[ upstream commit: 7d227cd235c809c36c847d6a597956ad9e9d2bae ]
We are seeing an issue with TCP in handling an ICMP frag needed
message that is received after net.ipv4.tcp_retries1 retransmits.
The default value of retries1 is 3. So if the path mtu changes
and ICMP frag needed is lost for the first 3 retransmits or if
it gets delayed until 3 retransmits are done, TCP doesn't update
MSS correctly and continues to retransmit the orginal message
until it timesout after tcp_retries2 retransmits.
I am seeing this issue even with the latest 2.6.25.4 kernel.
In tcp_retransmit_timer(), when retransmits counter exceeds
tcp_retries1 value, the dst cache entry of the socket is reset.
At this time, if we receive an ICMP frag needed message, the
dst entry gets updated with the new MTU, but the TCP sockets
dst_cache entry remains NULL.
So the next time when we try to retransmit after the ICMP frag
needed is received, tcp_retransmit_skb() gets called. Here the
cur_mss value is calculated at the start of the routine with
a NULL sk_dst_cache. Instead we should call tcp_current_mss after
the rebuild_header that caches the dst entry with the updated mtu.
Also the rebuild_header should be called before tcp_fragment
so that skb is fragmented if the mss goes down.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
[ upstream commit: 81d85346b3fcd8b3167eac8b5fb415a210bd4345 ]
Commit 30688a9 ([VLAN]: Handle vlan devices net namespace changing)
changed the device notifier to special-case notifications for VLAN
devices, effectively disabling state propagation to underlying VLAN
devices. This is needed for layered VLANs though, so restore the
original behaviour.
Acked-by: Pavel Emelyanov <xemul@openvz.org>
[ upstream commit: 090c48d3dd5ea90b37350334aaed9a93b0c1e0a1 ]
A user reported seeing occasional bugs such as the following when
using the L2TP driver.
SKB BUG: Invalid truesize (272) len=72, sizeof(sk_buff)=208
When L2TP adds its header in the transmit path, it might need to
increase the headroom of the skb. In some cases, the increased
headroom trips a kernel bug when the skb is freed because the skb has
grown beyond its truesize value. The fix is to increase the truesize
by the amount of headroom added, after orphaning the skb.
While here, fix a misleading comment.
Thanks to Iouri Kharon <bc-info@styx.cabel.net> for the initial
report and testing the fix.
Signed-off-by: James Chapman <jchapman@katalix.com>
[ upstream commit: b9a2f2e450b0f770bb4347ae8d48eb2dea701e24 ]
The purpose of nla_parse_nested_compat() is to parse attributes which
contain a struct followed by a stream of nested attributes. So far,
it called nla_parse_nested() to parse the stream of nested attributes
which was wrong, as nla_parse_nested() expects a container attribute
as data which holds the attribute stream. It needs to call
nla_parse() directly while pointing at the next possible alignment
point after the struct in the beginning of the attribute.
With this patch, I can no longer reproduce the reported leftover
warnings.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Patrick McHardy <kaber@trash.net>
[ upstream commit: 1ac06e0306d0192a7a4d9ea1c9e06d355ce7e7d3 ]
Because the IPsec output function xfrm_output_resume does its
own dst_output call it should always call __ip_local_output
instead of ip_local_output as the latter may invoke dst_output
directly. Otherwise the return values from nf_hook and dst_output
may clash as they both use the value 1 but for different purposes.
When that clash occurs this can cause a packet to be used after
it has been freed which usually leads to a crash. Because the
offending value is only returned from dst_output with qdiscs
such as HTB, this bug is normally not visible.
Thanks to Marco Berizzi for his perseverance in tracking this
down.
[ upstream commit: f2df824948d559ea818e03486a8583e42ea6ab37 ]
cls_api should return ENOENT when the requested classifier doesn't
exist.
[ upstream commit: 0e91796eb46e29edc791131c832a2232bcaed9dd ]
Am I just being particularly dim today, or can the call to
dev->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() never
happen?
We've just set dev->flags = flags & IFF_MULTICAST, effectively. So the
condition '(dev->flags ^ flags) & IFF_MULTICAST' is _never_ going to be
true.
[ upstream commit: b1443e2f6501f06930a162ff1ff08382a98bf23e ]
According to David Monro, at least with Natsemi Saturn chips the
cassini driver has some trouble with ipv6 checksums.
Until we have more information about what's going on here, only
use the chip checksums for ipv4.
This workaround was suggested and tested by David.
Update version and release date.
[ Upstream commit: 3f91bd420a955803421f2db17b2e04aacfbb2bb8 ]
Both copy_to_ and _from_user return the number of bytes, that failed to
reach their destination, not the 0/-EXXX values.
Based on patch from Pavel Emelyanov <xemul@openvz.org>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de>
commit 537d59af73d894750cff14f90fe2b6d77fbab15b in mainline
There's logic in __rfcomm_dlc_close:
rfcomm_dlc_lock(d);
d->state = BT_CLOSED;
d->state_changed(d, err);
rfcomm_dlc_unlock(d);
In rfcomm_dev_state_change, it's possible that rfcomm_dev_put try to
take the dlc lock, then we will deadlock.
Here fixed it by unlock dlc before rfcomm_dev_get in
rfcomm_dev_state_change.
why not unlock just before rfcomm_dev_put? it's because there's
another problem. rfcomm_dev_get/rfcomm_dev_del will take
rfcomm_dev_lock, but in rfcomm_dev_add the lock order is :
rfcomm_dev_lock --> dlc lock
so I unlock dlc before the taken of rfcomm_dev_lock.
Actually it's a regression caused by commit
1905f6c736cb618e07eca0c96e60e3c024023428 ("bluetooth :
__rfcomm_dlc_close lock fix"), the dlc state_change could be two
callbacks : rfcomm_sk_state_change and rfcomm_dev_state_change. I
missed the rfcomm_sk_state_change that time.
Thanks Arjan van de Ven <arjan@linux.intel.com> for the effort in
commit 4c8411f8c115def968820a4df6658ccfd55d7f1a ("bluetooth: fix
locking bug in the rfcomm socket cleanup handling") but he missed the
rfcomm_dev_state_change lock issue.
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
[ Upstream commit: 7dccf1f4e1696c79bff064c3770867cc53cbc71c ]
in net/bluetooth/rfcomm/sock.c, rfcomm_sk_state_change() does the
following operation:
if (parent && sock_flag(sk, SOCK_ZAPPED)) {
/* We have to drop DLC lock here, otherwise
* rfcomm_sock_destruct() will dead lock. */
rfcomm_sock_kill(sk);
rfcomm_dlc_lock(d);
which is fine, since rfcomm_sock_kill() will call sk_free() which will call
rfcomm_sock_destruct() which takes the rfcomm_dlc_lock()... so far so good.
HOWEVER, this assumes that the rfcomm_sk_state_change() function always gets
called with the rfcomm_dlc_lock() taken. This is the case for all but one
case, and in that case where we don't have the lock, we do a double unlock
followed by an attempt to take the lock, which due to underflow isn't
going anywhere fast.
This patch fixes this by moving the stragling case inside the lock, like
the other usages of the same call are doing in this code.
This was found with the help of the www.kerneloops.org project, where this
deadlock was observed 51 times at this point in time:
http://www.kerneloops.org/search.php?search=rfcomm_sock_destruct
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
There is only one function in AX25 calling skb_append(), and it really
looks suspicious: appends skb after previously enqueued one, but in
the meantime this previous skb could be removed from the queue.
This patch Fixes it the simple way, so this is not fully compatible with
the current method, but testing hasn't shown any problems.
[ upstream commit: 4da5105687e0993a3bbdcffd89b2b94d9377faab ]
This propagates the xfrm_user fix made in commit
bcf0dda8d2408fe1c1040cdec5a98e5fcad2ac72 ("[XFRM]: xfrm_user: fix
selector family initialization")
Based upon a bug report from, and tested by, Alan Swanson.
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org>
[ upstream commit: 3651751fff44ede58f65cbb1e39242139ead251b ]
This causes the lock to be taken twice, thus resulting in
a deadlock.
upstream commit: 659179b28f15ab1b1db5f8767090f5e728f115a1
Frame buffer and mode setting drivers can be built as modules,
so fb_mode_option needs to be exported to support these.
Prevents this error:
ERROR: "fb_mode_option" [drivers/ps3/ps3av_mod.ko] undefined!
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
upstream commit: 71fd5179e8d1d4d503b517e0c5374f7c49540bfc
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
upstream commit: 8dc4e37362a5dc910d704d52ac6542bfd49ddc2f
dget(dentry->d_parent) --> dget_parent(dentry)
unlock_parent() is racy and unnecessary. Replace single caller with
unlock_dir().
There are several other suspect uses of ->d_parent in ecryptfs...
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
upstream commit: 2f9b12a31fcb738ea8c9eb0d4ddf906c6f1d696c
Make sure crypt_stat->flags is protected with a lock in ecryptfs_open().
Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
upstream commit: 9c3580aa52195699065bc2d7242b1c7e3e6903fa
Callers of notify_change() need to hold i_mutex.
upstream commit: 868e15dbd2940f9453b4399117686f408dc77299
When the Linux kernel is compiled with CONFIG_DEBUG_SHIRQ=y,
the Soundblaster Audigy2 ZS Notebook PCMCIA card causes the
system hang during boot (udev stage) or when the card is hot-plug.
The CONFIG_DEBUG_SHIRQ flag is by default 'y' with all Fedora
kernels since 2.6.23. The problem was reported as
https://bugzilla.redhat.com/show_bug.cgi?id=326411
The issue was hunted down to the snd_emu10k1_create() routine:
/* pseudo-code */
snd_emu10k1_create(...) {
request_irq(... IRQF_SHARED ...) {
register the irq handler
#ifdef CONFIG_DEBUG_SHIRQ
call the irq handler: snd_emu10k1_interrupt() {
poll I/O port // <---- !! system hangs
#endif
snd_emu10k1_cardbus_init(...) {
initialize I/O ports
The early access to I/O port in the interrupt handler causes
the freeze. Obviously it is necessary to init the I/O ports
before accessing them. This patch moves the registration of
the irq handler after the initialization of the I/O ports.
Signed-off-by: Jaroslav Franek <jarin.franek@post.cz>
Acked-by: James Courtier-Dutton <James@superbug.co.uk>
upstream commit: 07bc76dfa19b10017b518dd9aa1b2719e8c863de
The auto-config mode of Realtek ALC codecs has a bug since 2.6.25
that it cannot resume properly. The problem was the wrong assignment
of init_hook that overrides the whole initialization.
Relevant bug reports:
http://bugzilla.kernel.org/show_bug.cgi?id=10662
https://bugzilla.novell.com/show_bug.cgi?id=385473
upstream commit: ed1524371716466e9c762808b02601d0d0276a92
Duh... Fortunately, the bug is quite recent (post-2.6.25) and, embarrassingly,
mine ;-/
http://bugzilla.kernel.org/show_bug.cgi?id=10878
upstream commit: a3bafeedfff2ac5fa0a316bea4570e27900b6fcc
This fixes a context assertion in ssb that makes b44 print
out warnings on resume.
This fixes the following kernel oops:
http://www.kerneloops.org/oops.php?number=12732
http://www.kerneloops.org/oops.php?number=11410
Signed-off-by: Michael Buesch <mb@bu3sch.de>
upstream commit: efedf51c866130945b5db755cb58670e60205d83
Alias brd to rd in the hope of helping legacy users. Suggested by Jan.
Signed-off-by: Nick Piggin <npiggin@suse.de>
upstream commit: eb4e545d4ac82d9018487edb4419b33b9930c857
Packet sending is driven by two flags, tx_ready and tx_queued.
It was possible, that there were queued data for sending and
hardware was flagged as blocked but in fact it was not.
The tx_queued was indicator but should be really a counter else
first fragmented packet resets tx_queued flag, but there may be
pending packets which do not get sent.
New semantics:
tx_ready - set, if hw is ready to send packet, no packet is being
transferred right now
set the flag right at the place where data are copied
into hw memory and not earlier without checking if it
was succesful
tx_queued - count of enqueued packets, including fragments
Tested-by: Michal Rokos <michal.rokos@gmail.com>
Signed-off-by: David Sterba <dsterba@suse.cz>
upstream commit: 3bf0a32e22fedc0b46443699db2d61ac2a883ac4
This fixes a kernel crash on rmmod, in the case where the controller
was restarted before doing the rmmod.
upstream commit: 2884f110d5409714f3a04eeb6d2ecd77da66b242
OGAWA Hirofumi and Fede have reported rare pmd_ERROR messages:
mm/memory.c:127: bad pmd ffff810000207xxx(9090909090909090).
Initialization's cleanup_highmap was leaving alignment filler
behind in the pmd for MODULES_VADDR: when vmalloc's guard page
would occupy a new page table, it's not allocated, and then
module unload's vfree hits the bad 9090 pmd entry left over.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Hugh notes:
It's actually not a serious problem, but it does look as if it's a
serious problem, so we should stamp it out.
upstream commit: 879000f94442860e72c934f9e568989bc7fb8ec4
If cpu specific cpufreq driver(i.e. longrun) has "setpolicy" function,
governor object isn't set into cpufreq_policy object at "__cpufreq_set_policy"
function in driver/cpufreq/cpufreq.c .
This causes a null object access at "store_scaling_setspeed" and
"show_scaling_setspeed" function in driver/cpufreq/cpufreq.c when reading or
writing through /sys interface (ex. cat
/sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed)
Addresses:
http://bugzilla.kernel.org/show_bug.cgi?id=10654
https://bugzilla.redhat.com/show_bug.cgi?id=443354
Signed-off-by: CHIKAMA Masaki <masaki.chikama@gmail.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Chuck Ebbert <cebbert@redhat.com>
Acked-by: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: <stable@kernel.org>
support.
upstream commit: ca05a99a54db1db5bca72eccb5866d2a86f8517f
Source code out there hard-codes a notion of what the
_LINUX_CAPABILITY_VERSION #define means in terms of the semantics of the
raw capability system calls capget() and capset(). Its unfortunate, but
true.
Since the confusing header file has been in a released kernel, there is
software that is erroneously using 64-bit capabilities with the semantics
of 32-bit compatibilities. These recently compiled programs may suffer
corruption of their memory when sys_getcap() overwrites more memory than
they are coded to expect, and the raising of added capabilities when using
sys_capset().
As such, this patch does a number of things to clean up the situation
for all. It
1. forces the _LINUX_CAPABILITY_VERSION define to always retain its
legacy value.
2. adopts a new #define strategy for the kernel's internal
implementation of the preferred magic.
3. deprecates v2 capability magic in favor of a new (v3) magic
number. The functionality of v3 is entirely equivalent to v2,
the only difference being that the v2 magic causes the kernel
to log a "deprecated" warning so the admin can find applications
that may be using v2 inappropriately.
[User space code continues to be encouraged to use the libcap API which
protects the application from details like this. libcap-2.10 is the first
to support v3 capabilities.]
Fixes issue reported in https://bugzilla.redhat.com/show_bug.cgi?id=447518.
Thanks to Bojan Smojver for the report.
[akpm@linux-foundation.org: s/depreciate/deprecate/g]
[akpm@linux-foundation.org: be robust about put_user size]
Signed-off-by: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serue@us.ibm.com>
Cc: Bojan Smojver <bojan@rexursive.com>
Cc: stable@kernel.org
upstream commit: e0a115e5aa554b93150a8dc1c3fe15467708abb2
During the initial array synchronization process there is a window between
when a prexor operation is scheduled to a specific stripe and when it
completes for a sync_request to be scheduled to the same stripe. When
this happens the prexor completes and the stripe is unconditionally marked
"insync", effectively canceling the sync_request for the stripe. Prior to
2.6.23 this was not a problem because the prexor operation was done under
sh->lock. The effect in older kernels being that the prexor would still
erroneously mark the stripe "insync", but sync_request would be held off
and re-mark the stripe as "!in_sync".
Change the write completion logic to not mark the stripe "in_sync" if a
prexor was performed. The effect of the change is to sometimes not set
STRIPE_INSYNC. The worst this can do is cause the resync to stall waiting
for STRIPE_INSYNC to be set. If this were happening, then STRIPE_SYNCING
would be set and handle_issuing_new_read_requests would cause all
available blocks to eventually be read, at which point prexor would never
be used on that stripe any more and STRIPE_INSYNC would eventually be set.
echo repair > /sys/block/mdN/md/sync_action will correct arrays that may
have lost this race.
Signed-off-by: Neil Brown <neilb@suse.de>
[chrisw: backport to 2.6.25.5]
upstream commit: a6d8113a986c66aeb379a26b6e0062488b3e59e1
If an array was created with --assume-clean we will oops when trying to
set ->resync_max.
Fix this by initializing ->recovery_wait in mddev_find.
upstream commit: c337869d95011495fa181536786e74aa2d7ff031
If a block is computed (rather than read) then a check/repair operation
may be lead to believe that the data on disk is correct, when infact it
isn't. So only compute blocks for failed devices.
This issue has been around since at least 2.6.12, but has become harder to
hit in recent kernels since most reads bypass the cache.
echo repair > /sys/block/mdN/md/sync_action will set the parity blocks to the
correct state.
upstream commit: d3e49afbb66109613c3474f2273f5830ac2dcb09
The page decrypt calls in ecryptfs_write() are both pointless and buggy.
Pointless because ecryptfs_get_locked_page() has already brought the page
up to date, and buggy because prior mmap writes will just be blown away by
the decrypt call.
This patch also removes the declaration of a now-nonexistent function
ecryptfs_write_zeros().
Thanks to Eric Sandeen and David Kleikamp for helping to track this
down.
Eric said:
fsx w/ mmap dies quickly ( < 100 ops) without this, and survives
nicely (to millions of ops+) with it in place.
Cc: Eric Sandeen <sandeen@redhat.com>
Cc: Dave Kleikamp <shaggy@austin.ibm.com>
upstream commit: a5b4592cf77b973c29e7c9695873a26052b58951
Fix a regression introduced by
commit 4cc6028d4040f95cdb590a87db478b42b8be0508
Author: Jiri Kosina <jkosina@suse.cz>
Date: Wed Feb 6 22:39:44 2008 +0100
brk: check the lower bound properly
The check in sys_brk() on minimum value the brk might have must take
CONFIG_COMPAT_BRK setting into account. When this option is turned on
(i.e. we support ancient legacy binaries, e.g. libc5-linked stuff), the
lower bound on brk value is mm->end_code, otherwise the brk start is
allowed to be arbitrarily shifted.
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
/proc/pid/pagemap
upstream commit: aae8679b0ebcaa92f99c1c3cb0cd651594a43915
Fix a bug in add_to_pagemap. Previously, since pm->out was a char *,
put_user was only copying 1 byte of every PFN, resulting in the top 7
bytes of each PFN not being copied. By requiring that reads be a multiple
of 8 bytes, I can make pm->out and pm->end u64*s instead of char*s, which
makes put_user work properly, and also simplifies the logic in
add_to_pagemap a bit.
Signed-off-by: Thomas Tuttle <ttuttle@google.com>
Cc: Matt Mackall <mpm@selenic.com>
upstream commit: aed5417593ad125283f35513573282139a8664b5
This patch:
commit e9720acd728a46cb40daa52c99a979f7c4ff195c
Author: Pavel Emelyanov <xemul@openvz.org>
Date: Fri Mar 7 11:08:40 2008 -0800
[NET]: Make /proc/net a symlink on /proc/self/net (v3)
introduced a /proc/self/net directory without bumping the corresponding
link count for /proc/self.
This patch replaces the static link count initializations with a call that
counts the number of directory entries in the given pid_entry table
whenever it is instantiated, and thus relieves the burden of manually
keeping the two in sync.
[akpm@linux-foundation.org: cleanup]
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
upstream commit: e97dcb0eadbb821eccd549d4987b653cf61e2374
The d_instantiate hook for Smack can hang on the root inode of a
filesystem if the file system code has not really done all the set-up.
Fuse is known to encounter this problem.
This change detects an attempt to instantiate a root inode and addresses
it early in the processing, before any attempt is made to do something
that might hang.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Tested-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
upstream commit: aefdbf1a3b832a580a50cf3d1dcbb717be7cbdbe
When using 4+ GB RAM and SWIOTLB is active, the driver corrupts
memory by writing an skb after the relevant DMA page has been
unmapped. Although this doesn't happen when *not* using bounce
buffers, clearing the pointer to the DMA page after unmapping
it fixes the problem.
http://marc.info/?t=120861317000005&r=2&w=2
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
[jacliburn@bellsouth.net: backport to 2.6.25.4]
nf_ct_frag6_gather()
upstream commit: b9c698964614f71b9c8afeca163a945b4c2e2d20
[ 63.531438] =================================
[ 63.531520] [ INFO: inconsistent lock state ]
[ 63.531520] 2.6.26-rc4 #7
[ 63.531520] ---------------------------------
[ 63.531520] inconsistent {softirq-on-W} -> {in-softirq-W} usage.
[ 63.531520] tcpsic6/3864 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 63.531520] (&q->lock#2){-+..}, at: [<c07175b0>] ipv6_frag_rcv+0xd0/0xbd0
[ 63.531520] {softirq-on-W} state was registered at:
[ 63.531520] [<c0143bba>] __lock_acquire+0x3aa/0x1080
[ 63.531520] [<c0144906>] lock_acquire+0x76/0xa0
[ 63.531520] [<c07a8f0b>] _spin_lock+0x2b/0x40
[ 63.531520] [<c0727636>] nf_ct_frag6_gather+0x3f6/0x910
According to this and another similar lockdep report inet_fragment
locks are taken from nf_ct_frag6_gather() with softirqs enabled, but
these locks are mainly used in softirq context, so disabling BHs is
necessary.
Reported-and-tested-by: Eric Sesterhenn <snakebyte@gmx.de>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
ESTABLISHED state
upstream commit: d2ee3f2c4b1db1320c1efb4dcaceeaf6c7e6c2d3
In xt_connlimit match module, the counter of an IP is decreased when
the TCP packet is go through the chain with ip_conntrack state TW.
Well, it's very natural that the server and client close the socket
with FIN packet. But when the client/server close the socket with RST
packet(using so_linger), the counter for this connection still exsit.
The following patch can fix it which is based on linux-2.6.25.4
Signed-off-by: Dong Wei <dwei.zh@gmail.com>
Acked-by: Jan Engelhardt <jengelh@medozas.de>
nf_conntrack_expect_init()
upstream commit: 12293bf91126ad253a25e2840b307fdc7c2754c3
Signed-off-by: Alexey Dobriyan <adobriyan@parallels.com>
upstream commit: 870568b39064cab2dd971fe57969916036982862
Jürgen Mell reported an FPU state corruption bug under CONFIG_PREEMPT,
and bisected it to commit v2.6.19-1363-gacc2076, "i386: add sleazy FPU
optimization".
Add tsk_used_math() checks to prevent calling math_state_restore()
which can sleep in the case of !tsk_used_math(). This prevents
making a blocking call in __switch_to().
Apparently "fpu_counter > 5" check is not enough, as in some signal handling
and fork/exec scenarios, fpu_counter > 5 and !tsk_used_math() is possible.
It's a side effect though. This is the failing scenario:
process 'A' in save_i387_ia32() just after clear_used_math()
Got an interrupt and pre-empted out.
At the next context switch to process 'A' again, kernel tries to restore
the math state proactively and sees a fpu_counter > 0 and !tsk_used_math()
This results in init_fpu() during the __switch_to()'s math_state_restore()
And resulting in fpu corruption which will be saved/restored
(save_i387_fxsave and restore_i387_fxsave) during the remaining
part of the signal handling after the context switch.
Bisected-by: Jürgen Mell <j.mell@t-online.de>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Tested-by: Jürgen Mell <j.mell@t-online.de>
back.
upstream commit: e56a727b023d40d1adf660168883f30f2e6abe0a
We checked the hardware freq with OS cached freq value in get_cur_freqon_cpu().
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Thomas Renninger <trenn@suse.de>
Cc: "Anthony L. Awtrey" <tony@awtrey.com>
[chrisw: backport to 2.6.25.4]
upstream commit: 6e7045990f35ef9250804b3fd85e855b8c2aaeb6.
[jkosina@suse.cz: Needed to fix apple aluminium keyboard regression]
Since 2.6.25 the HID_QUIRK_APPLE_HAS_FN quirk is enabled even for
non-laptop Apple keyboards of the Aluminium series. The USB version of
these don't need Numlock emulation, like the laptop (and Aluminium
Wireless) do, as they have a proper keypad.
This patch splits the Numlock emulation for Apple keyboards in a
different quirk flag, so that it can be enabled for all the keyboards
but the Aluminium USB ones.
If the Numlock emulation is enabled for Aluminium USB keyboards, the
JKL and UIO keys become the numeric pad, and the rest of the keyboard
is disabled, included the key used to disable Numlock.
Additionally, these keyboard should not have a Numlock at all, as the
Numlock key is instead replaced by the 'Clear' key as usual for Apple
USB keyboards.
Signed-off-by: Diego 'Flameeyes' Petteno <flameeyes@gmail.com>
upstream commit: 01b7a314291b2ef56ad718ee1374a1bac4768b29
Using iptables 1.3.8 with kernel 2.6.25, rules which include '-m
iprange' don't automatically pull in xt_iprange module. Below patch
adds module aliases to fix that. Patch against latest -git, but seems
like a good candidate for -stable also.
Signed-off-by: Phil Oester <kernel@linuxace.com>
upstream commit: 6fc7431dc0775f21ad7a7a39c2ad0290291a56ea
This fixes the bug that the I/O buffer is not freed at the driver removal.
Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp>
upstream commit: 8d539108560ec121d59eee05160236488266221c
This reverts commit 9f8daccaa05c14e5643bdd4faf5aed9cc8e6f11e, which was
reported to break X startup (xf86-video-ati-6.8.0). See
http://bugs.freedesktop.org/show_bug.cgi?id=15523
for details.
Reported-by: Laurence Withers <l@lwithers.me.uk>
Cc: Gary Hade <garyhade@us.ibm.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jan Beulich <jbeulich@novell.com>
Cc: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com>
[cebbert@redhat.com: backport, remove first hunk to make port easier]
[chrisw@sous-sol.org: add back first hunk]
upstream commit: b1979a5fda7869a790f4fd83fb06c78498d26ba1
CR4 manipulation is not protected against interrupts and preemption,
but KVM uses smp_function_call to manipulate the X86_CR4_VMXE bit
either from the CPU hotplug code or from the kvm_init call.
We need to protect the CR4 manipulation from both interrupts and
preemption.
Original bug report: http://lkml.org/lkml/2008/5/7/48
Bugzilla entry: http://bugzilla.kernel.org/show_bug.cgi?id=10642
This is not a regression from 2.6.25, it's a long standing and hard to
trigger bug.
upstream commit: 6ab455eeaff6893cd06da33843e840d888cdc04a
When we have multiple buffers in a single page for a blocksize == pagesize
filesystem we might overwrite the page contents if two callers hit it
shortly after each other. To prevent that we need to keep the page locked
until I/O is completed and the page marked uptodate.
Thanks to Eric Sandeen for triaging this bug and finding a reproducible
testcase and Dave Chinner for additional advice.
This should fix kernel.org bz #10421.
Tested-by: Eric Sandeen <sandeen@sandeen.net>
SGI-PV: 981813
SGI-Modid: xfs-linux-melb:xfs-kern:31173a
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: David Chinner <dgc@sgi.com>
Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
