There is a new property to work around the bug of PMIC PF0100.
This property turns the pmic into the standby mode on power down the
system, that leads to turn off all power rails. In this mode the power
consumption is around 2 mA.
Related-to: ELB-3580
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry-picked from commit 36c91bbb3ff44beccc48a6e833d2b61e89affeb5)
It is not necessarily that the system with set up the
POWER_RESET_GPIO config option has the enabled device "gpio-poweroff".
Without this device the "pm_power_off" callback remains uninitialized
and the syscall "reboot" converts the signal LINUX_REBOOT_CMD_POWER_OFF
into LINUX_REBOOT_CMD_HALT.
This leads to skip calling the callback "pm_power_off_prepare" that
should do an important work for iMX6+PF0100 systems: it should turns
down all power rails of PMIC PF0100 to emulate a "power off" state as a
workaround for a PMIC PF0100 with PMIC_ON_REQ and VCC_BATT is supplied
from a battery, leading to unable to restart the module either by RESET
or power cycle.
Note, that gpio-poweroff device still can grab the pm_power_off callback
using the property "force-mode" introduced in the commit:
964f69e00a4d ("power: reset: gpio-poweroff: add force-mode")
Enable setting pm_power_off callback on the system with POWER_RESET_GPIO
config option.
(cherry-picked from aebbdbb42fbec323d242a6c0fb5fe6c97636ee3e)
On some boards the SoC can use one pin "PMIC_STBY_REQ" to notify th PMIC
about state changes. In this case internal state of PMIC must be
preconfigured for upcomming state change.
It works fine with the current regulator framework, except with the
power-off case.
This patch is providing an optional pm_power_off_prepare handler
which will configure standby state of the PMIC to disable all power lines.
In my power consumption test on RIoTBoard, I got the following results:
power off without this patch: 320 mA
power off with this patch: 2 mA
suspend to ram: 40 mA
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
Signed-off-by: Mark Brown <broonie@kernel.org>
(cherry-picked from commit c29daffa322ad36978cbce487f8ebcd9c3c3f7c0)
(tuned for 4.14 kernel)
The shutdown() callback of i2c client device calls for both scenarios,
power off and reboot the system.
In case of rebooting, the PMIC is configured to power off the power rails
when receiveing the PMIC_STBY_REQ request.
It leads to powering the module down and system hanging while suspending
the system after soft reboot.
Remove the shutdown() callback.
(cherry-picked from commit 22072a0ae32d68771e254aeb45c0edf87c61f7d5)
(tuned for kernel 4.14)
Looks like from the very beginning we were missing a proper pinmuxing
for the active state of the HSIC data pin!
Settings taken from discussion on NXP's public community forum:
https://community.nxp.com/t5/i-MX-Processors/i-MX-8QuadMax-USB-HSIC-Functionality/m-p/1228662/highlight/true#M169217
Fixes: 321682bbb785 ("apalis-imx8qm: add USB HSIC support")
Related-to: ELB-3228
(cherry picked from commit a43e07cd3980304b3665fff7b816dee6dad2bf5e)
Put settings into different file, as the filename changed in 5.4.
Sai2 and Sai3 definitions for DMA were missing in the device tree of
kernel 4.14.
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
Our GPIO list starts with gpio5-01 while it really should start with
gpio5-00. So the whole list is shifted by one.
Related-to: ELB-3032
(cherry picked from commit a4fae6e282a3b68f6d6c7dd5b7deca3b33099abb)
Correct ldo1/ldo2 voltage as below:
ldo1 --NVCC_SNVS_1V8
ldo2 --VDD_SNVS_0V8
Analogous to commit 96c179b63e7b ("MLK-23275-1: ARM64: dts: freescale: fsl-imx8mm-evk: correct ldo1/ldo2 voltage")
from NXP's downstream BSP.
toradex_4.14-2.3.x-imx
The pins which can be used for an external ethernet PHY are powered by
a sepearte LDO. Currently in the device tree this rail is set to 1.8V,
the default apalis functionality of these pins requires 3.3V so change
to that.
If used with an external PHY in addition to add the PHY to the device also
the rail's voltage needs to be adapted.
Related-to: ELB-2899
This commit adds the Cortex-M4- and RPMsg-related nodes to the base Verdin iMX8M Mini device tree.
We saw earlier with a lot of docker compose up and down work that this
was failing. Disabling this feature solves this issue:
[ 5169.152016] mmc0: cqhci: timeout for tag 20
[ 5169.156209] mmc0: cqhci: ============ CQHCI REGISTER DUMP ===========
[ 5169.162650] mmc0: cqhci: Caps: 0x0000310a | Version: 0x00000510
[ 5169.169089] mmc0: cqhci: Config: 0x00001001 | Control: 0x00000000
[ 5169.175529] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006
[ 5169.181969] mmc0: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000
[ 5169.188408] mmc0: cqhci: TDL base: 0x7807a000 | TDL up32: 0x00000000
[ 5169.194848] mmc0: cqhci: Doorbell: 0xb3700003 | TCN: 0x00000000
[ 5169.201287] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00000002
[ 5169.207727] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000
[ 5169.214166] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000800
[ 5169.220605] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x00000000
[ 5169.227044] mmc0: cqhci: Resp idx: 0x0000000d | Resp arg: 0x00000000
[ 5169.233484] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5169.239925] mmc0: sdhci: Sys addr: 0xbd2d4000 | Version: 0x00000002
[ 5169.246367] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x000000d8
[ 5169.252806] mmc0: sdhci: Argument: 0x00018000 | Trn mode: 0x00000023
[ 5169.259246] mmc0: sdhci: Present: 0x01f88008 | Host ctl: 0x00000030
[ 5169.265686] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 5169.272125] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x0000000f
[ 5169.278564] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 5169.285004] mmc0: sdhci: Int enab: 0x107f4000 | Sig enab: 0x107f4000
[ 5169.291443] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 5169.297883] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 5169.304323] mmc0: sdhci: Cmd: 0x00000d1a | Max curr: 0x00ffffff
[ 5169.310762] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0xffc003ff
[ 5169.317203] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d07f01
[ 5169.323643] mmc0: sdhci: Host ctl2: 0x00000088
[ 5169.328086] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x7809dcd8
[ 5169.334525] mmc0: sdhci: ============================================
which lead to hang the module.
Related-to: ELB-2612
brcmfamc driver attach mmc func devices only when func1 device's
node exist, and whose compatible string match "brcm,bcm4329-fmac".
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit: b9945d63c2b8a6c1c9b018869eb2479781501608)
Enable GPIO and serial-port (CD-signal) sources for
the PPS (pulse-per-second) module.
Related-to: ELB-2837
Related-to: ELB-2606, ELB-2730
Apalis carrier boards do not have the Write-Protect signal connected
The dts file for WIFI support on i.MX6ULZ Lite is missed, so add it.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Add btwifi dts support for i.MX6ULZ Lite.
for i.MX6ULZ Lite, there is no dedicated SOC id for it,
so add a dummy ID and identify it by checking the MARK
bit in fuse.
Temporarily add device trees for the e-con Systems e-CAM50_CUIMX8. Once
we have working device tree overlays for this we may drop those again.
These are the albeit heavily modified device tree parts from the following patch we got from Yogaesh
<yogaesh@e-consystems.com> on May 8, 2020:
Related-to: ELB-2793
Enable driver for the e-con Systems e-CAM50_CUIMX8.
Add initial driver for the e-con Systems e-CAM50_CUIMX8.
This is the driver part from the following patch we got from Yogaesh <yogaesh@e-consystems.com> on
May 8, 2020:
apalis_imx8qm_embedded_linux_eCAM50_support.patch
The 'nand_usdhc_bus' clock is only need to be enabled when usdhc
or nand module is active, so change it to non-critical clock type.
(cherry picked from commit 32caf053fc38697bd418ef95bb3ff9962f6b7019)
This is needed for the new KSZ9131 phy
NXP fixes a lot of issues in PCIe subsystem, in particular, add new
clocks. Synchronize the set of clocks for Apalis-iMX8QM SoM.
Related-to: ELB-1306
Fix conflicts after merging changes from the latest NXP branch.
arch/arm64/boot/dts/freescale/fsl-imx8qm-device.dtsi
drivers/pci/dwc/pci-imx6.c
Change model string of iMX8QM/QP V1.1 to differentiate from the model
string used in the device tree for the earlier iMX8QM/QP module (this
has been causing problems with the dtconf tool).
Related-to: ELB-2829
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
The i.MX6ULZ Lite is full compatible with i.MX6ULL/ULZ, and
only support 9x9 package.
It’s a limitation that one cannot use native SPI CS & DMA and have a
continuous CS for the whole transfer. The CS is deasserted after each
word sent.
One can either use DMA and GPIO CS or one can use PIO mode.
With this commit we change from using PIO mode to DMA mode and
change the CS used from the IP provided one to GPIO CS on the same pin.
This sync's the SPI configuration with the i.MX 8X based modules which
already uses DMA with GPIO CS.
Related-to: ELB-1278
Add GPIO line names on module level. Those are all GPIOs which a user
might use on his custom carrier board. If more meaningful names are
available on the carrier board, the user can overwrite the line names
in the carrier board level device tree.
Related-to: ELB-2528
Related-to: ELB-2527
Related-to: ELB-2526
Related-to: ELB-2794
Add bluetooth drivers useful for the Gumstix AutoBSP as kernel modules.
Related-to: TOR-1068
Add iio/hwmon sensor drivers useful for the Gumstix AutoBSP as kernel
modules.
Add sound drivers useful for the Gumstix AutoBSP as kernel modules.
Without a prompt string, a config setting can't be included in a
defconfig. Give CONFIG_SND_SOC_ICS43432 a prompt so that Pi soundcards
can use the driver.
Signed-off-by: Phil Elwell <phil@raspberrypi.org>
CL_MEM_USE_HOST_PHYSICAL_ADDR_VIV
CL_MEM_USE_HOST_PHYSICAL_ADDR_VIV will use host physical memory directly, logical address is zero.
gckOS_UnlockPages will check Logical address and return invalid parameter,
that causes memory leak in OpenCL user library, need remove this check.
Signed-off-by: Xianzhong <xianzhong.li@nxp.com>
(cherry picked from commit 85a7c0f80d4f44d990f9ba85ecf2b6baea06053c)
(cherry picked from commit d3f9bbb64cc198f06a92676eb536a7b4c0f08eeb)
Integrate RESET_MOCI#_DRV handling with work-around for PCIe switch as
found on the Apalis Evaluation Board similar to what we upstreamed.
Related-to: ELB-1929
This pulls the reset_moci signal by default low and insures reset is
applied when pin is being muxed. It needs then actively set high
for getting out of reset.
With GCC 10 there is an error during compiling of our downstream
branch. Removing multiple yylloc definitions help.
commit e33a814e772cdc36436c8c188d8c42d019fda639 upstream.
gcc 10 will default to -fno-common, which causes this error at link
time:
(.text+0x0): multiple definition of `yylloc'; dtc-lexer.lex.o (symbol from plugin):(.text+0x0): first defined here
This is because both dtc-lexer as well as dtc-parser define the same
global symbol yyloc. Before with -fcommon those were merged into one
defintion. The proper solution would be to to mark this as "extern",
however that leads to:
dtc-lexer.l:26:16: error: redundant redeclaration of 'yylloc' [-Werror=redundant-decls]
26 | extern YYLTYPE yylloc;
In file included from dtc-lexer.l:24:
dtc-parser.tab.h:127:16: note: previous declaration of 'yylloc' was here
127 | extern YYLTYPE yylloc;
cc1: all warnings being treated as errors
which means the declaration is completely redundant and can just be
dropped.
Signed-off-by: Dirk Mueller <dmueller@suse.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
[robh: cherry-pick from upstream]
Cc: stable@vger.kernel.org
Signed-off-by: Rob Herring <robh@kernel.org>
(cherry picked from commit 35b34d264cb347909ec89d9fa895900035d5438c)
