Hotplug does not work if the regulator is disabled, so keep it enabled
until the device wants to enter lowpower mode.
Change-Id: I5a53a0fb0a7f26ba9f2674bbc65f4650948f6143
Reviewed-on: http://git-master/r/33117
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
uart_update_termios is called on console resume and restores the line
parameters using cons->cflag before resetting it. However code in
uart_resume_port does the same afterwards, applying a 0 value to the
port's cflag and erasing the correct setting. This patch preserves the
value of cflag in uart_update_termios to prevent this and allow the
serial console to restore properly even if there is no program using it
on user side.
Serial code has been largely refactored upstream in the upstream kernel
and faulty code apparently removed.
Fixes bug 831077
Change-Id: Ia894f971d9b6bb0c6103dbca9d169dc2a2148f84
Reviewed-on: http://git-master/r/33098
Reviewed-by: Alex Courbot <acourbot@nvidia.com>
Tested-by: Alex Courbot <acourbot@nvidia.com>
Reviewed-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Janne Hellsten <jhellsten@nvidia.com>
Change-Id: I035a6cd254342fe11f074cb85439f378a7675943
Signed-off-by: Michael I. Gold <gold@nvidia.com>
Reviewed-on: http://git-master/r/33038
Reviewed-by: Brian Anderson <branderson@nvidia.com>
Change-Id: I6ec62abdaf3a8ec2e59e2a533b36b280d69538e1
Signed-off-by: Ari Hirvonen <ahirvonen@nvidia.com>
Reviewed-on: http://git-master/r/33037
Reviewed-by: Michael I Gold <gold@nvidia.com>
Tested-by: Michael I Gold <gold@nvidia.com>
PortConnectionDetect to be cleared if the usbphy clock interrupt is set.
The USB plugin detection is done appropriately without missing
cableconnect event.
Bug 825920
Change-Id: I4400f208f405a110fff48f1fea777b472aacce62
Reviewed-on: http://git-master/r/32599
Enabling AHB prefetch on USB1, USB2, USB3 controllers,
to improve the USB transfer throughput.
Bug 820602
Change-Id: I4e9e9fa37624cc11f83effd268cdbf31c01f1df7
Reviewed-on: http://git-master/r/30475
Tested-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Change-Id: I2dcdfadb44a981cccf583a156be0be093ca5feec
Reviewed-on: http://git-master/r/34229
Reviewed-by: Maria Gutowski <mgutowski@nvidia.com>
Tested-by: Maria Gutowski <mgutowski@nvidia.com>
unlock mutex if reset worker finds the display disabled.
Bug 801463
Reviewed-on: http://git-master/r/29898
(cherry picked from commit 672459efb81140b496e3749f1b1b14dcf84af74d)
Change-Id: I94254fca387cddcd58166757e46422167ed9262d
Reviewed-on: http://git-master/r/32758
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
Tested-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
this is done so that it's easy to get the emc stats without having to
enable this explicitly when one wants to get the emc stats.
Change-Id: Id6039e8cb4510740182981245453128f406ee00d
Reviewed-on: http://git-master/r/32171
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Enabling SDHCI_QUIRK_BROKEN_CARD_DETECTION. For non-
removable cards, always set card_present as true.
Bug 827470
Change-Id: I1148984e4dff314173b88373e1494379abce31f3
Reviewed-on: http://git-master/r/31990
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Added card_detect callback in sdhci_ops. When
SDHCI_QUIRK_BROKEN_CARD_DETECTION is enabled,
get the card present status from this callback.
Bug 827470
Change-Id: Ifdd9576ff4e33a4be4c32a57e2d49d692ec95f36
Reviewed-on: http://git-master/r/31987
Removes changes to DC reset flow introduced in commit e9f069bc2c9e0a9e3d7dfd30b66367667ab82dee.
Fixes the issue of HDMI output after playing 1080p stream.
bug 820455
bug 826061
Change-Id: I9c0802c4c39d4f899e948e8020a721699634d84c
Reviewed-on: http://git-master/r/31959
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
use smaller h_ref_to_sync values.
removed old debug printks
Bug 806009
(cherry picked from commit 8292b4988e6aa75c71f14cbf96dad8b5e931e681)
Change-Id: Iae3e84ddd8c02be1a83f9ac255fc1152dc867f0b
Reviewed-on: http://git-master/r/30585
Change-Id: I8ee718e0d56ff8dc2f2c2e1b5215d195f317f0e2
Reviewed-on: http://git-master/r/31084
Assignment moved inside if statement, where it belongs.
bug 828756
Change-Id: I2ee63bed168feade897ba15b364de1ee714f1381
Reviewed-on: http://git-master/r/31955
Tested-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Return last requested position if the motor settled or timeout occurs.
Reviewed-on: http://git-master/r/27978
(cherry picked from commit edb393adc0317a097858edeb4b9f5477d164b955)
Change-Id: I54572b180bf151785d55edde9060876ed0393ee3
Reviewed-on: http://git-master/r/31741
Reviewed-by: Frank Chen <frankc@nvidia.com>
Tested-by: Gary Zhang <garyz@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Gary Zhang <garyz@nvidia.com>
tegra_dc_hdmi_equal doesn't check pixclock. some devices doesn't
support 14.85Mhz pixclock so 1080p@60 cannot be used. However,
1080p@30 is supported. Therefore, adding a max pixclock prevents
1080p@60 mode is falsely used for those devices
Bug: 815409
Change-Id: Ia2d8dcf360afa51e160d0e997986fe1714254a6b
Reviewed-on: http://git-master/r/31663
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Donghan Ryu <dryu@nvidia.com>
Add support for usb hotplug, this change will add the following:
vbus is left enabled.
Bug 796158
Change-Id: I3c3cfa0bf8858b3be2351fe753ceb2a0229ed15d
Reviewed-on: http://git-master/r/30686
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
added code to support digital mic on wm8903 for ventana. By default
analog mic is enabled. To enable digital mic write 1 and to disable
write 0 to
/sys/devices/platform/soc-audio/enable_digital_mic
Change-Id: I36e239d10404a9bc8446e275e5c59e9829409608
Reviewed-on: http://git-master/r/29615
sclk max rate for AP25 is 300MHz and pclk is set as 1:2 to sclk.
pclk max rate changed to 150MHz for AP25.
Bug 821534
Change-Id: I6c6b30f0c9b2dd568e6171e9b6d88c8eef212ab7
Reviewed-on: http://git-master/r/31311
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
sdhci instance used by wifi should be always on to support
wake on wireless functionlity. pm_notify will power off
controller on suspend/resume which is not desired for wifi
instance.
bug 818687
bug 780047
bug 798783
Change-Id: I572e9e1f275c306eadda85ca95234a427fad23ca
Reviewed-on: http://git-master/r/30864
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Tested-by: Rakesh Kumar <krakesh@nvidia.com>
The kernel now receives wait tracking data (similar to gathers and
relocs) and compares the current syncpt with the threshold value.
If it's old, it gets a kernel mapping and rewrites the method data
to use a kernel reserved syncpt that is always 0 (so trivially pops
when seen by the HW).
Bug 519650
Bug 785525
Bug 803452
Note: reset the author in this commit to fix a email addr problem
and since from the latest/last cherry pick there was a reworking
of the code to be compatible with different user space versions
it also seemed reasonable.
(cherry picked from commit 4069d8e67665624ad3dceb628e572980dd57acd0)
(cherry picked from commit 6e4336408588e348804a62e53386acc9abc06823)
(cherry picked from commit 87a9efe751716ca741caac72b9061fdfdcec540a)
Change-Id: I9c6076da2384f373d5f402bee4406b09b4ebc4ff
Reviewed-on: http://git-master/r/23159
Reviewed-on: http://git-master/r/30281
Tested-by: Chris Johnson <cwj@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com>
Merge updates from tegra_defconfig
Change-Id: I45a488f27c516a0f892eb394771302c68cd2aa6c
Reviewed-on: http://git-master/r/31257
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Andrei Denissov <adenissov@nvidia.com>
Reviewed-by: Jonathan B White (Engrg-Mobile) <jwhite@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
clip invalid windows to fix screen size, failure to do so causes display
errors that result in corrupted display and invalid video modes.
prints a warning only once, if this warning is present in the logs then
there is a misbehaving application.
Bug 821094
(cherry picked from commit e08f18eba00bd5d86cb7770f709417a1bd0ca14f)
Change-Id: Ie5cec5c805bfe2bd4c5f1e5b7e22d5f255ca2680
Reviewed-on: http://git-master/r/30587
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
sclk minimum rate is set to 40MHz which is less than required by usb.
set sclk rate to 80MHz when usb is connected and disable sclk when usb is
not connected so that sclk will get clocked at minimum rate.
Bug 819796
Reviewed-on: http://git-master/r/28766
(cherry picked from commit e705e6b448791ef938a0897755205cdde72fa361)
Change-Id: I180d044f788e153d0057355e22ed422f32552d5c
Reviewed-on: http://git-master/r/30818
Set the platform data for the USB1 host mode to NULL during the unregister.
After freeing up the platform data pointer.
Bug 820333
Change-Id: I6fb3edf58d854c0d8f648572f40cebe6811e2069
Reviewed-on: http://git-master/r/30696
The commit 4547be7 rewrites suspend and resume functions. According
to this rewrite, when a serial port is a printk console device and
can suspend(without set no_console_suspend flag), it will definitely
call set_termios function during its resume, but parameter termios
isn't initialized, this will pass an unpredictable config to the
serial port. If this serial port is not a userspace opened tty device
, a suspend and resume action will make this serial port unusable.
I.E. ttyS0 is a printk console device, ttyS1 or keyboard+display is
userspace tty device, a suspend/resume action will make ttyS0
unusable.
If a serial port is both a printk console device and an opened tty
device, this issue can be overcome because it will call set_termios
again with the correct parameter in the uart_change_speed function.
Refer to the deleted content of commit 4547be7, revert parts relate
to restore settings into parameter termios. It is safe because if
a serial port is a printk console only device, the only meaningful
field in termios is c_cflag and its old config is saved in
uport->cons->cflag, if this port is also an opened tty device,
it will clear uport->cons->cflag in the uart_open and the old config
is saved in tty->termios.
refer http://git.kernel.org/?p=linux/kernel/git/stable/linux-2.6.37.y.git;
a=commit;h=891b9dd10764352926e1e107756aa229dfa2c210
cherry-pick the changes from the kernel 2.6.37 commit id
:891b9dd10764352926e1e107756aa229dfa2c210
Cherry-picked http://git-master/r/#change,20302
Bug 819016
Change-Id: Ic7ce0a6d595c0e1f65285d7978db93be12158f0f
Reviewed-on: http://git-master/r/30680
Do not handle requests further for displays that are not enabled
Bug 813310
Bug 813728
Reviewed-on: http://git-master/r/29515
(cherry picked from commit 22578f1d7065ea84855fdbcaf09a792e9f9d3856)
Change-Id: I1fa907e33f2d250fff64752c8f0e26de51f3655b
Reviewed-on: http://git-master/r/30672
Change-Id: Ic3eb5d136be746b55bea4efe302e0f417dfc1eb6
Reviewed-on: http://git-master/r/30512
Tested-by: Manjula Gupta <magupta@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Having the device resume and suspend when the cable is not present is
an overhead for the system. Hence removed resume and device function
calls when the cable is not present.
Bug 803280
Change-Id: I238474fb1f3629f78833d58a89ffcabff7754fbb
Reviewed-on: http://git-master/r/30500
* set bsea sclk to ulong_max
* use unbounded work queues with 1 max_active
work item on each of them
* clear INTR_STATUS per operation
* free nvmap handle after using it
Bug 803932
Change-Id: I9e46d86891f0026504ca4ab2f0c6da5776bb9a73
Reviewed-on: http://git-master/r/30196
Bug 803932
Change-Id: Ia9cf3f20c6921fc18b02527c9c0108fd4f08e79b
Reviewed-on: http://git-master/r/30195
shared clock rate is dependent on its parent max rate. Parent's max rate
get updated in sku limit init depending on the sku value. Hence initialize
shared clocks after sku limits are applied.
Bug 821534
Change-Id: Ic11631cd54af638c8afa75aceeb4bcd999c8135f
Reviewed-on: http://git-master/r/30504
dynamic changing of pclk divider to follow APB clock minimum
frequency requirements with respect to sclk frequency.
Bug 819796
Reviewed-on: http://git-master/r/29643
(cherry picked from commit c5ed952608ff2e3ffdcba99295f8892dac1506c0)
Change-Id: Iec403b137fa001ff401fd14990040889ec679eca
Reviewed-on: http://git-master/r/30315
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
sclk is shared between usb and avp. usb sets it to 80MHz, hence set sclk rate
to max when avp is running.
Bug 819796
Reviewed-on: http://git-master/r/28765
(cherry picked from commit 44234ba7be2de25ef79b803747064ce54f6dc081)
Change-Id: Iea5c785da0aff69f61c82f7e67356d93ead1d994
Reviewed-on: http://git-master/r/30314
sclk continues to be clocked at 120MHz even when there is no activity.
Add dfs so that different modules can set sclk rate as required and it will
be clocked to minimum when there is no activity.
Minimum limit changed to 40MHz for sclk.
Bug 819796
Reviewed-on: http://git-master/r/28764
(cherry picked from commit ee17dca953c7eadc01a221a245a7e95d0fff33ea)
Change-Id: I78d4a6b699bb827de4d5cfa5ac621961d09d47de
Reviewed-on: http://git-master/r/30313
the fix add testcase for testing aes ofb mode.
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Bug 787628
cherry picked the following commit
http://git.kernel.org/?p=linux/kernel/git/herbert/
cryptodev-2.6.git;a=commit;h=ba0e14acc417eceb895efda1ff46366f4d1728f8
Change-Id: Ibcb554ac4971edd61c8141137fbe6178e2fb8209
Reviewed-on: http://git-master/r/30339
Tested-by: Puneet Saxena <puneets@nvidia.com>
Revise some default settings for utimp phy
Bug 815848
Change-Id: I7eac6981e52bdf6b33e80d34aebb0dc403b326bf
Reviewed-on: http://git-master/r/30257
usbd clock is enabled during the probe and not disabled after the
functionality. Due to this clock reference count is non-zero and hence
usbd clock is not disabled during suspend. Fixed this by disabling
clock appropriately.
- Since clocks are now turned off during suspend clock
needs to be enabled during fsl_udc_resume.
Bug 793834
Reviewed-on: http://git-master/r/21652
(cherry picked from commit 8fa46a6da22e6def221435098de054e55c7d1196)
Reviewed-on: http://git-master/r/22999
(cherry picked from commit 7ca37264ae9f7358afea2622fa35b928391f8561)
Change-Id: I9f39696e04674e76fb088e9eee498153f981bac6
Reviewed-on: http://git-master/r/30075
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
some testing revealed certain loopholes in the
code. also the way the shell sends data down to
the sysfs handlers changed which warranted the
change in the handlers.
Change-Id: I131ab43691321a864ad5afd4f9852a7ba8842130
Reviewed-on: http://git-master/r/30134
This is to make sure this function will not cause any lock-up
during actual reboot
Should help bug 770426
Change-Id: Id5cfaee07d9438741b721b67c7cd342858e7b5cb
Reviewed-on: http://git-master/r/28345
Reviewed-on: http://git-master/r/30176
Disabling IRQ and FIQ before we stop other processor cores and start reboot
process will make sure the restart procedure is not preempted. This is to
prevent the potential lockup caused by the loss of synchronisation among
different processor cores due to IPI_STOP.
Reviewed-on: http://git-master/r/27780
(cherry picked from commit 3d63b7709f3614783ebbf97568132458e5198c29)
Change-Id: I513a1f7394478b16f6c0204af7b31b18244ac819
Reviewed-on: http://git-master/r/30172
LDO_SHDN_L signals control AVDD_2P8V and VDD_AF_2P8V supplies to
camera sensor modules. Power on these supplies only when camera
is in use.
BUG 782390
Change-Id: Ifefbb0b4da0b9213c4a2f76b51bcd3f2bbeb745d
Reviewed-on: http://git-master/r/30015
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-by: Erik M Lilliebjerg <elilliebjerg@nvidia.com>
On ventana, pca9546 is used as a mux for 0v2710/ov5650 camera
sensors. With UJA0H14 version of ov5650 sensor, it is observed
that pca9546 driver incorrectly caches last channel when VDDIO_CAM
is toggled while enabling/disabling tegra camera. Deselect i2c
mux channel on exit so that i2c mux is correctly configured with
new mux channel.
BUG 812134
(cherry picked from commit 2d62e589c0bd933db846d4b8f9fe4f2116bef8ad)
Change-Id: Id249bbeb33c370b8fc5360af33bdefecfd62a48a
Reviewed-on: http://git-master/r/29811
Delay of 4ms is needed after the SUSPEND bit in the PORTSC register is
programmed. The hardware would be set only after 4ms of delay.
Bug 812427
Change-Id: I5253928264112b429f78e6682e261a44820811db
Reviewed-on: http://git-master/r/27510
Reviewed-on: http://git-master/r/29974
Change-Id: I6f0bc3b5859c8545853051f10bda60ab6ac3dd8b
Bug 819975
Change-Id: I19e1448b07702bebaf2889efc3a304fcd2d07df8
Reviewed-on: http://git-master/r/29467
Change-Id: I26f58048e4bb2988a7121bf4a7738607ced88a12
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/29674
* add bsea engine support for encryption and decryption
* add arbitration semaphore id for bsea
Bug 803932
Change-Id: I978b06a12265acecae99dbf13607e00ae74e87f7
Reviewed-on: http://git-master/r/29672
program pwren signal of max8907c regulator to power down/up core rail on
deep sleep enter/exit deep sleep mode.
core_timer and core_off_timer changed as per K32.
separate_req set to false as whistler pmu has combined power requests.
Bug 817378
Change-Id: Ia95a61360079f919a039572cf8fd4597db9efd50
Reviewed-on: http://git-master/r/28435
apis added to program max8907c regulator to power down and up core supply rail
via the pwren signal on enter and exit deep sleep mode.
Bug 817378
Change-Id: I5af04db22b6c84fc4359c1a0cf209710ca144159
Reviewed-on: http://git-master/r/28434
