This keeps the numbering of the /sys/class/pwmchipX independent of
which overlays are loaded and allows the use of Verdin PWM_3_DSI from
user space if it is not used as a backlight PWM.
Related-to: ELB-3411
lpuart2 is the only UART where DMA request works and linux tries to use
a DMA. However this DMA does not work and output hangs, disbling the DMA
works for now.
This change was originally introduced in commit
1a8badaa585de ARM64: dts: apalis-imx8: disable dma for lpuart2
but lost when doing the devicetree-split.
Fixes: 2715972aadc8f arm64: dts: apalis-imx8: separate common module pa
Related-to: ELB-3178
Work around potential probe deferral, order and race condition issues.
Both Verdin Developer Board V1.0A and V1.1A have their PHYs at address
7. Only V1.0B had it at the address 3!
Add SODIMM annotation to FEC pins.
The following happens e.g. on the i.MX 8M Plus EVK which does not
specify any phy-supply:
[ 1.077851] imx-dwmac 30bf0000.ethernet: no regulator found
[ 1.083445] Unable to handle kernel NULL pointer dereference at
virtual address 0000000000000078
[ 1.092234] Mem abort info:
[ 1.095033] ESR = 0x96000004
[ 1.098087] EC = 0x25: DABT (current EL), IL = 32 bits
[ 1.103402] SET = 0, FnV = 0
[ 1.106456] EA = 0, S1PTW = 0
[ 1.109603] Data abort info:
[ 1.112489] ISV = 0, ISS = 0x00000004
[ 1.116329] CM = 0, WnR = 0
[ 1.119301] [0000000000000078] user address but active_mm is swapper
[ 1.125660] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 1.131232] Modules linked in:
[ 1.134291] CPU: 2 PID: 1 Comm: swapper/0 Not tainted
5.4.77-05639-g581745444980 #10
[ 1.142032] Hardware name: NXP i.MX8MPlus EVK board (DT)
[ 1.147344] pstate: 60000005 (nZCv daif -PAN -UAO)
[ 1.152141] pc : regulator_enable+0x1c/0x78
[ 1.156326] lr : imx_dwmac_init+0x134/0x1a8
[ 1.160508] sp : ffff80001003bad0
Fixes: ca8811172bdc ("net: stmmac: dwmac-imx: add phy-supply")
Rework the read and write code paths in the driver to support operation
in atomic contexts. To achieve this, the driver must not rely on IRQs
and not call schedule(), e.g. via a sleep routine, in these cases.
With this patch the driver supports normal operation, DMA transfers and
now the polling mode or also called sleep-free or IRQ-less operation. It
makes the code not simpler or easier to read, but atomic I2C transfers
are needed on some hardware configurations, e.g. to trigger reboots on
an external PMIC chip.
Related-to: ELB-3308
Related-to: ELB-1403
Signed-off-by: Stefan Lengfeld <contact@stefanchrist.eu>
[m.felsch@pengutronix.de: integrate https://patchwork.ozlabs.org/patch/1085943/ review feedback]
[m.felsch@pengutronix.de: adapt commit message]
Signed-off-by: Marco Felsch <m.felsch@pengutronix.de>
Acked-by: Oleksij Rempel <o.rempel@pengutronix.de>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Tested-by: Stefan Lengfeld <contact@stefanchrist.eu>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
(cherry picked from commit 3a5ee18d2a32bda6b9a1260136f6805848e3839d)
tempmon driver requires the platform driver imx-cpufreq-dt that is enabled
for imx7 with the option ARM_IMX_CPUFREQ_DT. Adding this option fixes
tempmon driver working.
Related-to: ELB-3339
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Prepare the nodes for the Verdin DSI to LVDS Adapter overlay.
Prepare the nodes for the DSI to HDMI Adapter overlay.
The OV5640 driver crashes on NXP's i.MX 8M Plus if loaded as a module.
Related to: ELB-3209
From the SD-Card specification:
> The host shall supply power to the card so that the voltage is
> reached to V DD _min within 250ms and start to supply at least
> 74 SD clocks to the SD card with keeping CMD line to high. In case of
> SPI mode, CS shall be held to high during 74 clock cycles.
According to this information I think we should pull the CMD data
line like on other boards to 3.3V. Also on other boards we
do have the CLK signal pulled.
This looks like this got mixed that up.
The pcie_phy uses ext_osc info in addition to the pcie node.
While at it add the bus-range property to prevent:
No bus range found for /pcie@33800000, using [bus 00-ff]
Correct the clock mode of PCIe PHY.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Reviewed-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit 2c23d9de9fc41d5436a7d3f8510fc95f3bf1c56b)
- Verify the both internal PLL_SYS and external OSC reference clock
modes on iMX8MP EVK board, and pass the PCIe compliance tests.
- Remove the no-needed bypass setting.
- PHY configration should be completed before CMN_RSTN is set to 1b1
- To manually initiate the speed change to make sure GEN2 is linked up:
- Write to LINK_CONTROL2_LINK_STATUS2_REG.PCIE_CAP_TARGET_LINK_SPEED
in the local device
- De-assert GEN2_CTRL_OFF.DIRECT_SPEED_CHANGE in the local device
- Assert GEN2_CTRL_OFF.DIRECT_SPEED_CHANGE in the local device
(cherry picked from commit 12589ba98b1145e2d2a9f439b20064197aea8ca9)
Add the PERST for iMX8MP PCIe.
(cherry picked from commit 0a91df355e20aa53a4bcaa9d352952e5fa9e4ef6)
Verify the PCIe PLL_SYS reference clock source on EVK board.
The external OSC clock is used as PCIe REF clock source in default.
- sequence should be the following one.
phy configuration--> CMN_RSTN--> wait for pll lock
- add the calibrate callback to fit the correct init sequence of phy
(cherry picked from commit 9afaf7a465858970aee8858fb52067f2ef152c7f)
Update the clock modes of iMX8MP PCIe PHY in binding DOC.
(cherry picked from commit eade3750bf840948b29db26f0beabf10dea5f981)
NOTE: Change the ext_osc of pcie/pcie_phy to '0' when enable SYS_PLL
clock mode.
(cherry picked from commit 1bda33273eccae3c0d878d34660eca9da1765db0)
Configure the L1 latency of iMX8M's RC to less than 64us, otherwise,
the L1/L1SS wouldn't be enabled by ASPM.
(cherry picked from commit eb9fdb1d10c10dc4d4bbe9bc6fc060afe1485989)
Signed-off-by: Jaskaranjeet Singh <jaskaranjeet.singh@toradex.com>
Add support of sub-functions disabling. It allows one to
define and turn on sub-function devices in different
devicetree files.
Toradex BSP 5.x uses the video/fbdev stack of display drivers.
Remove unused nodes for gpu/drm/imx stack of drivers.
Related-to: ELB-3240
With the driver now supporting the phy-supply property, remove the
regulator-boot-on property.
The driver does not support the 'sleep' state pinctrl. Remove it.
The PHY connected to the FEC doesn't have a seperate switchable rail.
Add an support for an optional regulator which powers an attached phy.
CONFIG_CRYPTO_XTS is selcted (as 'y') by CRYPTO_DEV_FSL_CAAM_CRYPTO_API_QI.
This adds back drivers enabled in the following 3 commits
commit e7704de31f0b ("arm64: defconfig: add zram support")
commit 08d125a06697 ("arm64: defconfig: add sound drivers for Gumstix AutoBSP")
commit f2bf706a88d6 ("arm64: defconfig: add bluetooth drivers for Gumstix AutoBSP")
Only the Development Board gives access to the native hdmi signals.
Move the nodes into imx8mp-verdin-dev.dtsi.
RX and TX seem to be swapped and the function is currently not
implemented. Mux the pins as GPIOs to ensure to not have two
connected outputs.
Use the correct clk as the mclk.
Additionally set the mux pad values to a more sensible value, i.e.
for inputs enable the pullup.
This device is described in an overlay. Removing this node here
fixes the kernel stuck if the colibri-imx7-aster_atmel-mxt_overlay is
applied.
According to the decision to use overlays just for enabling
subsystems, add back the definition of Atmel MXT touchscreen device.
The VGA interface and all related stuff enable in an overlay.
Remains them disabled in the main devicetree.
Realetd-to: ELB-3240
Now HDMI interface is driven with an overlay, so that it is not needed to
configure hdmi_ddc on a board level.
Move all i2cddc/hdmi_ddc stuff to the module level and disable it by
default.
The HDMI interface and all related stuff enable in an overlay.
This device enables in an overlay. Remains it disabled here.
PWM-part of the backlight device is the same for all Toradex boards.
Move all backlight properties to the module-level devicetree.
Remain the device disabled - it should be enabled in corresponding
overlays.
The LCD (parallel RGB) and LVDS interfaces and all related stuff are
driven with overlays. This stuff is already disabled for Evaluation board.
Disable it for all versions of Ixora board as well.
On the i.MX 8M Plus the 3rd LCDIF drives an on-SoC Samsung HDMI PHY
giving us native HDMI functionality.
At least the following of the configured devices work:
- Console
- eMMC
- ETH0
- ETH1
- SD_1
- USB_1 as peripheral, USB_2 as host
- CAN_1, CAN_2
Everything else is either known to not work or untested.
Enable CONFIG_STMMAC_ETH for the additional MAC in the i.MX8 M Plus.
Enable CONFIG_VLAN_8021Q/CONFIG_TSN for new features that MAC supports.
toradex_5.4-2.1.x-imx
Update 5.4-2.1.x-imx to v5.4.77 from stable
This is the 5.4.77 stable release
Merge conflicts:
Merged automatically, no conflicts
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Use the predefined resource name of the PMIC thermal sensor.
Related-to: ELB-3037
Do not print an error. This is no error in our use-case so just delete
this error message that confuses users.
As we now move back to full loglevel this is the only way to get rid of
that message.
fixes: d182137f18f24de3bc4b45c5a3d52e2f8f96a093 net: wireless:
cfg80211: decrease importance of sched_scan message
This reverts commit 2c7781c5d5d0b0c8b4c67f945fdf7e8992fb36b5.
We decided to go back to full loglevel so customers can see all messages
on boot.
Related-to: ELB-3183
