gen1_i2c comment
Split the pinctrl property for usdhc1 into a 4-bit SD interface
and an extension to 8-bit. This is required to support both 8-bit
and 4-bit interface on usdhc1 as per the carrier board.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
The SD1 pinctrl-0 property is overridden but only the card detect pin
is muxed, the control and data signals are not referenced at all.
It worked because the bootloader muxed them to a sensible state though.
Fix this.
Support proper system power-off, which disables main regulator. This
results in much lower power consumption and support of power-on issued
by button press.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
The CX9020 differs from i.MX53 Quick Start Board by:
- use uart2 instead of uart1
- DVI-D connector instead of VGA
- no audio
- no SATA connector
- CCAT FPGA connected to emi
- enable rtc
Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
UART2 on EIM_D26 - EIM_D29 pins supports interchanging RXD/TXD pins
and RTS/CTS pins.
One board using these alternate settings is Beckhoff CX9020. Add the
alternative configuration here, to make it available to others, too.
The i.MX53 has an integrated secure real time clock. Add it to the dtsi.
- add vendor prefix bhf for Beckhoff
- add new board binding bhf,cx9020
Acked-by: Rob Herring <robh@kernel.org>
Add a devicetree entry for the Random Number Generator Version B (RNGB).
The driver for RNGC supports version B as well.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00 is connected to the INT1 pin of
the FXLS8471Q accelerometer, so remove it from the unrelated ENET
group.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Add support for Flexcan.
The Colibri iMX7 modules come with 512MB on-module SLC NAND flash
populated. Make use of it by enabling the GPMI controller.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Han Xu <han.xu@nxp.com>
Add i.MX 7 APBH DMA and GPMI NAND modules.
Declared as a regulator since the driver doesn't have a reset-gpios
property for this.
This ensures that the PHY is woken up, not depending on the state the
second stage bootloader leaves the pin.
This is a workaround until a proper mechanism is provided to reset such
devices like the pwrseq library [1] for instance.
[1] https://lkml.org/lkml/2017/2/10/779
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
property for this.
gpio-line-names may help to make work with GPIOs from user space easier.
Following examples are provided with libgpiod
https://github.com/brgl/libgpiod :
|# Toggle a GPIO by name, then wait for the user to press ENTER.
|$ gpioset --mode=wait `gpiofind "USR-LED-2"`=1
|# Pause execution until a single event of any type occurs. Don't print
|# anything. Find the line by name.
|$ gpiomon --num-events=1 --silent `gpiofind "USR-IN"`
Used names was taken from RIoTboard schematics, version 1 (2013.12.07).
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
The Micrel PHY has its interrupt pin connected to a GPIO line. Wire
this up in the device tree.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Chris Healy <cphealy@gmail.com>
The Marvell switch has its interrupt pin connected to a GPIO
line. Wire this up in the device tree. This then allows us to use
interrupts from the embedded Ethernet PHYs in the switch. Also wire
them up in device tree.
The Marvell switch has an EEPROM connected to it. List the size in DT,
in order to enable access to it via ethtool.
The RDU2 has a Marvell 88E6352 switch. Both the FEC and the i210
Ethernet interfaces are connected to the switch. Make the FEC the DSA
"CPU" port, and the i210 as a regular port on the switch.
The FEC has a Micrel PHY connected to it. This PHY is managed using
the bit-banging MDIO bus. Add this to the device tree.
Currently the LCD is turned on thanks to the bootloader initialization.
In order to make the kernel to turn on the LCD on is own, pass the
'enable-gpios' and 'power-supply' properties.
Also, the GPIO1_IO01 is not used as PWM functionality on this board. It is
connected to the PWREN pin of connector J14 and has a GPIO function, so
remove the PWM1 node and change the GPIO1_IO01 IOMUX to GPIO function.
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
It is preferred to use the panel compatible string rather than passing the
LCD timming in the device tree.
So pass the "innolux,at043tn24" compatible string to describe the parallel
LCD on this board.
The 'uart-has-rtscts' property should be used when the board exposes the
native RTS and CTS UART pins.
On the imx6qdl-gw5xxx boards such pins are not used, so remove the
'uart-has-rtscts' property to make the hardware description correct.
Documentation/devicetree/bindings/serial/serial.txt states that
'uart-has-rtscts' and 'rts-gpios' properties are mutually exclusive.
Pass the 'backlight' property as described in
Documentation/devicetree/bindings/display/panel/simple-panel.txt
It is preferred to use the panel compatible string rather than passing the LCD
So pass the "innolux,at043tn24" compatible string to describe the parallel LCD
on this board.
Make the syscon-poweroff driver change only the shutdown bits on the
SNVS_LP control register.
This change fixes an issue with the RTC wakeup alarm, that was
previously disabled during power off.
Signed-off-by: Guy Shapiro <guy.shapiro@mobi-wize.com>
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
imx6qdl-icore-rqs boards use sgtl5000 codec and the machine
file (imx-sgtl5000) already sets SSI in slave mode and codec in
master mode, so there is no need for having this property.
Pass the phy-reset-gpios property so that Ethernet PHYs can go
through a proper reset.
The IPU that drives HDMI must have its pre_sel set to pll2_pfd_396m
to avoid stepping on the LVDS output's toes, as the PLL can't be clocked
to the pixel clock and to the LVDS serial clock (3.5*pixel clock) at the
same time.
As we are using ipu1_di0 and ipu2_di0, ensure both are switched to
to pll2_pfd2_396m to avoid issues. The LDB driver will switch the
required IPU to ldb_di1 when it uses it to drive LVDS.
Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
Signed-off-by: Romain Perier <romain.perier@collabora.com>
According to mx7sabresd schematics the MIPI CSI/DSI voltage rails
should be 2.8V but the voltage provided is a maximum of 3.3V and
minimum of 1.8V. Providing such a higher voltage might damage the
peripherals and violates the schematic settings.
Signed-off-by: Gautam Bhat <mindentropy@gmail.com>
Enables the ADV7180 analog video decoder sensor connected to the
IMX6 IPU on various Gateworks Ventana boards.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Add support for Sound card and related codec(via i2c1) nodes
on Engicam GEAM6UL variant module boards.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Engicam SOM's with mounted on starter kits like icorem6(rqs), isiot
usually not explicitly named with -kit in dts file names and
instead Model has mentioned 'Starter kit' So apply the same rule
for geam SOM as well.
GEAM6UL SOM does have single module, it doesn't come with
any variants. Maintaining imx6ul-geam.dtsi make no sense
so move all devices from .dtsi into dts file and drop the same.
usdhc1 is enabled and assigned pinctrl-0 on imx6ul-geam.dtsi
but same thing done on imx6ul-geam-kit.dts, so remove this
re-enabled node from the same.
Add support for fec1 node on Engicam Is.IoT variant boards.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
on Engicam Is.IoT MX6UL variant module boards.
Maintaining separate dtsi file with common nodes make unclear and
confusing since -isiot.dtsi is available for adding common nodes.
If the nodes are common between the dts files then mark status
as "okay" otherwise mark it "disabled" so-that respective dts
can mark status "okay"
Pull documentation format standardization from Jonathan Corbet:
"This series converts a number of top-level documents to the RST format
without incorporating them into the Sphinx tree. The hope is to bring
some uniformity to kernel documentation and, perhaps more importantly,
have our existing docs serve as an example of the desired formatting
for those that will be added later.
Mauro has gone through and fixed up a lot of top-level documentation
files to make them conform to the RST format, but without moving or
renaming them in any way. This will help when we incorporate the ones
we want to keep into the Sphinx doctree, but the real purpose is to
bring a bit of uniformity to our documentation and let the top-level
docs serve as examples for those writing new ones"
* tag 'standardize-docs' of git://git.lwn.net/linux: (84 commits)
docs: kprobes.txt: Fix whitespacing
tee.txt: standardize document format
cgroup-v2.txt: standardize document format
dell_rbu.txt: standardize document format
zorro.txt: standardize document format
xz.txt: standardize document format
xillybus.txt: standardize document format
vfio.txt: standardize document format
vfio-mediated-device.txt: standardize document format
unaligned-memory-access.txt: standardize document format
this_cpu_ops.txt: standardize document format
svga.txt: standardize document format
static-keys.txt: standardize document format
smsc_ece1099.txt: standardize document format
SM501.txt: standardize document format
siphash.txt: standardize document format
sgi-ioc4.txt: standardize document format
SAK.txt: standardize document format
rpmsg.txt: standardize document format
robust-futexes.txt: standardize document format
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull random updates from Ted Ts'o:
"Add wait_for_random_bytes() and get_random_*_wait() functions so that
callers can more safely get random bytes if they can block until the
CRNG is initialized.
Also print a warning if get_random_*() is called before the CRNG is
initialized. By default, only one single-line warning will be printed
per boot. If CONFIG_WARN_ALL_UNSEEDED_RANDOM is defined, then a
warning will be printed for each function which tries to get random
bytes before the CRNG is initialized. This can get spammy for certain
architecture types, so it is not enabled by default"
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random:
random: reorder READ_ONCE() in get_random_uXX
random: suppress spammy warnings about unseeded randomness
random: warn when kernel uses unseeded randomness
net/route: use get_random_int for random counter
net/neighbor: use get_random_u32 for 32-bit hash random
rhashtable: use get_random_u32 for hash_rnd
ceph: ensure RNG is seeded before using
iscsi: ensure RNG is seeded before use
cifs: use get_random_u32 for 32-bit lock random
random: add get_random_{bytes,u32,u64,int,long,once}_wait family
random: add wait_for_random_bytes() API
Pull ->s_options removal from Al Viro:
"Preparations for fsmount/fsopen stuff (coming next cycle). Everything
gets moved to explicit ->show_options(), killing ->s_options off +
some cosmetic bits around fs/namespace.c and friends. Basically, the
stuff needed to work with fsmount series with minimum of conflicts
with other work.
It's not strictly required for this merge window, but it would reduce
the PITA during the coming cycle, so it would be nice to have those
bits and pieces out of the way"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
isofs: Fix isofs_show_options()
VFS: Kill off s_options and helpers
orangefs: Implement show_options
9p: Implement show_options
isofs: Implement show_options
afs: Implement show_options
affs: Implement show_options
befs: Implement show_options
spufs: Implement show_options
bpf: Implement show_options
ramfs: Implement show_options
pstore: Implement show_options
omfs: Implement show_options
hugetlbfs: Implement show_options
VFS: Don't use save/replace_mount_options if not using generic_show_options
VFS: Provide empty name qstr
VFS: Make get_filesystem() return the affected filesystem
VFS: Clean up whitespace in fs/namespace.c and fs/super.c
Provide a function to create a NUL-terminated string from unterminated data
Pull more __copy_.._user elimination from Al Viro.
* 'work.__copy_to_user' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
drm_dp_aux_dev: switch to read_iter/write_iter
Pull uacess-unaligned removal from Al Viro:
"That stuff had just one user, and an exotic one, at that - binfmt_flat
on arm and m68k"
* 'work.uaccess-unaligned' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill {__,}{get,put}_user_unaligned()
binfmt_flat: flat_{get,put}_addr_from_rp() should be able to fail
Pull network field-by-field copy-in updates from Al Viro:
"This part of the misc compat queue was held back for review from
networking folks and since davem has jus ACKed those..."
* 'misc.compat' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
get_compat_bpf_fprog(): don't copyin field-by-field
get_compat_msghdr(): get rid of field-by-field copyin
copy_msghdr_from_user(): get rid of field-by-field copyin
Pull MIPS updates from Ralf Baechle:
"Boston platform support:
- Document DT bindings
- Add CLK driver for board clocks
CM:
- Avoid per-core locking with CM3 & higher
- WARN on attempt to lock invalid VP, not BUG
CPS:
- Select CONFIG_SYS_SUPPORTS_SCHED_SMT for MIPSr6
- Prevent multi-core with dcache aliasing
- Handle cores not powering down more gracefully
- Handle spurious VP starts more gracefully
DSP:
- Add lwx & lhx missaligned access support
eBPF:
- Add MIPS support along with many supporting change to add the
required infrastructure
Generic arch code:
- Misc sysmips MIPS_ATOMIC_SET fixes
- Drop duplicate HAVE_SYSCALL_TRACEPOINTS
- Negate error syscall return in trace
- Correct forced syscall errors
- Traced negative syscalls should return -ENOSYS
- Allow samples/bpf/tracex5 to access syscall arguments for sane
traces
- Cleanup from old Kconfig options in defconfigs
- Fix PREF instruction usage by memcpy for MIPS R6
- Fix various special cases in the FPU eulation
- Fix some special cases in MIPS16e2 support
- Fix MIPS I ISA /proc/cpuinfo reporting
- Sort MIPS Kconfig alphabetically
- Fix minimum alignment requirement of IRQ stack as required by
ABI / GCC
- Fix special cases in the module loader
- Perform post-DMA cache flushes on systems with MAARs
- Probe the I6500 CPU
- Cleanup cmpxchg and add support for 1 and 2 byte operations
- Use queued read/write locks (qrwlock)
- Use queued spinlocks (qspinlock)
- Add CPU shared FTLB feature detection
- Handle tlbex-tlbp race condition
- Allow storing pgd in C0_CONTEXT for MIPSr6
- Use current_cpu_type() in m4kc_tlbp_war()
- Support Boston in the generic kernel
Generic platform:
- yamon-dt: Pull YAMON DT shim code out of SEAD-3 board
- yamon-dt: Support > 256MB of RAM
- yamon-dt: Use serial* rather than uart* aliases
- Abstract FDT fixup application
- Set RTC_ALWAYS_BCD to 0
- Add a MAINTAINERS entry
core kernel:
- qspinlock.c: include linux/prefetch.h
Loongson 3:
- Add support
Perf:
- Add I6500 support
SEAD-3:
- Remove GIC timer from DT
- Set interrupt-parent per-device, not at root node
- Fix GIC interrupt specifiers
SMP:
- Skip IPI setup if we only have a single CPU
VDSO:
- Make comment match reality
- Improvements to time code in VDSO"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (86 commits)
locking/qspinlock: Include linux/prefetch.h
MIPS: Fix MIPS I ISA /proc/cpuinfo reporting
MIPS: Fix minimum alignment requirement of IRQ stack
MIPS: generic: Support MIPS Boston development boards
MIPS: DTS: img: Don't attempt to build-in all .dtb files
clk: boston: Add a driver for MIPS Boston board clocks
dt-bindings: Document img,boston-clock binding
MIPS: Traced negative syscalls should return -ENOSYS
MIPS: Correct forced syscall errors
MIPS: Negate error syscall return in trace
MIPS: Drop duplicate HAVE_SYSCALL_TRACEPOINTS select
MIPS16e2: Provide feature overrides for non-MIPS16 systems
MIPS: MIPS16e2: Report ASE presence in /proc/cpuinfo
MIPS: MIPS16e2: Subdecode extended LWSP/SWSP instructions
MIPS: MIPS16e2: Identify ASE presence
MIPS: VDSO: Fix a mismatch between comment and preprocessor constant
MIPS: VDSO: Add implementation of gettimeofday() fallback
MIPS: VDSO: Add implementation of clock_gettime() fallback
MIPS: VDSO: Fix conversions in do_monotonic()/do_monotonic_coarse()
MIPS: Use current_cpu_type() in m4kc_tlbp_war()
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml
Pull UML updates from Richard Weinberger:
"Mostly fixes for UML:
- First round of fixes for PTRACE_GETRESET/SETREGSET
- A printf vs printk cleanup
- Minor improvements"
* 'for-linus-4.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml:
um: Correctly check for PTRACE_GETRESET/SETREGSET
um: v2: Use generic NOTES macro
um: Add kerneldoc for userspace_tramp() and start_userspace()
um: Add kerneldoc for segv_handler
um: stub-data.h: remove superfluous include
um: userspace - be more verbose in ptrace set regs error
um: add dummy ioremap and iounmap functions
um: Allow building and running on older hosts
um: Avoid longjmp/setjmp symbol clashes with libpthread.a
um: console: Ignore console= option
um: Use os_warn to print out pre-boot warning/error messages
um: Add os_warn() for pre-boot warning/error messages
um: Use os_info for the messages on normal path
um: Add os_info() for pre-boot information messages
um: Use printk instead of printf in make_uml_dir
Pull UBIFS updates from Richard Weinberger:
- Updates and fixes for the file encryption mode
- Random fixes
* tag 'upstream-4.13-rc1' of git://git.infradead.org/linux-ubifs:
ubifs: Set double hash cookie also for RENAME_EXCHANGE
ubifs: Massage assert in ubifs_xattr_set() wrt. init_xattrs
ubifs: Don't leak kernel memory to the MTD
ubifs: Change gfp flags in page allocation for bulk read
ubifs: Fix oops when remounting with no_bulk_read.
ubifs: Fail commit if TNC is obviously inconsistent
ubifs: allow userspace to map mounts to volumes
ubifs: Wire-up statx() support
ubifs: Remove dead code from ubifs_get_link()
ubifs: Massage debug prints wrt. fscrypt
ubifs: Add assert to dent_key_init()
ubifs: Fix unlink code wrt. double hash lookups
ubifs: Fix data node size for truncating uncompressed nodes
ubifs: Don't encrypt special files on creation
ubifs: Fix memory leak in RENAME_WHITEOUT error path in do_rename
ubifs: Fix inode data budget in ubifs_mknod
ubifs: Correctly evict xattr inodes
ubifs: Unexport ubifs_inode_slab
ubifs: don't bother checking for encryption key in ->mmap()
ubifs: require key for truncate(2) of encrypted file
