Allow in-place crypto operations. Also remove the coherent user flag
(we use it automagically now), and by default use the user written
key rather then the HW hidden key - this makes crypto just work without
any special considerations, and thats OK, since its our only usage
model.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
The function crypto_mod_put first frees the algorithm and then drops
the reference to its module. Unfortunately we read the module pointer
which after freeing the algorithm and that pointer sits inside the
object that we just freed.
So this patch reads the module pointer out before we free the object.
Thanks to Luca Tettamanti for reporting this.
When the PST tables are broken, powernow-k7 uses ACPI's processor_perflib to
deduce the available frequency multipliers from the _PSS tables.
Upon frequency change, processor_perflib performs some verification on the
frequency (checks that it's within allowable bounds).
powernow-k7 deals with absolute frequencies in KHz, whereas perflib only
deals with MHz values. When performing the above verification, perflib
multiplies the MHz values by 1000 to obtain the KHz value.
We then end up with situations like the following:
- powernow-k7 multiplies the multiplier by the FSB, and obtains a value
such as 1266768 KHz
- perflib belives the same state has frequency of 1266 MHz
- acpi_processor_ppc_notifier calls cpufreq_verify_within_limits to verify
that 1266768 is in the allowable range of 0 to 1266000 (i.e. 1266 * 1000)
- it's not, so that frequency is rejected
- the maximum CPU frequency is not reachable
This patch solves the problem by rounding up the MHz values stored in perflib's
tables. Additionally it corrects a broken URL.
It also fixes http://bugzilla.kernel.org/show_bug.cgi?id=8255 although this
case is a bit different: the frequencies in the _PSS tables are wildly wrong,
but we get better results if we force ACPI to respect the fsb * multiplier
calculations (even though it seems that the multiplier values aren't entirely
correct either).
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Signed-off-by: Dave Jones <davej@redhat.com>
Mark Langsdorf points out that the correct define for this
revision bump is 0x80000. Also to save us having to keep
renaming the #define, give it a more meaningful name.
Reported-by: Calvin Dodge <caldodge@gmail.com>
callback invocation
When the helper module is removed for a master connection that has a
fulfilled expectation, but has already timed out and got removed from
the hash tables, nf_conntrack_helper_unregister can't find the master
connection to unset the helper, causing a use-after-free when the
expected connection is destroyed and releases the last reference to
the master.
The helper destroy callback was introduced for the PPtP helper to clean
up expectations and expected connections when the master connection
times out, but doing this from destroy_conntrack only works for
unfulfilled expectations since expected connections hold a reference
to the master, preventing its destruction. Move the destroy callback to
the timeout function, which fixes both problems.
Reported/tested by Gabor Burjan <buga@buvoshetes.hu>.
It's possible for a journal I/O request to be added to the log_redrive
queue and the jfsIO thread to be awakened after the thread releases
log_redrive_lock but before it sets its state to TASK_INTERRUPTIBLE.
The jfsIO thread should set the state before giving up the spinlock, so
the waking thread will really wake it.
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
hiddev_release()
USB HID: hiddev - fix race between hiddev_send_event() and hiddev_release()
There is a small race window in which hiddev_release() could corrupt the
list that is being processed for new event in hiddev_send_event().
Synchronize the operations over this list.
If the device fails during module startup for some reason like unsupported chip
version then the driver would crash dereferencing a null pointer, on shutdown
or suspend/resume.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
If device fails during module startup for some reason (like unsupported chip
version) then driver would crash dereferencing a null pointer, on shutdown
or suspend/resume.
The driver is not ready to support 88e8071 chip, it requires several
more changes (not done yet). If this chip is present, system will hang on boot.
It looks like the problems of Gigabyte 88E8056 are unique to that chip
motherboard and maybe fixable by EEPROM update.
If we miss on the ranges, just toss the translation up to the parent
instead of failing.
Some devices have more than 15 which was the previous
setting.
The 'compatible' property can be SUNW,sun4v-console as
well as 'qcn'.
Use iteration for scanning of PROM node siblings.
Based upon a patch by Greg Onufer, who found this bug.
The function xfrm_policy_byid takes a dir argument but finds the policy
using the index instead. We only use the dir argument to update the
policy count for that direction. Since the user can supply any value
for dir, this can corrupt our policy count.
I know this is the problem because a few days ago I was deleting
policies by hand using indicies and accidentally typed in the wrong
direction. It still deleted the policy and at the time I thought
that was cool. In retrospect it isn't such a good idea :)
I decided against letting it delete the policy anyway just in case
we ever remove the connection between indicies and direction.
SCTP was checking for NULL when trying to detect hmac
allocation failure where it should have been using IS_ERR.
Also, print a rate limited warning to the log telling the
user what happend.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
This fixes an out-of-boundary condition when the classified
band equals q->bands. Caught by Alexey
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
Reverse the sense of the promiscuous-mode tests in ip6_mc_input().
Signed-off-by: Corey Mutter <crm-netdev@mutternet.com>
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
I think this is less critical, but is also suitable for -stable
release.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Because skb->dst is assigned in ip6_route_input(), it is really
bad to use it in hop-by-hop option handler(s).
Closes: Bug #8450 (Eric Sesterhenn <snakebyte@gmx.de>)
When an IPv6 router is forwarding a packet with a link-local scope source
address off-link, RFC 4007 requires it to send an ICMPv6 destination
unreachable with code 2 ("not neighbor"), but Linux doesn't. Fix below.
vgettimeofday() may return some bad timeval values, (tv_usec = 1000000), because of a wrong compare.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Fix a rather obvious error that Patrick found in the setup routines. Need to
set the proper address space in the ACPI case.
Signed-off-by: Corey Minyard <minyard@acm.org>
Cc: Patrick Schoeller <Patrick.Schoeller@hp.com>
Added a missing call to resume mixer controls for STAC92xx codecs.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
connected to mptspi driver
Patch for: http://bugzilla.kernel.org/show_bug.cgi?id=8426
A recent code cleanup that moved code from mptscsih to mptspi inadvertently
change the order some code was called. This caused a massive slowdown (of
150x to 300x) on the CD/DVD drive on the high-end HP Integrity servers.
Signed-off-by: Doug Chapman <doug.chapman@hp.com>
Cc: <Eric.Moore@lsil.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
MSI doesn't work on RS400-200 and RS480 requiring pci=nomsi kernel boot
parameter for ahci to work. This patch renames quirk_svw_msi() to
quirk_disable_all_msi() and use it to disable MSI on those chips.
http://thread.gmane.org/gmane.linux.ide/17820
http://thread.gmane.org/gmane.linux.ide/17516
https://bugzilla.novell.com/show_bug.cgi?id=263893
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Matí-as Alejandro Torres <torresmat@gmail.com>
Cc: Greg K-H <greg@kroah.com>
Cc: Jeff Garzik <jeff@garzik.org>
Currently, devt_attr for the "dev" file is freed immediately on device
removal, but if the "dev" sysfs file is open when a device is removed,
sysfs will access its attribute structure for further access including
close resulting in jumping to garbled address. Fix it by postponing
freeing devt_attr to device release time.
Note that devt_attr for class_device is already freed on release.
This bug is reported by Chris Rankin as bugzilla bug#8198.
Cc: Chris Rankin <rankincj@yahoo.com>
through md/raid1 to a filesystem.
When a raid1 has only one working drive, we want read error to
propagate up to the filesystem as there is no point failing the last
drive in an array.
Currently the code perform this check is racy. If a write and a read
a both submitted to a device on a 2-drive raid1, and the write fails
followed by the read failing, the read will see that there is only one
working drive and will pass the failure up, even though the one
working drive is actually the *other* one.
So, tighten up the locking.
Signed-off-by: Neil Brown <neilb@suse.de>
We need to make sure that the clocksources are resumed, when timekeeping is
resumed. The current resume logic does not guarantee this.
Add a resume function pointer to the clocksource struct, so clocksource
drivers which need to reinitialize the clocksource can provide a resume
function.
Add a resume function, which calls the maybe available clocksource resume
functions and resets the watchdog function, so a stable TSC can be used
accross suspend/resume.
Cc: john stultz <johnstul@us.ibm.com>
Cc: Andi Kleen <ak@suse.de>
The internal hugetlb resv_huge_pages variable can permanently leak nonzero
value in the error path of hugetlb page fault handler when hugetlb page is
used in combination of cpuset. The leaked count can permanently trap N
number of hugetlb pages in unusable "reserved" state.
Steps to reproduce the bug:
(1) create two cpuset, user1 and user2
(2) reserve 50 htlb pages in cpuset user1
(3) attempt to shmget/shmat 50 htlb page inside cpuset user2
(4) kernel oom the user process in step 3
(5) ipcrm the shm segment
At this point resv_huge_pages will have a count of 49, even though
there are no active hugetlbfs file nor hugetlb shared memory segment
in the system. The leak is permanent and there is no recovery method
other than system reboot. The leaked count will hold up all future use
of that many htlb pages in all cpusets.
The culprit is that the error path of alloc_huge_page() did not
properly undo the change it made to resv_huge_page, causing
inconsistent state.
Signed-off-by: Ken Chen <kenchen@google.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
Cc: Adam Litke <agl@us.ibm.com>
Cc: Martin Bligh <mbligh@google.com>
Acked-by: David Gibson <dwg@au1.ibm.com>
When the server drops its connection, NFS client reconnects using the
same socket after disconnecting. If the new connection's SYN,ACK
doesn't contain the TCP timestamp option and the old connection's did,
tp->tcp_header_len is recomputed assuming no timestamp header but
tp->rx_opt.tstamp_ok remains set. Then tcp_build_and_update_options()
adds in a timestamp option past the end of the allocated TCP header,
overwriting TCP data, or when the data is in skb_shinfo(skb)->frags[],
overwriting skb_shinfo(skb) causing a crash soon after. (The issue was
debugged from such a crash.)
Similarly, wscale_ok and sack_ok also get set based on the SYN,ACK
packet but not reset on disconnect, since they are zeroed out at
initialization. The patch zeroes out the entire tp->rx_opt struct in
tcp_disconnect() to avoid this sort of problem.
Signed-off-by: Srinivas Aji <Aji_Srinivas@emc.com>
I broke the non-wildcard case recently. This is to fixes it.
Now, explictitly bound addresses can ge retrieved using the API.
sctp_getsockopt_local_addrs_old() in net/sctp/socket.c calls
copy_to_user() while the spinlock addr_lock is held. this should not
be done as copy_to_user() might sleep. the call to
sctp_copy_laddrs_to_user() while holding the lock is also problematic
as it calls copy_to_user()
Get rid of the CONFIG_NETPOLL_RX option completely since all the
dependencies have been removed long ago...
Acked-by: Jeff Garzik <jgarzik@pobox.com>
Acked-by: Matt Mackall <mpm@selenic.com>
CONFIG_NETPOLL_TRAP causes the TX queue controls to be completely bypassed in
the netpoll's "trapped" mode which easily causes overflows in the drivers with
short TX queues (most notably, in 8139too with its 4-deep queue). So, make
this option more sensible by making it only bypass the TX softirq wakeup.
Acked-by: Tom Rini <trini@kernel.crashing.org>
It appears that a minor thinko occurred in udf_rmdir and the
(already-cleared) link count on the directory that is being removed was
being decremented instead of the link count on its parent directory. This
gives rise to lots of kernel messages similar to:
UDF-fs warning (device loop1): udf_rmdir: empty directory has nlink != 2 (8)
when removing directory trees. No other ill effects have been observed but
I guess it could theoretically result in the link count overflowing on a
very long-lived, much modified directory.
Signed-off-by: Stephen Mollett <molletts@yahoo.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Jan Kara <jack@ucw.cz>
If you compile and run the below test case in an msdos or vfat directory on
an x86-64 system with -m32 you'll get garbage in the kernel_dirent struct
followed by a SIGSEGV.
The patch fixes this.
Reported and initial fix by Bart Oldeman
#include <sys/types.h>
#include <sys/ioctl.h>
#include <dirent.h>
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
struct kernel_dirent {
long d_ino;
long d_off;
unsigned short d_reclen;
char d_name[256]; /* We must not include limits.h! */
#define VFAT_IOCTL_READDIR_BOTH _IOR('r', 1, struct kernel_dirent [2])
#define VFAT_IOCTL_READDIR_SHORT _IOR('r', 2, struct kernel_dirent [2])
int main(void)
int fd = open(".", O_RDONLY);
struct kernel_dirent de[2];
while (1) {
int i = ioctl(fd, VFAT_IOCTL_READDIR_BOTH, (long)de);
if (i == -1) break;
if (de[0].d_reclen == 0) break;
printf("SFN: reclen=%2d off=%d ino=%d, %-12s",
de[0].d_reclen, de[0].d_off, de[0].d_ino, de[0].d_name);
if (de[1].d_reclen)
printf("\tLFN: reclen=%2d off=%d ino=%d, %s",
de[1].d_reclen, de[1].d_off, de[1].d_ino, de[1].d_name);
printf("\n");
return 0;
Signed-off-by: Bart Oldeman <bartoldeman@users.sourceforge.net>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
While the !highres/!dyntick code assigns the duty of the do_timer() call to
one specific CPU, this was dropped in the highres/dyntick part during
development.
Steven Rostedt discovered the xtime lock contention on highres/dyntick due
to several CPUs trying to update jiffies.
Add the single CPU assignement back. In the dyntick case this needs to be
handled carefully, as the CPU which has the do_timer() duty must drop the
assignement and let it be grabbed by another CPU, which is active.
Otherwise the do_timer() calls would not happen during the long sleep.
Acked-by: Mark Lord <mlord@pobox.com>
Update version to 1.5.8.1.
Signed-off-by: Michael Chan <mchan@broadcom.com>
This is needed to save the MSI state which will be lost during
suspend.
The device may be in D3hot state and should not allow MII register
access.
Remove the check for skb->len greater than MTU when doing TSO. When
the destination has a smaller MSS than the source, a TSO packet may
be smaller than the MTU at the source and we still need to process it
as a TSO packet.
Thanks to Brian Ristuccia <bristuccia@starentnetworks.com> for
reporting the problem.
Update version to 3.75.1.
The reset was added a while back so that ASF could re-init whatever
MAC address it wanted to use after the MAC address was changed.
Instead of resetting, we can just keep MAC address 1 unchanged during
MAC address changes if MAC address 1 is different from MAC address 0.
This fixes 2 problems:
1. Bonding calls set_mac_address in contexts that cannot sleep.
It no longer sleeps with the chip reset removed.
2. When ASF shares the same MAC address as the NIC, it needs to
always do that even when the MAC address is changed.
