brcmfamc driver attach mmc func devices only when func1 device's
node exist, and whose compatible string match "brcm,bcm4329-fmac".
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit: b9945d63c2b8a6c1c9b018869eb2479781501608)
The dts file for WIFI support on i.MX6ULZ Lite is missed, so add it.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Add btwifi dts support for i.MX6ULZ Lite.
for i.MX6ULZ Lite, there is no dedicated SOC id for it,
so add a dummy ID and identify it by checking the MARK
bit in fuse.
The 'nand_usdhc_bus' clock is only need to be enabled when usdhc
or nand module is active, so change it to non-critical clock type.
(cherry picked from commit 32caf053fc38697bd418ef95bb3ff9962f6b7019)
The i.MX6ULZ Lite is full compatible with i.MX6ULL/ULZ, and
only support 9x9 package.
CL_MEM_USE_HOST_PHYSICAL_ADDR_VIV
CL_MEM_USE_HOST_PHYSICAL_ADDR_VIV will use host physical memory directly, logical address is zero.
gckOS_UnlockPages will check Logical address and return invalid parameter,
that causes memory leak in OpenCL user library, need remove this check.
Signed-off-by: Xianzhong <xianzhong.li@nxp.com>
(cherry picked from commit 85a7c0f80d4f44d990f9ba85ecf2b6baea06053c)
(cherry picked from commit d3f9bbb64cc198f06a92676eb536a7b4c0f08eeb)
The issue is GPU will crash when do dsp suspend test, and only
meet this issue when load GPU as module.
The reason is that dsp framework's global data set size little
than actul size. So dsp will touch the memory that not owned
dsp, then caused GPU crash.
Signed-off-by: Zhang Peng <peng.zhang_8@nxp.com>
(cherry picked from commit 1a17334e714037f8424e5f1df5cbcd06f6e79294)
- Refine the PCIe clocks for iMX8DX and iMX8QXP.
- Correct the HSIO power domain name on iMX8QXP, otherwise, the
peripheral clocks wouldn't be enabled.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Reviewed-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit a2c09691aeafc818c287f25d69e53b6411d4ef26)
Only one group voltage support on L4.14 so that the below two patches for
dts are not enough since 1.8V/0.8V not support by pmic driver:
commit 1c923bdd27021b011358f9422a6a18cbf30de491
("MLK-23275-2: ARM64: dts: freescale: fsl-imx8mn-ddr4-evk: correct ldo1/ldo2 voltage")
commit 8574922dd583141a332be58fe1656ee05c9e5dd4
("MLK-23275-1: ARM64: dts: freescale: fsl-imx8mm-evk: correct ldo1/ldo2 voltage")
So change ldo1/ldo2 voltage to 1.6V~1.9V/0.8V per i.mx8mm/i.mx8mn for quick
fix. For the kernel from L4.19, no need this patch.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
(cherry picked from commit 4166421be644aea1c7add0f786c859c4b81f6923)
voltage
Correct ldo1/ldo2 voltage as below:
ldo1 --NVCC_SNVS_1V8
ldo2 --VDD_SNVS_0V8
(cherry picked from commit d11796134f55d88b49d79bf25d6c42b677ff47bc)
(cherry picked from commit 1c923bdd27021b011358f9422a6a18cbf30de491)
ldo2 --VDD_SNVS_0V8
(cherry picked from commit 6e1db954c1261c9a8a40f7c4e33f03173c4d05b6)
(cherry picked from commit 8574922dd583141a332be58fe1656ee05c9e5dd4)
memory
Need flush outer cache after zero CMA allocated memory on arm32 platform.
Change-Id: Ieaa7c62bf65e4490f904d68bed1fa16fb7c5d8fa
Signed-off-by: Richard Liu <xuegang.liu@nxp.com>
Reviewed-by: Bing Song <bing.song@nxp.com>
(cherry picked from commit 9e51da339eb290f35eb79d9acc0ea147d8bdf0cf)
ION CMA memory default is cacheable, need flush cache after memset(),
else cache and physical memory not sync may cause problem.
Issue case:
VPU Video playback or GPU render have dirty line issue.
Root cause:
ION CMA allocate cacheable buffer and do memset(), some data still in cache
not in physical memory, VPU or GPU write the buffer with physical address,
or user call ion_mmap() to map the buffer through pgprot_writecombine() as
no-cache and write the buffer, later some CPU cache access trigger cache
flush, previous memset() data go to physical memory as dirty data.
Change-Id: I82b4cb61bbe6cffc687d452f9f81c1e35914d2f1
(cherry picked from commit 5d360f25f3523311b5f478b7b1c7bc9020cfda58)
kfifo memory size must roundup to power-of-two if it is
allocated by driver. Because kfifo elements size will
roundup to power-of-two in kfifo_init(), must guarantee
allocated memory is enough.
Signed-off-by: Shijie Qin <shijie.qin@nxp.com>
Reviewed-by: ming_qian <ming.qian@nxp.com>
(cherry picked from commit c900bb4cd98efc43dddfb18d96c8af358e804481)
This is a temporary workround for the case when:
-SWIOTLB is used for DMA bounce buffering AND
-data to be DMA-ed is mapped DMA_FROM_DEVICE and device only partially
overwrites the "original" data AND
-it's expected that the "original" data that was not overwritten
by the device to be untouched
As discussed in upstream, the proper fix should be:
-either an extension of the DMA API OR
-a workaround in the device driver (considering these cases are rarely
met in practice)
Since both alternatives are not trivial (to say the least),
add a workaround for the few cases matching the error conditions
listed above.
Link: https://lore.kernel.org/lkml/VI1PR0402MB348537CB86926B3E6D1DBE0A98070@VI1PR0402MB3485.eurprd04.prod.outlook.com/
Link: https://lore.kernel.org/lkml/20190522072018.10660-1-horia.geanta@nxp.com/
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
Reviewed-by: Valentin Ciocoi Radulescu <valentin.ciocoi@nxp.com>
Reviewed-by: Iuliana Prodan <iuliana.prodan@nxp.com>
The incorrect traversal of the scatterlist, during the linearization phase
lead to computing the hash value of the wrong input buffer.
New implementation uses scatterwalk_map_and_copy()
to address this issue.
Fixes: 15b59e7c3733 ("crypto: mxs - Add Freescale MXS DCP driver")
Signed-off-by: Rosioru Dragos <dragos.rosioru@nxp.com>
Acked-by: Horia Geantă <horia.geanta@nxp.com>
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Based on imx_4.1x kernel, enable the PCIEB on i.MX8QM MEK baseboard.
Regarding to the base board HW limitation(two Disable#) are not
connected. Only the standard PCIe EP device is supported on PCIEB port.
(cherry picked from commit d0331d84e5a14d6e2520d04540d1e893d75bd678)
Suggest to use vmalloc for fifo entity.
Then use kfifo_init to init the fifo structure.
Then we do not have to require contiguous memory from buddy,
especially in a high pressure of memory resource.
Signed-off-by: Ming Qian <ming.qian@nxp.com>
(cherry picked from commit 0cd3c661b95ecb273da5ee76fe7353ab7abd38c9)
In caam_hash_state struct, caam_ctx buffer needs to have a
separate cacheline, not sharing it with "update" callback.
On imx8, the cacheline size is 64 and the MAX_CTX_LEN,
from caam_ctx buffer, is (8 + 64).
Therefore, add a ____cacheline_aligned to the update callback,
in caam_hash_state struct, to ensure that caam_ctx buffer is
not sharing the cacheline.
Signed-off-by: Iuliana Prodan <iuliana.prodan@nxp.com>
Reviewed-by: Horia Geantă <horia.geanta@nxp.com>
To avoid potential dump when access the HSIO CRR registers during
PCIE initialization.
Add the PHY_PER and MISC clocks for both PCI controllers.
PCIEB has one more PER clock, since the PCIEA CSR register would be
configuired when PCIEB is initialized.
Enable the clocks before CRR registers manipulations.
Different usecase maybe used by customer, add the PCIEA two lanes and
PCIEB one lane usecase into fsl-imx8qm-pcieax2pciebx1.dts.
Refine the PCIE dts nodes, add the requrired HSIO peripheral clocks for
different consumers.
To avoid potential dump when access the PHY and MISC CRR registers.
Add the CRRS clocks into SATA driver.
The codes are merged back from 4.19 to 4.14 refer to MLK-21695.
Add the CRRS clocks into SATA node.
Add the documentation for the peripheral clocks required by iMX8QM SATA
to access the HSIO MIX regions.
According to latest datasheet Rev.0.1, 03/2020, VDD_ARM does
NOT have dependency on VDD_SOC, so below table in datasheet
can be used directly for VDD_ARM:
Clock Voltage
1.2GHz 0.85V
1.4GHz 0.95V
1.5GHz 1.0V
For DDR4 EVK board, system runs at nominal mode, so GPU can
ONLY run up to 400MHz.
For LPDDR4 EVK board, system runs at over-drive mode, so GPU
can run up to 600MHz.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
(cherry picked from commit e619dfe015d96f9322b59f386e00167ec1aab321)
system
In caam_jr_enqueue, under heavy DDR load, smp_wmb() or dma_wmb()
fail to make the input ring be updated before the CAAM starts
reading it. So, CAAM will process, again, an old descriptor address
and will put it in the output ring. This will make caam_jr_dequeue()
to fail, since this old descriptor is not in the software ring.
To fix this, use wmb() which works on the full system instead of
inner/outer shareable domains.
(cherry picked from commit e4978516eeacb083412753dbc523de7d9dca8463)
It looks like this also fixes MLK-23259, so cherry-pick
from LF linux-lts-nxp:lf-5.4.y into linux-imx:imx_4.14.y.
When running at OD mode, VDD_ARM can NOT be lower than VDD_SOC,
overwrite the 1.2GHz OPP's voltage to be same as VDD_SOC.
(cherry picked from commit 77714128a1da83fbc516b41206574e2e62348dc8)
This patch adds JDI WUXGA LVDS panel support on the i.MX8DX MEK platform.
The JDI WUXGA LVDS panel works in LDB split mode.
fsl-imx8dx-mek-jdi-wuxga-lvds0-panel.dts uses LDB1 channel0 as the
channel to transmit odd pixels and LDB2 channel0 as the channel to
transmit even pixels. fsl-imx8dx-mek-jdi-wuxga-lvds1-panel.dts swaps
the channels to transmit odd/even pixels.
Signed-off-by: Liu Ying <victor.liu@nxp.com>
(cherry picked from commit 31c6c62eff01b3288828f2e1b9ecf6ad9204b3c6)
support
This patch adds IT6263 LVDS to HDMI transmitter dual channel support.
The transmitter works with LDB split mode.
fsl-imx8dx-mek-it6263-lvds0-dual-channel.dts uses LDB1 channel0 as the
transmit even pixels. fsl-imx8dx-mek-it6263-lvds1-dual-channel.dts
swaps the channels to transmit odd/even pixels.
(cherry picked from commit 7cd2417af24b8f54d0b91f9b655211db79f63abb)
Create the fsl-imx8dx-mek-dsi-rm67191.dts in order to add support for
the MIPI-DSI panel usecase with the Raydium RM67191 DSI panel.
Signed-off-by: Robert Chiras <robert.chiras@nxp.com>
Add tja1100 card support for enet2 port.
Reviewed-by: Ye Li <ye.li@nxp.com>
Add ov5640 dts support for i.MX8DX MEK board
Signed-off-by: Guoniu.zhou <guoniu.zhou@nxp.com>
SATA driver write to regisers in the PCIE_A power domain and
hence PCIE_A needs to be powered on even when ONLY SATA is enabled.
Signed-off-by: Ranjani Vaidyanathan <ranjani.vaidyanathan@nxp.com>
Fix the parent-child power domain dependency to handle different
PCIE usecases.
Fix PCIE LPCG clock power domains.
The power domain driver should ensure all the child power domains
are powered off before powering down the parent.
The 8DX MEK only has 1GB DDR, update GPU memory as below:
- set GPU MMU mapping size to 1GB (0x80000000-0xC0000000)
- set GPU reserve size to 128MB
(cherry picked from commit 30efecdc1cef0fcff82f5cebd9823c61fee17e74)
Malone decoder used bits of fuse are 14-15 bits
(cherry picked from commit 8d34c1d1ce31048316da88448f8eecbed885fc44)
There is no Type-C ss mux chip on imx8dx mek, so delete the related
GPIOs. The rpmsg dts file fsl-imx8x-mek-rpmsg.dtsi includes another
phandle typec_ptn5110 for rpmsg i2c, we need this change to delete
it again.
Reviewed-by: Jun Li <jun.li@nxp.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
GPIOs.
In order to avoid garbage data left in RTRAM after disabling CRTC,
the SoC designer suggests us to disable DPRC repeat_en after FrameGen
FGEN is cleared and before ENSTS is cleared. Also, it is suggested
that FGEN clearing should be done in the frame prior to DPRC repeat_en
disablement. So, syncing to FrameGen frame counter moving is needed.
The disablement procedure should be done as soon as possible, so we
disable local irq and preemption during the procedure to ensure this.
Reviewed-by: Sandor Yu <Sandor.yu@nxp.com>
(cherry picked from commit ac84ef51ed68ce0ff9e7a3b5f5878ce0f788bb31)
(cherry picked from commit dd0dd77bf3231efb2979b0bbe86d5c99cc892d5f)
moving
In the coming patch, we would wait for FrameGen counter moving in
->atomic_disable() to get synchronization before disabling DPRC
repeat_en. It appears that waiting for 50ms for video mode
1920x1080@24Hz is not enough in this case and increasing timeout
to 100ms looks ok.
(cherry picked from commit 97ba7831a140f85666306606176004e3634b384c)
(cherry picked from commit 0f3a9e7dd10cd152866e32e855e8b9c0f6846020)
This file is almost same as the fsl-imx8qxp-mek-dsp.dts
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Add iMX8DX MEK DTS file and its rpmsg DTS file, both re-use the
common MEK board DTS files.
The 8DX MEK only has 1GB DDR, so decrease its CMA size to 320MB.
Signed-off-by: Ye Li <ye.li@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 9ab7b42c2c99dc0e2dd7fafa5cb4cebd792aceaf)
Abstract the MEK board DTS nodes to common files fsl-imx8x-mek.dtsi
and fsl-imx8x-mek-rpmsg.dtsi. So that we can share the board nodes
between 8QXP and 8DX MEK DTS
(cherry picked from commit e1a4c61d3c0f9593ec0d2292cc4d510bcb59a01f)
According to iMX8DX spec, the GPU and shader frequecy are both 372Mhz
(cherry picked from commit 2dd79af22fd753434b4213b11b799053cb9ec358)
Current i2c4/uart1 clocks ID have conflict with pwm2/pwm3,
correct them.
command
we should reinit the completion before send command
who may trigger the completion,
otherwise it may be reinit after complete in certain timing,
then led to timeout
use private workqueue instead of public workqueue
Signed-off-by: ming_qian <ming.qian@nxp.com>
Acked-by: Shijie Qin <shijie.qin@nxp.com>
(cherry picked from commit fc50fb22a8ee8ddf27885c63c49ea45b5b3ba9b3)
Handle the case when powering down a pd with no active slave domains.
(cherry picked from commit c5403cfa210cd44ba7c427a519a957e24b86dfb7)
