"uinfo->value.enumerated.item" is an unsigned int. If it's negative
when we do the comparison:
if ((int)uinfo->value.enumerated.item >= cval->max)
then we would read past the end of the array on the next line.
I also changed the strcpy() to strlcpy() out of paranoia.
When user want to change the card id to the same string
on the card via /sys/class/sound/cardX/id, do not
report error. Instead return with success without
doing anything.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Used only when CONFIG_SND_DEBUG=y
sound/usb/mixer.c: In function 'get_min_max':
sound/usb/mixer.c:762: warning: unused variable 'chip'
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Obvious copy-and-paste error.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
The usage of the BKL in the OSS sound drivers is
trivial, and each of them only locks against itself,
so it can be turned into per-driver mutexes.
This is the script that was used for the conversion:
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
Modifying an object twice without an intervening sequence point is
undefined.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Reported-by: Carmen Cru <carmen.cru@belgacom.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Geoff Levand <geoff@infradead.org>
Fix docbook templates that reference files that do not contain the
expected kernel-doc notation.
Fixes these warnings:
Warning(arch/x86/include/asm/unaligned.h): no structured comments found
Warning(lib/vsprintf.c): no structured comments found
These cause errors in the generated html output, like below, so drop
these lines.
Name
arch/x86/include/asm/unaligned.h - Document generation inconsistency
Oops
Warning
The template for this document tried to insert the structured comment from the file arch/x86/include/asm/unaligned.h at this point, but none was found. This dummy section is inserted to allow generation to continue.
When you don't use !E or !I but only !F, then it's very easy to miss
including some functions, structs etc. in documentation. To help
finding which ones were missed, allow printing out the unused ones as
warnings.
For example, using this on mac80211 yields a lot of warnings like this:
Warning: didn't use docs for DOC: mac80211 workqueue
Warning: didn't use docs for ieee80211_max_queues
Warning: didn't use docs for ieee80211_bss_change
Warning: didn't use docs for ieee80211_bss_conf
when generating the documentation for it.
There are valid attributes that could have upper case letters, but we
still want to remove, like for example
__attribute__((aligned(NETDEV_ALIGN)))
as encountered in the wireless code.
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / Hibernate: Avoid hitting OOM during preallocation of memory
PM QoS: Correct pr_debug() misuse and improve parameter checks
PM: Prevent waiting forever on asynchronous resume after failing suspend
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] fix use-after-free in scsi_init_io()
[SCSI] sd: fix medium-removal bug
[SCSI] qla2xxx: Update version number to 8.03.04-k0.
[SCSI] qla2xxx: Check for empty slot in request queue before posting Command type 6 request.
[SCSI] qla2xxx: Cover UNDERRUN case where SCSI status is set.
[SCSI] qla2xxx: Correctly set fw hung and complete only waiting mbx.
[SCSI] qla2xxx: Reset seconds_since_last_heartbeat correctly.
[SCSI] qla2xxx: make rport deletions explicit during vport removal
[SCSI] qla2xxx: Fix vport delete issues
[SCSI] sd, sym53c8xx: Remove warnings after vsprintf %pV introducation.
[SCSI] Fix warning: zero-length gnu_printf format string
[SCSI] hpsa: disable doorbell reset on reset_devices
[SCSI] be2iscsi: Fix for Login failure
[SCSI] fix bio.bi_rw handling
There is a problem in hibernate_preallocate_memory() that it calls
preallocate_image_memory() with an argument that may be greater than
the total number of available non-highmem memory pages. If that's
the case, the OOM condition is guaranteed to trigger, which in turn
can cause significant slowdown to occur during hibernation.
To avoid that, make preallocate_image_memory() adjust its argument
before calling preallocate_image_pages(), so that the total number of
saveable non-highem pages left is not less than the minimum size of
a hibernation image. Change hibernate_preallocate_memory() to try to
allocate from highmem if the number of pages allocated by
preallocate_image_memory() is too low.
Modify free_unnecessary_pages() to take all possible memory
allocation patterns into account.
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Tested-by: M. Vefa Bicakci <bicave@superonline.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (28 commits)
ipheth: remove incorrect devtype to WWAN
MAINTAINERS: Add CAIF
sctp: fix test for end of loop
KS8851: Correct RX packet allocation
udp: add rehash on connect()
net: blackhole route should always be recalculated
ipv4: Suppress lockdep-RCU false positive in FIB trie (3)
niu: Fix kernel buffer overflow for ETHTOOL_GRXCLSRLALL
ipvs: fix active FTP
gro: Re-fix different skb headrooms
via-velocity: Turn scatter-gather support back off.
ipv4: Fix reverse path filtering with multipath routing.
UNIX: Do not loop forever at unix_autobind().
PATCH: b44 Handle RX FIFO overflow better (simplified)
irda: off by one
3c59x: Fix deadlock in vortex_error()
netfilter: discard overlapping IPv6 fragment
ipv6: discard overlapping fragment
net: fix tx queue selection for bridged devices implementing select_queue
bonding: Fix jiffies overflow problems (again)
Fix up trivial conflicts due to the same cgroup API thinko fix going
through both Andrew and the networking tree. However, there were small
differences between the two, with Andrew's version generally being the
nicer one, and the one I merged first. So pick that one.
Conflicts in: include/linux/cgroup.h and kernel/cgroup.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc: Kill all BKL usage.
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, tsc: Fix a preemption leak in restore_sched_clock_state()
sched: Move sched_avg_update() to update_cpu_load()
Doh, a real life genuine preemption leak..
This caused a suspend failure.
Reported-bisected-and-tested-by-the-invaluable: Jeff Chua <jeff.chua.linux@gmail.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Nico Schottelius <nico-linux-20100709@schottelius.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Florian Pritz <flo@xssn.at>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: <stable@kernel.org> # Greg, please apply after: cd7240c ("x86, tsc, sched: Recompute cyc2ns_offset's during resume from")
sleep states
LKML-Reference: <1284150773.402.122.camel@laptop>
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel
* 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel:
drm/i915: don't enable self-refresh on Ironlake
drm/i915: Double check that the wait_request is not pending before warning
Revert "drm/i915: Warn if we run out of FIFO space for a mode"
Revert "drm/i915: Allow LVDS on pipe A on gen4+"
Revert "drm/i915: Enable RC6 on Ironlake."
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: log IO completion workqueue is a high priority queue
xfs: prevent reading uninitialized stack memory
A real life genuine preemption leak..
Reported-and-tested-by: Jeff Chua <jeff.chua.linux@gmail.com>
Correct some pr_debug() misuse and add a stronger parameter check to
pm_qos_write() for the ASCII hex value case. Thanks to Dan Carpenter
for pointing out the problem!
Signed-off-by: mark gross <markgross@thegnar.org>
The workqueue implementation in 2.6.36-rcX has changed, resulting
in the workqueues no longer having dedicated threads for work
processing. This has caused severe livelocks under heavy parallel
create workloads because the log IO completions have been getting
held up behind metadata IO completions. Hence log commits would
stall, memory allocation would stall because pages could not be
cleaned, and lock contention on the AIL during inode IO completion
processing was being seen to slow everything down even further.
By making the log Io completion workqueue a high priority workqueue,
they are queued ahead of all data/metadata IO completions and
processed before the data/metadata completions. Hence the log never
gets stalled, and operations needed to clean memory can continue as
quickly as possible. This avoids the livelock conditions and allos
the system to keep running under heavy load as per normal.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
An execve with a very large total of argument/environment strings
can take a really long time in the execve system call. It runs
uninterruptibly to count and copy all the strings. This change
makes it abort the exec quickly if sent a SIGKILL.
Note that this is the conservative change, to interrupt only for
SIGKILL, by using fatal_signal_pending(). It would be perfectly
correct semantics to let any signal interrupt the string-copying in
execve, i.e. use signal_pending() instead of fatal_signal_pending().
We'll save that change for later, since it could have user-visible
consequences, such as having a timer set too quickly make it so that
an execve can never complete, though it always happened to work before.
Signed-off-by: Roland McGrath <roland@redhat.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
This adds a preemption point during the copying of the argument and
environment strings for execve, in copy_strings(). There is already
a preemption point in the count() loop, so this doesn't add any new
points in the abstract sense.
When the total argument+environment strings are very large, the time
spent copying them can be much more than a normal user time slice.
So this change improves the interactivity of the rest of the system
when one process is doing an execve with very large arguments.
The CONFIG_STACK_GROWSDOWN variant of setup_arg_pages() does not
check the size of the argument/environment area on the stack.
When it is unworkably large, shift_arg_pages() hits its BUG_ON.
This is exploitable with a very large RLIMIT_STACK limit, to
create a crash pretty easily.
Check that the initial stack is not too large to make it possible
to map in any executable. We're not checking that the actual
executable (or intepreter, for binfmt_elf) will fit. So those
mappings might clobber part of the initial stack mapping. But
that is just userland lossage that userland made happen, not a
kernel problem.
* 'kvm-updates/2.6.36' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: Perform hardware_enable in CPU_STARTING callback
KVM: i8259: fix migration
KVM: fix i8259 oops when no vcpus are online
KVM: x86 emulator: fix regression with cmpxchg8b on i386 hosts
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: t_start: reset FTRACE_ITER_HASH in case of seek/pread
perf symbols: Fix multiple initialization of symbol system
perf: Fix CPU hotplug
perf, trace: Fix module leak
tracing/kprobe: Fix handling of C-unlike argument names
tracing/kprobes: Fix handling of argument names
perf probe: Fix handling of arguments names
perf probe: Fix return probe support
tracing/kprobe: Fix a memory leak in error case
tracing: Do not allow llseek to set_ftrace_filter
Fix a bug in keyctl_session_to_parent() whereby it tries to check the ownership
of the parent process's session keyring whether or not the parent has a session
keyring [CVE-2010-2960].
This results in the following oops:
BUG: unable to handle kernel NULL pointer dereference at 00000000000000a0
IP: [<ffffffff811ae4dd>] keyctl_session_to_parent+0x251/0x443
Call Trace:
[<ffffffff811ae2f3>] ? keyctl_session_to_parent+0x67/0x443
[<ffffffff8109d286>] ? __do_fault+0x24b/0x3d0
[<ffffffff811af98c>] sys_keyctl+0xb4/0xb8
[<ffffffff81001eab>] system_call_fastpath+0x16/0x1b
if the parent process has no session keyring.
If the system is using pam_keyinit then it mostly protected against this as all
processes derived from a login will have inherited the session keyring created
by pam_keyinit during the log in procedure.
To test this, pam_keyinit calls need to be commented out in /etc/pam.d/.
Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com>
Acked-by: Tavis Ormandy <taviso@cmpxchg8b.com>
There's an protected access to the parent process's credentials in the middle
of keyctl_session_to_parent(). This results in the following RCU warning:
[ INFO: suspicious rcu_dereference_check() usage. ]
security/keys/keyctl.c:1291 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by keyctl-session-/2137:
#0: (tasklist_lock){.+.+..}, at: [<ffffffff811ae2ec>] keyctl_session_to_parent+0x60/0x236
stack backtrace:
Pid: 2137, comm: keyctl-session- Not tainted 2.6.36-rc2-cachefs+ #1
Call Trace:
[<ffffffff8105606a>] lockdep_rcu_dereference+0xaa/0xb3
[<ffffffff811ae379>] keyctl_session_to_parent+0xed/0x236
[<ffffffff811af77e>] sys_keyctl+0xb4/0xb6
The code should take the RCU read lock to make sure the parents credentials
don't go away, even though it's holding a spinlock and has IRQ disabled.
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: Range check cpu in blk_cpu_to_group
scatterlist: prevent invalid free when alloc fails
writeback: Fix lost wake-up shutting down writeback thread
writeback: do not lose wakeup events when forking bdi threads
cciss: fix reporting of max queue depth since init
block: switch s390 tape_block and mg_disk to elevator_change()
block: add function call to switch the IO scheduler from a driver
fs/bio-integrity.c: return -ENOMEM on kmalloc failure
bio-integrity.c: remove dependency on __GFP_NOFAIL
BLOCK: fix bio.bi_rw handling
block: put dev->kobj in blk_register_queue fail path
cciss: handle allocation failure
cfq-iosched: Documentation help for new tunables
cfq-iosched: blktrace print per slice sector stats
cfq-iosched: Implement tunable group_idle
cfq-iosched: Do group share accounting in IOPS when slice_idle=0
cfq-iosched: Do not idle if slice_idle=0
cciss: disable doorbell reset on reset_devices
blkio: Fix return code for mkdir calls
* 'at91-fixes-for-linus' of git://github.com/at91linux/linux-2.6-at91:
AT91: at91sam9261ek: remove C99 comments but keep information
AT91: at91sam9261ek board: remove warnings related to use of SPI or SD/MMC
AT91: dm9000 initialization update
AT91: SAM9G45 - add a separate clock entry for every single TC block
AT91: clock: peripheral clocks can have other parent than mck
AT91: change dma resource index
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: rawmidi: fix the get next midi device ioctl
ALSA: hda - Fix wrong HP pin detection in snd_hda_parse_pin_def_config()
ALSA: seq/oss - Fix double-free at error path of snd_seq_oss_open()
ALSA: msnd-classic: Fix invalid cfg parameter
ALSA: hda - Enable PC-beep for EeePC with ALC269 codec
ALSA: hda - Add errata initverb sequence for CS42xx codecs
ALSA: usb - Release capture substream URBs properly
ALSA: virtuoso: fix setting of Xonar DS line-in/mic-in controls
ALSA: virtuoso: work around missing reset in the Xonar DS Windows driver
ALSA: hda - Add quirk for Lenovo T400s
ALSA: usb-audio: fix detection of vendor-specific device protocol settings
ALSA: usb-audio: Assume first control interface is for audio
ALSA: hda - Add a new hp-laptop model for Conexant 5066, tested on HP G60
We don't know how to enable it safely, especially as outputs turn on and
off. When disabling LP1 we also need to make sure LP2 and 3 are already
disabled.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29173
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29082
Reported-by: Chris Lord <chris@linux.intel.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Tested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: stable@kernel.org
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
The XFS_IOC_FSGETXATTR ioctl allows unprivileged users to read 12
bytes of uninitialized stack memory, because the fsxattr struct
declared on the stack in xfs_ioc_fsgetxattr() does not alter (or zero)
the 12-byte fsx_pad member before copying it back to the user. This
patch takes care of it.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The sd/mmc data structure is not used if SPI is selected. The configuration
of PIO on the board prevent from using both interfaces at the same time
(board dependent).
Remove the warnings at compilation time adding a preprocessor condition.
Add information in dm9000 mac/phy chip initialization:
- irq resource details
- platform data details
This patch adds support for the new Traktor Kontrol S4 by Native
Instruments. It features a new audio data streaming model, MIDI
in and out ports, a huge number of 174 dimmable LEDs, 96 buttons
and 46 absolute encoder axis, including some rotary encoders.
All features are supported by the driver now.
Did some code refactoring along the way.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Let git do the job.
While testing CPU DLPAR, the following problem was discovered.
We were DLPAR removing the first CPU, which in this case was
logical CPUs 0-3. CPUs 0-2 were already marked offline and
we were in the process of offlining CPU 3. After marking
the CPU inactive and offline in cpu_disable, but before the
cpu was completely idle (cpu_die), we ended up in __make_request
on CPU 3. There we looked at the topology map to see which CPU
to complete the I/O on and found no CPUs in the cpu_sibling_map.
This resulted in the block layer setting the completion cpu
to be NR_CPUS, which then caused an oops when we tried to
complete the I/O.
Fix this by sanity checking the value we return from blk_cpu_to_group
to be a valid cpu value.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/urgent
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
The 'wwan' devtype is meant for devices that require preconfiguration
and *every* time setup before the ethernet interface can be used, like
cellular modems which require a series of setup commands on serial ports
or other mechanisms before the ethernet interface will handle packets.
As ipheth only requires one-per-hotplug pairing setup with no
preconfiguration (like APN, phone #, etc) and the network interface is
usable at any time after that initial setup, remove the incorrect
devtype wwan.
Signed-off-by: Dan Williams <dcbw@redhat.com>
