2024-05-15tty: serial: fsl_lpuart: optimize the timer based EOP logictoradex_5.15-2.2.x-imxShenwei Wang
DMA transfer may end prematurely due to the DMA Rx timeout even during an active transfer because a constant timeout does not accurately simulate an EOP (End Of Package) event. This patch uses a timer to simulate the hardware EOP event. The timer should only complete a DMA transfer once the idle period satisfies a specified interval which is baud rate dependent. The problem has been observed with low baud rates but could occur also with high baud rates. Make the DMA Rx timeout baud rate dependent and check the DMA residue count before copying data to the TTY buffer. If the residue count remains unchanged since the last interrupt, that indicates no new data was received. In this case, the DMA should complete as an EOP event. Otherwise, new data was received during the interval and the EOP condition is not met so restart the DMA Rx timeout Upstream-Status: Backport [cf9aa72d2f91defea23fe29b9e8e941bb2486d5c] Signed-off-by: Shenwei Wang <shenwei.wang@nxp.com> Reviewed-by: Ilpo Järvinen <ilpo.jarvinen@linux.intel.com> Link: https://lore.kernel.org/r/20230510203359.1353469-1-shenwei.wang@nxp.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
2024-05-15serial: Store character timing information to uart_portIlpo Järvinen
Struct uart_port currently stores FIFO timeout. Having character timing information readily available is useful. Even serial core itself determines char_time from port->timeout using inverse calculation. Store frame_time directly into uart_port. Character time is stored in nanoseconds to have reasonable precision with high rates. To avoid overflow, 64-bit math is necessary. It might be possible to determine timeout from frame_time by multiplying it with fifosize as needed but only part of the users seem to be protected by a lock. Thus, this patch does not pursue storing only frame_time in uart_port. Upstream-Status: Backport [31f6bd7fad3b149a1eb6f67fc2e742e4df369b3d] Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@linux.intel.com> Link: https://lore.kernel.org/r/20220425143410.12703-2-ilpo.jarvinen@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
2024-05-02arm64: dts: freescale: imx8mm-verdin-dahlia: support sleep-mociStefan Eichenberger
Previously, we had the sleep-moci pin set to always on. However, the Dahlia carrier board supports disabling the sleep-moci when the system is suspended to power down peripherals that support it. This reduces overall power consumption. This commit adds support for this feature by disabling the reg_force_sleep_moci regulator and adding two new regulators for the USB hub and PCIe that can be turned off when the system is suspended. Upstream-Status: Backport [1288f819d6c7e3dc2e301728cb7fa9a99a718234] Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-05-02arm64: dts: freescale: imx8mm-verdin: replace sleep-moci hog with regulatorStefan Eichenberger
The Verdin family has a signal called sleep-moci which can be used to turn off peripherals on the carrier board when the SoM goes into suspend. So far we have hogged this signal, which means the peripherals are always on and it is not possible to add peripherals that depend on the sleep-moci to be on. With this change, we replace the hog with a regulator so that peripherals can add their own regulators that use the same gpio. Carrier boards that allow peripherals to be powered off in suspend can disable this regulator and implement their own regulator to control the sleep-moci. Upstream-Status: Backport [9f06926ef1b22a52e3c8ceea394cf7408c4e66b2] Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-05-02arm64: dts: freescale: imx8mp-verdin-dahlia: support sleep-mociStefan Eichenberger
Previously, we had the sleep-moci pin set to always on. However, the Dahlia carrier board supports disabling the sleep-moci when the system is suspended to power down peripherals that support it. This reduces overall power consumption. This commit adds support for this feature by disabling the reg_force_sleep_moci regulator and adding two new regulators for the USB hub and PCIe that can be turned off when the system is suspended. Upstream-Status: Backport [25b3af5395b5b07d8e656c932b7f694daa14b384] Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-05-02arm64: dts: freescale: imx8mp-verdin: replace sleep-moci hog with regulatorStefan Eichenberger
The Verdin family has a signal called sleep-moci which can be used to turn off peripherals on the carrier board when the SoM goes into suspend. So far we have hogged this signal, which means the peripherals are always on and it is not possible to add peripherals that depend on the sleep-moci to be on. With this change, we replace the hog with a regulator so that peripherals can add their own regulators that use the same gpio. Carrier boards that allow peripherals to be powered off in suspend can disable this regulator and implement their own regulator to control the sleep-moci. Upstream-Status: Backport [9d071e1889a578162ced6a6c9062653f9bcb442c] Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-05-02toradex_defconfig: enable onboard usb hubStefan Eichenberger
Enable the onboard USB hub to support sleep moci. It will control the reg_usb_hub regulator on the Dahlia carrier board. Upstream-Status: Inappropriate [Configuration] Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-05-02usb: core: hub: Create platform devices for onboard hubs in hub_probe()Matthias Kaehlcke
Call onboard_hub_create/destroy_pdevs() from hub_probe/disconnect() to create/destroy platform devices for onboard USB hubs that may be connected to the hub. The onboard hubs must have nodes in the device tree. onboard_hub_create/destroy_pdevs() are NOPs unless CONFIG_USB_ONBOARD_HUB=y/m. Also add a field to struct usb_hub to keep track of the onboard hub platform devices that are owned by the hub. Upstream-Status: Backport [3a6bf4a08142826698121bef16b244dcf50a6431] Reviewed-by: Douglas Anderson <dianders@chromium.org> Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Link: https://lore.kernel.org/r/20220630123445.v24.4.Ic9dd36078f9d803de82ca01a6700c58b8e4de27e@changeid Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2024-04-26toradex_defconfig: enable user-space i/o driver for hid subsystemMarcel Ziswiler
Enable user-space I/O driver support for HID subsystem (CONFIG_UHID=m) as e.g. required for Bluetooth keyboards. Related-to: ELB-5738 Upstream-Status: Inappropriate [Configuration] Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2024-04-11arm64: dts: freescale: imx8m[mp]-verdin: Update audio card nameHiago De Franco
On the Dahlia and Development carrier boards for the Verdin family (iMX8MM and iMX8MP), WM8904 and NAU8822 codecs are used. Instead of module-specific names, switch to more generic names based on the codec employed on the carrier board itself. This modification facilitates access to ALSA card names, ensuring consistency across iMX8MP and iMX8MM, as they share the same carrier board. Upstream-Status: Submitted [https://lore.kernel.org/all/20240411161441.70262-1-hiagofranco@gmail.com/] Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
2024-04-05dmaengine: imx-sdma: register sdma after firmware has loadedStefan Eichenberger
On an i.MX8M Plus we have the use case where a Bluetooth controller is attached to a imx-uart that uses the SDMA engine. We use serdev to load the Bluetooth driver as follows: &uart4 { bluetooth { compatible = "mrvl,88w8997"; max-speed = <921600>; }; } From time to time we see that the SDMA engine is not ready when the Bluetooth driver tries to load. This will result in the following error: [ 5.833037] imx-sdma 30bd0000.dma-controller: firmware found. [ 5.835034] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 5.835305] Bluetooth: HCI UART protocol Broadcom registered [ 5.835330] Bluetooth: HCI UART protocol QCA registered [ 5.835378] Bluetooth: HCI UART protocol Marvell registered [ 5.837497] ------------[ cut here ]------------ [ 5.841549] imx-sdma 30e00000.dma-controller: firmware found. [ 5.847712] WARNING: CPU: 3 PID: 143 at kernel/dma/mapping.c:528 dma_free_attrs+0xb0/0xe0 [ 5.847730] Modules linked in: snd_soc_wm8904(+) sec_mipi_dsim_imx(+) hci_uart sec_dsim [ 5.853442] imx-sdma 30e10000.dma-controller: firmware found. [ 5.858637] btqca btbcm dw_hdmi_cec lontium_lt8912b(+) ina2xx bluetooth snd_soc_fsl_sai snd_soc_fsl_aud2htx rfkill imx_sdma lm75 flexcan can_dev caam [ 5.864530] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5 [ 5.868870] secvio error display_connector galcore(O) fuse [ 5.868890] CPU: 3 PID: 143 Comm: kworker/u8:2 Tainted: G O 5.15.148-6.6.0-devel+git.23a8e831749d #1 [ 5.868896] Hardware name: Toradex Verdin iMX8M Plus WB on Dahlia Board (DT) [ 5.868900] Workqueue: events_unbound async_run_entry_fn [ 5.915483] lt8912 3-0048: supply vcclvdspll not found, using dummy regulator [ 5.919370] pstate: 600000c5 (nZCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 5.919377] pc : dma_free_attrs+0xb0/0xe0 [ 5.919384] lr : dma_free_attrs+0x50/0xe0 [ 5.919390] sp : ffff80000a07b8f0 [ 5.919393] x29: ffff80000a07b8f0 x28: 0000000000000000 x27: ffff80000a2c5200 [ 5.919401] x26: ffff0000c6453100 x25: 0000000000000000 x24: 0000000000000000 [ 5.919408] x23: 00000000de081000 x22: 0000000000000000 [ 6.021103] lt8912 3-0048: supply vcchdmipll not found, using dummy regulator [ 6.021961] x21: ffff800009f17000 [ 6.052001] x20: 00000000000000c0 x19: ffff0000c056bc10 x18: ffff800009bcddcc [ 6.059145] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000 [ 6.066293] x14: 0000000000000000 x13: 0000000000000000 x12: 0000000000001000 [ 6.073448] x11: 0000000000000000 x10: 0000000000000000 x9 : 0000000000000000 [ 6.080595] x8 : ffff800009f18000 x7 : 0000000000000000 x6 : 000000000000003f [ 6.087744] x5 : 0000000000000040 x4 : 0000000000000000 x3 : 00000000de081000 [ 6.094887] x2 : ffff800009f17000 x1 : 00000000000000c0 x0 : 0000000000000080 [ 6.102034] Call trace: [ 6.104482] dma_free_attrs+0xb0/0xe0 [ 6.108154] sdma_free_bd+0x60/0x70 [imx_sdma] [ 6.112609] sdma_transfer_init+0x208/0x344 [imx_sdma] [ 6.117760] sdma_prep_dma_cyclic+0xa4/0x364 [imx_sdma] [ 6.122995] imx_uart_startup+0x468/0x780 [ 6.127011] uart_port_startup+0x138/0x2fc [ 6.131111] uart_port_activate+0x54/0xd0 [ 6.135124] tty_port_open+0x90/0x130 [ 6.138791] uart_open+0x1c/0x30 [ 6.142023] ttyport_open+0x70/0x17c [ 6.145602] serdev_device_open+0x2c/0xe0 [ 6.149615] hci_uart_register_device+0x5c/0x33c [hci_uart] [ 6.155228] mrvl_serdev_probe+0x78/0x9c [hci_uart] [ 6.160140] serdev_drv_probe+0x38/0x80 [ 6.163984] really_probe+0xbc/0x46c [ 6.167562] __driver_probe_device+0x104/0x160 [ 6.172008] driver_probe_device+0x40/0x120 [ 6.176198] __driver_attach_async_helper+0x4c/0xf0 [ 6.181082] async_run_entry_fn+0x34/0x160 [ 6.185181] process_one_work+0x1d0/0x374 [ 6.189196] worker_thread+0x13c/0x490 [ 6.192949] kthread+0x150/0x160 [ 6.196180] ret_from_fork+0x10/0x20 [ 6.199764] ---[ end trace 906604ec7108d636 ]--- [ 6.204403] imx-uart 30a60000.serial: We cannot prepare for the RX slave dma! When the issue appears the sdma firmware is loaded after the uart requests a dma channel. This results in the above error. With this commit we make sure that the firmware is loaded before the sdma is registered and thus making sure that the sdma is ready when a driver requests a dma channel. Upstream-Status: Inappropriate [other] The upstream driver is not affected by this issue because it works even if the firmware is not loaded yet. It then uses the preprogrammed sdma firmware and switches to the new firmware as soon as it is ready. However, in comparison to the downstream driver it does not support suspend/resume and the drivers are therefore different. Trying to make the downstream driver work without the firmware loaded resulted in spare "Timeout waiting for CH0 ready" errors. Most likely it is an issue with the clock enable/disable sequence in the sdma driver that doesn't foresee this use case. Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-02-29toradex_defconfig: update after stable mergesMax Krummenacher
CONFIG_MMC_SDHCI_AM654 now depends on ARCH_K3 which is not set. The driver is not needed on NXP SoCs. commit da9eae2c1a45 ("mmc: sdhci_am654: Fix TI SoC dependencies") CONFIG_DEBUG_PREEMPT is by default not selected Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-29Merge remote-tracking branch 'fslc/5.15-2.2.x-imx' into toradex_5.15-2.2.x-imxMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: drivers/gpu/drm/bridge/lontium-lt8912b.c drivers/usb/dwc3/drd.c
2024-02-29Merge pull request #654 from MaxKrummenacher/fslc-5.15-2.2.x-imxOtavio Salvador
ARM: dts: imx6sx: fix, remove conflict marker
2024-02-29ARM: dts: imx6sx: fix, remove conflict markerMax Krummenacher
Fixes: 5955a854cd80 ("Merge commit v5.4.132 into fslc-5.15-2.2.x-imx") Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-28Merge pull request #653 from MaxKrummenacher/fslc-5.15-2.2.x-imxOtavio Salvador
Merge downstream `lf-5.15.71-2.2.2` and merge stable releases up to 5.15.148
2024-02-28Revert "drm/bridge: lt8912b: Register and attach our DSI device at probe"Max Krummenacher
This reverts commit ef4a40953c8076626875ff91c41e210fcee7a6fd. The commit was applied to make further commits apply cleanly, but the commit depends on other commits in the same patchset. I.e. the controlling DSI host would need a change too. Thus one would need to backport the full patchset changing the DSI hosts and all downstream DSI device drivers. Revert the commit and fix up the conflicts with the backported fixes to the lt8912b driver. Upstream-Status: Submitted [https://lore.kernel.org/stable/20240228145945.2499754-1-max.oss.09@gmail.com/] Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: drivers/gpu/drm/bridge/lontium-lt8912b.c
2024-02-23arm64: dts: imx8mp-verdin: overwrite alloc-ranges propertyStefan Eichenberger
With commit 1263f108fb28 ("arm64: dts: imx8mp-verdin: fix cma memory region") we introduced a new problem for modules with more than 3GB of RAM. The VPU driver Hantro is currently unable to cross 32bit boundaries. However, since the cma region is at the end of the RAM, we have crossed the boundary for modules with more than 3GB of RAM. We set the alloc-ranges property to the same value that is used in imx8mp.dtsi. We do this to be consistent between Verdin iMX8MM and Verdin iMX8MP. Upstream-Status: Inappropriate [other] We use the kernel configuration to define the CMA size and don't use the linux,cma node in the device tree. However, we need to verify that the upstream hantro driver can handle 64 bit addresses. Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-02-23arm64: dts: imx8mm-verdin: overwrite alloc-ranges propertyStefan Eichenberger
With commit 757e132269ec ("arm64: dts: imx8mm-verdin: fix cma memory region") we introduced a new problem for modules with more than 3GB of RAM. The VPU driver Hantro is currently unable to cross 32bit boundaries. However, since the cma region is located at the end of the RAM, we have crossed the boundary for modules with more than 3GB of RAM. The Verdin iMX8MM modules are not yet affected by this issue as there is no module with more than 2GB of RAM. However, to be consistent with the Verdin iMX8MP and to be future proof in case there is a module with more RAM, we overwrite the alloc-ranges property here as well. We cannot use the default alloc-ranges property from imx8mm.dtsi because it starts at 1GB of RAM and therefore does not work with modules that only have 1GB of RAM. That is why we deleted this property in the first place. Upstream-Status: Inappropriate [other] We use the kernel configuration to define the CMA size and don't use the linux,cma node in the device tree. However, we need to verify that the upstream hantro driver can handle 64 bit addresses. Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-02-23gpu: imx: lcdifv3: power down imx8mp hdmi PHYJoao Paulo Goncalves
The lcdifv3 video controller has a clock dependency on the HDMI PHY for the imx8mp. Powering down the HDMI PHY before the drm display pipeline finishes after a hot-plug monitor disconnection event causes a vblank timeout error due to the lcdif clock stopping. Likely because of this, the downstream code doesn't power down the HDMI PHY (it was commented), leaving the PHY ON even on a disconnection event, resulting in the HDMI data and clock signals still running. This appears to cause issues when using HDMI with bridge devices (e.g. HDMI-->eDP) to handle HPD (Hot-Plug Detect) events from the bridge. To address the problem, the workaround moves the PHY power-off logic to the suspend of the lcdifv3 driver. At this position, it guarantees that the DRM pipeline has finished and disabled and the PHY can be powered off without problems. Doing this appears to be safe as the PHY is powered on again on imx8mp_hdmi_phy_init() before starting the DRM pipeline. The PHY is controlled by the HDMI TX BLK CTRL peripheral, but the downstream driver for the peripheral is not fully implemented. So, the workaround maps HDMI TX BLK CTRL register space to the lcdifv3 driver and controls it directly, similar to the approach used in the imx HDMI driver. Upstream-Status: Inappropriate [other] The imx8mp already has a fully working implementation on upstream [1] and [2]. Nonetheless, attempting to backport it appears impractical, leading to the adoption of this workaround. [1] https://lore.kernel.org/lkml/20240210204606.11944-1-aford173@gmail.com/ [2] https://lore.kernel.org/lkml/20240203165307.7806-1-aford173@gmail.com/ Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
2024-02-23toradex_defconfig: enable EXFAT_FSParth Pancholi
Add support for ExFAT filesystem. Related-to: ELB-5583 Upstream-Status: Inappropriate [Configuration] Signed-off-by: Parth Pancholi <parth.pancholi@toradex.com>
2024-02-22Merge tag 'v5.15.148' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.148 stable release Conflicts: drivers/usb/phy/phy-mxs-usb.c
2024-02-22Merge tag 'v5.15.147' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.147 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.146' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.146 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.145' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.145 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.144' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.144 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.143' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.143 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: arch/arm64/boot/dts/freescale/imx8mq.dtsi
2024-02-22Merge tag 'v5.15.142' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.142 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.141' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.141 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.140' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.140 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: arch/arm64/boot/dts/freescale/fsl-ls208xa.dtsi drivers/i3c/master/svc-i3c-master.c
2024-02-22Merge tag 'v5.15.139' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.139 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: drivers/clk/imx/clk-imx8mq.c
2024-02-22Merge commit v5.15.138+reverts into fslc-5.15-2.2.x-imxMax Krummenacher
Revert the following commits in stable before merging, the sources have been heavely modified by NXP. d4c8bf5635c4b rpmsg: Fix possible refcount leak in rpmsg_register_device_override() a82e0fda8a2f8 rpmsg: glink: Release driver_override bfd4a664ddfbe rpmsg: Fix calling device_lock() on non-initialized device 2e76b4f6218c4 rpmsg: Fix kfree() of static memory on setting driver_override 5c0da71871d3a rpmsg: Constify local variable in field store macro Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: drivers/misc/pci_endpoint_test.c
2024-02-22Revert "rpmsg: Constify local variable in field store macro"Max Krummenacher
This reverts commit 5c0da71871d3ac3f96d37067bf1a0ba9c25c2c72. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Revert "rpmsg: Fix kfree() of static memory on setting driver_override"Max Krummenacher
This reverts commit 2e76b4f6218c4db3ff00eb15d94d72f371736de4. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Revert "rpmsg: Fix calling device_lock() on non-initialized device"Max Krummenacher
This reverts commit bfd4a664ddfbe12f008efb0b0ab6bf25a8ab2538. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Revert "rpmsg: glink: Release driver_override"Max Krummenacher
This reverts commit a82e0fda8a2f8561a6a6681e8b3557e60cad17da. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Revert "rpmsg: Fix possible refcount leak in rpmsg_register_device_override()"Max Krummenacher
This reverts commit d4c8bf5635c4bedaf2470761ced1f502b2d5434e. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.137' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.137 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-22Merge tag 'v5.15.136' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.136 stable release Conflicts: Documentation/security/keys/trusted-encrypted.rst security/keys/trusted-keys/trusted_core.c Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge tag 'v5.15.135' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.135 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge tag 'v5.15.134' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.134 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge tag 'v5.15.133' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.133 stable release Conflicts: drivers/perf/fsl_imx8_ddr_perf.c Used the stable fix Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge commit v5.4.132 into fslc-5.15-2.2.x-imxMax Krummenacher
Revert the following commits before merging, the sources have been heavely modified by NXP. 5a86ca588b3f9 Revert "perf/imx_ddr: don't enable counter0 if none of 4 counters are used" 56ad67babb7fb Revert "usb: phy: mxs: fix getting wrong state with mxs_phy_is_otg_host()" 50b3a42d82f07 Revert "USB: core: Unite old scheme and new scheme descriptor reads" cdcf46014f5ca Revert "USB: core: Change usb_get_device_descriptor() API" 2f2af6028f201 Revert "USB: core: Fix race by not overwriting udev->descriptor in hub_port_init()" 9e168d3268f89 Revert "USB: core: Fix oversight in SuperSpeed initialization" 7e95107f9b664 Revert "PCI: dwc: Add start_link/stop_link inlines" d0bec10a7f796 Revert "PCI: layerscape: Add the endpoint linkup notifier support" aaf9dc6089bc3 Revert "PCI: layerscape: Add workaround for lost link capabilities during reset" Conflicts: arch/arm/boot/dts/imx6qdl.dtsi arch/arm/boot/dts/imx6sx.dtsi Keep stable node name changes drivers/gpu/drm/bridge/adv7511/adv7511_drv.c Keep stable code change drivers/media/i2c/ov5640.c Keep stable code change Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-21Merge tag 'v5.15.131' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.131 stable release
2024-02-21Merge tag 'v5.15.130' into fslc-5.15-2.2.x-imxMax Krummenacher
This is the 5.15.130 stable release
2024-02-20MGS-7215 [#imx-3183] 0034-CL694252-KERNEL-SPACE-6.4.11_22Q2_NXP-IMX-3189-fix-tYuan Tian
6.4.11_22Q2_NXP: IMX-3189: fix the build error caused by conflicting types of "_QuerySignal" with gcc13.1. Signed-off-by: IPD_SCM <IPD_SCM@verisilicon.com> Signed-off-by: Yuan Tian <yuan.tian@nxp.com> Upstream-Status: Inappropriate [other] Upstream does not have the propriatery Vivante driver. Cherry picked from NXP downstream commit 9b70e0e11b04c18545093bd6d172762f65709365. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "perf/imx_ddr: don't enable counter0 if none of 4 counters are used"Max Krummenacher
This reverts commit c7802ff51adce9ae2e8392b926943342549de38c. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "usb: phy: mxs: fix getting wrong state with mxs_phy_is_otg_host()"Max Krummenacher
This reverts commit 484ddaa90b7e8b40b0a479dfc24f0a1b9cd70e7d. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "USB: core: Unite old scheme and new scheme descriptor reads"Max Krummenacher
This reverts commit 56c49a3328e988c82981f4d098be22695d46fcf3. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-02-20Revert "USB: core: Change usb_get_device_descriptor() API"Max Krummenacher
This reverts commit eda9a296658203b1cc07d777c19c8c9eac6d0d17. Downstream NXP and stable have deviated to far, do not pull this in. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
