commit 134d12fae0bb8f3d60dc7440a9e1950bb5427167 upstream.
For some weird (freudian?) reason, commit 435792d "ARM: OMAP: make
iommu subsys_initcall to fix builtin omap3isp" unintentionally changed
the mailbox's initcall instead of the iommu's.
Fix that.
Reported-by: Fernando Guzman Lugo <fernando.lugo@ti.com>
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Joerg Roedel <Joerg.Roedel@amd.com>
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit c88db233251b026fda775428f0250c760553e216 upstream.
Rename static struct pci_driver pch_spi_pcidev to
pch_spi_pcidev_driver to get rid of warnings from modpost checks.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
commit 97e43c983c721a47546e6db3b7711dcd912a6481 upstream.
Silence following warnings:
WARNING: drivers/mfd/cs5535-mfd.o(.data+0x20): Section mismatch in
reference from the variable cs5535_mfd_drv to the function
.devinit.text:cs5535_mfd_probe()
The variable cs5535_mfd_drv references
the function __devinit cs5535_mfd_probe()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console
WARNING: drivers/mfd/cs5535-mfd.o(.data+0x28): Section mismatch in
.devexit.text:cs5535_mfd_remove()
the function __devexit cs5535_mfd_remove()
variable with __exit* (see linux/init.h) or name the variable:
Rename the variable from *_drv to *_driver so
modpost ignore the OK references to __devinit/__devexit
functions.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Acked-by: Andres Salomon <dilinger@queued.net>
commit 474de3bbadd9cb75ffc32cc759c40d868343d46c upstream.
Fix scan_timers() to be __devinit and not __init since
the function get called from cs5535_mfgpt_probe which is
__devinit.
commit 0ca93de9b789e0eb05e103f0c04de72df13da73a upstream.
Fix dm-raid flush support.
Both md and dm have support for flush, but the dm-raid target
forgot to set the flag to indicate that flushes should be
passed on. (Important for data integrity e.g. with writeback cache
enabled.)
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Acked-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
commit 3aa3b2b2b1edb813dc5342d0108befc39541542d upstream.
The 'rebuild' parameter is used to rebuild individual devices in an
array (e.g. resynchronize a RAID1 device or recalculate a parity device
in higher RAID). The MD_CHANGE_DEVS flag must be set when this
parameter is given in order to write out the superblocks and make the
change take immediate effect. The code that handles new devices in
super_load already sets MD_CHANGE_DEVS and 'FirstUse'. (The 'FirstUse'
flag was being set as a special case for rebuilds in
super_init_validation.)
Add a condition for rebuilds in super_load to take care of both flags
without the special case in 'super_init_validation'.
commit af63bcb817cf708f53bcae6edc2e3fb7dd7d8051 upstream.
Correct the number of mapped sectors shown on a thin device's
status line by decrementing td->mapped_blocks in __remove() each time
a block is removed.
Signed-off-by: Joe Thornber <ejt@redhat.com>
commit 4469a5f387fdde956894137751a41473618a4a52 upstream.
If dm_sm_disk_create() fails the superblock must be unlocked.
commit 1f3db25d8be4ac50b897b39609802183ea68a514 upstream.
The __open_device() error paths in __create_thin() and __create_snap()
incorrectly call __close_device() even if td was not initialized by
__open_device(). Remove this.
Also document __open_device() return values, remove a redundant
td->changed = 1 in __create_thin(), and insert an additional
safeguard against creating an already-existing device.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 1212268fd9816e3b8801e57b896fceaec71969ad upstream.
The following BUG is hit on the first read that is submitted to a dm
flakey test device while the device is "down" if the corrupt_bio_byte
feature wasn't requested when the device's table was loaded.
Example DM table that will hit this BUG:
0 2097152 flakey 8:0 2048 0 30
This bug was introduced by commit a3998799fb4df0b0af8271a7d50c4269032397aa
(dm flakey: add corrupt_bio_byte feature) in v3.1-rc1.
BUG: unable to handle kernel paging request at ffff8801cfce3fff
IP: [<ffffffffa008c233>] corrupt_bio_data+0x6e/0xae [dm_flakey]
PGD 1606063 PUD 0
Oops: 0002 [#1] SMP
Call Trace:
<IRQ>
[<ffffffffa008c2b5>] flakey_end_io+0x42/0x48 [dm_flakey]
[<ffffffffa00dca98>] clone_endio+0x54/0xb6 [dm_mod]
[<ffffffff81130587>] bio_endio+0x2d/0x2f
[<ffffffff811c819a>] req_bio_endio+0x96/0x9f
[<ffffffff811c94b9>] blk_update_request+0x1dc/0x3a9
[<ffffffff812f5ee2>] ? rcu_read_unlock+0x21/0x23
[<ffffffff811c96a6>] blk_update_bidi_request+0x20/0x6e
[<ffffffff811c9713>] blk_end_bidi_request+0x1f/0x5d
[<ffffffff811c978d>] blk_end_request+0x10/0x12
[<ffffffff8128f450>] scsi_io_completion+0x1e5/0x4b1
[<ffffffff812882a9>] scsi_finish_command+0xec/0xf5
[<ffffffff8128f830>] scsi_softirq_done+0xff/0x108
[<ffffffff811ce284>] blk_done_softirq+0x84/0x98
[<ffffffff81048d19>] __do_softirq+0xe3/0x1d5
[<ffffffff8138f83f>] ? _raw_spin_lock+0x62/0x69
[<ffffffff810997cf>] ? handle_irq_event+0x4c/0x61
[<ffffffff8139833c>] call_softirq+0x1c/0x30
[<ffffffff81003b37>] do_softirq+0x4b/0xa3
[<ffffffff81048a39>] irq_exit+0x53/0xca
[<ffffffff81398acd>] do_IRQ+0x9d/0xb4
[<ffffffff81390333>] common_interrupt+0x73/0x73
commit 0c535e0d6f463365c29623350dbd91642363c39b upstream.
This patch fixes a crash by recognising discards in dm_io.
Currently dm_mirror can send REQ_DISCARD bios if running over a
discard-enabled device and without support in dm_io the system
crashes badly.
BUG: unable to handle kernel paging request at 00800000
IP: __bio_add_page.part.17+0xf5/0x1e0
bio_add_page+0x56/0x70
dispatch_io+0x1cf/0x240 [dm_mod]
? km_get_page+0x50/0x50 [dm_mod]
? vm_next_page+0x20/0x20 [dm_mod]
? mirror_flush+0x130/0x130 [dm_mirror]
dm_io+0xdc/0x2b0 [dm_mod]
Introduced in 2.6.38-rc1 by commit 5fc2ffeabb9ee0fc0e71ff16b49f34f0ed3d05b4
(dm raid1: support discard).
Signed-off-by: Milan Broz <mbroz@redhat.com>
commit 902c6a96a7cb9c50d2a8aed1788efad0a5d8f04c upstream.
If 'argc' is zero we jump to the 'out:' label, but this leaks the
(unused) memory that 'dm_split_args()' allocated for 'argv' if the
string being split consisted entirely of whitespace. Jump to the
'out_argv:' label instead to free up that memory.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
commit 6b7f000eb6a0b81d7a809833edb7a457eedf8512 upstream.
This function is called from enable_iommus(), which in turn is used
from amd_iommu_resume().
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d upstream.
|kernel BUG at kernel/rtmutex.c:724!
|[<c029599c>] (rt_spin_lock_slowlock+0x108/0x2bc) from [<c01c2330>] (defer_bh+0x1c/0xb4)
|[<c01c2330>] (defer_bh+0x1c/0xb4) from [<c01c3afc>] (rx_complete+0x14c/0x194)
|[<c01c3afc>] (rx_complete+0x14c/0x194) from [<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0)
|[<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0) from [<c01e1ff4>] (musb_giveback+0x34/0x40)
|[<c01e1ff4>] (musb_giveback+0x34/0x40) from [<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0)
|[<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0) from [<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c)
|[<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c) from [<c01e2ed0>] (musb_urb_dequeue+0xec/0x108)
|[<c01e2ed0>] (musb_urb_dequeue+0xec/0x108) from [<c01cbb90>] (unlink1+0xbc/0xcc)
|[<c01cbb90>] (unlink1+0xbc/0xcc) from [<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8)
|[<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8) from [<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58)
|[<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58) from [<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c)
|[<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c) from [<c01c2d68>] (usbnet_stop+0x100/0x15c)
|[<c01c2d68>] (usbnet_stop+0x100/0x15c) from [<c020f718>] (__dev_close_many+0x94/0xc8)
defer_bh() takes the lock which is hold during unlink_urbs(). The safe
walk suggest that the skb will be removed from the list and this is done
by defer_bh() so it seems to be okay to drop the lock here.
Reported-by: AnÃbal Almeida Pinto <anibal.pinto@efacec.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Oliver Neukum <oliver@neukum.org>
commit cf00790dea6f210ddd01a6656da58c7c9a4ea0e4 upstream.
Mesa may set it to 1, causing all primitives to be killed.
v2: also update the r7xx code
Signed-off-by: Marek Olšák <maraeo@gmail.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 9926a67557532acb6cddb1c1add02952175b5c72 upstream.
Nicolas Cavallari discovered that carl9170 has some
serious problems delivering data to sleeping stations.
It turns out that the driver was not honoring two
important flags (IEEE80211_TX_CTL_POLL_RESPONSE and
IEEE80211_TX_CTL_CLEAR_PS_FILT) which are set on
frames that should be sent although the receiving
station is still in powersave mode.
Reported-by: Nicolas Cavallari <Nicolas.Cavallari@lri.fr>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit 992d52529d7840236d3059b51c15d5eb9e81a869 upstream.
On Access Point mode, when transmitting a packet, if the destination
station is in powersave mode, we abort transmitting the packet to the
device queue, but we do not reclaim the allocated memory. Given enough
packets, we can go in a state where there is no packet on the device
queue, but we think the device has no memory left, so no packet gets
transmitted, connections breaks and the AP stops working.
This undo the allocation done in the TX path when the station is in
power-save mode.
Signed-off-by: Nicolas Cavallari <cavallar@lri.fr>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
commit 7ad6307ad6968ce25cecf209d4822d4c722be030 upstream.
A global delay parameter has the side effect of being overwritten with 0 if a
single ZL2004 or ZL6105 is instantiated. If other chips supported by the same
driver are in the system, this will result in access errors for those chips.
To solve the problem, keep a per-instance copy of the delay parameter, and do
not change the original parameter.
Acked-by: Jean Delvare <khali@linux-fr.org>
commit 1bd612a25855f4cc9345052b53d7da697dba6358 upstream.
Also update IDT datasheet locations.
commit 4de86126a712ba83fa038d277c8282f7ed466a4b upstream.
These are fully compatible with Jedec JC 42.4 as far as I can see.
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 7cb3c44fb1f7999e4c53b6a52de6bc25da6de079 upstream.
There are up to three POUT alarm attributes, not two, since cap_alarm was added.
Reported-by: Michele Petracca <mi.petracca@gmail.com>
commit 99c90ab31fad855b9da9dee3a5aa6c27f263e9d6 upstream.
ALPS touchpad detection fails if some buttons of ALPS are pressed.
The reason is that the "E6" query response byte is different from
what is expected.
This was tested on a Toshiba Portege R500.
Signed-off-by: Akio Idehara <zbe64533@gmail.com>
Tested-by: Seth Forshee <seth.forshee@canonical.com>
commit affc9a0d59ac49bd304e2137bd5e4ffdd6fdfa52 upstream.
lirc_serial_probe() must fail if request_irq() returns an error, even if
it isn't EBUSY or EINVAL,
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
commit 1ff1d88e862948ae5bfe490248c023ff8ac2855d upstream.
A resume function cannot remove the device it is resuming!
lirc_serial_probe()
commit c8e57e1b766c2321aa76ee5e6878c69bd2313d62 upstream.
Failure to allocate the I/O region leaves the IRQ allocated.
A later failure leaves them both allocated.
Reported-by: Torsten Crass <torsten.crass@eBiology.de>
commit 9105b8b200410383d0854bbe237ee385d7d33ba6 upstream.
Currently the module init function registers a platform_device and
only then allocates its IRQ and I/O region. This allows allocation to
race with the device's suspend() function. Instead, allocate
resources in the platform driver's probe() function and free them in
the remove() function.
The module exit function removes the platform device before the
character device that provides access to it. Change it to reverse the
order of initialisation.
commit 3f31ae121348afd9ed39700ea2a63c17cd7eeed1 upstream.
xscale2 PMUs indicate overflow not via the PMU control register, but by
a separate overflow FLAG register instead.
This patch fixes the xscale2 PMU code to use this register to detect
to overflow and ensures that we clear any pending overflow when
disabling a counter.
commit f6f5a30c834135c9f2fa10400c59ebbdd9188567 upstream.
The PMU IRQ handlers in perf assume that if a counter has overflowed
then perf must be responsible. In the paranoid world of crazy hardware,
this could be false, so check that we do have a valid event before
attempting to dereference NULL in the interrupt path.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit 99c1745b9c76910e195889044f914b4898b7c9a5 upstream.
When disabling a counter on an ARMv7 PMU, we should also clear the
overflow flag in case an overflow occurred whilst stopping the counter.
This prevents a spurious overflow being picked up later and leading to
either false accounting or a NULL dereference.
Reported-by: Ming Lei <tom.leiming@gmail.com>
commit 5727347180ebc6b4a866fcbe00dcb39cc03acb37 upstream.
On ARM, the PMU does not stop counting after an overflow and therefore
IRQ latency affects the new counter value read by the kernel. This is
significant for non-sampling runs where it is possible for the new value
to overtake the previous one, causing the delta to be out by up to
max_period events.
Commit a737823d ("ARM: 6835/1: perf: ensure overflows aren't missed due
to IRQ latency") attempted to fix this problem by allowing interrupt
handlers to pass an overflow flag to the event update function, causing
the overflow calculation to assume that the counter passed through zero
when going from prev to new. Unfortunately, this doesn't work when
overflow occurs on the perf_task_tick path because we have the flag
cleared and end up computing a large negative delta.
This patch removes the overflow flag from armpmu_event_update and
instead limits the sample_period to half of the max_period for
non-sampling profiling runs.
Signed-off-by: Ming Lei <ming.lei@canonical.com>
commit efbc74ace95338484f8d732037b99c7c77098fce upstream.
Erratum #743622 affects all r2 variants of the Cortex-A9 processor, so
ensure that the workaround is applied regardless of the revision.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
commit ca888a7958b3d808e4efd08ceff88913f4212c69 upstream.
The "OMAPDSS: HDMI: PHY burnout fix" commit switched the HDMI driver
over to using a GPIO for plug detect. Unfortunately the ->detect()
method was not also updated, causing HDMI to no longer work for the
omapdrm driver (because it would actually check if a connection was
detected before attempting to enable display).
Signed-off-by: Rob Clark <rob@ti.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit c49d005b6cc8491fad5b24f82805be2d6bcbd3dd upstream.
A hardware bug in the OMAP4 HDMI PHY causes physical damage to the board
if the HDMI PHY is kept powered on when the cable is not connected.
This patch solves the problem by adding hot-plug-detection into the HDMI
IP driver. This is not a real HPD support in the sense that nobody else
than the IP driver gets to know about the HPD events, but is only meant
to fix the HW bug.
The strategy is simple: If the display device is turned off by the user,
the PHY power is set to OFF. When the display device is turned on by the
user, the PHY power is set either to LDOON or TXON, depending on whether
the HDMI cable is connected.
The reason to avoid PHY OFF when the display device is on, but the cable
is disconnected, is that when the PHY is turned OFF, the HDMI IP is not
"ticking" and thus the DISPC does not receive pixel clock from the HDMI
IP. This would, for example, prevent any VSYNCs from happening, and
would thus affect the users of omapdss. By using LDOON when the cable is
disconnected we'll avoid the HW bug, but keep the HDMI working as usual
from the user's point of view.
commit aa74274b464d4aa24703963ac89a0ee942d5d267 upstream.
Both Panda and 4430SDP use GPIO 63 as HDMI hot-plug-detect. Configure
this GPIO in the board files.
commit 78a1ad8f12db70b8b0a4548b90704de08ee216ce upstream.
The HDMI GPIO pins LS_OE and CT_CP_HPD are not currently configured.
This patch configures them as output pins.
commit 7bb122d155f742fe2d79849090c825be7b4a247e upstream.
"hdmi_hpd" pin is muxed to INPUT and PULLUP, but the pin is not
currently used, and in the future when it is used, the pin is used as a
GPIO and is board specific, not an OMAP4 wide thing.
So remove the muxing for now.
commit 3932a32fcf5393f8be70ac99dc718ad7ad0a415b upstream.
The GPIO 60 on 4430sdp and Panda is not HPD GPIO, as currently marked in
the board files, but CT_CP_HPD, which is used to enable/disable HPD
functionality.
This patch renames the GPIO.
commit 575753e3bea3b67eef8e454fb87f719e3f7da599 upstream.
Instead of freeing the GPIOs individually, use gpio_free_array().
commit b06540371063f0f07aafc1d1ac5e974da85c973c upstream.
Patchset "ARM: orion: Refactor the MPP code common in the orion
platform" broke at least Orion5x based platforms. These platforms have
pins configured as GPIO when the selector is not 0x0. However the
common code assumes the selector is always 0x0 for a GPIO lines. It
then ignores the GPIO bits in the MPP definitions, resulting in that
Orion5x machines cannot correctly configure there GPIO lines.
The Fix removes the assumption that the selector is always 0x0.
In order that none GPIO configurations are correctly blocked,
Kirkwood and mv78xx0 MPP definitions are corrected to only set the
GPIO bits for GPIO configurations.
This third version, which does not contain any whitespace changes,
and is rebased on v3.3-rc2.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Nicolas Pitre <nico@linaro.org>
commit 72053353583230952c4b187e110e9da00dfc3afb upstream.
The patch "ARM: orion: Consolidate USB platform setup code.", commit
4fcd3f374a928081d391cd9a570afe3b2c692fdc broke USB on TS-7800 and
other orion5x boards, because the wrong type of PHY was being passed
to the EHCI driver in the platform data. Orion5x needs EHCI_PHY_ORION
and all the others want EHCI_PHY_NA.
Allow the mach- code to tell the generic plat-orion code which USB PHY
enum to place into the platform data.
Version 2: Rebase to v3.3-rc2.
Reported-by: Ambroz Bizjak <ambrop7@gmail.com>
Tested-by: Ambroz Bizjak <ambrop7@gmail.com>
commit b3f33cbf7ace8fc149993ee35e0d0fd57f41d6d8 upstream.
SandyBridge should be using the same register addresses as IvyBridge.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
commit d71de14ddf423ccc9a2e3f7e37553c99ead20d7c upstream.
The BSpec Workarounds page states that bits 10 and 26 must be set to
avoid 3D ring hangs.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44610
Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Kenneth Graunke <kenneth@whitecape.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit db099c8f963fe656108e0a068274c5580a17f69b upstream.
This adds the workaround for WaCatErrorRejectionIssue which could result
in a system hang.
Reviewed-by: Kenneth Graunke <kenneth@whitecape.org>
commit e4e0c058a19c41150d12ad2d3023b3cf09c5de67 upstream.
This adds two cache-related workarounds for Ivy Bridge which can lead to
3D ring hangs and corruptions.
commit eae66b50c760233fad526edf4a0d327be17a055d upstream.
This is yet another workaround related to clock gating which we need on
Ivy Bridge.
commit 6cddafab54e9a17b2efefe982547865955a5ff3a upstream.
The latest vendor (non-mac80211) driver of 9/22/2011 shows some new
device IDs for rtl8192cu. In addition, some typos in the table are
fixed and one duplicate is removed.
commit 5a50a7c32d630d6cdb13d69afabb0cc81b2f379c upstream.
The models do not resume correctly without acpi_sleep=nonvs.
Signed-off-by: Keng-Yu Lin <kengyu@canonical.com>
Cc: Tim Gardner <tim.gardner@canonical.com>
commit 31e0017e6f6fb5cfdfaf932c1f98c9bef8d57688 upstream.
Enable use of the generic atomic64 implementation on AVR32 platforms.
Without this the kernel fails to build as the architecture does not
provide its version.
Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
commit 37b40adf2d1b4a5e51323be73ccf8ddcf3f15dd3 upstream.
We create "bsg" link if q->kobj.sd is not NULL, so remove it only
when the same condition is true.
Fixes:
WARNING: at fs/sysfs/inode.c:323 sysfs_hash_and_remove+0x2b/0x77()
sysfs: can not remove 'bsg', no directory
Call Trace:
[<c0429683>] warn_slowpath_common+0x6a/0x7f
[<c0537a68>] ? sysfs_hash_and_remove+0x2b/0x77
[<c042970b>] warn_slowpath_fmt+0x2b/0x2f
[<c0537a68>] sysfs_hash_and_remove+0x2b/0x77
[<c053969a>] sysfs_remove_link+0x20/0x23
[<c05d88f1>] bsg_unregister_queue+0x40/0x6d
[<c0692263>] __scsi_remove_device+0x31/0x9d
[<c069149f>] scsi_forget_host+0x41/0x52
[<c0689fa9>] scsi_remove_host+0x71/0xe0
[<f7de5945>] quiesce_and_remove_host+0x51/0x83 [usb_storage]
[<f7de5a1e>] usb_stor_disconnect+0x18/0x22 [usb_storage]
[<c06c29de>] usb_unbind_interface+0x4e/0x109
[<c067a80f>] __device_release_driver+0x6b/0xa6
[<c067a861>] device_release_driver+0x17/0x22
[<c067a46a>] bus_remove_device+0xd6/0xe6
[<c06785e2>] device_del+0xf2/0x137
[<c06c101f>] usb_disable_device+0x94/0x1a0
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
