bug 1021221
Change-Id: Ifbe007de5bdeafaa15a0b3f2a138086045eba160
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/118179
(cherry picked from commit 74be8d4e7210d7bcea0d55565a7cbb06d6cc960e)
Reviewed-on: http://git-master/r/121087
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
do_heap_alloc locates a suitable free block from a nvmap heap given a
size and alignment. Unfortunately, if a heap block happens to be
smaller than the alignment passed to the function, an integer overflow
will occur, and a block that's too small gets accidentally returned.
Bug 1032642
Change-Id: Ic650c520409134d753e968f62f144ddeb065ccc7
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Reviewed-on: http://git-master/r/123076
GVS: Gerrit_Virtual_Submit
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
LOCALVERSION_AUTO is set by default.
And git commit will be part of the version.
E.g. "3.1.10-g0fe9b4a" where 0fe9b4a is the commit.
The version will appear in kpanic logs.
It would help developers to know the exact kernel version.
But a tagged commit (main-ics-2012.06.07-A5) will lead to no git info.
E.g. "3.1.10"
This patch will solve the issue.
Change-Id: I28370ada903b4be12bfc51eb3626512572e15c20
wChange-Id: I9dbb6c0a9e2964ead92114197a6d5c457ed7aab9
Signed-off-by: Tao Hu <taoh@nvidia.com>
Reviewed-on: http://git-master/r/123670
Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
E1853 is T30 based automotive platform. Modify Makefile to support build
of E1853 board. Also, added config option to Kconfig file.
Bug 966833
Bug 1018258
Change-Id: I18dc015b79256fde1c77947198b426a0060a9017
Signed-off-by: Ashwin Joshi <asjoshi@nvidia.com>
Reviewed-on: http://git-master/r/118932
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
(cherry picked from commit bed57d893803f2ccef8f40bd30bdf1e8a44f184b)
Reviewed-on: http://git-master/r/119652
Tested-by: Haribabu Narayanan <hnarayanan@nvidia.com>
Reviewed-by: Bob Johnston <bjohnston@nvidia.com>
To fix an instability issue, the power sequence is updated to match
the specification for this device.
bug 1031318
Change-Id: I3970af7ae8ed2baa6060f548242b0093040afb53
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/122867
Reviewed-by: Patrick Shehane <pshehane@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
In rpm_suspend, when suspend fail,
before going to reschedule another autosuspend,
wake_up_all is required to avoid remote wakeup
issues.
Bug 1026169
Bug 1027598
Bug 1032565
Change-Id: Ieaf9282dae59b2cb343bf01aa2ba837a8cdc39c7
Signed-off-by: BH Hsieh <bhsieh@nvidia.com>
Reviewed-on: http://git-master/r/122978
Reviewed-by: Neil Patel <neilp@nvidia.com>
Tested-by: Neil Patel <neilp@nvidia.com>
Tested-by: Steve Lin <stlin@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Sometimes USB connect and disconnect events is not detected properly. The
OTG irq handler is using a workqueue which has no protection for multiple
incoming event handling.
This patch adds mutex to protect the workqueue for USB connection
handling.
BUG 968345
Change-Id: If1c6fec4231dd0dc918f7f278e0a1d7667782917
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/122308
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Current Tegra UDC driver share same IRQ with OTG driver, and it will call
bus_resume() even if there is no UDC IRQ pending.
This patch will check UDC IRQ source and will not cause bus resume if no
IRQ pending for UDC driver.
BUG 1015685
Change-Id: Ifc5634ae5d1f7f1435c64bc527ab2e9fb8d0e36b
Reviewed-on: http://git-master/r/121896
Reviewed-by: Simone Willett <swillett@nvidia.com>
Enable the USB charging based on the USB charging spec 1.2. Now we can
detect:
1. SDP (stanardard downstream port)
2. CDP (charging downstream port)
3. DCP (dedicated charging port)
4. None (no cable connected)
5. Non-standard charger
For some non-standard charger, we cannot detect it as DCP device.
If we find a charger detected as USB device but no EP0 packet recieved
with 1s, we then decided this is 1A charger.
bug 968345
Change-Id: I804f90ea6e4794da8f52b1c3ebd694828d99f40e
Reviewed-on: http://git-master/r/120218
Check return code for set_page_array_* calls.
Change-Id: Ie62ac78b82321939d5bd9d2a636d72dadea50d28
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/123544
When a otg cable is connected along with device during lp0
system will wakeup but might not complete device enumeration
before going back to lp0. In this case we have to handle pmc
disable.
Bug 1024456
Change-Id: I9acbf434e58776c3d58de1b28d442d6b20b256d0
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/123383
Increase max packet size and clean up timing logic so we can better
recover from not getting an interrupt in time for a SOF.
Bug 1026047
Signed-off-by: Mike Lockwood <lockwood@google.com>
(cherry picked from commit 3d2096a7959d023bc31a3cf934c3d425de01c94f)
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Change-Id: I0a0a6f448e71e4a0c478bb44cadc54fa021e13e4
Reviewed-on: http://git-master/r/123344
This driver presents a standard USB audio class interface to the host
and an ALSA PCM device to userspace
Bug 1026047
(cherry picked from commit a23ff394752015a233dd3b27b05c9d913cbf5536)
Change-Id: I4054e09888f17d9cdfcfd4a3d430ca5cfb3fd9fa
Reviewed-on: http://git-master/r/123343
Bug 1026047
(cherry picked from commit 7a3d01af4f04950a86a18f5a439f1802d8093650)
drivers/usb/gadget/f_accessory.c
Change-Id: I30bc02a1bcf636967d56370db83578f49f0e7514
Reviewed-on: http://git-master/r/123342
The control request will be used by the host to enable/disable USB audio
and the ioctl will be used by userspace to read the audio mode
Bug 1026047
(cherry picked from commit 3e1ff6142761eef148c667e540381d1fbc437d4f)
Change-Id: I5f449de230ca8f44e2dae30a0f87772310b68f20
Reviewed-on: http://git-master/r/123341
bug 1033234
Change-Id: I67a28113fbf0a2461886658322f9106d17a69f23
Signed-off-by: Kerwin Wan <kerwinw@nvidia.com>
Reviewed-on: http://git-master/r/123301
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
nvmap_map_into_caller_ptr takes a memory handle from usermode
and adds a memory mapping for the handle. However, the handle
is not checked for being allocated. An unallocated handle
would cause a kernel panic later on from a NULL dereference.
Change-Id: I73987b097a0c843b913660445e8bd1b4755dac61
Reviewed-on: http://git-master/r/119689
The direction apis and irq_set_wake() support the
configuration of pins in gpio mode and hence it
is not require to export the apis for gpio_enable()/
gpio_disable().
Hiding these api.
Change-Id: I5493e4f270df85da21afb6500ac841f4fa4b522a
Reviewed-on: http://git-master/r/119616
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
This adds a frequency histogram of the frequencies that SCLK
and CBUS clocks go to over time. Stats are presented in the
debugfs at /d/clock_stats/cbus and /d/clock_stats/sclk only if
debugfs is enabled in config
Change-Id: Icae83329612958d8ed4318b2e10c487683d9d734
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/118380
Reviewed-by: Wen Yi <wyi@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Currently dr_controller_run() is called only during otg state
change.
When we unload a gadget driver, for example g_mass_storage
gadget driver, dr_controller_stop() is called but when it is
loaded back dr_controller_run() won't get called becasue of the
if condition failure. i.e
if (!udc->transceiver) {
dr_controller_run(udc);
So when the gadget driver is loaded for the second time
without removing the cable (i.e without otg state change),
the device won't get enumerated on the host because DR
IRQs are not enabled.
This CL fixes the above issue.
Bug 1012787
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ia127630e24dbe4c1e418163c2b858efb3baa8e45
Reviewed-on: http://git-master/r/114592
Due to issues with rcu notifiers on secureos, modifying dc flip
notifications to use a simple callback instead.
Bug 1028850
Change-Id: Iebf2a6d64d7316e3df2b88444201f9f9a29698c5
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/123103
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Tegra 3 version: TF_TEGRA3_AB01.15.36932
1)Fix an issue in GIC controller
2)Add a task profiler option into the Trusted Foundations
3)Fixes the RCU stalls
Change-Id: Ib137dc4f155765cb7d7084f1f9a6f75d3bf38116
Signed-off-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Reviewed-on: http://git-master/r/122808
Reviewed-by: James Zhao <jamesz@nvidia.com>
This is necessary to support future tegra SOC's.
Change-Id: I2f6ce328e30a6895dce16d82c4097291339155cd
Reviewed-on: http://git-master/r/123146
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
When 3D register is read, and we need to do a context switch, the old
context reference is incremented, but it never gets decremented. Fix
by using nvhost_job_get_hwctx() to acquire the reference.
Bug 1031746
Change-Id: Ic72637cb2399f960e2297733bfe45e585a8ec180
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/123678
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Align memblock reserve for text area to PMD size.
Reserve the memory hole between DRAM start and Page table start.
Add Sanity check to avoid section split in text area.
Bug 1028787
Change-Id: I586e4ad6e3a94aa0c79b302e51156dbe089e481f
Reviewed-on: http://git-master/r/121883
(cherry picked from commit 65d02640b4b0b38263687c7f3e664c873237dc43)
Reviewed-on: http://git-master/r/123431
Add traces for measuring LP2 entry/exit times.
Bug 960304
Change-Id: I20bb0f8d55a7ed6f7e88e10d924871a3d09f2507
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/123313
Tristate and pull down LCD pins D0-D23, LCD_PWR* and
LCD_CS*_N pins for E1506 DSI panel. Reduced the power
consumption on VDDIO_LCD to 0.37mW for PM269 with E1506
DSI panel.
Bug 1007512
Bug 1015349
Signed-off-by: Prem Sasidharan <psasidharan@nvidia.com>
Change-Id: Ic54d1ca71f5ff92742f70915b7b27104c0a508a6
Reviewed-on: http://git-master/r/123172
Setting default I2S mode as slave. This will help in power
optimization of around 4mW.
Change-Id: Ic2d702c332283bd0f6c4f73615e8097fb3b16ef9
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Reviewed-on: http://git-master/r/122943
The gpio mode is enabled when setting direction and
disabled when freeing gpio and hence this call is no
more required.
Change-Id: Ic40a506a54ee8fe125c0c1f56a8857fb290fcccb
Reviewed-on: http://git-master/r/122938
more required.
Change-Id: I30647b96fa2a120fb323c18e97bc9936a95c305d
Reviewed-on: http://git-master/r/122937
Add support to alloc zeroed pages for user space alloc requests. Also
define a config option to force userspace allocation requests to be
zeroed.
Change-Id: I75d3b2bc36e808f1470b423578ec4cba99e0f967
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: http://git-master/r/122549
armv7 uses cache policy as WRITEALLOC. CPA is
restoring the cache attributes to WRITEBACK during
set_pages_array_wb().
Fixed issues in pmd to pte prot translation and vice versa.
Change-Id: I8406b784f62d559f657ef7bc08e77c83ac6e5690
Reviewed-on: http://git-master/r/122472
adding callback of xmm modem for L3->L0 power sequence.
Bug 1030815
Change-Id: I4997f56819726a55fc8268a1011bc98ff6baf8ca
Signed-off-by: Shawn Joo <sjoo@nvidia.com>
Reviewed-on: http://git-master/r/122960
host1x interrupts have been left on at suspend due to using wrong
constant for the interrupt register. Disable host1x interrupts at
suspend.
Change-Id: I915fc4e663e6ad90fccacff6fb223c5080e21fcd
Reviewed-on: http://git-master/r/123055
Reviewed-by: Andrew Howe <ahowe@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
BUG 1015045
Change-Id: Id9ac783365f08787638edc057d55f29c9a0e46eb
Reviewed-on: http://git-master/r/122310
After the charging completed, TPS80031 can re-enable the charging if it
sense the voltage dropping (120mV below target). Current drive does not
handle this event and causing the charging forever stopped.
This patch will check the above re-charging happens in the charging WDT
handler, and will ack WDT in order to continue charging.
BUG 1015045
Change-Id: Ia0a53d29cd0e73e7ebcd53f8176c8ef81b6c6090
Reviewed-on: http://git-master/r/122309
Perform throughput notifications to clients on work queue rather than
synchronously to dc flip notifications.
Bug 1028850
Change-Id: Ib9446a4ab87a476230a90a1f23c260bcf98e01dc
(cherry picked from commit f48bec5168232d7a50ecfb193146a4be214af3d7)
Reviewed-on: http://git-master/r/#change,122160
Reviewed-on: http://git-master/r/123102
Lock was missing around one state set, so we add it here.
Bug 1024031
Change-Id: Iab013fff7e8519e8bcc91e84a5ca7cd6e6e783da
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/122802
The cpu hotplug drivers should only bother updating state or switching
to the G cluster if the driver is not disabled
Bug 1032096
Change-Id: Ice938b094bbf48fef47afa3915b1a48362fb256d
Signed-off-by: Sai Charan Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-on: http://git-master/r/122859
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
We will report the exact width/height instead of rounding it off for
Android's bucketed dpi values. The determination of the bucketed dpi
values is handled in user mode.
Bug 1003707.
Change-Id: Id3d4b9fc325187067e2d3df895ff6a753b730633
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/121431
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
When tegra-otg suspends with charger cable connected, the charger
state and type should not be changed, neither should the charger
callback be executed.
SMB349 has a debounce delay of ~20ms +/- 3 after cable is unpluged
and will stop all I2C functions for 2.3ms when getting reset to POR.
Add 50ms' delay before reading charger status to avoid I2C error and
make sure we get the right charger state.
Bug 1024735
Change-Id: I1667b23df768b46b524c6578c4bee09e131d9f96
Signed-off-by: Allen Yu <alleny@nvidia.com>
Reviewed-on: http://git-master/r/120905
nvhost context related functions were in init section, even though
they are called from non-init functions.
Bug 1022681
Change-Id: Ie85e9dd3f19873aec4153e34c7bffa19f40d37fa
Reviewed-on: http://git-master/r/120884
Add tracing for clock lock/unlock operations.
Bug 960307
Change-Id: Id5c2d8be25900bc701e5dcd73f87c068ab6e5894
Reviewed-on: http://git-master/r/122666
This change merges two patchsets. The first set,
containing 6 patches, reimplements WQ_HIGHPRI
to use a seperate worker_pool. gcwq->pools[0]
is used for normal priority work and pools[1]
for high priority.
The second patchset contains 9 patches and
reimplements CPU hotplug to keep idle workers.
Updates workqueue CPU hotplug path to use a
disassociated global_cwq, which runs as an
unbound one (WQ_UNBOUND). While this requires
rebinding idle workers, overall hotplug path
is much simpler.
Original patchset:
http://thread.gmane.org/gmane.linux.kernel/1329164
Bug 978010
Change-Id: Ic66ec8848a8d111b5278e63ef6a410846dfd8fcc
Signed-off-by: Mitch Luban <mluban@nvidia.com>
Reviewed-on: http://git-master/r/118387
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
add compilation flag to treat warnings as errors
handle error of variable declaration
bug 949219
Change-Id: Iac05d4d0e4c4cbf39a534b7aee32c0dac57ae49d
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/118027
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Reviewed-by: Manoj Chourasia <mchourasia@nvidia.com>
-add compilation flag to treat warning as error
bug 949219
Change-Id: I3f7f557099b0473883e0b959b65eb8f17ed30978
Reviewed-on: http://git-master/r/118008
- Register HDMI device.
- Panel init also registers HOST1x.
- HDMI is fully functional
- Hotplug detect GPIO, DDC bus works fine.
bug 966833
bug 1018258
Change-Id: Ia04fbfb9b9ddcf81cef241f3cd1187cdc87d159d
Reviewed-on: http://git-master/r/119118
Reviewed-by: Raymond Rees <rrees@nvidia.com>
Tested-by: Dongfang Shi <dshi@nvidia.com>
(cherry picked from commit c62d307b84a034bae31afce67b8755d500170f58)
Reviewed-on: http://git-master/r/119743
more required.
Change-Id: Ib384ec9295184ee6d3b2edcf76b0c99bcd28e25a
Reviewed-on: http://git-master/r/122117
The gpio mode is disabled when freeing gpio and
hence this call is no more required.
Change-Id: I21f0f098a4ed741984c474996ba13d7390617646
Reviewed-on: http://git-master/r/122116
Change-Id: I61469ec85713e3599245c59d2311f869ba03335b
Reviewed-on: http://git-master/r/122115
