The SMT scheduler incorrectly skips kernel threads even if they are
runnable (but they are preempted by a higher-prio user-space task which got
SMT-delayed by an even higher-priority task running on a sibling CPU).
Fix this for now by only doing the SMT-nice optimization if the
to-be-delayed task is the only runnable task. (This should cover most of
the real-life cases anyway.)
This bug has been in the SMT scheduler since 2.6.17 or so, but has only
been noticed now by the active check in the dynticks code.
Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Chuck Ebbert <cebbert@redhat.com>
This patch fixes a possible race that leads to double freeing an idr index.
When the master begin to close, release_dev() is called and then
pty_close() is called:
if (tty->driver->close)
tty->driver->close(tty, filp);
This is done without helding any locks other than BKL. Inside pty_close(),
being a master close, the devpts entry will be removed:
#ifdef CONFIG_UNIX98_PTYS
if (tty->driver == ptm_driver)
devpts_pty_kill(tty->index);
#endif
But devpts_pty_kill() will call get_node() that may sleep while waiting for
&devpts_root->d_inode->i_sem. When this happens and the slave is being
opened, tty_open() just found the driver and index:
driver = get_tty_driver(device, &index);
if (!driver) {
mutex_unlock(&tty_mutex);
return -ENODEV;
This part of the code is already protected under tty_mute. The problem is
that the slave close already got an index. Then init_dev() is called and
blocks waiting for the same &devpts_root->d_inode->i_sem.
When the master close resumes, it removes the devpts entry, and the
relation between idr index and the tty is gone. The master then sleeps
waiting for the tty_mutex on release_dev().
Slave open resumes and found no tty for that index. As result, a NULL tty
is returned and init_dev() doesn't flow to fast_track:
/* check whether we're reopening an existing tty */
if (driver->flags & TTY_DRIVER_DEVPTS_MEM) {
tty = devpts_get_tty(idx);
if (tty && driver->subtype == PTY_TYPE_MASTER)
tty = tty->link;
} else {
tty = driver->ttys[idx];
if (tty) goto fast_track;
The result of this, is that a new tty will be created and init_dev() returns
sucessfull. After returning, tty_mutex is dropped and master close may resume.
Master close finds it's the only use and both sides are closing, then releases
the tty and the index. At this point, the idr index is free, but slave still
has it.
Slave open then calls pty_open() and finds that tty->link->count is 0,
because there's no master and returns error. Then tty_open() calls
release_dev() which executes without any warning, as it was a case of last
slave close when the master is already closed (master->count == 0,
slave->count == 1). The tty is then released with the already released idr
index.
This normally would only issue a warning on idr_remove() but in case of a
customer's critical application, it's never too simple:
thread1: opens master, gets index X
thread1: begin closing master
thread2: begin opening slave with index X
thread1: finishes closing master, index X released
thread3: opens master, gets index X, just released
thread2: fails opening slave, releases index X <----
thread4: opens master, gets index X, init_dev() then find an already in use
and healthy tty and fails
If no more indexes are released, ptmx_open() will keep failing, as the
first free index available is X, and it will make init_dev() fail because
you're trying to "reopen a master" which isn't valid.
The patch notices when this race happens and make init_dev() fail
imediately. The init_dev() function is called with tty_mutex held, so it's
safe to continue with tty till the end of function because release_dev()
won't make any further changes without grabbing the tty_mutex.
Without the patch, on some machines it's possible get easily idr warnings
like this one:
idr_remove called for id=15 which is not allocated.
[<c02555b9>] idr_remove+0x139/0x170
[<c02a1b62>] release_mem+0x182/0x230
[<c02a28e7>] release_dev+0x4b7/0x700
[<c02a0ea7>] tty_ldisc_enable+0x27/0x30
[<c02a1e64>] init_dev+0x254/0x580
[<c02a0d64>] check_tty_count+0x14/0xb0
[<c02a4f05>] tty_open+0x1c5/0x340
[<c02a4d40>] tty_open+0x0/0x340
[<c017388f>] chrdev_open+0xaf/0x180
[<c017c2ac>] open_namei+0x8c/0x760
[<c01737e0>] chrdev_open+0x0/0x180
[<c0167bc9>] __dentry_open+0xc9/0x210
[<c0167e2c>] do_filp_open+0x5c/0x70
[<c0167a91>] get_unused_fd+0x61/0xd0
[<c0167e93>] do_sys_open+0x53/0x100
[<c0167f97>] sys_open+0x27/0x30
[<c010303b>] syscall_call+0x7/0xb
using this test application available on:
http://www.ruivo.org/~aris/pty_sodomizer.c
Signed-off-by: Aristeu Sergio Rozanski Filho <aris@ruivo.org>
forcedeth: disable msix
There seems to be an issue when both MSI-X is enabled and NAPI is
configured. This patch disables MSI-X until the issue is root caused.
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
On Monday February 12, marcm@liquid-nexus.net wrote:
> > Thanks for the quick response Neil unfortunately the kernel doesn't build with
> > this patch due to a missing symbol:
> > WARNING: "blk_recount_segments" [drivers/md/raid456.ko] undefined!
> > Is that in another file that needs patching or within raid5.c?
Yes. I keep forgetting about that bit. Sorry.
Signed-off-by: Neil Brown <neilb@suse.de>
related to packet queueing.
Signed-off-by: MichaÅ MirosÅaw <mirq-linux@rere.qmqm.pl>
[IPV6]: /proc/net/anycast6 unbalanced inet6_dev refcnt
Reading /proc/net/anycast6 when there is no anycast address
on an interface results in an ever-increasing inet6_dev reference
count, as well as a reference to the netdevice you can't get rid of.
[IPV6]: anycast refcnt fix
This patch fixes a bug in Linux IPv6 stack which caused anycast address
to be added to a device prior DAD has been completed. This led to
incorrect reference count which resulted in infinite wait for
unregister_netdevice completion on interface removal.
Signed-off-by: Michal Wrobel <xmxwx@asn.pl>
[TCP]: Fix MD5 signature pool locking.
The locking calls assumed that these code paths were only
invoked in software interrupt context, but that isn't true.
Therefore we need to use spin_{lock,unlock}_bh() throughout.
[SPARC64] bbc_i2c: Fix kenvctrld eating %100 cpu.
Based almost entirely upon a patch by Joerg Friedrich
[XFRM_TUNNEL]: Reload header pointer after pskb_may_pull/pskb_expand_head
Please consider applying, this was found on your latest
net-2.6 tree while playing around with that ip_hdr() + turn
skb->nh/h/mac pointers as offsets on 64 bits idea :-)
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[XFRM] xfrm_user: Fix return values of xfrm_add_sa_expire.
As noted by Kent Yoder, this function will always return an
error. Make sure it returns zero on success.
[SPARC64]: Fix PCI interrupts on E450 et al.
When the PCI controller OBP node lacks an interrupt-map
and interrupt-map-mask property, we need to form the
INO by hand. The PCI swizzle logic was not doing that
properly.
This was a regression added by the of_device code.
HID: fix possible double-free on error path in hid parser
Freeing of device->collection is properly done in hid_free_device() (as
this function is supposed to free all the device resources and could be
called from transport specific code, e.g. usb_hid_configure()).
Remove all kfree() calls preceeding the hid_free_device() call.
To the issue: some point during 2.6.20 development, Paul Mackerras
introduced the "lazy IRQ disabling" patch (very cool work, BTW).
In that patch, the performance monitor unit exception was marked as
"maskable", in the sense that if interrupts were soft-disabled, that
exception could be ignored. This broke my PowerPC profiling code.
The symptom that I see is that a varying number of interrupts
(from 0 to $n$, typically closer to 0) get delivered, when, in
reality, it should always be very close to $n$.
The issue stems from the way masking is being done. Masking in
this fashion seems to work well with the decrementer and external
interrupts, because they are raised again until "really" handled.
For the PMU, however, this does not apply (at least on my Xserver
machine with a 970FX processor). If the PMU exception is not handled,
it will _not_ be re-raised (at least on my machine). The documentation
states that the PMXE bit in MMCR0 is set to 0 when the PMU exception
is raised. However, software must re-set the bit to re-enable PMU
exceptions. If the exception is ignored (as currently) not only is
that interrupt lost, but because software does not re-set PMXE, the
PMU registers are "frozen" forever.
[This patch means that performance monitor exceptions are taken and
handled even if irqs are off, as long as some other interrupt hasn't
come along and caused interrupts to be hard-disabled. In this sense
the PMU exception becomes like an NMI. The oprofile code for most
powerpc processors does nothing that is unsafe in an NMI context, but
the Cell oprofile code does a spin_lock_irqsave. However, that turns
out to be OK because Cell doesn't actually use the performance
monitor exception; performance monitor interrupts come in as a
regular interrupt on Cell, so will be disabled when irqs are off.
-- paulus.]
Add missing #ifdef CONFIG_PM conditionals around all PM related parts
in libata LLDs.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Some LLDs were missing scsi device PM callbacks while having host/port
suspend support. Add missing ones.
In the bcm43xx interrupt handler, sanity checks are wrongly done before the
verification that the interrupt is for the bcm43xx.
Signed-off-by: Pavel Roskin <proski@gnu.org>
mmc: Power quirk for ENE controllers
Support for these devices was broken for 2.6.18-rc1 and later by commit
146ad66eac836c0b976c98f428d73e1f6a75270d, which added voltage level support.
This restores the previous behaviour for these devices by ensuring that when
the voltage is changed, only one write to set the voltage is performed.
It may be that both writes are needed if the voltage is being changed between
two non-zero values or that it's safe to ensure that only one write is done
if the hardware only supports one voltage; I don't know whether either is the
case nor can I test since I have only the one SD reader (1524:0550), and it
supports just the one voltage.
Signed-off-by: Darren Salt <linux@youmustbejoking.demon.co.uk>
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
A previous cleanup misused need_poll, which had a fairly broken
interface. It implemented a growable array, changing the used
elements count itself, but leaving it up to the caller to fill in the
actual elements, including the entire array if the array had to be
reallocated. This worked because the previous users were switching
between two such structures, and the elements were copied from the
inactive array to the active array after making sure the active array
had enough room.
maybe_sigio_broken was made to use need_poll, but it was operating on
a single array, so when the buffer was reallocated, the previous
contents were lost.
This patch makes need_poll implement more sane semantics. It merely
assures that the array is of the proper size and that the contents are
preserved. It is up to the caller to adjust the used elements count
and to ensure that the proper elements are resent.
This manifested itself as a hang in 2.6.20 as the uninitialized buffer
convinced UML that one of its own file descriptors didn't support
SIGIO and needed to be watched by poll in a separate thread. The
result was an interrupt flood as control traffic over this descriptor
sparked interrupts, which resulted in more control traffic, ad nauseum.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Fix insecure default behaviour reported by Tigran Aivazian: if an ext2
or ext3 or ext4 filesystem is tuned to mount with "acl", but mounted by
a kernel built without ACL support, then umask was ignored when creating
inodes - though root or user has umask 022, touch creates files as 0666,
and mkdir creates directories as 0777.
This appears to have worked right until 2.6.11, when a fix to the default
mode on symlinks (always 0777) assumed VFS applies umask: which it does,
unless the mount is marked for ACLs; but ext[234] set MS_POSIXACL in
s_flags according to s_mount_opt set according to def_mount_opts.
We could revert to the 2.6.10 ext[234]_init_acl (adding an S_ISLNK test);
but other filesystems only set MS_POSIXACL when ACLs are configured. We
could fix this at another level; but it seems most robust to avoid setting
the s_mount_opt flag in the first place (at the expense of more ifdefs).
Likewise don't set the XATTR_USER flag when built without XATTR support.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Acked-by: Andreas Gruenbacher <agruen@suse.de>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
sata_sil used to trigger HSM error if IRQ occurs during polling
command. This didn't matter because polling wasn't used in sata_sil.
However, as of 2.6.20, all IDENTIFYs are performed by polling and
device detection sometimes fails due to spurious IRQ. This patch
makes sata_sil ignore and clear spurious IRQ while executing commands
by polling.
This fixes bug#7996 and IMHO should also be included in -stable.
Cc: Jeff Garzik <jeff@garzik.org>
Fix the Oops occuring when SNAPSHOT_PMOPS or SNAPSHOT_S2RAM ioctl is called on
a system without pm_ops defined (eg. a non-ACPI kernel on x86 PC).
Signed-off-by: Stefan Seyfried <seife@suse.de>
Acked-by: Pavel Machek <pavel@ucw.cz>
Problem description at:
http://bugzilla.kernel.org/show_bug.cgi?id=8048
Commit b18ec80396834497933d77b81ec0918519f4e2a7
[PATCH] sched: improve migration accuracy
optimized the scheduler time calculations, but broke posix-cpu-timers.
The problem is that the p->last_ran value is not updated after a context
switch. So a subsequent call to current_sched_time() calculates with a
stale p->last_ran value, i.e. accounts the full time, which the task was
scheduled away.
This updates the cx88-blackbird driver to be able to use the new cx23416
firmware image released by Hauppauge Computer Works, while retaining
compatibility with the older firmware images.
cx2341x firmware can be downloaded at: http://dl.ivtvdriver.org/ivtv/firmware/
(cherry picked from commit af70dbd3346999570db73b3bc3d4f7b7c004f2ea)
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Due to changes in the i2c handling in 2.6.20 this cx25840 bug surfaced,
causing the firmware load to fail for the ivtv driver. The correct
sequence is to first attach the i2c client, then use the client's
device to load the firmware.
(cherry picked from commit d55c7aec666658495e5b57a6b194c8c2a1ac255f)
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Acked-by: Mike Isely <isely@pobox.com>
dvb-pll normally opens the i2c gate before attempting to communicate with
the pll, but the code for this device is not using dvb-pll. This should
be cleaned up in the future, but for now, just open the i2c gate at the
appropriate place in order to fix this driver bug.
(cherry picked from commit 2fe22dcdc79b8dd34e61a3f1231caffd6180a626)
Without this patch, the device will not be detected after firmware download
on big endian systems.
(cherry picked from commit 1d1370a48ca285ebe197ecd3197a8d5f161bc291)
Signed-off-by: Jin-Bong lee <jinbong.lee@samsung.com>
Rework the cx23416 firmware loader so that it longer requires the
firmware size to be a multiple of 8KB. Until recently all cx2341x
firmware images were exactly 256KB, but newer firmware is larger than
that and also appears to have arbitrary size. We still must check
against a multiple of 4 bytes (because the cx23416 itself uses a 32
bit word size).
This fix is already in the upstream driver source and has proven
itself there; this is a backport for the 2.6.20.y kernel series.
(backported from commit 90060d32ca0a941b158994f78e60d0381871c84b)
Signed-off-by: Mike Isely <isely@pobox.com>
This introduces some extra cx23416 commands when streaming is
started. The addition of these commands fix random sporadic video
corruption that can take place when the video stream is temporarily
disrupted through loss of signal (e.g. changing the channel in the RF
tuner).
(backported from commit 6fe7d2c4660174110c6872cacc4fc2acb6e00acf)
Arjan van de Ven <arjan@infradead.org> reported an illegal re-usage of
the fileoperations struct if more than one dvb device (e.g. frontend) is
present.
This patch fixes this issue.
It allocates a new fileoperations struct each time a device is
registered and copies the default template fileops.
(backported from commit b61901024776b25ce7b8edc31bb1757c7382a88e)
Signed-off-by: Marcel Siegert <mws@linuxtv.org>
There are two errors that can lead to recovery problems with raid10
when used in 'far' more (not the default).
Due to a '>' instead of '>=' the wrong block is located which would
result in garbage being written to some random location, quite
possible outside the range of the device, causing the newly
reconstructed device to fail.
The device size calculation had some rounding errors (it didn't round
when it should) and so recovery would go a few blocks too far which
would again cause a write to a random block address and probably
a device error.
The code for working with device sizes was fairly confused and spread
out, so this has been tided up a bit.
BCM4309 devices aren't working properly as A PHYs aren't supported yet, but
we probe 802.11a cores anyway. This fixes it, while still allowing for A PHY code
to be developed in the future.
Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it>
Cc: Michael Buesch <mb@bu3sch.de>
After updating several machines to 2.6.20, I can't boot anymore the single
one of them that supports the NX bit and is configured as a 32-bit system.
My understanding is that the VDSO changes in 2.6.20-rc7 were not fully
cooked, in that with that config option enabled VDSO_SYM(x) now equals
x, meaning that an address in the fixmap area is now being passed to
apps via AT_SYSINFO. However, the page is mapped with PAGE_READONLY
rather than PAGE_READONLY_EXEC.
I'm not certain whether having app code go through the fixmap area is
intended, but in case it is here is the simple patch that makes things work
again.
Cc: Theodore Tso <tytso@mit.edu>
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Andi Kleen <ak@suse.de>
x86: Don't require the vDSO for handling a.out signals
and in other strange binfmts. vDSO is not necessarily mapped there.
This fixes signals in a.out programs
gcc 5.0 will likely not have the constraint problem
The code in transmit timeout incorrectly assumed that netif_tx_lock
was not set.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Don't mark pause frames as errors. This problem caused transmitter not
to pause and would effectively take out a gigabit switch because the
it can't handle overrun.
[XFRM]: Fix OOPSes in xfrm_audit_log().
Make sure that this function is called correctly, and
add BUG() checking to ensure the arguments are sane.
Based upon a patch by Joy Latten.
TCP may advertize up to 16-bits window in SYN packets (no window
scaling allowed). At the same time, TCP may have rcv_wnd
(32-bits) that does not fit to 16-bits without window scaling
resulting in pseudo garbage into advertized window from the
low-order bits of rcv_wnd. This can happen at least when
mss <= (1<<wscale) (see tcp_select_initial_window). This patch
fixes the handling of SYN advertized windows (compile tested
only).
In worst case (which is unlikely to occur though), the receiver
advertized window could be just couple of bytes. I'm not sure
that such situation would be handled very well at all by the
receiver!? Fortunately, the situation normalizes after the
first non-SYN ACK is received because it has the correct,
scaled window.
Alternatively, tcp_select_initial_window could be changed to
prevent too large rcv_wnd in the first place.
[ tcp_make_synack() has the same bug, and I've added a fix for
that to this patch -DaveM ]
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
[IPX]: Fix NULL pointer dereference on ipx unload
Fixes a null pointer dereference when unloading the ipx module.
On initialization of the ipx module, registering certain packet
types can fail. When this happens, unloading the module later
dereferences NULL pointers. This patch fixes that. Please apply.
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
[NETFILTER]: Clear GSO bits for TCP reset packet
The TCP reset packet is copied from the original. This
includes all the GSO bits which do not apply to the new
packet. So we should clear those bits.
Spotted by Patrick McHardy.
[ATM]: atmarp.h needs to always include linux/types.h
To provide the __be* types, even for userspace includes.
Reported by Andrew Walrond.
This patch (as863) fixes a problem encountered sometimes when resuming
a port on a UHCI controller. The hardware may turn off the
Resume-Detect bit before turning off the Suspend bit, leading usbcore
to think that the port is still suspended and the resume has failed.
The patch makes uhci_finish_suspend() wait until both bits are safely
off.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
When the last thread of nfsd exits, it shuts down all related sockets.
It currently uses svc_close_socket to do this, but that only is
immediately effective if the socket is not SK_BUSY.
If the socket is busy - i.e. if a request has arrived that has not yet
been processes - svc_close_socket is not effective and the shutdown
process spins.
So create a new svc_force_close_socket which removes the SK_BUSY flag
is set and then calls svc_close_socket.
Also change some open-codes loops in svc_destroy to use
list_for_each_entry_safe.
process-pools have real benefits for NUMA, but on SMP
machines they only work if network interface interrupts
go to all CPUs (via round-robin or multiple nics). This is
not always the case, so disable the pools in this case until
a better solution is developped.
diff .prev/net/sunrpc/svc.c ./net/sunrpc/svc.c
This patch (as850b) disables remote wakeup (and everything else!) on
all EHCI ports when the shutdown() method is called. If remote wakeup
is left active then some systems will reboot instead of powering off.
This fixes Bugzilla #7828.
Tetsuo Handa <handat@pm.nttdata.co.jp> told me that connect(2) with TCPv6
socket almost always took a few minutes to return when we did not have any
ports available in the range of net.ipv4.ip_local_port_range.
The reason was that we used incorrect seed for calculating index of
hash when we check established sockets in __inet6_check_established().
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[MTD] Fix regression in RedBoot partition scanning
This fixes a regression introduced by the attempt to handle RedBoot FIS
tables which are smaller than an eraseblock, in commit
0b47d654089c5ce3f2ea26a4485db9bcead1e515
It moves the recalculation of the number of slots in the table to the
correct place, and improves the heuristic for when we think we need to
byte-swap what we read from the flash.
Cc: Rod Whitby <rod@whitby.id.au>
There is no prompt for STACKTRACE, so it is enabled only when 'select'ed.
FAULT_INJECTION depends on it, while LOCKDEP selects it. So FAULT_INJECTION
becomes visible in Kconfig only when LOCKDEP is enabled.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
The USB vendor and product IDs are not byteswapped appropriately, and
thus come out in the wrong endianness when fetched through the evdev
using ioctl() on big endian platforms.
Signed-off-by: Julien BLACHE <jb@jblache.org>
