To support a wider variety of backlight setups, introduce an optional
enable GPIO. Legacy users of the platform data already have a means of
supporting GPIOs by using the .init(), .exit() and .notify() hooks. DT
users however cannot use those, so an alternative method is required.
In order to ease the introduction of the optional enable GPIO, make it
available in the platform data first, so that existing users can be
converted. Once that has happened a second patch will add code to make
use of it in the driver.
Signed-off-by: Thierry Reding <treding@nvidia.com>
(cherry picked from commit 2b9b1620349e325f184c68cddf3b484499c163c0)
When a device is shut down, make sure to disable the backlight. If it
stays lit, it gives the impression that the device hasn't turned off.
Furthermore keeping the backlight on may consume power, which is not
what users expect when they shut down a device.
(cherry picked from commit 5f33b896246a2d9bdf01352de11d4dab96ba2fc9)
No need to have a specific OOM message, since there is generic MM out of memory
message in place.
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
(cherry picked from commit ca7a97add4d4a7b0602b3bd1eff5c89da8636713)
I forgot to remove this during earlier cleanup patches and only checked
various builds for errors, not warnings.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
(cherry picked from commit 73d4e2b82b4bb1571b1a7f97012c0db8a0faef42)
Use SIMPLE_DEV_PM_OPS macro will initialize the member "freeze"
and "thaw" of pwm_backlight_pm_ops as below,
.freeze = suspend_fn,
.thaw = resume_fn,
then during the process of making hibernation snapshot, screen
will be blank at the moment of freezing, and then light at the
moment of thawing.
this is not the right user experience for suspending to disk.
so this patch drops freeze and thaw callback, make the LCD is
always lighting before the final shutdown.
Signed-off-by: Huayi Li <huayi.li@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
(cherry picked from commit 1dea1fd09246ada581a99d0669108eea94b7bfee)
Split adjustment of the brightness (by changing the PWM duty cycle) from
the power on sequence. This fixes an issue where the brightness can no
longer be updated once the backlight has been enabled.
Reported-by: Marc Dietrich <marvin24@gmx.de>
(cherry picked from commit e4bfeda96872bfe6015cd360008b77cd3b981b2b)
Currently the driver assumes that the values specified in the
brightness-levels device tree property increase as they are parsed from
left to right. But boards that invert the signal between the PWM output
and the backlight will need to specify decreasing brightness-levels.
This patch removes the assumption that the last element of the array is
the maximum value, and instead searches the array for the maximum value
and uses that in the duty cycle calculation.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
(cherry picked from commit 8f43e18e2769b3b28383903d501b4da29e388aad)
Backlights require a power supply to work properly. This commit adds a
regulator to power up and power down the backlight.
(cherry picked from commit 22ceeee16eb8f0d04de3ef43a5174fb30ec18af9)
Make use of the new enable_gpio field and allow it to be set from DT as
well. Now that all legacy users of platform data have been converted to
initialize this field to an invalid value, it is safe to use the field
from the driver.
(cherry picked from commit 8265b2e4e62632b01f998095d1bbda4d281629fe)
Follow up patches will add support for more complex means of powering
the backlight on and off such as using a regulator. To prevent calls to
the regulator API from becoming unbalanced, keep track of the enabled
state internally.
(cherry picked from commit 97c38437115aa0c3fb2d50c488814b503ba529e0)
In preparation for adding an optional regulator and enable GPIO to the
driver, split the power on and power off sequences into separate
functions to reduce code duplication at the multiple call sites.
(cherry picked from commit 62b744a87c1170b339f993aa3cfb22465974816a)
Add more blank lines to increase readability. While at it, remove a
trailing blank line at the end of the file.
(cherry picked from commit 668e63c6701d486c68b49ffffc0e5b7de1a2e95c)
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change to
make the code simpler and enhance the readability.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
(cherry picked from commit c512794cada491e008eeca822af7e4ad5db72a56)
This reverts commit 95730406a0e3bbd7f862718782924a3c367845a1.
This reverts commit 74df06fb565b7250bc86d79727b66bb02259d54c.
This reverts commit 08a13bacb43f206239ae0f1ccbe37325993e2b1b.
This reverts commit 153a5d54d1a10c5a35f6923e0c6423430d2c7c89.
Both firmware and kernel are using the same set of constants
in a header file, this patch separates them in to a single file.
That way it will be easier to track changes to FW or kernel.
DC initialization now relays only on device-tree entry.
Add ability to switch between 24.1 and 24.0 lvds modes.
Mode description can be found in "Using 24-bpp LVDS Panels with
IntelĀ® Mobile Chipsets for Embedded Applications".
This change also modifies SPI clock for ezPort mode.
Increased SPI speed for transfers and peripheral speed.
Switch to cleaning IRQ flags on read, instead of separate write.
Switched to zero-copy on SPI reads.
GPIO used for WOL is briefly used in i210 reset procedure.
This patch makes sure it's freed and can be used for a wakeup
source.
_BSD_SOURCE was deprecated in favour of _DEFAULT_SOURCE since glibc
2.20[1]. To avoid build warning on glibc2.20, _DEFAULT_SOURCE should
also be defined.
[1]: https://sourceware.org/glibc/wiki/Release/2.20
Signed-off-by: Chanho Park <chanho61.park@samsung.com>
Link: http://lkml.kernel.org/r/1410487817-13403-1-git-send-email-chanho61.park@samsung.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
(cherry picked from commit 512fe365373b9c95a70b4b6357503ee74d27214f)
Let the kernel print some debug messages when a user program
crashes due to an exception.
Some functionality used by android binary drivers
were missing.
As stated by the eMMC 5.0 specification, a chip should not be rejected
only because of the revision stated in the EXT_CSD_REV field of the
EXT_CSD register.
Remove the control on this value, the control of the CSD_STRUCTURE field
should be sufficient to reject future incompatible changes.
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit 03a59437ef6b6ad7fb0165cb9b96c08d6bf057fc)
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
b271e8fa67a6d9c4600274a25636cfe00fdd1b68
This reverts commit 8fdf8dc5afdb02625084356ebd7c0d1c7494a00e.
This reverts commit 0293e897d740cc7991c82567aab5dee0e66294fd.
Signed-off-by: Peter Gielda <pgielda@antmicro.com>
DDC/EDID detection was failing on Apalis TK1 V1.2A on Ixora.
We moved HDMI DDC configuration to the device-tree.
If DDC config is missing from the device-tree
we default to v1.2 config.
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Update model and compatibility nodes to be more in-line with mainline.
Cosmetic clean-up to bring it more in-line with mainline driver in order
to be able to easily assess whether it is all kosher.
Validate the output buffer length for L2CAP config requests and responses
to avoid overflowing the stack buffer used for building the option blocks.
Bug 1989825
Change-Id: Id158ece2176c4ac339a7232dfde8c47ce2241122
Cc: stable@vger.kernel.org
Signed-off-by: Ben Seri <ben@armis.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1558952
(cherry picked from commit c005032a3ffe77437f6ebc704af377fc9bc46279)
Reviewed-on: https://git-master.nvidia.com/r/1570529
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Tested-by: Winnie Hsu <whsu@nvidia.com>
This automatically selects options for zone DMA and 64 bit DMA addresses
when LPAE is enabled on ARM Tegra platforms. These options are required
for proper operation with LPAE enabled.
The ZONE_DMA option is required to ensure that drivers that allocate DMA
memory get buffers from the first 4 GiB. This is necessary because a lot
of the controllers only support addressing 32 bits.
As for ARCH_DMA_ADDR_T_64BIT, there are situations where devices that do
support addresses of more than 32 bits (such as the display controller
or the GPU) can run without translating addresses through an IOMMU on a
device with more than 4 GiB of system memory.
Note that both of these options are stop-gap solutions required only
until the IOMMU can be properly integrated with the DMA mapping API and
drivers use that properly and consistently.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
[treding@nvidia.com: specify rationale for options]
(backported from commit 6aa26c5d66595494e810c791602d87a572c78808)
With gcc 7 the following compile time error occurs:
| drivers/video/tegra/dc/dp.c:1178:12: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses]
| cr_done ? : ({ret = -EINVAL; goto fail; });
| drivers/video/tegra/dc/dp.c:1186:12: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses]
| lt_done ? : ({ret = -EINVAL; goto fail; });
