Link: https://lore.kernel.org/r/20211101082440.664392327@linuxfoundation.org
Tested-by: Jon Hunter <jonathanh@nvidia.com>
Tested-by: Shuah Khan <skhan@linuxfoundation.org>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Linux Kernel Functional Testing <lkft@linaro.org>
Tested-by: Pavel Machek (CIP) <pavel@denx.de>
[ Upstream commit aa0f697e45286a6b5f0ceca9418acf54b9099d99 ]
sctp_sf_violation() is called when processing HEARTBEAT_ACK chunk
in cookie_wait state, and some other places are also using it.
The vtag in the chunk's sctphdr should be verified, otherwise, as
later in chunk length check, it may send abort with the existent
asoc's vtag, which can be exploited by one to cook a malicious
chunk to terminate a SCTP asoc.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit 4f7019c7eb33967eb87766e0e4602b5576873680 ]
Currently Linux SCTP uses the verification tag of the existing SCTP
asoc when failing to process and sending the packet with the ABORT
chunk. This will result in the peer accepting the ABORT chunk and
removing the SCTP asoc. One could exploit this to terminate a SCTP
asoc.
This patch is to fix it by always using the initiate tag of the
received INIT chunk for the ABORT chunk to be sent.
commit 4a089e95b4d6bb625044d47aed0c442a8f7bd093 upstream.
nios2:allmodconfig builds fail with
make[1]: *** No rule to make target 'arch/nios2/boot/dts/""',
needed by 'arch/nios2/boot/dts/built-in.a'. Stop.
make: [Makefile:1868: arch/nios2/boot/dts] Error 2 (ignored)
This is seen with compile tests since those enable NIOS2_DTB_SOURCE_BOOL,
which in turn enables NIOS2_DTB_SOURCE. This causes the build error
because the default value for NIOS2_DTB_SOURCE is an empty string.
Disable NIOS2_DTB_SOURCE_BOOL for compile tests to avoid the error.
Fixes: 2fc8483fdcde ("nios2: Build infrastructure")
Reviewed-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
commit 55e6d8037805b3400096d621091dfbf713f97e83 upstream.
In regcache_rbtree_insert_to_block(), when 'present' realloc failed,
the 'blk' which is supposed to assign to 'rbnode->block' will be freed,
so 'rbnode->block' points a freed memory, in the error handling path of
regcache_rbtree_init(), 'rbnode->block' will be freed again in
regcache_rbtree_exit(), KASAN will report double-free as follows:
BUG: KASAN: double-free or invalid-free in kfree+0xce/0x390
Call Trace:
slab_free_freelist_hook+0x10d/0x240
kfree+0xce/0x390
regcache_rbtree_exit+0x15d/0x1a0
regcache_rbtree_init+0x224/0x2c0
regcache_init+0x88d/0x1310
__regmap_init+0x3151/0x4a80
__devm_regmap_init+0x7d/0x100
madera_spi_probe+0x10f/0x333 [madera_spi]
spi_probe+0x183/0x210
really_probe+0x285/0xc30
To fix this, moving up the assignment of rbnode->block to immediately after
the reallocation has succeeded so that the data structure stays valid even
if the second reallocation fails.
Fixes: 3f4ff561bc88b ("regmap: rbtree: Make cache_present bitmap per node")
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
Link: https://lore.kernel.org/r/20211012023735.1632786-1-yangyingliang@huawei.com
Signed-off-by: Mark Brown <broonie@kernel.org>
commit db6c3c064f5d55fa9969f33eafca3cdbefbb3541 upstream.
Add the missing endpoint max-packet sanity check to probe() to avoid
division by zero in lan78xx_tx_bh() in case a malicious device has
broken descriptors (or when doing descriptor fuzz testing).
Note that USB core will reject URBs submitted for endpoints with zero
wMaxPacketSize but that drivers doing packet-size calculations still
need to handle this (cf. commit 2548288b4fb0 ("USB: Fix: Don't skip
endpoint descriptors with maxpacket=0")).
Fixes: 55d7de9de6c3 ("Microchip's LAN7800 family USB 2/3 to 10/100/1000 Ethernet device driver")
Cc: stable@vger.kernel.org # 4.3
Cc: Woojung.Huh@microchip.com <Woojung.Huh@microchip.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 4217d07b9fb328751f877d3bd9550122014860a2 upstream.
On Thundercomm TurboX CM2290, the eMMC OCR reports vdd = 23 (3.5 ~ 3.6 V),
which is being treated as an invalid value by sdhci_set_power_noreg().
And thus eMMC is totally broken on the platform.
[ 1.436599] ------------[ cut here ]------------
[ 1.436606] mmc0: Invalid vdd 0x17
[ 1.436640] WARNING: CPU: 2 PID: 69 at drivers/mmc/host/sdhci.c:2048 sdhci_set_power_noreg+0x168/0x2b4
[ 1.436655] Modules linked in:
[ 1.436662] CPU: 2 PID: 69 Comm: kworker/u8:1 Tainted: G W 5.15.0-rc1+ #137
[ 1.436669] Hardware name: Thundercomm TurboX CM2290 (DT)
[ 1.436674] Workqueue: events_unbound async_run_entry_fn
[ 1.436685] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1.436692] pc : sdhci_set_power_noreg+0x168/0x2b4
[ 1.436698] lr : sdhci_set_power_noreg+0x168/0x2b4
[ 1.436703] sp : ffff800010803a60
[ 1.436705] x29: ffff800010803a60 x28: ffff6a9102465f00 x27: ffff6a9101720a70
[ 1.436715] x26: ffff6a91014de1c0 x25: ffff6a91014de010 x24: ffff6a91016af280
[ 1.436724] x23: ffffaf7b1b276640 x22: 0000000000000000 x21: ffff6a9101720000
[ 1.436733] x20: ffff6a9101720370 x19: ffff6a9101720580 x18: 0000000000000020
[ 1.436743] x17: 0000000000000000 x16: 0000000000000004 x15: ffffffffffffffff
[ 1.436751] x14: 0000000000000000 x13: 00000000fffffffd x12: ffffaf7b1b84b0bc
[ 1.436760] x11: ffffaf7b1b720d10 x10: 000000000000000a x9 : ffff800010803a60
[ 1.436769] x8 : 000000000000000a x7 : 000000000000000f x6 : 00000000fffff159
[ 1.436778] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 00000000ffffffff
[ 1.436787] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff6a9101718d80
[ 1.436797] Call trace:
[ 1.436800] sdhci_set_power_noreg+0x168/0x2b4
[ 1.436805] sdhci_set_ios+0xa0/0x7fc
[ 1.436811] mmc_power_up.part.0+0xc4/0x164
[ 1.436818] mmc_start_host+0xa0/0xb0
[ 1.436824] mmc_add_host+0x60/0x90
[ 1.436830] __sdhci_add_host+0x174/0x330
[ 1.436836] sdhci_msm_probe+0x7c0/0x920
[ 1.436842] platform_probe+0x68/0xe0
[ 1.436850] really_probe.part.0+0x9c/0x31c
[ 1.436857] __driver_probe_device+0x98/0x144
[ 1.436863] driver_probe_device+0xc8/0x15c
[ 1.436869] __device_attach_driver+0xb4/0x120
[ 1.436875] bus_for_each_drv+0x78/0xd0
[ 1.436881] __device_attach_async_helper+0xac/0xd0
[ 1.436888] async_run_entry_fn+0x34/0x110
[ 1.436895] process_one_work+0x1d0/0x354
[ 1.436903] worker_thread+0x13c/0x470
[ 1.436910] kthread+0x150/0x160
[ 1.436915] ret_from_fork+0x10/0x20
[ 1.436923] ---[ end trace fcfac44cb045c3a8 ]---
Fix the issue by mapping MMC_VDD_35_36 (and MMC_VDD_34_35) to
SDHCI_POWER_330 as well.
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Link: https://lore.kernel.org/r/20211004024935.15326-1-shawn.guo@linaro.org
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 697542bceae51f7620af333b065dd09d213629fb upstream.
Even though there are candiates value if can't find best value, it's
returned -EIO. It's not proper behavior.
If there is not best value, use a first candiate value to work eMMC.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Christian Hewitt <christianshewitt@gmail.com>
Fixes: c537a1c5ff63 ("mmc: dw_mmc: exynos: add variable delay tuning sequence")
Link: https://lore.kernel.org/r/20211022082106.1557-1-jh80.chung@samsung.com
commit 8c8171929116cc23f74743d99251eedadf62341a upstream.
USB control-message timeouts are specified in milliseconds and should
specifically not vary with CONFIG_HZ.
Fixes: 88095e7b473a ("mmc: Add new VUB300 USB-to-SD/SDIO/MMC driver")
Cc: stable@vger.kernel.org # 3.0
Link: https://lore.kernel.org/r/20211025115608.5287-1-johan@kernel.org
commit 10eff1f5788b6ffac212c254e2f3666219576889 upstream.
This reverts commit ab609f25d19858513919369ff3d9a63c02cd9e2e.
This patch is correct in the sense that we _should_ call device_put() in
case of device_register() failure, but the problem in this code is more
vast.
We need to set bus->state to UNMDIOBUS_REGISTERED before calling
device_register() to correctly release the device in mdiobus_free().
This patch prevents us from doing it, since in case of device_register()
failure put_device() will be called 2 times and it will cause UAF or
something else.
Also, Reported-by: tag in revered commit was wrong, since syzbot
reported different leak in same function.
Link: https://lore.kernel.org/netdev/20210928092657.GI2048@kadam/
Acked-by: Yanfei Xu <yanfei.xu@windriver.com>
Signed-off-by: Pavel Skripkin <paskripkin@gmail.com>
Link: https://lore.kernel.org/r/f12fb1faa4eccf0f355788225335eb4309ff2599.1633024062.git.paskripkin@gmail.com
commit 2195f2062e4cc93870da8e71c318ef98a1c51cef upstream.
During probing, the driver tries to get a list (mask) of supported
command types in port100_get_command_type_mask() function. The value
is u64 and 0 is treated as invalid mask (no commands supported). The
function however returns also -ERRNO as u64 which will be interpret as
valid command mask.
Return 0 on every error case of port100_get_command_type_mask(), so the
probing will stop.
Cc: <stable@vger.kernel.org>
Fixes: 0347a6ab300a ("NFC: port100: Commands mechanism implementation")
Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com>
commit a0023bb9dd9bc439d44604eeec62426a990054cd upstream.
mv_init_host() propagates the value returned by mv_chip_id() which in turn
gets propagated by mv_pci_init_one() and hits local_pci_probe().
During the process of driver probing, the probe function should return < 0
for failure, otherwise, the kernel will treat value > 0 as success.
Since this is a bug rather than a recoverable runtime error we should
use dev_alert() instead of dev_err().
Signed-off-by: Zheyu Ma <zheyuma97@gmail.com>
Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com>
commit 6f7c88691191e6c52ef2543d6f1da8d360b27a24 upstream.
Return error code if usb_maxpacket() returns 0 in usbnet_probe()
Fixes: 397430b50a36 ("usbnet: sanity check for maxpacket")
Signed-off-by: Wang Hai <wanghai38@huawei.com>
Reviewed-by: Johan Hovold <johan@kernel.org>
Link: https://lore.kernel.org/r/20211026124015.3025136-1-wanghai38@huawei.com
commit 397430b50a363d8b7bdda00522123f82df6adc5e upstream.
maxpacket of 0 makes no sense and oopses as we need to divide
by it. Give up.
V2: fixed typo in log and stylistic issues
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Reported-by: syzbot+76bb1d34ffa0adc03baa@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20211021122944.21816-1-oneukum@suse.com
commit 091bb549f7722723b284f63ac665e2aedcf9dec9 upstream.
This option is not supported by lld:
ld.lld: error: unknown argument: -p
This has been a no-op in binutils since 2004 (see commit dea514f51da1 in
that tree). Given that the lowest officially supported of binutils for
the kernel is 2.20, which was released in 2009, nobody needs this flag
around so just remove it. Commit 1a381d4a0a9a ("arm64: remove no-op -p
linker flag") did the same for arm64.
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 1f323127cab086e4fd618981b1e5edc396eaf0f4 upstream.
With extra warnings enabled, gcc complains about this function
definition:
arch/arm/probes/kprobes/core.c: In function 'arch_init_kprobes':
arch/arm/probes/kprobes/core.c:465:12: warning: old-style function definition [-Wold-style-definition]
465 | int __init arch_init_kprobes()
Link: https://lore.kernel.org/all/20201027093057.c685a14b386acacb3c449e3d@kernel.org/
Fixes: 24ba613c9d6c ("ARM kprobes: core code")
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk>
commit eaf6cc7165c9c5aa3c2f9faa03a98598123d0afb upstream.
Both the decompressor code and the kasan logic try to override
the memcpy() and memmove() definitions, which leading to a clash
in a KASAN-enabled kernel with XZ decompression:
arch/arm/boot/compressed/decompress.c:50:9: error: 'memmove' macro redefined [-Werror,-Wmacro-redefined]
#define memmove memmove
arch/arm/include/asm/string.h:59:9: note: previous definition is here
#define memmove(dst, src, len) __memmove(dst, src, len)
arch/arm/boot/compressed/decompress.c:51:9: error: 'memcpy' macro redefined [-Werror,-Wmacro-redefined]
#define memcpy memcpy
arch/arm/include/asm/string.h:58:9: note: previous definition is here
#define memcpy(dst, src, len) __memcpy(dst, src, len)
Here we want the set of functions from the decompressor, so undefine
the other macros before the override.
Link: https://lore.kernel.org/linux-arm-kernel/CACRpkdZYJogU_SN3H9oeVq=zJkRgRT1gDz3xp59gdqWXxw-B=w@mail.gmail.com/
Link: https://lore.kernel.org/lkml/202105091112.F5rmd4By-lkp@intel.com/
Fixes: d6d51a96c7d6 ("ARM: 9014/2: Replace string mem* functions for KASan")
Fixes: a7f464f3db93 ("ARM: 7001/2: Wire up support for the XZ decompressor")
Reported-by: kernel test robot <lkp@intel.com>
commit e6a0c958bdf9b2e1b57501fc9433a461f0a6aadd upstream.
A kernel built with CONFIG_THUMB2_KERNEL=y and using clang as the
assembler could generate non-naturally-aligned v7wbi_tlb_fns which
results in a boot failure. The original commit adding the macro missed
the .align directive on this data.
Link: https://github.com/ClangBuiltLinux/linux/issues/1447
Link: https://lore.kernel.org/all/0699da7b-354f-aecc-a62f-e25693209af4@linaro.org/
Debugged-by: Ard Biesheuvel <ardb@kernel.org>
Debugged-by: Nathan Chancellor <nathan@kernel.org>
Debugged-by: Richard Henderson <richard.henderson@linaro.org>
Fixes: 66a625a88174 ("ARM: mm: proc-macros: Add generic proc/cache/tlb struct definition macros")
Suggested-by: Ard Biesheuvel <ardb@kernel.org>
Acked-by: Ard Biesheuvel <ardb@kernel.org>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Tested-by: Nathan Chancellor <nathan@kernel.org>
Link: https://lore.kernel.org/r/20211025190928.054676643@linuxfoundation.org
commit 9d417cbe36eee7afdd85c2e871685f8dab7c2dba upstream.
tglx notes:
This function [futex_detect_cmpxchg] is only needed when an
architecture has to runtime discover whether the CPU supports it or
not. ARM has unconditional support for this, so the obvious thing to
do is the below.
Fixes linkage failure from Clang randconfigs:
kernel/futex.o:(.text.fixup+0x5c): relocation truncated to fit: R_ARM_JUMP24 against `.init.text'
and boot failures for CONFIG_THUMB2_KERNEL.
Link: https://github.com/ClangBuiltLinux/linux/issues/325
Comments from Nick Desaulniers:
See-also: 03b8c7b623c8 ("futex: Allow architectures to skip
futex_atomic_cmpxchg_inatomic() test")
Reported-by: Nathan Chancellor <nathan@kernel.org>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: stable@vger.kernel.org # v3.14+
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
commit ed65df63a39a3f6ed04f7258de8b6789e5021c18 upstream.
While writing an email explaining the "bit = 0" logic for a discussion on
making ftrace_test_recursion_trylock() disable preemption, I discovered a
path that makes the "not do the logic if bit is zero" unsafe.
The recursion logic is done in hot paths like the function tracer. Thus,
any code executed causes noticeable overhead. Thus, tricks are done to try
to limit the amount of code executed. This included the recursion testing
logic.
Having recursion testing is important, as there are many paths that can
end up in an infinite recursion cycle when tracing every function in the
kernel. Thus protection is needed to prevent that from happening.
Because it is OK to recurse due to different running context levels (e.g.
an interrupt preempts a trace, and then a trace occurs in the interrupt
handler), a set of bits are used to know which context one is in (normal,
softirq, irq and NMI). If a recursion occurs in the same level, it is
prevented*.
Then there are infrastructure levels of recursion as well. When more than
one callback is attached to the same function to trace, it calls a loop
function to iterate over all the callbacks. Both the callbacks and the
loop function have recursion protection. The callbacks use the
"ftrace_test_recursion_trylock()" which has a "function" set of context
bits to test, and the loop function calls the internal
trace_test_and_set_recursion() directly, with an "internal" set of bits.
If an architecture does not implement all the features supported by ftrace
then the callbacks are never called directly, and the loop function is
called instead, which will implement the features of ftrace.
Since both the loop function and the callbacks do recursion protection, it
was seemed unnecessary to do it in both locations. Thus, a trick was made
to have the internal set of recursion bits at a more significant bit
location than the function bits. Then, if any of the higher bits were set,
the logic of the function bits could be skipped, as any new recursion
would first have to go through the loop function.
This is true for architectures that do not support all the ftrace
features, because all functions being traced must first go through the
loop function before going to the callbacks. But this is not true for
architectures that support all the ftrace features. That's because the
loop function could be called due to two callbacks attached to the same
function, but then a recursion function inside the callback could be
called that does not share any other callback, and it will be called
directly.
i.e.
traced_function_1: [ more than one callback tracing it ]
call loop_func
loop_func:
trace_recursion set internal bit
call callback
callback:
trace_recursion [ skipped because internal bit is set, return 0 ]
call traced_function_2
traced_function_2: [ only traced by above callback ]
call callback
callback:
[ wash, rinse, repeat, BOOM! out of shampoo! ]
Thus, the "bit == 0 skip" trick is not safe, unless the loop function is
call for all functions.
Since we want to encourage architectures to implement all ftrace features,
having them slow down due to this extra logic may encourage the
maintainers to update to the latest ftrace features. And because this
logic is only safe for them, remove it completely.
[*] There is on layer of recursion that is allowed, and that is to allow
for the transition between interrupt context (normal -> softirq ->
irq -> NMI), because a trace may occur before the context update is
visible to the trace recursion logic.
Link: https://lore.kernel.org/all/609b565a-ed6e-a1da-f025-166691b5d994@linux.alibaba.com/
Link: https://lkml.kernel.org/r/20211018154412.09fcad3c@gandalf.local.home
Cc: Petr Mladek <pmladek@suse.com>
Cc: "James E.J. Bottomley" <James.Bottomley@hansenpartnership.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Albert Ou <aou@eecs.berkeley.edu>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Miroslav Benes <mbenes@suse.cz>
Cc: Joe Lawrence <joe.lawrence@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Jisheng Zhang <jszhang@kernel.org>
Cc: =?utf-8?b?546L6LSH?= <yun.wang@linux.alibaba.com>
Cc: Guo Ren <guoren@kernel.org>
Fixes: edc15cafcbfa3 ("tracing: Avoid unnecessary multiple recursion checks")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit ab609f25d19858513919369ff3d9a63c02cd9e2e upstream.
Once device_register() failed, we should call put_device() to
decrement reference count for cleanup. Or it will cause memory
leak.
BUG: memory leak
unreferenced object 0xffff888114032e00 (size 256):
comm "kworker/1:3", pid 2960, jiffies 4294943572 (age 15.920s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 08 2e 03 14 81 88 ff ff ................
08 2e 03 14 81 88 ff ff 90 76 65 82 ff ff ff ff .........ve.....
backtrace:
[<ffffffff8265cfab>] kmalloc include/linux/slab.h:591 [inline]
[<ffffffff8265cfab>] kzalloc include/linux/slab.h:721 [inline]
[<ffffffff8265cfab>] device_private_init drivers/base/core.c:3203 [inline]
[<ffffffff8265cfab>] device_add+0x89b/0xdf0 drivers/base/core.c:3253
[<ffffffff828dd643>] __mdiobus_register+0xc3/0x450 drivers/net/phy/mdio_bus.c:537
[<ffffffff828cb835>] __devm_mdiobus_register+0x75/0xf0 drivers/net/phy/mdio_devres.c:87
[<ffffffff82b92a00>] ax88772_init_mdio drivers/net/usb/asix_devices.c:676 [inline]
[<ffffffff82b92a00>] ax88772_bind+0x330/0x480 drivers/net/usb/asix_devices.c:786
[<ffffffff82baa33f>] usbnet_probe+0x3ff/0xdf0 drivers/net/usb/usbnet.c:1745
[<ffffffff82c36e17>] usb_probe_interface+0x177/0x370 drivers/usb/core/driver.c:396
[<ffffffff82661d17>] call_driver_probe drivers/base/dd.c:517 [inline]
[<ffffffff82661d17>] really_probe.part.0+0xe7/0x380 drivers/base/dd.c:596
[<ffffffff826620bc>] really_probe drivers/base/dd.c:558 [inline]
[<ffffffff826620bc>] __driver_probe_device+0x10c/0x1e0 drivers/base/dd.c:751
[<ffffffff826621ba>] driver_probe_device+0x2a/0x120 drivers/base/dd.c:781
[<ffffffff82662a26>] __device_attach_driver+0xf6/0x140 drivers/base/dd.c:898
[<ffffffff8265eca7>] bus_for_each_drv+0xb7/0x100 drivers/base/bus.c:427
[<ffffffff826625a2>] __device_attach+0x122/0x260 drivers/base/dd.c:969
[<ffffffff82660916>] bus_probe_device+0xc6/0xe0 drivers/base/bus.c:487
[<ffffffff8265cd0b>] device_add+0x5fb/0xdf0 drivers/base/core.c:3359
[<ffffffff82c343b9>] usb_set_configuration+0x9d9/0xb90 drivers/usb/core/message.c:2170
[<ffffffff82c4473c>] usb_generic_driver_probe+0x8c/0xc0 drivers/usb/core/generic.c:238
BUG: memory leak
unreferenced object 0xffff888116f06900 (size 32):
comm "kworker/0:2", pid 2670, jiffies 4294944448 (age 7.160s)
75 73 62 2d 30 30 31 3a 30 30 33 00 00 00 00 00 usb-001:003.....
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff81484516>] kstrdup+0x36/0x70 mm/util.c:60
[<ffffffff814845a3>] kstrdup_const+0x53/0x80 mm/util.c:83
[<ffffffff82296ba2>] kvasprintf_const+0xc2/0x110 lib/kasprintf.c:48
[<ffffffff82358d4b>] kobject_set_name_vargs+0x3b/0xe0 lib/kobject.c:289
[<ffffffff826575f3>] dev_set_name+0x63/0x90 drivers/base/core.c:3147
[<ffffffff828dd63b>] __mdiobus_register+0xbb/0x450 drivers/net/phy/mdio_bus.c:535
Reported-by: syzbot+398e7dc692ddbbb4cfec@syzkaller.appspotmail.com
Signed-off-by: Yanfei Xu <yanfei.xu@windriver.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit b37a15188eae9d4c49c5bb035e0c8d4058e4d9b3 ]
The snd_hdac_bus_reset_link() contains logic to clear STATESTS register
before performing controller reset. This code dates back to an old
bugfix in commit e8a7f136f5ed ("[ALSA] hda-intel - Improve HD-audio
codec probing robustness"). Originally the code was added to
azx_reset().
The code was moved around in commit a41d122449be ("ALSA: hda - Embed bus
into controller object") and ended up to snd_hdac_bus_reset_link() and
called primarily via snd_hdac_bus_init_chip().
The logic to clear STATESTS is correct when snd_hdac_bus_init_chip() is
called when controller is not in reset. In this case, STATESTS can be
cleared. This can be useful e.g. when forcing a controller reset to retry
codec probe. A normal non-power-on reset will not clear the bits.
However, this old logic is problematic when controller is already in
reset. The HDA specification states that controller must be taken out of
reset before writing to registers other than GCTL.CRST (1.0a spec,
3.3.7). The write to STATESTS in snd_hdac_bus_reset_link() will be lost
if the controller is already in reset per the HDA specification mentioned.
This has been harmless on older hardware. On newer generation of Intel
PCIe based HDA controllers, if configured to report issues, this write
will emit an unsupported request error. If ACPI Platform Error Interface
(APEI) is enabled in kernel, this will end up to kernel log.
Fix the code in snd_hdac_bus_reset_link() to only clear the STATESTS if
the function is called when controller is not in reset. Otherwise
clearing the bits is not possible and should be skipped.
Signed-off-by: Kai Vehmanen <kai.vehmanen@linux.intel.com>
Link: https://lore.kernel.org/r/20211012142935.3731820-1-kai.vehmanen@linux.intel.com
[ Upstream commit a0c5814b9933f25ecb6de169483c5b88cf632bca ]
The comment decribing the IPC timeout hadn't been updated when the
actual timeout was changed from 3 to 5 seconds in
commit a7d53dbbc70a ("platform/x86: intel_scu_ipc: Increase virtual
timeout from 3 to 5 seconds") .
Since the value is anyway updated to 10s now, take this opportunity to
update the value in the comment too.
Signed-off-by: Prashant Malani <pmalani@chromium.org>
Cc: Benson Leung <bleung@chromium.org>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Link: https://lore.kernel.org/r/20210928101932.2543937-4-pmalani@chromium.org
[ Upstream commit 6510e80a0b81b5d814e3aea6297ba42f5e76f73c ]
The driver can call card->isac.release() function from an atomic
context.
Fix this by calling this function after releasing the lock.
The following log reveals it:
[ 44.168226 ] BUG: sleeping function called from invalid context at kernel/workqueue.c:3018
[ 44.168941 ] in_atomic(): 1, irqs_disabled(): 1, non_block: 0, pid: 5475, name: modprobe
[ 44.169574 ] INFO: lockdep is turned off.
[ 44.169899 ] irq event stamp: 0
[ 44.170160 ] hardirqs last enabled at (0): [<0000000000000000>] 0x0
[ 44.170627 ] hardirqs last disabled at (0): [<ffffffff814209ed>] copy_process+0x132d/0x3e00
[ 44.171240 ] softirqs last enabled at (0): [<ffffffff81420a1a>] copy_process+0x135a/0x3e00
[ 44.171852 ] softirqs last disabled at (0): [<0000000000000000>] 0x0
[ 44.172318 ] Preemption disabled at:
[ 44.172320 ] [<ffffffffa009b0a9>] nj_release+0x69/0x500 [netjet]
[ 44.174441 ] Call Trace:
[ 44.174630 ] dump_stack_lvl+0xa8/0xd1
[ 44.174912 ] dump_stack+0x15/0x17
[ 44.175166 ] ___might_sleep+0x3a2/0x510
[ 44.175459 ] ? nj_release+0x69/0x500 [netjet]
[ 44.175791 ] __might_sleep+0x82/0xe0
[ 44.176063 ] ? start_flush_work+0x20/0x7b0
[ 44.176375 ] start_flush_work+0x33/0x7b0
[ 44.176672 ] ? trace_irq_enable_rcuidle+0x85/0x170
[ 44.177034 ] ? kasan_quarantine_put+0xaa/0x1f0
[ 44.177372 ] ? kasan_quarantine_put+0xaa/0x1f0
[ 44.177711 ] __flush_work+0x11a/0x1a0
[ 44.177991 ] ? flush_work+0x20/0x20
[ 44.178257 ] ? lock_release+0x13c/0x8f0
[ 44.178550 ] ? __kasan_check_write+0x14/0x20
[ 44.178872 ] ? do_raw_spin_lock+0x148/0x360
[ 44.179187 ] ? read_lock_is_recursive+0x20/0x20
[ 44.179530 ] ? __kasan_check_read+0x11/0x20
[ 44.179846 ] ? do_raw_spin_unlock+0x55/0x900
[ 44.180168 ] ? ____kasan_slab_free+0x116/0x140
[ 44.180505 ] ? _raw_spin_unlock_irqrestore+0x41/0x60
[ 44.180878 ] ? skb_queue_purge+0x1a3/0x1c0
[ 44.181189 ] ? kfree+0x13e/0x290
[ 44.181438 ] flush_work+0x17/0x20
[ 44.181695 ] mISDN_freedchannel+0xe8/0x100
[ 44.182006 ] isac_release+0x210/0x260 [mISDNipac]
[ 44.182366 ] nj_release+0xf6/0x500 [netjet]
[ 44.182685 ] nj_remove+0x48/0x70 [netjet]
[ 44.182989 ] pci_device_remove+0xa9/0x250
[ Upstream commit 6636fec29cdf6665bd219564609e8651f6ddc142 ]
On SPEAr3xx, ethernet driver is not compatible with the SPEAr600
one.
Indeed, SPEAr3xx uses an earlier version of this IP (v3.40) and
needs some driver tuning compare to SPEAr600.
The v3.40 IP support was added to stmmac driver and this patch
fixes this issue and use the correct compatible string for
SPEAr3xx
Signed-off-by: Herve Codina <herve.codina@bootlin.com>
commit 77076934afdcd46516caf18ed88b2f88025c9ddb upstream.
This option, NF_CONNTRACK_SECMARK, is a bool, so it can never be 'm'.
Fixes: 33b8e77605620 ("[NETFILTER]: Add CONFIG_NETFILTER_ADVANCED option")
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
commit 1f3e2e97c003f80c4b087092b225c8787ff91e4d upstream.
The cmtp_add_connection() would add a cmtp session to a controller
and run a kernel thread to process cmtp.
__module_get(THIS_MODULE);
session->task = kthread_run(cmtp_session, session, "kcmtpd_ctr_%d",
session->num);
During this process, the kernel thread would call detach_capi_ctr()
to detach a register controller. if the controller
was not attached yet, detach_capi_ctr() would
trigger an array-index-out-bounds bug.
[ 46.866069][ T6479] UBSAN: array-index-out-of-bounds in
drivers/isdn/capi/kcapi.c:483:21
[ 46.867196][ T6479] index -1 is out of range for type 'capi_ctr *[32]'
[ 46.867982][ T6479] CPU: 1 PID: 6479 Comm: kcmtpd_ctr_0 Not tainted
5.15.0-rc2+ #8
[ 46.869002][ T6479] Hardware name: QEMU Standard PC (i440FX + PIIX,
1996), BIOS 1.14.0-2 04/01/2014
[ 46.870107][ T6479] Call Trace:
[ 46.870473][ T6479] dump_stack_lvl+0x57/0x7d
[ 46.870974][ T6479] ubsan_epilogue+0x5/0x40
[ 46.871458][ T6479] __ubsan_handle_out_of_bounds.cold+0x43/0x48
[ 46.872135][ T6479] detach_capi_ctr+0x64/0xc0
[ 46.872639][ T6479] cmtp_session+0x5c8/0x5d0
[ 46.873131][ T6479] ? __init_waitqueue_head+0x60/0x60
[ 46.873712][ T6479] ? cmtp_add_msgpart+0x120/0x120
[ 46.874256][ T6479] kthread+0x147/0x170
[ 46.874709][ T6479] ? set_kthread_struct+0x40/0x40
[ 46.875248][ T6479] ret_from_fork+0x1f/0x30
[ 46.875773][ T6479]
Signed-off-by: Xiaolong Huang <butterflyhuangxx@gmail.com>
Link: https://lore.kernel.org/r/20211008065830.305057-1-butterflyhuangxx@gmail.com
commit 1b1499a817c90fd1ce9453a2c98d2a01cca0e775 upstream.
The nci_core_conn_close_rsp_packet() function will release the conn_info
with given conn_id. However, it needs to set the rf_conn_info to NULL to
prevent other routines like nci_rf_intf_activated_ntf_packet() to trigger
the UAF.
Reviewed-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com>
Signed-off-by: Lin Ma <linma@zju.edu.cn>
commit a295aef603e109a47af355477326bd41151765b6 upstream.
The following reproducer
mkdir lower upper work merge
touch lower/old
touch lower/new
mount -t overlay overlay -olowerdir=lower,upperdir=upper,workdir=work merge
rm merge/new
mv merge/old merge/new & unlink upper/new
may result in this race:
PROCESS A:
rename("merge/old", "merge/new");
overwrite=true,ovl_lower_positive(old)=true,
ovl_dentry_is_whiteout(new)=true -> flags |= RENAME_EXCHANGE
PROCESS B:
unlink("upper/new");
PROCESS A:
lookup newdentry in new_upperdir
call vfs_rename() with negative newdentry and RENAME_EXCHANGE
Fix by adding the missing check for negative newdentry.
Signed-off-by: Zheng Liang <zhengliang6@huawei.com>
Fixes: e9be9d5e76e3 ("overlay filesystem")
Cc: <stable@vger.kernel.org> # v3.18
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Signed-off-by: Masami Ichikawa(CIP) <masami.ichikawa@cybertrust.co.jp>
commit 5af82c81b2c49cfb1cad84d9eb6eab0e3d1c4842 upstream.
The put callback of a kcontrol is supposed to return 1 when the value
is changed, and this will be notified to user-space. However, some
DAPM kcontrols always return 0 (except for errors), hence the
user-space misses the update of a control value.
This patch corrects the behavior by properly returning 1 when the
value gets updated.
Reported-and-tested-by: Hans de Goede <hdegoede@redhat.com>
Link: https://lore.kernel.org/r/20211006141712.2439-1-tiwai@suse.de
commit 3c414eb65c294719a91a746260085363413f91c1 upstream.
As per discussion at: https://github.com/szszoke/sennheiser-gsp670-pulseaudio-profile/issues/13
The GSP670 has 2 playback and 1 recording device that by default are
detected in an incompatible order for alsa. This may have been done to make
it compatible for the console by the manufacturer and only affects the
latest firmware which uses its own ID.
This quirk will resolve this by reordering the channels.
Signed-off-by: Brendan Grieve <brendan@grieve.com.au>
Link: https://lore.kernel.org/r/20211015025335.196592-1-brendan@grieve.com.au
commit b0e901280d9860a0a35055f220e8e457f300f40a upstream.
Commit 6e7b64b9dd6d ("elfcore: fix building with clang") introduces
special handling for two architectures, ia64 and User Mode Linux.
However, the wrong name, i.e., CONFIG_UM, for the intended Kconfig
symbol for User-Mode Linux was used.
Although the directory for User Mode Linux is ./arch/um; the Kconfig
symbol for this architecture is called CONFIG_UML.
Luckily, ./scripts/checkkconfigsymbols.py warns on non-existing configs:
UM
Referencing files: include/linux/elfcore.h
Similar symbols: UML, NUMA
Correct the name of the config to the intended one.
[akpm@linux-foundation.org: fix um/x86_64, per Catalin]
Link: https://lkml.kernel.org/r/20211006181119.2851441-1-catalin.marinas@arm.com
Link: https://lkml.kernel.org/r/YV6pejGzLy5ppEpt@arm.com
Link: https://lkml.kernel.org/r/20211006082209.417-1-lukas.bulwahn@gmail.com
Fixes: 6e7b64b9dd6d ("elfcore: fix building with clang")
Signed-off-by: Lukas Bulwahn <lukas.bulwahn@gmail.com>
Cc: Nathan Chancellor <nathan@kernel.org>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Barret Rhoden <brho@google.com>
commit b15fa9224e6e1239414525d8d556d824701849fc upstream.
Starting with kernel 5.11 built with CONFIG_FORTIFY_SOURCE mouting an
ocfs2 filesystem with either o2cb or pcmk cluster stack fails with the
trace below. Problem seems to be that strings for cluster stack and
cluster name are not guaranteed to be null terminated in the disk
representation, while strlcpy assumes that the source string is always
null terminated. This causes a read outside of the source string
triggering the buffer overflow detection.
detected buffer overflow in strlen
kernel BUG at lib/string.c:1149!
invalid opcode: 0000 [#1] SMP PTI
CPU: 1 PID: 910 Comm: mount.ocfs2 Not tainted 5.14.0-1-amd64 #1
Debian 5.14.6-2
RIP: 0010:fortify_panic+0xf/0x11
Call Trace:
ocfs2_initialize_super.isra.0.cold+0xc/0x18 [ocfs2]
ocfs2_fill_super+0x359/0x19b0 [ocfs2]
mount_bdev+0x185/0x1b0
legacy_get_tree+0x27/0x40
vfs_get_tree+0x25/0xb0
path_mount+0x454/0xa20
__x64_sys_mount+0x103/0x140
do_syscall_64+0x3b/0xc0
entry_SYSCALL_64_after_hwframe+0x44/0xae
Link: https://lkml.kernel.org/r/20210929180654.32460-1-vvidic@valentin-vidic.from.hr
Signed-off-by: Valentin Vidic <vvidic@valentin-vidic.from.hr>
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Cc: Mark Fasheh <mark@fasheh.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
Cc: Changwei Ge <gechangwei@live.cn>
Cc: Gang He <ghe@suse.com>
Cc: Jun Piao <piaojun@huawei.com>
commit 949fe9b35570361bc6ee2652f89a0561b26eec98 upstream.
When remove the module peek_pci, referencing 'chan' again after
releasing 'dev' will cause UAF.
Fix this by releasing 'dev' later.
[ 35.961814 ] BUG: KASAN: use-after-free in peak_pci_remove+0x16f/0x270 [peak_pci]
[ 35.963414 ] Read of size 8 at addr ffff888136998ee8 by task modprobe/5537
[ 35.965513 ] Call Trace:
[ 35.965718 ] dump_stack_lvl+0xa8/0xd1
[ 35.966028 ] print_address_description+0x87/0x3b0
[ 35.966420 ] kasan_report+0x172/0x1c0
[ 35.966725 ] ? peak_pci_remove+0x16f/0x270 [peak_pci]
[ 35.967137 ] ? trace_irq_enable_rcuidle+0x10/0x170
[ 35.967529 ] ? peak_pci_remove+0x16f/0x270 [peak_pci]
[ 35.967945 ] __asan_report_load8_noabort+0x14/0x20
[ 35.968346 ] peak_pci_remove+0x16f/0x270 [peak_pci]
[ 35.968752 ] pci_device_remove+0xa9/0x250
Fixes: e6d9c80b7ca1 ("can: peak_pci: add support of some new PEAK-System PCI cards")
Link: https://lore.kernel.org/all/1634192913-15639-1-git-send-email-zheyuma97@gmail.com
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
notification
commit 3d031abc7e7249573148871180c28ecedb5e27df upstream.
This corrects the lack of notification of a return to ERROR_ACTIVE
state for USB - CANFD devices from PEAK-System.
Fixes: 0a25e1f4f185 ("can: peak_usb: add support for PEAK new CANFD USB adapters")
Link: https://lore.kernel.org/all/20210929142111.55757-1-s.grosjean@peak-system.com
Signed-off-by: Stephane Grosjean <s.grosjean@peak-system.com>
commit f7c05c3987dcfde9a4e8c2d533db013fabebca0d upstream.
If the driver was not opened, rcar_can_suspend() should not call
clk_disable() because the clock was not enabled.
Fixes: fd1159318e55 ("can: add Renesas R-Car CAN driver")
Link: https://lore.kernel.org/all/20210924075556.223685-1-yoshihiro.shimoda.uh@renesas.com
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Tested-by: Ayumi Nakamichi <ayumi.nakamichi.kf@renesas.com>
Reviewed-by: Ulrich Hecht <uli+renesas@fpond.eu>
Tested-by: Biju Das <biju.das.jz@bp.renesas.com>
[ Upstream commit 4cce60f15c04d69eff6ffc539ab09137dbe15070 ]
Both arch/nios2/ and drivers/mmc/host/tmio_mmc.c define a macro
with the name "CTL_STATUS". Change the one in arch/nios2/ to be
"CTL_FSTATUS" (flags status) to eliminate the build warning.
In file included from ../drivers/mmc/host/tmio_mmc.c:22:
drivers/mmc/host/tmio_mmc.h:31: warning: "CTL_STATUS" redefined
31 | #define CTL_STATUS 0x1c
arch/nios2/include/asm/registers.h:14: note: this is the location of the previous definition
14 | #define CTL_STATUS 0
Fixes: b31ebd8055ea ("nios2: Nios2 registers")
Cc: Dinh Nguyen <dinguyen@kernel.org>
[ Upstream commit 174c376278949c44aad89c514a6b5db6cee8db59 ]
Because the data pointer of net/ipv4/vs/debug_level is not updated per
netns, it must be marked as read-only in non-init netns.
Fixes: c6d2d445d8de ("IPVS: netns, final patch enabling network name space.")
Signed-off-by: Antoine Tenart <atenart@kernel.org>
Acked-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit c20106944eb679fa3ab7e686fe5f6ba30fbc51e5 ]
If nfsd has existing listening sockets without any processes, then an error
returned from svc_create_xprt() for an additional transport will remove
those existing listeners. We're seeing this in practice when userspace
attempts to create rpcrdma transports without having the rpcrdma modules
present before creating nfsd kernel processes. Fix this by checking for
existing sockets before calling nfsd_destroy().
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit 9973a43012b6ad1720dbc4d5faf5302c28635b8c upstream.
Fix the following build/link errors by adding a dependency on
CRYPTO, CRYPTO_HASH, CRYPTO_SHA256 and CRC32:
ld: drivers/net/usb/r8152.o: in function `rtl8152_fw_verify_checksum':
r8152.c:(.text+0x2b2a): undefined reference to `crypto_alloc_shash'
ld: r8152.c:(.text+0x2bed): undefined reference to `crypto_shash_digest'
ld: r8152.c:(.text+0x2c50): undefined reference to `crypto_destroy_tfm'
ld: drivers/net/usb/r8152.o: in function `_rtl8152_set_rx_mode':
r8152.c:(.text+0xdcb0): undefined reference to `crc32_le'
Fixes: 9370f2d05a2a1 ("r8152: support request_firmware for RTL8153")
Fixes: ac718b69301c7 ("net/usb: new driver for RTL8152")
commit 2133c4fc8e1348dcb752f267a143fe2254613b34 upstream.
The initialization of pointer dev dereferences pointer edp before
edp is null checked, so there is a potential null pointer deference
issue. Fix this by only dereferencing edp after edp has been null
checked.
Addresses-Coverity: ("Dereference before null check")
Fixes: ab5b0107ccf3 ("drm/msm: Initial add eDP support in msm drm driver (v5)")
Reviewed-by: Dmitry Baryshkov <dmitry.baryshkov@linaro.org>
Link: https://lore.kernel.org/r/20210929121857.213922-1-colin.king@canonical.com
Signed-off-by: Rob Clark <robdclark@chromium.org>
commit 013923477cb311293df9079332cf8b806ed0e6f2 upstream.
The last byte of "pad" is used without being initialized.
Fixes: 55dba3120fbc ("libata: update ->data_xfer hook for ATAPI")
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
commit 291c932fc3692e4d211a445ba8aa35663831bac7 upstream.
'skb' is allocated in digital_in_send_sdd_req(), but not free when
digital_in_send_cmd() failed, which will cause memory leak. Fix it
by freeing 'skb' if digital_in_send_cmd() return failed.
Fixes: 2c66daecc409 ("NFC Digital: Add NFC-A technology support")
Signed-off-by: Ziyang Xuan <william.xuanziyang@huawei.com>
commit 58e7dcc9ca29c14e44267a4d0ea61e3229124907 upstream.
'params' is allocated in digital_tg_listen_mdaa(), but not free when
digital_send_cmd() failed, which will cause memory leak. Fix it by
freeing 'params' if digital_send_cmd() return failed.
Fixes: 1c7a4c24fbfd ("NFC Digital: Add target NFC-DEP support")
commit 0911ab31896f0e908540746414a77dd63912748d upstream.
When nfc proto id is using, nfc_proto_register() return -EBUSY error
code, but forgot to unregister proto. Fix it by adding proto_unregister()
in the error handling case.
Fixes: c7fe3b52c128 ("NFC: add NFC socket family")
Link: https://lore.kernel.org/r/20211013034932.2833737-1-william.xuanziyang@huawei.com
commit 40507e7aada8422c38aafa0c8a1a09e4623c712a upstream.
After recent cleanups, gcc started warning about a suspicious
memcpy() call during the s2io_io_resume() function:
In function '__dev_addr_set',
inlined from 'eth_hw_addr_set' at include/linux/etherdevice.h:318:2,
inlined from 's2io_set_mac_addr' at drivers/net/ethernet/neterion/s2io.c:5205:2,
inlined from 's2io_io_resume' at drivers/net/ethernet/neterion/s2io.c:8569:7:
arch/x86/include/asm/string_32.h:182:25: error: '__builtin_memcpy' accessing 6 bytes at offsets 0 and 2 overlaps 4 bytes at offset 2 [-Werror=restrict]
182 | #define memcpy(t, f, n) __builtin_memcpy(t, f, n)
include/linux/netdevice.h:4648:9: note: in expansion of macro 'memcpy'
4648 | memcpy(dev->dev_addr, addr, len);
What apparently happened is that an old cleanup changed the calling
conventions for s2io_set_mac_addr() from taking an ethernet address
as a character array to taking a struct sockaddr, but one of the
callers was not changed at the same time.
Change it to instead call the low-level do_s2io_prog_unicast() function
that still takes the old argument type.
Fixes: 2fd376884558 ("S2io: Added support set_mac_address driver entry point")
Link: https://lore.kernel.org/r/20211013143613.2049096-1-arnd@kernel.org
commit f03dca0c9e2297c84a018e306f8a9cd534ee4287 upstream.
devm_regmap_init may return error which caused by like out of memory,
this will results in null pointer dereference later when reading
or writing register:
general protection fault in encx24j600_spi_probe
KASAN: null-ptr-deref in range [0x0000000000000090-0x0000000000000097]
CPU: 0 PID: 286 Comm: spi-encx24j600- Not tainted 5.15.0-rc2-00142-g9978db750e31-dirty #11 9c53a778c1306b1b02359f3c2bbedc0222cba652
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.13.0-1ubuntu1.1 04/01/2014
RIP: 0010:regcache_cache_bypass drivers/base/regmap/regcache.c:540
Code: 54 41 89 f4 55 53 48 89 fb 48 83 ec 08 e8 26 94 a8 fe 48 8d bb a0 00 00 00 48 b8 00 00 00 00 00 fc ff df 48 89 fa 48 c1 ea 03 <80> 3c 02 00 0f 85 4a 03 00 00 4c 8d ab b0 00 00 00 48 8b ab a0 00
RSP: 0018:ffffc900010476b8 EFLAGS: 00010207
RAX: dffffc0000000000 RBX: fffffffffffffff4 RCX: 0000000000000000
RDX: 0000000000000012 RSI: ffff888002de0000 RDI: 0000000000000094
RBP: ffff888013c9a000 R08: 0000000000000000 R09: fffffbfff3f9cc6a
R10: ffffc900010476e8 R11: fffffbfff3f9cc69 R12: 0000000000000001
R13: 000000000000000a R14: ffff888013c9af54 R15: ffff888013c9ad08
FS: 00007ffa984ab580(0000) GS:ffff88801fe00000(0000) knlGS:0000000000000000
CR2: 000055a6384136c8 CR3: 000000003bbe6003 CR4: 0000000000770ef0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
PKRU: 55555554
Call Trace:
encx24j600_spi_probe drivers/net/ethernet/microchip/encx24j600.c:459
spi_probe drivers/spi/spi.c:397
really_probe drivers/base/dd.c:517
__driver_probe_device drivers/base/dd.c:751
driver_probe_device drivers/base/dd.c:782
__device_attach_driver drivers/base/dd.c:899
bus_for_each_drv drivers/base/bus.c:427
__device_attach drivers/base/dd.c:971
bus_probe_device drivers/base/bus.c:487
device_add drivers/base/core.c:3364
__spi_add_device drivers/spi/spi.c:599
spi_add_device drivers/spi/spi.c:641
spi_new_device drivers/spi/spi.c:717
new_device_store+0x18c/0x1f1 [spi_stub 4e02719357f1ff33f5a43d00630982840568e85e]
dev_attr_store drivers/base/core.c:2074
sysfs_kf_write fs/sysfs/file.c:139
kernfs_fop_write_iter fs/kernfs/file.c:300
new_sync_write fs/read_write.c:508 (discriminator 4)
vfs_write fs/read_write.c:594
ksys_write fs/read_write.c:648
do_syscall_64 arch/x86/entry/common.c:50
entry_SYSCALL_64_after_hwframe arch/x86/entry/entry_64.S:113
Add error check in devm_regmap_init_encx24j600 to avoid this situation.
Fixes: 04fbfce7a222 ("net: Microchip encx24j600 driver")
Signed-off-by: Nanyong Sun <sunnanyong@huawei.com>
Link: https://lore.kernel.org/r/20211012125901.3623144-1-sunnanyong@huawei.com
commit 427f974d9727ca681085ddcd0530c97ab5811ae0 upstream.
Fix the following build/link error by adding a dependency on the CRC32
routines:
ld: drivers/net/ethernet/korina.o: in function `korina_multicast_list':
korina.c:(.text+0x1af): undefined reference to `crc32_le'
Fixes: ef11291bcd5f9 ("Add support the Korina (IDT RC32434) Ethernet MAC")
Acked-by: Florian fainelli <f.fainelli@gmail.com>
Link: https://lore.kernel.org/r/20211012152509.21771-1-vegard.nossum@oracle.com
commit e599ee234ad4fdfe241d937bbabd96e0d8f9d868 upstream.
routines:
ld: drivers/net/ethernet/arc/emac_main.o: in function `arc_emac_set_rx_mode':
emac_main.c:(.text+0xb11): undefined reference to `crc32_le'
The crc32_le() call comes through the ether_crc_le() call in
arc_emac_set_rx_mode().
[v2: moved the select to ARC_EMAC_CORE; the Makefile is a bit confusing,
but the error comes from emac_main.o, which is part of the arc_emac module,
which in turn is enabled by CONFIG_ARC_EMAC_CORE. Note that arc_emac is
different from emac_arc...]
Fixes: 775dd682e2b0ec ("arc_emac: implement promiscuous mode and multicast filtering")
Link: https://lore.kernel.org/r/20211012093446.1575-1-vegard.nossum@oracle.com
