commit 6039f37dd6b76641198e290f26b31c475248f567 upstream.
The bar values are little endian, not big endian. The pack
function did it right but the unpack got it wrong. Fix it.
Cc: stable@vger.kernel.org
Cc: linux-media@vger.kernel.org
Cc: Martin Bugge <marbugge@cisco.com>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Fixes: 2c676f378edb ("[media] hdmi: added unpack and logging functions for InfoFrames")
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190919132853.30954-1-ville.syrjala@linux.intel.com
Reviewed-by: Thierry Reding <treding@nvidia.com>
commit b67a95f2abff0c34e5667c15ab8900de73d8d087 upstream.
The PCI INTx interrupts and other LSI interrupts are handled differently
under a sPAPR platform. When the interrupt source characteristics are
queried, the hypervisor returns an H_INT_ESB flag to inform the OS
that it should be using the H_INT_ESB hcall for interrupt management
and not loads and stores on the interrupt ESB pages.
A default -1 value is returned for the addresses of the ESB pages. The
driver ignores this condition today and performs a bogus IO mapping.
Recent changes and the DEBUG_VM configuration option make the bug
visible with :
kernel BUG at arch/powerpc/include/asm/book3s/64/pgtable.h:612!
Oops: Exception in kernel mode, sig: 5 [#1]
LE PAGE_SIZE=64K MMU=Radix MMU=Hash SMP NR_CPUS=1024 NUMA pSeries
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.0-0.rc6.git0.1.fc32.ppc64le #1
NIP: c000000000f63294 LR: c000000000f62e44 CTR: 0000000000000000
REGS: c0000000fa45f0d0 TRAP: 0700 Not tainted (5.4.0-0.rc6.git0.1.fc32.ppc64le)
NIP ioremap_page_range+0x4c4/0x6e0
LR ioremap_page_range+0x74/0x6e0
Call Trace:
ioremap_page_range+0x74/0x6e0 (unreliable)
do_ioremap+0x8c/0x120
__ioremap_caller+0x128/0x140
ioremap+0x30/0x50
xive_spapr_populate_irq_data+0x170/0x260
xive_irq_domain_map+0x8c/0x170
irq_domain_associate+0xb4/0x2d0
irq_create_mapping+0x1e0/0x3b0
irq_create_fwspec_mapping+0x27c/0x3e0
irq_create_of_mapping+0x98/0xb0
of_irq_parse_and_map_pci+0x168/0x230
pcibios_setup_device+0x88/0x250
pcibios_setup_bus_devices+0x54/0x100
__of_scan_bus+0x160/0x310
pcibios_scan_phb+0x330/0x390
pcibios_init+0x8c/0x128
do_one_initcall+0x60/0x2c0
kernel_init_freeable+0x290/0x378
kernel_init+0x2c/0x148
ret_from_kernel_thread+0x5c/0x80
Fixes: bed81ee181dd ("powerpc/xive: introduce H_INT_ESB hcall")
Cc: stable@vger.kernel.org # v4.14+
Signed-off-by: Cédric Le Goater <clg@kaod.org>
Tested-by: Daniel Axtens <dja@axtens.net>
Link: https://lore.kernel.org/r/20191203163642.2428-1-clg@kaod.org
commit 29430fae82073d39b1b881a3cd507416a56a363f upstream.
When calling flush_icache_range with a size >4GB, we were masking
off the upper 32 bits, so we would incorrectly flush a range smaller
than intended.
This patch replaces the 32 bit shifts with 64 bit ones, so that
the full size is accounted for.
Signed-off-by: Alastair D'Silva <alastair@d-silva.org>
Link: https://lore.kernel.org/r/20191104023305.9581-2-alastair@au1.ibm.com
commit 1ca3dec2b2dff9d286ce6cd64108bda0e98f9710 upstream.
When the machine crash handler is invoked, all interrupts are masked
but interrupts which have not been started yet do not have an ESB page
mapped in the Linux address space. This crashes the 'crash kexec'
sequence on sPAPR guests.
To fix, force the mapping of the ESB page when an interrupt is being
mapped in the Linux IRQ number space. This is done by setting the
initial state of the interrupt to OFF which is not necessarily the
case on PowerNV.
Fixes: 243e25112d06 ("powerpc/xive: Native exploitation of the XIVE interrupt controller")
Cc: stable@vger.kernel.org # v4.12+
Reviewed-by: Greg Kurz <groug@kaod.org>
Link: https://lore.kernel.org/r/20191031063100.3864-1-clg@kaod.org
commit f9ec11165301982585e5e5f606739b5bae5331f3 upstream.
When calling __kernel_sync_dicache with a size >4GB, we were masking
than intended.
Link: https://lore.kernel.org/r/20191104023305.9581-3-alastair@au1.ibm.com
commit 998174042da229e2cf5841f574aba4a743e69650 upstream.
Going through the uses of timeval in the user space API,
I noticed two bugs in ppdev that were introduced in the y2038
conversion:
* The range check was accidentally moved from ppsettime to
ppgettime
* On sparc64, the microseconds are in the other half of the
64-bit word.
Fix both, and mark the fix for stable backports.
Fixes: 3b9ab374a1e6 ("ppdev: convert to y2038 safe")
Link: https://lore.kernel.org/r/20191108203435.112759-8-arnd@arndb.de
commit 287897f9aaa2ad1c923d9875914f57c4dc9159c8 upstream.
The MMC card detection GPIO polarity is active low on TAO3530, like in many
other similar boards. Now the card is not detected and it is unable to
mount rootfs from an SD card.
Fix this by using the correct polarity.
This incorrect polarity was defined already in the commit 30d95c6d7092
("ARM: dts: omap3: Add Technexion TAO3530 SOM omap3-tao3530.dtsi") in v3.18
kernel and later changed to use defined GPIO constants in v4.4 kernel by
the commit 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags
cell for OMAP2+ boards").
While the latter commit did not introduce the issue I'm marking it with
Fixes tag due the v4.4 kernels still being maintained.
Fixes: 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags cell for OMAP2+ boards")
Cc: linux-stable <stable@vger.kernel.org> # 4.4+
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
pandora_wl1251_init_card
commit f6498b922e57aecbe3b7fa30a308d9d586c0c369 upstream.
Pandora_wl1251_init_card was used to do special pdata based
setup of the sdio mmc interface. This does no longer work with
v4.7 and later. A fix requires a device tree based mmc3 setup.
Therefore we move the special setup to omap_hsmmc.c instead
of calling some pdata supplied init_card function.
The new code checks for a DT child node compatible to wl1251
so it will not affect other MMC3 use cases.
Generally, this code was and still is a hack and should be
moved to mmc core to e.g. read such properties from optional
DT child nodes.
Fixes: 81eef6ca9201 ("mmc: omap_hsmmc: Use dma_request_chan() for requesting DMA channel")
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Cc: <stable@vger.kernel.org> # v4.7+
[Ulf: Fixed up some checkpatch complaints]
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
controller init
commit 7f028caadf6c37580d0f59c6c094ed09afc04062 upstream.
In s3c64xx_eint_eint0_init() the for_each_child_of_node() loop is used
with a break to find a matching child node. Although each iteration of
for_each_child_of_node puts the previous node, but early exit from loop
misses it. This leads to leak of device node.
Fixes: 61dd72613177 ("pinctrl: Add pinctrl-s3c64xx driver")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit a322b3377f4bac32aa25fb1acb9e7afbbbbd0137 upstream.
Several functions use for_each_child_of_node() loop with a break to find
Fixes: 9a2c1c3b91aa ("pinctrl: samsung: Allow grouping multiple pinmux/pinconf nodes")
controller init
commit 6fbbcb050802d6ea109f387e961b1dbcc3a80c96 upstream.
In s3c24xx_eint_init() the for_each_child_of_node() loop is used with a
Fixes: af99a7507469 ("pinctrl: Add pinctrl-s3c24xx driver")
commit 3d2557ab75d4c568c79eefa2e550e0d80348a6bd upstream.
Each iteration of for_each_child_of_node puts the previous node, but in
the case of a return from the middle of the loop, there is no put, thus
causing a memory leak. Hence add an of_node_put before the return of
exynos_eint_wkup_init() error path.
Issue found with Coccinelle.
Signed-off-by: Nishka Dasgupta <nishkadg.linux@gmail.com>
Fixes: 14c255d35b25 ("pinctrl: exynos: Add irq_chip instance for Exynos7 wakeup interrupts")
commit b9ea0bae260f6aae546db224daa6ac1bd9d94b91 upstream.
Certain ACPI-enumerated devices represented as platform devices in
Linux, like fans, require special low-level power management handling
implemented by their drivers that is not in agreement with the ACPI
PM domain behavior. That leads to problems with managing ACPI fans
during system-wide suspend and resume.
For this reason, make acpi_dev_pm_attach() skip the affected devices
by adding a list of device IDs to avoid to it and putting the IDs of
the affected devices into that list.
Fixes: e5cc8ef31267 (ACPI / PM: Provide ACPI PM callback routines for subsystems)
Reported-by: Zhang Rui <rui.zhang@intel.com>
Tested-by: Todd Brandt <todd.e.brandt@linux.intel.com>
Cc: 3.10+ <stable@vger.kernel.org> # 3.10+
commit 627ead724eff33673597216f5020b72118827de4 upstream.
kmemleak reported backtrace:
[<bbee0454>] kmem_cache_alloc_trace+0x128/0x260
[<6677f215>] i2c_acpi_install_space_handler+0x4b/0xe0
[<1180f4fc>] i2c_register_adapter+0x186/0x400
[<6083baf7>] i2c_add_adapter+0x4e/0x70
[<a3ddf966>] intel_gmbus_setup+0x1a2/0x2c0 [i915]
[<84cb69ae>] i915_driver_probe+0x8d8/0x13a0 [i915]
[<81911d4b>] i915_pci_probe+0x48/0x160 [i915]
[<4b159af1>] pci_device_probe+0xdc/0x160
[<b3c64704>] really_probe+0x1ee/0x450
[<bc029f5a>] driver_probe_device+0x142/0x1b0
[<d8829d20>] device_driver_attach+0x49/0x50
[<de71f045>] __driver_attach+0xc9/0x150
[<df33ac83>] bus_for_each_dev+0x56/0xa0
[<80089bba>] driver_attach+0x19/0x20
[<cc73f583>] bus_add_driver+0x177/0x220
[<7b29d8c7>] driver_register+0x56/0xf0
In i2c_acpi_remove_space_handler(), a leak occurs whenever the
"data" parameter is initialized to 0 before being passed to
acpi_bus_get_private_data().
This is because the NULL pointer check in acpi_bus_get_private_data()
(condition->if(!*data)) returns EINVAL and, in consequence, memory is
never freed in i2c_acpi_remove_space_handler().
Fix the NULL pointer check in acpi_bus_get_private_data() to follow
the analogous check in acpi_get_data_full().
Signed-off-by: Vamshi K Sthambamkadi <vamshi.k.sthambamkadi@gmail.com>
[ rjw: Subject & changelog ]
Cc: All applicable <stable@vger.kernel.org>
commit 833a426cc471b6088011b3d67f1dc4e147614647 upstream.
acpi_os_map_cleanup checks map->refcount outside of acpi_ioremap_lock
before freeing the map. This creates a race condition the can result
in the map being freed more than once.
A panic can be caused by running
for ((i=0; i<10; i++))
do
for ((j=0; j<100000; j++))
do
cat /sys/firmware/acpi/tables/data/BERT >/dev/null
done &
done
This patch makes sure that only the process that drops the reference
to 0 does the freeing.
Fixes: b7c1fadd6c2e ("ACPI: Do not use krefs under a mutex in osl.c")
Signed-off-by: Francesco Ruggeri <fruggeri@arista.com>
Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com>
commit db0d32d84031188443e25edbd50a71a6e7ac5d1d upstream.
The following build warning occurred on powerpc 64-bit builds:
drivers/cpufreq/powernv-cpufreq.c: In function 'init_chip_info':
drivers/cpufreq/powernv-cpufreq.c:1070:1: warning: the frame size of
1040 bytes is larger than 1024 bytes [-Wframe-larger-than=]
This is with a cross-compiler based on gcc 8.1.0, which I got from:
https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/8.1.0/
The warning is due to putting 1024 bytes on the stack:
unsigned int chip[256];
...and it's also undesirable to have a hard limit on the number of
CPUs here.
Fix both problems by dynamically allocating based on num_possible_cpus,
as recommended by Michael Ellerman.
Fixes: 053819e0bf840 ("cpufreq: powernv: Handle throttling due to Pmax capping at chip level")
Signed-off-by: John Hubbard <jhubbard@nvidia.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: 4.10+ <stable@vger.kernel.org> # 4.10+
commit 2abb0d5268ae7b5ddf82099b1f8d5aa8414637d4 upstream.
There is no locking in this sysfs show function so stats printing can
race with a devfreq_update_status called as part of freq switching or
with initialization.
Also add an assert in devfreq_update_status to make it clear that lock
must be held by caller.
Fixes: 39688ce6facd ("PM / devfreq: account suspend/resume for stats")
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
commit 6e6c18bcb78c0dc0601ebe216bed12c844492d0c upstream.
This adds support for the Trace Hub in Tiger Lake CPU.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Link: https://lore.kernel.org/r/20191120130806.44028-4-alexander.shishkin@linux.intel.com
commit 6a1743422a7c0fda26764a544136cac13e5ae486 upstream.
This adds support for the Trace Hub in Ice Lake CPU.
Link: https://lore.kernel.org/r/20191120130806.44028-3-alexander.shishkin@linux.intel.com
commit 512592779a337feb5905d8fcf9498dbf33672d4a upstream.
Commit a753bfcfdb1f ("intel_th: Make the switch allocate its subdevices")
factored out intel_th_subdevice_alloc() from intel_th_populate(), but got
the error path wrong, resulting in two instances of a double put_device()
on a freshly initialized, but not 'added' device.
Fix this by only doing one put_device() in the error path.
Fixes: a753bfcfdb1f ("intel_th: Make the switch allocate its subdevices")
Reported-by: Wen Yang <wenyang@linux.alibaba.com>
Link: https://lore.kernel.org/r/20191120130806.44028-2-alexander.shishkin@linux.intel.com
commit 918c1fe9fbbe46fcf56837ff21f0ef96424e8b29 upstream.
Fix __cpuidle_set_driver() to check if any of the CPUs in the mask has
a driver different from drv already and, if so, return -EBUSY before
updating any cpuidle_drivers per-CPU pointers.
Fixes: 82467a5a885d ("cpuidle: simplify multiple driver support")
Cc: 3.11+ <stable@vger.kernel.org> # 3.11+
Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com>
commit 806e0cdfee0b99efbb450f9f6e69deb7118602fc upstream.
CEC_OP_REC_FLAG_NOT_USED is 0 and CEC_OP_REC_FLAG_USED is 1, not the
other way around.
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Reported-by: Jiunn Chang <c0d1n61at3@gmail.com>
Cc: <stable@vger.kernel.org> # for v4.10 and up
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
commit 1091eb830627625dcf79958d99353c2391f41708 upstream.
If a process is interrupted while accessing the radio device and the
core lock is contended, release() could return early and fail to update
the interrupt mask.
Note that the return value of the v4l2 release file operation is
ignored.
Fixes: 87d1a50ce451 ("[media] V4L2: WL1273 FM Radio: TI WL1273 FM radio driver")
Cc: stable <stable@vger.kernel.org> # 2.6.38
Cc: Matti Aaltonen <matti.j.aaltonen@nokia.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@kernel.org>
commit 11609a7e21f8cea42630350aa57662928fa4dc63 upstream.
If a process is interrupted while accessing the video device and the
device lock is contended, release() could return early and fail to free
related resources.
ignored.
Fixes: 28ffeebbb7bd ("[media] bdisp: 2D blitter driver using v4l2 mem2mem framework")
Cc: stable <stable@vger.kernel.org> # 4.2
Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
commit ab874f22d35a8058d8fdee5f13eb69d8867efeae upstream.
On older HW or under a hypervisor, w/o the instruction-execution-
protection (IEP) facility, and also w/o EDAT-1, a translation-specification
exception may be recognized when bit 55 of a pte is one (_PAGE_NOEXEC).
The current code tries to prevent setting _PAGE_NOEXEC in such cases,
by removing it within set_pte_at(). However, ptep_set_access_flags()
will modify a pte directly, w/o using set_pte_at(). There is at least
one scenario where this can result in an active pte with _PAGE_NOEXEC
set, which would then lead to a panic due to a translation-specification
exception (write to swapped out page):
do_swap_page
pte = mk_pte (with _PAGE_NOEXEC bit)
set_pte_at (will remove _PAGE_NOEXEC bit in page table, but keep it
in local variable pte)
vmf->orig_pte = pte (pte still contains _PAGE_NOEXEC bit)
do_wp_page
wp_page_reuse
entry = vmf->orig_pte (still with _PAGE_NOEXEC bit)
ptep_set_access_flags (writes entry with _PAGE_NOEXEC bit)
Fix this by clearing _PAGE_NOEXEC already in mk_pte_phys(), where the
pgprot value is applied, so that no pte with _PAGE_NOEXEC will ever be
visible, if it is not supported. The check in set_pte_at() can then also
be removed.
Cc: <stable@vger.kernel.org> # 4.11+
Fixes: 57d7f939e7bd ("s390: add no-execute support")
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
commit 315cee426f87658a6799815845788fde965ddaad upstream.
memcpy() call with "idata == NULL && ilen == 0" results in undefined
behavior in ar5523_cmd(). For example, NULL is passed in callchain
"ar5523_stat_work() -> ar5523_cmd_write() -> ar5523_cmd()". This patch
adds ilen check before memcpy() call in ar5523_cmd() to prevent an
undefined behavior.
Cc: Pontus Fuchs <pontus.fuchs@gmail.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
Cc: David Laight <David.Laight@ACULAB.COM>
Signed-off-by: Denis Efremov <efremov@linux.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit a713af394cf382a30dd28a1015cbe572f1b9ca75 upstream.
Because pids->limit can be changed concurrently (but we don't want to
take a lock because it would be needlessly expensive), use atomic64_ts
instead.
Fixes: commit 49b786ea146f ("cgroup: implement the PIDs subsystem")
Cc: stable@vger.kernel.org # v4.3+
Signed-off-by: Aleksa Sarai <cyphar@cyphar.com>
commit 8962842ca5abdcf98e22ab3b2b45a103f0408b95 upstream.
It is reported that sysfs buffer overflow can be triggered if the system
has too many CPU cores(>841 on 4K PAGE_SIZE) when showing CPUs of
hctx via /sys/block/$DEV/mq/$N/cpu_list.
Use snprintf to avoid the potential buffer overflow.
This version doesn't change the attribute format, and simply stops
showing CPU numbers if the buffer is going to overflow.
Fixes: 676141e48af7("blk-mq: don't dump CPU -> hw queue map on driver load")
Signed-off-by: Ming Lei <ming.lei@redhat.com>
commit 8f157d4ff039e03e2ed4cb602eeed2fd4687a58f upstream.
Check for existance of jack before tracing.
NULL pointer dereference has been reported by KASAN while unloading
machine driver (snd_soc_cnl_rt274).
Signed-off-by: Pawel Harlozinski <pawel.harlozinski@linux.intel.com>
Link: https://lore.kernel.org/r/20191112130237.10141-1-pawel.harlozinski@linux.intel.com
Signed-off-by: Mark Brown <broonie@kernel.org>
commit e66b39af00f426b3356b96433d620cb3367ba1ff upstream.
008847f66c3 ("workqueue: allow rescuer thread to do more work.") made
the rescuer worker requeue the pwq immediately if there may be more
work items which need rescuing instead of waiting for the next mayday
timer expiration. Unfortunately, it doesn't check whether the pwq is
already on the mayday list and unconditionally gets the ref and moves
it onto the list. This doesn't corrupt the list but creates an
additional reference to the pwq. It got queued twice but will only be
removed once.
This leak later can trigger pwq refcnt warning on workqueue
destruction and prevent freeing of the workqueue.
Cc: "Williams, Gerald S" <gerald.s.williams@intel.com>
Cc: NeilBrown <neilb@suse.de>
Cc: stable@vger.kernel.org # v3.19+
commit def98c84b6cdf2eeea19ec5736e90e316df5206b upstream.
Before actually destrying a workqueue, destroy_workqueue() checks
whether it's actually idle. If it isn't, it prints out a bunch of
warning messages and leaves the workqueue dangling. It unfortunately
has a couple issues.
* Mayday list queueing increments pwq's refcnts which gets detected as
busy and fails the sanity checks. However, because mayday list
queueing is asynchronous, this condition can happen without any
actual work items left in the workqueue.
* Sanity check failure leaves the sysfs interface behind too which can
lead to init failure of newer instances of the workqueue.
This patch fixes the above two by
* If a workqueue has a rescuer, disable and kill the rescuer before
sanity checks. Disabling and killing is guaranteed to flush the
existing mayday list.
* Remove sysfs interface before sanity checks.
Reported-by: Marcin Pawlowski <mpawlowski@fb.com>
Reported-by: "Williams, Gerald S" <gerald.s.williams@intel.com>
commit e7fad909b68aa37470d9f2d2731b5bec355ee5d6 upstream.
Commit 75d66ffb48efb3 added backing device health checks and as a part
of these checks, check_events() block ops template call is invoked in
dm-zoned mapping path as well as in reclaim and flush path. Calling
check_events() with ATA or SCSI backing devices introduces a blocking
scsi_test_unit_ready() call being made in sd_check_events(). Even though
the overhead of calling scsi_test_unit_ready() is small for ATA zoned
devices, it is much larger for SCSI and it affects performance in a very
negative way.
Fix this performance regression by executing check_events() only in case
of any I/O errors. The function dmz_bdev_is_dying() is modified to call
only blk_queue_dying(), while calls to check_events() are made in a new
helper function, dmz_check_bdev().
Reported-by: zhangxiaoxu <zhangxiaoxu5@huawei.com>
Fixes: 75d66ffb48efb3 ("dm zoned: properly handle backing device failure")
Signed-off-by: Dmitry Fomichev <dmitry.fomichev@wdc.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit be867f987a4e1222114dd07a01838a17c26f3fff upstream.
Existing RNG data read timeout is 200us but it doesn't cover EIP76 RNG
data rate which takes approx. 700us to produce 16 bytes of output data
as per testing results. So configure the timeout as 1000us to also take
account of lack of udelay()'s reliability.
Fixes: 383212425c92 ("hwrng: omap - Add device variant for SafeXcel IP-76 found in Armada 8K")
Signed-off-by: Sumit Garg <sumit.garg@linaro.org>
[ Upstream commit c04571251b3d842096f1597f5d4badb508be016d ]
The ast2600 no longer uses bit 4 in the control register to indicate a
1MHz clock (It now controls whether this watchdog is reset by a SOC
reset). This means we do not want to set it. It also does not need to be
set for the ast2500, as it is read-only on that SoC.
The comment next to the clock rate selection wandered away from where it
was set, so put it back next to the register setting it's describing.
Fixes: b3528b487448 ("watchdog: aspeed: Add support for AST2600")
Signed-off-by: Joel Stanley <joel@jms.id.au>
Reviewed-by: Cédric Le Goater <clg@kaod.org>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Link: https://lore.kernel.org/r/20191108032905.22463-1-joel@jms.id.au
Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org>
[ Upstream commit e3fc3f3d0943b126f76b8533960e4168412d9e5a ]
The first argument to WARN() is supposed to be a condition. The
original code will just print the mdname() instead of the full warning
message.
Fixes: c84a1372df92 ("md/raid0: avoid RAID0 data corruption due to layout confusion.")
Signed-off-by: Song Liu <songliubraving@fb.com>
[ Upstream commit ca58f55108fee41d87c9123f85ad4863e5de7f45 ]
This is an alternative fix attemp for the issue reported in the commit
caa8422d01e9 ("ALSA: hda: Flush interrupts on disabling") that was
reverted later due to regressions. Instead of tweaking the hardware
disablement order and the enforced irq flushing, do calling
cancel_work_sync() of the unsol work early enough, and explicitly
ignore the unsol events during the shutdown by checking the
bus->shutdown flag.
Fixes: caa8422d01e9 ("ALSA: hda: Flush interrupts on disabling")
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Link: https://lore.kernel.org/r/s5h1ruxt9cz.wl-tiwai@suse.de
commit 6889ee5a53b8d969aa542047f5ac8acdc0e79a91 upstream.
In ovl_rename(), if new upper is hardlinked to old upper underneath
overlayfs before upper dirs are locked, user will get an ESTALE error
and a WARN_ON will be printed.
Changes to underlying layers while overlayfs is mounted may result in
unexpected behavior, but it shouldn't crash the kernel and it shouldn't
trigger WARN_ON() either, so relax this WARN_ON().
Reported-by: syzbot+bb1836a212e69f8e201a@syzkaller.appspotmail.com
Fixes: 804032fabb3b ("ovl: don't check rename to self")
Cc: <stable@vger.kernel.org> # v4.9+
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 702600eef73033ddd4eafcefcbb6560f3e3a90f7 upstream.
Newer versions of awk spit out these fun warnings:
awk: ../lib/raid6/unroll.awk:16: warning: regexp escape sequence `\#' is not a known regexp operator
As commit 700c1018b86d ("x86/insn: Fix awk regexp warnings") showed, it
turns out that there are a number of awk strings that do not need to be
escaped and newer versions of awk now warn about this.
Fix the string up so that no warning is produced. The exact same kernel
module gets created before and after this patch, showing that it wasn't
needed.
Link: https://lore.kernel.org/r/20191206152600.GA75093@kroah.com
commit 330bb7117101099c687e9c7f13d48068670b9c62 upstream.
In commit 38506ecefab9 ("rtlwifi: rtl_pci: Start modification for
new drivers"), the flag that indicates that interrupts are enabled was
never set.
In addition, there are several places when enable/disable interrupts
were commented out are restored. A sychronize_interrupts() call is
removed.
Fixes: 38506ecefab9 ("rtlwifi: rtl_pci: Start modification for new drivers")
Cc: Stable <stable@vger.kernel.org> # v3.18+
commit 3155db7613edea8fb943624062baf1e4f9cfbfd6 upstream.
new drivers"), a callback needed to check if the hardware has released
a buffer indicating that a DMA operation is completed was not added.
commit 0e531cc575c4e9e3dd52ad287b49d3c2dc74c810 upstream.
new drivers"), a callback to get the RX buffer address was added to
the PCI driver. Unfortunately, driver rtl8192de was not modified
appropriately and the code runs into a WARN_ONCE() call. The use
of an incorrect array is also fixed.
Cc: Stable <stable@vger.kernel.org> # 3.18+
commit 3e1740993e43116b3bc71b0aad1e6872f6ccf341 upstream.
Testing with the new fsstress support for subvolumes uncovered a pretty
bad problem with rename exchange on subvolumes. We're modifying two
different subvolumes, but we only start the transaction on one of them,
so the other one is not added to the dirty root list. This is caught by
btrfs_cow_block() with a warning because the root has not been updated,
however if we do not modify this root again we'll end up pointing at an
invalid root because the root item is never updated.
Fix this by making sure we add the destination root to the trans list,
the same as we do with normal renames. This fixes the corruption.
Fixes: cdd1fedf8261 ("btrfs: add support for RENAME_EXCHANGE and RENAME_WHITEOUT")
CC: stable@vger.kernel.org # 4.9+
Reviewed-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Josef Bacik <josef@toxicpanda.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit fd0ddbe2509568b00df364156f47561e9f469f15 upstream.
Backreference walking, which is used by send to figure if it can issue
clone operations instead of write operations, can be very slow and use
too much memory when extents have many references. This change simply
skips backreference walking when an extent has more than 64 references,
in which case we fallback to a write operation instead of a clone
operation. This limit is conservative and in practice I observed no
signicant slowdown with up to 100 references and still low memory usage
up to that limit.
This is a temporary workaround until there are speedups in the backref
walking code, and as such it does not attempt to add extra interfaces or
knobs to tweak the threshold.
Reported-by: Atemu <atemu.main@gmail.com>
Link: https://lore.kernel.org/linux-btrfs/CAE4GHgkvqVADtS4AzcQJxo0Q1jKQgKaW3JGp3SGdoinVo=C9eQ@mail.gmail.com/T/#me55dc0987f9cc2acaa54372ce0492c65782be3fa
CC: stable@vger.kernel.org # 4.4+
Reviewed-by: Qu Wenruo <wqu@suse.com>
Signed-off-by: Filipe Manana <fdmanana@suse.com>
commit 34b127aecd4fe8e6a3903e10f204a7b7ffddca22 upstream.
The last user of btrfs_bio::flags was removed in commit 326e1dbb5736
("block: remove management of bi_remaining when restoring original
bi_end_io"), remove it.
(Tagged for stable as the structure is heavily used and space savings
are desirable.)
Signed-off-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
write
commit a0e248bb502d5165b3314ac3819e888fdcdf7d9f upstream.
When doing a buffered write it's possible to leave the subv_writers
counter of the root, used for synchronization between buffered nocow
writers and snapshotting. This happens in an exceptional case like the
following:
1) We fail to allocate data space for the write, since there's not
enough available data space nor enough unallocated space for allocating
a new data block group;
2) Because of that failure, we try to go to NOCOW mode, which succeeds
and therefore we set the local variable 'only_release_metadata' to true
and set the root's sub_writers counter to 1 through the call to
btrfs_start_write_no_snapshotting() made by check_can_nocow();
3) The call to btrfs_copy_from_user() returns zero, which is very unlikely
to happen but not impossible;
4) No pages are copied because btrfs_copy_from_user() returned zero;
5) We call btrfs_end_write_no_snapshotting() which decrements the root's
subv_writers counter to 0;
6) We don't set 'only_release_metadata' back to 'false' because we do
it only if 'copied', the value returned by btrfs_copy_from_user(), is
greater than zero;
7) On the next iteration of the while loop, which processes the same
page range, we are now able to allocate data space for the write (we
got enough data space released in the meanwhile);
8) After this if we fail at btrfs_delalloc_reserve_metadata(), because
now there isn't enough free metadata space, or in some other place
further below (prepare_pages(), lock_and_cleanup_extent_if_need(),
btrfs_dirty_pages()), we break out of the while loop with
'only_release_metadata' having a value of 'true';
9) Because 'only_release_metadata' is 'true' we end up decrementing the
root's subv_writers counter to -1 (through a call to
btrfs_end_write_no_snapshotting()), and we also end up not releasing the
data space previously reserved through btrfs_check_data_free_space().
As a consequence the mechanism for synchronizing NOCOW buffered writes
with snapshotting gets broken.
Fix this by always setting 'only_release_metadata' to false at the start
of each iteration.
Fixes: 8257b2dc3c1a ("Btrfs: introduce btrfs_{start, end}_nocow_write() for each subvolume")
Fixes: 7ee9e4405f26 ("Btrfs: check if we can nocow if we don't have data space")
Reviewed-by: Josef Bacik <josef@toxicpanda.com>
commit baf320b9d531f1cfbf64c60dd155ff80a58b3796 upstream.
We hit the following warning while running down a different problem
[ 6197.175850] ------------[ cut here ]------------
[ 6197.185082] refcount_t: underflow; use-after-free.
[ 6197.194704] WARNING: CPU: 47 PID: 966 at lib/refcount.c:190 refcount_sub_and_test_checked+0x53/0x60
[ 6197.521792] Call Trace:
[ 6197.526687] __btrfs_release_delayed_node+0x76/0x1c0
[ 6197.536615] btrfs_kill_all_delayed_nodes+0xec/0x130
[ 6197.546532] ? __btrfs_btree_balance_dirty+0x60/0x60
[ 6197.556482] btrfs_clean_one_deleted_snapshot+0x71/0xd0
[ 6197.566910] cleaner_kthread+0xfa/0x120
[ 6197.574573] kthread+0x111/0x130
[ 6197.581022] ? kthread_create_on_node+0x60/0x60
[ 6197.590086] ret_from_fork+0x1f/0x30
[ 6197.597228] ---[ end trace 424bb7ae00509f56 ]---
This is because the free side drops the ref without the lock, and then
takes the lock if our refcount is 0. So you can have nodes on the tree
that have a refcount of 0. Fix this by zero'ing out that element in our
temporary array so we don't try to kill it again.
CC: stable@vger.kernel.org # 4.14+
Reviewed-by: Nikolay Borisov <nborisov@suse.com>
[ add comment ]
commit 3797136b626ad4b6582223660c041efdea8f26b2 upstream.
While testing 5.2 we ran into the following panic
[52238.017028] BUG: kernel NULL pointer dereference, address: 0000000000000001
[52238.105608] RIP: 0010:drop_buffers+0x3d/0x150
[52238.304051] Call Trace:
[52238.308958] try_to_free_buffers+0x15b/0x1b0
[52238.317503] shrink_page_list+0x1164/0x1780
[52238.325877] shrink_inactive_list+0x18f/0x3b0
[52238.334596] shrink_node_memcg+0x23e/0x7d0
[52238.342790] ? do_shrink_slab+0x4f/0x290
[52238.350648] shrink_node+0xce/0x4a0
[52238.357628] balance_pgdat+0x2c7/0x510
[52238.365135] kswapd+0x216/0x3e0
[52238.371425] ? wait_woken+0x80/0x80
[52238.378412] ? balance_pgdat+0x510/0x510
[52238.386265] kthread+0x111/0x130
[52238.392727] ? kthread_create_on_node+0x60/0x60
[52238.401782] ret_from_fork+0x1f/0x30
The page we were trying to drop had a page->private, but had no
page->mapping and so called drop_buffers, assuming that we had a
buffer_head on the page, and then panic'ed trying to deref 1, which is
our page->private for data pages.
This is happening because we're truncating the free space cache while
we're trying to load the free space cache. This isn't supposed to
happen, and I'll fix that in a followup patch. However we still
shouldn't allow those sort of mistakes to result in messing with pages
that do not belong to us. So add the page->mapping check to verify that
we still own this page after dropping and re-acquiring the page lock.
This page being unlocked as:
btrfs_readpage
extent_read_full_page
__extent_read_full_page
__do_readpage
if (!nr)
unlock_page <-- nr can be 0 only if submit_extent_page
returns an error
[ add callchain ]
commit 2d7b78f59e020b07fc6338eefe286f54ee2d6773 upstream.
Clear ep0's DWC3_EP_TRANSFER_STARTED flag if the END_TRANSFER command is
completed. Otherwise, we can't start control transfer again after
END_TRANSFER.
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
commit 63341ab03706e11a31e3dd8ccc0fbc9beaf723f0 upstream.
In case we have to migrate a ballon page to a newpage of another zone, the
managed page count of both zones is wrong. Paired with memory offlining
(which will adjust the managed page count), we can trigger kernel crashes
and all kinds of different symptoms.
One way to reproduce:
1. Start a QEMU guest with 4GB, no NUMA
2. Hotplug a 1GB DIMM and online the memory to ZONE_NORMAL
3. Inflate the balloon to 1GB
4. Unplug the DIMM (be quick, otherwise unmovable data ends up on it)
5. Observe /proc/zoneinfo
Node 0, zone Normal
pages free 16810
min 24848885473806
low 18471592959183339
high 36918337032892872
spanned 262144
present 262144
managed 18446744073709533486
6. Do anything that requires some memory (e.g., inflate the balloon some
more). The OOM goes crazy and the system crashes
[ 238.324946] Out of memory: Killed process 537 (login) total-vm:27584kB, anon-rss:860kB, file-rss:0kB, shmem-rss:00
[ 238.338585] systemd invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
[ 238.339420] CPU: 0 PID: 1 Comm: systemd Tainted: G D W 5.4.0-next-20191204+ #75
[ 238.340139] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.12.0-59-gc9ba5276e321-prebuilt.qemu4
[ 238.341121] Call Trace:
[ 238.341337] dump_stack+0x8f/0xd0
[ 238.341630] dump_header+0x61/0x5ea
[ 238.341942] oom_kill_process.cold+0xb/0x10
[ 238.342299] out_of_memory+0x24d/0x5a0
[ 238.342625] __alloc_pages_slowpath+0xd12/0x1020
[ 238.343024] __alloc_pages_nodemask+0x391/0x410
[ 238.343407] pagecache_get_page+0xc3/0x3a0
[ 238.343757] filemap_fault+0x804/0xc30
[ 238.344083] ? ext4_filemap_fault+0x28/0x42
[ 238.344444] ext4_filemap_fault+0x30/0x42
[ 238.344789] __do_fault+0x37/0x1a0
[ 238.345087] __handle_mm_fault+0x104d/0x1ab0
[ 238.345450] handle_mm_fault+0x169/0x360
[ 238.345790] do_user_addr_fault+0x20d/0x490
[ 238.346154] do_page_fault+0x31/0x210
[ 238.346468] async_page_fault+0x43/0x50
[ 238.346797] RIP: 0033:0x7f47eba4197e
[ 238.347110] Code: Bad RIP value.
[ 238.347387] RSP: 002b:00007ffd7c0c1890 EFLAGS: 00010293
[ 238.347834] RAX: 0000000000000002 RBX: 000055d196a20a20 RCX: 00007f47eba4197e
[ 238.348437] RDX: 0000000000000033 RSI: 00007ffd7c0c18c0 RDI: 0000000000000004
[ 238.349047] RBP: 00007ffd7c0c1c20 R08: 0000000000000000 R09: 0000000000000033
[ 238.349660] R10: 00000000ffffffff R11: 0000000000000293 R12: 0000000000000001
[ 238.350261] R13: ffffffffffffffff R14: 0000000000000000 R15: 00007ffd7c0c18c0
[ 238.350878] Mem-Info:
[ 238.351085] active_anon:3121 inactive_anon:51 isolated_anon:0
[ 238.351085] active_file:12 inactive_file:7 isolated_file:0
[ 238.351085] unevictable:0 dirty:0 writeback:0 unstable:0
[ 238.351085] slab_reclaimable:5565 slab_unreclaimable:10170
[ 238.351085] mapped:3 shmem:111 pagetables:155 bounce:0
[ 238.351085] free:720717 free_pcp:2 free_cma:0
[ 238.353757] Node 0 active_anon:12484kB inactive_anon:204kB active_file:48kB inactive_file:28kB unevictable:0kB iss
[ 238.355979] Node 0 DMA free:11556kB min:36kB low:48kB high:60kB reserved_highatomic:0KB active_anon:152kB inactivB
[ 238.358345] lowmem_reserve[]: 0 2955 2884 2884 2884
[ 238.358761] Node 0 DMA32 free:2677864kB min:7004kB low:10028kB high:13052kB reserved_highatomic:0KB active_anon:0B
[ 238.361202] lowmem_reserve[]: 0 0 72057594037927865 72057594037927865 72057594037927865
[ 238.361888] Node 0 Normal free:193448kB min:99395541895224kB low:73886371836733356kB high:147673348131571488kB reB
[ 238.364765] lowmem_reserve[]: 0 0 0 0 0
[ 238.365101] Node 0 DMA: 7*4kB (U) 5*8kB (UE) 6*16kB (UME) 2*32kB (UM) 1*64kB (U) 2*128kB (UE) 3*256kB (UME) 2*512B
[ 238.366379] Node 0 DMA32: 0*4kB 1*8kB (U) 2*16kB (UM) 2*32kB (UM) 2*64kB (UM) 1*128kB (U) 1*256kB (U) 1*512kB (U)B
[ 238.367654] Node 0 Normal: 1985*4kB (UME) 1321*8kB (UME) 844*16kB (UME) 524*32kB (UME) 300*64kB (UME) 138*128kB (B
[ 238.369184] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[ 238.369915] 130 total pagecache pages
[ 238.370241] 0 pages in swap cache
[ 238.370533] Swap cache stats: add 0, delete 0, find 0/0
[ 238.370981] Free swap = 0kB
[ 238.371239] Total swap = 0kB
[ 238.371488] 1048445 pages RAM
[ 238.371756] 0 pages HighMem/MovableOnly
[ 238.372090] 306992 pages reserved
[ 238.372376] 0 pages cma reserved
[ 238.372661] 0 pages hwpoisoned
In another instance (older kernel), I was able to observe this
(negative page count :/):
[ 180.896971] Offlined Pages 32768
[ 182.667462] Offlined Pages 32768
[ 184.408117] Offlined Pages 32768
[ 186.026321] Offlined Pages 32768
[ 187.684861] Offlined Pages 32768
[ 189.227013] Offlined Pages 32768
[ 190.830303] Offlined Pages 32768
[ 190.833071] Built 1 zonelists, mobility grouping on. Total pages: -36920272750453009
In another instance (older kernel), I was no longer able to start any
process:
[root@vm ~]# [ 214.348068] Offlined Pages 32768
[ 215.973009] Offlined Pages 32768
cat /proc/meminfo
-bash: fork: Cannot allocate memory
[root@vm ~]# cat /proc/meminfo
Fix it by properly adjusting the managed page count when migrating if
the zone changed. The managed page count of the zones now looks after
unplug of the DIMM (and after deflating the balloon) just like before
inflating the balloon (and plugging+onlining the DIMM).
We'll temporarily modify the totalram page count. If this ever becomes a
problem, we can fine tune by providing helpers that don't touch
the totalram pages (e.g., adjust_zone_managed_page_count()).
Please note that fixing up the managed page count is only necessary when
we adjusted the managed page count when inflating - only if we
don't have VIRTIO_BALLOON_F_DEFLATE_ON_OOM. With that feature, the
managed page count is not touched when inflating/deflating.
Reported-by: Yumei Huang <yuhuang@redhat.com>
Fixes: 3dcc0571cd64 ("mm: correctly update zone->managed_pages")
Cc: <stable@vger.kernel.org> # v3.11+
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Igor Mammedov <imammedo@redhat.com>
Cc: virtualization@lists.linux-foundation.org
Signed-off-by: David Hildenbrand <david@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 69c7f4618c16b4678f8a4949b6bb5ace259c0033 upstream.
Any write with either dd or flashcp to a device driven by the
spear_smi.c driver will pass through the spear_smi_cpy_toio()
function. This function will get called for chunks of up to 256 bytes.
If the amount of data is smaller, we may have a problem if the data
length is not 4-byte aligned. In this situation, the kernel panics
during the memcpy:
# dd if=/dev/urandom bs=1001 count=1 of=/dev/mtd6
spear_smi_cpy_toio [620] dest c9070000, src c7be8800, len 256
spear_smi_cpy_toio [620] dest c9070100, src c7be8900, len 256
spear_smi_cpy_toio [620] dest c9070200, src c7be8a00, len 256
spear_smi_cpy_toio [620] dest c9070300, src c7be8b00, len 233
Unhandled fault: external abort on non-linefetch (0x808) at 0xc90703e8
PC is at memcpy+0xcc/0x330
The above error occurs because the implementation of memcpy_toio()
tries to optimize the number of I/O by writing 4 bytes at a time as
much as possible, until there are less than 4 bytes left and then
switches to word or byte writes.
Unfortunately, the specification states about the Write Burst mode:
"the next AHB Write request should point to the next
incremented address and should have the same size (byte,
half-word or word)"
This means ARM architecture implementation of memcpy_toio() cannot
reliably be used blindly here. Workaround this situation by update the
write path to stick to byte access when the burst length is not
multiple of 4.
Fixes: f18dbbb1bfe0 ("mtd: ST SPEAr: Add SMI driver for serial NOR flash")
Cc: Russell King <linux@armlinux.org.uk>
Cc: Boris Brezillon <boris.brezillon@collabora.com>
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Russell King <rmk+kernel@armlinux.org.uk>
