2010-07-27[Arm] whistler: Disable config "TEGRA_BATTERY_ODM"tegra-10.7.2Venkat Moganty
Disabling the battery config variable in the def-config file. Enabling the battery driver causing the kernel boot failure. Bug 715080 Change-Id: I729ac5cb30c1eb861ffaa8fb5f38926131aee7cb Reviewed-on: http://git-master/r/4448 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2010-07-27[Arm] whistler: Disable config "TEGRA_BATTERY_ODM"Venkat Moganty
Disabling the battery config variable in the def-config file. Enabling battery driver causing the kernel boot failure. Bug 715080 Change-Id: I479bb8b9611af67737a3f86d6a10bc5824c55ec4 Reviewed-on: http://git-master/r/4449 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2010-07-26[ventana/battery] enable battery chargingSuresh Mangipudi
defconfig change to enable battery changes for ventana Change-Id: Ib4da3a7328c89b86a5557cb9255360dd7fa3df56 Reviewed-on: http://git-master/r/4362 Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com> Tested-by: Suresh Mangipudi <smangipudi@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-26[accelerometer]:Support on VentanaSuresh Mangipudi
removed the BoardID based identification, now use only Peripheral GUID for determining if the board supports accelerometer or not Change-Id: I95938ff4836cbb0bb8547e2d9684dfb534816bfc Reviewed-on: http://git-master/r/4031 Tested-by: Suresh Mangipudi <smangipudi@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-26[ventana]Battery charging.Suresh Mangipudi
The GPIO port R pin 6 needs to be set low for charging of battery on ventana rev C Change-Id: I2ac17494f65f550d5bf676ae8ec09819983b72ac Reviewed-on: http://git-master/r/4171 Tested-by: Suresh Mangipudi <smangipudi@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-26[arm/tegra]spi: Fifo should be empty before starting transfer.Laxman Dewangan
It is recommended by ASIC to make sure that fifos are empty before starting any new transfer specially dma based transfer. Adding support code for this. Change-Id: Ic6b5db650b50e664b5cdd601eed9e0c3286a764b Reviewed-on: http://git-master/r/4211 Reviewed-by: Michael Hsu <mhsu@nvidia.com> Tested-by: Michael Hsu <mhsu@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-26[ARM] tegra: suspend: add work-around for AP20 A03 LP0 restorekrishna kishore
SDRAM initialization is broken in the boot ROM on AP20 A03, so LP0 restore needs to reload the first-stage bootloader and then jump to its LP0 restore sequence. to trigger this behavior, the lp0 flag is moved to a dummy location in the scratch register which the boot ROM ignores, but the bootloader will detect. Change-Id: Iea144e7440367938755ab66d67758558bc184b44 Reviewed-on: http://git-master/r/4022 Reviewed-by: Gary King <gking@nvidia.com> Tested-by: Gary King <gking@nvidia.com>
2010-07-26[ARM/tegra] power: Rescaled power timers (Part 2).Alex Frid
Fixed timer "fix" in commit c0fd286380b8b5276c7aed6fb7a9f5eacde9f60e. Removed from the LP0 entry path call to set_power_timers(), that could overwrite 32kHz-scaled timer values. This did not happen (and original "fix" worked in testing) because set_power_timers() does nothing when there is no change in APB frequency since last call, i.e., since last LP2 before LP0. Change-Id: Ida84319f26eff06d4d94f11c717fe667082bb54f Reviewed-on: http://git-master/r/4376 Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-26[arm/tegra]DMA : Delayed ISR recovery routine.Victor(Weiguo) Pan
Sometimes, due to high interrupt latency in the continuous mode of DMA transfer, the half buffer complete interrupt is handled after DMA transferred the full buffer. In this case, SW DMA state and HW DMA state is out of sync. When out of sync detected, stopping DMA immediately and restarting the DMA with next buffer if next buffer is ready. bug 696953 Change-Id: Ic4b7cb251e472a309e9583eedbd26ea5dfcfceb1 Reviewed-on: http://git-master/r/4351 Tested-by: Victor (Weiguo) Pan <wpan@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com> Reviewed-by: Venkata (Muni) Anda <vanda@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23[ARM] Fix race condition in kmap_high_l1_viptAndrew Howe
smp_processor_id() must not be called from a preemptible context (this is checked by CONFIG_DEBUG_PREEMPT). kmap_high_l1_vipt() was doing so. This lead to a problem where the wrong per_cpu kmap_high_l1_vipt_depth could be incremented, causing a BUG_ON(*depth <= 0); in kunmap_high_l1_vipt(). The solution is to move the call to smp_processor_id() after the call to preempt_disable(). Change-Id: I205a85ebecaedb430860462012d0571b83f08adc Reviewed-on: http://git-master/r/4342 Reviewed-by: Janne Hellsten <jhellsten@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com> Tested-by: Gary King <gking@nvidia.com>
2010-07-23tegra: Save CP14 registers as part of CPU suspend contextScott Williams
The CP14 (debug interface) registers were not being saved as part of the CPU suspend context. This can cause attached JTAG debuggers to lose their mind after CPU hotplug or suspend. Change-Id: Ia9cfd8a711160fd1f0852c33e3fb72f15298de85 Reviewed-on: http://git-master/r/4281 Reviewed-by: Scott Williams <scwilliams@nvidia.com> Tested-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23odmquery:remove extra check of sdio3 is_removablePavan Kunapuli
In odm query, returning the is_removable prop of sdio3 from the static array. The redundant check is removed. This is causing locking issues between kernel and nvrm. Bug 711837 Change-Id: I9d49a0f65ebb1de79d091badb0f316798c63c1cf Reviewed-on: http://git-master/r/4340 Reviewed-by: Ramachandrudu Kandhala <rkandhala@nvidia.com> Tested-by: Ramachandrudu Kandhala <rkandhala@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23[arm/tegra] spi: Use native dma for data transferLaxman Dewangan
The rm spi driver is using the nvrm dma driver which is wrapper over the native dma. Using directly the native dma driver to get rid of one more level of wrapper call from spi driver. Making sure that prev dma operation is completed before starting new transfer. Removed the code which was specific to OAL as this is not required any more. Calling the write buffer barriers after writing into the write dma buffer and before starting the transmit dma to make sure that all written data is available in physical memory before dma start. Change-Id: Iabcd86f0d63b2decffda0ad6da6f1b22161e9d3b Reviewed-on: http://git-master/r/2670 Reviewed-by: Michael Hsu <mhsu@nvidia.com> Tested-by: Michael Hsu <mhsu@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23[tegra-udc] Fix remove mutex call from spin_locks.Venkat Moganty
Regulator current limit uses mutex, which is called from the irq after acquiring the spin locks. Similarly when vbus is detected phy clock enable is called, which uses mutex inside the spin locks. This is fixed by calling these apis under work when called from interrupt context. Bug 711837 Change-Id: Ib926ad33d3d3674353447b3d94ff63f9eecf6f65 Reviewed-on: http://git-master/r/4339 Tested-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com> Reviewed-by: Ramachandrudu Kandhala <rkandhala@nvidia.com> Tested-by: Ramachandrudu Kandhala <rkandhala@nvidia.com> Reviewed-by: Frank Cheng <fcheng@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23tegra spi: added support for various spi signal modesSheshu Shenoy
with out this change, we would only support signal mode 0... Change-Id: I2cd2c9a3e30da94f2e95a654f3154fd33e940f13 Reviewed-on: http://git-master/r/4286 Reviewed-by: Udaykumar Rameshchan Raval <uraval@nvidia.com> Reviewed-by: Sheshagiri Shenoy <sshenoy@nvidia.com> Tested-by: Sheshagiri Shenoy <sshenoy@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23[ARM/tegra] power: Rescaled power timers on LP0 entry.Alex Frid
Rescaled CPU power timers to 32kHz clock on entry to LP0 (before these timers were rescaled only on entry to LP1, but power off timer does affect LPO as well). Change-Id: Ifb316170a1225767f3e9b9033b5f5cb0999504d4 Reviewed-on: http://git-master/r/4349 Reviewed-by: Bitan Biswas <bbiswas@nvidia.com> Tested-by: Bitan Biswas <bbiswas@nvidia.com> Reviewed-by: Narendra Damahe <ndamahe@nvidia.com> Tested-by: Narendra Damahe <ndamahe@nvidia.com> Tested-by: Iqbal Bhinderwala <iqbalb@nvidia.com> Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23[ventana]:enable HDMI by setting GPIO state.Suresh Mangipudi
Setting the gpio to Input mode for the HDMI. Change-Id: If8eebb714bf09450ebaf5cae924e2b5cae4048df Reviewed-on: http://git-master/r/3771 Tested-by: Suresh Mangipudi <smangipudi@nvidia.com> Reviewed-by: Venkata Nageswara Penumarty <vpenumarty@nvidia.com> Tested-by: Venkata Nageswara Penumarty <vpenumarty@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23[ventana] lp0 supportSuresh Mangipudi
Set 2 sources of wake up, for ventana 1. PWR key 2. WAKE key Added support for reading the odm option for the low power state from the odm data that is provided during nvflash. Change-Id: Ib8da228a89bb514f1bce2f4971e432c269cd80ea Reviewed-on: http://git-master/r/4187 Reviewed-by: Gary King <gking@nvidia.com> Tested-by: Gary King <gking@nvidia.com>
2010-07-23[ARM/tegra] configuration: set LP2 config options.Alex Frid
Set LP2 configuration options for NV platforms. Change-Id: I5fcf1192f0b30774496ddcc95ca71e9613a7aecc Reviewed-on: http://git-master/r/4233 Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-23[arm/tegra] dma: Interupt thread should be smp safe.Laxman Dewangan
The interrupt thread handler have the static variable inside a function. This is causing the corruption in the variale when two processor execute the interrupt thread at same time in smp mode. Removing the qualifier static of a variable as this is not required and also safe in smp mode. Change-Id: I43fdab81a0a71c82e67eb4c12be0826f3bd8a927 Reviewed-on: http://git-master/r/4300 Reviewed-by: Gary King <gking@nvidia.com> Tested-by: Gary King <gking@nvidia.com>
2010-07-23[arm/tegra] ODM: adding csr and broadcom GUIDrgoyal
Added GUID for broadcom and csr to identify which BT chip is present. Change-Id: Ib4163d2aacd97700047be4f20b66fc40d7aa1a35 Reviewed-on: http://git-master/r/4238 Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Tested-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Udaykumar Rameshchan Raval <uraval@nvidia.com> Reviewed-by: Janne Hellsten <jhellsten@nvidia.com>
2010-07-22[ARM] config: enable HAVE_DEFAULT_NO_SPIN_MUTEXESBharat Nihalani
There was a change introduced in K32 to optimally spin inside the mutex-lock implementation. This in-turn caused a regression and manifested as a soft-lockup in kernel while running mulit-media stress test. By enabling this config, we are disabling the newly introduced change. Bug 702462 Change-Id: I25720a4462a2c6a1b52a9682ba5cbc03a7bcca19 Reviewed-on: http://git-master/r/3718 Tested-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2010-07-22[tegra-otg] Fix usb cable notification after LP0 resume.Venkat Moganty
After resume from LP0 VBUS and ID interrupt enable bits are cleared and are not enabled. So cable connect/disconnect is not functional after resume from LP0. This is fixed by enabling the interrupts during the resume functionality. Bug 712862 Change-Id: I67fd63f4daefbb811757c675538071371242c428 Reviewed-on: http://git-master.nvidia.com/r/4266 Reviewed-by: Narendra Damahe <ndamahe@nvidia.com> Tested-by: Narendra Damahe <ndamahe@nvidia.com> Tested-by: Bitan Biswas <bbiswas@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-22[ARM/tegra] ODM: set CPU power off time on Whistler.Alex Frid
Set CPU power off time on Whistler to assure correct power-on reset on exit from LP2. Possible fix for bug 710566 Change-Id: Ifb15183150b32345e21df23da96dc5d76fdb0802 Reviewed-on: http://git-master.nvidia.com/r/4189 Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-22[arm/tegra] board-nvodm: adding bcm4329 supportrgoyal
Adding odm support for broadcom bcm4329 chip. Change-Id: I9155d06c37ca31ad00f0c90fa1470ea9ad384ec0 Reviewed-on: http://git-master.nvidia.com/r/4236 Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Tested-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Udaykumar Rameshchan Raval <uraval@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-22[ARM/tegra] ODM: Integrated Elpida EMC DVFS table.Alex Frid
Integrated Elpida EMC DVFS table for Whistler E1108 processor board. Bug 709629 Change-Id: I493d2e8cb3f87b9bcabeee97602994d4d85c794e Reviewed-on: http://git-master.nvidia.com/r/4106 Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-22[tegra-udc] Fix LP0 resume hang in USB OTG-deviceVenkat Moganty
Setting OTG state to device mode on resume from LP0 if VBUS is detected during LP0 resume. Change-Id: Ib029e6ea5b1d3e4b5c4b5c913c71e2789106a426 Reviewed-on: http://git-master/r/4247 Reviewed-by: Narendra Damahe <ndamahe@nvidia.com> Tested-by: Narendra Damahe <ndamahe@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-22[odm]whistler:Making DeepSleep[LP0] as a default power state.Bitan Biswas
Making DeepSleep as a default power state during system suspend. Suspend[LP1] power state can be selected with ODMDATA Change-Id: I41fbffb901174a121447e1f97de2d8150245d1db Reviewed-on: http://git-master/r/4115 Reviewed-by: Bitan Biswas <bbiswas@nvidia.com> Reviewed-by: Narendra Damahe <ndamahe@nvidia.com> Tested-by: Narendra Damahe <ndamahe@nvidia.com> Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-22[ARM/tegra] RM: added LP2 configuration options.Alex Frid
Added configuration options to set default LP2 policy. Change-Id: I81820f575858dda62d31b304b6adf09f7d0f3689 Reviewed-on: http://git-master/r/4164 Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-22tegra rfkill: adding of rfkill support for bcm4329rgoyal
Adding rfkill Implementation for Broadcom BT chip (BCM4329) in existing code. Change-Id: I9a59052ca440124a1039255c72aa7cb00a015416 Reviewed-on: http://git-master/r/3883 Reviewed-by: Udaykumar Rameshchan Raval <uraval@nvidia.com> Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Tested-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-21[arm] whistler: enable USB_ANDROID_ADBBowen Sun
Bug 678046 Change-Id: Id807aeb5fb004ec52714603aae78debf76b7c405 Reviewed-on: http://git-master/r/4229 Reviewed-by: Bowen Sun <bsun@nvidia.com> Tested-by: Bowen Sun <bsun@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2010-07-21[arm] harmony: enable USB_ANDROID_ADBBowen Sun
Bug 678046 Change-Id: If9b208a47e77e9c57c02d89c4c133933a82249df Reviewed-on: http://git-master/r/4095 Reviewed-by: Bowen Sun <bsun@nvidia.com> Tested-by: Bowen Sun <bsun@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2010-07-21[arm/tegra] let RTC internal and ODM drivers coexistJon Mayo
Change-Id: I353d5ff87243c3098100320b2cd184b47b471e84 Reviewed-on: http://git-master/r/4182 Reviewed-by: Gary King <gking@nvidia.com> Reviewed-by: Jonathan Mayo <jmayo@nvidia.com> Tested-by: Jonathan Mayo <jmayo@nvidia.com>
2010-07-21[ARM/tegra]AES:SW WAR for reading updated IV for X9.31Kasoju Mallikarjun
Implemented SW WAR for getting Updated IV for X9.31 using following steps: 1. Perform CBC encryption on zero data to get A=CBC(encrypt, plaintext=zeroes) 2. Perform ECB decryption on A. This will result in Updated IV. UpdatedIV = ECB(decrypt, A) In the current implementation X9.31 operations are disabled with key slots where reads of Updated IV have been disabled. This restriction has been removed now. Bug 672022 Change-Id: I756d8500e00b9572648eec5803a5a04e25a7b70d Reviewed-on: http://git-master/r/4129 Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com> Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-21[odm] ventana: Adding support for volup/down and onkey.Laxman Dewangan
Adding the entry for volume-up, volume-down and onkey of ventana to support these keys events. Change-Id: Ia01f369626052de7a76361d47b6df1d5839b7353 Reviewed-on: http://git-master/r/4141 Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com> Tested-by: Suresh Mangipudi <smangipudi@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-20[ARM] harmony: Disable Power Management Wake LocksRakesh Iyer
Disabling the CONFIG_WAKELOCK config variable from defconfig file. Bug 700568 Change-Id: I042937ea692d08f6ce6754295fb9c628536acdb2 Reviewed-on: http://git-master/r/4113 Reviewed-by: Rakesh Iyer <riyer@nvidia.com> Tested-by: Rakesh Iyer <riyer@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2010-07-20[arm/tegra] Fix includeMaria Gutowski
gpio-names.h must be included as a local header, not a system header. Change-Id: I3ea5d2f92bb283f68e6acbfb5bc813cd993a8acf Reviewed-on: http://git-master.nvidia.com/r/4161 Tested-by: Maria Gutowski <mgutowski@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-20[ARM] tegra: nvrm: remove GART allocation from I2C driverKirill Artamonov
The problem is that some drivers can keep GART memory pinned, fragmenting it and making impossible to pin the memory allocated in other process. 24M limit on GART made situation less probable but didn't solve it completely. This fix disables GART allocation for ap20rm_i2c driver. Change-Id: I22889a58ca9f6c0e38b00301abd36e272654e7d4 Reviewed-on: http://git-master/r/4150 Reviewed-by: Gary King <gking@nvidia.com> Tested-by: Gary King <gking@nvidia.com>
2010-07-20[tegra ALSA] Change Default Buffer SizeManjula Gupta
- Change TEGRA_DEFAULT_BUFFER_SIZE to 4k, as it's the normal processing size in Audiofx. - Update tegra_sndfx.h to keep it in sync with audiofx header file. Change-Id: Ica7a396b4fa66134be7193a983da64b312fe5f38 Reviewed-on: http://git-master/r/4131 Tested-by: Manjula Gupta <magupta@nvidia.com> Reviewed-by: Vijay Mali <vmali@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-20MMC: fix to report correct disk space in case of emmc 4.3+ cardsNitin Ghate
change to subtract the boot partiotion size from the entire device size so that proper device size is reported. updated the code as per suggestions from Gary, removed the comment bug: 683019 Change-Id: Iaa1a8d773dc1b876eb1da55823ff44a7f745d234 Reviewed-on: http://git-master/r/3496 Tested-by: Nitin Ghate <nghate@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-20[arm/tegra] power : Fixing pinmux save/restore orderRaj Jayaraman
To avoid spurious signal transitions on exit from deepsleep pinmux restoration should be done in an order. Change-Id: Ie7fc48c964aef83d7f6c5e150d9b0f387bd26998 Reviewed-on: http://git-master/r/4116 Reviewed-by: Venkata (Muni) Anda <vanda@nvidia.com> Tested-by: Venkata (Muni) Anda <vanda@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-20dsi: Configuring Normal mode for lcd_de pinNagesh Penumarty
The POR value of the lcd_de pin is pull up. Becasue of default pull up of lcd_de pin, display controller is triggering the frame even when TE is not connected to the panel. So, configuring the lcd_de pin in Normal mode instead of default pullup. With this change, Android is display is seen on the dsi panel only when TE is connected to the panel, else there will not be any display. Tested on: Whistler, Android using dsi panel. Bug 703400 Change-Id: I0f934d703caedac1be2317bfe80568d3a74e21db Reviewed-on: http://git-master/r/4126 Tested-by: Venkata Nageswara Penumarty <vpenumarty@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-19[ARM] whistler: Enable USB_SUSPENDRakesh Iyer
Enabling the USB_SUSPEND config variable from defconfig file. Bug 700516 Change-Id: Icf7c5c8cfc571b95f8315f3da027ba3c0d601acf Reviewed-on: http://git-master/r/4105 Reviewed-by: Rakesh Iyer <riyer@nvidia.com> Tested-by: Rakesh Iyer <riyer@nvidia.com> Reviewed-by: Narendra Damahe <ndamahe@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2010-07-19[arm/tegra] dma: Stopping Dma after last req transfer.Laxman Dewangan
In continous mode, dma should stop after last transfer completed and if there is no more req pending. If there is pending req then it should check whether it has updated in hw for next transfer or not and if it has not started then stop dma and start new req immediatley. Change-Id: Id79f72fbd9650685962fc7085b6bb8f818effd27 Reviewed-on: http://git-master/r/3799 Reviewed-by: Panneer Arumugam <parumugam@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com> Tested-by: Gary King <gking@nvidia.com>
2010-07-19[ARM/tegra] power: cleaned up suspend entry/exit.Alex Frid
- Saved/restored CPU power Off timer on LP1 entry/exit - Re-arranged symmetrically suspend entry/exit code Change-Id: Iebc2f56e2794e1e93f2c195f22d70007243b1036 Reviewed-on: http://git-master/r/3989 Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-19[tegra-udc]: Fix LP0 hang in udc suspend for OTG mode.Venkat Moganty
After long time of executing LP0 cycles some times device fails to handle the udc irq in OTG mode. This is due to the OTG state which is changed to unknown before the controller is completely stopped. Fixed this by setting OTG state properly to unknown only after disabling the interrupts and stopping the controller completely in suspend path. Change-Id: I4baf2f29857cd35937acc67aca7c01077e362be1 Reviewed-on: http://git-master/r/4016 Reviewed-by: Narendra Damahe <ndamahe@nvidia.com> Tested-by: Narendra Damahe <ndamahe@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-19[ARM] dmabounce: check for alignment & aperture for bouncingSteve Lin
change 53f34260 accidentally deleted the code that checked the dma address to determine if it needed to be bounced, so no bouncing was performed. revert this part of the change Change-Id: Iae2d097c38e178c25132cacfe58c132736186c46 Reviewed-on: http://git-master/r/4053 Tested-by: Szming Lin <stlin@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-19[arm/tegra] ventana: Board info for AK8975 and isl29018.Laxman Dewangan
Registering the board info for the magnetometer AK8975 and ALS isl29018 hw monitor i2c client driver based on ventana board layout. Change-Id: I48d4dbb62605c2c840af4df4e6d31ae371fe75ba Reviewed-on: http://git-master/r/3855 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> Tested-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-19[ARM/tegra] AES:Remove intermediate memcopy in process bufferKasoju Mallikarjun
Modified AES kernel driver to copy client buffer into DMA buffer instead of copying it to local buffer. This reduces number of memory copies from four to two. Bug 660522 Change-Id: Iafb4aff9c8d10e1bc40bef29ef762174420ec057 Reviewed-on: http://git-master/r/4069 Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
2010-07-19[arm] ventana: Enable SENSORS_AK8975 and SENSORS_ISL29018.Laxman Dewangan
Enabling the CONFIG_SENSORS_AK8975 for enabling the magnetometer AK8975 driver to provide the measurements of magnetic flux in 3 axis. Enabling the CONFIG_SENSORS_ISL29018 for enabling the intersil ISL29018 driver to provide the ambient light sensing in lux. Change-Id: Id289dde1d216096a02520e373f2a1a408a87229a Reviewed-on: http://git-master/r/3861 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> Tested-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Gary King <gking@nvidia.com>
