commit d7824370e26325c881b665350ce64fb0a4fde24a upstream.
This commit makes the stack guard page somewhat less visible to user
space. It does this by:
- not showing the guard page in /proc/<pid>/maps
It looks like lvm-tools will actually read /proc/self/maps to figure
out where all its mappings are, and effectively do a specialized
"mlockall()" in user space. By not showing the guard page as part of
the mapping (by just adding PAGE_SIZE to the start for grows-up
pages), lvm-tools ends up not being aware of it.
- by also teaching the _real_ mlock() functionality not to try to lock
the guard page.
That would just expand the mapping down to create a new guard page,
so there really is no point in trying to lock it in place.
It would perhaps be nice to show the guard page specially in
/proc/<pid>/maps (or at least mark grow-down segments some way), but
let's not open ourselves up to more breakage by user space from programs
that depends on the exact deails of the 'maps' file.
Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools
source code to see what was going on with the whole new warning.
Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be
Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit 11ac552477e32835cb6970bf0a70c210807f5673 upstream.
We do in fact need to unmap the page table _before_ doing the whole
stack guard page logic, because if it is needed (mainly 32-bit x86 with
PAE and CONFIG_HIGHPTE, but other architectures may use it too) then it
will do a kmap_atomic/kunmap_atomic.
And those kmaps will create an atomic region that we cannot do
allocations in. However, the whole stack expand code will need to do
anon_vma_prepare() and vma_lock_anon_vma() and they cannot do that in an
atomic region.
Now, a better model might actually be to do the anon_vma_prepare() when
_creating_ a VM_GROWSDOWN segment, and not have to worry about any of
this at page fault time. But in the meantime, this is the
straightforward fix for the issue.
See https://bugzilla.kernel.org/show_bug.cgi?id=16588 for details.
Reported-by: Wylda <wylda@volny.cz>
Reported-by: Sedat Dilek <sedat.dilek@gmail.com>
Reported-by: Mike Pagano <mpagano@gentoo.org>
Reported-by: François Valenduc <francois.valenduc@tvcablenet.be>
Tested-by: Ed Tomlinson <edt@aei.ca>
Cc: Pekka Enberg <penberg@kernel.org>
commit 96054569190bdec375fe824e48ca1f4e3b53dd36 upstream.
It's wrong for several reasons, but the most direct one is that the
fault may be for the stack accesses to set up a previous SIGBUS. When
we have a kernel exception, the kernel exception handler does all the
fixups, not some user-level signal handler.
Even apart from the nested SIGBUS issue, it's also wrong to give out
kernel fault addresses in the signal handler info block, or to send a
SIGBUS when a system call already returns EFAULT.
commit 5528f9132cf65d4d892bcbc5684c61e7822b21e9 upstream.
.. which didn't show up in my tests because it's a no-op on x86-64 and
most other architectures. But we enter the function with the last-level
page table mapped, and should unmap it at exit.
commit 320b2b8de12698082609ebbc1a17165727f4c893 upstream.
This is a rather minimally invasive patch to solve the problem of the
user stack growing into a memory mapped area below it. Whenever we fill
the first page of the stack segment, expand the segment down by one
page.
Now, admittedly some odd application might _want_ the stack to grow down
into the preceding memory mapping, and so we may at some point need to
make this a process tunable (some people might also want to have more
than a single page of guarding), but let's try the minimal approach
first.
Tested with trivial application that maps a single page just below the
stack, and then starts recursing. Without this, we will get a SIGSEGV
_after_ the stack has smashed the mapping. With this patch, we'll get a
nice SIGBUS just as the stack touches the page just above the mapping.
Requested-by: Keith Packard <keithp@keithp.com>
commit 966cca029f739716fbcc8068b8c6dfe381f86fc3 upstream.
Since 2.6.31, swap_map[]'s refcounting was changed to show that a used
swap entry is just for swap-cache, can be reused. Then, while scanning
free entry in swap_map[], a swap entry may be able to be reclaimed and
reused. It was caused by commit c9e444103b5e7a5 ("mm: reuse unused swap
entry if necessary").
But this caused deta corruption at resume. The scenario is
- Assume a clean-swap cache, but mapped.
- at hibernation_snapshot[], clean-swap-cache is saved as
clean-swap-cache and swap_map[] is marked as SWAP_HAS_CACHE.
- then, save_image() is called. And reuse SWAP_HAS_CACHE entry to save
image, and break the contents.
After resume:
- the memory reclaim runs and finds clean-not-referenced-swap-cache and
discards it because it's marked as clean. But here, the contents on
disk and swap-cache is inconsistent.
Hance memory is corrupted.
This patch avoids the bug by not reclaiming swap-entry during hibernation.
This is a quick fix for backporting.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Reported-by: Ondreg Zary <linux@rainbow-software.org>
Tested-by: Ondreg Zary <linux@rainbow-software.org>
Tested-by: Andrea Gelmini <andrea.gelmini@gmail.com>
commit e555190d82c0f58e825e3cbd9e6ebe2e7ac713bd upstream.
When a raid1 array is configured to support write-behind
on some devices, it normally only reads from other devices.
If all devices are write-behind (because the rest have failed)
it is possible for a read request to be serviced before a
behind-write request, which would appear as data corruption.
So when forced to read from a WriteMostly device, wait for any
write-behind to complete, and don't start any more behind-writes.
Signed-off-by: NeilBrown <neilb@suse.de>
commit daa142d1773dd3a986f02a8a4da929608d24daaa upstream.
If a command times out resulting in EH getting invoked, we wait for the
aborted commands to come back after sending the abort. Shorten
the amount of time we wait for these responses, to ensure we don't
get stuck in EH for several minutes.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit f5832fa2f8dc39adcf3ae348d2d6383163235e79 upstream.
Commands which are completed by the VIOS are placed on a CRQ
in kernel memory for the ibmvfc driver to process. Each CRQ
entry is 16 bytes. The ibmvfc driver reads the first 8 bytes
to check if the entry is valid, then reads the next 8 bytes to get
the handle, which is a pointer the completed command. This fixes
an issue seen on Power 7 where the processor reordered the
loads from memory, resulting in processing command completion
with a stale handle. This could result in command timeouts,
and also early completion of commands.
commit 534ef056db8a8fb6b9d50188d88ed5d1fbc66673 upstream.
When removing several devices aic79xx will occasionally Oops
in ahd_handle_nonpkt_busfree during rescan. Looking at the
code I found that we're indeed not checking if the scb in
question is NULL. So check for it before accessing it.
Signed-off-by: Hannes Reinecke <hare@suse.de>
commit 02246c41171097ceab3246f6dc251ac89de6004b upstream.
Update mtime when writing to backing filesystem using the address space
operations write_begin and write_end.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
commit ee860b6a650360c91f5d5f9a94262aad9be90015 upstream.
ocfs2_lock() will skip locks on file which has mode set to 02666. This
is a problem in cases where the mode of the file is changed after a
process has obtained a lock on the file.
ocfs2_lock() should skip the check for mandatory locks when unlocking a
file.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
Signed-off-by: Neil Brown <neilb@suse.de>
commit 57b09bb5e492c37c1e4273fe4e435ffd1d2ddbe0 upstream.
We have to set MS_POSIXACL on remount as well. Otherwise VFS
would not know we started supporting ACLs after remount and
thus ACLs would not work.
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
commit 38a04e432768ec0b016f3c687b4de31ac111ae59 upstream.
ocfs2 refcount tree is stored as an extent tree while
the leaf ocfs2_refcount_rec points to a refcount block.
The following step can trip a kernel panic.
mkfs.ocfs2 -b 512 -C 1M --fs-features=refcount $DEVICE
mount -t ocfs2 $DEVICE $MNT_DIR
FILE_NAME=$RANDOM
FILE_NAME_1=$RANDOM
FILE_REF="${FILE_NAME}_ref"
FILE_REF_1="${FILE_NAME}_ref_1"
for((i=0;i<305;i++))
do
# /mnt/1048576 is a file with 1048576 sizes.
cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME
cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1
done
for((i=0;i<3;i++))
do
done
for((i=0;i<2;i++))
do
done
for((i=0;i<11;i++))
do
done
reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF
# write_f is a program which will write some bytes to a file at offset.
# write_f -f file_name -l offset -w write_bytes.
./write_f -f $MNT_DIR/$FILE_REF -l $[310*1048576] -w 4096
./write_f -f $MNT_DIR/$FILE_REF -l $[306*1048576] -w 4096
./write_f -f $MNT_DIR/$FILE_REF -l $[311*1048576] -w 4096
./write_f -f $MNT_DIR/$FILE_NAME -l $[310*1048576] -w 4096
./write_f -f $MNT_DIR/$FILE_NAME -l $[311*1048576] -w 4096
reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF_1
#kernel panic here.
The reason is that if the ocfs2_extent_rec is the last record
in a leaf extent block, the old solution fails to find the
suitable end cpos. So this patch try to walk through the b-tree,
find the next sub root and get the c_pos the next sub-tree starts
from.
btw, I have runned tristan's test case against the patched kernel
for several days and this type of kernel panic never happens again.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
commit cf6620acc0f6fac57968aafef79ab372bdcf6157 upstream.
When the lock master processes a successful operation (request,
convert, cancel, or unlock), it will process the effects of the
change before sending the reply for the operation. The "effects"
of the operation are:
- blocking callbacks (basts) for any newly granted locks
- waiting or converting locks that can now be granted
The cast is queued on the local node when the reply from the lock
master is received. This means that a lock holder can receive a
bast for a lock mode that is doesn't yet know has been granted.
Signed-off-by: David Teigland <teigland@redhat.com>
commit 7fe2b3190b8b299409f13cf3a6f85c2bd371f8bb upstream.
When both blocking and completion callbacks are queued for lock,
the dlm would always deliver the completion callback (cast) first.
In some cases the blocking callback (bast) is queued before the
cast, though, and should be delivered first. This patch keeps
track of the order in which they were queued and delivers them
in that order.
This patch also keeps track of the granted mode in the last cast
and eliminates the following bast if the bast mode is compatible
with the preceding cast mode. This happens when a remotely mastered
lock is demoted, e.g. EX->NL, in which case the local node queues
a cast immediately after sending the demote message. In this way
a cast can be queued for a mode, e.g. NL, that makes an in-transit
bast extraneous.
commit 573c24c4af6664ffcd9aa7ba617a35fde2b95534 upstream.
Replace all GFP_KERNEL and ls_allocation with GFP_NOFS.
ls_allocation would be GFP_KERNEL for userland lockspaces
and GFP_NOFS for file system lockspaces.
It was discovered that any lockspaces on the system can
affect all others by triggering memory reclaim in the
file system which could in turn call back into the dlm
to acquire locks, deadlocking dlm threads that were
shared by all lockspaces, like dlm_recv.
commit 6cb4aff0a77cc0e6bae9475d62205319e3ebbf3f upstream.
Commit 57fe60df ("reiserfs: add atomic addition of selinux attributes
during inode creation") contains a bug that will cause it to oops when
mounting a file system that didn't previously contain extended attributes
on a system using security.* xattrs.
The issue is that while creating the privroot during mount
reiserfs_security_init calls reiserfs_xattr_jcreate_nblocks which
dereferences the xattr root. The xattr root doesn't exist, so we get an
oops.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=15309
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 3f8b5ee33293d43ca360771b535dfae8c57259dc upstream.
The reiserfs journal behaves inconsistently when determining whether to
allow a mount of a read-only device.
This is due to the use of the continue_replay variable to short circuit
the journal scanning. If it's set, it's assumed that there are
transactions to replay, but there may not be. If it's unset, it's assumed
that there aren't any, and that may not be the case either.
I've observed two failure cases:
1) Where a clean file system on a read-only device refuses to mount
2) Where a clean file system on a read-only device passes the
optimization and then tries writing the journal header to update
the latest mount id.
The former is easily observable by using a freshly created file system on
a read-only loopback device.
This patch moves the check into journal_read_transaction, where it can
bail out before it's about to replay a transaction. That way it can go
through and skip transactions where appropriate, yet still refuse to mount
a file system with outstanding transactions.
commit 15121c18a22ae483279f76dc9e554334b800d0f7 upstream.
We have 2 mount options, "barrier" and "auto_da_alloc" which may or
may not take a 1/0 argument. This causes the ext4 superblock mount
code to subtract uninitialized pointers and pass the result to
kmalloc, which results in very noisy failures.
Per Ted's suggestion, initialize the args struct so that
we know whether match_token() found an argument for the
option, and skip match_int() if not.
Also, return error (0) from parse_options if we thought
we found an argument, but match_int() Fails.
Reported-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Acked-by: Jeff Mahoney <jeffm@suse.com>
commit 1f5a81e41f8b1a782c68d3843e9ec1bfaadf7d72 upstream.
Dan Roseberg has reported a problem with the MOVE_EXT ioctl. If the
donor file is an append-only file, we should not allow the operation
to proceed, lest we end up overwriting the contents of an append-only
file.
Cc: Dan Rosenberg <dan.j.rosenberg@gmail.com>
commit 455c0d71d46e86b0b7ff2c9dcfc19bc162302ee9 upstream.
Earlier, Ingo Molnar posted a patch to make it so that the kernel would avoid
reading _PPC on his broken T60. Unfortunately, it seems that with Thomas
Renninger's patch last July to eliminate _PPC evaluations when the processor
driver loads, the kernel never actually reads _PPC at all! This is problematic
if you happen to boot your non-T60 computer in a state where the BIOS _wants_
_PPC to be something other than zero.
So, put the _PPC evaluation back into acpi_processor_get_performance_info if
ignore_ppc isn't 1.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 8d3d50bf1913561ef3b1f5b53115c5a481ba9b1e upstream.
During a EEH recover, the pci_dev structure can be null, mainly if an
eeh event is detected during cpi config operation. In this case, the
pci_dev will not be known (and will be null) the kernel will crash
with the following message:
Unable to handle kernel paging request for data at address 0x000000a0
Faulting instruction address: 0xc00000000006b8b4
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c00000000006b8b4] .eeh_event_handler+0x10c/0x1a0
LR [c00000000006b8a8] .eeh_event_handler+0x100/0x1a0
Call Trace:
[c0000003a80dff00] [c00000000006b8a8] .eeh_event_handler+0x100/0x1a0
[c0000003a80dff90] [c000000000031f1c] .kernel_thread+0x54/0x70
The bug occurs because pci_name() tries to access a null pointer.
This patch just guarantee that pci_name() is not called on Null pointers.
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Signed-off-by: Linas Vepstas <linasvepstas@gmail.com>
commit 1668bfd5be9d8a52536c4865000fbbe065a3613b upstream.
Don't try to isolate a still mapped page. Otherwise we will hit the
BUG_ON(page_mapped(page)) in __remove_from_page_cache().
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
commit 9b9a29ecd75e310f75a9243e1c3538ad34598fcb upstream.
(PG_swapbacked && !PG_lru) pages should not happen.
Better to treat them as unknown pages.
commit fad539956c9e69749a03f7817d22d1bab87657bf upstream.
Iranna D Ankad reported that IBM x3950 systems have boot
problems after this commit:
| commit b9c61b70075c87a8612624736faf4a2de5b1ed30
| x86/pci: update pirq_enable_irq() to setup io apic routing
The problem is that with the patch, the machine freezes when
console=ttyS0,... kernel serial parameter is passed.
It seem to freeze at DVD initialization and the whole problem
seem to be DVD/pata related, but somehow exposed through the
serial parameter.
Such apic problems can expose really weird behavior:
ACPI: IOAPIC (id[0x10] address[0xfecff000] gsi_base[0])
IOAPIC[0]: apic_id 16, version 0, address 0xfecff000, GSI 0-2
ACPI: IOAPIC (id[0x0f] address[0xfec00000] gsi_base[3])
IOAPIC[1]: apic_id 15, version 0, address 0xfec00000, GSI 3-38
ACPI: IOAPIC (id[0x0e] address[0xfec01000] gsi_base[39])
IOAPIC[2]: apic_id 14, version 0, address 0xfec01000, GSI 39-74
ACPI: INT_SRC_OVR (bus 0 bus_irq 1 global_irq 4 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 5 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 3 global_irq 6 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 4 global_irq 7 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 6 global_irq 9 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 7 global_irq 10 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 8 global_irq 11 low edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 12 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 12 global_irq 15 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 13 global_irq 16 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 17 low edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 18 dfl dfl)
It turns out that the system has three io apic controllers, but
boot ioapic routing is in the second one, and that gsi_base is
not 0 - it is using a bunch of INT_SRC_OVR...
So these recent changes:
1. one set routing for first io apic controller
2. assume irq = gsi
... will break that system.
So try to remap those gsis, need to seperate boot_ioapic_idx
detection out of enable_IO_APIC() and call them early.
So introduce boot_ioapic_idx, and remap_ioapic_gsi()...
-v2: shift gsi with delta instead of gsi_base of boot_ioapic_idx
-v3: double check with find_isa_irq_apic(0, mp_INT) to get right
boot_ioapic_idx
-v4: nr_legacy_irqs
-v5: add print out for boot_ioapic_idx, and also make it could be
applied for current kernel and previous kernel
-v6: add bus_irq, in acpi_sci_ioapic_setup, so can get overwride
for sci right mapping...
-v7: looks like pnpacpi get irq instead of gsi, so need to revert
them back...
-v8: split into two patches
-v9: according to Eric, use fixed 16 for shifting instead of remap
-v10: still need to touch rsparser.c
-v11: just revert back to way Eric suggest...
anyway the ioapic in first ioapic is blocked by second...
-v12: two patches, this one will add more loop but check apic_id and irq > 16
Reported-by: Iranna D Ankad <iranna.ankad@in.ibm.com>
Bisected-by: Iranna D Ankad <iranna.ankad@in.ibm.com>
Tested-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: len.brown@intel.com
LKML-Reference: <4B8A321A.1000008@kernel.org>
commit ea0854170c95245a258b386c7a9314399c949fe0 upstream.
Newly added memory can not be accessed via /dev/mem, because we do not
update the variables high_memory, max_pfn and max_low_pfn.
Add a function update_end_of_memory_vars() to update these variables for
64-bit kernels.
[akpm@linux-foundation.org: simplify comment]
Signed-off-by: Shaohui Zheng <shaohui.zheng@intel.com>
Cc: Li Haicheng <haicheng.li@intel.com>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 863b557a88f8c033f7419fabafef4712a5055f85 upstream.
When load aesni-intel and ghash_clmulni-intel driver,kernel will complain no
test for some internal used algorithm.
The strange information as following:
alg: No test for __aes-aesni (__driver-aes-aesni)
alg: No test for __ecb-aes-aesni (__driver-ecb-aes-aesni)
alg: No test for __cbc-aes-aesni (__driver-cbc-aes-aesni)
alg: No test for __ecb-aes-aesni (cryptd(__driver-ecb-aes-aesni)
alg: No test for __ghash (__ghash-pclmulqdqni)
alg: No test for __ghash (cryptd(__ghash-pclmulqdqni))
This patch add NULL test entries for these algorithm and driver.
Signed-off-by: Song Youquan <youquan.song@intel.com>
Signed-off-by: Hang Ying <ying.huang@intel.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit e2a465675dc089e9a56ba2fa2a5fbd9bd8844d18 upstream.
It's possible that SBA IOMMU might fail to find I/O space under heavy
I/Os. SBA IOMMU panics on allocation failure but it shouldn't; drivers
can handle the failure. The majority of other IOMMU drivers don't panic
on allocation failure.
This patch fixes SBA IOMMU path to handle allocation failure properly.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Acked-by: Leonardo Chiquitto <lchiquitto@novell.com>
commit 4b402210486c6414fe5fbfd85934a0a22da56b04 upstream.
Due to recent load-balancer changes that delay the task migration to
the next wakeup, the adaptive mutex spinning ends up in a live lock
when the owner's CPU gets offlined because the cpu_online() check
lives before the owner running check.
This patch changes mutex_spin_on_owner() to return 0 (don't spin) in
any case where we aren't sure about the owner struct validity or CPU
number, and if the said CPU is offline. There is no point going back &
re-evaluate spinning in corner cases like that, let's just go to
sleep.
LKML-Reference: <1271212509.13059.135.camel@pasglop>
commit 0cf55e1ec08bb5a22e068309e2d8ba1180ab4239 upstream.
This is a real fix for problem of utime/stime values decreasing
described in the thread:
http://lkml.org/lkml/2009/11/3/522
Now cputime is accounted in the following way:
- {u,s}time in task_struct are increased every time when the thread
is interrupted by a tick (timer interrupt).
- When a thread exits, its {u,s}time are added to signal->{u,s}time,
after adjusted by task_times().
- When all threads in a thread_group exits, accumulated {u,s}time
(and also c{u,s}time) in signal struct are added to c{u,s}time
in signal struct of the group's parent.
So {u,s}time in task struct are "raw" tick count, while
{u,s}time and c{u,s}time in signal struct are "adjusted" values.
And accounted values are used by:
- task_times(), to get cputime of a thread:
This function returns adjusted values that originates from raw
{u,s}time and scaled by sum_exec_runtime that accounted by CFS.
- thread_group_cputime(), to get cputime of a thread group:
This function returns sum of all {u,s}time of living threads in
the group, plus {u,s}time in the signal struct that is sum of
adjusted cputimes of all exited threads belonged to the group.
The problem is the return value of thread_group_cputime(),
because it is mixed sum of "raw" value and "adjusted" value:
group's {u,s}time = foreach(thread){{u,s}time} + exited({u,s}time)
This misbehavior can break {u,s}time monotonicity.
Assume that if there is a thread that have raw values greater
than adjusted values (e.g. interrupted by 1000Hz ticks 50 times
but only runs 45ms) and if it exits, cputime will decrease (e.g.
-5ms).
To fix this, we could do:
group's {u,s}time = foreach(t){task_times(t)} + exited({u,s}time)
But task_times() contains hard divisions, so applying it for
every thread should be avoided.
This patch fixes the above problem in the following way:
- Modify thread's exit (= __exit_signal()) not to use task_times().
It means {u,s}time in signal struct accumulates raw values instead
of adjusted values. As the result it makes thread_group_cputime()
to return pure sum of "raw" values.
- Introduce a new function thread_group_times(*task, *utime, *stime)
that converts "raw" values of thread_group_cputime() to "adjusted"
values, in same calculation procedure as task_times().
- Modify group's exit (= wait_task_zombie()) to use this introduced
thread_group_times(). It make c{u,s}time in signal struct to
have adjusted values like before this patch.
- Replace some thread_group_cputime() by thread_group_times().
This replacements are only applied where conveys the "adjusted"
cputime to users, and where already uses task_times() near by it.
(i.e. sys_times(), getrusage(), and /proc/<PID>/stat.)
This patch have a positive side effect:
- Before this patch, if a group contains many short-life threads
(e.g. runs 0.9ms and not interrupted by ticks), the group's
cputime could be invisible since thread's cputime was accumulated
after adjusted: imagine adjustment function as adj(ticks, runtime),
{adj(0, 0.9) + adj(0, 0.9) + ....} = {0 + 0 + ....} = 0.
After this patch it will not happen because the adjustment is
applied after accumulated.
v2:
- remove if()s, put new variables into signal_struct.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Spencer Candland <spencer@bluehost.com>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
LKML-Reference: <4B162517.8040909@jp.fujitsu.com>
commit 761b1d26df542fd5eb348837351e4d2f3bc7bffe upstream.
Originally task_s/utime() were designed to return clock_t but
later changed to return cputime_t by following commit:
commit efe567fc8281661524ffa75477a7c4ca9b466c63
Author: Christian Borntraeger <borntraeger@de.ibm.com>
Date: Thu Aug 23 15:18:02 2007 +0200
It only changed the type of return value, but not the
implementation. As the result the granularity of task_s/utime()
is still that of clock_t, not that of cputime_t.
So using task_s/utime() in __exit_signal() makes values
accumulated to the signal struct to be rounded and coarse
grained.
This patch removes casts to clock_t in task_u/stime(), to keep
granularity of cputime_t over the calculation.
v2:
Use div_u64() to avoid error "undefined reference to `__udivdi3`"
on some 32bit systems.
Cc: xiyou.wangcong@gmail.com
LKML-Reference: <4AFB9029.9000208@jp.fujitsu.com>
commit 0696b711e4be45fa104c12329f617beb29c03f78 upstream.
Since commit 0a544198 "timekeeping: Move NTP adjusted clock multiplier
to struct timekeeper" the clock multiplier of vsyscall is updated with
the unmodified clock multiplier of the clock source and not with the
NTP adjusted multiplier of the timekeeper.
This causes user space observerable time warps:
new CLOCK-warp maximum: 120 nsecs, 00000025c337c537 -> 00000025c337c4bf
Add a new argument "mult" to update_vsyscall() and hand in the
timekeeping internal NTP adjusted multiplier.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Cc: "Zhang Yanmin" <yanmin_zhang@linux.intel.com>
LKML-Reference: <1258436990.17765.83.camel@minggr.sh.intel.com>
Signed-off-by: Kurt Garloff <garloff@suse.de>
commit eed3b9cf3fe3fcc7a50238dfcab63a63914e8f42 upstream.
On a system with NOHZ=y tick_check_idle calls tick_nohz_stop_idle and
tick_nohz_update_jiffies. Given the right conditions (ts->idle_active
and/or ts->tick_stopped) both function get a time stamp with ktime_get.
The same time stamp can be reused if both function require one.
On s390 this change has the additional benefit that gcc inlines the
tick_nohz_stop_idle function into tick_check_idle. The number of
instructions to execute tick_check_idle drops from 225 to 144
(without the ktime_get optimization it is 367 vs 215 instructions).
before:
0) | tick_check_idle() {
0) | tick_nohz_stop_idle() {
0) | ktime_get() {
0) | read_tod_clock() {
0) 0.601 us | }
0) 1.765 us | }
0) 3.047 us | }
0) | ktime_get() {
0) 0.570 us | }
0) 1.727 us | }
0) | tick_do_update_jiffies64() {
0) 0.609 us | }
0) 8.055 us | }
after:
0) | ktime_get() {
0) 0.617 us | }
0) 1.773 us | }
0) 0.593 us | }
0) 4.477 us | }
Cc: john stultz <johnstul@us.ibm.com>
LKML-Reference: <20090929122533.206589318@de.ibm.com>
Acked-by: John Jolly <jjolly@suse.de>
commit 3c5d92a0cfb5103c0d5ab74d4ae6373d3af38148 upstream.
Allow the architecture to request a normal jiffy tick when the system
goes idle and tick_nohz_stop_sched_tick is called . On s390 the hook is
used to prevent the system going fully idle if there has been an
interrupt other than a clock comparator interrupt since the last wakeup.
On s390 the HiperSockets response time for 1 connection ping-pong goes
down from 42 to 34 microseconds. The CPU cost decreases by 27%.
LKML-Reference: <20090929122533.402715150@de.ibm.com>
commit da495ecc0fb096b383754952a1c152147bc95b52 upstream.
We kstrdup the options string, but then strsep screws with the pointer,
so when we kfree() it, we're not giving it the right pointer.
Tested-by: Andy Lutomirski <luto@mit.edu>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
commit 3f6fae9559225741c91f1320090b285da1413290 upstream.
My test do: fallocate a big file and do write. The file is 512M, but
after file write is done btrfs-debug-tree shows:
item 6 key (257 EXTENT_DATA 0) itemoff 3516 itemsize 53
extent data disk byte 1103101952 nr 536870912
extent data offset 0 nr 399634432 ram 536870912
extent compression 0
Looks like a regression introducted by
6c7d54ac87f338c479d9729e8392eca3f76e11e1, where we set wrong slot.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Acked-by: Yan Zheng <zheng.yan@oracle.com>
commit 23b5c50945f2294add0137799400329c0ebba290 upstream.
This version of the i_size fix for fallocate makes sure we only update
the i_size when the current fallocate is really operating outside of
i_size.
commit efd049fb26a162c3830fd3cb1001fdc09b147f3b upstream.
When running the following fio job
[torrent]
filename=torrent-test
rw=randwrite
size=4g
filesize=4g
bs=4k
ioengine=sync
you would see long stalls where no work was being done. That is because we were
doing all this extra work to read in the file extent outside of the transaction,
however in the random io case this ends up hurting us because the file extents
are not there to begin with. So axe this logic, since we end up reading in the
file extent when we go to update it anyway. This took the fio job from 11 mb/s
with several ~10 second stalls to 24 mb/s to a couple of 1-2 second stalls.
Signed-off-by: Josef Bacik <josef@redhat.com>
commit 7a7965f83e89f0be506a96769938a721e4e5ae50 upstream.
When dropping a empty tree, walk_down_tree() skips checking
extent information for the tree root. This will triggers a
BUG_ON in walk_up_proc().
Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
commit d7ce5843bb28ada6845ab2ae8510ba3f12d33154 upstream.
Mounting a bad filesystem caused a BUG_ON(). The following is steps to
reproduce it.
# mkfs.btrfs /dev/sda2
# mount /dev/sda2 /mnt
# mkfs.btrfs /dev/sda1 /dev/sda2
(the program says that /dev/sda2 was mounted, and then exits. )
# umount /mnt
# mount /dev/sda1 /mnt
At the third step, mkfs.btrfs exited in the way of make filesystem. So the
initialization of the filesystem didn't finish. So the filesystem was bad, and
it caused BUG_ON() when mounting it. But BUG_ON() should be called by the wrong
code, not user's operation, so I think it is a bug of btrfs.
This patch fixes it.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
commit 014e4ac4f7d9c981750491fa40ea35efadc9ed49 upstream.
It appears the error return should be negative
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
commit f044ba7835b84e69c68b620ca8fa27e5ef67759d upstream.
Increase extent buffer's reference count while holding the lock.
Otherwise it can race with try_release_extent_buffer.
commit 035fe03a7ad56982b30ab3a522b7b08d58feccd0 upstream.
If you have a disk failure in RAID1 and then add a new disk to the
array, and then try to remove the missing volume, it will fail. The
reason is the sanity check only looks at the total number of rw devices,
which is just 2 because we have 2 good disks and 1 bad one. Instead
check the total number of devices in the array to make sure we can
actually remove the device. Tested this with a failed disk setup and
with this test we can now run
btrfs-vol -r missing /mount/point
and it works fine.
commit 7f59203abeaf18bf3497b308891f95a4489810ad upstream.
Hit this problem while testing RAID1 failure stuff. open_bdev_exclusive
returns ERR_PTR(), not NULL. So change the return value properly. This
is important if you accidently specify a device that doesn't exist when
trying to add a new device to an array, you will panic the box
dereferencing bdev.
commit f48b90756bd834dda852ff514f2690d3175b1f44 upstream.
If a RAID setup has chunks that span multiple disks, and one of those
disks has failed, btrfs_chunk_readonly will return 1 since one of the
disks in that chunk's stripes is dead and therefore not writeable. So
instead if we are in degraded mode, return 0 so we can go ahead and
allocate stuff. Without this patch all of the block groups in a RAID1
setup will end up read-only, which will mean we can't add new disks to
the array since we won't be able to make allocations.
commit e3acc2a6850efff647f1c5458524eb3a8bcba20a upstream.
This patch revert's commit
6c090a11e1c403b727a6a8eff0b97d5fb9e95cb5
Since it introduces this problem where we can run orphan cleanup on a
volume that can have orphan entries re-added. Instead of my original
fix, Yan Zheng pointed out that we can just revert my original fix and
then run the orphan cleanup in open_ctree after we look up the fs_root.
I have tested this with all the tests that gave me problems and this
patch fixes both problems. Thanks,
commit f858153c367a397235d3e81136741e40e44faf1d upstream.
In btrfs_init_acl() cloned acl is not released
Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com>
