2009-06-24Linux 2.6.31-rc1v2.6.31-rc1Linus Torvalds
2009-06-24Revert "PCI: use ACPI _CRS data by default"Linus Torvalds
This reverts commit 9e9f46c44e487af0a82eb61b624553e2f7118f5b. Quoting from the commit message: "At this point, it seems to solve more problems than it causes, so let's try using it by default. It's an easy revert if it ends up causing trouble." And guess what? The _CRS code causes trouble. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: da9030_battery: Fix race between event handler and monitor Add MAX17040 Fuel Gauge driver w1: ds2760_battery: add support for sleep mode feature w1: ds2760: add support for EEPROM read and write ds2760_battery: cleanups in ds2760_battery_probe()
2009-06-24Merge branches 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/{vfs-2.6,audit-current} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: another race fix in jfs_check_acl() Get "no acls for this inode" right, fix shmem breakage inline functions left without protection of ifdef (acl) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: audit: inode watches depend on CONFIG_AUDIT not CONFIG_AUDIT_SYSCALL
2009-06-24another race fix in jfs_check_acl()Al Viro
2009-06-24Get "no acls for this inode" right, fix shmem breakageAl Viro
2009-06-24audit: inode watches depend on CONFIG_AUDIT not CONFIG_AUDIT_SYSCALLEric Paris
Even though one cannot make use of the audit watch code without CONFIG_AUDIT_SYSCALL the spaghetti nature of the audit code means that the audit rule filtering requires that it at least be compiled. Thus build the audit_watch code when we build auditfilter like it was before cfcad62c74abfef83762dc05a556d21bdf3980a2 Clearly this is a point of potential future cleanup.. Reported-by: Frans Pop <elendil@planet.nl> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24inline functions left without protection of ifdef (acl)Markus Trippelsdorf
2009-06-24Merge branch 'futexes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Fix the write access fault problem for real
2009-06-24futex: Fix the write access fault problem for realThomas Gleixner
commit 64d1304a64 (futex: setup writeable mapping for futex ops which modify user space data) did address only half of the problem of write access faults. The patch was made on two wrong assumptions: 1) access_ok(VERIFY_WRITE,...) would actually check write access. On x86 it does _NOT_. It's a pure address range check. 2) a RW mapped region can not go away under us. That's wrong as well. Nobody can prevent another thread to call mprotect(PROT_READ) on that region where the futex resides. If that call hits between the get_user_pages_fast() verification and the actual write access in the atomic region we are toast again. The solution is to not rely on access_ok and get_user() for any write access related fault on private and shared futexes. Instead we need to fault it in with verification of write access. There is no generic non destructive write mechanism which would fault the user page in trough a #PF, but as we already know that we will fault we can as well call get_user_pages() directly and avoid the #PF overhead. If get_user_pages() returns -EFAULT we know that we can not fix it anymore and need to bail out to user space. Remove a bunch of confusing comments on this issue as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2009-06-24SLUB: Don't pass __GFP_FAIL for the initial allocationPekka Enberg
SLUB uses higher order allocations by default but falls back to small orders under memory pressure. Make sure the GFP mask used in the initial allocation doesn't include __GFP_NOFAIL. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24Don't warn about order-1 allocations with __GFP_NOFAILLinus Torvalds
Traditionally, we never failed small orders (even regardless of any __GFP_NOFAIL flags), and slab will allocate order-1 allocations even for small allocations that could fit in a single page (in order to avoid excessive fragmentation). Maybe we should remove this warning entirely, but before making that judgement, at least limit it to bigger allocations. Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: Staging: octeon-ethernet: Fix race freeing transmit buffers. Staging: octeon-ethernet: Convert to use net_device_ops. MIPS: Cavium: Add CPU hotplugging code. MIPS: SMP: Allow suspend and hibernation if CPU hotplug is available MIPS: Add arch generic CPU hotplug DMA: txx9dmac: use dma_unmap_single if DMA_COMPL_{SRC,DEST}_UNMAP_SINGLE set MIPS: Sibyte: Fix build error if CONFIG_SERIAL_SB1250_DUART is undefined. MIPS: MIPSsim: Fix build error if MSC01E_INT_BASE is undefined. MIPS: Hibernation: Remove SMP TLB and cacheflushing code. MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users. MIPS: bug.h Build fix - include <linux/compiler.h>.
2009-06-24Staging: octeon-ethernet: Fix race freeing transmit buffers.David Daney
The existing code had the following race: Thread-1 Thread-2 inc/read in_use inc/read in_use inc tx_free_list[qos].len inc tx_free_list[qos].len The actual in_use value was incremented twice, but thread-1 is going to free memory based on its stale value, and will free one too many times. The result is that memory is freed back to the kernel while its packet is still in the transmit buffer. If the memory is overwritten before it is transmitted, the hardware will put a valid checksum on it and send it out (just like it does with good packets). If by chance the TCP flags are clobbered but not the addresses or ports, the result can be a broken TCP stream. The fix is to track the number of freed packets in a single location (a Fetch-and-Add Unit register). That way it can never get out of sync with itself. We try to free up to MAX_SKB_TO_FREE (currently 10) buffers at a time. If fewer are available we adjust the free count with the difference. The action of claiming buffers to free is atomic so two threads cannot claim the same buffers. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24Staging: octeon-ethernet: Convert to use net_device_ops.David Daney
Convert the driver to use net_device_ops as it is now mandatory. Also compensate for the removal of struct sk_buff's dst field. The changes are mostly mechanical, the content of ethernet-common.c was moved to ethernet.c and ethernet-common.{c,h} are removed. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Cavium: Add CPU hotplugging code.Ralf Baechle
Thanks to Cavium Inc. for the code contribution and help. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: SMP: Allow suspend and hibernation if CPU hotplug is availableRalf Baechle
The SMP implementation of suspend and hibernate depends on CPU hotplugging. In the past we didn't have CPU hotplug so suspend and hibernation were not possible on SMP systems. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Add arch generic CPU hotplugRalf Baechle
Each platform has to add support for CPU hotplugging itself by providing suitable definitions for the cpu_disable and cpu_die of the smp_ops methods and setting SYS_SUPPORTS_HOTPLUG_CPU. A platform should only set SYS_SUPPORTS_HOTPLUG_CPU once all it's smp_ops definitions have the necessary changes. This patch contains the changes to the dummy smp_ops definition for uni-processor systems. Parts of the code contributed by Cavium Inc. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24DMA: txx9dmac: use dma_unmap_single if DMA_COMPL_{SRC,DEST}_UNMAP_SINGLE setAtsushi Nemoto
This patch does not change actual behaviour since dma_unmap_page is just an alias of dma_unmap_single on MIPS. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Sibyte: Fix build error if CONFIG_SERIAL_SB1250_DUART is undefined.Ralf Baechle
This fixes kernel.org bugzilla 13596, see http://bugzilla.kernel.org/show_bug.cgi?id=13596 Reported-by: dvice_null@yahoo.com Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: MIPSsim: Fix build error if MSC01E_INT_BASE is undefined.Ralf Baechle
This fixes kernel.org bugzilla 13595, see http://bugzilla.kernel.org/show_bug.cgi?id=13595 Reported-by: dvice_null@yahoo.com Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Hibernation: Remove SMP TLB and cacheflushing code.Ralf Baechle
We can't perform any flushes on SMP from swsusp_arch_resume because interrupts are disabled. A cross-CPU flush is unnecessary anyway because all but the local CPU have already been disabled. A local flush is not needed either because we didn't change any mappings. So just delete the code. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: bug.h Build fix - include <linux/compiler.h>.Ralf Baechle
In the past this file somehow used to be dragged in. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dmLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: (48 commits) dm mpath: change to be request based dm: disable interrupt when taking map_lock dm: do not set QUEUE_ORDERED_DRAIN if request based dm: enable request based option dm: prepare for request based option dm raid1: add userspace log dm: calculate queue limits during resume not load dm log: fix create_log_context to use logical_block_size of log device dm target:s introduce iterate devices fn dm table: establish queue limits by copying table limits dm table: replace struct io_restrictions with struct queue_limits dm table: validate device logical_block_size dm table: ensure targets are aligned to logical_block_size dm ioctl: support cookies for udev dm: sysfs add suspended attribute dm table: improve warning message when devices not freed before destruction dm mpath: add service time load balancer dm mpath: add queue length load balancer dm mpath: add start_io and nr_bytes to path selectors dm snapshot: use barrier when writing exception store ...
2009-06-24Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: uwb: allow WLP to be used with IPv6. uwb: event_size should be signed
2009-06-24Merge branch 'audit.b63' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b63' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: Fix rule eviction order for AUDIT_DIR Audit: clean up all op= output to include string quoting Audit: move audit_get_nd completely into audit_watch audit: seperate audit inode watches into a subfile Audit: clean up audit_receive_skb Audit: cleanup netlink mesg handling Audit: unify the printk of an skb when auditd not around Audit: dereferencing krule as if it were an audit_watch Audit: better estimation of execve record length Audit: fix audit watch use after free
2009-06-24MAINTAINERS: Change mailing list info for CRISJesper Nilsson
Posting to the dev-etrax mailing list is only allowed for subscribers, and the list is more geared toward user applications than kernel developers. Change to newly created mailing list for CRIS. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (72 commits) asus-laptop: remove EXPERIMENTAL dependency asus-laptop: use pr_fmt and pr_<level> eeepc-laptop: cpufv updates eeepc-laptop: sync eeepc-laptop with asus_acpi asus_acpi: Deprecate in favor of asus-laptop acpi4asus: update MAINTAINER and KConfig links asus-laptop: platform dev as parent for led and backlight eeepc-laptop: enable camera by default ACPI: Rename ACPI processor device bus ID acerhdf: Acer Aspire One fan control ACPI: video: DMI workaround broken Acer 7720 BIOS enabling display brightness ACPI: run ACPI device hot removal in kacpi_hotplug_wq ACPI: Add the reference count to avoid unloading ACPI video bus twice ACPI: DMI to disable Vista compatibility on some Sony laptops ACPI: fix a deadlock in hotplug case Show the physical device node of backlight class device. ACPI: pdc init related memory leak with physical CPU hotplug ACPI: pci_root: remove unused dev/fn information ACPI: pci_root: simplify list traversals ACPI: pci_root: use driver data rather than list lookup ...
2009-06-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (23 commits) switch xfs to generic acl caching helpers helpers for acl caching + switch to those switch shmem to inode->i_acl switch reiserfs to inode->i_acl switch reiserfs to usual conventions for caching ACLs reiserfs: minimal fix for ACL caching switch nilfs2 to inode->i_acl switch btrfs to inode->i_acl switch jffs2 to inode->i_acl switch jfs to inode->i_acl switch ext4 to inode->i_acl switch ext3 to inode->i_acl switch ext2 to inode->i_acl add caching of ACLs in struct inode fs: Add new pre-allocation ioctls to vfs for compatibility with legacy xfs ioctls cleanup __writeback_single_inode ... and the same for vfsmount id/mount group id Make allocation of anon devices cheaper update Documentation/filesystems/Locking devpts: remove module-related code ...
2009-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: bnx2: Fix the behavior of ethtool when ONBOOT=no qla3xxx: Don't sleep while holding lock. qla3xxx: Give the PHY time to come out of reset. ipv4 routing: Ensure that route cache entries are usable and reclaimable with caching is off net: Move rx skb_orphan call to where needed ipv6: Use correct data types for ICMPv6 type and code net: let KS8842 driver depend on HAS_IOMEM can: let SJA1000 driver depend on HAS_IOMEM netxen: fix firmware init handshake netxen: fix build with without CONFIG_PM netfilter: xt_rateest: fix comparison with self netfilter: xt_quota: fix incomplete initialization netfilter: nf_log: fix direct userspace memory access in proc handler netfilter: fix some sparse endianess warnings netfilter: nf_conntrack: fix conntrack lookup race netfilter: nf_conntrack: fix confirmation race condition netfilter: nf_conntrack: death_by_timeout() fix
2009-06-24Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6: udf: remove redundant tests on unsigned udf: Use device size when drive reported bogus number of written blocks
2009-06-24Remove low_latency flag setting from nozomi and mxser driversChuck Ebbert
The kernel oopses if this flag is set. [and neither driver should set it as they call tty_flip_buffer_push from IRQ paths so have always been buggy] Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24tty: fix tty_port_block_til_ready waitingJiri Slaby
Since commit 3e3b5c087799e536871c8261b05bc28e4783c8da ("tty: use prepare/finish_wait"), tty_port_block_til_ready() is using prepare_to_wait()/finish_wait(). Those functions require that the wait_queue_t be initialised with .func=autoremove_wake_function, via DEFINE_WAIT(). But the conversion from DECLARE_WAITQUEUE() to DEFINE_WAIT() was not made, so this code will oops in finish_wait(). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24pci: use pci_ioremap_bar() in drivers/serialArjan van de Ven
Use the newly introduced pci_ioremap_bar() function in drivers/serial. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24synclink_gt: fix transmit race and timeoutPaul Fulghum
Fix race condition when adding transmit data to active DMA buffer ring that can cause transmit stall. Update transmit timeout when adding data to active DMA buffer ring. Base transmit timeout on amount of buffered data instead of using fixed value. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24jsm: clean up "serial: jsm: correctly support 4 8 port boards"Andrew Morton
Remove unneeded casts. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24kgdb: kgdboc console poll hooks for serial_txx9 uartAtsushi Nemoto
Implement the serial polling hooks for the serial_txx9 uart for use with kgdboc. This patch once got SOB from Jason on Jul 2008 and (perhaps) merged into kgdb-next branch, but lost somewhere then. I resend it now with Jason's Acked-by. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24switch xfs to generic acl caching helpersAl Viro
2009-06-24helpers for acl caching + switch to thoseAl Viro
helpers: get_cached_acl(inode, type), set_cached_acl(inode, type, acl), forget_cached_acl(inode, type). ubifs/xattr.c needed includes reordered, the rest is a plain switchover. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24switch shmem to inode->i_aclAl Viro
2009-06-24switch reiserfs to inode->i_aclAl Viro
2009-06-24switch reiserfs to usual conventions for caching ACLsAl Viro
2009-06-24reiserfs: minimal fix for ACL cachingAl Viro
reiserfs uses NULL as "unknown" and ERR_PTR(-ENODATA) as "no ACL"; several codepaths store the former instead of the latter. All those codepaths go through iset_acl() and all cases when it's called with NULL acl are for the second variety, so the minimal fix is to teach iset_acl() to deal with that. Proper fix is to switch to more usual conventions and avoid back and forth between internally used ERR_PTR(-ENODATA) and NULL expected by the rest of the kernel. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24switch nilfs2 to inode->i_aclAl Viro
Actually, get rid of private analog, since nothing in there is using ACLs at all so far. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24switch btrfs to inode->i_aclAl Viro
2009-06-24switch jffs2 to inode->i_aclAl Viro
2009-06-24switch jfs to inode->i_aclAl Viro
2009-06-24switch ext4 to inode->i_aclAl Viro
2009-06-24switch ext3 to inode->i_aclAl Viro
