2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-04ASoC: TWL4030: Capture route runtime DAPM ordering fixPeter Ujfalusi
Fix the ordering problem in DAPM domain, when the user changes between digital and analog sources during active capture (or loopback) scenario. Before this patch, when the user changed from analog source to digital there were a short time, when the codec enabled analog mic bias (2.2 volts) instead of the correct digital mic bias (1.8 volts) to the digital microphones. This behaviour caused by the former implementation of selecting the correct type of bias. This was done at the POST_REG event of the DAPM_MUX_E("TXx Capture Route") widget. By moving the bias type selection as DAPM_SUPPLY and connecting it to the corresponding digimic widget the problematic situation can be avoided. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-03ASoC: wm9081: fix resource reclaim in wm9081_register error pathAxel Lin
This patch fixes the error path in wm9081_register to properly free resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: wm8978: fix a memory leak if a wm8978_register failAxel Lin
There is a memory leak found if wm8978_register() fail. This patch moves the buffer allocate and release at the same level to prevent the memory leak. Signed-off-by: Axel Lin <axel.lin@gmail.com> Reviewed-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: wm8974: fix a memory leak if another WM8974 is registeredAxel Lin
wm8974 is allocated in wm8974_i2c_probe() but is not freed if wm8974_register() return -EINVAL (if another WM8974 is registered). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: wm8961: fix resource reclaim in wm8961_register error pathAxel Lin
This patch fixes the error path in wm8961_register to properly free resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: wm8955: fix resource reclaim in wm8955_register error pathAxel Lin
This patch fixes the error path in wm8955_register to properly free resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: wm8940: fix a memory leak if wm8940_register return errorAxel Lin
This patch adds checking for wm8940_register return value, and does kfree(wm8940) if wm8940_register() fail. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: wm8904: fix resource reclaim in wm8904_register error pathAxel Lin
This patch includes below fixes: 1. wm8904 need to be kfreed in wm8904_register() error path before return. 2. fix the error path for snd_soc_register_codec() fail and snd_soc_register_dai() fail to properly free resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: wm8711: fix a memory leak if another WM8711 is registeredAxel Lin
wm8711 is allocated in either wm8711_spi_probe() or wm8711_i2c_probe() but is not freed if wm8711_register() return -EINVAL(if another ad1836 is registered). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: wm8523: fix resource reclaim in wm8523_register error pathAxel Lin
This patch includes below fixes: 1. If another WM8523 is registered, need to kfree wm8523 before return -EINVAL. 2. If snd_soc_register_codec failed, goto error path to properly free resources. 3. Instead of using mixed in-line and goto style cleanup, use goto style error handling if snd_soc_register_dai failed. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: da7210: fix a memory leak if failed to initialise da7210 audio codecAxel Lin
da7210 should be kfreed if da7210_init() return error. This patch also fixes the error handing in the case of snd_soc_register_dai() fail by adding snd_soc_unregister_codec() in error path. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: ak4642: fix a memory leak if failed to initialise AK4642Axel Lin
ak4642 should be kfreed if ak4642_init() return error. Signed-off-by: Axel Lin <axel.lin@gmail.com> Reviewed-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: ad1836: fix a memory leak if another ad1836 is registeredAxel Lin
ad1836 is allocated in ad1836_spi_probe() but is not freed if ad1836_register() return -EINVAL (if another ad1836 is registered). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Barry Song <21cnbao@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-03ASoC: Initial WM8741 CODEC driverIan Lartey
The WM8741 is a very high performance stereo DAC designed for audio applications such as professional recording systems, A/V receivers and high specification CD, DVD and home theatre systems. The device supports PCM data input word lengths from 16 to 32-bits and sampling rates up to 192kHz. The WM8741 also supports DSD bit-stream data format, in both direct DSD and PCM-converted DSD modes. TODO: Expand wm8741_set_dai_sysclk and rate_constraint members to allow for all supported sample rate / Master Clock frequency combinations. Fully enable control of supplies. Signed-off-by: Ian Lartey <ian@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-02Merge branch 'for-2.6.36' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
2010-08-02ASoC: omap-mcbsp: Remove period size constraint in THRESHOLD modePeter Ujfalusi
The use of sDMA packet mode in THRESHOLD mode removes the restriction on the period size. With the extended THRESHOLD mode user space can ask for any period size it wishes, and the driver will configure the sDMA and McBSP FIFO accordingly. Replace the hw_rule for the period size with static constraint, which will make sure that the period size will be always even (to avoid prime period size, which could be possible in mono stream) Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-02ASoC: omap-mcbsp: Support for sDMA packet modePeter Ujfalusi
Utilize the sDMA controller's packet syncronization mode, when the McBSP FIFO is in use (by extending the THRESHOLD mode). When the sDMA is configured for packet mode, the sDMA frame size does not need to match with the McBSP threshold configuration. Uppon DMA request the sDMA will transfer packet size number of words, and still trigger interrupt on frame boundary. The patch extends the original THRESHOLD mode by doing the following: if (period_words <= max_threshold) Current THRESHOLD mode configuration Otherwise (period_words > max_threshold) McBSP threshold = sDMA packet size sDMA frame size = period size With the extended THRESHOLD mode we can remove the constraint for the maximum period size, since if the period size is bigger than the maximum allowed threshold, than the driver will switch to packet mode, and picks the best (biggest) threshold value, which can divide evenly the period size. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-02ASoC: omap-mcbsp: Code cleanup in omap_mcbsp_dai_hw_paramsPeter Ujfalusi
To make the code a bit more readable, change the indexed references to the omap_mcbsp_dai_dma_params elements with pointer. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-02ASoC: omap-mcbsp: Restructure the code within omap_mcbsp_dai_hw_paramsPeter Ujfalusi
In preparation for the extended threshold mode (sDMA packet mode support), the code need to be restructured. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-29ASoC: fsi: Add new funtion for SPDIFKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-29ASoC: fsi: remove device id checkKuninori Morimoto
Current FSI driver id is not only 0 Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-29ASoC: fsi: remove unnecessary clock processingKuninori Morimoto
2010-07-29ASoC: tlv320dac33: Add support for automatic FIFO configurationPeter Ujfalusi
Platform parameter to enable automatic FIFO configuration when the codec is in Mode1 or Mode7 FIFO mode. When this mode is selected, the controls for changing nSample (in Mode1), and UTHR (in Mode7) are not added. The driver configures the FIFO configuration based on the stream's period size in a way, that every burst will read period size of data from the host. In Mode7 we need to use a formula, which gives close enough aproximation for the burst length from the host point of view. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-29ASoC: tlv320dac33: Revisit the FIFO Mode1 handlingPeter Ujfalusi
Replace the hardwired latency definition with platform data parameter, and simplify the nSample parameter calculation. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-27ASoC: TWL4030: Capture route DAPM event fixPeter Ujfalusi
There is no need to handle POST_PMU, POST_PMD event with the Capture Route widget. It is enough to handle POST_REG event, since that will come when the user changes the routing, and we will switch the needed bits in the registers. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-23ASoC: da7210: Add HeadPhone Playback Volume controlKuninori Morimoto
HeadPhone Playback Volume control register of DA7210 has reserved area. This patch considered it as mute. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-21Merge branch 'for-2.6.36' of ↵Takashi Iwai
2010-07-21ASoC: TWL4030: Add configurable delay after digimic enablePeter Ujfalusi
When digital microphones are connected to twl, delay is needed after enabling the digimic interface of the codec. Add new parameter for the setup data, which can be used to pass the apropriate delay in ms after the digimic interface has been enabled. Without certain delay (in certain HW configuration) the beggining of the recorded sample contains a glitch, which is generated by the digital microphones. Delaying the micbias1, 2 (which is the bias for the digimic0 or 1) does not help, since the glitch is coming after switching the digimic interface. Reversing the micbias and digimic enable order does not work either (in that case the wait need to be added after the micbias enabled). Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-20ASoC: Unconditionally enable WM8994 AIF1ADC TDM modeMark Brown
AIF1ADC TDM mode has no effect other than causing the ADCDAT line to be tristated rather than driven low on clock cycles where there is no data to be transmitted. If the clock cycle is idle then there should be no devices using the data so tristating should have no adverse effects. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-20ASoC: davinci: let platform data define edma queue numbersSekhar Nori
Currently the EDMA queue to be used by for servicing ASP through internal RAM is fixed to EDMAQ_0 and that to service internal RAM from external RAM is fixed to EDMAQ_1. This may not be the desirable configuration on all platforms. For example, on DM365, queue 0 has large fifo size and is more suitable for video transfers. Having audio and video transfers on the same queue may lead to starvation on audio side. platform data as defined currently passes a queue number to the driver but that remains unused inside the driver. Fix this by defining one queue each for ASP and RAM transfers in the platform data and using it inside the driver. Since EDMAQ_0 maps to 0, thats the queue that will be used if the asp queue number is not initialized. None of the platforms currently utilize ping-pong transfers through internal RAM so that functionality remains unchanged too. This patch has been tested on DM644x and OMAP-L138 EVMs. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-20ASoC:Support Samsung SoC(S5P) in I2Sv2Chanwoo Choi
This patch modify I2Sv2 driver to support Samsung SoC(S5PV210). Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-20Merge branch 'for-2.6.35' into for-2.6.36Mark Brown
2010-07-20ASoC: Select wm_hubs automatically for WM8994Chanwoo Choi
Otherwise all machine drivers need to do so. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-20ASoC: Implement WM8994 AIF1ADC2 pathsMark Brown
2010-07-20ASoC: Explicitly disable DC servo on WM hubs headphone powerdownMark Brown
2010-07-20ASoC: eukrea-tlv320: add support for cpuimx35sdEric Bénard
Signed-off-by: Eric Bénard <eric@eukrea.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-17ASoC: imx: check kzalloc() result and fix memory leakKulikov Vasiliy
If kzalloc() fails we must exit with -ENOMEM. Also we must free allocated runtime->private_data on error as it would be lost on next call to snd_imx_open(). Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-17ASoC: davinci: check kzalloc() result (typo)Kulikov Vasiliy
The code checks 'davinci_vc' after kzalloc() and do not checks 'davinci_vcif_dev' that kzalloc() result is assigned to. It seems that it is a typo (autocompletion?). Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-17ASoC: fsi: Add specified ID for soc-audioKuninori Morimoto
Specified ID is necessary, when some codecs are used with FSI. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-17Merge branch 'for-2.6.35' into for-2.6.36Mark Brown
2010-07-17ASoC: Remove duplicate AUX definition from WM8776Mark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Cc: stable@kernel.org
2010-07-17ASoC: TWL6040: Correct widget handling for driversJorge Eduardo Candelaria
In order to reduce pop-noise at powering up/down of the DACs and Drivers, these components have to be handled in a specific sequence. Headset, Handsfree, and Earphone drivers are now registered as PGA components to ensure DACs are enabled first. Also, add a delay to leave time for DACs to settle before continuing power up/down sequence. Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Signed-off-by: Margarita Olaya Cabrera <magi.olaya@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-14ASoC: Handle read failures in codec_regMark Brown
When a device is powered down volatile registers can't be read so attempts to display codec_reg will show error values, and obviously it is also possible for there to be hardware errors too. Check for errors from reads and display them more clearly when formatting codec_reg. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-14Merge branch 'for-2.6.35' into for-2.6.36Mark Brown
2010-07-14ASoC:: remove a redundant snd_soc_unregister_codec call in wm8988_registerAxel Lin
snd_soc_unregister_codec is called twice if snd_soc_register_dai fail. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-14ASoC: wm8727: add a missing return in wm8727_platform_probeAxel Lin
otherwise the error path will always be executed. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-13ASoC: au1x: fix section mismatch in psc-i2s.cManuel Lauss
Annotate platform probe callback with __devinit instead of plain __init. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-13ASoC: kirkwood-i2s: Handle mute/unmute playback/recordarnaud.patard@rtp-net.org
The controller has mute/unmute capability and some bootloader may mute them at boot. If it's not handled, all things will seem to be working but no sound will come out of the speaker/headphone. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
