commit c2f6595fbdb408d3d6850cfae590c8fa93e27399 upstream.
This patch (as1304) fixes a regression in ehci-hcd. Evidently some
hubs don't handle Clear-TT-Buffer requests correctly, so we should
avoid sending them when they don't appear to be absolutely necessary.
The reported symptom is that output on a downstream audio device cuts
out because the hub stops relaying isochronous packets.
The patch prevents Clear-TT-Buffer requests from being sent following
a STALL handshake. In theory a STALL indicates either that the
downstream device sent a STALL or that no matching TT buffer could be
found. In either case, the transfer is completed and the TT buffer
does not remain busy, so it doesn't need to be cleared.
Also, the patch fixes a minor flaw in the code that actually sends the
Clear-TT-Buffer requests. Although the pipe direction isn't really
used for control transfers, it should be a Send rather than a Receive.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Javier Kohen <jkohen@users.sourceforge.net>
CC: David Brownell <david-b@pacbell.net>
commit 8dca15e40889e5d5e9655b03ba79c26200f760ce upstream.
"[CPUFREQ] cpumask: avoid playing with cpus_allowed in speedstep-ich.c"
changed the code to mistakenly pass the current cpu as the "processor"
argument of speedstep_get_frequency(), whereas it should be the type of
the processor.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14340
Based on a patch by Dave Mueller.
Acked-by: Dominik Brodowski <linux@brodo.de>
Reported-by: Dave Mueller <dave.mueller@gmx.ch>
Signed-off-by: Dave Jones <davej@redhat.com>
NULL ptr OOPS
commit bbf31bf18d34caa87dd01f08bf713635593697f2 upstream.
ipv4 ip_frag_reasm(), fully replace 'dev_net(dev)' with 'net', defined
previously patched into 2.6.29.
Between 2.6.28.10 and 2.6.29, net/ipv4/ip_fragment.c was patched,
changing from dev_net(dev) to container_of(...). Unfortunately the goto
section (out_fail) on oversized packets inside ip_frag_reasm() didn't
get touched up as well. Oversized IP packets cause a NULL pointer
dereference and immediate hang.
I discovered this running openvasd and my previous email on this is
titled: NULL pointer dereference at 2.6.32-rc8:net/ipv4/ip_fragment.c:566
Signed-off-by: David Ford <david@blue-labs.org>
commit 22370ef5035f206283505409c9a64a595c5c7320 upstream.
The Hauppauge WinTV HVR-1150 retail boards require the FORCE_TS_VALID bit
to be set in order to function properly. This change will work on the early
revisions on the board as well, but the final revision will not function
without this change.
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
commit 4007a672abd88091e3cced158ec491d41c0c454c upstream.
When FORCE_TS_VALID mode is enabled, the saa713x will accept MPEG TS input
without requiring TS_VALID set high. This is required for some new boards
to function properly, due to the hardware design implementation.
The configuration is toggled within the board setup configuration. Boards
that do not have this bit set will function as before with no change.
Hauppauge USB IDs
commit 78c948ab0cc44f9c8ae397d7d9d217bb498bfa2f upstream.
Add support for three new Hauppauge Device USB IDs:
2040:b900
2040:b910
2040:c000
commit bdddd2963c0264c56f18043f6fa829d3c1d3d1c0 upstream.
Anton Blanchard wrote:
> We allocate and zero cpu_isolated_map after the isolcpus
> __setup option has run. This means cpu_isolated_map always
> ends up empty and if CPUMASK_OFFSTACK is enabled we write to a
> cpumask that hasn't been allocated.
I introduced this regression in 49557e620339cb13 (sched: Fix
boot crash by zalloc()ing most of the cpu masks).
Use the bootmem allocator if they set isolcpus=, otherwise
allocate and zero like normal.
Reported-by: Anton Blanchard <anton@samba.org>
Cc: peterz@infradead.org
LKML-Reference: <200912021409.17013.rusty@rustcorp.com.au>
Tested-by: Anton Blanchard <anton@samba.org>
commit 49557e620339cb134127b5bfbcfecc06b77d0232 upstream.
I got a boot crash when forcing cpumasks offstack on 32 bit,
because find_new_ilb() returned 3 on my UP system (nohz.cpu_mask
wasn't zeroed).
AFAICT the others need to be zeroed too: only
nohz.ilb_grp_nohz_mask is initialized before use.
LKML-Reference: <200911022037.21282.rusty@rustcorp.com.au>
[ Upstream commit 1c9d80ddc60f8ac26344ec3db9830e5f8016c16d ]
Otherwise we try to sleep with preemption disabled, etc.
Noticed by Thomas Gleixner.
[ Upstream commit 88b938e63e68fd35e603421f722be0f35dde1016 ]
`>>' has a higher precedence than `?' so src2 evaluated to
either 16 or 0 dependent on the bits set in rs2.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
[ Upstream commit 345056af41feeda506a8993474b9cbb2c66bc9fb ]
Page buffers containing packets with an incorrect checksum or using a
protocol not handled by hardware checksum offload were previously not
passed to LRO. The conversion to GRO changed this, but did not set
the ip_summed value accordingly.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
[ Upstream commit d3da68310a2cf934c2ea8a99a519d8b1ccca4c56 ]
Modify bonding hash transmit policies to use the psource MAC address of
the packet instead of the MAC address configured for the bonding device.
The old sitation conflicts with the documentation.
Signed-off-by: Jasper Spaans <spaans@fox-it.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
[ Upstream commit: 9d410c796067686b1e032d54ce475b7055537138 ]
On UDP sockets, we must call skb_free_datagram() with socket locked,
or risk sk_forward_alloc corruption. This requirement is not respected
in SUNRPC.
Add a convenient helper, skb_free_datagram_locked() and use it in SUNRPC
Reported-by: Francis Moreau <francis.moro@gmail.com>
[ Upstream commit 53f7e35f8b7fc2f5620a863ac613bcf3080cb6ba ]
This probably deserves to go into -stable.
Pedit will reject a policy that is large because it
uses the wrong structure in the policy validation.
This fixes it.
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
[ Upstream commit 6c60e0c30c80fcd53e61701b7865a85283f8a341 ]
If ace_load_firmware() fails, ace_init() cleans up but still returns
0, leading to an oops as seen in <http://bugs.debian.org/521383>.
It should pass the error code up.
[ Upstream commit 85584672012ee0c3b7b8e033a1ecf7c11878e45f ]
udp_poll() can in some circumstances drop frames with incorrect checksums.
Problem is we now have to lock the socket while dropping frames, or risk
sk_forward corruption.
This bug is present since commit 95766fff6b9a78d1
([UDP]: Add memory accounting.)
While we are at it, we can correct ioctl(SIOCINQ) to also drop bad frames.
commit 2d109a845dd3074885db726892c629ab73dd0ed8 upstream.
The master irq control in DE must be disabled before irq handling,
and enable after the process. This fixes the irq stall issue on
Ironlake.
Signed-off-by: Nanhai Zou <nanhai.zou@intel.com>
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
commit 7064fef56369c9e2c6e35ff6d6b4b63d42a859ce upstream.
We did this on the userspace side, but we need a similar fix for the
kernel.
Fixes LP #460664.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit ca9ab10033d190c1ede85fdf456307bdfdabf079 upstream.
The driver requires shmfs as the backing filesystem to handle the buffer
objects, so ensure it is selected if the user chooses to build our
driver.
Fixes: Bug 14662 - Dell E5500 kernel panic with KMS
http://bugzilla.kernel.org/show_bug.cgi?id=14662
The revealing nature of the panic is the NULL function pointer
dereference in read_cache_page_async().
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reported-and-tested-by: Mateusz Kaduk <mateusz.kaduk@gmail.com>
0c45:613e.
commit f077b0a64856c5b3bf346ae9fba8631c1fb210cf upstream.
Let 0c45:60fc in sn9c102 and 0c45:613e in gspca-sonixj (sensor not supported).
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
commit 1f78a976ce18bc98e8b509cee04c5b3756098614 upstream.
commit 47f7f6fb7949b6546baf4b6f26bf0ca075d12759 upstream.
- bad sensor power
- bad edge gain/threshold
- set back the auto gain
- light frequency filter inverted
commit 6baefab531b22288be3b4ddef5671ea6469b09f8 upstream.
Signed-off-by: Denis Loginov <dinvlad@gmail.com>
commit d8f400efc1ef7b344e07590fb6b77431bc358ba0 upstream.
commit 707ca1e30f087f9a6d144693dafc4b67880678c2 upstream.
The VIDIOC_G_STD ioctl may not be present in the case of radio receivers.
In that case G_STD will return an error. The v4l1-compat layer should not
attempt to propagate that error to the caller, instead it should be
ignored.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
commit 3addbb8075c00e2a2408c192bd1002dead26b2aa upstream.
Double mutexlock found by the Linux Driver Verification project and
reported by Alexander Strakh.
(rev 1)
commit 0bc3518019f917a370935055f07698a4e9b3ea20 upstream.
Address yet another regression introduced by the introduction of the zl10353
disable_i2c_gate field.
djh - I unmangled the patch which apparently got screwed up in the user's
email client.
Signed-off-by: Robert Lowery <rglowery@exemail.com.au>
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
commit d77b81974521c82fa6fda38dfff1b491dcc62a32 upstream.
In commit 0de51088e6a82bc8413d3ca9e28bbca2788b5b53, we introduced the
use of acpi-cpufreq on VIA/Centaur CPU's by removing a vendor check for
VENDOR_INTEL. However, as it turns out, at least the Nano CPU's also
need the PDC (processor driver capabilities) handshake in order to
activate the methods required for acpi-cpufreq.
Since arch_acpi_processor_init_pdc() contains another vendor check for
Intel, the PDC is not initialized on VIA CPU's. The resulting behavior
of a current mainline kernel on such systems is: acpi-cpufreq
loads and it indicates CPU frequency changes. However, the CPU stays at
a single frequency
This trivial patch ensures that init_intel_pdc() is called on Intel and
VIA/Centaur CPU's alike.
Signed-off-by: Harald Welte <HaraldWelte@viatech.com>
commit 80a8d1228e90349b4514e8c925c061fa5cbcea75 upstream.
The returned error should be negative
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 45ba564d765d6165330e9bb14a197bdd348c114d upstream.
The /dev/rfkill ops don't refer to the module,
so it is possible to unload the module while
file descriptors are open. Fix this oversight.
Reported-by: Maxim Levitsky <maximlevitsky@gmail.com>
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
commit 18c6951091eca7645005a71b556106cc99a6f4b1 upstream.
As shown in http://thread.gmane.org/gmane.linux.kernel.wireless.general/36497,
mac80211 has a bug that allows a call to the TX routine after the queues have
been stopped. This situation will only occur under extreme stress. Although
b43 does not crash when this condition occurs, it does generate a WARN_ON and
also logs a queue overrun message. This patch recognizes b43 is not at fault
and logs a message only when the most verbose debugging mode is enabled. In
the unlikely event that the queue is not stopped when the DMA queue becomes
full, then a warning is issued.
During testing of this patch with one output stream running repeated tcpperf
writes and a second running a flood ping, this routine was entered with
the DMA ring stopped about once per hour. The condition where the DMA queue is
full but the ring has not been stopped has never been seen by me.
Cc: Michael Buesch <mb@bu3sch.de>
commit 827d42c9ac91ddd728e4f4a31fefb906ef2ceff7 upstream.
Lennert Buytenhek noticed that delBA handling in mac80211
was broken and has remotely triggerable problems, some of
which are due to some code shuffling I did that ended up
changing the order in which things were done -- this was
commit d75636ef9c1af224f1097941879d5a8db7cd04e5
Author: Johannes Berg <johannes@sipsolutions.net>
Date: Tue Feb 10 21:25:53 2009 +0100
mac80211: RX aggregation: clean up stop session
and other parts were already present in the original
commit d92684e66091c0f0101819619b315b4bb8b5bcc5
Author: Ron Rindjunsky <ron.rindjunsky@intel.com>
Date: Mon Jan 28 14:07:22 2008 +0200
mac80211: A-MPDU Tx add delBA from recipient support
The first problem is that I moved a BUG_ON before various
checks -- thereby making it possible to hit. As the comment
indicates, the BUG_ON can be removed since the ampdu_action
callback must already exist when the state is != IDLE.
The second problem isn't easily exploitable but there's a
race condition due to unconditionally setting the state to
OPERATIONAL when a delBA frame is received, even when no
aggregation session was ever initiated. All the drivers
accept stopping the session even then, but that opens a
race window where crashes could happen before the driver
accepts it. Right now, a WARN_ON may happen with non-HT
drivers, while the race opens only for HT drivers.
For this case, there are two things necessary to fix it:
1) don't process spurious delBA frames, and be more careful
about the session state; don't drop the lock
2) HT drivers need to be prepared to handle a session stop
even before the session was really started -- this is
true for all drivers (that support aggregation) but
iwlwifi which can be fixed easily. The other HT drivers
(ath9k and ar9170) are behaving properly already.
Reported-by: Lennert Buytenhek <buytenh@marvell.com>
commit 4253119acf412fd686ef4bd8749b5a4d70ea3a51 upstream.
Lennert Buytenhek noticed a remotely triggerable problem
in mac80211, which is due to some code shuffling I did
that ended up changing the order in which things were
done -- this was in
The problem is that the BUG_ON moved before the various
checks, and as such can be triggered.
As the comment indicates, the BUG_ON can be removed since
the ampdu_action callback must already exist when the
state is OPERATIONAL.
A similar code path leads to a WARN_ON in
ieee80211_stop_tx_ba_session, which can also be removed.
Cc: Lennert Buytenhek <buytenh@marvell.com>
commit e9ff5eb2ae018fe2298c68746c873bf828c6b10e upstream.
This patch fixes two issues:
a) Infinite loop in resume function
b) Writes to non-existing registers in resume function
Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
commit 50b6bce59d154b5db137907a5c0ed45a4e7a3829 upstream.
When we get a stream suspend event force the power down since otherwise
the stream would remain marked as active. In future we'll probably want
to make this stream-specific and add an interface to make the power down
of other widgets optional in order to support leaving bypass paths
active while suspending the processor.
Reported-by: Joonyoung Shim <jy0922.shim@samsung.com>
Tested-by: Joonyoung Shim <jy0922.shim@samsung.com>
commit 1b7323965a8c6eee9dc4e345a7ae4bff1dc93149 upstream.
The comment in fuse_open about O_DIRECT:
"VFS checks this, but only _after_ ->open()"
also holds for fuse_create, however, the same kind of check was missing there.
As an impact of this bug, open(newfile, O_RDWR|O_CREAT|O_DIRECT) fails, but a
stub newfile will remain if the fuse server handled the implied FUSE_CREATE
request appropriately.
Other impact: in the above situation ima_file_free() will complain to open/free
imbalance if CONFIG_IMA is set.
Signed-off-by: Csaba Henk <csaba@gluster.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: Harshavardhana <harsha@gluster.com>
commit 96d25e532234bec1a1989e6e1baf702d43a78b0d upstream.
Changeset a65318bf3afc93ce49227e849d213799b072c5fd (NFSv4: Simplify some
cache consistency post-op GETATTRs) incorrectly changed the getattr
bitmap for readdir().
This causes the readdir() function to fail to return a
fileid/inode number, which again exposed a bug in the NFS readdir code that
causes spurious ENOENT errors to appear in applications (see
http://bugzilla.kernel.org/show_bug.cgi?id=14541).
The immediate band aid is to revert the incorrect bitmap change, but more
long term, we should change the NFS readdir code to cope with the
fact that NFSv4 servers are not required to support fileids/inode numbers.
Reported-by: Daniel J Blueman <daniel.blueman@gmail.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit c09c59e6a070d6af05f238f255aea268185273ef upstream.
While running fsstress tests on the NFSv4 mounted ext3 and ext4
filesystem, the following call trace was generated on the nfs
server machine.
Replace GFP_KERNEL with GFP_NOFS in ima_iint_insert() to avoid a
potential deadlock.
[ INFO: inconsistent lock state ]
2.6.31-31.el6.x86_64 #1
inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage.
kswapd2/75 [HC0[0]:SC0[0]:HE1:SE1] takes:
(jbd2_handle){+.+.?.}, at: [<ffffffff811edd5e>] jbd2_journal_start+0xfe/0x13f
{RECLAIM_FS-ON-W} state was registered at:
[<ffffffff81091e40>] mark_held_locks+0x65/0x99
[<ffffffff81091f31>] lockdep_trace_alloc+0xbd/0xf5
[<ffffffff81126fdd>] kmem_cache_alloc+0x40/0x185
[<ffffffff812344d7>] ima_iint_insert+0x3d/0xf1
[<ffffffff812345b0>] ima_inode_alloc+0x25/0x44
[<ffffffff811484ac>] inode_init_always+0xec/0x271
[<ffffffff81148682>] alloc_inode+0x51/0xa1
[<ffffffff81148700>] new_inode+0x2e/0x94
[<ffffffff811b2f08>] ext4_new_inode+0xb8/0xdc9
[<ffffffff811be611>] ext4_create+0xcf/0x175
[<ffffffff8113e2cd>] vfs_create+0x82/0xb8
[<ffffffff8113f337>] do_filp_open+0x32c/0x9ee
[<ffffffff811309b9>] do_sys_open+0x6c/0x12c
[<ffffffff81130adc>] sys_open+0x2e/0x44
[<ffffffff81011e42>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
irq event stamp: 90371
hardirqs last enabled at (90371): [<ffffffff8112708d>]
kmem_cache_alloc+0xf0/0x185
hardirqs last disabled at (90370): [<ffffffff81127026>]
kmem_cache_alloc+0x89/0x185
softirqs last enabled at (89492): [<ffffffff81068ecf>]
__do_softirq+0x1bf/0x1eb
softirqs last disabled at (89477): [<ffffffff8101312c>] call_softirq+0x1c/0x30
2 locks held by kswapd2/75:
#0: (shrinker_rwsem){++++..}, at: [<ffffffff810f98ba>] shrink_slab+0x44/0x177
#1: (&type->s_umount_key#25){++++..}, at: [<ffffffff811450ba>]
Reported-by: Muni P. Beerakam <mbeeraka@in.ibm.com>
Reported-by: Amit K. Arora <amitarora@in.ibm.com>
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit d01032e4fd33110f9f3a085a36cb819c1dfc5827 upstream
Turn on RTS/CTS for HT to prevent uCode TX fifo underrun
This is fix for
http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2103
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Tested-by: Jiajia Zheng <jiajia.zheng@intel.com>
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
commit 73871f7181a1406c67e93c8c83f5edb26057a2a6 upstream
When 802.11g was introduced, we had RTS/CTS and CTS-to-Self protection
mechanisms. In an HT Beacon, HT stations use the "Operating Mode" field
in the HT Information Element to determine whether or not to use
protection.
The Operating Mode field has 4 possible settings: 0-3:
Mode 0: If all stations in the BSS are 20/40 MHz HT capable, or if the
BSS is 20/40 MHz capable, or if all stations in the BSS are 20 MHz HT
stations in a 20 MHz BSS
Mode 1: used if there are non-HT stations or APs using the primary or
secondary channels
Mode 2: if only HT stations are associated in the BSS and at least one
20 MHz HT station is associated.
Mode 3: used if one or more non-HT stations are associated in the BSS.
When in operating modes 1 or 3, and the Use_Protection field is 1 in the
Beacon's ERP IE, all HT transmissions must be protected using RTS/CTS or
CTS-to-Self.
By default, CTS-to-self is the preferred protection mechanism for less
overhead and higher throughput; but using the full RTS/CTS will better
protect the inner exchange from interference, especially in
highly-congested environment.
For 6000 series WIFI NIC, RTS/CTS protection mechanism is the
recommended choice for HT traffic based on the HW design.
commit 5294bea40666db5c5d6c336b8e4e55d69fa576ca upstream.
The scratchpad_free() function uses xhci->page_size to free some memory
with pci_free_consistent(). However, the page_size is set to zero before
the call, causing kernel oopses on driver unload. Call scratchpad_free()
before setting xhci->page_size to zero.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Acked-by: John Youn <John.Youn@synopsys.com>
commit 2fa88daa6f299bfb83672c3b525d786ad03b4735 upstream.
The trb_in_td() function in the xHCI driver is supposed to translate a
physical transfer buffer request (TRB) into a virtual pointer to the ring
segment that TRB is in.
Unfortunately, a mistake in this function may cause endless loops as the
driver searches through the linked list of ring segments over and over
again. Fix a couple bugs that may lead to loops or bad output:
1. Bail out if we get a NULL pointer when translating the segment's
private structure and the starting DMA address of the segment chunk. If
this happens, we've been handed a starting TRB pointer from a different
ring.
2. Make sure the function works when there's multiple segments in the
ring. In the while loop to search through the ring segments, use the
current segment variable (cur_seg), rather than the starting segment
variable (start_seg) that is passed in.
3. Stop searching the ring if we've run through all the segments in the
ring.
commit d94c05e33d9212ee67b8d4998f984cc71df8168b upstream.
If the xHCI driver fails during the memory initialization, xhci->ir_set
may not be a valid pointer. Check that it points to valid DMA'able memory
before writing to that address during the memory freeing process.
commit 18a77b5d237a67d2c621a46f5271a3b51da1b380 upstream.
If acm_rx_tasklet() gets called before tty_port_block_til_ready()
returns, then bulk IN urbs may not be sent. This fixes it.
Signed-off-by: Henry Gebhardt <gebhardt@astro.uni-tuebingen.de>
Acked-by: Oliver Neukum <oliver@neukum.org>
commit ff854ce0b17161a86b5ae444c6cb0aa221720fab upstream.
Add D-Link DWM-162-U5 device id 1e0e:ce16 into option driver. The device
has 4 interfaces, of which 1 is handled by storage and the other 3 by
option driver.
The device appears first as CD-only 05c6:2100 device and must be
switched to 1e0e:ce16 mode either by using "eject CD" or usb_modeswitch.
The MessageContent for usb_modeswitch.conf is:
"55534243e0c26a85000000000000061b000000020000000000000000000000"
Signed-off-by: Zhang Le <r0bertz@gentoo.org>
commit fca94748c5136ff390eadc443871b82f1f77dcd6 upstream.
This patch (as1299b) fixes a bug in an error-handling path of usbmon's
binary interface. The storage area for URB data is divided into
fixed-size blocks. If an URB's data can't be copied, the area
reserved for it should be decreased to the size of the truncated
information (rounded up to a block boundary). Rounding up the amount
to be removed and subtracting it from the reserved size is definitely
the wrong thing to do.
Also, when the data for an isochronous URB can't be copied, we can
still copy the isoc packet descriptors. In fact the current code does
copy the descriptors, but then sets the capture length to 0 so they
remain inaccessible. The capture length should be reduced to the
length of the descriptors, not set to 0.
Acked-by: Pete Zaitcev <zaitcev@redhat.com>
commit a1f17a872bc7b1cb7efdd5486a2963e88a536e61 upstream.
The following patch in the driver is required to avoid USB 1.1 device
failures that may occur due to requests from USB OHCI controllers may
be overwritten if the latency for any pending request by the USB
controller is very long (in the range of milliseconds).
Signed-off-by: Libin Yang <libin.yang@amd.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Alan Stern <stern@rowland.harvard.edu>
commit d94c7bd4c1361cab58a21d530078c5673863dcc2 upstream.
Original discussion:
http://thread.gmane.org/gmane.linux.usb.general/23217/focus=23248
or
http://marc.info/?l=linux-usb&m=125553790714133&w=2
9a68e39d4a701fb3be03cae9b462408664ebd205 broke carrier handling so that a
cp210x setup which needed the carrier lines set up (non CLOCAL) which did
not make a call which set the termios bits left the lines down even if
CLOCAL was not asserted.
Fix this not by reverting but by adding the proper dtr_rts and
carrier_raised methods. This both sets the modem lines properly and also
implements the correct blocking semantics for the port as required by
POSIX.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reported-by: Karl Hiramoto <karl@hiramoto.org>
Tested-by: Karl Hiramoto <karl@hiramoto.org>
commit 4175f3e31cc7157669aa66d46dc79de6ae0126ce upstream.
or
The tty_port code inherited a bug common to various drivers it was based
upon. If the tty is opened O_NONBLOCK we do not wait for the carrier to be
raised but we must still raise our modem lines if appropriate.
(There is a second question here about whether we should do so if CLOCAL is
set but that can wait)
after direct reclaim failed
commit cc4a6851466039a8a688c843962a05689059ff3b upstream.
If a direct reclaim makes no forward progress, it considers whether it
should go OOM or not. Whether OOM is triggered or not, it may retry the
allocation afterwards. In times past, this would always wake kswapd as
well but currently, kswapd is not woken up after direct reclaim fails.
For order-0 allocations, this makes little difference but if there is a
heavy mix of higher-order allocations that direct reclaim is failing for,
it might mean that kswapd is not rewoken for higher orders as much as it
did previously.
This patch wakes up kswapd when an allocation is being retried after a
direct reclaim failure. It would be expected that kswapd is already
awake, but this has the effect of telling kswapd to reclaim at the higher
order as well.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
