commit 84c7efd607e7fb6933920322086db64654f669b2 upstream.
The pinmuxing was missing for I2C1 which was causing intermittent issues
with the PMIC which is connected to I2C1. The bootloader did not quite
configure the I2C1 either, so when running at 2.6MHz, it was generating
errors at times.
This correctly sets the I2C1 pinmuxing so it can operate at 2.6MHz
Fixes: ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD DM3730
SOM-LV")
commit feb7695fe9fb83084aa29de0094774f4c9d4c9fc upstream.
If only a subset of the devices associated with multiple regions support
a given special operation (eg. DISCARD) then the dec_count() that is
used to set error for the region must increment the io->count.
Otherwise, when the dec_count() is called it can cause the dm-io
caller's bio to be completed multiple times. As was reported against
the dm-mirror target that had mirror legs with a mix of discard
capabilities.
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=196077
Reported-by: Zhang Yi <yizhan@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit ee8bdfb6568d86bb93f55f8d99c4c643e77304ee upstream.
Even though it is unconventional, some PCIe host implementations omit the
root ports entirely, and simply consist of a host bridge (which is not
modeled as a device in the PCI hierarchy) and a link.
When the downstream device is an endpoint, our current code does not seem
to mind this unusual configuration. However, when PCIe switches are
involved, the ASPM code assumes that any downstream switch port has a
parent, and blindly dereferences the bus->parent->self field of the pci_dev
struct to chain the downstream link state to the link state of the root
port. Given that the root port is missing, the link is not modeled at all,
and nor is the link state, and attempting to access it results in a NULL
pointer dereference and a crash.
Avoid this by allowing the link state chain to terminate at the downstream
port if no root port exists.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
path as unlikely()
commit 946fbbc13dce68902f64515b610eeb2a6c3d7a64 upstream.
vmx_vcpu_run() and svm_vcpu_run() are large functions, and giving
branch hints to the compiler can actually make a substantial cycle
difference by keeping the fast path contiguous in memory.
With this optimization, the retpoline-guest/retpoline-host case is
about 50 cycles faster.
Reviewed-by: Jim Mattson <jmattson@google.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: KarimAllah Ahmed <karahmed@amazon.de>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: kvm@vger.kernel.org
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/20180222154318.20361-3-pbonzini@redhat.com
commit ecb586bd29c99fb4de599dec388658e74388daad upstream.
Having a paravirt indirect call in the IBRS restore path is not a
good idea, since we are trying to protect from speculative execution
of bogus indirect branch targets. It is also slower, so use
native_wrmsrl() on the vmentry path too.
Fixes: d28b387fb74da95d69d2615732f50cceb38e9a4d
Link: http://lkml.kernel.org/r/20180222154318.20361-2-pbonzini@redhat.com
commit b28676bb8ae4569cced423dc2a88f7cb319d5379 upstream.
Reported by syzkaller:
pte_list_remove: ffff9714eb1f8078 0->BUG
kernel BUG at arch/x86/kvm/mmu.c:1157!
invalid opcode: 0000 [#1] SMP
RIP: 0010:pte_list_remove+0x11b/0x120 [kvm]
Call Trace:
drop_spte+0x83/0xb0 [kvm]
mmu_page_zap_pte+0xcc/0xe0 [kvm]
kvm_mmu_prepare_zap_page+0x81/0x4a0 [kvm]
kvm_mmu_invalidate_zap_all_pages+0x159/0x220 [kvm]
kvm_arch_flush_shadow_all+0xe/0x10 [kvm]
kvm_mmu_notifier_release+0x6c/0xa0 [kvm]
? kvm_mmu_notifier_release+0x5/0xa0 [kvm]
__mmu_notifier_release+0x79/0x110
? __mmu_notifier_release+0x5/0x110
exit_mmap+0x15a/0x170
? do_exit+0x281/0xcb0
mmput+0x66/0x160
do_exit+0x2c9/0xcb0
? __context_tracking_exit.part.5+0x4a/0x150
do_group_exit+0x50/0xd0
SyS_exit_group+0x14/0x20
do_syscall_64+0x73/0x1f0
entry_SYSCALL64_slow_path+0x25/0x25
The reason is that when creates new memslot, there is no guarantee for new
memslot not overlap with private memslots. This can be triggered by the
following program:
#include <fcntl.h>
#include <pthread.h>
#include <setjmp.h>
#include <signal.h>
#include <stddef.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/ioctl.h>
#include <sys/stat.h>
#include <sys/syscall.h>
#include <sys/types.h>
#include <unistd.h>
#include <linux/kvm.h>
long r[16];
int main()
void *p = valloc(0x4000);
r[2] = open("/dev/kvm", 0);
r[3] = ioctl(r[2], KVM_CREATE_VM, 0x0ul);
uint64_t addr = 0xf000;
ioctl(r[3], KVM_SET_IDENTITY_MAP_ADDR, &addr);
r[6] = ioctl(r[3], KVM_CREATE_VCPU, 0x0ul);
ioctl(r[3], KVM_SET_TSS_ADDR, 0x0ul);
ioctl(r[6], KVM_RUN, 0);
struct kvm_userspace_memory_region mr = {
.slot = 0,
.flags = KVM_MEM_LOG_DIRTY_PAGES,
.guest_phys_addr = 0xf000,
.memory_size = 0x4000,
.userspace_addr = (uintptr_t) p
ioctl(r[3], KVM_SET_USER_MEMORY_REGION, &mr);
return 0;
This patch fixes the bug by not adding a new memslot even if it
overlaps with private memslots.
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit 67870eb1204223598ea6d8a4467b482e9f5875b5 upstream.
In banked-sr.c, we use a top-level '__asm__(".arch_extension virt")'
statement to allow compilation of a multi-CPU kernel for ARMv6
and older ARMv7-A that don't normally support access to the banked
registers.
This is considered to be a programming error by the gcc developers
and will no longer work in gcc-8, where we now get a build error:
/tmp/cc4Qy7GR.s:34: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_usr'
/tmp/cc4Qy7GR.s:41: Error: Banked registers are not available with this architecture. -- `mrs r3,ELR_hyp'
/tmp/cc4Qy7GR.s:55: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_svc'
/tmp/cc4Qy7GR.s:62: Error: Banked registers are not available with this architecture. -- `mrs r3,LR_svc'
/tmp/cc4Qy7GR.s:69: Error: Banked registers are not available with this architecture. -- `mrs r3,SPSR_svc'
/tmp/cc4Qy7GR.s:76: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_abt'
Passign the '-march-armv7ve' flag to gcc works, and is ok here, because
we know the functions won't ever be called on pre-ARMv7VE machines.
Unfortunately, older compiler versions (4.8 and earlier) do not understand
that flag, so we still need to keep the asm around.
Backporting to stable kernels (4.6+) is needed to allow those to be built
with future compilers as well.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=84129
Fixes: 33280b4cd1dc ("ARM: KVM: Add banked registers save/restore")
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 8aa36a8dcde3183d84db7b0d622ffddcebb61077 upstream.
The MACH_ARMADA_375 and MACH_ARMADA_38X boards select ARM_ERRATA_753970,
but it was renamed to PL310_ERRATA_753970 by commit fa0ce4035d48 ("ARM:
7162/1: errata: tidy up Kconfig options for PL310 errata workarounds").
Fix the selects to use the new name.
Discovered with the
https://github.com/ulfalizer/Kconfiglib/blob/master/examples/list_undefined.py
script.
Fixes: fa0ce4035d48 ("ARM: 7162/1: errata: tidy up Kconfig options for
cc: stable@vger.kernel.org
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
commit b98c6a160a057d5686a8c54c79cc6c8c94a7d0c8 upstream.
The last expression in a statement expression need not be a bare
variable, quoting gcc docs
The last thing in the compound statement should be an expression
followed by a semicolon; the value of this subexpression serves as the
value of the entire construct.
and we already use that in e.g. the min/max macros which end with a
ternary expression.
This way, we can allow index to have const-qualified type, which will in
some cases avoid the need for introducing a local copy of index of
non-const qualified type. That, in turn, can prevent readers not
familiar with the internals of array_index_nospec from wondering about
the seemingly redundant extra variable, and I think that's worthwhile
considering how confusing the whole _nospec business is.
The expression _i&_mask has type unsigned long (since that is the type
of _mask, and the BUILD_BUG_ONs guarantee that _i will get promoted to
that), so in order not to change the type of the whole expression, add
a cast back to typeof(_i).
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/151881604837.17395.10812767547837568328.stgit@dwillia2-desk3.amr.corp.intel.com
commit b9c97c67fd19262c002d94ced2bfb513083e161e upstream.
If m88d3103 chip ID is not recognized, the device is not initialized.
However, it returns from probe without any error, causing this OOPS:
[ 7.689289] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 7.689297] pgd = 7b0bd7a7
[ 7.689302] [00000000] *pgd=00000000
[ 7.689318] Internal error: Oops: 80000005 [#1] SMP ARM
[ 7.689322] Modules linked in: dvb_usb_dvbsky(+) m88ds3103 dvb_usb_v2 dvb_core videobuf2_vmalloc videobuf2_memops videobuf2_core crc32_arm_ce videodev media
[ 7.689358] CPU: 3 PID: 197 Comm: systemd-udevd Not tainted 4.15.0-mcc+ #23
[ 7.689361] Hardware name: BCM2835
[ 7.689367] PC is at 0x0
[ 7.689382] LR is at m88ds3103_attach+0x194/0x1d0 [m88ds3103]
[ 7.689386] pc : [<00000000>] lr : [<bf0ae1ec>] psr: 60000013
[ 7.689391] sp : ed8e5c20 ip : ed8c1e00 fp : ed8945c0
[ 7.689395] r10: ed894000 r9 : ed894378 r8 : eda736c0
[ 7.689400] r7 : ed894070 r6 : ed8e5c44 r5 : bf0bb040 r4 : eda77600
[ 7.689405] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : eda77600
[ 7.689412] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 7.689417] Control: 10c5383d Table: 2d8e806a DAC: 00000051
[ 7.689423] Process systemd-udevd (pid: 197, stack limit = 0xe9dbfb63)
[ 7.689428] Stack: (0xed8e5c20 to 0xed8e6000)
[ 7.689439] 5c20: ed853a80 eda73640 ed894000 ed8942c0 ed853a80 bf0b9e98 ed894070 bf0b9f10
[ 7.689449] 5c40: 00000000 00000000 bf08c17c c08dfc50 00000000 00000000 00000000 00000000
[ 7.689459] 5c60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 7.689468] 5c80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 7.689479] 5ca0: 00000000 00000000 ed8945c0 ed8942c0 ed894000 ed894830 bf0b9e98 00000000
[ 7.689490] 5cc0: ed894378 bf0a3cb4 bf0bc3b0 0000533b ed920540 00000000 00000034 bf0a6434
[ 7.689500] 5ce0: ee952070 ed826600 bf0a7038 bf0a2dd8 00000001 bf0a6768 bf0a2f90 ed8943c0
[ 7.689511] 5d00: 00000000 c08eca68 ed826620 ed826620 00000000 ee952070 bf0bc034 ee952000
[ 7.689521] 5d20: ed826600 bf0bb080 ffffffed c0aa9e9c c0aa9dac ed826620 c16edf6c c168c2c8
[ 7.689531] 5d40: c16edf70 00000000 bf0bc034 0000000d 00000000 c08e268c bf0bb080 ed826600
[ 7.689541] 5d60: bf0bc034 ed826654 ed826620 bf0bc034 c164c8bc 00000000 00000001 00000000
[ 7.689553] 5d80: 00000028 c08e2948 00000000 bf0bc034 c08e2848 c08e0778 ee9f0a58 ed88bab4
[ 7.689563] 5da0: bf0bc034 ed90ba80 c168c1f0 c08e1934 bf0bb3bc c17045ac bf0bc034 c164c8bc
[ 7.689574] 5dc0: bf0bc034 bf0bb3bc ed91f564 c08e34ec bf0bc000 c164c8bc bf0bc034 c0aa8dc4
[ 7.689584] 5de0: ffffe000 00000000 bf0bf000 ed91f600 ed91f564 c03021e4 00000001 00000000
[ 7.689595] 5e00: c166e040 8040003f ed853a80 bf0bc448 00000000 c1678174 ed853a80 f0f22000
[ 7.689605] 5e20: f0f21fff 8040003f 014000c0 ed91e700 ed91e700 c16d8e68 00000001 ed91e6c0
[ 7.689615] 5e40: bf0bc400 00000001 bf0bc400 ed91f564 00000001 00000000 00000028 c03c9a24
[ 7.689625] 5e60: 00000001 c03c8c94 ed8e5f50 ed8e5f50 00000001 bf0bc400 ed91f540 c03c8cb0
[ 7.689637] 5e80: bf0bc40c 00007fff bf0bc400 c03c60b0 00000000 bf0bc448 00000028 c0e09684
[ 7.689647] 5ea0: 00000002 bf0bc530 c1234bf8 bf0bc5dc bf0bc514 c10ebbe8 ffffe000 bf000000
[ 7.689657] 5ec0: 00011538 00000000 ed8e5f48 00000000 00000000 00000000 00000000 00000000
[ 7.689666] 5ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 7.689676] 5f00: 00000000 00000000 7fffffff 00000000 00000013 b6e55a18 0000017b c0309104
[ 7.689686] 5f20: ed8e4000 00000000 00510af0 c03c9430 7fffffff 00000000 00000003 00000000
[ 7.689697] 5f40: 00000000 f0f0f000 00011538 00000000 f0f107b0 f0f0f000 00011538 f0f1fdb8
[ 7.689707] 5f60: f0f1fbe8 f0f1b974 00004000 000041e0 bf0bc3d0 00000001 00000000 000024c4
[ 7.689717] 5f80: 0000002d 0000002e 00000019 00000000 00000010 00000000 16894000 00000000
[ 7.689727] 5fa0: 00000000 c0308f20 16894000 00000000 00000013 b6e55a18 00000000 b6e5652c
[ 7.689737] 5fc0: 16894000 00000000 00000000 0000017b 00020000 00508110 00000000 00510af0
[ 7.689748] 5fe0: bef68948 bef68938 b6e4d3d0 b6d32590 60000010 00000013 00000000 00000000
[ 7.689790] [<bf0ae1ec>] (m88ds3103_attach [m88ds3103]) from [<bf0b9f10>] (dvbsky_s960c_attach+0x78/0x280 [dvb_usb_dvbsky])
[ 7.689821] [<bf0b9f10>] (dvbsky_s960c_attach [dvb_usb_dvbsky]) from [<bf0a3cb4>] (dvb_usbv2_probe+0xa3c/0x1024 [dvb_usb_v2])
[ 7.689849] [<bf0a3cb4>] (dvb_usbv2_probe [dvb_usb_v2]) from [<c0aa9e9c>] (usb_probe_interface+0xf0/0x2a8)
[ 7.689869] [<c0aa9e9c>] (usb_probe_interface) from [<c08e268c>] (driver_probe_device+0x2f8/0x4b4)
[ 7.689881] [<c08e268c>] (driver_probe_device) from [<c08e2948>] (__driver_attach+0x100/0x11c)
[ 7.689895] [<c08e2948>] (__driver_attach) from [<c08e0778>] (bus_for_each_dev+0x4c/0x9c)
[ 7.689909] [<c08e0778>] (bus_for_each_dev) from [<c08e1934>] (bus_add_driver+0x1c0/0x264)
[ 7.689919] [<c08e1934>] (bus_add_driver) from [<c08e34ec>] (driver_register+0x78/0xf4)
[ 7.689931] [<c08e34ec>] (driver_register) from [<c0aa8dc4>] (usb_register_driver+0x70/0x134)
[ 7.689946] [<c0aa8dc4>] (usb_register_driver) from [<c03021e4>] (do_one_initcall+0x44/0x168)
[ 7.689963] [<c03021e4>] (do_one_initcall) from [<c03c9a24>] (do_init_module+0x64/0x1f4)
[ 7.689979] [<c03c9a24>] (do_init_module) from [<c03c8cb0>] (load_module+0x20a0/0x25c8)
[ 7.689993] [<c03c8cb0>] (load_module) from [<c03c9430>] (SyS_finit_module+0xb4/0xec)
[ 7.690007] [<c03c9430>] (SyS_finit_module) from [<c0308f20>] (ret_fast_syscall+0x0/0x54)
[ 7.690018] Code: bad PC value
This may happen on normal circumstances, if, for some reason, the demod
hangs and start returning an invalid chip ID:
[ 10.394395] m88ds3103 3-0068: Unknown device. Chip_id=00
So, change the logic to cause probe to fail with -ENODEV, preventing
the OOPS.
Detected while testing DVB MMAP patches on Raspberry Pi 3 with
DVBSky S960CI.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 028091f82eefd5e84f81cef81a7673016ecbe78b upstream.
When the Intel Edison module is powered with 3.3V, the reboot command makes
the module stuck. If the module is powered at a greater voltage, like 4.4V
(as the Edison Mini Breakout board does), reboot works OK.
The official Intel Edison BSP sends the IPCMSG_COLD_RESET message to the
SCU by default. The IPCMSG_COLD_BOOT which is used by the upstream kernel
is only sent when explicitely selected on the kernel command line.
Use IPCMSG_COLD_RESET unconditionally which makes reboot work independent
of the power supply voltage.
[ tglx: Massaged changelog ]
Fixes: bda7b072de99 ("x86/platform/intel-mid: Implement power off sequence")
Signed-off-by: Sebastian Panceac <sebastian@resin.io>
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Link: https://lkml.kernel.org/r/1519810849-15131-1-git-send-email-sebastian@resin.io
commit 71c208dd54ab971036d83ff6d9837bae4976e623 upstream.
Older Xen versions (4.5 and before) might have problems migrating pv
guests with MSR_IA32_SPEC_CTRL having a non-zero value. So before
suspending zero that MSR and restore it after being resumed.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Jan Beulich <jbeulich@suse.com>
Cc: xen-devel@lists.xenproject.org
Cc: boris.ostrovsky@oracle.com
Link: https://lkml.kernel.org/r/20180226140818.4849-1-jgross@suse.com
commit 230f5a8969d8345fc9bbe3683f068246cf1be4b8 upstream.
Gerd reports that ->i_mode may contain other bits besides S_IFCHR. Use
S_ISCHR() instead. Otherwise, get_user_pages_longterm() may fail on
device-dax instances when those are meant to be explicitly allowed.
Fixes: 2bb6d2837083 ("mm: introduce get_user_pages_longterm")
Cc: <stable@vger.kernel.org>
Reported-by: Gerd Rausch <gerd.rausch@oracle.com>
Acked-by: Jane Chu <jane.chu@oracle.com>
Reported-by: Haozhong Zhang <haozhong.zhang@intel.com>
commit 0373ca74831b0f93cd4cdbf7ad3aec3c33a479a5 upstream.
commit a307a1e6bc0d "cpufreq: s3c: use cpufreq_generic_init()"
accidentally broke cpufreq on s3c2410 and s3c2412.
These two platforms don't have a CPU frequency table and used to skip
calling cpufreq_table_validate_and_show() for them. But with the
above commit, we started calling it unconditionally and that will
eventually fail as the frequency table pointer is NULL.
Fix this by calling cpufreq_table_validate_and_show() conditionally
again.
Fixes: a307a1e6bc0d "cpufreq: s3c: use cpufreq_generic_init()"
Cc: 3.13+ <stable@vger.kernel.org> # v3.13+
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 0adb24e03a124b79130c9499731936b11ce2677d upstream.
The change to flush_kernel_vmap_range() wasn't sufficient to avoid the
SMP stalls. The problem is some drivers call these routines with
interrupts disabled. Interrupts need to be enabled for flush_tlb_all()
and flush_cache_all() to work. This version adds checks to ensure
interrupts are not disabled before calling routines that need IPI
interrupts. When interrupts are disabled, we now drop into slower code.
The attached change fixes the ordering of cache and TLB flushes in
several cases. When we flush the cache using the existing PTE/TLB
entries, we need to flush the TLB after doing the cache flush. We don't
need to do this when we flush the entire instruction and data caches as
these flushes don't use the existing TLB entries. The same is true for
tmpalias region flushes.
The flush_kernel_vmap_range() and invalidate_kernel_vmap_range()
routines have been updated.
Secondly, we added a new purge_kernel_dcache_range_asm() routine to
pacache.S and use it in invalidate_kernel_vmap_range(). Nominally,
purges are faster than flushes as the cache lines don't have to be
written back to memory.
Hopefully, this is sufficient to resolve the remaining problems due to
cache speculation. So far, testing indicates that this is the case. I
did work up a patch using tmpalias flushes, but there is a performance
hit because we need the physical address for each page, and we also need
to sequence access to the tmpalias flush code. This increases the
probability of stalls.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # 4.9+
Signed-off-by: Helge Deller <deller@gmx.de>
commit c52232a49e203a65a6e1a670cd5262f59e9364a0 upstream.
On CPU hotunplug the enqueued timers of the unplugged CPU are migrated to a
live CPU. This happens from the control thread which initiated the unplug.
If the CPU on which the control thread runs came out from a longer idle
period then the base clock of that CPU might be stale because the control
thread runs prior to any event which forwards the clock.
In such a case the timers from the unplugged CPU are queued on the live CPU
based on the stale clock which can cause large delays due to increased
granularity of the outer timer wheels which are far away from base:;clock.
But there is a worse problem than that. The following sequence of events
illustrates it:
- CPU0 timer1 is queued expires = 59969 and base->clk = 59131.
The timer is queued at wheel level 2, with resulting expiry time = 60032
(due to level granularity).
- CPU1 enters idle @60007, with next timer expiry @60020.
- CPU0 is hotplugged at @60009
- CPU1 exits idle and runs the control thread which migrates the
timers from CPU0
timer1 is now queued in level 0 for immediate handling in the next
softirq because the requested expiry time 59969 is before CPU1 base->clk
60007
- CPU1 runs code which forwards the base clock which succeeds because the
next expiring timer. which was collected at idle entry time is still set
to 60020.
So it forwards beyond 60007 and therefore misses to expire the migrated
timer1. That timer gets expired when the wheel wraps around again, which
takes between 63 and 630ms depending on the HZ setting.
Address both problems by invoking forward_timer_base() for the control CPUs
timer base. All other places, which might run into a similar problem
(mod_timer()/add_timer_on()) already invoke forward_timer_base() to avoid
that.
[ tglx: Massaged comment and changelog ]
Fixes: a683f390b93f ("timers: Forward the wheel clock whenever possible")
Co-developed-by: Neeraj Upadhyay <neeraju@codeaurora.org>
Signed-off-by: Neeraj Upadhyay <neeraju@codeaurora.org>
Signed-off-by: Lingutla Chandrasekhar <clingutla@codeaurora.org>
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: linux-arm-msm@vger.kernel.org
Link: https://lkml.kernel.org/r/20180118115022.6368-1-clingutla@codeaurora.org
commit 71db96ddfa72671bd43cacdcc99ca178d90ba267 upstream.
We've added a quirk to enable the recent Lenovo dock support, where it
overwrites the pin configs of NID 0x17 and 19, not only updating the
pin config cache. It works right after the boot, but the problem is
that the pin configs are occasionally cleared when the machine goes to
PM. Meanwhile the quirk writes the pin configs only at the pre-probe,
so this won't be applied any longer.
For addressing that issue, this patch moves the code to overwrite the
pin configs into HDA_FIXUP_ACT_INIT section so that it's always
applied at both probe and resume time.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195161
Fixes: 61fcf8ece9b6 ("ALSA: hda/realtek - Enable Thinkpad Dock device for ALC298 platform")
commit 1ba8f9d308174e647b864c36209b4d7934d99888 upstream.
On some boards setting power_save to a non 0 value leads to clicking /
popping sounds when ever we enter/leave powersaving mode. Ideally we would
figure out how to avoid these sounds, but that is not always feasible.
This commit adds a blacklist for devices where powersaving is known to
cause problems and disables it on these devices.
Note I tried to put this blacklist in userspace first:
https://github.com/systemd/systemd/pull/8128
But the systemd maintainers rightfully pointed out that it would be
impossible to then later remove entries once we actually find a way to
make power-saving work on listed boards without issues. Having this list
in the kernel will allow removal of the blacklist entry in the same commit
which fixes the clicks / plops.
The blacklist only applies to the default power_save module-option value,
if a user explicitly sets the module-option then the blacklist is not
used.
[ added an ifdef CONFIG_PM for the build error -- tiwai]
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1525104
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=198611
commit 240a8af929c7c57dcde28682725b29cf8474e8e5 upstream.
The capture interface doesn't work and the playback interface only
supports 48 kHz sampling rate even though it advertises more rates.
Signed-off-by: Erik Veijola <erik.veijola@gmail.com>
commit ee70bc1e7b63ac8023c9ff9475d8741e397316e7 upstream.
tpm_transmit() does not offer an explicit interface to indicate the number
of valid bytes in the communication buffer. Instead, it relies on the
commandSize field in the TPM header that is encoded within the buffer.
Therefore, ensure that a) enough data has been written to the buffer, so
that the commandSize field is present and b) the commandSize field does not
announce more data than has been written to the buffer.
This should have been fixed with CVE-2011-1161 long ago, but apparently
a correct version of that patch never made it into the kernel.
Signed-off-by: Alexander Steffen <Alexander.Steffen@infineon.com>
Reviewed-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Tested-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
commit 6b3a13173f23e798e1ba213dd4a2c065a3b8d751 upstream.
The buffers used as tx_buf/rx_buf in a SPI transfer need to be DMA-safe.
This cannot be guaranteed for the buffers passed to tpm_tis_spi_read_bytes
and tpm_tis_spi_write_bytes. Therefore, we need to use our own DMA-safe
buffer and copy the data to/from it.
The buffer needs to be allocated separately, to ensure that it is
cacheline-aligned and not shared with other data, so that DMA can work
correctly.
Fixes: 0edbfea537d1 ("tpm/tpm_tis_spi: Add support for spi phy")
commit c37fbc09bd4977736f6bc4050c6f099c587052a7 upstream.
Making cmd_getticks 'const' introduced a couple of harmless warnings:
drivers/char/tpm/tpm_tis_core.c: In function 'probe_itpm':
drivers/char/tpm/tpm_tis_core.c:469:31: error: passing argument 2 of 'tpm_tis_send_data' discards 'const' qualifier from pointer target type [-Werror=discarded-qualifiers]
rc = tpm_tis_send_data(chip, cmd_getticks, len);
drivers/char/tpm/tpm_tis_core.c:477:31: error: passing argument 2 of 'tpm_tis_send_data' discards 'const' qualifier from pointer target type [-Werror=discarded-qualifiers]
drivers/char/tpm/tpm_tis_core.c:255:12: note: expected 'u8 * {aka unsigned char *}' but argument is of type 'const u8 * {aka const unsigned char *}'
static int tpm_tis_send_data(struct tpm_chip *chip, u8 *buf, size_t len)
This changes the related functions to all take 'const' pointers
so that gcc can see this as being correct. I had to slightly
modify the logic around tpm_tis_spi_transfer() for this to work
without introducing ugly casts.
Fixes: 5e35bd8e06b9 ("tpm_tis: make array cmd_getticks static const to shink object code size")
commit 6bb320ca4a4a7b5b3db8c8d7250cc40002046878 upstream.
Discrete TPMs are often connected over slow serial buses which, on
some platforms, can have glitches causing bit flips. In all the
driver _recv() functions, we need to use a u32 to unmarshal the
response size, otherwise a bit flip of the 31st bit would cause the
expected variable to go negative, which would then try to read a huge
amount of data. Also sanity check that the expected amount of data is
large enough for the TPM header.
Signed-off-by: Jeremy Boone <jeremy.boone@nccgroup.trust>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Signed-off-by: James Morris <james.morris@microsoft.com>
commit f9d4d9b5a5ef2f017bc344fb65a58a902517173b upstream.
the bus
commit 9b8cb28d7c62568a5916bdd7ea1c9176d7f8f2ed upstream.
commit 6d24cd186d9fead3722108dec1b1c993354645ff upstream.
commit ebabcf17bcd7ce968b1631ebe08236275698f39b upstream.
GCC7 is a bit too eager to generate suboptimal __multi3 calls (128bit
multiply with 128bit result) for MIPS64r6 builds, even in code which
doesn't explicitly use 128bit types, such as the following:
unsigned long func(unsigned long a, unsigned long b)
return a > (~0UL) / b;
Which GCC rearanges to:
return (unsigned __int128)a * (unsigned __int128)b > 0xffffffffffffffff;
Therefore implement __multi3, but only for MIPS64r6 with GCC7 as under
normal circumstances we wouldn't expect any calls to __multi3 to be
generated from kernel code.
Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: James Hogan <jhogan@kernel.org>
Tested-by: Waldemar Brodkorb <wbx@openadk.org>
Cc: Maciej W. Rozycki <macro@mips.com>
Cc: Matthew Fortune <matthew.fortune@mips.com>
Cc: Florian Fainelli <florian@openwrt.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/17890/
Commit 45ee9d5e97a4 ("KVM: arm/arm64: Check pagesize when allocating a
hugepage at Stage 2") lost the check for PMD_SIZE during the backport
to 4.9.
Fix this by correcting the condition to detect hugepages during stage
2 allocation.
Fixes: 45ee9d5e97a4 ("KVM: arm/arm64: Check pagesize when allocating a hugepage at Stage 2")
Reported-by: Ioana Ciornei <ioana.ciornei@nxp.com>
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
[ Upstream commit 11d827a993a969c3c6ec56758ff63a44ba19b466 ]
set_fipers() calling should be protected by spinlock in
case that any interrupt breaks related registers setting
and the function we expect. This patch is to move set_fipers()
to spinlock protecting area in ptp_gianfar_adjtime().
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Acked-by: Richard Cochran <richardcochran@gmail.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
[ Upstream commit c76f97c99ae6d26d14c7f0e50e074382bfbc9f98 ]
Some sockopt handling functions were calculating the length of the
buffer to be written to userspace and then calculating it again when
actually writing the buffer, which could lead to some write not using
an up-to-date length.
This patch updates such places to just make use of the len variable.
Also, replace some sizeof(type) to sizeof(var).
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit cf2acf66ad43abb39735568f55e1f85f9844e990 ]
When cleaning up after a partially successful gntdev_mmap(), unmap the
successfully mapped grant pages otherwise Xen will kill the domain if
in debug mode (Attempt to implicitly unmap a granted PTE) or Linux will
kill the process and emit "BUG: Bad page map in process" if Xen is in
release mode.
This is only needed when use_ptemod is true because gntdev_put_map()
will unmap grant pages itself when use_ptemod is false.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit 951a010233625b77cde3430b4b8785a9a22968d1 ]
If the requested range has a hole, the calculation of the number of
pages to unmap is off by one. Fix it.
[ Upstream commit 195e2addbce09e5afbc766efc1e6567c9ce840d3 ]
The 'sh_eth' driver's probe() method would fail on the SolutionEngine7710
board and crash on SolutionEngine7712 board as the platform code is
hopelessly behind the driver's platform data -- it passes the PHY address
instead of 'struct sh_eth_plat_data *'; pass the latter to the driver in
order to fix the bug...
Fixes: 71557a37adb5 ("[netdrvr] sh_eth: Add SH7619 support")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 56c0290202ab94a2f2780c449395d4ae8495fab4 ]
If the probing of the regulator is deferred, the memory allocated by
'mdiobus_alloc_size()' will be leaking.
It should be freed before the next call to 'sun4i_mdio_probe()' which will
reallocate it.
Fixes: 4bdcb1dd9feb ("net: Add MDIO bus driver for the Allwinner EMAC")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit b707fda2df4070785d0fa8a278aa13944c5f51f8 ]
When loading the module after unloading it, the network interface would
not be enabled and thus wouldn't have a backend counterpart and unable
to be used by the guest.
The guest would face errors like:
[root@guest ~]# ethtool -i eth0
Cannot get driver information: No such device
[root@guest ~]# ifconfig eth0
eth0: error fetching interface information: Device not found
This patch initializes the state of the netfront device whenever it is
loaded manually, this state would communicate the netback to create its
device and establish the connection between them.
Signed-off-by: Eduardo Otubo <otubo@redhat.com>
[ Upstream commit 78f300049335ae81a5cc6b4b232481dc5e1f9d41 ]
In bnxt_vf_ndo_prep (which is called by bnxt_get_vf_config ndo), there is a
check for "Invalid VF id". Currently, the check is done against max_vfs.
However, the user doesn't always create max_vfs. So, the check should be
against the created number of VFs. The number of bnxt_vf_info structures
that are allocated in bnxt_alloc_vf_resources routine is the "number of
requested VFs". So, if an "invalid VF id" falls between the requested
number of VFs and the max_vfs, the driver will be dereferencing an invalid
pointer.
Fixes: c0c050c58d84 ("bnxt_en: New Broadcom ethernet driver.")
Signed-off-by: Venkat Devvuru <venkatkumar.duvvuru@broadcom.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 13454c14550065fcc1705d6bd4ee6d40e057099f ]
The flexcan_start_xmit() function compares the frame length with data
register length to write frame content into data[0] and data[1]
register. Data register length is 4 bytes and frame maximum length is 8
bytes.
Fix the check that compares frame length with 3. Because the register
length is 4.
Signed-off-by: Luu An Phu <phu.luuan@nxp.com>
Reviewed-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit 736a80bbfda709fb3631f5f62056f250a38e5804 ]
If there are multiple mesh stations with the same MAC address,
they will both get confused and start throwing warnings.
Obviously in this case nothing can actually work anyway, so just
drop frames that look like they're from ourselves early on.
Reported-by: Gui Iribarren <gui@altermundi.net>
[ Upstream commit 3ea15452ee85754f70f3b9fa1f23165ef2e77ba7 ]
nl80211_nan_add_func() does not check if the required attribute
NL80211_NAN_FUNC_FOLLOW_UP_DEST is present when processing
NL80211_CMD_ADD_NAN_FUNCTION request. This request can be issued
by users with CAP_NET_ADMIN privilege and may result in NULL dereference
and a system crash. Add a check for the required attribute presence.
Signed-off-by: Hao Chen <flank3rsky@gmail.com>
linearize
[ Upstream commit 248de22e638f10bd5bfc7624a357f940f66ba137 ]
The original code for __i40e_chk_linearize didn't take into account the
fact that if a fragment is 16K in size or larger it has to be split over 2
descriptors and the smaller of those 2 descriptors will be on the trailing
edge of the transmit. As a result we can get into situations where we didn't
catch requests that could result in a Tx hang.
This patch takes care of that by subtracting the length of all but the
trailing edge of the stale fragment before we test for sum. By doing this
we can guarantee that we have all cases covered, including the case of a
fragment that spans multiple descriptors. We don't need to worry about
checking the inner portions of this since 12K is the maximum aligned DMA
size and that is larger than any MSS will ever be since the MTU limit for
jumbos is something on the order of 9K.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
[ Upstream commit c0bace798436bca0fdc221ff61143f1376a9c3de ]
libc-compat.h aims to prevent symbol collisions between uapi and libc
headers for each supported libc. This requires continuous coordination
between them.
The goal of this commit is to improve the situation for libcs (such as
musl) which are not yet supported and/or do not wish to be explicitly
supported, while not affecting supported libcs. More precisely, with
this commit, unsupported libcs can request the suppression of any
specific uapi definition by defining the correspondings _UAPI_DEF_*
macro as 0. This can fix symbol collisions for them, as long as the
libc headers are included before the uapi headers. Inclusion in the
other order is outside the scope of this commit.
All infrastructure in order to enable this fallback for unsupported
libcs is already in place, except that libc-compat.h unconditionally
defines all _UAPI_DEF_* macros to 1 for all unsupported libcs so that
any previous definitions are ignored. In order to fix this, this commit
merely makes these definitions conditional.
This commit together with the musl libc commit
http://git.musl-libc.org/cgit/musl/commit/?id=04983f2272382af92eb8f8838964ff944fbb8258
fixes for example the following compiler errors when <linux/in6.h> is
included after musl's <netinet/in.h>:
./linux/in6.h:32:8: error: redefinition of 'struct in6_addr'
./linux/in6.h:49:8: error: redefinition of 'struct sockaddr_in6'
./linux/in6.h:59:8: error: redefinition of 'struct ipv6_mreq'
The comments referencing glibc are still correct, but this file is not
only used for glibc any more.
Signed-off-by: Felix Janda <felix.janda@posteo.de>
Reviewed-by: Hauke Mehrtens <hauke@hauke-m.de>
[ Upstream commit 19d859a7205bc59ffc38303eb25ae394f61d21dc ]
In the function ttm_page_alloc_init, kzalloc call is made for variable
_manager, we need to check its return value, it may return NULL.
Signed-off-by: Xiongwei Song <sxwjean@gmail.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit bd30ffc414e55194ed6149fad69a145550cb7c18 ]
This patch adds support for PID 0x9625 of YUGA CLM920-NC5.
YUGA CLM920-NC5 needs to enable QMI_WWAN_QUIRK_DTR before QMI operation.
qmicli -d /dev/cdc-wdm0 -p --dms-get-revision
[/dev/cdc-wdm0] Device revision retrieved:
Revision: 'CLM920_NC5-V1 1 [Oct 23 2016 19:00:00]'
Signed-off-by: SZ Lin (林上智) <sz.lin@moxa.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 0b76aae741abb9d16d2c0e67f8b1e766576f897d ]
This patch adds check so that driver does not disable already
disabled device.
[ 44.637743] advantechwdt: Unexpected close, not stopping watchdog!
[ 44.997548] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input6
[ 45.013419] e1000 0000:00:03.0: disabling already-disabled device
[ 45.013447] ------------[ cut here ]------------
[ 45.014868] WARNING: CPU: 1 PID: 71 at drivers/pci/pci.c:1641 pci_disable_device+0xa1/0x105:
pci_disable_device at drivers/pci/pci.c:1640
[ 45.016171] CPU: 1 PID: 71 Comm: rcu_perf_shutdo Not tainted 4.14.0-01330-g3c07399 #1
[ 45.017197] task: ffff88011bee9e40 task.stack: ffffc90000860000
[ 45.017987] RIP: 0010:pci_disable_device+0xa1/0x105:
[ 45.018603] RSP: 0000:ffffc90000863e30 EFLAGS: 00010286
[ 45.019282] RAX: 0000000000000035 RBX: ffff88013a230008 RCX: 0000000000000000
[ 45.020182] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000203
[ 45.021084] RBP: ffff88013a3f31e8 R08: 0000000000000001 R09: 0000000000000000
[ 45.021986] R10: ffffffff827ec29c R11: 0000000000000002 R12: 0000000000000001
[ 45.022946] R13: ffff88013a230008 R14: ffff880117802b20 R15: ffffc90000863e8f
[ 45.023842] FS: 0000000000000000(0000) GS:ffff88013fd00000(0000) knlGS:0000000000000000
[ 45.024863] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 45.025583] CR2: ffffc900006d4000 CR3: 000000000220f000 CR4: 00000000000006a0
[ 45.026478] Call Trace:
[ 45.026811] __e1000_shutdown+0x1d4/0x1e2:
__e1000_shutdown at drivers/net/ethernet/intel/e1000/e1000_main.c:5162
[ 45.027344] ? rcu_perf_cleanup+0x2a1/0x2a1:
rcu_perf_shutdown at kernel/rcu/rcuperf.c:627
[ 45.027883] e1000_shutdown+0x14/0x3a:
e1000_shutdown at drivers/net/ethernet/intel/e1000/e1000_main.c:5235
[ 45.028351] device_shutdown+0x110/0x1aa:
device_shutdown at drivers/base/core.c:2807
[ 45.028858] kernel_power_off+0x31/0x64:
kernel_power_off at kernel/reboot.c:260
[ 45.029343] rcu_perf_shutdown+0x9b/0xa7:
rcu_perf_shutdown at kernel/rcu/rcuperf.c:637
[ 45.029852] ? __wake_up_common_lock+0xa2/0xa2:
autoremove_wake_function at kernel/sched/wait.c:376
[ 45.030414] kthread+0x126/0x12e:
kthread at kernel/kthread.c:233
[ 45.030834] ? __kthread_bind_mask+0x8e/0x8e:
kthread at kernel/kthread.c:190
[ 45.031399] ? ret_from_fork+0x1f/0x30:
ret_from_fork at arch/x86/entry/entry_64.S:443
[ 45.031883] ? kernel_init+0xa/0xf5:
kernel_init at init/main.c:997
[ 45.032325] ret_from_fork+0x1f/0x30:
[ 45.032777] Code: 00 48 85 ed 75 07 48 8b ab a8 00 00 00 48 8d bb 98 00 00 00 e8 aa d1 11 00 48 89 ea 48 89 c6 48 c7 c7 d8 e4 0b 82 e8 55 7d da ff <0f> ff b9 01 00 00 00 31 d2 be 01 00 00 00 48 c7 c7 f0 b1 61 82
[ 45.035222] ---[ end trace c257137b1b1976ef ]---
[ 45.037838] ACPI: Preparing to enter system sleep state S5
Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit d02fd6e7d2933ede6478a15f9e4ce8a93845824e ]
Because the macvlan_uninit would free the macvlan port, so there is one
double free case in macvlan_common_newlink. When the macvlan port is just
created, then register_netdevice or netdev_upper_dev_link failed and they
would invoke macvlan_uninit. Then it would reach the macvlan_port_destroy
which triggers the double free.
Signed-off-by: Gao Feng <gfree.wind@vip.163.com>
[ Upstream commit 3a3882ff26fbdbaf5f7e13f6a0bccfbf7121041d ]
xfs_qm_init_quotainfo() does not check result of register_shrinker()
which was tagged as __must_check recently, reported by sparse.
Signed-off-by: Aliaksei Karaliou <akaraliou.dev@gmail.com>
[darrick: move xfs_qm_destroy_quotainos nearer xfs_qm_init_quotainos]
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
[ Upstream commit 2196881566225f3c3428d1a5f847a992944daa5b ]
xfs_qm_destroy_quotainfo() does not destroy quotainfo->qi_tree_lock
while destroys quotainfo->qi_quotaofflock.
[ Upstream commit 16ba3defb8bd01a9464ba4820a487f5b196b455b ]
When using enhanced mode for IPoIB, two threads may execute xmit in
parallel to two different TX queues while the target is the same.
In this case, both of them will add the same neighbor to the path's
neigh link list and we might see the following message:
list_add double add: new=ffff88024767a348, prev=ffff88024767a348...
WARNING: lib/list_debug.c:31__list_add_valid+0x4e/0x70
ipoib_start_xmit+0x477/0x680 [ib_ipoib]
dev_hard_start_xmit+0xb9/0x3e0
sch_direct_xmit+0xf9/0x250
__qdisc_run+0x176/0x5d0
__dev_queue_xmit+0x1f5/0xb10
__dev_queue_xmit+0x55/0xb10
Analysis:
Two SKB are scheduled to be transmitted from two cores.
In ipoib_start_xmit, both gets NULL when calling ipoib_neigh_get.
Two calls to neigh_add_path are made. One thread takes the spin-lock
and calls ipoib_neigh_alloc which creates the neigh structure,
then (after the __path_find) the neigh is added to the path's neigh
link list. When the second thread enters the critical section it also
calls ipoib_neigh_alloc but in this case it gets the already allocated
ipoib_neigh structure, which is already linked to the path's neigh
link list and adds it again to the list. Which beside of triggering
the list, it creates a loop in the linked list. This loop leads to
endless loop inside path_rec_completion.
Solution:
Check list_empty(&neigh->list) before adding to the list.
Add a similar fix in "ipoib_multicast.c::ipoib_mcast_send"
Fixes: b63b70d87741 ('IPoIB: Use a private hash table for path lookup in xmit path')
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
Reviewed-by: Alex Vesker <valex@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit 5a371cf87e145b86efd32007e46146e78c1eff6d ]
ibmr.device is being set only after ib_alloc_mr() is successfully complete.
Therefore, in case imlx4_mr_enable() returns with error, the error flow
unwinder calls to mlx4_free_priv_pages(), which uses ibmr.device.
Such usage causes to NULL dereference oops and to fix it, the IB device
should be set in the mr struct earlier stage (e.g. prior to calling
mlx4_free_priv_pages()).
Fixes: 1b2cd0fc673c ("IB/mlx4: Support the new memory registration API")
Signed-off-by: Nitzan Carmi <nitzanc@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
