2006-06-22[ALSA] hda-codec - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
Move EXPORT_SYMBOL() to adjacent to each exported function/variable. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] i2c - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] vx - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] emux - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] trident - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] emu10k1 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] opl4 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] opl3 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] ac97 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
2006-06-22[ALSA] Clean up EXPORT_SYMBOL()s in snd-seq moduleTakashi Iwai
Move EXPORT_SYMBOL()s to places adjacent to functions/variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Clean up EXPORT_SYMBOL()s in snd moduleTakashi Iwai
2006-06-22[ALSA] Clean up ugly hacks in pcm_params.hTakashi Iwai
Clean up ugly hacks for sync with alsa-lib in pcm_params.h. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] PM support for cs5535audioJaya Kumar
Appended is my patch adding PM support to the cs5535audio driver. I also added the ac97 quirk but it's not yet confirmed which boards need to be in the quirk list. The patch also includes some Kconfig and misc cleanup. Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Add support for Sony Vaio VGN-A790 laptopKenneth Crudup
Added the model entry for Sony Vaio VGN-A790 laptop with ALC260 codec. From: Kenneth Crudup <kenny@panix.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] ice1712 - Provides specified midi port names instead of defaultsAlan Horstmann
Patch provides for the ice1712 card driver to overwrite the midi port name string given by default in mpu401_uart, with one specified in snd_ice1712_card_info. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Change seq_midi.c so client name is card, rather than port, specificAlan Horstmann
Change snd_seq_midisynth_register_port() in seq_midi.c so that if a new client is created, the client name string is based on card->shortname not (port-specific) info->name. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] hda-codec - Fix a typoTakashi Iwai
Fixed a typo of 'pci_subsystem' in the last changeset. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] hda-codec - Add Thinkpad X60/T60/Z60 supportTakashi Iwai
Added the support for Thinkpad X60/T60/Z60 laptops with AD1981HD codec. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
This second one unregisters the platform device again when the probe is unsuccesful for sound/drivers, sound/arm/sa11xx-uda1341.c and sound/ppc/powermac.c. This gets them all. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] vxpocket - Fix a typoTakashi Iwai
Fix a typo of return value from vxpocket_config(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] AC97: Correct Mic Boost label.James Courtier-Dutton
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2006-06-22[ALSA] ca0106: Fixes MSI K8N's SB Live 24 bit, no sound from line-in.James Courtier-Dutton
Fixed bug#1331 Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2006-06-22[ALSA] Add p17v.h file.James Courtier-Dutton
2006-06-22[ALSA] emu10k1: Add support for Audigy4 (not Pro)James Courtier-Dutton
2006-06-22[ALSA] ca0106: Add analog capture controls.James Courtier-Dutton
2006-06-21Merge git://oss.sgi.com:8090/xfs-2.6Linus Torvalds
* git://oss.sgi.com:8090/xfs-2.6: (43 commits) [XFS] Remove files from the build that are now unused. [XFS] Fix a Makefile issue related to exports.o handling. [XFS] Remove version 1 directory code. Never functioned on Linux, just [XFS] Map EFSCORRUPTED to an actual error code, not just a made up one [XFS] Kill direct access to ->count in valusema(); all we ever use it for [XFS] Remove unneeded conditional code on NFS export interface related [XFS] Remove an incorrect use of unlikely() on a relatively likely code [XFS] Push some common code out of write path into core XFS code for [XFS] Remove unnecessary local from open_exec dmapi path. [XFS] Minor XFS documentation updates. [XFS] Fix broken const use inside local suffix_strtoul routine. [XFS] Fix nused counter. It's currently getting set to -1 rather than [XFS] Fix mismerge of the fs_writable cleanup patch causing a freeze/thaw [XFS] Fix up debug code so that bulkstat wont generate thousands of [XFS] Remove unused parameter from di2xflags routine. [XFS] Cleanup a missed porting conversion, and freezing. [XFS] Resolve a namespace collision on remaining vtypes for FreeBSD [XFS] Resolve a namespace collision on vnode/vnodeops for FreeBSD porters. [XFS] Resolve a namespace collision on vfs/vfsops for FreeBSD porters. [XFS] statvfs component of directory/project quota support, code ...
2006-06-21[PATCH] USB: only make /sys/class/usb show up when there is something in itGreg Kroah-Hartman
Now /sys/class/usb is dynamically created when we have something to put in it, and removed when all devices go away. Just trying to cut down on the clutter in sysfs... Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: convert usb class devices to real devicesGreg Kroah-Hartman
2006-06-21[PATCH] USB: move usb_device_class class devices to be real devicesGreg Kroah-Hartman
This moves the usb class devices that control the usbfs nodes to show up in the proper place in the larger device tree. No userspace changes is needed, this is compatible due to the symlinks generated by the driver core. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: make endpoints real struct devicesGreg Kroah-Hartman
This will allow for us to give endpoints a major/minor to create a "usbfs2-like" way to access endpoints directly from userspace in an easier manner than the current usbfs provides us. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: make usb_create_ep_files take a struct deviceGreg Kroah-Hartman
Instead of a kobject, will make things easier in the future (don't know what I was thinking when I did this originally...) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: move the endpoint specific sysfs code to it's own fileGreg Kroah-Hartman
This makes it easier to modify in the future without touching anything else. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: move <linux/usb_input.h> to <linux/usb/input.h>David Brownell
Move <linux/usb_input.h> to <linux/usb/input.h> and remove some redundant includes. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: move hardware-specific <linux/usb_*.h> to <linux/usb/*.h>David Brownell
This moves header files for controller-specific platform data from <linux/usb_XXX.h> to <linux/usb/XXX.h> to start reducing some clutter. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: move <linux/usb_cdc.h> to <linux/usb/cdc.h>David Brownell
This moves <linux/usb_cdc.h> to <linux/usb/cdc.h> to reduce some of the clutter of usb header files. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: whitespace removal from usb/gadget/etherDavid Brownell
This removes extraneous whitespace from the Ethernet/RNDIS gadget driver. It's all space-at-EOL, spaces-before-tabs, or tabs-then-spaces. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: unusual_devs entry for Nokia N80Alan Stern
Here is a patch (as720) adding an unusual_devs entry for the Nokia N80 mobile phone. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] usbserial: Fixes wrong return values.Luiz Fernando N. Capitulino
Some usbserial functions returns -EINVAL if the port doesn't exist or if it's not opened. However, the right error code for such situations is -ENODEV. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] usb gadget: update pxa2xx_udc.c driver to fully support IXP4xx platformMilan Svoboda
This patch adds IXP465 into the list of known devices and adds IXP425 and IXP465 to the list of devices that have cfr. This is not described in the hardware documentation, but without it driver won't work. Workaround (#if 1) that seemed to get rid of lost status irqs is disabled for IXP4XX as it caused freezes during testing of control messages. No lost irqs are visible on IXP4XX. Driver survived tests running over night without any visible problems. Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] usb gadget: fix compile errorsMilan Svoboda
This patch fixes compile errors when pxa2xx_udc is to be compiled for ixp4xx platform. Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] usb gadget: allow drivers support speeds higher than full speedMilan Svoboda
This patch removes limitation which prevents use of drivers that support speeds different that full speed. Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: gadget-serial: do not save/restore IRQ flags in gs_close()Franck Bui-Huu
As pointed out by David Brownell, we know that IRQs are never blocked when calling gs_close function. So the save/restore IRQ flags are pointless. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: gadget-serial: fix a deadlock when closing the serial deviceFranck Bui-Huu
When closing the device, the driver acquires/release twice the port lock before/after waiting for the data to be completely sent. Therefore it will dead lock. This patch fixes it and also uses the generic scheduler services for waiting for an event. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB Serial: clean tty fields on failed device openFrank Gevaerts
If either the driver's open() method or try_module_get() fails, we need to set 'tty->driver_data' and 'port->tty' to NULL in serial_open(), otherwise we'll get an OOPS in usb_device_disconnect() when the device is disconnected. Signed-off-by: Frank Gevaerts <frank.gevaerts@fks.be> Acked-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: trivial DEBUG message correction in gadget ether driverMatt Reimer
Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: new driver for Cypress CY7C63xxx mirco controllersOliver Bock
This is a new driver for the Cypress CY7C63xxx mirco controller series. It currently supports the pre-programmed CYC63001A-PC by AK Modul-Bus GmbH. It's based on a kernel 2.4 driver (cyport) by Marcus Maul which I ported to kernel 2.6 using sysfs. I intend to support more controllers of this family (and more features) as soon as I get hold of the required IDs etc. Please see the source code's header for more information. Signed-off-by: Oliver Bock <o.bock@fh-wolfenbuettel.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: update usbmon.txtPete Zaitcev
Fix up the documentation. Apparently, I left unedited copy-paste results in examples. Also, Alan helped me to improve the most confusing parts. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: implement error event in usbmonPete Zaitcev
Implement the "error" event in usbmon. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: update usbmon, fix glued linesPete Zaitcev
This update contains one bug fix: some lines can come out truncated, because of the safety cutoff. This happened because I forgot to update the size when status packets began to be printed. The rest is: - Comments updates - Allow snooping with pkmap on x86_64, which is cache-coherent - Enlarge event buffers (certainly we can have a couple of pages) - Add event counter First touch upon usbmon for 2.6.18. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: io_edgeport touch-upPete Zaitcev
Al Borchers suggested to do this in his review of my previous patch. I guess that I skipped this initially because of my visceral dislike of sizeof(data). But in this case it seems well localized. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
