WoWLAN may need the NIC even after suspend. One should not do anything to the
NIC in the bus level, since one cannot check whether WoWLAN is enabled or not.
Same for resume.
Add a simple comment to the code to warn about this.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
The price to pay is the access to the log system. Therefore logs from bus layer
are sent by dev_printk instead of IWL_XXXX.
Rename bus->priv to bus->drv_data to make the separation even clearer.
Call iwl_probe with a ready iwl_bus struct. This means that the bus layer
assigns the irq, dev and iwl_bus_ops pointers to iwl_bus before giving it to
iwl_probe.
The device specific struct is allocated together with the common iwl_bus struct
by the bus specific layer. The pointer to the aggregate struct is passed to the
upper layer that holds a pointer to iwl_bus instead of an embedded iw_bus.
The private data given to the PCI subsystem is now iwl_bus and not iwl_priv.
Provide bus_* inliners on the way in order to simplify the syntax.
Rename iwl-pci.h -> iwl-bus.h since it is bus agnostic and represent the
external of the bus layer.
It still holds a pointer to iwl_priv. But hopefully this will disappear at some point.
Also add the multiple inclusion protection to iwl-trans.h that was forgotten.
Move iwl-trans structures to iwl-trans.h
This function is really related to the transport layer - move it.
Basically all the nic_init flow should be in the transport layer.
iwl_prepare_card_hw will move to the transport too in a separate patch.
All the configurations of the HW for AMPDU are now in the transport layer.
For temperature offset calibration, send radio sensor offset in le16 format
Use the valid calibration mask for init calibration
IWL_PHY_CALIBRATE_DIFF_GAIN_CMD is for legacy device, remove it
Set calibration config flag for complete notification
Since iwlagn_setup_deferred_work is always called, fold it into
iwl_setup_deferred_work. BT related works are setup by the new
bt_setup_deferred_work lib_ops.
Signed-off-by: Wey-Yi Guy <wey-yi.guy@intel.com>
Since iwlagn_rx_handler_setup is always called, fold it into
iwl_rx_handler_setup. BT related handlers are setup by the new
bt_rx_handler_setup lib_ops.
kick_nic means to remove the RESET bit from the embedded CPU
Previously, the mesh was running whenever the appropriate hardware
and firmware was present.
Now we only run the mesh when the interface is running.
Also simplifies interface management a little.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Acked-by: Dan Williams <dcbw@redhat.com>
Remove unused blindlist code.
Mark a few items const and static where possible. Involved some
code re-ordering, but no code changes.
Cc: Bing Zhao <bzhao@marvell.com>
Cc: "Luis R. Rodriguez" <lrodriguez@atheros.com>
Cc: ath9k-devel@lists.ath9k.org
Cc: Larry Finger <Larry.Finger@lwfinger.net>
commit 58389c69150e6032504dfcd3edca6b1975c8b5bc
Author: Johannes Berg <johannes.berg@intel.com>
Date: Mon Jul 18 18:08:35 2011 +0200
cfg80211: allow userspace to control supported rates in scan
made single-band cards crash since it would always
access all wiphy->bands[]. Fix this and reject any
attempts in the new helper ieee80211_get_ratemask()
to do the same, rejecting rates configuration for
unsupported bands.
Reported-by: Pavel Roskin <proski@gnu.org>
Tested-by: Pavel Roskin <proski@gnu.org>
Signed-off-by: Pavel Roskin <proski@gnu.org>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
ieee80211_stop_rx_ba_session() was calling sta_info_get()
without rcu locking, and the return value was not
checked.
This resulted in the following panic:
[<bf05726c>] (ieee80211_stop_rx_ba_session+0x0/0x60 [mac80211])
[<bf0abd94>] (wl1271_event_handle+0x0/0xdc8 [wl12xx])
[<bf0a7308>] (wl1271_irq+0x0/0x4a0 [wl12xx])
[<c00c40a8>] (irq_thread+0x0/0x254)
[<c00a7398>] (kthread+0x0/0x8c)
Signed-off-by: Eliad Peller <eliad@wizery.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
cfg80211_netdev_notifier_call() is configuring psm in case
of NL80211_IFTYPE_STATION interface type (on NETDEV_UP).
do the same for NL80211_IFTYPE_P2P_CLIENT interface type.
In P2P client mode, the GO (AP) to connect to might
have periods of time where it is not available due
to powersave. To allow the driver to sync with it
and send frames to the GO only when it is available
add a new callback tx_sync (and the corresponding
finish_tx_sync). These callbacks can sleep unlike
the actual TX.
Both ath5k_hw and ath5k_softc represent one instance of the hardware.
This duplication is historical and is not needed anymore.
Keep the name "ath5k_hw" for the merged structure and "ah" for the
variable pointing to it. "ath5k_hw" is shorter than "ath5k_softc", more
descriptive and more widely used.
Put the combined structure to ath5k.h where the old ath5k_softc used to
be. Move some code from base.h to ath5k.h as needed.
Remove memory allocation for struct ath5k_hw and the corresponding error
handling. Merge iobase and ah_iobase fields.
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Recent experiments have shown many cores share 0x1E0 register used for
clock management.
Some of the newer Broadcom chipsets have longe names like BCM43224,
BCM43225, etc. However Broadcom decided to keep using u16 for storing
them. Use %X or %d depending on chip_id value to avoid BCMA8D8, etc.
Acked-by: Pavel Roskin <proski@gnu.org>
Scanning currently uses the TX rate mask to
restrict the rate set, which is bogus. Make
it use the new set of rates from userspace.
Some P2P scans are not allowed to advertise
11b rates, but that is a rather special case
so instead of having that, allow userspace
to request the rate sets (per band) that are
advertised in scan probe request frames.
Since it's needed in two places now, factor
out some common code parsing a rate array.
Old masks were causing ugly, delayed lock ups.
These are needed by ath6kl for parsing tspec status from an IE.
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
Some cards do not use additional 0x30 offset for SPROM location. We do
not know the real condition for it yet, make it BCM4331 specific for
now.
Following operation was incorrectly translated:
radio_read(0x0011) -> 0xffff
radio_write(0x0011) <- 0xfff7
Also change the default channel to 11. This is the first channel closed
driver switches to.
BCMA_IOCTL is register in agent (AKA wrapper) core, we need to use
special R/W ops for it.
drivers/net/wireless/ath/ath9k/hif_usb.c +135 hif_usb_mgmt_cb(6) warn:
variable dereferenced before check 'cmd'
drivers/net/wireless/ath/ath9k/btcoex.c +77 ath9k_hw_init_btcoex_hw(38)
error: buffer overflow 'ah->hw_gen_timers.gen_timer_index' 32 <=
2009813776
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Kalle Valo has asked me to take over the maintenance of the wl1251
driver. Thanks Kalle for all his work on the wl1251 driver, I'll try
to keep up with his good work from now on.
At the same time, update the Web URL to something more specific.
There's not much in that page, but we will try to update it soon.
Signed-off-by: Luciano Coelho <coelho@ti.com>
Acked-by: Kalle Valo <kvalo@adurom.com>
drivers/net/wireless/ath/ath9k/init.c:199:21: warning: context imbalance
in 'ath9k_reg_rmw' - different lock contexts for basic block
drivers/net/wireless/ath/ath9k/xmit.c:1175:31: warning: context
imbalance in 'ath_drain_txq_list' - unexpected unlock
drivers/net/wireless/ath/ath9k/xmit.c:2047:23: warning: context
imbalance in 'ath_tx_process_buffer' - unexpected unlock
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c:3041:24: warning: cast to
restricted __le32
We use all that functions by pointers only. This forces compiler to
create additional duplicated functions that are not inline.
Noticed by Michael in similar bcma code.
Harshal Chhaya discovered during network tests, that
several of his clients dropped-off the network. The
captured packets shows that the beacons sent by the
AP are at a much lower power than the other data
packets.
The reason for this mishap: The driver never updated
the beacon phy register, so all beacons were always
sent at the lowest power.
Reference: http://marc.info/?l=linux-wireless&m=131067225105801
Reported-by: Harshal Chhaya <harshal@gmail.com>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
* reserves feature bit for CCA counters
* extends hardware register file definitions
