Calculate SYS_MCLK using sample rate or SYS_FS.
These helpers allow to simplify a code to set up external system clock
for different sample rates.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Backported commit 8326ab1285e71e24481d8e1eee3e72a6b3abbb38
If VDDA != VDDIO and any of them is greater than 3.1V, charge pump
source can be assigned automatically [1].
[1] https://www.nxp.com/docs/en/data-sheet/SGTL5000.pdf
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Backported commit 8337f764b45e122bd17b8c84b7ac26da3086fe26
To enable "zero cross detect" for ADC/HP, change
HP_ZCD_EN/ADC_ZCD_EN bits only instead of writing the whole
CHIP_ANA_CTRL register.
Backported from commit 19a1d41649f695658a67898dcb9312de02878eb1.
This control mute/unmute the ADC input of SGTL5000
using its CHIP_ANA_CTRL register.
Tuned: add Headphone and Line-Out mute/unmute controlling.
Backported from commit 55e23d488cd1367638ee304bd8bb6210f53d13db.
SGTL5000_SMALL_POP is a bit mask, not a value. Usage of
correct definition makes device probing code more clear.
Backported from commit e6e98e2e05baa3862ac7d1d2334f88ec927c8f66.
VAG power control is improved to fit the manual [1]. This patch fixes as
minimum one bug: if customer muxes Headphone to Line-In right after boot,
the VAG power remains off that leads to poor sound quality from line-in.
I.e. after boot:
- Connect sound source to Line-In jack;
- Connect headphone to HP jack;
- Run following commands:
$ amixer set 'Headphone' 80%
$ amixer set 'Headphone Mux' LINE_IN
Change VAG power on/off control according to the following algorithm:
- turn VAG power ON on the 1st incoming event.
- keep it ON if there is any active VAG consumer (ADC/DAC/HP/Line-In).
- turn VAG power OFF when there is the latest consumer's pre-down event
come.
- always delay after VAG power OFF to avoid pop.
- delay after VAG power ON if the initiative consumer is Line-In, this
prevents pop during line-in muxing.
According to the data sheet [1], to avoid any pops/clicks,
the outputs should be muted during input/output
routing changes.
Fixes: 9b34e6cc3bc2 ("ASoC: Add Freescale SGTL5000 codec support")
Prepare to use SND_SOC_DAPM_PRE_POST_PMU definition to
reduce coming code size and make it more readable.
Cc: stable@vger.kernel.org
Patch-cc: stable
Patch-cc: Sasha Levin <sashal@kernel.org>
Series-changes: 5
- Add explicit stable tag
Series-changes: 4
- CC the patch to kernel-stable
Series-changes: 2
- Fix patch formatting
For iptables filtering to work we need the NF_FILTER kernel module.
This fixes TC58NYG2S0HBAI4 and TH58NYG3S0HBAI4 which got added in
commit 2a1eb198705c ("colibri_t20: nand: add new v1.2b flashes")
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
To avoid spurious shutdowns on over-temperature make sure we read the
temperature 3 times in a row.
Using module parameter, Etherent compliance testing
can be run.
The current reset-gpio support triggers an interrupt storm on platforms
using the maxtouch with level based interrupt. The Motorola Droid 4,
which I used for some of the tests is not affected, since it uses a edge
based interrupt.
This change avoids the interrupt storm by enabling the device while its
interrupt is disabled. Afterwards we wait 100ms. This is important for
two reasons: The device is unresponsive for some time (~22ms for
mxt224E) and the CHG (interrupt) line is not working properly for 100ms.
We don't need to wait for any following interrupts, since the following
mxt_initialize() checks for bootloader mode anyways.
This fixes a boot issue on GE PPD (watchdog kills device due to
interrupt storm) and does not cause regression on Motorola Droid 4.
Fixes: f657b00df22e ("Input: atmel_mxt_ts - add support for reset line")
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
(cherry picked from commit ca1cd36cef00260db6b35b32d863e0c580c0488d)
(cherry picked from commit 40af4dba5fe9c14bd254fde06b1f64f8c0348974)
Provide support for controlling reset pin. If this is not driven
correctly the device will be held in reset and will not respond.
Acked-by: Rob Herring <robh@kernel.org>
(cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f)
(cherry picked from commit 51a32466a0ca40843039b6d1f1e719bc93db8a21)
Switch mxt_data and interrupt to resource managed allocation methods,
which cleans up the driver slightly and prepares for adding
reset GPIO support.
(cherry picked from commit 8cc8446b9b62ef954b630ed30e53bd1553e916a6)
When using the 'object' sysfs attribute, T100 is not displayed in
the output.
Signed-off-by: Maxime Roussin-Bélanger <maxime.roussinbelanger@gmail.com>
(cherry picked from commit 089b50d95948f691589cca4d81f1f8761747dbaa)
If a function declares a variable to access a structure element,
use it consistently.
(cherry picked from commit d7ddf15414dd598b9b875664e6b7aebe6c988f5d)
This reverts commit 28531a1ff5ca27c0ab7e2f99bbb0058858b72aa5.
Building kernels before linux-4.7 with gcc-8 results in many build failures
when gcc triggers a check that was meant to catch broken compilers:
/tmp/ccCGMQmS.s:648: Error: .err encountered
According to the discussion in the gcc bugzilla, a local "register
asm()" variable is still supposed to be the correct way to force an
inline assembly to use a particular register, but marking it 'const'
lets the compiler do optimizations that break that, i.e the compiler is
free to treat the variable as either 'const' or 'register' in that case.
Upstream commit 9f73bd8bb445 ("ARM: uaccess: remove put_user() code
duplication") fixed this problem in linux-4.8 as part of a larger change,
but seems a little too big to be backported to 4.4.
Let's take the simplest fix and change only the one broken line in the
same way as newer kernels.
Suggested-by: Bernd Edlinger <bernd.edlinger@hotmail.de>
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=85745
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=86673
(cherry picked from commit 0ca85fc310e8c24cba10ed241a0188795e177683)
/tmp/ccmcXtfu.s: Assembler messages:
/tmp/ccmcXtfu.s:1441: Error: .err encountered
arch/arm/include/asm/uaccess.h
gcc-7 has an "optimization" pass that completely screws up, and
generates the code expansion for the (impossible) case of calling
ilog2() with a zero constant, even when the code gcc compiles does not
actually have a zero constant.
And we try to generate a compile-time error for anybody doing ilog2() on
a constant where that doesn't make sense (be it zero or negative). So
now gcc7 will fail the build due to our sanity checking, because it
created that constant-zero case that didn't actually exist in the source
code.
There's a whole long discussion on the kernel mailing about how to work
around this gcc bug. The gcc people themselevs have discussed their
"feature" in
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785
but it's all water under the bridge, because while it looked at one
point like it would be solved by the time gcc7 was released, that was
not to be.
So now we have to deal with this compiler braindamage.
And the only simple approach seems to be to just delete the code that
tries to warn about bad uses of ilog2().
So now "ilog2()" will just return 0 not just for the value 1, but for
any non-positive value too.
It's not like I can recall anybody having ever actually tried to use
this function on any invalid value, but maybe the sanity check just
meant that such code never made it out in public.
Reported-by: Laura Abbott <labbott@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
(cherry picked from commit 474c90156c8dcc2fa815e6716cc9394d7930cb9c)
tools/include/linux/log2.h
File does not exist in the 3.1 kernel, change dropped.
This helps with the move to GCC 8.
| include/linux/log2.h:22:1: error: ignoring attribute 'noreturn' because it conflicts with attribute 'const' [-Werror=attributes]
| int ____ilog2_NaN(void);
On a system running glibc trunk perf doesn't build:
CC builtin-sched.o
builtin-sched.c: In function ‘get_cpu_usage_nsec_parent’: builtin-sched.c:399:16: error: storage size of ‘ru’ isn’t known builtin-sched.c:403:2: error: implicit declaration of function ‘getrusage’ [-Werror=implicit-function-declaration]
Fix it by including sys/resource.h.
Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Link: http://lkml.kernel.org/r/20120404084527.GA294@x4
(cherry picked from commit 7b78f13603c6fcb64e020a0bbe31a651ea2b657b)
Leave reset line setup to the capacitive touch drivers.
This commit adds support for the 2nd CSI Camera Module 5MP OV5640 with
SCCB_ID of 0x3d connected to Apalis T30 Mezzanine V2.0A on X4 aka
CSI_2_CSI-2/2x.
(cherry picked from commit 22a2065b9a3fa6ad458e3100b66c4acaa05f2466)
In order to avoid any floating SD card detect pins as may e.g. happen on
Ixora V1.1A pull them all up.
Adds compile time option to enable support for
Toradex Capacitive Touch Adapter.
Let the kernel print some debug messages when a user program
crashes due to an exception.
We already use them for openat() and friends, but fchdir() also wants to
be able to use O_PATH file descriptors. This should make it comparable
to the O_SEARCH of Solaris. In particular, O_PATH allows you to access
(not-quite-open) a directory you don't have read persmission to, only
execute permission.
Noticed during development of multithread support for ksh93.
Reported-by: ольга крыжановская <olga.kryzhanovska@gmail.com>
Cc: stable@kernel.org # O_PATH introduced in 3.0+
(cherry picked from commit 332a2e1244bd08b9e3ecd378028513396a004a24)
We already use them for openat() and friends, but fstat() also wants to
be able to use O_PATH file descriptors. This should make it more
directly comparable to the O_SEARCH of Solaris.
Note that you could already do the same thing with "fstatat()" and an
empty path, but just doing "fstat()" directly is simpler and faster, so
there is no reason not to just allow it directly.
See also commit 332a2e1244bd, which did the same thing for fchdir, for
the same reasons.
(cherry picked from commit 55815f70147dcfa3ead5738fd56d3574e2e3c1c2)
Use the *_light() versions that properly avoid doing the file user count
updates when they are unnecessary.
(cherry picked from commit e994defb7b6813ba6fa7a2a36e86d2455ad1dc35)
Add user crypto to defconfigs.
The upcomming crypto user configuration api needs to identify
crypto instances. This patch adds a flag that is set if the
algorithm is an instance that is build from templates.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
(cherry picked from commit 64a947b1337b93061da7c7af1f6ce6b2431b70ae)
The upcomming crypto usrerspace configuration api needs
to remove the spawns on top on an algorithm, so export
crypto_remove_final.
(cherry picked from commit 22e5b20be72e2e166c3ba915b01a59a8eb2dc71f)
The list_empty case in crypto_alg_match() will return without calling
up_read() on crypto_alg_sem. We could do the "goto out" routine, but the
function will clearly do the right thing with that test simply removed.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
(cherry picked from commit fb223c32b4d3ee593c8dce07e983680d06abe387)
We need to default match to 0 as otherwise it may lead to a false
positive.
(cherry picked from commit e6ea64ece7f4c14294b2fce5403b1e71eab87f1e)
(cherry picked from commit 540b97c1dd9ee68112269be322d901f1edc1a282)
(cherry picked from commit 07a5fa4abd8b6965d4585d3b110f89bdf5612aff)
(cherry picked from commit 792608e9c215141fa4b870b7b2a23767a1ef12f4)
(cherry picked from commit a55465dca7befd31f4ffa54508d4e2d1e701b8dc)
(cherry picked from commit b735d0a91556fd9fd5bbeeebd7d327c2d92c36c8)
(cherry picked from commit 6ad414fe710d4fd3a8c8c6c2ad8fefcfcc207968)
(cherry picked from commit 3e29c1095a091f606a26c04a6542061c9e5f1d6b)
(cherry picked from commit 29ffc87640e2a5bf0ab98bfeed8d6fc78b2d848e)
(cherry picked from commit 50496a1fab6c6a90b77da4b247321a88e632bd46)
