Correct copy/past errors with UART2 pinfunctions.
This driver supports Toradex USB WiFi module LP816.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
pxp_soft_reset is writing to registers that are not clocked and then
resulting in a lockup. Interestingly I could only see this behaviour
when starting a kernel using kexec.
This could have something to do with how u-boot enables clocks on a
regular boot.
In this commit this gets fixed with enabling the clocks before doing
a pxp_soft_reset.
Improve module help messages and logging operations
in debug mode.
- Fix a probing to handle errors in scu notifier registration.
- Unregister scu notifier properly on unload, so it is possible to
load driver again.
1. Fix this compilation error:
/workdir/oe/tmp-glibc/work-shared/verdin-imx8mm/kernel-source/drivers/
rpmsg/virtio_rpmsg_bus.c:1106:23: error: redeclaration of 'newch'
with no linkage
struct rpmsg_device *newch;
rpmsg/virtio_rpmsg_bus.c:1101:23: note: previous declaration of
'newch' was here
2. Fix warnings that are reproduced when RPMsg char device support is
disabled.
Fixes: 1172ee2e ("rpmsg: virtio rpmsg: Add RPMsg char driver support")
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Ordering of stuff in lpspi probe was a little off.
- num_chipselect gets set with devm_spi_register_controller.
- devm_spi_register_controller needs data that gets set into
controller variable
Order stuff appropriate so num_chipselect gets set before it is used.
There is now a mainline variant for a regulator-fixed to be enabled
by a clock. Make use of this newly cherry-picked mainline feature.
This commit adds the possibility to choose the compatible
"regulator-fixed-clock" in devicetree.
This is a special regulator-fixed that has to have a clock, from which
the regulator gets switched on and off.
Link: https://lore.kernel.org/r/20190910062103.39641-2-philippe.schenker@toradex.com
Signed-off-by: Mark Brown <broonie@kernel.org>
(cherry picked from commit 8959e5324485ace9bedc33ce1e760b759d4dd2ac)
drivers/regulator/fixed.c
Toradex USB WiFi module LM816 uses RTL8188EUS wi-fi chip.
There is staging working driver in kernel for this chip.
Enabling it makes one able to use LM816 wifi usb dongle
"from the box" w/o installing additional software.
virtio rpmsg was not implemented to use RPMsg char driver.
Each virtio ns announcement will create a new RPMsg device which
is supposed to bound to a RPMsg driver. It doesn't support
dynamic endpoints with name service per RPMsg device.
With RPMsg char driver, you can have multiple endpoints per
RPMsg device.
Here is the change from this patch:
* Introduce a macro to indicate if want to use RPMsg char driver
for virtio RPMsg. The RPMsg device can either be bounded to
a simple RPMsg driver or the RPMsg char driver.
* Create Virtio RPMsg char device when the virtio RPMsg driver is
probed.
* when there is a remote service announced, keep it in the virtio
proc remote services list.
* when there is an endpoint created, bind it to a remote service
from the remote services list. If the service doesn't exist yet,
create one and mark the service address as ANY.
That patch ported to our 4.14 kernel + additional fixes added [1].
Example of usage from userspace app:
char data_buf [] = {'a', 'b', 'c', 'd', '\0'};
struct rpmsg_endpoint_info ept_info = {"rpmsg-openamp-demo-channel", 0x2, 0x1};
int fd = open("/dev/rpmsg_ctrl0", O_RDWR);
/* create endpoint interface */
ioctl(fd, RPMSG_CREATE_EPT_IOCTL, &ept_info);
/* create endpoint */
int fd_ept = open("/dev/rpmsg0", O_RDWR);
/* receive data from remote device */
read(fd_ept, &data_buf, sizeof(data_buf));
/* send data to remote device */
write(fd_ept, &data_buf, sizeof(data_buf));
/* destroy endpoint */
ioctl(fd_ept, RPMSG_DESTROY_EPT_IOCTL);
close(fd_ept);
close(fd);
[1] https://patchwork.kernel.org/patch/10145779/
Signed-off-by: Wendy Liang <jliang@xilinx.com>
Ixora board has several differences from the Apalis Evaluation one.
Some important differences are reflected in personalized device-tree files.
The simple-audio-card driver sets clk_id to a constant 0.
Assume that we want to derive the sysclk from the MCLK in that case rather
than error out with -EINVAL.
This patch adds the device tree to support Toradex Verdin iMX8M Mini a
computer on module which can be used on different carrier boards.
The module consists of an NXP i.MX 8M Mini family SoC, a Rohm BD71847
PMIC, a Gigabit Ethernet PHY, 2 GB of LPDDR4 RAM, an eMMC, an ADC, a
Secure Element, an EEPROM, an RTC, USB host and OTG ports, PCIe and
MIPI-CSI2/DSI interfaces plus optional Bluetooth/Wi-Fi module and CAN
controllers.
Anything that is not self-contained on the module is disabled by
default.
The device tree for the Verdin Development Board includes the module's
device tree and enables the supported peripherals of the carrier board
(the Verdin Development Board supports almost all of them).
Not yet tested:
- all UARTs other than console/debug Verdin UART_3
- push button controller on carrier board
- JTAG
- I2S to Wi-Fi
- I2S to DSI Mezzanine
Not yet working:
- carrier board audio
- MIPI-CSI2
- carrier board power gating
- FTDI control signals and JTAG
On Verdin iMX8MM ADC is provided by a MAX11607.
On Verdin iMX8MM Development board the CAN-FD controller Microchip
MCP2518FD is used.
Enable the driver which got backported from linux-can-next.git,
branch mcp25xxfd-rpi.
Remove firmware kobject uevent fallback mechanism and make imx_sdma
a module so it gets loaded when rootfs is mounted.
This prevents the error, that firmware can't be loaded from rootfs
On Verdin iMX8MM the Wi-Fi module is connected through SDIO.
Add this driver variant.
On Verdin iMX8MM Development board this codec is used.
The LDO have a Soft-Start feature. Add enable_time to all LDOs to
account for that.
Some CRTC drivers use and evaluate this information and if missing
print a warning.
| [ 248.956112] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector
This is at most an informational message.
This allows using this codec with the simple-sound-card driver.
This allows to have a clock on clko even if the controller is
disabled.
The current implementation uses the clko pin always as a clock out.
Implement the binding documentation and use the pin as a start of frame
indication when microchip,clock-out-div is set to 0.
Backport helper functions not available from the 4.14 kernel from 5.3.
If CONFIG_CAN_MCP25XXFD_DEBUG_FS is not defined but CONFIG_DEBUG_FS is
then the code fails to compile.
Fix this by conditionally compile on CONFIG_CAN_MCP25XXFD_DEBUG_FS.
CONFIG_CAN_MCP25XXFD_DEBUG_FS depends on CONFIG_DEBUG_FS, there is no
need to test for both.
Add device-tree bindings for Microcip CanFD Controller mcp2517fd
Changelog:
V1 -> V2: new more generic name based on feedback from microchip
cleanup of dt custom properties removing (most) gpio functions
V2 -> V3: added vendor-prefix for gpio-opendrain
s/_/-/
added gpio-controller
V3 -> V4: resend
added: Reviewed-by: Rob Herring <robh@kernel.org>
V7 -> V8: added support for mcp2518fd
added microchip,gpio0-xstandby
removed Reviewed-by because of changes
Signed-off-by: Martin Sperl <kernel@martin.sperl.org>
(cherry picked from commit ca3c427d353bafffa51d38da57e49f61ba16dbbf)
By masking the FIFO number in the MCP25XXFD_CAN_FLTCON macro, the
mcp25xxfd_can_fifo_clear() function doesn't clear the filters at all, as
the masking makes MCP25XXFD_CAN_FLTCON(32) equal MCP25XXFD_CAN_FLTCON(0).
| mcp25xxfd_can_fifo_clear_regs(cpriv, MCP25XXFD_CAN_FLTCON(0),
| MCP25XXFD_CAN_FLTCON(32));
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
(cherry picked from commit 265153724aa0339bae525d22511377380fa45af5)
The interrupt handler thread mcp25xxfd_can_int() will reschedule, if
"loops % reschedule_int_thread_after" equals 0. This is the case for the
initial loop.
Change the code to match what the module parameter suggests to do.
(cherry picked from commit d4f9db41f6db9c233dd8847171c82c7f2ba0ec2e)
The timestamp is an u32, so don't cap to upper 16 bit.
(cherry picked from commit 6546a196615cae17d1e4c52f5135b02469adc15f)
Put sbk into echo queue before triggering send.
(cherry picked from commit 2c1df7da765455d86f5630e050905aa3b599ed97)
push skb into networking stack in interrupt handler
Use netif_rx() instead of netif_receive_skb() to push skb into
networking stack from interrupt handler.
Reported-by: Tom Prohaszka <tprohaszka@capp-tech.com>
Tested-by: Tom Prohaszka <tprohaszka@capp-tech.com>
(cherry picked from commit 62f9531af8e7f470830d3d285b39570b361e6473)
The xmit callback is serialized by the network stack, no need for
locking.
(cherry picked from commit 8d59059d2098ef612fad460e0e9f832ec36d5fbd)
(cherry picked from commit 6f267fd90b21536d3dcb3b4549dbf800357cd944)
(cherry picked from commit 4dc124bd4f631ff0f83a43a2ae9bfafd664b0e34)
(cherry picked from commit 9781ee8b4dc9feb1809e864bbbbe0bd2001aed59)
(cherry picked from commit 6cf806f542afb974470f29324fcfa76539539c8b)
(cherry picked from commit d8a864d5eab58cfb0e4deb137359f80a828dc050)
(cherry picked from commit 5a142c75c22d38f7166e2e3ac8b08b3f834b61bc)
submit_queue_count
otherwise with switched off DEBUGFS support the driver will not work
anymore.
(cherry picked from commit 3d566db75ce8a954c0a4ad67b23d9069e7851175)
add comments
(cherry picked from commit bd0713e14f8665ffaff2f17f6e0ac0b7fcaef902)
(cherry picked from commit 252e80b4deb8cc90c723d64eac22b2ccdb699234)
... to match struct spi_transfer::len
(cherry picked from commit 39254b601f7f8b96772b2e5438f246b3222aa394)
