1. Remove the check for skb->len greater than MTU when doing TSO.
When the destination has a smaller MSS than the source, a TSO packet
may be smaller than the MTU and we still need to process it as a TSO
packet.
2. On 5705A3 devices with TSO enabled, the DMA engine can hang due to a
hardware bug. This patch avoids the hanging condition by reducing the
DMA burst size.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Wake On Lan works correctly on Yukon-FE and other variants.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
By default, the skge driver now enables wake on magic and wake on PHY.
This is a bad default (bug), wake on PHY means machine will never shutdown
if connected to a switch.
It's not necessarily correct to assume that the xdr_buf used to hold the
server's reply must have page data whenever it has tail data.
And there's no need for us to deal with that case separately anyway.
Acked-by: "J. Bruce Fields" <bfields@citi.umich.edu>
Signed-off-by: Neil Brown <neilb@suse.de>
exports.
We need to zero various parts of 'exp' before any 'goto out', otherwise
when we go to free the contents... we die.
The last zlib_inflate update broke certain corner cases for ppp_deflate
decompression handling. This patch fixes some logic to make things work
properly again. Users other than ppp_deflate (the only Z_PACKET_FLUSH
user) should be unaffected.
Fixes bug 8405 (confirmed by Stefan)
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Cc: Stefan Wenk <stefan.wenk@gmx.at>
SLOB doesn't calculate correct page order when page size is not 4KB. This
patch fixes it with using get_order() instead of find_order() which is SLOB
version of get_order().
Acked-by: Matt Mackall <mpm@selenic.com>
Fixes a deadlock in the OOM killer for allocations that are not
__GFP_HARDWALL.
Before the OOM killer checks for the allocation constraint, it takes
callback_mutex.
constrained_alloc() iterates through each zone in the allocation zonelist
and calls cpuset_zone_allowed_softwall() to determine whether an allocation
for gfp_mask is possible. If a zone's node is not in the OOM-triggering
task's mems_allowed, it is not exiting, and we did not fail on a
__GFP_HARDWALL allocation, cpuset_zone_allowed_softwall() attempts to take
callback_mutex to check the nearest exclusive ancestor of current's cpuset.
This results in deadlock.
We now take callback_mutex after iterating through the zonelist since we
don't need it yet.
Cc: Andi Kleen <ak@suse.de>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Christoph Lameter <clameter@engr.sgi.com>
Cc: Martin J. Bligh <mbligh@mbligh.org>
Signed-off-by: David Rientjes <rientjes@google.com>
Now that do_undefinstr handles kernel and user mode undefined
instruction exceptions it must not assume that interrupts are enabled at
entry.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
For some reason, sata_via is missing PM hooks. Add them. Spotted by
Jeroen Janssen <jeroen.janssen@gmail.com>.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Jeroen Janssen <jeroen.janssen@gmail.com>
packets through NAT
While porting some changes of the 2.6.21-rc7 pptp/proto_gre conntrack
and nat modules to a 2.4.32 kernel I noticed that the gre_key function
returns a wrong pointer to the GRE key of a version 0 packet thus
corrupting the packet payload.
The intended behaviour for GREv0 packets is to act like
nf_conntrack_proto_generic/nf_nat_proto_unknown so I have ripped the
offending functions (not used anymore) and modified the
nf_nat_proto_gre modules to not touch version 0 (non PPTP) packets.
Signed-off-by: Jorge Boncompte <jorge@dti2.net>
build scripts: fixdep blows segfault on string CONFIG_MODULE seen
The string "CONFIG_MODULE" appearing anywhere in a source file causes
fixdep to segfault. This string appeared in the wild in the current
mISDN sources (I think they meant CONFIG_MODULES). But it shouldn't
segfault (esp as CONFIG_MODULE appeared in a quoted string).
Signed-off-by: Andy Green <andy@warmcat.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
PCI devices were being programmed with an incorrect base address value.
This patch moves I/O space into a 16-bit addressable region and corrects
the i/o offset.
Much thanks to Martin Michlmayr for tracking this issue and testing
debug patches.
Cc: Martin Michlmayr <tbm@cyrius.com>
Fix a typo which causes a necessary cpwait to be missed on iop3xx, Michael
Brunner <mibru@gmx.de>
Save a register in the assembly routine, rmk
Cc: Lennert Buytenhek <kernel@wantstofly.org>
If you have a controller with one channel disabled and unmapped the new
iomap code blindly tries to iomap unconfigured BARs. Later on the code
does the right thing and checks for unmapped bars but it is done in the
wrong order
Reorder the checks and make the iomap conditional
Tejun: I think the code below is now correct but would appreciate you
giving it a review.
Signed-off-by: Alan Cox <alan@redhat.com>
Acked-by: Tejun Heo <htejun@gmail.com>
We're getting lockdep warnings due to a post-2.6.21-rc7 bugfix.
The xattr_sem can never be taken in the manner described. Internal inodes
are protected by I_PRIVATE. Add the appropriate annotation.
Cc: <stable@kernel.org>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Takashi Iwai <tiwai@suse.de>
As part of the device initialisation cxacru_atm_start starts
a rearming status polling task, which is cancelled in
cxacru_unbind. Failure to ever start the task means an
infinite loop occurs trying to cancel it.
Possible reasons for not starting the polling task:
* Firmware files missing
* Device initialisation fails
* User unplugs device or unloads module
Effect:
* Infinite loop in khubd trying to add/remove the device (or rmmod if timed right)
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Up through 2.6.20 we cleared the FADT.CSTATE_CONTROL field
for FADT versions before r3, because it made no sense
for that reserved field to be set for pre-ACPI 2.0 systems.
It turns out that not clearing this field exposes
Linux to SMM BIOS failures, so do the same in 2.6.21.
http://bugzilla.kernel.org/show_bug.cgi?id=8346
Signed-off-by: Len Brown <len.brown@intel.com>
the patch below fixes compilation breakage of smc911x driver when ENABLE_SMC_DEBUG_PKTS equals to 1.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
Just found a hole in my last patch. It was reported to me that shortly after we
integrated this patch. The report was of an oops that took place inside of
netif_rx when using the sis900 driver. Looking at my origional patch I noted
that there was a spot between the new skb_alloc and the refill_rx_ring label
where skb got reassigned to the pointer currently held in the rx_ring for the
purposes of receiveing the frame. The result of this is however that the buffer
that gets passed to netif_rx (if it is called), then gets placed right back into
the rx_ring. So if you receive frames fast enough the skb being processed by
the network stack can get corrupted. The reporter is testing out the fix I've
written for this below (I'm not near my hardware at the moment to test myself),
but I wanted to post it for review ASAP. I'll post test results when I hear
them, but I think this is a pretty straightforward fix. It just uses a separate
pointer to do the rx operation, so that we don't improperly reassign the pointer
that we use to refill the rx ring.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
When network device's are renamed, the IPV6 snmp6 code
gets confused. It doesn't track name changes so it will OOPS
when network device's are removed.
The fix is trivial, just unregister/re-register in notify handler.
[IPV6]: Fix thinko in ipv6_rthdr_rcv() changes.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[IPV4] nl_fib_lookup: Initialise res.r before fib_res_put(&res)
When CONFIG_IP_MULTIPLE_TABLES is enabled, the code in nl_fib_lookup()
needs to initialize the res.r field before fib_res_put(&res) - unlike
fib_lookup(), a direct call to ->tb_lookup does not set this field.
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
.. ok, enough waffling about it already. "Just do it!"
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[PARPORT] SUNBPP: Fix OOPS when debugging is enabled.
[SPARC] openprom: Switch to ref counting PCI API
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[NETLINK]: Infinite recursion in netlink.
The packet driver is assuming (reasonably) that the (undocumented)
request.errors is an errno. But it is in fact some mysterious bitfield. When
things go wrong we return weird positive numbers to the VFS as pointers and it
goes oops.
Thanks to William Heimbigner for reporting and diagnosis.
(It doesn't oops, but this driver still doesn't work for William)
Cc: William Heimbigner <icxcnika@mar.tar.cc>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Reply to NETLINK_FIB_LOOKUP messages were misrouted back to kernel,
which resulted in infinite recursion and stack overflow.
The bug is present in all kernel versions since the feature appeared.
The patch also makes some minimal cleanup:
1. Return something consistent (-ENOENT) when fib table is missing
2. Do not crash when queue is empty (does not happen, but yet)
3. Put result of lookup
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
There's a really rare and obscure bug in CFQ, that causes a crash in
cfq_dispatch_insert() due to rq == NULL. One example of the resulting
oops is seen here:
http://lkml.org/lkml/2007/4/15/41
Neil correctly diagnosed the situation for how this can happen: if two
concurrent requests with the exact same sector number (due to direct IO
or aliasing between MD and the raw device access), the alias handling
will add the request to the sortlist, but next_rq remains NULL.
Read the more complete analysis at:
http://lkml.org/lkml/2007/4/25/57
This looks like it requires md to trigger, even though it should
potentially be possible to due with O_DIRECT (at least if you edit the
kernel and doctor some of the unplug calls).
The fix is to move the ->next_rq update to when we add a request to the
rbtree. Then we remove the possibility for a request to exist in the
rbtree code, but not have ->next_rq correctly updated.
Oops, thinko. The test for accempting a RH0 was exatly the wrong way
around.
[BNX2]: Fix occasional NETDEV WATCHDOG on 5709.
[IPV6]: Disallow RH0 by default.
[XFRM]: beet: fix pseudo header length value
[TCP]: Congestion control initialization.
Tweak a register setting to prevent the tx mailbox from halting.
Update version to 1.5.8.
A security issue is emerging. Disallow Routing Header Type 0 by default
as we have been doing for IPv4.
Note: We allow RH2 by default because it is harmless.
This did cause oprofile to fail on non-multithreaded systems with more
than 2 processors such as the BCM1480.
Reported by Manish Lachwani (mlachwani@mvista.com).
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
* 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6:
drivers/net/hamradio/baycom_ser_fdx build fix
usb-net/pegasus: fix pegasus carrier detection
sis900: Allocate rx replacement buffer before rx operation
[netdrvr] depca: handle platform_device_add() failure
sparc64:
drivers/net/hamradio/baycom_ser_fdx.c: In function `ser12_open':
drivers/net/hamradio/baycom_ser_fdx.c:417: error: `NR_IRQS' undeclared (first us
e in this function)
drivers/net/hamradio/baycom_ser_fdx.c:417: error: (Each undeclared identifier is
reported only once
drivers/net/hamradio/baycom_ser_fdx.c:417: error: for each function it appears i
n.)
Cc: Folkert van Heusden <folkert@vanheusden.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Broken by 4a1728a28a193aa388900714bbb1f375e08a6d8e which switched the
return semantics of read_mii_word() but didn't fix usage of
read_mii_word() to conform to the new semantics.
Setting carrier to off based on the NO_CARRIER flag is also incorrect as
that flag only triggers on TX failure and therefore isn't correct when
no frames are being transmitted. Since there is already a 2*HZ MII
carrier check going on, defer to that.
Add a TRUST_LINK_STATUS feature flag for adapters where the LINK_STATUS
flag is actually correct, and use that rather than the NO_CARRIER flag.
Signed-off-by: Dan Williams <dcbw@redhat.com>
The sis900 driver appears to have a bug in which the receive routine
passes the skbuff holding the received frame to the network stack before
refilling the buffer in the rx ring. If a new skbuff cannot be allocated, the
driver simply leaves a hole in the rx ring, which causes the driver to stop
receiving frames and become non-recoverable without an rmmod/insmod according to
reporters. This patch reverses that order, attempting to allocate a replacement
buffer first, and receiving the new frame only if one can be allocated. If no
skbuff can be allocated, the current skbuf in the rx ring is recycled, dropping
the current frame, but keeping the NIC operational.
The following patch fixes a kernel bug in depca_platform_probe().
We don't use a dynamic pointer for pldev->dev.platform_data, so it seems
that the correct way to proceed if platform_device_add(pldev) fails is
to explicitly set the pldev->dev.platform_data pointer to NULL, before
calling the platform_device_put(pldev), or it will be kfree'ed by
platform_device_release().
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6:
[PATCH] i386: Fix some warnings added by earlier patch
[PATCH] x86-64: Always flush all pages in change_page_attr
[PATCH] x86: Remove noreplacement option
[PATCH] x86-64: make GART PTEs uncacheable
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
Revert "adjust legacy IDE resource setting (v2)"
serial8250_interrupt()
Commit 40b36daa introduced possibility that serial8250_backup_timeout() ->
serial8250_handle_port() locks port.lock without disabling irqs, thus
allowing deadlock against interrupt handler (port.lock is acquired in
serial8250_interrupt()).
Spotted by lockdep.
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Alex Williamson <alex.williamson@hp.com>
Add maintainer for fault injection support.
Two functions are called from __devinit context, but they are marked as
__init. Fix this.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
The listxattr() and getxattr() operations are only protected by a read
lock. As a result, if either of these operations run in parallel, a race
condition exists where the xattr_root will end up being cached twice, which
results in the leaking of a reference and a BUG() on umount.
This patch refactors get_xa_root(), __get_xa_root(), and create_xa_root(),
into one get_xa_root() function that takes the appropriate locking around
the entire critical section.
Reported, diagnosed and tested by Andrea Righi <a.righi@cineca.it>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Cc: Andrea Righi <a.righi@cineca.it>
Cc: "Vladimir V. Saveliev" <vs@namesys.com>
Cc: Edward Shishkin <edward@namesys.com>
Cc: Alex Zarochentsev <zam@namesys.com>
On ia64, kernel headers define REGION_OFFSET so we can't use that.
Reported by Andrew Morton.
Acked-by: David Hubbard <david.c.hubbard@gmail.com>
irq values are u32, not u8. Large irq numbers will be truncated,
free_irq may free a different irq.
Remove incorrectly sized struct member and use the one from pci_dev.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
The commit 34f5a39899f3f3e815da64f48ddb72942d86c366 restricted reading
of the tainted value. The attached patch changes this back to a
write-only check and restores the read behaviour of older versions.
Signed-off-by: Bastian Blank <bastian@waldi.eu.org>
Cc: Theodore Ts'o <tytso@mit.edu>
Use relative time, not absolute. Discovered by Jung-Ik (John) Lee
<jilee@google.com>.
Cc: Jung-Ik (John) Lee <jilee@google.com>
Acked-by: Len Brown <lenb@kernel.org>
