Some routes are adjusted by
mono controls that don't match to associated mixer switch, many routes are
not covered at all and stereo controls have following variants:
- L-to-L & R-to-R
- R-to-L & R-to-R
- L-to-L & R-to-L
This patch attempts to fix these issues. First, for the convenience, only
direct L-to-L, R-to-R and [L | R]-to-Mono routes are controlled by the
stereo controls. This logic is also used with the output pin mute controls
so all of them except mono output are controlled by stereo switches.
Then rest of the swapped L-to-R and R-to-L routes are controlled by the
mono controls that map to mixer switches with a same name. Mixers can then
associate these switches and volumes together.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
It turned out that the output mixers and their routes were misdefined: They
are not mixing output pins to internal signals but opposite. This has worked
for direct left-to-left and right-to-right routes since for those there are
complete routes. For swapped left-to-right and right-to-left routes this is
not working since there are no routes defined between them.
Another consequence is that those misdefined mixers are incorrectly routed
to several output pins leading unnecessary pin powerings even if there is no
route active to them.
Fix these by reimplementing the output mixers and routes as they are in
hardware. For completeness add also a few missing links between internal
signals and outputs.
Each output pin has 7 consecutive control registers in tlv320aic3x register
map. First 6 of them control the signal mixing and one is for output level
and power control.
Sort these registers as they are sorted clearly in hardware, it makes also
definitions more readable and easier to pinpoint missing register
definitions.
Bit 3 in output pin_CTRL register mutes the whole output pin not just the
route from DAC so remove misleading DAC from control name. Currently only
"Line[L | R] Playback Switch" were correct.
Signed-off-by: Ian Lartey <ian@opensource.wolfsonmicro.com>
I think this is a typo, debugfs_pop_time should not be executable.
Acked-by: Liam Girdwood <lrg@slimloogic.co.uk>
If the platform device id is 1, the code will fallthrough the
case and incorrectly return -EINVAL. Add a break to avoid fallthrough.
Make logging slightly more verbose by including the device id.
This fixes an issue only present in multi-component.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
The "priv" allocated in pxa_ssp_probe() should be kfreed in pxa_ssp_remove().
In synchronous mode the SSI_SRCCR values are ignored. Instead
SSI_STCCR must be used for both receiving and transmitting.
The Makefile and Kconfig updates for WL1273 appear to have been mising
from the patch posted, add them.
This makes it that little bit easier to spot the diagnostics in the
logs.
Redefinition of rx51_aic3x_data got introduced when merging upstread changes
for 2.6.36 and ASoC Multi-Component Support.
This must go together with multi-component commit f0fba2a.
Cc: Tony Lindgren <tony@atomide.com>
Speaker amplifier is controlled by TWL4030 GPIO which may sleep. Therefore
use gpio_set_value_cansleep to get rid of runtime warning that is introduced
after the commit 9c4ba94 and to get a stack trace if ever executing this
code in atomic context.
aic3x_init does a soft reset first and thus TLV320AIC3x GPIO setup must be
done after doing the basic init. Before multi-component the init was done
at i2c probe time and GPIO setup at soc probe time.
'struct of_device' no longer exists, and its functionality has been merged
into platform_device. Update the MPC8610 HPCD audio drivers (fsl_ssi, fsl_dma,
and mpc8610_hpcd) accordingly.
Also add a #include for slab.h, which is now needed for kmalloc and kfree.
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into for-2.6.37
Otherwise we generate worrying (but benign) warnings for amps.
This is an ALSA codec for the Texas Instruments WL1273 FM Radio.
Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com>
The Freescale P1022 is a dual-core e500-based SOC with multimedia capabilities,
specifically the same SSI audio controller on the MPC8610. The P1022 DS
reference board includes a P1022 and a Wolfson Microelectronics WM8776
codec.
Fix reference to moved header file, which was unused anyway.
This change fixes below build error:
CC sound/soc/pxa/pxa2xx-ac97.o
sound/soc/pxa/pxa2xx-ac97.c:27:24: error: pxa2xx-pcm.h: No such file or directory
make[3]: *** [sound/soc/pxa/pxa2xx-ac97.o] Error 1
make[2]: *** [sound/soc/pxa] Error 2
make[1]: *** [sound/soc] Error 2
make: *** [sound] Error 2
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
This patch adds support for the tlv320aic3007 codec to the tlv320aic3x
driver.
The tlv320aic3007 is similar to the aic31, but has an additional class-D
speaker amp. The speaker amp control register overlaps with the mono
output register of other codecs in this family, so we add logic to
identify the actual codec being registered to set things up accordingly.
Signed-off-by: Randolph Chung <tausq@parisc-linux.org>
Some codecs have separate DAIs for playback and capture, so the DMA driver
should allocate a DMA buffer only for the streams that are valid when the
driver is opened.
In e740_init(), we call gpio_request() for
GPIO_E740_MIC_ON, GPIO_E740_AMP_ON and GPIO_E740_WM9705_nAVDD2.
We should free the these gpio accordingly in e740_exit().
In the process of unification of codec DAI names while implementing
multi-component, the CX20442 codec DAI has been renamed to "cx20442-hifi".
This new name seems not adequate for a 8kHz voice codec.
Use a better name, "cx20442-voice", as suggested by Liam Girdwood.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
The tlv320aic3x codec driver only supports symmetric rates for capture/
playback. Set the flag in the DAI accordingly.
Add code that programs the DMA and SSI controllers differently based on the
FIFO depth of the SSI.
The SSI devices on the MPC8610 and the P1022 are identical in every way except
one: the transmit and receive FIFO depth. On the MPC8610, the depth is eight.
On the P1022, it's fifteen. The device tree nodes for the SSI include a
"fsl,fifo-depth" property that specifies the FIFO depth.
88PM860x codec is used in Marvell saarb development board. 88PM860x codec
is used as master mode for SSP communication. Only I2S format is supported.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Add 88PM860x codec driver. 88PM860x codec supports two interfaces. And it
also supports headset/mic/hook/short detection.
Since the SSC is already being registered as a device under arch and
the DMA and SSC hardware are pretty much the same provide a simplified
device registration function for the Atmel SSC which will add the
ASoC-specific devices within the ASoC code, parenting the SSC device
off the actual SSC device. Also use it in the sam9g20-ek driver.
A couple of typos in the multi-component conversion.
Instead of unconditionally enabling the crystal oscillator on the WM8731
only enable it when explicitly selected via set_sysclk(), allowing machine
drivers to specify that they drive a clock into MCLK alone. This avoids
any conflicts between the oscillator and the external MCLK source and saves
power for systems which do not need the oscillator.
This should also deliver a small power saving on systems using the crystal
since the oscillator will only be enabled when the ADC or DAC is active.
