2009-06-11Linux 2.6.27.25v2.6.27.25Greg Kroah-Hartman
2009-06-11ext4: Fix race in ext4_inode_info.i_cached_extentTheodore Ts'o
(cherry picked from commit 2ec0ae3acec47f628179ee95fe2c4da01b5e9fc4) If two CPU's simultaneously call ext4_ext_get_blocks() at the same time, there is nothing protecting the i_cached_extent structure from being used and updated at the same time. This could potentially cause the wrong location on disk to be read or written to, including potentially causing the corruption of the block group descriptors and/or inode table. This bug has been in the ext4 code since almost the very beginning of ext4's development. Fortunately once the data is stored in the page cache cache, ext4_get_blocks() doesn't need to be called, so trying to replicate this problem to the point where we could identify its root cause was *extremely* difficult. Many thanks to Kevin Shanahan for working over several months to be able to reproduce this easily so we could finally nail down the cause of the corruption. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Clear the unwritten buffer_head flag after the extent is initializedAneesh Kumar K.V
(cherry picked from commit 2a8964d63d50dd2d65d71d342bc7fb6ef4117614) The BH_Unwritten flag indicates that the buffer is allocated on disk but has not been written; that is, the disk was part of a persistent preallocation area. That flag should only be set when a get_blocks() function is looking up a inode's logical to physical block mapping. When ext4_get_blocks_wrap() is called with create=1, the uninitialized extent is converted into an initialized one, so the BH_Unwritten flag is no longer appropriate. Hence, we need to make sure the BH_Unwritten is not left set, since the combination of BH_Mapped and BH_Unwritten is not allowed; among other things, it will result ext4's get_block() to be called over and over again during the write_begin phase of write(2). Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Use a fake block number for delayed new buffer_headAneesh Kumar K.V
(cherry picked from commit 33b9817e2ae097c7b8d256e3510ac6c54fc6d9d0) Use a very large unsigned number (~0xffff) as as the fake block number for the delayed new buffer. The VFS should never try to write out this number, but if it does, this will make it obvious. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Fix sub-block zeroing for writes into preallocated extentsAneesh Kumar K.V
(cherry picked from commit 9c1ee184a30394e54165fa4c15923cabd952c106) We need to mark the buffer_head mapping preallocated space as new during write_begin. Otherwise we don't zero out the page cache content properly for a partial write. This will cause file corruption with preallocation. Now that we mark the buffer_head new we also need to have a valid buffer_head blocknr so that unmap_underlying_metadata() unmaps the correct block. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Ignore i_file_acl_high unless EXT4_FEATURE_INCOMPAT_64BIT is presentTheodore Ts'o
(cherry picked from commit a9e817425dc0baede8ebe5fbc9984a640257432b) Don't try to look at i_file_acl_high unless the INCOMPAT_64BIT feature bit is set. The field is normally zero, but older versions of e2fsck didn't automatically check to make sure of this, so in the spirit of "be liberal in what you accept", don't look at i_file_acl_high unless we are using a 64-bit filesystem. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Fix softlockup caused by illegal i_file_acl value in on-disk inodeTheodore Ts'o
(cherry picked from commit 485c26ec70f823f2a9cf45982b724893e53a859e) If the block containing external extended attributes (which is stored in i_file_acl and i_file_acl_high) is larger than the on-disk filesystem, the process which tried to access the extended attributes will endlessly issue kernel printks complaining that "__find_get_block_slow() failed", locking up that CPU until the system is forcibly rebooted. So when we read in the inode, make sure the i_file_acl value is legal, and if not, flag the filesystem as being corrupted. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: really print the find_group_flex fallback warning only onceChuck Ebbert
(cherry picked from commit 6b82f3cb2d480b7714eb0ff61aee99c22160389e) Missing braces caused the warning to print more than once. Signed-Off-By: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: fix locking typo in mballoc which could cause soft lockup hangsTheodore Ts'o
upstream commit: e7c9e3e99adf6c49c5d593a51375916acc039d1e Smatch (http://repo.or.cz/w/smatch.git/) complains about the locking in ext4_mb_add_n_trim() from fs/ext4/mballoc.c 4438 list_for_each_entry_rcu(tmp_pa, &lg->lg_prealloc_list[order], 4439 pa_inode_list) { 4440 spin_lock(&tmp_pa->pa_lock); 4441 if (tmp_pa->pa_deleted) { 4442 spin_unlock(&pa->pa_lock); 4443 continue; 4444 } Brown paper bag time... Reported-by: Dan Carpenter <error27@gmail.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: fix typo which causes a memory leak on error pathDan Carpenter
upstream commit: a7b19448ddbdc34b2b8fedc048ba154ca798667b This was found by smatch (http://repo.or.cz/w/smatch.git/) Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11jbd2: Update locking comentsJan Kara
(cherry picked from commit 86db97c87f744364d5889ca8a4134ca2048b8f83) Update information about locking in JBD2 revoke code. Inconsistency in comments found by Lin Tan <tammy000@gmail.com> CC: Lin Tan <tammy000@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Check for an valid i_mode when reading the inode from diskTheodore Ts'o
(cherry picked from commit 563bdd61fe4dbd6b58cf7eb06f8d8f14479ae1dc) Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Fix discard of inode prealloc space with delayed allocation.Aneesh Kumar K.V
(cherry picked from commit d6014301b5599fba395c42a1e96a7fe86f7d0b2d) With delayed allocation we should not/cannot discard inode prealloc space during file close. We would still have dirty pages for which we haven't allocated blocks yet. With this fix after each get_blocks request we check whether we have zero reserved blocks and if yes and we don't have any writers on the file we discard inode prealloc space. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Automatically allocate delay allocated blocks on renameTheodore Ts'o
(cherry picked from commit 8750c6d5fcbd3342b3d908d157f81d345c5325a7) When renaming a file such that a link to another inode is overwritten, force any delay allocated blocks that to be allocated so that if the filesystem is mounted with data=ordered, the data blocks will be pushed out to disk along with the journal commit. Many application programs expect this, so we do this to avoid zero length files if the system crashes unexpectedly. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Automatically allocate delay allocated blocks on closeTheodore Ts'o
(cherry picked from commit 7d8f9f7d150dded7b68e61ca6403a1f166fb4edf) When closing a file that had been previously truncated, force any delay allocated blocks that to be allocated so that if the filesystem is mounted with data=ordered, the data blocks will be pushed out to disk along with the journal commit. Many application programs expect this, so we do this to avoid zero length files if the system crashes unexpectedly. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: add EXT4_IOC_ALLOC_DA_BLKS ioctlTheodore Ts'o
(cherry picked from commit ccd2506bd43113659aa904d5bea5d1300605e2a6) Add an ioctl which forces all of the delay allocated blocks to be allocated. This also provides a function ext4_alloc_da_blocks() which will be used by the following commits to force files to be fully allocated to preserve application-expected ext3 behaviour. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Add fine print for the 32000 subdirectory limitTheodore Ts'o
(cherry picked from commit 722bde6875bfb49a0c84e5601eb82dd7ac02d27c) Some poeple are reading the ext4 feature list too literally and create dubious test cases involving very long filenames and 1k blocksize and then complain when they run into an htree-imposed limit. So add fine print to the "fix 32000 subdirectory limit" ext4 feature. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: return -EIO not -ESTALE on directory traversal through deleted inodeBryan Donlan
(cherry picked from commit e6f009b0b45220c004672d41a58865e94946104d) ext4_iget() returns -ESTALE if invoked on a deleted inode, in order to report errors to NFS properly. However, in ext4_lookup(), this -ESTALE can be propagated to userspace if the filesystem is corrupted such that a directory entry references a deleted inode. This leads to a misleading error message - "Stale NFS file handle" - and confusion on the part of the admin. The bug can be easily reproduced by creating a new filesystem, making a link to an unused inode using debugfs, then mounting and attempting to ls -l said link. This patch thus changes ext4_lookup to return -EIO if it receives -ESTALE from ext4_iget(), as ext4 does for other filesystem metadata corruption; and also invokes the appropriate ext*_error functions when this case is detected. Signed-off-by: Bryan Donlan <bdonlan@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: tighten restrictions on inode flagsDuane Griffin
(cherry picked from commit 2dc6b0d48ca0599837df21b14bb8393d0804af57) At the moment there are few restrictions on which flags may be set on which inodes. Specifically DIRSYNC may only be set on directories and IMMUTABLE and APPEND may not be set on links. Tighten that to disallow TOPDIR being set on non-directories and only NODUMP and NOATIME to be set on non-regular file, non-directories. Introduces a flags masking function which masks flags based on mode and use it during inode creation and when flags are set via the ioctl to facilitate future consistency. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: don't inherit inappropriate inode flags from parentDuane Griffin
(cherry picked from commit 8fa43a81b97853fc69417bb6054182e78f95cbeb) At present INDEX and EXTENTS are the only flags that new ext4 inodes do NOT inherit from their parent. In addition prevent the flags DIRTY, ECOMPR, IMAGIC, TOPDIR, HUGE_FILE and EXT_MIGRATE from being inherited. List inheritable flags explicitly to prevent future flags from accidentally being inherited. This fixes the TOPDIR flag inheritance bug reported at http://bugzilla.kernel.org/show_bug.cgi?id=9866. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: fix bb_prealloc_list corruption due to wrong group lockingEric Sandeen
(cherry-picked from commit d33a1976fbee1ee321d6f014333d8f03a39d526c) This is for Red Hat bug 490026: EXT4 panic, list corruption in ext4_mb_new_inode_pa ext4_lock_group(sb, group) is supposed to protect this list for each group, and a common code flow to remove an album is like this: ext4_get_group_no_and_offset(sb, pa->pa_pstart, &grp, NULL); ext4_lock_group(sb, grp); list_del(&pa->pa_group_list); ext4_unlock_group(sb, grp); so it's critical that we get the right group number back for this prealloc context, to lock the right group (the one associated with this pa) and prevent concurrent list manipulation. however, ext4_mb_put_pa() passes in (pa->pa_pstart - 1) with a comment, "-1 is to protect from crossing allocation group". This makes sense for the group_pa, where pa_pstart is advanced by the length which has been used (in ext4_mb_release_context()), and when the entire length has been used, pa_pstart has been advanced to the first block of the next group. However, for inode_pa, pa_pstart is never advanced; it's just set once to the first block in the group and not moved after that. So in this case, if we subtract one in ext4_mb_put_pa(), we are actually locking the *previous* group, and opening the race with the other threads which do not subtract off the extra block. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: fix bogus BUG_ONs in in mballoc codeEric Sandeen
(cherry picked from commit 8d03c7a0c550e7ab24cadcef5e66656bfadec8b9) Thiemo Nagel reported that: # dd if=/dev/zero of=image.ext4 bs=1M count=2 # mkfs.ext4 -v -F -b 1024 -m 0 -g 512 -G 4 -I 128 -N 1 \ -O large_file,dir_index,flex_bg,extent,sparse_super image.ext4 # mount -o loop image.ext4 mnt/ # dd if=/dev/zero of=mnt/file oopsed, with a BUG_ON in ext4_mb_normalize_request because size == EXT4_BLOCKS_PER_GROUP It appears to me (esp. after talking to Andreas) that the BUG_ON is bogus; a request of exactly EXT4_BLOCKS_PER_GROUP should be allowed, though larger sizes do indicate a problem. Fix that an another (apparently rare) codepath with a similar check. Reported-by: Thiemo Nagel <thiemo.nagel@ph.tum.de> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: Print the find_group_flex() warning only onceTheodore Ts'o
(cherry picked from commit 2842c3b5449f31470b61db716f1926b594fb6156) This is a short-term warning, and even printk_ratelimit() can result in too much noise in system logs. So only print it once as a warning. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: fix header check in ext4_ext_search_right() for deep extent trees.Eric Sandeen
(cherry picked from commit 395a87bfefbc400011417e9eaae33169f9f036c0) The ext4_ext_search_right() function is confusing; it uses a "depth" variable which is 0 at the root and maximum at the leaves, but the on-disk metadata uses a "depth" (actually eh_depth) which is opposite: maximum at the root, and 0 at the leaves. The ext4_ext_check_header() function is given a depth and checks the header agaisnt that depth; it expects the on-disk semantics, but we are giving it the opposite in the while loop in this function. We should be giving it the on-disk notion of "depth" which we can get from (p_depth - depth) - and if you look, the last (more commonly hit) call to ext4_ext_check_header() does just this. Sending in the wrong depth results in (incorrect) messages about corruption: EXT4-fs error (device sdb1): ext4_ext_search_right: bad header in inode #2621457: unexpected eh_depth - magic f30a, entries 340, max 340(0), depth 1(2) http://bugzilla.kernel.org/show_bug.cgi?id=12821 Reported-by: David Dindorp <ddi@dubex.dk> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11ext4: fix ext4_free_inode() vs. ext4_claim_inode() raceEric Sandeen
(cherry picked from commit 7ce9d5d1f3c8736511daa413c64985a05b2feee3) I was seeing fsck errors on inode bitmaps after a 4 thread dbench run on a 4 cpu machine: Inode bitmap differences: -50736 -(50752--50753) etc... I believe that this is because ext4_free_inode() uses atomic bitops, and although ext4_new_inode() *used* to also use atomic bitops for synchronization, commit 393418676a7602e1d7d3f6e560159c65c8cbd50e changed this to use the sb_bgl_lock, so that we could also synchronize against read_inode_bitmap and initialization of uninit inode tables. However, that change left ext4_free_inode using atomic bitops, which I think leaves no synchronization between setting & unsetting bits in the inode table. The below patch fixes it for me, although I wonder if we're getting at all heavy-handed with this spinlock... Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11mac80211: pid, fix memory corruptionJiri Slaby
commit a8659597bf744b0f8d2560e2a734b5c941569e0e upstream pid doesn't count with some band having more bitrates than the one associated the first time. Fix that by counting the maximal available bitrate count and allocate big enough space. Secondly, fix touching uninitialized memory which causes panics. Index sucked from this random memory points to the hell. The fix is to sort the rates on each band change. Also remove a comment which is wrong now. This version also contains half of mac80211: avoid NULL ptr deref when finding max_rates in PID and minstrel patch by John W. Linville, which is namely: - if (sband->n_bitrates > max_rates) + if (sband && sband->n_bitrates > max_rates) to fix oopses on one band devices. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11x86: fix DMI on EFIBrian Maly
commit ff0c0874905fb312ca1491bbdac2653b0b48c20b upstream. Impact: reactivate DMI quirks on EFI hardware DMI tables are loaded by EFI, so the dmi calls must happen after efi_init() and not before. Currently Apple hardware uses DMI to determine the framebuffer mappings for efifb. Without DMI working you also have no video on MacBook Pro. This patch resolves the DMI issue for EFI hardware (DMI is now properly detected at boot), and additionally efifb now loads on Apple hardware (i.e. video works). Signed-off-by: Brian Maly <bmaly@redhat> Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: ying.huang@intel.com LKML-Reference: <49ADEDA3.1030406@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11V4L/DVB (10943): cx88: Prevent general protection fault on rmmodJean Delvare
commit 569b7ec73abf576f9a9e4070d213aadf2cce73cb upstream. V4L/DVB (10943): cx88: Prevent general protection fault on rmmod When unloading the cx8800 driver I sometimes get a general protection fault. Analysis revealed a race in cx88_ir_stop(). It can be solved by using a delayed work instead of a timer for infrared input polling. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11x86/pci: fix mmconfig detection with 32bit near 4gYinghai Lu
commit 75e613cdc7bb2ba3795b1bc3ddf19476c767ba68 upstream. Pascal reported and bisected a commit: | x86/PCI: don't call e820_all_mapped with -1 in the mmconfig case which broke one system system. ACPI: Using IOAPIC for interrupt routing PCI: MCFG configuration 0: base f0000000 segment 0 buses 0 - 255 PCI: MCFG area at f0000000 reserved in ACPI motherboard resources PCI: Using MMCONFIG for extended config space it didn't have PCI: updated MCFG configuration 0: base f0000000 segment 0 buses 0 - 63 anymore, and try to use 0xf000000 - 0xffffffff for mmconfig For 32bit, mcfg_res->end could be 32bit only (if 64 resources aren't used) So use end - 1 to pass the value in mcfg->end to avoid overflow. We don't need to worry about the e820 path, they are always 64 bit. Reported-by: Pascal Terjan <pterjan@mandriva.com> Bisected-by: Pascal Terjan <pterjan@mandriva.com> Tested-by: Pascal Terjan <pterjan@mandriva.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11x86: ignore VM_LOCKED when determining if hugetlb-backed page tables can be ↵Mel Gorman
shared or not commit 32b154c0b0bae2879bf4e549d861caf1759a3546 upstream. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13302 On x86 and x86-64, it is possible that page tables are shared beween shared mappings backed by hugetlbfs. As part of this, page_table_shareable() checks a pair of vma->vm_flags and they must match if they are to be shared. All VMA flags are taken into account, including VM_LOCKED. The problem is that VM_LOCKED is cleared on fork(). When a process with a shared memory segment forks() to exec() a helper, there will be shared VMAs with different flags. The impact is that the shared segment is sometimes considered shareable and other times not, depending on what process is checking. What happens is that the segment page tables are being shared but the count is inaccurate depending on the ordering of events. As the page tables are freed with put_page(), bad pmd's are found when some of the children exit. The hugepage counters also get corrupted and the Total and Free count will no longer match even when all the hugepage-backed regions are freed. This requires a reboot of the machine to "fix". This patch addresses the problem by comparing all flags except VM_LOCKED when deciding if pagetables should be shared or not for hugetlbfs-backed mapping. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <starlight@binnacle.cx> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11USB: isp1760: urb_dequeue doesn't always find the urbsWarren Free
commit 0afb20e00b5053170c85298fed842b32d20b4ea9 upstream. The option driver (and presumably others) allocates several URBs when it opens and tries to free them when it closes. The isp1760_urb_dequeue function gets called, but the packet being dequeued is not necessarily at the front of one of the 32 queues. If not, the isp1760_urb_done function doesn't get called for the URB and the process trying to free it hangs forever on a wait_queue. This patch does two things. If the URB being dequeued has others queued behind it, it re-queues them. And it searches the queues looking for the URB being dequeued rather than just looking at the one at the front of the queue. [bigeasy@linutronix] whitespace fixes, reformating Signed-off-by: Warren Free <wfree@ipmn.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11sound: usb-audio: make the MotU Fastlane work againClemens Ladisch
commit 55de5ef970c680d8d75f2a9aa7e4f172140dbd9c upstream. Kernel 2.6.18 broke the MotU Fastlane, which uses duplicate endpoint numbers in a manner that is not only illegal but also confuses the kernel's endpoint descriptor caching mechanism. To work around this, we have to add a separate usb_set_interface() call to guide the USB core to the correct descriptors. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-and-tested-by: David Fries <david@fries.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11SELinux: BUG in SELinux compat_net codeEric Paris
This patch is not applicable to Linus's tree as the code in question has been removed for 2.6.30. I'm sending in case any of the stable maintainers would like to push to their branches (which I think anything pre 2.6.30 would like to do). Ubuntu users were experiencing a kernel panic when they enabled SELinux due to an old bug in our handling of the compatibility mode network controls, introduced Jan 1 2008 effad8df44261031a882e1a895415f7186a5098e Most distros have not used the compat_net code since the new code was introduced and so noone has hit this problem before. Ubuntu is the only distro I know that enabled that legacy cruft by default. But, I was ask to look at it and found that the above patch changed a call to avc_has_perm from if(send_perm) to if(!send_perm) in selinux_ip_postroute_iptables_compat(). The result is that users who turn on SELinux and have compat_net set can (and oftern will) BUG() in avc_has_perm_noaudit since they are requesting 0 permissions. This patch corrects that accidental bug introduction. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11Avoid ICE in get_random_int() with gcc-3.4.5Linus Torvalds
commit 26a9a418237c0b06528941bca693c49c8d97edbe upstream. Martin Knoblauch reports that trying to build 2.6.30-rc6-git3 with RHEL4.3 userspace (gcc (GCC) 3.4.5 20051201 (Red Hat 3.4.5-2)) causes an internal compiler error (ICE): drivers/char/random.c: In function `get_random_int': drivers/char/random.c:1672: error: unrecognizable insn: (insn 202 148 150 0 /scratch/build/linux-2.6.30-rc6-git3/arch/x86/include/asm/tsc.h:23 (set (reg:SI 0 ax [91]) (subreg:SI (plus:DI (plus:DI (reg:DI 0 ax [88]) (subreg:DI (reg:SI 6 bp) 0)) (const_int -4 [0xfffffffffffffffc])) 0)) -1 (nil) (nil)) drivers/char/random.c:1672: internal compiler error: in extract_insn, at recog.c:2083 and after some debugging it turns out that it's due to the code trying to figure out the rough value of the current stack pointer by taking an address of an uninitialized variable and casting that to an integer. This is clearly a compiler bug, but it's not worth fighting - while the current stack kernel pointer might be somewhat hard to predict in user space, it's also not generally going to change for a lot of the call chains for a particular process. So just drop it, and mumble some incoherent curses at the compiler. Tested-by: Martin Knoblauch <spamtrap@knobisoft.de> Cc: Matt Mackall <mpm@selenic.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11random: make get_random_int() more randomLinus Torvalds
commit 8a0a9bd4db63bc45e3017bedeafbd88d0eb84d02 upstream. It's a really simple patch that basically just open-codes the current "secure_ip_id()" call, but when open-coding it we now use a _static_ hashing area, so that it gets updated every time. And to make sure somebody can't just start from the same original seed of all-zeroes, and then do the "half_md4_transform()" over and over until they get the same sequence as the kernel has, each iteration also mixes in the same old "current->pid + jiffies" we used - so we should now have a regular strong pseudo-number generator, but we also have one that doesn't have a single seed. Note: the "pid + jiffies" is just meant to be a tiny tiny bit of noise. It has no real meaning. It could be anything. I just picked the previous seed, it's just that now we keep the state in between calls and that will feed into the next result, and that should make all the difference. I made that hash be a per-cpu data just to avoid cache-line ping-pong: having multiple CPU's write to the same data would be fine for randomness, and add yet another layer of chaos to it, but since get_random_int() is supposed to be a fast interface I did it that way instead. I considered using "__raw_get_cpu_var()" to avoid any preemption overhead while still getting the hash be _mostly_ ping-pong free, but in the end good taste won out. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jake Edge <jake@lwn.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11mm: account for MAP_SHARED mappings using VM_MAYSHARE and not VM_SHARED in ↵Mel Gorman
hugetlbfs commit f83a275dbc5ca1721143698e844243fcadfabf6a upstream. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13302 hugetlbfs reserves huge pages but does not fault them at mmap() time to ensure that future faults succeed. The reservation behaviour differs depending on whether the mapping was mapped MAP_SHARED or MAP_PRIVATE. For MAP_SHARED mappings, hugepages are reserved when mmap() is first called and are tracked based on information associated with the inode. Other processes mapping MAP_SHARED use the same reservation. MAP_PRIVATE track the reservations based on the VMA created as part of the mmap() operation. Each process mapping MAP_PRIVATE must make its own reservation. hugetlbfs currently checks if a VMA is MAP_SHARED with the VM_SHARED flag and not VM_MAYSHARE. For file-backed mappings, such as hugetlbfs, VM_SHARED is set only if the mapping is MAP_SHARED and the file was opened read-write. If a shared memory mapping was mapped shared-read-write for populating of data and mapped shared-read-only by other processes, then hugetlbfs would account for the mapping as if it was MAP_PRIVATE. This causes processes to fail to map the file MAP_SHARED even though it should succeed as the reservation is there. This patch alters mm/hugetlb.c and replaces VM_SHARED with VM_MAYSHARE when the intent of the code was to check whether the VMA was mapped MAP_SHARED or MAP_PRIVATE. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <starlight@binnacle.cx> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11igb: fix LRO warningJeff Kirsher
This fix is only needed for 2.6.29.y tree, since in 2.6.30 and later IGB has moved to using GRO instead of LRO. igb supports LRO, but was not setting any hooks to the ->set_flags ethtool_ops function. This would trigger warnings if the user tried to enable or disable LRO. Based on the patch provided by Stephen Hemminger <shemminger@vyatta.com> Reported-by: Sergey Kononenko <sergk@sergk.org.ua> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11hwmon: (lm78) Add missing __devexit_p()Mike Frysinger
commit 39d8bbedb9571a89d638f5b05358f26ab503d7a6 upstream. The remove function uses __devexit, so the .remove assignment needs __devexit_p() to fix a build error with hotplug disabled. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11e1000: add missing length check to e1000 receive routineNeil Horman
commit ea30e11970a96cfe5e32c03a29332554573b4a10 upstream. Patch to fix bad length checking in e1000. E1000 by default does two things: 1) Spans rx descriptors for packets that don't fit into 1 skb on recieve 2) Strips the crc from a frame by subtracting 4 bytes from the length prior to doing an skb_put Since the e1000 driver isn't written to support receiving packets that span multiple rx buffers, it checks the End of Packet bit of every frame, and discards it if its not set. This places us in a situation where, if we have a spanning packet, the first part is discarded, but the second part is not (since it is the end of packet, and it passes the EOP bit test). If the second part of the frame is small (4 bytes or less), we subtract 4 from it to remove its crc, underflow the length, and wind up in skb_over_panic, when we try to skb_put a huge number of bytes into the skb. This amounts to a remote DOS attack through careful selection of frame size in relation to interface MTU. The fix for this is already in the e1000e driver, as well as the e1000 sourceforge driver, but no one ever pushed it to e1000. This is lifted straight from e1000e, and prevents small frames from causing the underflow described above Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Tested-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11drivers/serial/mpc52xx_uart.c: fix array overindexing checkRoel Kluin
commit b898f4f869da5b9d41f297fff87aca4cd42d80b3 upstream. The check for an overindexing of mpc52xx_uart_{ports,nodes} has an off-by-one. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11cpuidle: make AMC C1E work in processor_idleShaohua Li
commit 87ad57bacb25c3f24c54f142ef445f68277705f0 upstream When AMD C1E is enabled, local APIC timer will stop even in C1. This patch uses broadcast ipi to replace local APIC timer in C1. http://bugzilla.kernel.org/show_bug.cgi?id=13233 [ impact: avoid boot hang in AMD CPU with C1E enabled ] Tested-by: Dmitry Lyzhyn <thisistempbox@yahoo.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11cpuidle: fix AMD C1E suspend hangShaohua Li
commit 7d60e8ab0d5507229dfbdf456501cc378610fa01 upstream. When AMD C1E is enabled, local APIC timer will stop even in C1. To avoid suspend/resume hang, this patch removes C1 and replace it with a cpu_relax() in suspend/resume path. This hasn't any impact in runtime path. http://bugzilla.kernel.org/show_bug.cgi?id=13233 [ impact: avoid suspend/resume hang in AMD CPU with C1E enabled ] Tested-by: Dmitry Lyzhyn <thisistempbox@yahoo.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11bnx2: Fix panic in bnx2_poll_work().Michael Chan
commit 581daf7e00c5e766f26aff80a61a860a17b0d75a upstream. Add barrier() to bnx2_get_hw_{tx|rx}_cons() to fix this issue: http://bugzilla.kernel.org/show_bug.cgi?id=12698 This issue was reported by multiple i386 users. Without barrier(), the compiled code looks like the following where %eax contains the address of the tx_cons or rx_cons in the DMA status block. The status block contents can change between the cmpb and the movzwl instruction. The driver would crash if the value was not 0xff during the cmpb instruction, but changed to 0xff during the movzwl instruction. 6828: 80 38 ff cmpb $0xff,(%eax) 682b: 0f b7 10 movzwl (%eax),%edx With the added barrier(), the compiled code now looks correct: 683d: 0f b7 10 movzwl (%eax),%edx 6840: 0f b6 c2 movzbl %dl,%eax 6843: 3d ff 00 00 00 cmp $0xff,%eax Thanks to Pascal de Bruijn <pmjdebruijn@pcode.nl> for reporting the problem and Holger Noefer <hnoefer@pironet-ndh.com> for patiently testing test patches for us. [greg - took out version change] Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-113w-xxxx: scsi_dma_unmap fixadam radford
commit 7b14f58ad65f9d74e4273fb45360cfea824495aa upstream. This patch fixes the following regression that occurred during the scsi_dma_map()/unmap() changes when compiling with CONFIG_DMA_API_DEBUG=y : WARNING: at lib/dma-debug.c:496 check_unmap+0x142/0x542() Hardware name: 3w-xxxx 0000:02:02.0: DMA-API: device driver tries to free DMA memory it has not allocated [device address=0x0000000000000000] [size=36 bytes] Signed-off-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11x86: work around Fedora-11 x86-32 kernel failures on Intel Atom CPUsIngo Molnar
commit 211b3d03c7400f48a781977a50104c9d12f4e229 upstream [Trivial backport to 2.6.27 by cebbert@redhat.com] x86: work around Fedora-11 x86-32 kernel failures on Intel Atom CPUs Impact: work around boot crash Work around Intel Atom erratum AAH41 (probabilistically) - it's triggering in the field. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11tcp: fix >2 iw selectionIlpo Järvinen
[ Upstream commit 86bcebafc5e7f5163ccf828792fe694b112ed6fa ] A long-standing feature in tcp_init_metrics() is such that any of its goto reset prevents call to tcp_init_cwnd(). Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11net: fix skb_seq_read returning wrong offset/length for page frag dataThomas Chenault
[ Upstream commit 995b337952cdf7e05d288eede580257b632a8343 ] When called with a consumed value that is less than skb_headlen(skb) bytes into a page frag, skb_seq_read() incorrectly returns an offset/length relative to skb->data. Ensure that data which should come from a page frag does. Signed-off-by: Thomas Chenault <thomas_chenault@dell.com> Tested-by: Shyam Iyer <shyam_iyer@dell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11pktgen: do not access flows[] beyond its lengthFlorian Westphal
[ Upstream commit 5b5f792a6a9a2f9ae812d151ed621f72e99b1725 ] typo -- pkt_dev->nflows is for stats only, the number of concurrent flows is stored in cflows. Reported-By: Vladimir Ivashchenko <hazard@francoudi.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11myr10ge: again fix lro_gen_skb() alignmentStanislaw Gruszka
[ Upstream commit 636d2f68a0814d84de26c021b2c15e3b4ffa29de ] Add LRO alignment initially committed in 621544eb8c3beaa859c75850f816dd9b056a00a3 ("[LRO]: fix lro_gen_skb() alignment") and removed in 0dcffac1a329be69bab0ac604bf7283737108e68 ("myri10ge: add multislices support") during conversion to multi-slice. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11vlan/macvlan: fix NULL pointer dereferences in ethtool handlersPatrick McHardy
[ Upstream commit 7816a0a862d851d0b05710e7d94bfe390f3180e2 ] Check whether the underlying device provides a set of ethtool ops before checking for individual handlers to avoid NULL pointer dereferences. Reported-by: Art van Breemen <ard@telegraafnet.nl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
