Some pcnet32 hardware erroneously has the Vendor ID for Trident. The
pcnet32 driver looks for the PCI ethernet class before grabbing the
hardware, but the current trident driver does not check against the PCI
audio class. This allows the trident driver to claim the pcnet32 hardware.
This patch prevents that.
This revised version of the OSS Trident patch includes PCI_DEVICE Macro
usage.
Signed-off-by: Jon Mason <jdmason@us.ibm.com>
Signed-off-by: Muli Ben-Yehuda <mulix@mulix.org>
Fix incorrect variable size used to hold register value. This bug might
wipe out a portion of the TCR value when setting the interface options.
Signed-off-by: Paul Fulghum <paulkf@microgate.com>
On alpha:
In file included from drivers/scsi/sym53c8xx_2/sym_glue.h:59,
from drivers/scsi/sym53c8xx_2/sym_fw.c:40:
include/scsi/scsi_transport_spi.h:57: error: field `dv_mutex' has incomplete type
Cc: James Bottomley <James.Bottomley@steeleye.com>
Fix a typo/mis-merge in one of the previous patches.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Andi Kleen <ak@suse.de>
We have to check that also the second checkpoint list is non-empty before
dropping the transaction.
While checkpointing we have to check that our transaction still is in the
checkpoint list *and* (not or) that it's not just a different transaction
with the same address.
Based upon a report and preliminary patch from Jim Gifford.
I have the following patch for serial console over the RSC
(remote system controller) on my E250 machine. It basically adds
support for input-device=rsc and output-device=rsc from OBP, and
allows 115200,8,n,1,- serial mode setting.
Add an entry to MAINTAINERS for wireless networking, just so people
know whom to bless with patches.
Correct location info for net-2.6 git tree.
Patch from David Vrabel
Export ixp4xx_exp_bus_size so modules can use the IXP4XX_EXP_BUS_BASE(n) macro.
Also, fix a printk format warning.
Signed-off-by: David Vrabel <dvrabel@arcom.com>
Patch from Nicolas Pitre
Commit f4619025a51747a3788fd1bb6bdc46e368a889a7 broke the kernel
decompressor (at least on PXA). Here's the fix.
Signed-off-by: Nicolas Pitre <nico@cam.org>
This is kernel provided user space code.
Since a syscall is used, it has to be updated to work with EABI.
The signal return path consists of user code provided by the kernel.
Noticed by Daniel Jacobowitz.
Patch from Andrew Victor
This patch fixes two small issues with 2.6.15-git12.
1) Corrected major/minor numbers for ttyAT devices in the KConfig help.
(Patch from Karl Olsen)
2) tty->flip.count has been removed.
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
PXA27x SSP controller has a few different registers, including SCR (serial clock rate) in SSCR0.
1) fix "mld_marksources()" to
a) send nothing when all queried sources are excluded
b) send full exclude report when source queried sources are
not excluded
c) don't schedule a timer when there's nothing to report
2) fix "add_grec()" to send empty-source records when it should
The original check doesn't account for a non-empty source
list with all sources inactive; the new code keeps that
short-circuit case, and also generates the group header
with an empty list if needed.
3) fix mca_crcount decrement to be after add_grec(), which needs
its original value
4) add/remove delete records and prevent current advertisements
when an exclude-mode filter moves from "active" to "inactive"
or vice versa based on new filter additions.
Items 1-3 are just IPv4 versions of the IPv6 bugs found
by Yan Zheng and fixed earlier. Item #4 is a related bug that
affects exclude-mode change records only (but not queries) and
also occurs in IPv6 (IPv6 version coming soon).
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
Don't assume 16.
Found by Ben Greear.
Jean says he really doesn't have time to much IRDA any more.
The following would help motivate someone who has more time.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Remove page refcount manipulations from cassini driver by using
another field in struct page. Needed for lockless pagecache.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Signed-off-by: John Ronciak <john.ronciak@intel.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
in attempting to not send the "prefetch" patch, we broke the receive code,
this patch fixes that issue.
Added e1000_mc_addr_list_update
Added e1000_read_reg_io
Added e1000_enable_pciex_master
These are not static functions, that is why we have them declared in the header.
These functions help restore the driver to active configuration when coming out of resume for power management.
Align the prefetches to a dword to help speed them up.
Recycle skb's and early replenish.
Force memory writes to complete before fetching more descriptors.
Adds the ability to disability packet split at compile time and use the legacy receive path on PCI express hardware. Made this a CONFIG option and modified the Kconfig, to reflect the new option.
There is a new device which is look like:
Serial controller: Decision Computer International Co. PCCOM2 (rev 02) (prog-if 02 [16550])
0700: 6666:0004 (rev 02) (prog-if 02)
Flags: medium devsel, IRQ 177
Memory at fe000000 (32-bit, non-prefetchable) [size=128]
I/O ports at e880 [size=128]
I/O ports at e400 [size=256]
It has two 16550A, and is not listed in kernel, although the
manufacturer clams that it is supported...
I've created the following patch, it only add the new PCI id and the
card to the repository, it seems to work.
Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com>
Commit 7493a314cb83797ce612a577475aacaedc553fed changed the ordering
of the registration of the platform device driver vs the 8250 drivers
internal initialisation. This led to the probe function being called
before the driver had finished its internal initialisation, causing
mayhem. Revert the ordering change.
BUG: using smp_processor_id() in preemptible [00000001] code: rpc.statd/2408
And it _is_ a bug, but I guess we don't care enough to add preempt_disable().
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
a page while we are still submitting other buffers on the same page for
I/O.
SGI-PV: 948197
SGI-Modid: xfs-linux-melb:xfs-kern:25004a
Signed-off-by: David Chinner <dgc@sgi.com>
Signed-off-by: Nathan Scott <nathans@sgi.com>
sparse can't parse a struct definition in include/asm-powerpc/lppaca.h,
even though gcc can accept it. The form looks like this:
struct __attribute__((whatever)) foo { };
An equivalent that both gcc and sparse can handle is
struct foo { } __attribute__((whatever));
This is the only definition of this type in the tree, and fixing it is
easier than fixing sparse.
Signed-off-by: Bryan O'Sullivan <bos@serpentine.com>
[ Side note: fixing sparse wouldn't be hard, but the "attribute at the
end" version is the canonical one, and the one that makes sense. So
let's just fix the kernel instead. Luc Van Oostenryck already sent
out a sparse patch to the sparse mailing list in case anybody cares.
-- Linus ]
There are a couple of problems in the DMA setup code for skge.
* In the 64 bit case, it doesn't set the consistent mask.
* In the 32 bit case, the error check is backwards!
It likely will only be visible as a bug on 64 bit platforms.
Signed-off-by: Alan Cox <alan@redhat.com>
Somewhat cleaner in the resync as someone cleaned up the pio xfer users
IRQ flag for next diff
Signed-off-by: Jason Gaston <Jason.d.gaston@intel.com>
