Jonathan Layes is hard to find.
from sections that should not have them.
To avoid userspace build failures such as:
.../linux/uio.h:37: error: expected `=', `,', `;', `asm' or `__attribute__' before `iov_length'
.../linux/uio.h:47: error: expected declaration specifiers or `...' before `size_t'
move uio functions inside a __KERNEL__ block.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
CONFIG_SERIAL_ATMEL_CONSOLE=N
When SERIAL_ATMEL_CONSOLE is disabled, ATMEL_CONSOLE_DEVICE is set to
NULL, and trying to access ATMEL_CONSOLE_DEVICE->flags in
atmel_serial_probe makes the compile fail. This fixes the issue by only
accessing it if CONFIG_SERIAL_ATMEL_CONSOLE is defined
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Once a structure goes over PAGE_SIZE*2, we see occasional allocation
failures. Some people have chosen to switch over to things like vmalloc()
that will let them keep array-like access to such a large structures.
But, vmalloc() has plenty of downsides.
Here's an alternative. I think it's what Andrew was suggesting here:
http://lkml.org/lkml/2009/7/2/518
I call it a flexible array. It does all of its work in PAGE_SIZE bits, so
never does an order>0 allocation. The base level has
PAGE_SIZE-2*sizeof(int) bytes of storage for pointers to the second level.
So, with a 32-bit arch, you get about 4MB (4183112 bytes) of total
storage when the objects pack nicely into a page. It is half that on
64-bit because the pointers are twice the size. There's a table detailing
this in the code.
There are kerneldocs for the functions, but here's an
overview:
flex_array_alloc() - dynamically allocate a base structure
flex_array_free() - free the array and all of the
second-level pages
flex_array_free_parts() - free the second-level pages, but
not the base (for static bases)
flex_array_put() - copy into the array at the given index
flex_array_get() - copy out of the array at the given index
flex_array_prealloc() - preallocate the second-level pages
between the given indexes to
guarantee no allocs will occur at
put() time.
We could also potentially just pass the "element_size" into each of the
API functions instead of storing it internally. That would get us one
more base pointer on 32-bit.
I've been testing this by running it in userspace. The header and patch
that I've been using are here, as well as the little script I'm using to
generate the size table which goes in the kerneldocs.
http://sr71.net/~dave/linux/flexarray/
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Since commit 8dfd0374be84793360db7fff2e635d2cd3bbcb21 ("MMC core: limit
minimum initialization frequency to 400kHz") MMC core checks for minimum
frequency, and that causes following messages flood when using eSDHC
controllers:
mmc0: Minimum clock frequency too high for identification mode
The warnings are legitimate, since if we'd use 133 MHz clocks for standard
SDHCI controllers, we'd not able to scale frequency down to 400 kHz.
But eSDHC controllers have a non-standard SD clock management, so we can
divide clock by 256 * 16, not just 256.
This patch introduces get_min_clock() callback for sdhci core and
implements it for sdhci-of driver, and thus fixes the issue.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Matt Fleming <matt@console-pimps.org>
Cc: Ian Molton <ian@mnementh.co.uk>
Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com>
Cc: Pierre Ossman <drzeus@drzeus.cx>
commit d6580a9f15238b87e618310c862231ae3f352d2d ("kexec: sysrq: simplify
sysrq-c handler") changed the behavior of sysrq-c to unconditional
dereference of NULL pointer. So in cases with CONFIG_KEXEC, where
crash_kexec() was directly called from sysrq-c before, now it can be said
that a step of "real oops" was inserted before starting kdump.
However, in contrast to oops via SysRq-c from keyboard which results in
panic due to in_interrupt(), oops via "echo c > /proc/sysrq-trigger" will
not become panic unless panic_on_oops=1. It means that even if dump is
properly configured to be taken on panic, the sysrq-c from proc interface
might not start crashdump while the sysrq-c from keyboard can start
crashdump. This confuses traditional users of kdump, i.e. people who
expect sysrq-c to do common behavior in both of the keyboard and proc
interface.
This patch brings the keyboard and proc interface behavior of sysrq-c in
line, by forcing panic_on_oops=1 before oops in sysrq-c handler.
And some updates in documentation are included, to clarify that there is
no longer dependency with CONFIG_KEXEC, and that now the system can just
crash by sysrq-c if no dump mechanism is configured.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Brayan Arraes <brayan@yack.com.br>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Found with make headers_check
/usr/include/linux/pps.h:52: found __[us]{8,16,32,64} type without #include <linux/types.h>
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Rodolfo Giometti <giometti@linux.it>
This file makes use of various macros defined in files like asm/current.h
or asm-generic/resource.h. All these files can be included via sched.h.
The building of the !MMU ARM kernel (with additional patches) fails
without this change.
The DCCP protocol tries to allocate some large hash tables during
initialisation using the largest size possible. This can be larger than
what the page allocator can provide so it prints a warning. However, the
caller is able to handle the situation so this patch suppresses the
warning.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
When profile= is used, a large buffer is allocated early at boot. This
can be larger than what the page allocator can provide so it prints a
warning. However, the caller is able to handle the situation so this
patch suppresses the warning.
__GFP_NOWARN
The page allocator warns once when an order >= MAX_ORDER is specified.
This is to catch callers of the allocator that are always falling back to
their worst-case when it was not expected. However, there are cases where
the caller is behaving correctly but cannot suppress the warning. This
patch allows the warning to be suppressed by the callers by specifying
__GFP_NOWARN.
Acked-by: David Rientjes <rientjes@google.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
After commit ec64f51545fffbc4cb968f0cea56341a4b07e85a ("cgroup: fix
frequent -EBUSY at rmdir"), cgroup's rmdir (especially against memcg)
doesn't return -EBUSY by temporary ref counts. That commit expects all
refs after pre_destroy() is temporary but...it wasn't. Then, rmdir can
wait permanently. This patch tries to fix that and change followings.
- set CGRP_WAIT_ON_RMDIR flag before pre_destroy().
- clear CGRP_WAIT_ON_RMDIR flag when the subsys finds racy case.
if there are sleeping ones, wakes them up.
- rmdir() sleeps only when CGRP_WAIT_ON_RMDIR flag is set.
Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Reviewed-by: Paul Menage <menage@google.com>
Acked-by: Balbir Sigh <balbir@linux.vnet.ibm.com>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Under certain circumstances msleep(1) within the loop, which waits for the
EEPROM to be finished, might take longer than the timeout. On the next
loop the status register might now return to be ready and therefore the
loop finishes. The following check now tests if a timeout occurred and if
so returns an error although the device reported it was ready.
This fix replaces testing the occurrence of the timeout by testing the
"not ready" bit in the status register.
Signed-off-by: Sebastian Heutling <heutling@who-ing.de>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
The bug was introduced by commit cc31edceee04a7b87f2be48f9489ebb72d264844
("cgroups: convert tasks file to use a seq_file with shared pid array").
We cache a pid array for all threads that are opening the same "tasks"
file, but the pids in the array are always from the namespace of the
last process that opened the file, so all other threads will read pids
from that namespace instead of their own namespaces.
To fix it, we maintain a list of pid arrays, which is keyed by pid_ns.
The list will be of length 1 at most time.
Reported-by: Paul Menage <menage@google.com>
Idea-by: Paul Menage <menage@google.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Reviewed-by: Serge Hallyn <serue@us.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
The generic atomic64_t implementation in lib/ did not export the functions
it defined, which means that modules that use atomic64_t would not link on
platforms (such as 32-bit powerpc). For example, trying to build a kernel
with CONFIG_NET_RDS on such a platform would fail with:
ERROR: "atomic64_read" [net/rds/rds.ko] undefined!
ERROR: "atomic64_set" [net/rds/rds.ko] undefined!
Fix this by exporting the atomic64_t functions to modules. (I export the
entire API even if it's not all currently used by in-tree modules to avoid
having to continue fixing this in dribs and drabs)
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Acked-by: Paul Mackerras <paulus@samba.org>
As reported in Red Hat bz #509671, i_blocks for files on hugetlbfs get
accounting wrong when doing something like:
$ > foo
$ date > foo
date: write error: Invalid argument
$ /usr/bin/stat foo
File: `foo'
Size: 0 Blocks: 18446744073709547520 IO Block: 2097152 regular
This is because hugetlb_unreserve_pages() is unconditionally removing
blocks_per_huge_page(h) on each call rather than using the freed amount.
If there were 0 blocks, it goes negative, resulting in the above.
This is a regression from commit a5516438959d90b071ff0a484ce4f3f523dc3152
("hugetlb: modular state for hugetlb page size")
which did:
- inode->i_blocks -= BLOCKS_PER_HUGEPAGE * freed;
+ inode->i_blocks -= blocks_per_huge_page(h);
so just put back the freed multiplier, and it's all happy again.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Acked-by: Andi Kleen <andi@firstfloor.org>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: <stable@kernel.org>
rtc-cmos has two drivers, one PNP and one platform. When PNP has not
succeeded probing, platform is registered. However, it tries to
unregister both drivers unconditionally, instead of only unregistering
those that were successfully registered. This causes runtime warnings to
be emitted from the driver core code.
Fix this with a boolean variable for each driver indicating whether
registering was successful.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Alessandro Zummo <alessandro.zummo@towertech.it>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Greg KH <greg@kroah.com>
Cc: Ozan Caglayan <ozan@pardus.org.tr>
When data is read through DMA, the last element must be read separately
through the RX register. It cannot be transferred by the DMA. For
further details see e.g. OMAP35x TRM (table 19-16).
Without the fix the driver causes extra clocks to be clocked to the bus
after DMA RX operations. This can cause interesting behaviour with some
devices.
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
Signed-off-by: Eero Nurkkala <ext-eero.nurkkala@nokia.com>
[aaro.koskinen@nokia.com: Simplified the patch while keeping the idea.]
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Currently mcspi wake-ups are not enabled. This might cause cases where
OMAP is not waking up on mcspi events.
Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com>
Fixed off-by-one bug in loop indexes - some elements beyond windows' array
were accessed, which might result in memory access violations when
removing/suspending the device.
Signed-off-by: Pawel Osciak <p.osciak@samsung.com>
Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Cc: Ben Dooks <ben-linux@fluff.org>
Intel X38 MCHBAR is a 64bits register, base from 0x48, so its higher base
is 0x4C.
Signed-off-by: Lu Zhihe <tombowfly@gmail.com>
Signed-off-by: Doug Thompson <dougthompson@xmission.com>
Cc: <stable@kernel.org> [2.6.30.x]
Setting
"crashkernel=512M-2G:64M,2G-:128M"
does not work but it turns to work if it has a trailing-whitespace,
like
"crashkernel=512M-2G:64M,2G-:128M ".
It was because of a bug in the parser, running over the cmdline.
This patch adds a check of the termination.
Reported-by: Jin Dongming <jin.dongming@np.css.fujitsu.com>
Tested-by: Jin Dongming <jin.dongming@np.css.fujitsu.com>
Fix a post-2.6.31 regression which was introduced by
2ff05b2b4eac2e63d345fc731ea151a060247f53 ("oom: move oom_adj value from
task_struct to mm_struct").
After moving the oom_adj value from the task struct to the mm_struct, the
oom_adj value was no longer properly inherited by child processes.
Copying over the oom_adj value at fork time fixes that bug.
[kosaki.motohiro@jp.fujitsu.com: test for current->mm before dereferencing it]
Signed-off-by: Rik van Riel <riel@redhat.com>
Reported-by: Paul Menage <manage@google.com>
If a task is oom killed and still cannot find memory when trying with
no watermarks, it's better to fail the allocation attempt than to loop
endlessly. Direct reclaim has already failed and the oom killer will
be a no-op since current has yet to die, so there is no other
alternative for allocations that are not __GFP_NOFAIL.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Fix a post-2.6.24 performace regression caused by
3dfa5721f12c3d5a441448086bee156887daa961 ("page-allocator: preserve PFN
ordering when __GFP_COLD is set").
Narayanan reports "The regression is around 15%. There is no disk controller
as our setup is based on Samsung OneNAND used as a memory mapped device on a
OMAP2430 based board."
The page allocator tries to preserve contiguous PFN ordering when returning
pages such that repeated callers to the allocator have a strong chance of
getting physically contiguous pages, particularly when external fragmentation
is low. However, of the bulk of the allocations have __GFP_COLD set as they
are due to aio_read() for example, then the PFNs are in reverse PFN order.
This can cause performance degration when used with IO controllers that could
have merged the requests.
This patch attempts to preserve the contiguous ordering of PFNs for users of
__GFP_COLD.
Reported-by: Narayananu Gopalakrishnan <narayanan.g@samsung.com>
Tested-by: Narayanan Gopalakrishnan <narayanan.g@samsung.com>
A 32-bit perl can't handle 64-bit addresses without using the BigInt
package.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Objects passed to kmemleak_seq_next() have an incremented reference
count (hence not freed) but they may point via object_list.next to
other freed objects. To avoid this, the whole start/next/stop sequence
must be protected by rcu_read_lock().
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-radeon-kms' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (35 commits)
drm/radeon: set fb aperture sizes for framebuffer handoff.
drm/ttm: fix highuser vs dma32 confusion.
drm/radeon: Fix size used for benchmarking BO copies.
drm/radeon: Add radeon.test parameter for running BO GPU copy tests.
drm/radeon/kms: allow interruptible waits for objects.
drm/ttm: powerpc: Fix Highmem cache flushing.
x86: Export kmap_atomic_prot() needed for TTM.
drm/ttm: Fix ttm in-kernel copying of pages with non-standard caching attributes.
drm/ttm: Fix an oops and sync object leak.
drm/radeon/kms: vram sizing on certain r100 chips needs workaround.
drm/radeon: Pay more attention to object placement requested by userspace.
drm/radeon: Fall back to evicting BOs with memcpy if necessary.
drm/radeon: Don't unreserve twice on failure to validate.
drm/radeon/kms: fix bandwidth computation on avivo hardware
drm/radeon/kms: add initial colortiling support.
drm/radeon/kms: fix hotspot handling on pre-avivo chips
drm/radeon/kms: enable frac fb divs on rs600/rs690/rs740
drm/radeon/kms: add PLL flag to prefer frequencies <= the target freq
drm/radeon/kms: block RN50 from using 3D engine.
drm/radeon/kms: fix VRAM sizing like DDX does it.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6
* 'zero-length' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6:
Remove zero-length file drivers/char/vr41xx_giu.c
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: accept late unlocking of HPA
libata: Updates and fixes for pata_at91 driver
ata_piix: Add new short cable ID
ata_piix: Add new laptop short cable IDs
ahci: add device IDs for Ibex Peak ahci controllers
libata: remove superfluous NULL pointer checks
libata: add missing NULL pointer check to ata_eh_reset()
pata_pcmcia: add CNF-CDROM-ID
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
driver core: documentation: make it clear that sysfs is optional
driver core: sysdev: do not send KOBJ_ADD uevent if kobject_init_and_add fails
Dynamic debug: fix typo: -/->
driver core: firmware_class:fix memory leak of page pointers array
sysfs: fix hardlink count on device_move
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6:
staging: udlfb: Add vmalloc.h include
staging: remove aten2011 driver
Staging: android: lowmemorykiller.c: fix it for "oom: move oom_adj value from task_struct to mm_struct"
Staging: serqt_usb2: fix memory leak in error case
Staging: serqt_usb2: add missing calls to tty_kref_put()
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (34 commits)
USB: xhci: Stall handling bug fixes.
USB: xhci: Support for 64-byte contexts
USB: xhci: Always align output device contexts to 64 bytes.
USB: xhci: Scratchpad buffer allocation
USB: Fix parsing of SuperSpeed Endpoint Companion descriptor.
USB: xhci: Fail gracefully if there's no SS ep companion descriptor.
USB: xhci: Handle babble errors on transfers.
USB: xhci: Setup HW retries correctly.
USB: xhci: Check if the host controller died in IRQ handler.
USB: xhci: Don't oops if the host doesn't halt.
USB: xhci: Make debugging more verbose.
USB: xhci: Correct Event Handler Busy flag usage.
USB: xhci: Handle short control packets correctly.
USB: xhci: Represent 64-bit addresses with one u64.
USB: xhci: Use GFP_ATOMIC while holding spinlocks.
USB: xhci: Deal with stalled endpoints.
USB: xhci: Set TD size in transfer TRB.
USB: xhci: fix less- and greater than confusion
USB: usbtest: no need for USB_DEVICEFS
USB: musb: fix CONFIGDATA register read issue
We really don't want to mark the pty as a low-latency device, because as
Alan points out, the ->write method can be called from an IRQ (ppp?),
and that means we can't use ->low_latency=1 as we take mutexes in the
low_latency case.
So rather than using low_latency to force the written data to be pushed
to the ldisc handling at 'write()' time, just make the reader side (or
the poll function) do the flush when it checks whether there is data to
be had.
This also fixes the problem with lost data in an emacs compile buffer
(bugzilla 13815), and we can thus revert the low_latency pty hack
(commit 3a54297478e6578f96fd54bf4daa1751130aca86: "pty: quickfix for the
pty ENXIO timing problems").
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
[ Modified to do the tty_flush_to_ldisc() inside input_available_p() so
that it triggers for both read and poll() - Linus]
This will allow efi/vesa to handoff to radeon.
DMA32 and highmem are sort of exclusive.
Noticed by AndrewR on #radeon.
The incorrect size caused benchmark results to be inflated by a factor of 4.
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
If enabled, during initialization BO GTT->VRAM and VRAM->GTT GPU copies are
tested across the whole GTT aperture.
This has helped uncover the benchmark copy size bug and verify the maximum
aperture size supported by the AGP bridge in my PowerBook.
Blocking here isn't something the X server mouse appreciates,
avoid the block and let userspace retry the waits.
libdrm_radeon userspace library is also expecting EBUSY not ERESTART
Temporarily maps highmem pages while flushing to get a valid virtual
address to flush.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
This functionality is needed to kmap_atomic() highmem pages that may
potentially have or are about to set up other mappings with
attributes.
For x86 this affected highmem pages only, since they were always kmapped
cache-coherent, and this is fixed using kmap_atomic_prot().
For other architectures that may not modify the linear kernel map we
resort to vmap() for now, since kmap_atomic_prot() generally uses the
linear kernel map for lowmem pages. This of course comes with a
performance impact and should be optimized when possible.
The code was potentially dereferencig a NULL sync object pointer.
At the same time a sync object reference was potentially leaked.
If an rn50/r100/m6/m7 GPU has < 64MB RAM, i.e. 8/16/32, the
aperture used to calculate the MC_FB_LOCATION needs to be worked
out from the CONFIG_APER_SIZE register, and not the actual vram size.
TTM VRAM size was also being initialised wrong, use actual vram size
to initialise it.
