2014-04-04ENGR00306993 revert gpu2d may cause bus hang fixkk4.4.2_1.0.0-betaRichard Liu
gpu2d hang fix has side effect, it causes flicker issue for popup window menu on android, not integrate this fix before the side effect be fixed. Revert "ENGR00302036-3 gpu:gpu2d may cause bus hang in some corner case" This reverts commit 0d5505cfd0b50db4bd046270b119c4dae0a143c2. Signed-off-by: Richard Liu <r66033@freescale.com> Acked-by: Shawn Guo
2014-04-02ENGR00302036-3 gpu:gpu2d may cause bus hang in some corner caseLoren Huang
Vivante patch name: cl17466.17776.rls.lockup.2dhang(clear.blit) -Updated the outstanding request limit to 12. -Refined the 2D chip feature check. -Refine the 2D cache flush operation (avoid FE and PE access memory through the same port). -Enable cache flush for filterblt. -Dynamic enabling SPLIT_RECT by checking chip feature(disable for us) -Use brush stretch blt for clear operation. Date: Mar 26, 2014 Signed-off-by: Loren Huang <b02279@freescale.com> Acked-by: Shawn Guo
2014-04-01ENGR00306276: iMX6: Add workaround for ARM errata 761320 and 794072Nitin Garg
These are Category B, hence workaround is essential. Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
2014-04-01ENGR00306340 usb: ehci-arc: fix build warningPeter Chen
drivers/usb/host/ehci-arc.c: In function 'ehci_fsl_drv_resume': drivers/usb/host/ehci-arc.c:805: warning: ISO C90 forbids mixed declarations and code Signed-off-by: Peter Chen <peter.chen@freescale.com>
2014-04-01ENGR00306257 [#1027]fix system hang up issue caused by GPURichard Liu
This issue happens when multiple thread is trying to idle GPU at the same time, root cause is some wrong logic related with powerMutex which cause cpu still access GPU AHB register after GPU is suspend(clock off), that cause the bus lockup and make the whole system hang. Signed-off-by: Richard Liu <r66033@freescale.com> Acked-by: Jason Liu
2014-04-01ENGR00303543 usb: ehci-arc: do noop during resume if it is not in host modePeter Chen
We find a bug that the usb will produce endless interrupt during the resume after below steps: - nothing connected at usb otg port, but enable usb gadget driver - system enters suspend - plug in usb cable - system leaves suspend The reasons of endless interrupt is: the host controller resume routine leaves the phy low power mode, but device controller resume routine has still not been called, so the software considers it is still at low power mode. After this time, the vbus change interrupt comes, the wakeup routine considers it is an wakeup interrupt, but in fact it is not. So, the endless interrupt occurs. The solution of this problem is do noop during host controller resume routine if current usb mode is not host mode, and the device controller reusme routine will handle it. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2014-03-31ENGR00305534 asoc: audio block when switch between headphone and HDMIShengjiu Wang
Machine driver will swith sysclk to MCLK when hw_free(). When switch from headphone -> HDMI -> headphone through hotplug headphone in Android, in HDMI->headphone, the dapm will call POST_PMD -> PRE_PMU, then call hw_params(). So in sysclk_enent(), the FLL_ENA will not be set, because currently sysclk is MCLK. then audio is blocked. because hw_params() set the sysclk to FLL, but FLL is not enabled. So update the sysclk_enent(), the FLL_ENA will be set always when audio enabled. Signed-off-by: Shengjiu Wang <b02247@freescale.com>
2014-03-27ENGR00305465 MXC IPUv3 fb: Fix permissions of fsl_disp_property sysfs entryJulien Olivain
Set the correct permissions of the fsl_disp_property sysfs entry. Acked-by: Liu Ying <Ying.Liu@freescale.com> Signed-off-by: Julien Olivain <julien.olivain@freescale.com> (cherry picked from commit 9db2d982c90b6edb3dfebe03a68f50f381bb99bb)
2014-03-25ENGR00303824 audio: Headphone hotplug not work in mx6sl_evkShengjiu Wang
When hotplug, user will close and reopen the device, shutdown() will be called, MCLK will be disabled, then I2C access to wm8962 will have issue. so the drive didn't switch to headphone. Move the clk enable and disable to codec driver to fix this issue. Signed-off-by: Shengjiu Wang <b02247@freescale.com>
2014-03-25ENGR00304402 video: mxc LDB: Enable LDB channel after display controllerLiu Ying
In order to avoid any random pixelation issue, we should follow a correct display controller/LDB initialization sequence, that is, LDB channel should be enabled after its relevant display controller is enabled. Since the enable() callback of the mxc display driver is called after a display controller is enabled, this patch uses the enable()/disable() callbacks to replace the fb notifier callback implemented in the LDB driver. Also, we disable a LDB channel in the setup() callback of the mxc display driver to make sure of the correct sequence in any fb set_par() function. As the enable()/disable() callbacks are always invoked with fb_blank(), this patch drops the suspend()/resume() functions of the LDB driver which do nothing but enable/disable LDB channels. We also remove the code to enable ldb di clocks because they can be enabled when their relevant child pixel clocks are enabled. Conflicts: drivers/video/mxc/ldb.c drivers/video/mxc/mxc_dispdrv.h Signed-off-by: Liu Ying <Ying.Liu@freescale.com> (cherry picked from commit 8d189a9cc067f74cc3d49757af25118b459b9726)
2014-03-18ENGR00303453:[Android_ MX6DL_ARD]Boot: Android cannot boot up from NAND. 100%Ke Qinghua
Enable UBIFS selinux setting Signed-off-by: Ke Qinghua <qinghua.ke@freescale.com>
2014-03-18ENGR00303820 [#887] refine physical address check for external memoryXianzhong
2G above address will cause system reboot and fixed in original patch, error check code is added based on the original logic. Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2014-03-11ping: always initialize ->sin6_scope_id and ->sin6_flowinfoCong Wang
[net-next commit c26d6b46da3ee86fa8a864347331e5513ca84c2b] If we don't need scope id, we should initialize it to zero. Same for ->sin6_flowinfo. Change-Id: I28e4bc9593e76fc3434052182466fab4bb8ccf3a Cc: Lorenzo Colitti <lorenzo@google.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Acked-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-11net: ipv6: fix wrong ping_v6_sendmsg return valueLorenzo Colitti
[net-next commit fbfe80c890a1dc521d0b629b870e32fcffff0da5] ping_v6_sendmsg currently returns 0 on success. It should return the number of bytes written instead. Bug: 9469865 Change-Id: I82b7d3a37ba91ad24e6dbd97a4880745ce16ad31 Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-11net: ipv6: add missing lock in ping_v6_sendmsgLorenzo Colitti
[net-next commit a1bdc45580fc19e968b32ad27cd7e476a4aa58f6] Bug: 9469865 Change-Id: I480f8ce95956dd8f17fbbb26dc60cc162f8ec933 Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-11net: ipv6: Add IPv6 support to the ping socket.Lorenzo Colitti
[backport of net-next 6d0bfe22611602f36617bc7aa2ffa1bbb2f54c67] This adds the ability to send ICMPv6 echo requests without a raw socket. The equivalent ability for ICMPv4 was added in 2011. Instead of having separate code paths for IPv4 and IPv6, make most of the code in net/ipv4/ping.c dual-stack and only add a few IPv6-specific bits (like the protocol definition) to a new net/ipv6/ping.c. Hopefully this will reduce divergence and/or duplication of bugs in the future. Caveats: - Setting options via ancillary data (e.g., using IPV6_PKTINFO to specify the outgoing interface) is not yet supported. - There are no separate security settings for IPv4 and IPv6; everything is controlled by /proc/net/ipv4/ping_group_range. - The proc interface does not yet display IPv6 ping sockets properly. Tested with a patched copy of ping6 and using raw socket calls. Compiles and works with all of CONFIG_IPV6={n,m,y}. Change-Id: Ia359af556021344fc7f890c21383aadf950b6498 Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> [lorenzo@google.com: backported to 3.0] Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
2014-03-11ipv4: fix a bug in ping_err().Li Wei
[ Upstream commit b531ed61a2a2a77eeb2f7c88b49aa5ec7d9880d8 ] We should get 'type' and 'code' from the outer ICMP header. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-11ipv6: introdcue __ipv6_addr_needs_scope_id and ipv6_iface_scope_id helper ↵Hannes Frederic Sowa
functions [net-next commit b7ef213ef65256168df83ddfbb8131ed9adc10f9] __ipv6_addr_needs_scope_id checks if an ipv6 address needs to supply a 'sin6_scope_id != 0'. 'sin6_scope_id != 0' was enforced in case of link-local addresses. To support interface-local multicast these checks had to be enhanced and are now consolidated into these new helper functions. v2: a) migrated to struct ipv6_addr_props v3: a) reverted changes for ipv6_addr_props b) test for address type instead of comparing scope v4: a) unchanged Change-Id: Id6fc54cec61f967928e08a9eba4f857157d973a3 Suggested-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-11tcp: undo spurious timeout after SACK renegingYuchung Cheng
[ Upstream commit 7ebe183c6d444ef5587d803b64a1f4734b18c564 ] On SACK reneging the sender immediately retransmits and forces a timeout but disables Eifel (undo). If the (buggy) receiver does not drop any packet this can trigger a false slow-start retransmit storm driven by the ACKs of the original packets. This can be detected with undo and TCP timestamps. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-11tcp: preserve ACK clocking in TSOEric Dumazet
[ Upstream commit f4541d60a449afd40448b06496dcd510f505928e ] A long standing problem with TSO is the fact that tcp_tso_should_defer() rearms the deferred timer, while it should not. Current code leads to following bad bursty behavior : 20:11:24.484333 IP A > B: . 297161:316921(19760) ack 1 win 119 20:11:24.484337 IP B > A: . ack 263721 win 1117 20:11:24.485086 IP B > A: . ack 265241 win 1117 20:11:24.485925 IP B > A: . ack 266761 win 1117 20:11:24.486759 IP B > A: . ack 268281 win 1117 20:11:24.487594 IP B > A: . ack 269801 win 1117 20:11:24.488430 IP B > A: . ack 271321 win 1117 20:11:24.489267 IP B > A: . ack 272841 win 1117 20:11:24.490104 IP B > A: . ack 274361 win 1117 20:11:24.490939 IP B > A: . ack 275881 win 1117 20:11:24.491775 IP B > A: . ack 277401 win 1117 20:11:24.491784 IP A > B: . 316921:332881(15960) ack 1 win 119 20:11:24.492620 IP B > A: . ack 278921 win 1117 20:11:24.493448 IP B > A: . ack 280441 win 1117 20:11:24.494286 IP B > A: . ack 281961 win 1117 20:11:24.495122 IP B > A: . ack 283481 win 1117 20:11:24.495958 IP B > A: . ack 285001 win 1117 20:11:24.496791 IP B > A: . ack 286521 win 1117 20:11:24.497628 IP B > A: . ack 288041 win 1117 20:11:24.498459 IP B > A: . ack 289561 win 1117 20:11:24.499296 IP B > A: . ack 291081 win 1117 20:11:24.500133 IP B > A: . ack 292601 win 1117 20:11:24.500970 IP B > A: . ack 294121 win 1117 20:11:24.501388 IP B > A: . ack 295641 win 1117 20:11:24.501398 IP A > B: . 332881:351881(19000) ack 1 win 119 While the expected behavior is more like : 20:19:49.259620 IP A > B: . 197601:202161(4560) ack 1 win 119 20:19:49.260446 IP B > A: . ack 154281 win 1212 20:19:49.261282 IP B > A: . ack 155801 win 1212 20:19:49.262125 IP B > A: . ack 157321 win 1212 20:19:49.262136 IP A > B: . 202161:206721(4560) ack 1 win 119 20:19:49.262958 IP B > A: . ack 158841 win 1212 20:19:49.263795 IP B > A: . ack 160361 win 1212 20:19:49.264628 IP B > A: . ack 161881 win 1212 20:19:49.264637 IP A > B: . 206721:211281(4560) ack 1 win 119 20:19:49.265465 IP B > A: . ack 163401 win 1212 20:19:49.265886 IP B > A: . ack 164921 win 1212 20:19:49.266722 IP B > A: . ack 166441 win 1212 20:19:49.266732 IP A > B: . 211281:215841(4560) ack 1 win 119 20:19:49.267559 IP B > A: . ack 167961 win 1212 20:19:49.268394 IP B > A: . ack 169481 win 1212 20:19:49.269232 IP B > A: . ack 171001 win 1212 20:19:49.269241 IP A > B: . 215841:221161(5320) ack 1 win 119 Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Van Jacobson <vanj@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Nandita Dukkipati <nanditad@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: fix bad free of addrconf_init_netHong Zhiguo
[ Upstream commit a79ca223e029aa4f09abb337accf1812c900a800 ] Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10inet: limit length of fragment queue hash table bucket listsHannes Frederic Sowa
[ Upstream commit 5a3da1fe9561828d0ca7eca664b16ec2b9bf0055 ] This patch introduces a constant limit of the fragment queue hash table bucket list lengths. Currently the limit 128 is choosen somewhat arbitrary and just ensures that we can fill up the fragment cache with empty packets up to the default ip_frag_high_thresh limits. It should just protect from list iteration eating considerable amounts of cpu. If we reach the maximum length in one hash bucket a warning is printed. This is implemented on the caller side of inet_frag_find to distinguish between the different users of inet_fragment.c. I dropped the out of memory warning in the ipv4 fragment lookup path, because we already get a warning by the slab allocator. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: stop multicast forwarding to process interface scoped addressesHannes Frederic Sowa
[ Upstream commit ddf64354af4a702ee0b85d0a285ba74c7278a460 ] v2: a) used struct ipv6_addr_props v3: a) reverted changes for ipv6_addr_props v4: a) do not use __ipv6_addr_needs_scope_id Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10net: ipv6: Don't purge default router if accept_ra=2Lorenzo Colitti
Setting net.ipv6.conf.<interface>.accept_ra=2 causes the kernel to accept RAs even when forwarding is enabled. However, enabling forwarding purges all default routes on the system, breaking connectivity until the next RA is received. Fix this by not purging default routes on interfaces that have accept_ra=2. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-10ipv6: do not create neighbor entries for local deliveryMarcelo Ricardo Leitner
[ Upstream commit bd30e947207e2ea0ff2c08f5b4a03025ddce48d3 ] They will be created at output, if ever needed. This avoids creating empty neighbor entries when TPROXYing/Forwarding packets for addresses that are not even directly reachable. Note that IPv4 already handles it this way. No neighbor entries are created for local input. Tested by myself and customer. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
commit c7ac8679bec9397afe8918f788cbcef88c38da54 upstream. The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: setsockopt(IPIPPROTO_IPV6, IPV6_MINHOPCOUNT) forgot to set return valueHannes Frederic Sowa
[ Upstream commit d4596bad2a713fcd0def492b1960e6d899d5baa8 ] Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: send unsolicited neighbour advertisements to all-nodesHannes Frederic Sowa
[ Upstream commit 60713a0ca7fd6651b951cc1b4dbd528d1fc0281b ] As documented in RFC4861 (Neighbor Discovery for IP version 6) 7.2.6., unsolicited neighbour advertisements should be sent to the all-nodes multicast address. Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: Set default hoplimit as zero.Li RongQing
[ Upstream commit 14edd87dc67311556f1254a8f29cf4dd6cb5b7d1 ] Commit a02e4b7dae4551(Demark default hoplimit as zero) only changes the hoplimit checking condition and default value in ip6_dst_hoplimit, not zeros all hoplimit default value. Keep the zeroing ip6_template_metrics[RTAX_HOPLIMIT - 1] to force it as const, cause as a37e6e344910(net: force dst_default_metrics to const section) Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10tcp: resets are misroutedAlexey Kuznetsov
[ Upstream commit 4c67525849e0b7f4bd4fab2487ec9e43ea52ef29 ] After commit e2446eaa ("tcp_v4_send_reset: binding oif to iif in no sock case").. tcp resets are always lost, when routing is asymmetric. Yes, backing out that patch will result in misrouting of resets for dead connections which used interface binding when were alive, but we actually cannot do anything here. What's died that's died and correct handling normal unbound connections is obviously a priority. Comment to comment: > This has few benefits: > 1. tcp_v6_send_reset already did that. It was done to route resets for IPv6 link local addresses. It was a mistake to do so for global addresses. The patch fixes this as well. Actually, the problem appears to be even more serious than guaranteed loss of resets. As reported by Sergey Soloviev <sol@eqv.ru>, those misrouted resets create a lot of arp traffic and huge amount of unresolved arp entires putting down to knees NAT firewalls which use asymmetric routing. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: mip6: fix mip6_mh_filter()Eric Dumazet
[ Upstream commit 96af69ea2a83d292238bdba20e4508ee967cf8cb ] mip6_mh_filter() should not modify its input, or else its caller would need to recompute ipv6_hdr() if skb->head is reallocated. Use skb_header_pointer() instead of pskb_may_pull() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: raw: fix icmpv6_filter()Eric Dumazet
[ Upstream commit 1b05c4b50edbddbdde715c4a7350629819f6655e ] icmpv6_filter() should not modify its input, or else its caller would need to recompute ipv6_hdr() if skb->head is reallocated. Use skb_header_pointer() instead of pskb_may_pull() and change the prototype to make clear both sk and skb are const. Also, if icmpv6 header cannot be found, do not deliver the packet, as we do in IPv4. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: release reference of ip6_null_entry's dst entry in __ip6_del_rtGao feng
[ Upstream commit 6825a26c2dc21eb4f8df9c06d3786ddec97cf53b ] as we hold dst_entry before we call __ip6_del_rt, so we should alse call dst_release not only return -ENOENT when the rt6_info is ip6_null_entry. and we already hold the dst entry, so I think it's safe to call dst_release out of the write-read lock. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: addrconf: Avoid calling netdevice notifiers with RCU read-side lockBen Hutchings
[ Upstream commit 4acd4945cd1e1f92b20d14e349c6c6a52acbd42d ] Cong Wang reports that lockdep detected suspicious RCU usage while enabling IPV6 forwarding: [ 1123.310275] =============================== [ 1123.442202] [ INFO: suspicious RCU usage. ] [ 1123.558207] 3.6.0-rc1+ #109 Not tainted [ 1123.665204] ------------------------------- [ 1123.768254] include/linux/rcupdate.h:430 Illegal context switch in RCU read-side critical section! [ 1123.992320] [ 1123.992320] other info that might help us debug this: [ 1123.992320] [ 1124.307382] [ 1124.307382] rcu_scheduler_active = 1, debug_locks = 0 [ 1124.522220] 2 locks held by sysctl/5710: [ 1124.648364] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff81768498>] rtnl_trylock+0x15/0x17 [ 1124.882211] #1: (rcu_read_lock){.+.+.+}, at: [<ffffffff81871df8>] rcu_lock_acquire+0x0/0x29 [ 1125.085209] [ 1125.085209] stack backtrace: [ 1125.332213] Pid: 5710, comm: sysctl Not tainted 3.6.0-rc1+ #109 [ 1125.441291] Call Trace: [ 1125.545281] [<ffffffff8109d915>] lockdep_rcu_suspicious+0x109/0x112 [ 1125.667212] [<ffffffff8107c240>] rcu_preempt_sleep_check+0x45/0x47 [ 1125.781838] [<ffffffff8107c260>] __might_sleep+0x1e/0x19b [...] [ 1127.445223] [<ffffffff81757ac5>] call_netdevice_notifiers+0x4a/0x4f [...] [ 1127.772188] [<ffffffff8175e125>] dev_disable_lro+0x32/0x6b [ 1127.885174] [<ffffffff81872d26>] dev_forward_change+0x30/0xcb [ 1128.013214] [<ffffffff818738c4>] addrconf_forward_change+0x85/0xc5 [...] addrconf_forward_change() uses RCU iteration over the netdev list, which is unnecessary since it already holds the RTNL lock. We also cannot reasonably require netdevice notifier functions not to sleep. Reported-by: Cong Wang <amwang@redhat.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-10ipv6: Move ipv6 proc file registration to end of init orderThomas Graf
[ Upstream commit d189634ecab947c10f6f832258b103d0bbfe73cc ] /proc/net/ipv6_route reflects the contents of fib_table_hash. The proc handler is installed in ip6_route_net_init() whereas fib_table_hash is allocated in fib6_net_init() _after_ the proc handler has been installed. This opens up a short time frame to access fib_table_hash with its pants down. Move the registration of the proc files to a later point in the init order to avoid the race. Tested :-) Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-07ARM: 7809/1: perf: fix event validation for software group leadersWill Deacon
It is possible to construct an event group with a software event as a group leader and then subsequently add a hardware event to the group. This results in the event group being validated by adding all members of the group to a fake PMU and attempting to allocate each event on their respective PMU. Unfortunately, for software events wthout a corresponding arm_pmu, this results in a kernel crash attempting to dereference the ->get_event_idx function pointer. This patch fixes the problem by checking explicitly for software events and ignoring those in event validation (since they can always be scheduled). We will probably want to revisit this for 3.12, since the validation checks don't appear to work correctly when dealing with multiple hardware PMUs anyway. Cc: <stable@vger.kernel.org> Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Conflicts: arch/arm/kernel/perf_event.c
2014-03-07perf/arm: Fix armpmu_map_hw_event()Stephen Boyd
Fix constraint check in armpmu_map_hw_event(). Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Conflicts: arch/arm/kernel/perf_event.c
2014-03-07ARM: 7527/1: uaccess: explicitly check __user pointer when !CPU_USE_DOMAINSRussell King
The {get,put}_user macros don't perform range checking on the provided __user address when !CPU_HAS_DOMAINS. This patch reworks the out-of-line assembly accessors to check the user address against a specified limit, returning -EFAULT if is is out of range. [will: changed get_user register allocation to match put_user] [rmk: fixed building on older ARM architectures] Reported-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: stable@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-03-07ENGR00302221-1: CTS test faild for security setting and test VrootKe Qinghua
Enable SELINUX in configuartion Signed-off-by: Ke Qinghua <qinghua.ke@freescale.com>
2014-03-04block: don't call blk_drain_queue() if elevator is not upTejun Heo
blk_cleanup_queue() may be called before elevator is set up on a queue which triggers the following oops. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff8125a69c>] elv_drain_elevator+0x1c/0x70 ... Pid: 830, comm: kworker/0:2 Not tainted 3.1.0-next-20111025_64+ #1590 Bochs Bochs RIP: 0010:[<ffffffff8125a69c>] [<ffffffff8125a69c>] elv_drain_elevator+0x1c/0x70 ... Call Trace: [<ffffffff8125da92>] blk_drain_queue+0x42/0x70 [<ffffffff8125db90>] blk_cleanup_queue+0xd0/0x1c0 [<ffffffff81469640>] md_free+0x50/0x70 [<ffffffff8126f43b>] kobject_release+0x8b/0x1d0 [<ffffffff81270d56>] kref_put+0x36/0xa0 [<ffffffff8126f2b7>] kobject_put+0x27/0x60 [<ffffffff814693af>] mddev_delayed_delete+0x2f/0x40 [<ffffffff81083450>] process_one_work+0x100/0x3b0 [<ffffffff8108527f>] worker_thread+0x15f/0x3a0 [<ffffffff81089937>] kthread+0x87/0x90 [<ffffffff81621834>] kernel_thread_helper+0x4/0x10 Fix it by making blk_cleanup_queue() check whether q->elevator is set up before invoking blk_drain_queue. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-03-04Fix race between starved list and device removalJames Bottomley
scsi_run_queue() examines all SCSI devices that are present on the starved list. Since scsi_run_queue() unlocks the SCSI host lock a SCSI device can get removed after it has been removed from the starved list and before its queue is run. Protect against that race condition by holding a reference on the queue while running it. Reported-by: Chanho Min <chanho.min@lge.com> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2014-03-04driver: scsi: Stop accepting SCSI requests before removing a devicePeter Chen
Based on Bart Van Assche's below patch Avoid that the code for requeueing SCSI requests triggers a crash by making sure that that code isn't scheduled anymore after a device has been removed. Also, source code inspection of __scsi_remove_device() revealed a race condition in this function: no new SCSI requests must be accepted for a SCSI device after device removal started. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2014-03-04block: fix request_queue lifetime handling by making blk_queue_cleanup() ↵Tejun Heo
properly shutdown [Peter] Delete the change for block throttle. request_queue is refcounted but actually depdends on lifetime management from the queue owner - on blk_cleanup_queue(), block layer expects that there's no request passing through request_queue and no new one will. This is fundamentally broken. The queue owner (e.g. SCSI layer) doesn't have a way to know whether there are other active users before calling blk_cleanup_queue() and other users (e.g. bsg) don't have any guarantee that the queue is and would stay valid while it's holding a reference. With delay added in blk_queue_bio() before queue_lock is grabbed, the following oops can be easily triggered when a device is removed with in-flight IOs. sd 0:0:1:0: [sdb] Stopping disk ata1.01: disabled general protection fault: 0000 [#1] PREEMPT SMP CPU 2 Modules linked in: Pid: 648, comm: test_rawio Not tainted 3.1.0-rc3-work+ #56 Bochs Bochs RIP: 0010:[<ffffffff8137d651>] [<ffffffff8137d651>] elv_rqhash_find+0x61/0x100 ... Process test_rawio (pid: 648, threadinfo ffff880019efa000, task ffff880019ef8a80) ... Call Trace: [<ffffffff8137d774>] elv_merge+0x84/0xe0 [<ffffffff81385b54>] blk_queue_bio+0xf4/0x400 [<ffffffff813838ea>] generic_make_request+0xca/0x100 [<ffffffff81383994>] submit_bio+0x74/0x100 [<ffffffff811c53ec>] dio_bio_submit+0xbc/0xc0 [<ffffffff811c610e>] __blockdev_direct_IO+0x92e/0xb40 [<ffffffff811c39f7>] blkdev_direct_IO+0x57/0x60 [<ffffffff8113b1c5>] generic_file_aio_read+0x6d5/0x760 [<ffffffff8118c1ca>] do_sync_read+0xda/0x120 [<ffffffff8118ce55>] vfs_read+0xc5/0x180 [<ffffffff8118cfaa>] sys_pread64+0x9a/0xb0 [<ffffffff81afaf6b>] system_call_fastpath+0x16/0x1b This happens because blk_queue_cleanup() destroys the queue and elevator whether IOs are in progress or not and DEAD tests are sprinkled in the request processing path without proper synchronization. Similar problem exists for blk-throtl. On queue cleanup, blk-throtl is shutdown whether it has requests in it or not. Depending on timing, it either oopses or throttled bios are lost putting tasks which are waiting for bio completion into eternal D state. The way it should work is having the usual clear distinction between shutdown and release. Shutdown drains all currently pending requests, marks the queue dead, and performs partial teardown of the now unnecessary part of the queue. Even after shutdown is complete, reference holders are still allowed to issue requests to the queue although they will be immmediately failed. The rest of teardown happens on release. This patch makes the following changes to make blk_queue_cleanup() behave as proper shutdown. * QUEUE_FLAG_DEAD is now set while holding both q->exit_mutex and queue_lock. * Unsynchronized DEAD check in generic_make_request_checks() removed. This couldn't make any meaningful difference as the queue could die after the check. * blk_drain_queue() updated such that it can drain all requests and is now called during cleanup. * blk_throtl updated such that it checks DEAD on grabbing queue_lock, drains all throttled bios during cleanup and free td when queue is released. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-03-04block: reorganize queue drainingTejun Heo
Reorganize queue draining related code in preparation of queue exit changes. * Factor out actual draining from elv_quiesce_start() to blk_drain_queue(). * Make elv_quiesce_start/end() responsible for their own locking. * Replace open-coded ELVSWITCH clearing in elevator_switch() with elv_quiesce_end(). This patch doesn't cause any visible functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-03-04block: make get_request[_wait]() fail if queue is deadTejun Heo
Currently get_request[_wait]() allocates request whether queue is dead or not. This patch makes get_request[_wait]() return NULL if @q is dead. blk_queue_bio() is updated to fail the submitted bio if request allocation fails. While at it, add docbook comments for get_request[_wait](). Note that the current code has rather unclear (there are spurious DEAD tests scattered around) assumption that the owner of a queue guarantees that no request travels block layer if the queue is dead and this patch in itself doesn't change much; however, this will allow fixing the broken assumption in the next patch. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-03-04iosched: prevent aliased requests from starving other I/OJeff Moyer
Hi, Jens, If you recall, I posted an RFC patch for this back in July of last year: http://lkml.org/lkml/2010/7/13/279 The basic problem is that a process can issue a never-ending stream of async direct I/Os to the same sector on a device, thus starving out other I/O in the system (due to the way the alias handling works in both cfq and deadline). The solution I proposed back then was to start dispatching from the fifo after a certain number of aliases had been dispatched. Vivek asked why we had to treat aliases differently at all, and I never had a good answer. So, I put together a simple patch which allows aliases to be added to the rb tree (it adds them to the right, though that doesn't matter as the order isn't guaranteed anyway). I think this is the preferred solution, as it doesn't break up time slices in CFQ or batches in deadline. I've tested it, and it does solve the starvation issue. Let me know what you think. Cheers, Jeff Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2014-02-12ENGR00298359 System can't resume from suspend mode by resume keyguoyin.chen
arm will keep busy to service mma8x5x int, as the int pin does not config to gpio input. Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
2014-02-10ENGR00296516 : FOV fail for ov5640 as camera1(csi)Fang Hui
Set 720x576's HS, HW register's value same as other resolutions Signed-off-by: Fang Hui <b31070@freescale.com>
2014-01-21ENGR00294354 gpu:Using vitural memory cause AXI bus errorLoren Huang
There are two possible reasons to cause AXI bus error 1.Allocate Tile status buffer from virtual memory. It seems gc2000 and gc880 doesn't support tile status buffer from virtual memory. 2.Stream buffer using very beginning gpu mmu address. In this condition, a faked non gpu mmu address maybe generated and fill into gpu which cause AXI bus error. [DATE]09-01-2014 Signed-off-by: Loren Huang <b02279@freescale.com> Acked-by: Shawn Guo
2014-01-21ARM: imx: return zero in case next event gets a large incrementXianzhong
The return of v2_set_next_event() will lead to an infinite loop in tick_handle_oneshot_broadcast() - "goto again;" with imx6q WAIT mode (to be enabled). This happens because when global event did not expire any CPU local events, the broadcast device will be rearmed to a CPU local next_event, which could be far away from now and result in a max_delta_tick programming in set_next_event(). Fix the problem by detecting those next events with increments larger than 0x7fffffff, and simply return zero in that case. It leaves mx1_2_set_next_event() unchanged since only v2_set_next_event() will be running with imx6q WAIT mode support. Thanks Russell King for helping understand the problem. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
