[ Upstream commit 6d9eb7ebae3d7e951bc0999235ae7028eb4cae4f ]
For negative temperatures, "temp" debugfs is showing wrong values.
Use signed types so proper calculations is done for sub zero
temperatures.
Signed-off-by: Dedy Lansky <dlansky@codeaurora.org>
Signed-off-by: Maya Erez <merez@codeaurora.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
[ Upstream commit 6ccae584014ef7074359eb4151086beef66ecfa9 ]
Firmware ready event may take longer than
current timeout in some scenarios, for example
with multiple RFs connected where each
requires an initial calibration.
Increase the timeout to support these scenarios.
Signed-off-by: Hamad Kadmany <hkadmany@codeaurora.org>
[ Upstream commit 1ca2a92b2a99323f666f1b669b7484df4bda05e4 ]
This reverts commit 72d3200061776264941be1b5a9bb8e926b3b30a5.
We cannot blindly query the direction of all GPIOs when the pins are
first registered. The get_direction callback normally triggers a
read/write to hardware, but we shouldn't be touching the hardware for
an individual GPIO until after it's been properly claimed.
Signed-off-by: Timur Tabi <timur@codeaurora.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
commit 22a07038c0eaf4d1315a493ce66dcd255accba19 upstream.
The Parfait (version 2.1.0) static code analysis tool found the
following NULL pointer derefernce problem.
- drivers/gpu/drm/drm_dp_mst_topology.c
The call to drm_dp_calculate_rad() in function drm_dp_port_setup_pdt()
could result in a NULL pointer being returned to port->mstb due to a
failure to allocate memory for port->mstb.
Signed-off-by: Joe Moriarty <joe.moriarty@oracle.com>
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20180212195144.98323-3-joe.moriarty@oracle.com
commit 864eb1afc60cb43e7df879b97f8ca0d719bbb735 upstream.
Clang warns when multiple pairs of parentheses are used for a single
conditional statement.
drivers/video/fbdev/sis/init301.c:851:42: warning: equality comparison
with extraneous parentheses [-Wparentheses-equality]
} else if((SiS_Pr->SiS_IF_DEF_LVDS == 1) /* ||
drivers/video/fbdev/sis/init301.c:851:42: note: remove extraneous
parentheses around the comparison to silence this warning
drivers/video/fbdev/sis/init301.c:851:42: note: use '=' to turn this
equality comparison into an assignment
1 warning generated.
Remove the parentheses and while we're at it, clean up the commented
code, which has been here since the beginning of git history.
Link: https://github.com/ClangBuiltLinux/linux/issues/118
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Cc: Thomas Winischhofer <thomas@winischhofer.net>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 25faa4bd37c10f19e4b848b9032a17a3d44c6f09 upstream.
At the error path of the firmware loading error, the driver tries to
release the card object and set NULL to drvdata. This may be referred
badly at the possible PM action, as the driver itself is still bound
and the PM callbacks read the card object.
Instead, we continue the probing as if it were no option set. This is
often a better choice than the forced abort, too.
Fixes: 5cb543dba986 ("ALSA: hda - Deferred probing with request_firmware_nowait()")
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=207043
Link: https://lore.kernel.org/r/20200413082034.25166-2-tiwai@suse.de
commit 849f8583e955dbe3a1806e03ecacd5e71cce0a08 upstream.
If the dxfer_len is greater than 256M then the request is invalid and we
need to call sg_remove_request in sg_common_write.
Link: https://lore.kernel.org/r/1586777361-17339-1-git-send-email-huawei.libin@huawei.com
Fixes: f930c7043663 ("scsi: sg: only check for dxfer_len greater than 256M")
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
Signed-off-by: Li Bin <huawei.libin@huawei.com>
commit b401efc120a399dfda1f4d2858a4de365c9b08ef upstream.
If a switch jump table's indirect branch is in a ".cold" subfunction in
.text.unlikely, objtool doesn't detect it, and instead prints a false
warning:
drivers/media/v4l2-core/v4l2-ioctl.o: warning: objtool: v4l_print_format.cold()+0xd6: sibling call from callable instruction with modified stack frame
drivers/hwmon/max6650.o: warning: objtool: max6650_probe.cold()+0xa5: sibling call from callable instruction with modified stack frame
drivers/media/dvb-frontends/drxk_hard.o: warning: objtool: init_drxk.cold()+0x16f: sibling call from callable instruction with modified stack frame
Fix it by comparing the function, instead of the section and offset.
Fixes: 13810435b9a7 ("objtool: Support GCC 8's cold subfunctions")
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Reviewed-by: Miroslav Benes <mbenes@suse.cz>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lkml.kernel.org/r/157c35d42ca9b6354bbb1604fe9ad7d1153ccb21.1585761021.git.jpoimboe@redhat.com
triggering 'snapshot' operation
commit 0bbe7f719985efd9adb3454679ecef0984cb6800 upstream.
Traced event can trigger 'snapshot' operation(i.e. calls snapshot_trigger()
or snapshot_count_trigger()) when register_snapshot_trigger() has completed
registration but doesn't allocate buffer for 'snapshot' event trigger. In
the rare case, 'snapshot' operation always detects the lack of allocated
buffer so make register_snapshot_trigger() allocate buffer first.
trigger-snapshot.tc in kselftest reproduces the issue on slow vm:
cat trace
ftracetest-3028 [002] .... 236.784290: sched_process_fork: comm=ftracetest pid=3028 child_comm=ftracetest child_pid=3036
<...>-2875 [003] .... 240.460335: tracing_snapshot_instance_cond: *** SNAPSHOT NOT ALLOCATED ***
<...>-2875 [003] .... 240.460338: tracing_snapshot_instance_cond: *** stopping trace here! ***
Link: http://lkml.kernel.org/r/20200414015145.66236-1-yangx.jy@cn.fujitsu.com
Cc: stable@vger.kernel.org
Fixes: 93e31ffbf417a ("tracing: Add 'snapshot' event trigger command")
Signed-off-by: Xiao Yang <yangx.jy@cn.fujitsu.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
session
[ Upstream commit 57c46e9f33da530a2485fa01aa27b6d18c28c796 ]
A number of hangs have been reported against the target driver; they are
due to the fact that multiple threads may try to destroy the iscsi session
at the same time. This may be reproduced for example when a "targetcli
iscsi/iqn.../tpg1 disable" command is executed while a logout operation is
underway.
When this happens, two or more threads may end up sleeping and waiting for
iscsit_close_connection() to execute "complete(session_wait_comp)". Only
one of the threads will wake up and proceed to destroy the session
structure, the remaining threads will hang forever.
Note that if the blocked threads are somehow forced to wake up with
complete_all(), they will try to free the same iscsi session structure
destroyed by the first thread, causing double frees, memory corruptions
etc...
With this patch, the threads that want to destroy the iscsi session will
increase the session refcount and will set the "session_close" flag to 1;
then they wait for the driver to close the remaining active connections.
When the last connection is closed, iscsit_close_connection() will wake up
all the threads and will wait for the session's refcount to reach zero;
when this happens, iscsit_close_connection() will destroy the session
structure because no one is referencing it anymore.
INFO: task targetcli:5971 blocked for more than 120 seconds.
Tainted: P OE 4.15.0-72-generic #81~16.04.1
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
targetcli D 0 5971 1 0x00000080
Call Trace:
__schedule+0x3d6/0x8b0
? vprintk_func+0x44/0xe0
schedule+0x36/0x80
schedule_timeout+0x1db/0x370
? __dynamic_pr_debug+0x8a/0xb0
wait_for_completion+0xb4/0x140
? wake_up_q+0x70/0x70
iscsit_free_session+0x13d/0x1a0 [iscsi_target_mod]
iscsit_release_sessions_for_tpg+0x16b/0x1e0 [iscsi_target_mod]
iscsit_tpg_disable_portal_group+0xca/0x1c0 [iscsi_target_mod]
lio_target_tpg_enable_store+0x66/0xe0 [iscsi_target_mod]
configfs_write_file+0xb9/0x120
__vfs_write+0x1b/0x40
vfs_write+0xb8/0x1b0
SyS_write+0x5c/0xe0
do_syscall_64+0x73/0x130
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
Link: https://lore.kernel.org/r/20200313170656.9716-3-mlombard@redhat.com
Reported-by: Matt Coleman <mcoleman@datto.com>
Tested-by: Matt Coleman <mcoleman@datto.com>
Tested-by: Rahul Kundu <rahul.kundu@chelsio.com>
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
[ Upstream commit e49a7d994379278d3353d7ffc7994672752fb0ad ]
iscsit_free_session() is equivalent to iscsit_stop_session() followed by a
call to iscsit_close_session().
Link: https://lore.kernel.org/r/20200313170656.9716-2-mlombard@redhat.com
commit 396d2e878f92ec108e4293f1c77ea3bc90b414ff upstream.
The host reports support for the synthetic feature X86_FEATURE_SSBD
when any of the three following hardware features are set:
CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31]
CPUID.80000008H:EBX.AMD_SSBD[bit 24]
CPUID.80000008H:EBX.VIRT_SSBD[bit 25]
Either of the first two hardware features implies the existence of the
IA32_SPEC_CTRL MSR, but CPUID.80000008H:EBX.VIRT_SSBD[bit 25] does
not. Therefore, CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31] should only be
set in the guest if CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31] or
CPUID.80000008H:EBX.AMD_SSBD[bit 24] is set on the host.
Fixes: 0c54914d0c52a ("KVM: x86: use Intel speculation bugs and features as derived in generic x86 code")
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Jacob Xu <jacobhxu@google.com>
Reviewed-by: Peter Shier <pshier@google.com>
Reported-by: Eric Biggers <ebiggers@kernel.org>
[bwh: Backported to 4.x: adjust indentation]
[ Upstream commit 7690e25302dc7d0cd42b349e746fe44b44a94f2b ]
One can crash dm-flakey by specifying more feature arguments than the
number of features supplied. Checking for null in arg_name avoids
this.
dmsetup create flakey-test --table "0 66076080 flakey /dev/sdb9 0 0 180 2 drop_writes"
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 801674f34ecfed033b062a0f217506b93c8d5e8a upstream.
We do not want to create initialized extents beyond end of file because
for e2fsck it is impossible to distinguish them from a case of corrupted
file size / extent tree and so it complains like:
Inode 12, i_size is 147456, should be 163840. Fix? no
Code in ext4_ext_convert_to_initialized() and
ext4_split_convert_extents() try to make sure it does not create
initialized extents beyond inode size however they check against
inode->i_size which is wrong. They should instead check against
EXT4_I(inode)->i_disksize which is the current inode size on disk.
That's what e2fsck is going to see in case of crash before all dirty
data is written. This bug manifests as generic/456 test failure (with
recent enough fstests where fsx got fixed to properly pass
FALLOC_KEEP_SIZE_FL flags to the kernel) when run with dioread_lock
mount option.
CC: stable@vger.kernel.org
Fixes: 21ca087a3891 ("ext4: Do not zero out uninitialized extents beyond i_size")
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Link: https://lore.kernel.org/r/20200331105016.8674-1-jack@suse.cz
commit 7ea862048317aa76d0f22334202779a25530980c upstream.
syzbot reports a warning:
precision 33020 too large
WARNING: CPU: 0 PID: 9618 at lib/vsprintf.c:2471 set_precision+0x150/0x180 lib/vsprintf.c:2471
vsnprintf+0xa7b/0x19a0 lib/vsprintf.c:2547
kvasprintf+0xb2/0x170 lib/kasprintf.c:22
kasprintf+0xbb/0xf0 lib/kasprintf.c:59
hwsim_del_radio_nl+0x63a/0x7e0 drivers/net/wireless/mac80211_hwsim.c:3625
genl_family_rcv_msg_doit net/netlink/genetlink.c:672 [inline]
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Thus it seems that kasprintf() with "%.*s" format can not be used for
duplicating a string with arbitrary length. Replace it with kstrndup().
Note that later this string is limited to NL80211_WIPHY_NAME_MAXLEN == 64,
but the code is simpler this way.
Reported-by: syzbot+6693adf1698864d21734@syzkaller.appspotmail.com
Reported-by: syzbot+a4aee3f42d7584d76761@syzkaller.appspotmail.com
Cc: stable@kernel.org
Link: https://lore.kernel.org/r/20200410123257.14559-1-tuomas.tynkkynen@iki.fi
[johannes: add note about length limit]
commit 4d4225fc228e46948486d8b8207955f0c031b92e upstream.
Previously we would set the reloc root's last snapshot to transid - 1.
However there was a problem with doing this, and we changed it to
setting the last snapshot to the generation of the commit node of the fs
root.
This however broke should_ignore_root(). The assumption is that if we
are in a generation newer than when the reloc root was created, then we
would find the reloc root through normal backref lookups, and thus can
ignore any fs roots we find with an old enough reloc root.
Now that the last snapshot could be considerably further in the past
than before, we'd end up incorrectly ignoring an fs root. Thus we'd
find no nodes for the bytenr we were searching for, and we'd fail to
relocate anything. We'd loop through the relocate code again and see
that there were still used space in that block group, attempt to
relocate those bytenr's again, fail in the same way, and just loop like
this forever. This is tricky in that we have to not modify the fs root
at all during this time, so we need to have a block group that has data
in this fs root that is not shared by any other root, which is why this
has been difficult to reproduce.
Fixes: 054570a1dc94 ("Btrfs: fix relocation incorrectly dropping data references")
CC: stable@vger.kernel.org # 4.9+
Reviewed-by: Filipe Manana <fdmanana@suse.com>
Signed-off-by: Josef Bacik <josef@toxicpanda.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit 3507245b82b4362dc9721cbc328644905a3efa22 upstream.
The mapping table may contain also ignore_ctl_error flag for devices
that are known to behave wild. Since this flag always writes the
card's own ignore_ctl_error flag, it overrides the value already set
by the module option, so it doesn't follow user's expectation.
Let's fix the code not to clear the flag that has been set by user.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=206873
Cc: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20200412081331.4742-3-tiwai@suse.de
commit 3025571edd9df653e1ad649f0638368a39d1bbb5 upstream.
Currently function sst_platform_get_resources always returns zero and
error return codes set by the function are never returned. Fix this
by returning the error return code in variable ret rather than the
hard coded zero.
Addresses-Coverity: ("Unused value")
Fixes: f533a035e4da ("ASoC: Intel: mrfld - create separate module for pci part")
Acked-by: Cezary Rojewski <cezary.rojewski@intel.com>
Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Link: https://lore.kernel.org/r/20200208220720.36657-1-colin.king@canonical.com
Signed-off-by: Mark Brown <broonie@kernel.org>
commit f5e056e1e46fcbb5f74ce560792aeb7d57ce79e6 upstream.
The check on p->sink looks bogus, I believe it should be p->source
since the following code blocks are related to p->source. Fix
this by replacing p->sink with p->source.
Fixes: 24c8d14192cc ("ASoC: Intel: mrfld: add DSP core controls")
Addresses-Coverity: ("Copy-paste error")
Link: https://lore.kernel.org/r/20191119113640.166940-1-colin.king@canonical.com
commit b9c538da4e52a7b79dfcf4cfa487c46125066dfb upstream.
If ext4_fill_super detects an invalid number of inodes per group, the
resulting error message printed the number of blocks per group, rather
than the number of inodes per group. Fix it to print the correct value.
Fixes: cd6bb35bf7f6d ("ext4: use more strict checks for inodes_per_block on mount")
Link: https://lore.kernel.org/r/8be03355983a08e5d4eed480944613454d7e2550.1585434649.git.josh@joshtriplett.org
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
commit df41460a21b06a76437af040d90ccee03888e8e5 upstream.
ext4_fill_super doublechecks the number of groups before mounting; if
that check fails, the resulting error message prints the group count
from the ext4_sb_info sbi, which hasn't been set yet. Print the freshly
computed group count instead (which at that point has just been computed
in "blocks_count").
Fixes: 4ec1102813798 ("ext4: Add sanity checks for the superblock before mounting the filesystem")
Link: https://lore.kernel.org/r/8b957cd1513fcc4550fe675c10bcce2175c33a49.1585431964.git.josh@joshtriplett.org
commit 780f66e59231fcf882f36c63f287252ee47cc75a upstream.
Improve comments in jbd2_journal_commit_transaction() to describe why
we don't need to clear the buffer_mapped bit for freeing file mapping
buffers whose page mapping is NULL.
Link: https://lore.kernel.org/r/20200217112706.20085-1-yi.zhang@huawei.com
Fixes: c96dceeabf76 ("jbd2: do not clear the BH_Mapped flag when forgetting a metadata buffer")
Suggested-by: Jan Kara <jack@suse.cz>
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
commit c63d6099a7959ecc919b2549dc6b71f53521f819 upstream.
The async version of ufshcd_hold(async == true), which is only called in
queuecommand path as for now, is expected to work in atomic context, thus
it should not sleep or schedule out. When it runs into the condition that
clocks are ON but link is still in hibern8 state, it should bail out
without flushing the clock ungate work.
Fixes: f2a785ac2312 ("scsi: ufshcd: Fix race between clk scaling and ungate work")
Link: https://lore.kernel.org/r/1581392451-28743-6-git-send-email-cang@codeaurora.org
Reviewed-by: Hongwu Su <hongwus@codeaurora.org>
Reviewed-by: Asutosh Das <asutoshd@codeaurora.org>
Reviewed-by: Bean Huo <beanhuo@micron.com>
Reviewed-by: Stanley Chu <stanley.chu@mediatek.com>
Signed-off-by: Can Guo <cang@codeaurora.org>
[ Upstream commit 03e2a984b6165621f287fadf5f4b5cd8b58dcaba ]
The behaviour for what is considered an anycast address changed in
commit 45e4fd26683c ("ipv6: Only create RTF_CACHE routes after
encountering pmtu exception"). This now considers the first
address in a subnet where there is a route via a gateway
to be an anycast address.
This breaks path MTU discovery and traceroutes when a host in a
remote network uses the address at the start of a prefix
(eg 2600:: advertised as 2600::/48 in the DFZ) as ICMP errors
will not be sent to anycast addresses.
This patch excludes any routes with a gateway, or via point to
point links, like the behaviour previously from
rt6_is_gw_or_nonexthop in net/ipv6/route.c.
This can be tested with:
ip link add v1 type veth peer name v2
ip netns add test
ip netns exec test ip link set lo up
ip link set v2 netns test
ip link set v1 up
ip netns exec test ip link set v2 up
ip addr add 2001:db8::1/64 dev v1 nodad
ip addr add 2001:db8:100:: dev lo nodad
ip netns exec test ip addr add 2001:db8::2/64 dev v2 nodad
ip netns exec test ip route add unreachable 2001:db8:1::1
ip netns exec test ip route add 2001:db8:100::/64 via 2001:db8::1
ip netns exec test sysctl net.ipv6.conf.all.forwarding=1
ip route add 2001:db8:1::1 via 2001:db8::2
ping -I 2001:db8::1 2001:db8:1::1 -c1
ping -I 2001:db8:100:: 2001:db8:1::1 -c1
ip addr delete 2001:db8:100:: dev lo
ip netns delete test
Currently the first ping will get back a destination unreachable ICMP
error, but the second will never get a response, with "icmp6_send:
acast source" logged. After this patch, both get destination
unreachable ICMP replies.
Fixes: 45e4fd26683c ("ipv6: Only create RTF_CACHE routes after encountering pmtu exception")
Signed-off-by: Tim Stallard <code@timstallard.me.uk>
[ Upstream commit 6dbf02acef69b0742c238574583b3068afbd227c ]
If the local node id(qrtr_local_nid) is not modified after its
initialization, it equals to the broadcast node id(QRTR_NODE_BCAST).
So the messages from local node should not be taken as broadcast
and keep the process going to send them out anyway.
The definitions are as follow:
static unsigned int qrtr_local_nid = NUMA_NO_NODE;
Fixes: fdf5fd397566 ("net: qrtr: Broadcast messages only from control port")
Signed-off-by: Wang Wenhu <wenhu.wang@vivo.com>
[ Upstream commit 690cc86321eb9bcee371710252742fb16fe96824 ]
When CONFIG_IP_MULTICAST is not set and multicast ip is added to the device
with autojoin flag or when multicast ip is deleted kernel will crash.
steps to reproduce:
ip addr add 224.0.0.0/32 dev eth0
ip addr del 224.0.0.0/32 dev eth0
or
ip addr add 224.0.0.0/32 dev eth0 autojoin
Unable to handle kernel NULL pointer dereference at virtual address 0000000000000088
pc : _raw_write_lock_irqsave+0x1e0/0x2ac
lr : lock_sock_nested+0x1c/0x60
Call trace:
ip_mc_config.isra.28+0x50/0xe0
inet_rtm_deladdr+0x1a8/0x1f0
rtnetlink_rcv_msg+0x120/0x350
netlink_rcv_skb+0x58/0x120
rtnetlink_rcv+0x14/0x20
netlink_unicast+0x1b8/0x270
netlink_sendmsg+0x1a0/0x3b0
____sys_sendmsg+0x248/0x290
___sys_sendmsg+0x80/0xc0
__sys_sendmsg+0x68/0xc0
__arm64_sys_sendmsg+0x20/0x30
el0_svc_common.constprop.2+0x88/0x150
do_el0_svc+0x20/0x80
el0_sync_handler+0x118/0x190
el0_sync+0x140/0x180
Fixes: 93a714d6b53d ("multicast: Extend ip address command to enable multicast group join/leave on")
Signed-off-by: Taras Chornyi <taras.chornyi@plvision.eu>
Signed-off-by: Vadym Kochan <vadym.kochan@plvision.eu>
[ Upstream commit 4faab8c446def7667adf1f722456c2f4c304069c ]
In the current hsr code, only 0 and 1 protocol versions are valid.
But current hsr code doesn't check the version, which is received by
userspace.
Test commands:
ip link add dummy0 type dummy
ip link add dummy1 type dummy
ip link add hsr0 type hsr slave1 dummy0 slave2 dummy1 version 4
In the test commands, version 4 is invalid.
So, the command should be failed.
After this patch, following error will occur.
"Error: hsr: Only versions 0..1 are supported."
Fixes: ee1c27977284 ("net/hsr: Added support for HSR v1")
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
[ Upstream commit fb945c95a482200876993977008b67ea658bd938 ]
While the commit 2b8bd606b1e6 ("mfd: dln2: More sanity checking for endpoints")
tries to harden the sanity checks it made at the same time a regression,
i.e. mixed in and out endpoints. Obviously it should have been not tested on
real hardware at that time, but unluckily it didn't happen.
So, fix above mentioned typo and make device being enumerated again.
While here, introduce an enumerator for magic values to prevent similar issue
to happen in the future.
Fixes: 2b8bd606b1e6 ("mfd: dln2: More sanity checking for endpoints")
Cc: Oliver Neukum <oneukum@suse.com>
[ Upstream commit 85dc2c65e6c975baaf36ea30f2ccc0a36a8c8add ]
drivers/misc/echo/echo.c:384:27: warning: equality comparison with
if ((ec->nonupdate_dwell == 0)) {
drivers/misc/echo/echo.c:384:27: note: remove extraneous parentheses
drivers/misc/echo/echo.c:384:27: note: use '=' to turn this equality
Remove them and while we're at it, simplify the zero check as '!var' is
used more than 'var == 0'.
Reported-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
[ Upstream commit aa4113340ae6c2811e046f08c2bc21011d20a072 ]
In the current implementation, the call to loadcam_multi() is wrapped
between switch_to_as1() and restore_to_as0() calls so, when it tries
to create its own temporary AS=1 TLB1 entry, it ends up duplicating
the existing one created by switch_to_as1(). Add a check to skip
creating the temporary entry if already running in AS=1.
Fixes: d9e1831a4202 ("powerpc/85xx: Load all early TLB entries at once")
Cc: stable@vger.kernel.org # v4.4+
Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com>
Acked-by: Scott Wood <oss@buserror.net>
Link: https://lore.kernel.org/r/20200123111914.2565-1-laurentiu.tudor@nxp.com
[ Upstream commit 32830a0534700f86366f371b150b17f0f0d140d7 ]
The wait_event() function is used to detect command completion.
When send_guid_cmd() returns an error, smi_send() has not been
called to send data. Therefore, wait_event() should not be used
on the error path, otherwise it will cause the following warning:
[ 1361.588808] systemd-udevd D 0 1501 1436 0x00000004
[ 1361.588813] ffff883f4b1298c0 0000000000000000 ffff883f4b188000 ffff887f7e3d9f40
[ 1361.677952] ffff887f64bd4280 ffffc90037297a68 ffffffff8173ca3b ffffc90000000010
[ 1361.767077] 00ffc90037297ad0 ffff887f7e3d9f40 0000000000000286 ffff883f4b188000
[ 1361.856199] Call Trace:
[ 1361.885578] [<ffffffff8173ca3b>] ? __schedule+0x23b/0x780
[ 1361.951406] [<ffffffff8173cfb6>] schedule+0x36/0x80
[ 1362.010979] [<ffffffffa071f178>] get_guid+0x118/0x150 [ipmi_msghandler]
[ 1362.091281] [<ffffffff810d5350>] ? prepare_to_wait_event+0x100/0x100
[ 1362.168533] [<ffffffffa071f755>] ipmi_register_smi+0x405/0x940 [ipmi_msghandler]
[ 1362.258337] [<ffffffffa0230ae9>] try_smi_init+0x529/0x950 [ipmi_si]
[ 1362.334521] [<ffffffffa022f350>] ? std_irq_setup+0xd0/0xd0 [ipmi_si]
[ 1362.411701] [<ffffffffa0232bd2>] init_ipmi_si+0x492/0x9e0 [ipmi_si]
[ 1362.487917] [<ffffffffa0232740>] ? ipmi_pci_probe+0x280/0x280 [ipmi_si]
[ 1362.568219] [<ffffffff810021a0>] do_one_initcall+0x50/0x180
[ 1362.636109] [<ffffffff812231b2>] ? kmem_cache_alloc_trace+0x142/0x190
[ 1362.714330] [<ffffffff811b2ae1>] do_init_module+0x5f/0x200
[ 1362.781208] [<ffffffff81123ca8>] load_module+0x1898/0x1de0
[ 1362.848069] [<ffffffff811202e0>] ? __symbol_put+0x60/0x60
[ 1362.913886] [<ffffffff8130696b>] ? security_kernel_post_read_file+0x6b/0x80
[ 1362.998514] [<ffffffff81124465>] SYSC_finit_module+0xe5/0x120
[ 1363.068463] [<ffffffff81124465>] ? SYSC_finit_module+0xe5/0x120
[ 1363.140513] [<ffffffff811244be>] SyS_finit_module+0xe/0x10
[ 1363.207364] [<ffffffff81003c04>] do_syscall_64+0x74/0x180
Fixes: 50c812b2b951 ("[PATCH] ipmi: add full sysfs support")
Signed-off-by: Wen Yang <wenyang@linux.alibaba.com>
Cc: Corey Minyard <minyard@acm.org>
Cc: openipmi-developer@lists.sourceforge.net
Cc: stable@vger.kernel.org # 2.6.17-
Message-Id: <20200403090408.58745-1-wenyang@linux.alibaba.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
[ Upstream commit ea36ec8623f56791c6ff6738d0509b7920f85220 ]
drm_pci_alloc/drm_pci_free are very thin wrappers around the core dma
facilities, and we have no special reason within the drm layer to behave
differently. In particular, since
commit de09d31dd38a50fdce106c15abd68432eebbd014
Author: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Date: Fri Jan 15 16:51:42 2016 -0800
page-flags: define PG_reserved behavior on compound pages
As far as I can see there's no users of PG_reserved on compound pages.
Let's use PF_NO_COMPOUND here.
it has been illegal to combine GFP_COMP with SetPageReserved, so lets
stop doing both and leave the dma layer to its own devices.
Reported-by: Taketo Kabe
Bug: https://gitlab.freedesktop.org/drm/intel/issues/1027
Fixes: de09d31dd38a ("page-flags: define PG_reserved behavior on compound pages")
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: <stable@vger.kernel.org> # v4.5+
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200202171635.4039044-1-chris@chris-wilson.co.uk
[ Upstream commit 8732fe46b20c951493bfc4dba0ad08efdf41de81 ]
The issues caused by:
commit 64e62bdf04ab ("drm/dp_mst: Remove VCPI while disabling topology
mgr")
Prompted me to take a closer look at how we clear the payload state in
general when disabling the topology, and it turns out there's actually
two subtle issues here.
The first is that we're not grabbing &mgr.payload_lock when clearing the
payloads in drm_dp_mst_topology_mgr_set_mst(). Seeing as the canonical
lock order is &mgr.payload_lock -> &mgr.lock (because we always want
&mgr.lock to be the inner-most lock so topology validation always
works), this makes perfect sense. It also means that -technically- there
could be racing between someone calling
drm_dp_mst_topology_mgr_set_mst() to disable the topology, along with a
modeset occurring that's modifying the payload state at the same time.
The second is the more obvious issue that Wayne Lin discovered, that
we're not clearing proposed_payloads when disabling the topology.
I actually can't see any obvious places where the racing caused by the
first issue would break something, and it could be that some of our
higher-level locks already prevent this by happenstance, but better safe
then sorry. So, let's make it so that drm_dp_mst_topology_mgr_set_mst()
first grabs &mgr.payload_lock followed by &mgr.lock so that we never
race when modifying the payload state. Then, we also clear
proposed_payloads to fix the original issue of enabling a new topology
with a dirty payload state. This doesn't clear any of the drm_dp_vcpi
structures, but those are getting destroyed along with the ports anyway.
Changes since v1:
* Use sizeof(mgr->payloads[0])/sizeof(mgr->proposed_vcpis[0]) instead -
vsyrjala
Cc: Sean Paul <sean@poorly.run>
Cc: Wayne Lin <Wayne.Lin@amd.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Lyude Paul <lyude@redhat.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200122194321.14953-1-lyude@redhat.com
[ Upstream commit f0cc2cd70164efe8f75c5d99560f0f69969c72e4 ]
During unmount we can have a job from the delayed inode items work queue
still running, that can lead to at least two bad things:
1) A crash, because the worker can try to create a transaction just
after the fs roots were freed;
2) A transaction leak, because the worker can create a transaction
before the fs roots are freed and just after we committed the last
transaction and after we stopped the transaction kthread.
A stack trace example of the crash:
[79011.691214] kernel BUG at lib/radix-tree.c:982!
[79011.692056] invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC PTI
[79011.693180] CPU: 3 PID: 1394 Comm: kworker/u8:2 Tainted: G W 5.6.0-rc2-btrfs-next-54 #2
[79011.696789] Workqueue: btrfs-delayed-meta btrfs_work_helper [btrfs]
[79011.697904] RIP: 0010:radix_tree_tag_set+0xe7/0x170
[79011.702014] RSP: 0018:ffffb3c84a317ca0 EFLAGS: 00010293
[79011.702949] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[79011.704202] RDX: ffffb3c84a317cb0 RSI: ffffb3c84a317ca8 RDI: ffff8db3931340a0
[79011.705463] RBP: 0000000000000005 R08: 0000000000000005 R09: ffffffff974629d0
[79011.706756] R10: ffffb3c84a317bc0 R11: 0000000000000001 R12: ffff8db393134000
[79011.708010] R13: ffff8db3931340a0 R14: ffff8db393134068 R15: 0000000000000001
[79011.709270] FS: 0000000000000000(0000) GS:ffff8db3b6a00000(0000) knlGS:0000000000000000
[79011.710699] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[79011.711710] CR2: 00007f22c2a0a000 CR3: 0000000232ad4005 CR4: 00000000003606e0
[79011.712958] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[79011.714205] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[79011.715448] Call Trace:
[79011.715925] record_root_in_trans+0x72/0xf0 [btrfs]
[79011.716819] btrfs_record_root_in_trans+0x4b/0x70 [btrfs]
[79011.717925] start_transaction+0xdd/0x5c0 [btrfs]
[79011.718829] btrfs_async_run_delayed_root+0x17e/0x2b0 [btrfs]
[79011.719915] btrfs_work_helper+0xaa/0x720 [btrfs]
[79011.720773] process_one_work+0x26d/0x6a0
[79011.721497] worker_thread+0x4f/0x3e0
[79011.722153] ? process_one_work+0x6a0/0x6a0
[79011.722901] kthread+0x103/0x140
[79011.723481] ? kthread_create_worker_on_cpu+0x70/0x70
[79011.724379] ret_from_fork+0x3a/0x50
The following diagram shows a sequence of steps that lead to the crash
during ummount of the filesystem:
CPU 1 CPU 2 CPU 3
btrfs_punch_hole()
btrfs_btree_balance_dirty()
btrfs_balance_delayed_items()
--> sees
fs_info->delayed_root->items
with value 200, which is greater
than
BTRFS_DELAYED_BACKGROUND (128)
and smaller than
BTRFS_DELAYED_WRITEBACK (512)
btrfs_wq_run_delayed_node()
--> queues a job for
fs_info->delayed_workers to run
btrfs_async_run_delayed_root()
--> job queued by CPU 1
--> starts picking and running
delayed nodes from the
prepare_list list
close_ctree()
btrfs_delete_unused_bgs()
btrfs_commit_super()
btrfs_join_transaction()
--> gets transaction N
btrfs_commit_transaction(N)
--> set transaction state
to TRANTS_STATE_COMMIT_START
btrfs_first_prepared_delayed_node()
--> picks delayed node X through
the prepared_list list
btrfs_run_delayed_items()
btrfs_first_delayed_node()
--> also picks delayed node X
but through the node_list
list
__btrfs_commit_inode_delayed_items()
--> runs all delayed items from
this node and drops the
node's item count to 0
through call to
btrfs_release_delayed_inode()
--> finishes running any remaining
delayed nodes
--> finishes transaction commit
--> stops cleaner and transaction threads
btrfs_free_fs_roots()
--> frees all roots and removes them
from the radix tree
fs_info->fs_roots_radix
start_transaction()
btrfs_record_root_in_trans()
radix_tree_tag_set()
--> crashes because
the root is not in
the radix tree
anymore
If the worker is able to call btrfs_join_transaction() before the unmount
task frees the fs roots, we end up leaking a transaction and all its
resources, since after the call to btrfs_commit_super() and stopping the
transaction kthread, we don't expect to have any transaction open anymore.
When this situation happens the worker has a delayed node that has no
more items to run, since the task calling btrfs_run_delayed_items(),
which is doing a transaction commit, picks the same node and runs all
its items first.
We can not wait for the worker to complete when running delayed items
through btrfs_run_delayed_items(), because we call that function in
several phases of a transaction commit, and that could cause a deadlock
because the worker calls btrfs_join_transaction() and the task doing the
transaction commit may have already set the transaction state to
TRANS_STATE_COMMIT_DOING.
Also it's not possible to get into a situation where only some of the
items of a delayed node are added to the fs/subvolume tree in the current
transaction and the remaining ones in the next transaction, because when
running the items of a delayed inode we lock its mutex, effectively
waiting for the worker if the worker is running the items of the delayed
node already.
Since this can only cause issues when unmounting a filesystem, fix it in
a simple way by waiting for any jobs on the delayed workers queue before
calling btrfs_commit_supper() at close_ctree(). This works because at this
point no one can call btrfs_btree_balance_dirty() or
btrfs_balance_delayed_items(), and if we end up waiting for any worker to
complete, btrfs_commit_super() will commit the transaction created by the
worker.
CC: stable@vger.kernel.org # 4.4+
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
commit c7def7fbdeaa25feaa19caf4a27c5d10bd8789e4 upstream.
In restore_tm_sigcontexts() we take the trap value directly from the
user sigcontext with no checking:
err |= __get_user(regs->trap, &sc->gp_regs[PT_TRAP]);
This means we can be in the kernel with an arbitrary regs->trap value.
Although that's not immediately problematic, there is a risk we could
trigger one of the uses of CHECK_FULL_REGS():
#define CHECK_FULL_REGS(regs) BUG_ON(regs->trap & 1)
It can also cause us to unnecessarily save non-volatile GPRs again in
save_nvgprs(), which shouldn't be problematic but is still wrong.
It's also possible it could trick the syscall restart machinery, which
relies on regs->trap not being == 0xc00 (see 9a81c16b5275 ("powerpc:
fix double syscall restarts")), though I haven't been able to make
that happen.
Finally it doesn't match the behaviour of the non-TM case, in
restore_sigcontext() which zeroes regs->trap.
So change restore_tm_sigcontexts() to zero regs->trap.
This was discovered while testing Nick's upcoming rewrite of the
syscall entry path. In that series the call to save_nvgprs() prior to
signal handling (do_notify_resume()) is removed, which leaves the
low-bit of regs->trap uncleared which can then trigger the FULL_REGS()
WARNs in setup_tm_sigcontexts().
Fixes: 2b0a576d15e0 ("powerpc: Add new transactional memory state to the signal context")
Cc: stable@vger.kernel.org # v3.9+
Link: https://lore.kernel.org/r/20200401023836.3286664-1-mpe@ellerman.id.au
ATA_DFLAG_DETACH is set
commit 8305f72f952cff21ce8109dc1ea4b321c8efc5af upstream.
During system resume from suspend, this can be observed on ASM1062 PMP
controller:
ata10.01: SATA link down (SStatus 0 SControl 330)
ata10.02: hard resetting link
ata10.02: SATA link down (SStatus 0 SControl 330)
ata10.00: configured for UDMA/133
Kernel panic - not syncing: stack-protector: Kernel
in: sata_pmp_eh_recover+0xa2b/0xa40
CPU: 2 PID: 230 Comm: scsi_eh_9 Tainted: P OE
#49-Ubuntu
Hardware name: System manufacturer System Product
1001 12/10/2017
Call Trace:
dump_stack+0x63/0x8b
panic+0xe4/0x244
? sata_pmp_eh_recover+0xa2b/0xa40
__stack_chk_fail+0x19/0x20
? ahci_do_softreset+0x260/0x260 [libahci]
? ahci_do_hardreset+0x140/0x140 [libahci]
? ata_phys_link_offline+0x60/0x60
? ahci_stop_engine+0xc0/0xc0 [libahci]
sata_pmp_error_handler+0x22/0x30
ahci_error_handler+0x45/0x80 [libahci]
ata_scsi_port_error_handler+0x29b/0x770
? ata_scsi_cmd_error_handler+0x101/0x140
ata_scsi_error+0x95/0xd0
? scsi_try_target_reset+0x90/0x90
scsi_error_handler+0xd0/0x5b0
kthread+0x121/0x140
? scsi_eh_get_sense+0x200/0x200
ret_from_fork+0x22/0x40
Kernel Offset: 0xcc00000 from 0xffffffff81000000
(relocation range: 0xffffffff80000000-0xffffffffbfffffff)
Since sata_pmp_eh_recover_pmp() doens't set rc when ATA_DFLAG_DETACH is
set, sata_pmp_eh_recover() continues to run. During retry it triggers
the stack protector.
Set correct rc in sata_pmp_eh_recover_pmp() to let sata_pmp_eh_recover()
jump to pmp_fail directly.
BugLink: https://bugs.launchpad.net/bugs/1821434
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit 25efb2ffdf991177e740b2f63e92b4ec7d310a92 upstream.
When removing files containing extended attributes, the hfsplus driver may
remove the wrong entries from the attributes b-tree, causing major
filesystem damage and in some cases even kernel crashes.
To remove a file, all its extended attributes have to be removed as well.
The driver does this by looking up all keys in the attributes b-tree with
the cnid of the file. Each of these entries then gets deleted using the
key used for searching, which doesn't contain the attribute's name when it
should. Since the key doesn't contain the name, the deletion routine will
not find the correct entry and instead remove the one in front of it. If
parent nodes have to be modified, these become corrupt as well. This
causes invalid links and unsorted entries that not even macOS's fsck_hfs
is able to fix.
To fix this, modify the search key before an entry is deleted from the
attributes b-tree by copying the found entry's key into the search key,
therefore ensuring that the correct entry gets removed from the tree.
Signed-off-by: Simon Gander <simon@tuxera.com>
Reviewed-by: Anton Altaparmakov <anton@tuxera.com>
Link: http://lkml.kernel.org/r/20200327155541.1521-1-simon@tuxera.com
commit d0a72efac89d1c35ac55197895201b7b94c5e6ef upstream.
The cpufreq driver has a use-after-free that we can hit if:
a) There's an OCC message pending when the notifier is registered, and
b) The cpufreq driver fails to register with the core.
When a) occurs the notifier schedules a workqueue item to handle the
message. The backing work_struct is located on chips[].throttle and
when b) happens we clean up by freeing the array. Once we get to
the (now free) queued item and the kernel crashes.
Fixes: c5e29ea7ac14 ("cpufreq: powernv: Fix bugs in powernv_cpufreq_{init/exit}")
Cc: stable@vger.kernel.org # v4.6+
Signed-off-by: Oliver O'Halloran <oohall@gmail.com>
Reviewed-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
Link: https://lore.kernel.org/r/20200206062622.28235-1-oohall@gmail.com
commit d7d27cfc5cf0766a26a8f56868c5ad5434735126 upstream.
Patch series "module autoloading fixes and cleanups", v5.
This series fixes a bug where request_module() was reporting success to
kernel code when module autoloading had been completely disabled via
'echo > /proc/sys/kernel/modprobe'.
It also addresses the issues raised on the original thread
(https://lkml.kernel.org/lkml/20200310223731.126894-1-ebiggers@kernel.org/T/#u)
bydocumenting the modprobe sysctl, adding a self-test for the empty path
case, and downgrading a user-reachable WARN_ONCE().
This patch (of 4):
It's long been possible to disable kernel module autoloading completely
(while still allowing manual module insertion) by setting
/proc/sys/kernel/modprobe to the empty string.
This can be preferable to setting it to a nonexistent file since it
avoids the overhead of an attempted execve(), avoids potential
deadlocks, and avoids the call to security_kernel_module_request() and
thus on SELinux-based systems eliminates the need to write SELinux rules
to dontaudit module_request.
However, when module autoloading is disabled in this way,
request_module() returns 0. This is broken because callers expect 0 to
mean that the module was successfully loaded.
Apparently this was never noticed because this method of disabling
module autoloading isn't used much, and also most callers don't use the
return value of request_module() since it's always necessary to check
whether the module registered its functionality or not anyway.
But improperly returning 0 can indeed confuse a few callers, for example
get_fs_type() in fs/filesystems.c where it causes a WARNING to be hit:
if (!fs && (request_module("fs-%.*s", len, name) == 0)) {
fs = __get_fs_type(name, len);
WARN_ONCE(!fs, "request_module fs-%.*s succeeded, but still no fs?\n", len, name);
This is easily reproduced with:
mount -t NONEXISTENT none /
It causes:
request_module fs-NONEXISTENT succeeded, but still no fs?
WARNING: CPU: 1 PID: 1106 at fs/filesystems.c:275 get_fs_type+0xd6/0xf0
This should actually use pr_warn_once() rather than WARN_ONCE(), since
it's also user-reachable if userspace immediately unloads the module.
Regardless, request_module() should correctly return an error when it
fails. So let's make it return -ENOENT, which matches the error when
the modprobe binary doesn't exist.
I've also sent patches to document and test this case.
Reviewed-by: Jessica Yu <jeyu@kernel.org>
Acked-by: Luis Chamberlain <mcgrof@kernel.org>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Jeff Vander Stoep <jeffv@google.com>
Cc: Ben Hutchings <benh@debian.org>
Cc: Josh Triplett <josh@joshtriplett.org>
Link: http://lkml.kernel.org/r/20200310223731.126894-1-ebiggers@kernel.org
Link: http://lkml.kernel.org/r/20200312202552.241885-1-ebiggers@kernel.org
commit ebc68cedec4aead47d8d11623d013cca9bf8e825 upstream.
The Acer Aspire 5738z has a button to disable (and re-enable) the
touchpad next to the touchpad.
When this button is pressed a LED underneath indicates that the touchpad
is disabled (and an event is send to userspace and GNOME shows its
touchpad enabled / disable OSD thingie).
So far so good, but after re-enabling the touchpad it no longer works.
The laptop does not have an external ps2 port, so mux mode is not needed
and disabling mux mode fixes the touchpad no longer working after toggling
it off and back on again, so lets add this laptop model to the nomux list.
Link: https://lore.kernel.org/r/20200331123947.318908-1-hdegoede@redhat.com
commit 6c7c851f1b666a8a455678a0b480b9162de86052 upstream.
Show the full diag statistic table and not just parts of it.
The issue surfaced in a KVM guest with a number of vcpus
defined smaller than NR_DIAG_STAT.
Fixes: 1ec2772e0c3c ("s390/diag: add a statistic for diagnose calls")
Signed-off-by: Michael Mueller <mimu@linux.ibm.com>
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
commit 783fda856e1034dee90a873f7654c418212d12d7 upstream.
Linux fallocate(2) with FALLOC_FL_PUNCH_HOLE mode set, its offset can
exceed the inode size. Ocfs2 now doesn't allow that offset beyond inode
size. This restriction is not necessary and violates fallocate(2)
semantics.
If fallocate(2) offset is beyond inode size, just return success and do
nothing further.
Otherwise, ocfs2 will crash the kernel.
kernel BUG at fs/ocfs2//alloc.c:7264!
ocfs2_truncate_inline+0x20f/0x360 [ocfs2]
ocfs2_remove_inode_range+0x23c/0xcb0 [ocfs2]
__ocfs2_change_file_space+0x4a5/0x650 [ocfs2]
ocfs2_fallocate+0x83/0xa0 [ocfs2]
vfs_fallocate+0x148/0x230
SyS_fallocate+0x48/0x80
do_syscall_64+0x79/0x170
Signed-off-by: Changwei Ge <chge@linux.alibaba.com>
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Cc: Mark Fasheh <mark@fasheh.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
Cc: Changwei Ge <gechangwei@live.cn>
Cc: Gang He <ghe@suse.com>
Cc: Jun Piao <piaojun@huawei.com>
Link: http://lkml.kernel.org/r/20200407082754.17565-1-chge@linux.alibaba.com
commit 28936b62e71e41600bab319f262ea9f9b1027629 upstream.
inode->i_blocks could be accessed concurrently as noticed by KCSAN,
BUG: KCSAN: data-race in ext4_do_update_inode [ext4] / inode_add_bytes
write to 0xffff9a00d4b982d0 of 8 bytes by task 22100 on cpu 118:
inode_add_bytes+0x65/0xf0
__inode_add_bytes at fs/stat.c:689
(inlined by) inode_add_bytes at fs/stat.c:702
ext4_mb_new_blocks+0x418/0xca0 [ext4]
ext4_ext_map_blocks+0x1a6b/0x27b0 [ext4]
ext4_map_blocks+0x1a9/0x950 [ext4]
_ext4_get_block+0xfc/0x270 [ext4]
ext4_get_block_unwritten+0x33/0x50 [ext4]
__block_write_begin_int+0x22e/0xae0
__block_write_begin+0x39/0x50
ext4_write_begin+0x388/0xb50 [ext4]
ext4_da_write_begin+0x35f/0x8f0 [ext4]
generic_perform_write+0x15d/0x290
ext4_buffered_write_iter+0x11f/0x210 [ext4]
ext4_file_write_iter+0xce/0x9e0 [ext4]
new_sync_write+0x29c/0x3b0
__vfs_write+0x92/0xa0
vfs_write+0x103/0x260
ksys_write+0x9d/0x130
__x64_sys_write+0x4c/0x60
do_syscall_64+0x91/0xb05
read to 0xffff9a00d4b982d0 of 8 bytes by task 8 on cpu 65:
ext4_do_update_inode+0x4a0/0xf60 [ext4]
ext4_inode_blocks_set at fs/ext4/inode.c:4815
ext4_mark_iloc_dirty+0xaf/0x160 [ext4]
ext4_mark_inode_dirty+0x129/0x3e0 [ext4]
ext4_convert_unwritten_extents+0x253/0x2d0 [ext4]
ext4_convert_unwritten_io_end_vec+0xc5/0x150 [ext4]
ext4_end_io_rsv_work+0x22c/0x350 [ext4]
process_one_work+0x54f/0xb90
worker_thread+0x80/0x5f0
kthread+0x1cd/0x1f0
ret_from_fork+0x27/0x50
4 locks held by kworker/u256:0/8:
#0: ffff9a025abc4328 ((wq_completion)ext4-rsv-conversion){+.+.}, at: process_one_work+0x443/0xb90
#1: ffffab5a862dbe20 ((work_completion)(&ei->i_rsv_conversion_work)){+.+.}, at: process_one_work+0x443/0xb90
#2: ffff9a025a9d0f58 (jbd2_handle){++++}, at: start_this_handle+0x1c1/0x9d0 [jbd2]
#3: ffff9a00d4b985d8 (&(&ei->i_raw_lock)->rlock){+.+.}, at: ext4_do_update_inode+0xaa/0xf60 [ext4]
irq event stamp: 3009267
hardirqs last enabled at (3009267): [<ffffffff980da9b7>] __find_get_block+0x107/0x790
hardirqs last disabled at (3009266): [<ffffffff980da8f9>] __find_get_block+0x49/0x790
softirqs last enabled at (3009230): [<ffffffff98a0034c>] __do_softirq+0x34c/0x57c
softirqs last disabled at (3009223): [<ffffffff97cc67a2>] irq_exit+0xa2/0xc0
Reported by Kernel Concurrency Sanitizer on:
CPU: 65 PID: 8 Comm: kworker/u256:0 Tainted: G L 5.6.0-rc2-next-20200221+ #7
Hardware name: HPE ProLiant DL385 Gen10/ProLiant DL385 Gen10, BIOS A40 07/10/2019
Workqueue: ext4-rsv-conversion ext4_end_io_rsv_work [ext4]
The plain read is outside of inode->i_lock critical section which
results in a data race. Fix it by adding READ_ONCE() there.
Link: https://lore.kernel.org/r/20200222043258.2279-1-cai@lca.pw
Signed-off-by: Qian Cai <cai@lca.pw>
commit c50156526a2f7176b50134e3e5fb108ba09791b2 upstream.
Clang warns when one enumerated type is implicitly converted to another:
drivers/rtc/rtc-omap.c:574:21: warning: implicit conversion from
enumeration type 'enum rtc_pin_config_param' to different enumeration
type 'enum pin_config_param' [-Wenum-conversion]
{"ti,active-high", PIN_CONFIG_ACTIVE_HIGH, 0},
drivers/rtc/rtc-omap.c:579:12: warning: implicit conversion from
PCONFDUMP(PIN_CONFIG_ACTIVE_HIGH, "input active high", NULL, false),
./include/linux/pinctrl/pinconf-generic.h:163:11: note: expanded from
macro 'PCONFDUMP'
.param = a, .display = b, .format = c, .has_arg = d \
2 warnings generated.
It is expected that pinctrl drivers can extend pin_config_param because
of the gap between PIN_CONFIG_END and PIN_CONFIG_MAX so this conversion
isn't an issue. Most drivers that take advantage of this define the
PIN_CONFIG variables as constants, rather than enumerated values. Do the
same thing here so that Clang no longer warns.
Link: https://github.com/ClangBuiltLinux/linux/issues/144
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
commit fc2266011accd5aeb8ebc335c381991f20e26e33 upstream.
For thumb instructions, call_undef_hook() in traps.c first reads a u16,
and if the u16 indicates a T32 instruction (u16 >= 0xe800), a second
u16 is read, which then makes up the the lower half-word of a T32
instruction. For T16 instructions, the second u16 is not read,
which makes the resulting u32 opcode always have the upper half set to
0.
However, having the upper half of instr_mask in the undef_hook set to 0
masks out the upper half of all thumb instructions - both T16 and T32.
This results in trapped T32 instructions with the lower half-word equal
to the T16 encoding of setend (b650) being matched, even though the upper
half-word is not 0000 and thus indicates a T32 opcode.
An example of such a T32 instruction is eaa0b650, which should raise a
SIGILL since T32 instructions with an eaa prefix are unallocated as per
Arm ARM, but instead works as a SETEND because the second half-word is set
to b650.
This patch fixes the issue by extending instr_mask to include the
upper u32 half, which will still match T16 instructions where the upper
half is 0, but not T32 instructions.
Fixes: 2d888f48e056 ("arm64: Emulate SETEND for AArch32 tasks")
Cc: <stable@vger.kernel.org> # 4.0.x-
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Fredrik Strupe <fredrik@strupe.net>
commit 819732be9fea728623e1ed84eba28def7384ad1f upstream.
v2.6.27 commit cc8c282963bd ("[SCSI] zfcp: Automatically attach remote
ports") introduced zfcp automatic port scan.
Before that, the user had to use the sysfs attribute "port_add" of an FCP
device (adapter) to add and open remote (target) ports, even for the remote
peer port in point-to-point topology. That code path did a proper port open
recovery trigger taking the erp_lock.
Since above commit, a new helper function zfcp_erp_open_ptp_port()
performed an UNlocked port open recovery trigger. This can race with other
parallel recovery triggers. In zfcp_erp_action_enqueue() this could corrupt
e.g. adapter->erp_total_count or adapter->erp_ready_head.
As already found for fabric topology in v4.17 commit fa89adba1941 ("scsi:
zfcp: fix infinite iteration on ERP ready list"), there was an endless loop
during tracing of rport (un)block. A subsequent v4.18 commit 9e156c54ace3
("scsi: zfcp: assert that the ERP lock is held when tracing a recovery
trigger") introduced a lockdep assertion for that case.
As a side effect, that lockdep assertion now uncovered the unlocked code
path for PtP. It is from within an adapter ERP action:
zfcp_erp_strategy[1479] intentionally DROPs erp lock around
zfcp_erp_strategy_do_action()
zfcp_erp_strategy_do_action[1441] NO erp lock
zfcp_erp_adapter_strategy[876] NO erp lock
zfcp_erp_adapter_strategy_open[855] NO erp lock
zfcp_erp_adapter_strategy_open_fsf[806]NO erp lock
zfcp_erp_adapter_strat_fsf_xconf[772] erp lock only around
zfcp_erp_action_to_running(),
BUT *_not_* around
zfcp_erp_enqueue_ptp_port()
zfcp_erp_enqueue_ptp_port[728] BUG: *_not_* taking erp lock
_zfcp_erp_port_reopen[432] assumes to be called with erp lock
zfcp_erp_action_enqueue[314] assumes to be called with erp lock
zfcp_dbf_rec_trig[288] _checks_ to be called with erp lock:
lockdep_assert_held(&adapter->erp_lock);
It causes the following lockdep warning:
WARNING: CPU: 2 PID: 775 at drivers/s390/scsi/zfcp_dbf.c:288
zfcp_dbf_rec_trig+0x16a/0x188
no locks held by zfcperp0.0.17c0/775.
Fix this by using the proper locked recovery trigger helper function.
Link: https://lore.kernel.org/r/20200312174505.51294-2-maier@linux.ibm.com
Fixes: cc8c282963bd ("[SCSI] zfcp: Automatically attach remote ports")
Cc: <stable@vger.kernel.org> #v2.6.27+
Reviewed-by: Jens Remus <jremus@linux.ibm.com>
Reviewed-by: Benjamin Block <bblock@linux.ibm.com>
Signed-off-by: Steffen Maier <maier@linux.ibm.com>
commit 75fa601934fda23d2f15bf44b09c2401942d8e15 upstream.
Fix below kmemleak detected in verity_fec_ctr. output_pool is
allocated for each dm-verity-fec device. But it is not freed when
dm-table for the verity target is removed. Hence free the output
mempool in destructor function verity_fec_dtr.
unreferenced object 0xffffffffa574d000 (size 4096):
comm "init", pid 1667, jiffies 4294894890 (age 307.168s)
hex dump (first 32 bytes):
8e 36 00 98 66 a8 0b 9b 00 00 00 00 00 00 00 00 .6..f...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<0000000060e82407>] __kmalloc+0x2b4/0x340
[<00000000dd99488f>] mempool_kmalloc+0x18/0x20
[<000000002560172b>] mempool_init_node+0x98/0x118
[<000000006c3574d2>] mempool_init+0x14/0x20
[<0000000008cb266e>] verity_fec_ctr+0x388/0x3b0
[<000000000887261b>] verity_ctr+0x87c/0x8d0
[<000000002b1e1c62>] dm_table_add_target+0x174/0x348
[<000000002ad89eda>] table_load+0xe4/0x328
[<000000001f06f5e9>] dm_ctl_ioctl+0x3b4/0x5a0
[<00000000bee5fbb7>] do_vfs_ioctl+0x5dc/0x928
[<00000000b475b8f5>] __arm64_sys_ioctl+0x70/0x98
[<000000005361e2e8>] el0_svc_common+0xa0/0x158
[<000000001374818f>] el0_svc_handler+0x6c/0x88
[<000000003364e9f4>] el0_svc+0x8/0xc
[<000000009d84cec9>] 0xffffffffffffffff
Fixes: a739ff3f543af ("dm verity: add support for forward error correction")
Depends-on: 6f1c819c219f7 ("dm: convert to bioset_init()/mempool_init()")
Signed-off-by: Harshini Shetty <harshini.x.shetty@sony.com>
commit 8644772637deb121f7ac2df690cbf83fa63d3b70 upstream.
This patch replaces the size + 1 value introduced with the recent fix for 1
byte allocs with a constant value.
The idea here is to reduce code overhead as the previous logic would have
to read size into a register, then increment it, and write it back to
whatever field was being used. By using a constant we can avoid those
memory reads and arithmetic operations in favor of just encoding the
maximum value into the operation itself.
Fixes: 2c2ade81741c ("mm: page_alloc: fix ref bias in page_frag_alloc() for 1-byte allocs")
Signed-off-by: Alexander Duyck <alexander.h.duyck@linux.intel.com>
commit 82f04bfe2aff428b063eefd234679b2d693228ed upstream.
Commit 0161a94e2d1c7 ("tools: gpio: Correctly add make dependencies for
gpio_utils") added a make rule for gpio-utils-in.o but used $(output)
instead of the correct $(OUTPUT) for the output directory, breaking
out-of-tree build (O=xx) with the following error:
No rule to make target 'out/tools/gpio/gpio-utils-in.o', needed by 'out/tools/gpio/lsgpio-in.o'. Stop.
Fix that.
Fixes: 0161a94e2d1c ("tools: gpio: Correctly add make dependencies for gpio_utils")
Cc: Laura Abbott <labbott@redhat.com>
Signed-off-by: Anssi Hannula <anssi.hannula@bitwise.fi>
Link: https://lore.kernel.org/r/20200325103154.32235-1-anssi.hannula@bitwise.fi
Reviewed-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
commit 34d66caf251df91ff27b24a3a786810d29989eca upstream.
With commit a74cfffb03b7 ("x86/speculation: Rework SMT state change"),
arch_smt_update() is invoked from each individual CPU hotplug function.
Therefore the extra arch_smt_update() call in the sysfs SMT control is
redundant.
Fixes: a74cfffb03b7 ("x86/speculation: Rework SMT state change")
Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com>
Cc: <konrad.wilk@oracle.com>
Cc: <dwmw@amazon.co.uk>
Cc: <bp@suse.de>
Cc: <srinivas.eeda@oracle.com>
Cc: <peterz@infradead.org>
Cc: <hpa@zytor.com>
Link: https://lkml.kernel.org/r/e2e064f2-e8ef-42ca-bf4f-76b612964752@default
