port of 3f7086978fc0193eff24a77d8b57ac4debc088fa from mainline.
A crash upon booting that is caused by bcm43xx has been reported [1] and
found to be due to a work queue being reinitialized while work on that
queue is still pending. This fix modifies the shutdown of work queues and
prevents periodic work from being requeued during shutdown. With this patch,
no more crashes on reboot were observed by the original reporter. I do not
get that particular failure on my system; however, when running a large
number of ifdown/ifup sequences, my system would kernel panic with the
'caps lock' light blinking at roughly a 1 Hz rate. In addition, there were
infrequent failures in the firmware that resulted in 'IRQ READY TIMEOUT'
errors. With this patch, no more of the first type of failure occur, and
incidence of the second type is greatly reduced.
[1] http://bugzilla.kernel.org/show_bug.cgi?id=8937
Acked-by: Michael Buesch <mb@bu3sch.de>
commit 2cc7345ff71b27b5ac99e49ad7de39360042f601 in mainline
Subject: [PATCH] [SPARC64]: Fix booting on V100 systems.
On the root PCI bus, the OBP device tree lists device 3 twice.
Once as 'pm' and once as 'lomp'.
Everything goes downhill from there.
Ignore the second instance to workaround this.
Thanks to Kövedi_Krisztián for the bug report and
testing the fix.
commit ce5d0b47f13f83dfb9fbb8ac91adad7120747aaf in mainline
Subject: [PATCH] [PKTGEN]: srcmac fix
commit ef8aef55ce61fd0e2af798695f7386ac756ae1e7 in mainline
Subject: [PATCH] [NET]: Do not dereference iov if length is zero
When msg_iovlen is zero we shouldn't try to dereference
msg_iov. Right now the only thing that tries to do so
is skb_copy_and_csum_datagram_iovec. Since the total
length should also be zero if msg_iovlen is zero, it's
sufficient to check the total length there and simply
return if it's zero.
commit 49ff4bb4cd4c04acf8f9e3d3ec2148305a1db445 in mainline.
[TCP]: DSACK signals data receival, be conservative
In case a DSACK is received, it's better to lower cwnd as it's
a sign of data receival.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
commit 6ee8009e38006da81d2a53da1aaa27365552553e in mainline
Subject: [PATCH 1/1] [TCP]: Also handle snd_una changes in tcp_cwnd_down
tcp_cwnd_down must check for it too as it should be conservative
in case of collapse stuff and also when receiver is trying to
lie (though it wouldn't be successful anyway).
Note:
- Separated also is_dupack and do_lost in fast_retransalert
* Much cleaner look-and-feel now
* This time it really fixes cumulative ACK + many new
SACK blocks recovery entry (I claimed this fixes with
last patch but it wasn't). TCP will now call
tcp_update_scoreboard regardless of is_dupack when
in recovery as long as there is enough fackets_out.
- Introduce FLAG_SND_UNA_ADVANCED
* Some prior_snd_una arguments are unnecessary after it
- Added helper FLAG_ANY_PROGRESS to avoid long FLAG...|FLAG...
constructs
This is a reduced version of a mainline patch.
commit 09d74cdd88a59a18f2ad7cfa0b6045ed1817b632 in mainline.
Subject: [PATCH] [KBUILD]: Sanitize tc_ematch headers.
The headers in tc_ematch are used by iproute2, so these headers should
be processed.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
commit 8c7b43a2e58baa24002fa2b266d9a5007bc52a40 in mainline
I tried to preserve bridging code as it was before, but logic is quite
strange - I think we should free skb on error, since it is already
unshared and thus will just leak.
Herbert Xu states:
> + if ((skb = skb_share_check(skb, GFP_ATOMIC)) == NULL)
> + goto out;
If this happens it'll be a double-free on skb since we'll
return NF_DROP which makes the caller free it too.
We could return NF_STOLEN to prevent that but I'm not sure
whether that's correct netfilter semantics. Patrick, could
you please make a call on this?
Patrick McHardy states:
NF_STOLEN should work fine here.
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
commit 6ae5f983cf8de769214d2d9e8a783c881eccd4cd in mainline
The commit 95c385 broke proper source address selection for cases in which
there is a address which is makred 'deprecated'. The commit mistakenly
changed ifa->flags to ifa_result->flags (probably copy/paste error from a
few lines above) in the 'Rule 3' address selection code.
The patch restores the previous RFC-compliant behavior.
commit 9e3be4b34364a670bd6e57d2e8c3caabdd8d89f8 in mainline
addrconf_dad_failure calls addrconf_dad_stop which takes referenced address
and drops the count. So, in6_ifa_put perrformed at out: is extra. This
results in message: "Freeing alive inet6 address" and not released dst entries.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
commit 3ef9d943d26dea764f4fecf3767001c90b778b0c in mainline
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
commit 8ee4f391831cb96916a8e8a05f04b1c1d7dd30d8 in mainline.
In testing our ESP/AH offload hardware, I discovered an issue with how
AH handles mutable fields in IPv4. RFC 4302 (AH) states the following
on the subject:
For IPv4, the entire option is viewed as a unit; so even
though the type and length fields within most options are immutable
in transit, if an option is classified as mutable, the entire option
is zeroed for ICV computation purposes.
The current implementation does not zero the type and length fields,
resulting in authentication failures when communicating with hosts
that do (i.e. FreeBSD).
I have tested record route and timestamp options (ping -R and ping -T)
on a small network involving Windows XP, FreeBSD 6.2, and Linux hosts,
with one router. In the presence of these options, the FreeBSD and
Linux hosts (with the patch or with the hardware) can communicate.
The Windows XP host simply fails to accept these packets with or
without the patch.
I have also been trying to test source routing options (using
traceroute -g), but haven't had much luck getting this option to work
*without* AH, let alone with.
Signed-off-by: Nick Bowler <nbowler@ellipticsemi.com>
commit e1f52208bb968291f7d9142eff60b62984b4a511 in mainline.
[IPv6]: Fix NULL pointer dereference in ip6_flush_pending_frames
Some of skbs in sk->write_queue do not have skb->dst because
we do not fill skb->dst when we allocate new skb in append_data().
BTW, I think we may not need to (or we should not) increment some stats
when using corking; if 100 sendmsg() (with MSG_MORE) result in 2 packets,
how many should we increment?
If 100, we should set skb->dst for every queued skbs.
If 1 (or 2 (*)), we increment the stats for the first queued skb and
we should just skip incrementing OutDiscards for the rest of queued skbs,
adn we should also impelement this semantics in other places;
e.g., we should increment other stats just once, not 100 times.
*: depends on the place we are discarding the datagram.
I guess should just increment by 1 (or 2).
commit 0a9c73014415d2a84dac346c1e12169142a6ad37 in mainline
[INET_DIAG]: Fix oops in netlink_rcv_skb
netlink_run_queue() doesn't handle multiple processes processing the
queue concurrently. Serialize queue processing in inet_diag to fix
a oops in netlink_rcv_skb caused by netlink_run_queue passing a
NULL for the skb.
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000054
[349587.500454] printing eip:
[349587.500457] c03318ae
[349587.500459] *pde = 00000000
[349587.500464] Oops: 0000 [#1]
[349587.500466] PREEMPT SMP
[349587.500474] Modules linked in: w83627hf hwmon_vid i2c_isa
[349587.500483] CPU: 0
[349587.500485] EIP: 0060:[<c03318ae>] Not tainted VLI
[349587.500487] EFLAGS: 00010246 (2.6.22.3 #1)
[349587.500499] EIP is at netlink_rcv_skb+0xa/0x7e
[349587.500506] eax: 00000000 ebx: 00000000 ecx: c148d2a0 edx: c0398819
[349587.500510] esi: 00000000 edi: c0398819 ebp: c7a21c8c esp: c7a21c80
[349587.500517] ds: 007b es: 007b fs: 00d8 gs: 0033 ss: 0068
[349587.500521] Process oidentd (pid: 17943, ti=c7a20000 task=cee231c0 task.ti=c7a20000)
[349587.500527] Stack: 00000000 c7a21cac f7c8ba78 c7a21ca4 c0331962 c0398819 f7c8ba00 0000004c
[349587.500542] f736f000 c7a21cb4 c03988e3 00000001 f7c8ba00 c7a21cc4 c03312a5 0000004c
[349587.500558] f7c8ba00 c7a21cd4 c0330681 f7c8ba00 e4695280 c7a21d00 c03307c6 7fffffff
[349587.500578] Call Trace:
[349587.500581] [<c010361a>] show_trace_log_lvl+0x1c/0x33
[349587.500591] [<c01036d4>] show_stack_log_lvl+0x8d/0xaa
[349587.500595] [<c010390e>] show_registers+0x1cb/0x321
[349587.500604] [<c0103bff>] die+0x112/0x1e1
[349587.500607] [<c01132d2>] do_page_fault+0x229/0x565
[349587.500618] [<c03c8d3a>] error_code+0x72/0x78
[349587.500625] [<c0331962>] netlink_run_queue+0x40/0x76
[349587.500632] [<c03988e3>] inet_diag_rcv+0x1f/0x2c
[349587.500639] [<c03312a5>] netlink_data_ready+0x57/0x59
[349587.500643] [<c0330681>] netlink_sendskb+0x24/0x45
[349587.500651] [<c03307c6>] netlink_unicast+0x100/0x116
[349587.500656] [<c0330f83>] netlink_sendmsg+0x1c2/0x280
[349587.500664] [<c02fcce9>] sock_sendmsg+0xba/0xd5
[349587.500671] [<c02fe4d1>] sys_sendmsg+0x17b/0x1e8
[349587.500676] [<c02fe92d>] sys_socketcall+0x230/0x24d
[349587.500684] [<c01028d2>] syscall_call+0x7/0xb
[349587.500691] =======================
[349587.500693] Code: f0 ff 4e 18 0f 94 c0 84 c0 0f 84 66 ff ff ff 89 f0 e8 86 e2 fc ff e9 5a ff ff ff f0 ff 40 10 eb be 55 89 e5 57 89 d7 56 89 c6 53 <8b> 50 54 83 fa 10 72 55 8b 9e 9c 00 00 00 31 c9 8b 03 83 f8 0f
Reported by Athanasius <link@miggy.org>
commit 596e41509550447b030f7b16adaeb0138ab585a8 in mainline
Bug: http://bugzilla.kernel.org/show_bug.cgi?id=8876
Not all ips are shown by "ip addr show" command when IPs number assigned to an
interface is more than 60-80 (in fact it depends on broadcast/label etc
presence on each address).
Steps to reproduce:
It's terribly simple to reproduce:
# for i in $(seq 1 100); do ip ad add 10.0.$i.1/24 dev eth10 ; done
# ip addr show
this will _not_ show all IPs.
Looks like the problem is in netlink/ipv4 message processing.
This is fix from bug submitter, it looks correct.
commit a2221f308dabb95abb914ad858d36c2462705558 in mainline.
Not all are listed, same as the IPV4 devinet bug.
commit ba685fb2abd71162bea6895a99449c1071b01402 in mainline.
As noticed by Chuck Ebbert, commit c5e3ae8823693b260ce1f217adca8add1bc0b3de
introduced a copy-paste typo, as realtek phy is 0x732 and not 0x1c1. Obvious
fix below suggested by Ayaz Abdulla.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Cc: Ayaz Abdulla <aabdulla@nvidia.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
This corresponds to upstream changesets
e4630f9fd8cdc14eb1caa08dafe649eb5ae09985 and
32528d0fbda1093eeeaa7d0a2c498bbb5154099d.
[CRYPTO] blkcipher: Fix handling of kmalloc page straddling
The function blkcipher_get_spot tries to return a buffer of
the specified length that does not straddle a page. It has
an off-by-one bug so it may advance a page unnecessarily.
What's worse, one of its callers doesn't provide a buffer
that's sufficiently long for this operation.
This patch fixes both problems. Thanks to Bob Gilligan for
diagnosing this problem and providing a fix.
The commit in Linus upstream git tree is
f3da54ba140c6427fa4a32913e1bf406f41b5dda.
Fix race with shared tag queue maps
There's a race condition in blk_queue_end_tag() for shared tag maps,
users include stex (promise supertrak thingy) and qla2xxx. The former
at least has reported bugs in this area, not sure why we haven't seen
any for the latter. It could be because the window is narrow and that
other conditions in the qla2xxx code hide this. It's a real bug,
though, as the stex smp users can attest.
We need to ensure two things - the tag bit clearing needs to happen
AFTER we cleared the tag pointer, as the tag bit clearing/setting is
what protects this map. Secondly, we need to ensure that the visibility
of the tag pointer and tag bit clear are ordered properly.
[ I removed the SMP barriers - "test_and_clear_bit()" already implies
all the required barriers. -- Linus ]
Also see http://bugzilla.kernel.org/show_bug.cgi?id=7842
commit 7a1fa065a0264f6b3d3003ba5635289f6583c478 in mainline.
Commit aaf68cfbf2241d24d46583423f6bff5c47e088b3 added a bias
to sk_inuse, so this test for an unused socket now fails. So no
sockets get closed because they are old (they might get closed
if the client closed them).
This bug has existed since 2.6.21-rc1.
Thanks to Wolfgang Walter for finding and reporting the bug.
Cc: Wolfgang Walter <wolfgang.walter@studentenwerk.mhn.de>
Signed-off-by: Neil Brown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Initialization of ohci1394 was broken according to one reporter if the
driver was statically linked, i.e. not built as loadable module. Dmesg:
PCI: Device 0000:02:07.0 not available because of resource collisions
ohci1394: Failed to enable OHCI hardware.
This was reported for a Toshiba Satellite 5100-503. The cause is commit
8df4083c5291b3647e0381d3c69ab2196f5dd3b7 in Linux 2.6.19-rc1 which only
served purposes of early remote debugging via FireWire. This
functionality is better provided by the currently out-of-tree driver
ohci1394_earlyinit. Reversal of the commit was OK'd by Andi Kleen.
Same as pre-2.6.23 commit be7963b7e7f08a149e247c0bf29a4abd174e0929.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit 3d82abae9523c33d4a16fdfdfd2bdde316d7b56a in mainline.
Convert asserts (BUGs) in dx_probe from bad on-disk data to recoverable
errors with helpful warnings. With help catching other asserts from Duane
Griffin <duaneg@dghda.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Acked-by: Duane Griffin <duaneg@dghda.com>
Acked-by: Theodore Ts'o <tytso@mit.edu>
commit 49af7ee181f4f516ac99eba85d3f70ed42cabe76 in mainline.
NFS unregisters sysctls only if V4 support is compiled in. However, sysctl
table is not V4 specific, so unregister it always.
Steps to reproduce:
[build nfs.ko with CONFIG_NFS_V4=n]
modrobe nfs
rmmod nfs
ls /proc/sys
Unable to handle kernel paging request at ffffffff880661c0 RIP:
[<ffffffff802af8e3>] proc_sys_readdir+0xd3/0x350
PGD 203067 PUD 207063 PMD 7e216067 PTE 0
Oops: 0000 [1] SMP
CPU 1
Modules linked in: lockd nfs_acl sunrpc
Pid: 3335, comm: ls Not tainted 2.6.23-rc3-bloat #2
RIP: 0010:[<ffffffff802af8e3>] [<ffffffff802af8e3>] proc_sys_readdir+0xd3/0x350
RSP: 0018:ffff81007fd93e78 EFLAGS: 00010286
RAX: ffffffff880661c0 RBX: ffffffff80466370 RCX: ffffffff880661c0
RDX: 00000000000014c0 RSI: ffff81007f3ad020 RDI: ffff81007efd8b40
RBP: 0000000000000018 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: ffffffff802a8570 R12: ffffffff880661c0
R13: ffff81007e219640 R14: ffff81007efd8b40 R15: ffff81007ded7280
FS: 00002ba25ef03060(0000) GS:ffff81007ff81258(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffffffff880661c0 CR3: 000000007dfaf000 CR4: 00000000000006e0
Process ls (pid: 3335, threadinfo ffff81007fd92000, task ffff81007d8a0000)
Stack: ffff81007f3ad150 ffffffff80283f30 ffff81007fd93f48 ffff81007efd8b40
ffff81007ee00440 0000000422222222 0000000200035593 ffffffff88037e9a
2222222222222222 ffffffff80466500 ffff81007e416400 ffff81007e219640
Call Trace:
[<ffffffff80283f30>] filldir+0x0/0xf0
[<ffffffff802840c7>] vfs_readdir+0xa7/0xc0
[<ffffffff80284376>] sys_getdents+0x96/0xe0
[<ffffffff8020bb3e>] system_call+0x7e/0x83
Code: 41 8b 14 24 85 d2 74 dc 49 8b 44 24 08 48 85 c0 74 e7 49 3b
RIP [<ffffffff802af8e3>] proc_sys_readdir+0xd3/0x350
RSP <ffff81007fd93e78>
Kernel panic - not syncing: Fatal exception
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
commit ef2b02d3e617cb0400eedf2668f86215e1b0e6af in mainline.
The do_split() function for htree dir blocks is intended to split a leaf
block to make room for a new entry. It sorts the entries in the original
block by hash value, then moves the last half of the entries to the new
block - without accounting for how much space this actually moves. (IOW,
it moves half of the entry *count* not half of the entry *space*). If by
chance we have both large & small entries, and we move only the smallest
entries, and we have a large new entry to insert, we may not have created
enough space for it.
The patch below stores each record size when calculating the dx_map, and
then walks the hash-sorted dx_map, calculating how many entries must be
moved to more evenly split the existing entries between the old block and
the new block, guaranteeing enough space for the new entry.
The dx_map "offs" member is reduced to u16 so that the overall map size
does not change - it is temporarily stored at the end of the new block, and
if it grows too large it may be overwritten. By making offs and size both
u16, we won't grow the map size.
Also add a few comments to the functions involved.
This fixes the testcase reported by hooanon05@yahoo.co.jp on the
linux-ext4 list, "ext3 dir_index causes an error"
Thanks to Andreas Dilger for discussing the problem & solution with me.
Signed-off-by: Andreas Dilger <adilger@clusterfs.com>
Tested-by: Junjiro Okajima <hooanon05@yahoo.co.jp>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: ext4 <linux-ext4@vger.kernel.org>
commit 0e2f6db88a6900bc9db576d6b478b12ee60d61f7 in mainline.
The inode->i_flock list contains the leases, flocks and posix
locks in the specified order. However, the flocks are added in
the head of this list thus hiding the leases from F_GETLEASE
command, from time_out_leases() and other code that expects
the leases to come first.
The following example will demonstrate this:
#define _GNU_SOURCE
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
#include <sys/file.h>
static void show_lease(int fd)
int res;
res = fcntl(fd, F_GETLEASE);
switch (res) {
case F_RDLCK:
printf("Read lease\n");
break;
case F_WRLCK:
printf("Write lease\n");
break;
case F_UNLCK:
printf("No leases\n");
break;
default:
printf("Some shit\n");
break;
int main(int argc, char **argv)
int fd, res;
fd = open(argv[1], O_RDONLY);
if (fd == -1) {
perror("Can't open file");
return 1;
res = fcntl(fd, F_SETLEASE, F_WRLCK);
if (res == -1) {
perror("Can't set lease");
return 1;
show_lease(fd);
if (flock(fd, LOCK_SH) == -1) {
perror("Can't flock shared");
return 1;
show_lease(fd);
return 0;
The first call to show_lease() will show the write lease set, but
the second will show no leases.
Fix the flock adding so that the leases always stay in the head
of this list.
Found during making the flocks pid-namespaces aware.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
commit 179c85ea53bef807621f335767e41e23f86f01df in mainline.
The futex list traversal on the compat side appears to have
a bug.
It's loop termination condition compares:
while (compat_ptr(uentry) != &head->list)
But that can't be right because "uentry" has the special
"pi" indicator bit still potentially set at bit 0. This
is cleared by fetch_robust_entry() into the "entry"
return value.
What this seems to mean is that the list won't terminate
when list iteration gets back to the the head. And we'll
also process the list head like a normal entry, which could
cause all kinds of problems.
So we should check for equality with "entry". That pointer
is of the non-compat type so we have to do a little casting
to keep the compiler and sparse happy.
The same problem can in theory occur with the 'pending'
variable, although that has not been reported from users
so far.
Based on the original patch from David Miller.
regression)
Minor regression since 2.6.22-rc1: If the experimental firewire-ohci
driver instead of ohci1394 was loaded, iBook G3 and older PowerBooks
refused to suspend.
Same as commit 5511142870046a7bed947d51ec9b320856ee120a plus format
string touch-ups from 8a8cea2734808522f02941ea16125810ee42c9c7,
"firewire: missing newline in printk". Original patch description:
Fixes (papers over) "Sleep problems with kernels >= 2.6.21 on powerpc",
http://lkml.org/lkml/2007/8/25/155. The issue is that the FireWire
controller's pci_dev.current_state of iBook G3 and presumably older
PowerBooks is still in PCI_UNKNOWN instead of PCI_D0 when the firewire
driver's .suspend method is called.
Like it was suggested earlier in http://lkml.org/lkml/2006/10/24/13, we
do not fail .suspend anymore if pci_set_power_state failed.
commit 3558c9b3232b5f0fd9f32043a191eca20fca64c6 in mainline.
sparc32:
drivers/block/DAC960.c: In function 'DAC960_V1_EnableMemoryMailboxInterface':
drivers/block/DAC960.c:1168: error: 'DMA_32BIT_MASK' undeclared (first use in this function)
drivers/block/DAC960.c:1168: error: (Each undeclared identifier is reported only
Cc: <dac@conglom-o.org>
Cc: Alessandro Polverini <alex@nibbles.it>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Matthew Wilcox <matthew@wil.cx>
commit 868047fcbb85dbb44ddd98c336fef83236a2c06a in mainline.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=8942
Use PCI_DMA_* constants instead of own private definitions Fall back to
32-bit DMA mask if a 64-bit one fails
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Acked-by: Jeff Garzik <jeff@garzik.org>
Tested-by: Lars <polynomial-c@gmx.de>
commit 1a1a1a758bf0107d1f78ff1d622f45987803d894 in mainline.
dput must be called before mntput here.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Acked-By: David Howells <dhowells@redhat.com>
commit e42601973b1bce1d2987f82159c1ebeaccc6b310 in mainline.
There is still some confusion and disagreement over what this interface should
actually do. So it is best that we disable it in 2.6.23 until we get that
fully sorted out.
(sys_timerfd() was present in 2.6.22 but it was apparently broken, so here we
assume that nobody is using it yet).
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Cc: Davide Libenzi <davidel@xmailserver.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 9db619e66503494e41159de3c76fafabe80d016b in mainline.
we upgraded the kernel of a nfs-server from 2.6.17.11 to 2.6.22.6. Since
then we get the message
lockd: too many open TCP sockets, consider increasing the number of nfsd threads
lockd: last TCP connect from ^\\236^\É^D
These random characters in the second line are caused by a bug in
svc_tcp_accept.
(Note: there are two previous __svc_print_addr(sin, buf, sizeof(buf))
calls in this function, either of which would initialize buf correctly;
but both are inside "if"'s and are not necessarily executed. This is
less obvious in the second case, which is inside a dprintk(), which is a
macro which expands to an if statement.)
Signed-off-by: Wolfgang Walter <wolfgang.walter@studentenwerk.mhn.de>
This is a splice patch for 2.6.22 and 2.6.21 (and earlier, I did not
check. Let me know if you still maintain older stable trees!). It fixes
an infinite loop in do_splice_direct(), when there's either nothing to
read or nothing to write and blocking doesn't help. It could be things
like running out of disk space. We need to exit both for failure and
zero return, or we could be going around forever.
This got fixed in 2.6.23-git with commit 51a92c0f6ce8fa85fa0e18ecda1d847e606e8066
Herbert Poetzl <herbert@13thfloor.at> noticed this bug in 2.6.22, and
has verified that this minimal fix works.
Commit 85237f202d46d55c1bffe0c5b1aa3ddc0f1dce4d introduced the
following warning:
drivers/media/video/pwc/pwc-if.c: In function "pwc_video_close":
drivers/media/video/pwc/pwc-if.c:1211: warning: "i" may be used uninitialized in this function
This is true, and can cause a broken debug message to be logged.
Here's a fix.
Fix is already in Linus' tree for 2.6.23:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=7b9fbc3e30f785412a26819aa4daf0b6c27f6c53
Fix an off-by-one error in the I/O region declaration of two
hardware monitoring drivers (lm78 and w83781d.) We were requesting
one extra port at the end of the region.
This is a regression in 2.6.22 and could prevent other drivers from
loading properly.
Already applied to Linus' tree for 2.6.23:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=15bde2f1a8e819213f54314505a5a0509673109b
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
(cherry picked from commit 48200baeab95fd39a7f4c4f3536c7142a64ac335)
[PATCH] V4L: cx88: Avoid a NULL pointer dereference during mpeg_open()
Bug: With a hardware encoder board installed as cx88[1] and a
non-encoder boards installed as cx88[0], an OOPS is generated
during cx8802_get_device() called from mpeg_open().
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Changeset fc0e01974ccccc7530b7634a63ee3fcc57b845ea from mainline.
I've bisected the deadlock when many small appends are done on jffs2 down to
this commit:
commit 6fe6900e1e5b6fa9e5c59aa5061f244fe3f467e2
Author: Nick Piggin <npiggin@suse.de>
Date: Sun May 6 14:49:04 2007 -0700
mm: make read_cache_page synchronous
Ensure pages are uptodate after returning from read_cache_page, which allows
us to cut out most of the filesystem-internal PageUptodate calls.
I didn't have a great look down the call chains, but this appears to fixes 7
possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in
ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in
block2mtd. All depending on whether the filler is async and/or can return
with a !uptodate page.
It introduced a wait to read_cache_page, as well as a
read_cache_page_async function equivalent to the old read_cache_page
without any callers.
Switching jffs2_gc_fetch_page to read_cache_page_async for the old
behavior makes the deadlocks go away, but maybe reintroduces the
use-before-uptodate problem? I don't understand the mm/fs interaction
well enough to say.
[It's fine. dwmw2.]
Signed-off-by: Jason Lunz <lunz@falooley.org>
changeset 48440e893d700fb8f0de95fa7d748b711d290365 from mainline.
Initialise s_flags in get_sb_mtd_aux() from the flags parameter.
Cc: Jason Lunz <lunz@falooley.org>
[SCSI] 3w-9xxx: Fix dma mask setting
Extracted from commit 0e78d158b67fba3977f577f293c323359d80dd0e
The attached patch updates the 3ware 9000 driver:
- Fix dma mask setting to fallback to 32-bit if 64-bit fails.
Signed-off-by: Adam Radford <linuxraid@amcc.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
commit 0ee6c15e7ba7b36a217cdadb292eeaf32a057a59 in mainline.
When we flush register state for FP, Altivec, or SPE in flush_*_to_thread
we need to respect the task_struct that the caller has passed to us.
Most cases we are called with current, however sometimes (ptrace) we may
be passed a different task_struct.
This showed up when using gdbserver debugging a simple program that used
floating point. When gdb tried to show the FP regs they all showed up as
0, because the child's FP registers were never properly flushed to memory.
commit 9f3119b70cf189530f1b46a006a052e171a1622f in mainline.
ACPI 1.0 used an RSDT with 32-bit physical addresses.
ACPI 2.0 adds an XSDT with 32-bit physical addresses.
An ACPI 2.0 aware OS is supposed to use the XSDT
(when present) instead of the RSDT.
However, several systems have failed because the XSDT
contains NULL entries -- while it is missing pointers
to needed tables, such as SSDTs.
When we find an XSDT with NULL entries, discard it
and use the ACPI 1.0 RSDT instead.
http://bugzilla.kernel.org/show_bug.cgi?id=8630
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Cc: Vincet Fortier <Vincent.Fortier1@EC.GC.CA>
Signed-off-by: Len Brown <len.brown@intel.com>
commit e5dd01154c1e9ca2400f4682602d1a4fa54c25dd in mainline.
This patch fixes the order of list_add_tail() arguments in
usb_store_new_id() so the list can have more than one single element.
Signed-off-by: Nathael Pajani <nathael.pajani@cpe.fr>
commit bec494775600b1cd7c144d31a09e1f46df9c6324 in mainline.
We want drivers/mtd/{mtdcore, mtdsuper, mtdpart}.c to be built and linked
into the same mtd.ko module. Fix the Makefile to ensure this, and remove
duplicate MODULE_ declarations in mtdpart.c, as mtdcore.c already has them.
Signed-off-by: Satyam Sharma <satyam@infradead.org>
commit f82f3f9422d4da1eeec6f6cf3e64c6c34c4fe19b in mainline.
Avoid setting the value if the symbol doesn't need to be changed or can't
be changed. Later choices may change the dependencies and thus the
possible input range.
make oldconfig from a 2.6.22 .config with CONFIG_HOTPLUG_CPU not set
was in some configurations setting CONFIG_HOTPLUG_CPU=y without asking,
even when there was no actual requirement for CONFIG_HOTPLUG_CPU.
This was triggered by SUSPEND_SMP that does a select HOTPLUG_CPU.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Tested-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
commit 60187d2708caa870f0825d753df1612ea688eb9e in mainline.
Spotted by taoyue <yue.tao@windriver.com> and Jeremy Katz <jeremy.katz@windriver.com>.
collect_signal: sigqueue_free:
list_del_init(&first->list);
if (!list_empty(&q->list)) {
// not taken
q->flags &= ~SIGQUEUE_PREALLOC;
__sigqueue_free(first); __sigqueue_free(q);
Now, __sigqueue_free() is called twice on the same "struct sigqueue" with the
obviously bad implications.
In particular, this double free breaks the array_cache->avail logic, so the
same sigqueue could be "allocated" twice, and the bug can manifest itself via
the "impossible" BUG_ON(!SIGQUEUE_PREALLOC) in sigqueue_free/send_sigqueue.
Hopefully this can explain these mysterious bug-reports, see
http://marc.info/?t=118766926500003
http://marc.info/?t=118466273000005
Alexey Dobriyan reports this patch makes the difference for the testcase, but
nobody has an access to the application which opened the problems originally.
Also, this patch removes tasklist lock/unlock, ->siglock is enough.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: taoyue <yue.tao@windriver.com>
Cc: Jeremy Katz <jeremy.katz@windriver.com>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Alexey Dobriyan <adobriyan@sw.ru>
Cc: Roland McGrath <roland@redhat.com>
commit b07e35f94a7b6a059f889b904529ee907dc0634d in mainline tree
Spotted by Marcin Kowalczyk <qrczak@knm.org.pl>.
sys_setpgid(child) fails if the child was forked by sub-thread.
Fix the "is it our child" check. The previous commit
ee0acf90d320c29916ba8c5c1b2e908d81f5057d was not complete.
(this patch asks for the new same_thread_group() helper, but mainline doesn't
have it yet).
Acked-by: Roland McGrath <roland@redhat.com>
Tested-by: "Marcin 'Qrczak' Kowalczyk" <qrczak@knm.org.pl>
cherry picked from commit 6175e487e314385e37f06448847e4c46c20edb44
b2c2-flexcop: fix Airstar HD5000 tuning regression
Git changeset 6bdcc6e6dbab8daffd05e5026486f34ba41a6c72 dropped the
stand-alone lgh06xf module, whose functionality was absorbed into the
dvb-pll module. However, there was a minor difference between the code
in lgh06xf and dvb-pll, which caused a regression in b2c2-flexcop
devices using the LG-H06xF NIM.
dvb-pll will probe for the presence of an i2c pll chip by performing a
single byte read, the lgh06xf driver did not do this. Unfortunately, the
code in flexcop-i2c.c does not currently support 1 byte or 0 byte reads
as a probe. Such probes with the current code will always fail.
In order to work around this problem, and restore proper functionality
of the Airstar HD5000 device, this hack was created to make the probe
appear to succeed. The single byte read in dvb_pll_attach is the only
place where such a probe would ever occur, so this change is safe, and
will not affect any other devices.
Of course, if one knew how to actually perform the read operation, it
would be better to go that route. In the meantime, however, we must
apply this workaround, in order to prevent the regression that causes
tuning to fail on the Airstar HD5000 ATSC device.
Thanks to Jarod Wilson, who had originally reported this regression, and
to Geoffrey Hausheer, whose original workaround patch led us to find the
actual cause of the problem.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Cc: Geoffrey Hausheer <inli3epy93n@phracturedblue.com>
Acked-by: Jarod Wilson <jwilson@redhat.com>
cherry picked from commit c545d6adbcacd296f7457bd992556feb055379de
Update get_dvb_firmware script for the new location of the
tda10046 firmware.
The old location doesn't work anymore.
Signed-off-by: Andreas Arens <ari@goron.de>
cherry picked from commit 302170a4b47e869372974abd885dd11d5536b64a
get_dvb_firmware: update script for new location of sp8870 firmware
This url is no longer valid:
http://www.technotrend.de/new/217g/tt_Premium_217g.zip
Replace with:
http://www.softwarepatch.pl/9999ccd06a4813cb827dbb0005071c71/tt_Premium_217g.zip
Thanks-to: Tobias Stoeber <tobi@to-st.de>
