This commit adds the touchscreens from Toradex so one can enable it.
- fix the name of pinctrl set for i2c2 recovery mode;
- add recovery mode for applicable i2c buses for
Apalis/Colibri iMX6Q/D/DL modules.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Related to: #49059
(cherry picked from commit 1501883b4682178e38afc3f08b221f9477fcd7ae)
This patch prepares the devicetree for the new Ixora V1.2 where we are
able to turn off the supply of the can transceiver. This implies to use
a sleep state on transmission pins in order to prevent backfeeding.
(cherry picked from commit c1016f5da0dbb8291575949e7f4a417c6306d70a)
Provide proper configuration for VGEN3, to make sure it's is always powered
which allows that rail to be automatically switched to 1.8 volts
for proper UHS-I operation. By default it's disabled.
With UHS-I enabled:
[ 104.153898] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 104.166202] mmcblk1: mmc1:59b4 USD00 15.0 GiB
[ 104.173923] mmcblk1: p1
root@colibri-imx6:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: 226 MB in 3.01 seconds = 75.01 MB/sec
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry-picked from 7ffa92d64cc7a6331faaae3e2507458461ab90f3)
Add the phy-node and mdio bus to the fec-node, represented as is on
hardware.
This commit includes micrel,led-mode that is set to the default
value, prepared for someone who wants to change this.
(cherry-picked from 03ff3610434d89fc8e20b280e1219ce0ebb08935)
This adds the muxing for the optional pins usb-oc (overcurrent) and
usb-id.
(cherry picked from commit d1c393ddcb6937b58fa3a9314c8b6f2382b346dc)
(cherry picked from commit a9dc775e6796488a3de676e1736d88560d181138)
Reduce the current drawn from VCC_BATT when the main power on the 3V3 pins
to the module are switched off.
This switches off SoC internal pull resistors which are provided on the module
for TAMPER7 and TAMPER9 SoC pin and switches on a pull down instead of a pullup
for the USBC_DET module pin (TAMPER2).
(cherry picked from commit 9fd59b6eebd12106b5b53fc56466bcd89b9a7ee9)
arch/arm/boot/dts/imx6ull-colibri.dtsi
This patch adds the watchdog to the imx6ull-colibri devicetree
Add the pinmuxing and a inactive node for flexcan1 on SODIMM 55/63
and move the inactive flexcan modes to imx6ull-colibri-eval-v3.dtsi
where they belong.
Note that this commit does not enable flexcan functionality, but rather
eases the effort needed to do so.
(cherry picked from commit 983ff8a6b61e9466beb6b4781fb370a6a7da937a)
arch/arm/boot/dts/imx6ull-colibri-nonwifi.dtsi
arch/arm/boot/dts/imx6ull-colibri-wifi.dtsi
(cherry picked from commit a6f40c3a1d659467267a9d16355c788524bc5ca7)
Switch on 22 kOhm pull ups and lower the I2C frequency to around 40kHz
to get a more reliable communication.
All PWM clock instances have their clock gate. Add these consistently.
Fixes freezing the kernel when one of these instances is used with
IMX6UL_CLK_DUMMY as its clock source.
(cherry picked from commit cd5d7ba49df7918732915a31bfc0f72827bebc2c)
(cherry picked from commit c6306e84601b15ee0152625757aab942fa2f2d28)
The file uses linux,keycode = <KEY_POWER>;, so include
the header which defines KEY_POWER.
(cherry picked from commit 479e0bae1ddfe3ec527634c241fadae558966323)
(cherry picked from commit b8a957b9613a597123f2eb6cd562191362fb153d)
Update #pwm-cells to 3 in order to support PWM signal polarity
control.
(cherry picked from commit 6863695b931ae31fe20171e75cf8a57c990873be)
(cherry picked from commit 3465c49c05258f88ad0584bac8cc6e30d9d1d3a8)
Pass the memory unit-adress to fix the following build warnings with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
There are cases where dts passes an empty memory node, which will be filled
by the bootloader. Passing the memory base address still allows the
bootloader to fill the memory size.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
(cherry picked from commit edc05819786fd5eee330b89bd5892dad1199effc)
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
arch/arm/boot/dts/imx6dl-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6dl-ts4900.dts
arch/arm/boot/dts/imx6dl-ts7970.dts
arch/arm/boot/dts/imx6q-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6q-h100.dts
arch/arm/boot/dts/imx6q-novena.dts
arch/arm/boot/dts/imx6q-ts4900.dts
arch/arm/boot/dts/imx6q-ts7970.dts
arch/arm/boot/dts/imx6q-zii-rdu2.dts
arch/arm/boot/dts/imx6qdl-apalis.dtsi
arch/arm/boot/dts/imx6qdl-cubox-i.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard2.dtsi
arch/arm/boot/dts/imx6qp-zii-rdu2.dts
arch/arm/boot/dts/imx6ul-tx6ul.dtsi
Boards based on imx6ul have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx6ul.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
(cherry picked from commit 750d8df6e7b269b828f66631a1d39ea027afc92a)
This vin-supply statement is not needed as the linked regulator
®_DCDC3 is anyway marked as always-on.
This is needed because NXP's code of GPCV2 can't handle deferred
probing.
As it is anyway default in downstream.
In this commit the mdio bus with the respective phy is added, so
one is able to make changes to that easier.
This is as well neede for 4.14
Enable gpmi part nessesary for Colibri iMX7 Dual 1GB (eMMC).
The iMX7 is supporting UHS-I but as those pins are shared
a define is needed to let the user decide if he wants UHS-I.
Add atmel mxt multitouch controller driver which is interfaced over
I2C bus. Add TouchRevolution multitouch controller driver which is
connectable over I2C bus.
This patch adds spigpios group to pinmux. This is needed by Aster
devicetrees that will be added later on.
Add new gpio hog group for atmel mxt ts GPIOs.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
(cherry picked from commit e747c0e955869e5cb6d9ea4da9477895901dbc92)
(cherry picked from commit 27e488ab4f471002a4549ea47551d08f62bbb698)
The SNVS subnodes reenable the power key which is not used on the
Colibri iMX7 modules. Disable the power key again.
Also make sure that the priority of the RTCs used is defined.
(cherry picked from commit 41ef3fad976e68175d9b087b1d072aac7183a906)
The keypad port (KPP) module is clocked by the IPG root clock
through clock gate CCM_CCGR170.
(cherry picked from commit 7b51b6365ebcf65b1054337a5bb0e1879397aae6)
(cherry picked from commit 09c36fb13aa73bac59709c5805f5f9f9e45acee9)
include/dt-bindings/clock/imx7d-clock.h
This reverts commit 511eacb77e74e9a23546b3afb0d2b2208eb4621c.
(cherry picked from commit ae8f31f4a7d78c8ff792cf2cf549b540f19488dc)
Merge changes from Toradex Linux 4.9 BSP.
Add pinmuxing and do not specify voltage restrictions in the
module level device tree.
(cherry picked from commit d4f875d9f8319ae9157702d5232f8b0b91444105)
Add wakeup GPIO key which is able to wake the system from sleep
modes (e.g. Suspend-to-Memory).
Colibri iMX7 module.
(cherry picked from commit 01c0bda6912c37456b3df34a7cf30300100ffbad)
arch/arm/boot/dts/imx7-colibri.dtsi
Add sleep pinmux to the fec so it can properly sleep.
Prepare FlexCAN use on SODIMM 55/63 178/188. Those SODIMM pins are
compatible for CAN bus use with several modules from the Colibri
family.
Add Better drivestrength and also add flexcan2.
This is a squashed commit from:
(cherry picked from commit 5562bcc82fd50633199a6627c11ec9d41833ed4e
and commit 491a63f465e45eda40336d3e75538668a44e166e)
Force HS200 by masking bit 63 of the SDHCI capability register.
The i.MX ESDHC driver uses SDHCI_QUIRK2_CAPS_BIT63_FOR_HS400. With
that the stack checks bit 63 to descide whether HS400 is available.
Using sdhci-caps-mask allows to mask bit 63. The stack then selects
HS200 as operating mode.
This prevents rare communication errors with minimal effect on
performance:
sdhci-esdhc-imx 30b60000.usdhc: warning! HS400 strobe DLL status REF not lock!
(cherry picked from commit cf7097961efb6c93945b940065375ede1e03b254)
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
(cherry picked from commit c81fc92fa8852d4dcc607b6771463471607d0942)
Add the stmpe-adc DT node as found on Toradex iMX6 modules
Reviewed-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit a822029a0cc0b838bff043482629f5fb9c2deb32)
A valid WEIM range configuration must specify range entries for
all four chip selects. This fixes an error on boot:
imx-weim: probe of 21b8000.weim failed with error -22
Signed-off-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit 063182a4c85673c735508dc01dd07fffbe7defb1)
Since commit d2d0ad2aec4a ("i2c: imx: use open drain for recovery
GPIO") GPIO lib expects this GPIO to be configured as open drain.
Make sure we define this GPIO as open drain in the device tree.
This gets rid of the following warning:
gpio-81 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Note that currently the i.MX pinctrl driver does not support
enabling open drain directly, so this patch has no effect in
practice. Open drain is enabled by the fixed pinmux entry.
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
(cherry picked from commit d2b91ab1480618885fe0a7f240b7e7710344a066)
Boards based on imx7 have duplicate memory nodes:
- One coming from the imx7s.dtsi file.
(cherry picked from commit 29988e867cb17de7119e971f9acfad2c3fccdb47)
arch/arm/boot/dts/imx7d-cl-som-imx7.dts
arch/arm/boot/dts/imx7d-colibri-emmc.dtsi
arch/arm/boot/dts/imx7d-colibri.dtsi
arch/arm/boot/dts/imx7d-nitrogen7.dts
arch/arm/boot/dts/imx7d-pico.dtsi
arch/arm/boot/dts/imx7d-sdb.dts
arch/arm/boot/dts/imx7s-colibri.dtsi
arch/arm/boot/dts/imx7s-warp.dts
arch/arm/boot/dts/imx7s.dtsi
The pinctrl properties on the IOMUXC node get overwritten by the
carrier board level device tree, hence the pinctrl_reset_moci
pinctrl does not get applied.
Associate the pinctrl_reset_moci pinctrl with the PCIe node where
we also make use of the pin as a reset GPIO.
Since the pin is muxed as a GPIO by default not muxing it explicitly
worked fine in practise.
(cherry picked from commit 78f10734f95873c22255f536e894c704bb5e8fa2)
100/200MHz states for USDHC3 are not required since the SoC
does not support modes faster than DDR52 for the on board eMMC.
(cherry picked from commit b074f057ac60d32f604e0ca3120064e688e9a622)
VDDD is connected to VGEN4 of the PF0100. This rail should only
run at 1.8V since there are multiple consumer and they all
expect the rail to be at 1.8V.
(cherry picked from commit 330f85598e87497974431c0f6f736e413ccf2d27)
Remove the 2.5V regulator, it does not exist. There is 3.3V and
3.3V_AUDIO provided to the module through the edge connector,
model those as fixed regulators like we use to do in other
Colibri device trees. The SGTL5000 uses 3.3V_AUDIO as VDDA. Note
that the driver derives the analog ground voltage (VAG) from this
supply. The new value should allow higher output swings before
clipping occurs. Refer to the SGTL5000 datasheet for details.
(cherry picked from commit 7060066d3e9920a4d96e106243e544c14ba0fd79)
