commit 2f640bf4c94324aeaa1b6385c10aab8c5ad1e1cf upstream.
The 8020i protocol (also 8070i and QIC-157) uses 12-byte commands;
shorter commands must be padded. Simon Detheridge reports that his
3-TB USB disk drive claims to use the 8020i protocol (which is
normally meant for ATAPI devices like CD drives), and because of its
large size, the disk drive requires the use of 16-byte commands.
However the usb_stor_pad12_command() routine in usb-storage always
sets the command length to 12, making the drive impossible to use.
Since the SFF-8020i specification allows for 16-byte commands in
future extensions, we may as well accept them. This patch (as1490)
changes usb_stor_pad12_command() to leave commands larger than 12
bytes alone rather than truncating them.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Simon Detheridge <simon@widgit.com>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
commit b1ffb4c851f185e9051ba837c16d9b84ef688d26 upstream.
Fix for ftdi_set_termios() glitching output
ftdi_set_termios() is constantly setting the baud rate, data bits and parity
unnecessarily on every call, . When called while characters are being
transmitted can cause the FTDI chip to corrupt the serial port bit stream
output by stalling the output half a bit during the output of a character.
Simple fix by skipping this setting if the baud rate/data bits/parity are
unchanged.
Signed-off-by: Andrew Worsley <amworsley@gmail.com>
commit 0c16595539b612fe948559433dda08ff96a8bdc7 upstream.
I get report from customer that his usb-serial
converter doesn't work well,it sometimes work,
but sometimes it doesn't.
The usb-serial converter's id:
vendor_id product_id
0x4348 0x5523
Then I search the usb-serial codes, and there are
two drivers announce support this device, pl2303
and ch341, commit 026dfaf1 cause it. Through many
times to test, ch341 works well with this device,
and pl2303 doesn't work quite often(it just work quite little).
ch341 works well with this device, so we doesn't
need pl2303 to support.I try to revert 026dfaf1 first,
but it failed. So I prepare this patch by hand to revert it.
Signed-off-by: Wang YanQing <Udknight@gmail.com>
commit 8417da6f2128008c431c7d130af6cd3d9079922e upstream.
Starting with 4.4, gcc will happily accept -Wno-<anything> in the
cc-option test and complain later when compiling a file that has some
other warning. This rather unexpected behavior is intentional as per
http://gcc.gnu.org/PR28322, so work around it by testing for support of
the opposite option (without the no-). Introduce a new Makefile function
cc-disable-warning that does this and update two uses of cc-option in
the toplevel Makefile.
Reported-and-tested-by: Stephen Rothwell <sfr@canb.auug.org.au>
commit a9cf73ea7ff78f52662c8658d93c226effbbedde upstream.
At this point, skb->data points to skb_transport_header.
So, headroom check is wrong.
For some case:bridge(UFO is on) + eth device(UFO is off),
there is no enough headroom for IPv6 frag head.
But headroom check is always false.
This will bring about data be moved to there prior to skb->head,
when adding IPv6 frag header to skb.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit f5252e009d5b87071a919221e4f6624184005368 upstream
The /proc/vmallocinfo shows information about vmalloc allocations in vmlist
that is a linklist of vm_struct. It, however, may access pages field of
vm_struct where a page was not allocated. This results in a null pointer
access and leads to a kernel panic.
Why this happen:
In __vmalloc_node() called from vmalloc(), newly allocated vm_struct
is added to vmlist at __get_vm_area_node() and then, some fields of
vm_struct such as nr_pages and pages are set at __vmalloc_area_node(). In
other words, it is added to vmlist before it is fully initialized. At the
same time, when the /proc/vmallocinfo is read, it accesses the pages field
of vm_struct according to the nr_pages field at show_numa_info(). Thus, a
null pointer access happens.
Patch:
This patch adds newly allocated vm_struct to the vmlist *after* it is fully
initialized. So, it can avoid accessing the pages field with unallocated
page when show_numa_info() is called.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream
This adds a mechanism to resume selected IRQs during syscore_resume
instead of dpm_resume_noirq.
Under Xen we need to resume IRQs associated with IPIs early enough
that the resched IPI is unmasked and we can therefore schedule
ourselves out of the stop_machine where the suspend/resume takes
place.
This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME".
Back ported to 2.6.32 (which lacks syscore support) by calling the relavant
resume function directly from sysdev_resume).
v2: Fixed non-x86 build errors.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com>
Cc: xen-devel <xen-devel@lists.xensource.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk
commit 7dcd2499deab8f10011713c40bc2f309c9b65077 upstream
... and do the same for pread.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
commit ce9d419dbecc292cc3e06e8b1d6d123d3fa813a4 upstream.
Move the access control up from the fast paths, which are no longer
universally taken first, up into the caller. This then duplicates some
sanity checking along the slow paths, but is much simpler.
Tracked as CVE-2010-2962.
Reported-by: Kees Cook <kees@ubuntu.com>
This reverts commit fdb1e4e9d85b973679d56f23ccf9017ff85fd11f.
It was wrong included in 2.6.32 stable (was intended for 2.6.38+ in the
original commit changelog in Linus tree), and causes a regression on
2.6.32 (https://launchpad.net/bugs/875300).
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
commit 55fe25b418640fad04190103274841b2c907bacd upstream.
This example file uses the old V4L1 API. It also doesn't use libv4l.
So, it is completely obsolete. A good example already exists at
v4l-utils (v4l2grab.c):
http://git.linuxtv.org/v4l-utils.git
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
commit 9a3f530f39f4490eaa18b02719fb74ce5f4d2d86 upstream.
When the number of failed devices exceeds the allowed number
we must abort any active parity operations (checks or updates) as they
are no longer meaningful, and can lead to a BUG_ON in
handle_parity_checks6.
This bug was introduce by commit 6c0069c0ae9659e3a91b68eaed06a5c6c37f45c8
in 2.6.29.
Reported-by: Manish Katiyar <mkatiyar@gmail.com>
Tested-by: Manish Katiyar <mkatiyar@gmail.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 5927f94700e860ae27ff24e7f3bc9e4f7b9922eb upstream.
Reported-by: Chris Paulson-Ellis <chris@edesix.com>
commit af0e5d565d2fffcd97d1e2d89669d627cc04e8b8 upstream.
Disable the new -Wunused-but-set-variable that was added in gcc 4.6.0
It produces more false positives than useful warnings.
This can still be enabled using W=1
[gregkh - No it can not for 2.6.32, but we don't care]
Signed-off-by: Dave Jones <davej@redhat.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Tested-by: Sam Ravnborg <sam@ravnborg.org>
commit bc5b8a9003132ae44559edd63a1623b7b99dfb68 upstream.
On a corrupted file system the ->len field could be wrong leading to
a buffer overflow.
Reported-and-acked-by: Clement LECIGNE <clement.lecigne@netasq.com>
commit 528f7ce6e439edeac38f6b3f8561f1be129b5e91 upstream.
In enter_state() we use "state" as an offset for the pm_states[]
array. The pm_states[] array only has PM_SUSPEND_MAX elements so
this test is off by one.
commit bf5140817b2d65faac9b32fc9057a097044ac35b upstream.
On writes in MODE_RAW the mtd_oob_ops struct is not sufficiently
initialized which may cause nandwrite to fail. With this patch
it is possible to write raw nand/oob data without additional ECC
(either for testing or when some sectors need different oob layout
e.g. bootloader) like
nandwrite -n -r -o /dev/mtd0 <myfile>
Signed-off-by: Peter Wippich <pewi@gw-instruments.de>
Tested-by: Ricard Wanderlof <ricardw@axis.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit c30bc94758ae2a38a5eb31767c1985c0aae0950b upstream.
L2TP for example uses NLA_MSECS like this:
policy:
[L2TP_ATTR_RECV_TIMEOUT] = { .type = NLA_MSECS, },
code:
if (info->attrs[L2TP_ATTR_RECV_TIMEOUT])
cfg.reorder_timeout = nla_get_msecs(info->attrs[L2TP_ATTR_RECV_TIMEOUT]);
As nla_get_msecs() is essentially nla_get_u64() plus the
conversion to a HZ-based value, this will not properly
reject attributes from userspace that aren't long enough
and might overrun the message.
Add NLA_MSECS to the attribute minlen array to check the
size properly.
Cc: Thomas Graf <tgraf@suug.ch>
commit dc6f55e9f8dac4b6479be67c5c9128ad37bb491f upstream.
The sunrpc layer keeps a cache of recently used credentials and
'unx_match' is used to find the credential which matches the current
process.
However unx_match allows a match when the cached credential has extra
groups at the end of uc_gids list which are not in the process group list.
So if a process with a list of (say) 4 group accesses a file and gains
access because of the last group in the list, then another process
with the same uid and gid, and a gid list being the first tree of the
gids of the original process tries to access the file, it will be
granted access even though it shouldn't as the wrong rpc credential
will be used.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 3308511c93e6ad0d3c58984ecd6e5e57f96b12c8 upstream.
Make sure that SCSI device removal via scsi_remove_host() does finish
all pending SCSI commands. Currently that's not the case and hence
removal of a SCSI host during I/O can cause a deadlock. See also
"blkdev_issue_discard() hangs forever if underlying storage device is
removed" (http://bugzilla.kernel.org/show_bug.cgi?id=40472). See also
http://lkml.org/lkml/2011/8/27/6.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit c68bf8eeaa57c852e74adcf597237be149eef830 upstream.
The call to complete() in st_scsi_execute_end() wakes up sleeping thread
in write_behind_check(), which frees the st_request, thus invalidating
the pointer to the associated bio structure, which is then passed to the
blk_rq_unmap_user(). Fix by storing pointer to bio structure into
temporary local variable.
This bug is present since at least linux-2.6.32.
Signed-off-by: Petr Uzel <petr.uzel@suse.cz>
Reported-by: Juergen Groß <juergen.gross@ts.fujitsu.com>
Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi>
This reverts commit 1badd98ea79b7b20fb4ddfea110d1bb99c33a55f.
It breaks the build on powerpc systems:
arch/powerpc/sysdev/mpic.c: In function 'irq_choose_cpu':
arch/powerpc/sysdev/mpic.c:574: error: passing argument 1 of '__cpus_equal' from incompatible pointer type
Reported-by: Jiri Slaby <jslaby@suse.cz>
Cc: Jiajun Wu <b06378@freescale.com>
Cc: Li Yang <leoli@freescale.com>
This reverts commit d85b1ce7fd0ecfdd43e8c3e67eb953900c209939.
It breaks the build and probably shouldn't be in the 2.6.32 kernel
Reported-by: Stefan Bader <stefan.bader@canonical.com>
Cc: Chris Paulson-Ellis <chris@edesix.com>
Cc: Axel Lin <axel.lin@gmail.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
This reverts commit 0f12a6ad9fa3a03f2bcee36c9cb704821e244c40.
It causes too many build errors and needs to be done properly.
Reported-by: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
Cc: Ian Campbell <ian.campbell@citrix.com>
commit ce7e9065958191e6b7ca49d7ed0e1099c486d198 upstream.
Here is a patch for a new PID (zeitcontrol-device mifare-reader FT232BL(like FT232BM but lead free)).
Signed-off-by: Artur Zimmer <artur128@3dzimmer.de>
commit 2f1def2695c223b2aa325e5e47d0d64200a45d23 upstream.
A new device ID pair is added for Sierra Wireless MC8305.
Signed-off-by: Florian Echtler <floe@butterbrot.org>
commit 1cd9f0976aa4606db8d6e3dc3edd0aca8019372a upstream.
This doesn't make much sense, and it exposes a bug in the kernel where
attempts to create a new file in an append-only directory using
O_CREAT will fail (but still leave a zero-length file). This was
discovered when xfstests #79 was generalized so it could run on all
file systems.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit e0c87bd95e8dad455c23bc56513af8dcb1737e55 upstream.
Modify Ethernet addess macros to be compatible with BE/LE platforms
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Chul Kim <chul.kim@idt.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Does not corrispond with a direct commit in Linus's tree as it was fixed
differently in the 3.0 release.
We will meet with a BUG_ON() if following script is run.
mkfs.ext4 -b 4096 /dev/sdb1 1000000
mount -t ext4 /dev/sdb1 /mnt/sdb1
fallocate -l 100M /mnt/sdb1/test
sync
for((i=0;i<170;i++))
do
dd if=/dev/zero of=/mnt/sdb1/test conv=notrunc bs=256k count=1
seek=`expr $i \* 2`
done
umount /mnt/sdb1
dd if=/dev/zero of=/mnt/sdb1/test conv=notrunc bs=256k count=1 seek=341
umount /mnt/sdb1
mount /dev/sdb1 /mnt/sdb1
dd if=/dev/zero of=/mnt/sdb1/test conv=notrunc bs=256k count=1 seek=340
sync
The reason is that it forgot to mark dirty when splitting two extents in
ext4_ext_convert_to_initialized(). Althrough ex has been updated in
memory, it is not dirtied both in ext4_ext_convert_to_initialized() and
ext4_ext_insert_extent(). The disk layout is corrupted. Then it will
meet with a BUG_ON() when writting at the start of that extent again.
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Xiaoyun Mao <xiaoyun.maoxy@aliyun-inc.com>
Cc: Yingbin Wang <yingbin.wangyb@aliyun-inc.com>
Cc: Jia Wan <jia.wanj@aliyun-inc.com>
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
commit 53b0f08042f04813cd1a7473dacd3edfacb28eb3 upstream.
Ben Pfaff reported a kernel oops and provided a test program to
reproduce it.
https://kerneltrap.org/mailarchive/linux-netdev/2010/5/21/6277805
tc_fill_qdisc() should not be called for builtin qdisc, or it
dereference a NULL pointer to get device ifindex.
Fix is to always use tc_qdisc_dump_ignore() before calling
tc_fill_qdisc().
Reported-by: Ben Pfaff <blp@nicira.com>
commit 57a27e1d6a3bb9ad4efeebd3a8c71156d6207536 upstream.
When one of the SSID's length passed in a scan or sched_scan request
is larger than 255, there will be an overflow in the u8 that is used
to store the length before checking. This causes the check to fail
and we overrun the buffer when copying the SSID.
Fix this by checking the nl80211 attribute length before copying it to
the struct.
This is a follow up for the previous commit
208c72f4fe44fe09577e7975ba0e7fa0278f3d03, which didn't fix the problem
entirely.
Reported-by: Ido Yariv <ido@wizery.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
commit 7ac28817536797fd40e9646452183606f9e17f71 upstream.
A remote user can provide a small value for the command size field in
the command header of an l2cap configuration request, resulting in an
integer underflow when subtracting the size of the configuration request
header. This results in copying a very large amount of data via
memcpy() and destroying the kernel heap. Check for underflow.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
commit 42c36f63ac1366ab0ecc2d5717821362c259f517 upstream.
Commit a626ca6a6564 ("vm: fix vm_pgoff wrap in stack expansion") fixed
the case of an expanding mapping causing vm_pgoff wrapping when you had
downward stack expansion. But there was another case where IA64 and
PA-RISC expand mappings: upward expansion.
This fixes that case too.
commit a626ca6a656450e9f4df91d0dda238fff23285f4 upstream.
Commit 982134ba6261 ("mm: avoid wrapping vm_pgoff in mremap()") fixed
the case of a expanding mapping causing vm_pgoff wrapping when you used
mremap. But there was another case where we expand mappings hiding in
plain sight: the automatic stack expansion.
This one also found by Robert Święcki, using his nasty system call
fuzzer tool. Good job.
Reported-and-tested-by: Robert Święcki <robert@swiecki.net>
commit 8d03e971cf403305217b8e62db3a2e5ad2d6263f upstream.
Structures "l2cap_conninfo" and "rfcomm_conninfo" have one padding
byte each. This byte in "cinfo" is copied to userspace uninitialized.
Signed-off-by: Filip Palian <filip.palian@pjwstk.edu.pl>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
commit 0b760113a3a155269a3fba93a409c640031dd68f upstream.
If the NLM daemon is killed on the NFS server, we can currently end up
hanging forever on an 'unlock' request, instead of aborting. Basically,
if the rpcbind request fails, or the server keeps returning garbage, we
really want to quit instead of retrying.
Tested-by: Vasily Averin <vvs@sw.ru>
commit a9712bc12c40c172e393f85a9b2ba8db4bf59509 upstream.
All of those are rw-r--r-- and all are broken for suid - if you open
a file before the target does suid-root exec, you'll be still able
to access it. For personality it's not a big deal, but for syscall
and stack it's a real problem.
Fix: check that task is tracable for you at the time of read().
commit bba14de98753cb6599a2dae0e520714b2153522d upstream.
Lower SCM_MAX_FD from 255 to 253 so that allocations for scm_fp_list are
halved. (commit f8d570a4 added two pointers in this structure)
scm_fp_dup() should not copy whole structure (and trigger kmemcheck
warnings), but only the used part. While we are at it, only allocate
needed size.
commit 9fbdaeb4f4dd14a0caa9fc35c496d5440c251a3a upstream.
The newer Lenovo ThinkPads have HKEY HID of LEN0068 instead
of IBM0068. Added new HID so that thinkpad_acpi module will
auto load on these newer Lenovo ThinkPads.
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: stable@vger.kernel.org
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 4fd2c20d964a8fb9861045f1022475c9d200d684 upstream.
"m" is never NULL here. We need a different test for the end of list
condition.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Leonardo Chiquitto <leonardo.lists@gmail.com>
Commit 6d86a0ee (watchdog: mtx1-wdt: request gpio before using it) was
backported from upstream. The patch is using a gpiolib call which is only
available in kernel 2.6.34+. Fix build by using the "old" gpiolib API
instead.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Commit ec3eb823 was not applicable in 2.6.32 and introduces a build breakage.
Revert that commit since it is irrelevant for this kernel version.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
This reverts commit 262e2d9d559334e09bc80516132ea99d82f97b8c.
Turns out this breaks the build, and as such, really isn't needed for
the 2.6.32-stable branch at all.
Reported-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: Anand Gadiyar <gadiyar@ti.com>
Cc: Ajay Kumar Gupta <ajay.gupta@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
place.
There is no upstream commit ID for this patch since it is not a straight
backport from upstream. It is a fix only relevant to 2.6.32.y.
Since 1d5f066e0b63271b67eac6d3752f8aa96adcbddb from 2.6.37 was
back-ported to 2.6.32.40 as ad2088cabe0fd7f633f38ba106025d33ed9a2105,
the following patch is needed to add the needed reset logic to 2.6.32 as
well.
Bug #23257: Reset tsc_timestamp on TSC writes
vcpu->last_guest_tsc is updated in vcpu_enter_guest() and kvm_arch_vcpu_put()
by getting the last value of the TSC from the guest.
On reset, the SeaBIOS resets the TSC to 0, which triggers a bug on the next
call to kvm_write_guest_time(): Since vcpu->hw_clock.tsc_timestamp still
contains the old value before the reset, "max_kernel_ns = vcpu->last_guest_tsc
- vcpu->hw_clock.tsc_timestamp" gets negative. Since the variable is u64, it
gets translated to a large positive value.
[9333.197080]
vcpu->last_guest_tsc =209_328_760_015 ←
vcpu->hv_clock.tsc_timestamp=209_328_708_109
vcpu->last_kernel_ns =9_333_179_830_643
kernel_ns =9_333_197_073_429
max_kernel_ns =9_333_179_847_943 ←
[9336.910995]
vcpu->last_guest_tsc =9_438_510_584 ←
vcpu->hv_clock.tsc_timestamp=211_080_593_143
vcpu->last_kernel_ns =9_333_763_732_907
kernel_ns =9_336_910_990_771
max_kernel_ns =6_148_296_831_006_663_830 ←
For completeness, here are the values for my 3 GHz CPU:
vcpu->hv_clock.tsc_shift =-1
vcpu->hv_clock.tsc_to_system_mul =2_863_019_502
This makes the guest kernel crawl very slowly when clocksource=kvmclock is
used: sleeps take way longer than expected and don't match wall clock any more.
The times printed with printk() don't match real time and the reboot often
stalls for long times.
In linux-git this isn't a problem, since on every MSR_IA32_TSC write
vcpu->arch.hv_clock.tsc_timestamp is reset to 0, which disables above logic.
The code there is only in arch/x86/kvm/x86.c, since much of the kvm-clock
related code has been refactured for 2.6.37:
99e3e30a arch/x86/kvm/x86.c
(Zachary Amsden 2010-08-19 22:07:17 -1000 1084)
vcpu->arch.hv_clock.tsc_timestamp = 0;
Signed-off-by: Philipp Hahn <hahn@univention.de>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit f611f2da99420abc973c32cdbddbf5c365d0a20c upstream.
The patches missed an indirect use of IRQF_NO_SUSPEND pulled in via
IRQF_TIMER. The following patch fixes the issue.
With this fixlet PV guest migration works just fine. I also booted the
entire series as a dom0 kernel and it appeared fine.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit c10b61f0910466b4b99c266a7d76ac4390743fb5 upstream.
A user reported a kernel bug when running a particular program that did
the following:
created 32 threads
- each thread took a mutex, grabbed a global offset, added a buffer size
to that offset, released the lock
- read from the given offset in the file
- created a new thread to do the same
- exited
The result is that cfq's close cooperator logic would trigger, as the
threads were issuing I/O within the mean seek distance of one another.
This workload managed to routinely trigger a use after free bug when
walking the list of merge candidates for a particular cfqq
(cfqq->new_cfqq). The logic used for merging queues looks like this:
static void cfq_setup_merge(struct cfq_queue *cfqq, struct cfq_queue *new_cfqq)
int process_refs, new_process_refs;
struct cfq_queue *__cfqq;
/* Avoid a circular list and skip interim queue merges */
while ((__cfqq = new_cfqq->new_cfqq)) {
if (__cfqq == cfqq)
return;
new_cfqq = __cfqq;
process_refs = cfqq_process_refs(cfqq);
* If the process for the cfqq has gone away, there is no
* sense in merging the queues.
if (process_refs == 0)
return;
* Merge in the direction of the lesser amount of work.
new_process_refs = cfqq_process_refs(new_cfqq);
if (new_process_refs >= process_refs) {
cfqq->new_cfqq = new_cfqq;
atomic_add(process_refs, &new_cfqq->ref);
} else {
new_cfqq->new_cfqq = cfqq;
atomic_add(new_process_refs, &cfqq->ref);
When a merge candidate is found, we add the process references for the
queue with less references to the queue with more. The actual merging
of queues happens when a new request is issued for a given cfqq. In the
case of the test program, it only does a single pread call to read in
1MB, so the actual merge never happens.
Normally, this is fine, as when the queue exits, we simply drop the
references we took on the other cfqqs in the merge chain:
* If this queue was scheduled to merge with another queue, be
* sure to drop the reference taken on that queue (and others in
* the merge chain). See cfq_setup_merge and cfq_merge_cfqqs.
__cfqq = cfqq->new_cfqq;
while (__cfqq) {
if (__cfqq == cfqq) {
WARN(1, "cfqq->new_cfqq loop detected\n");
break;
next = __cfqq->new_cfqq;
cfq_put_queue(__cfqq);
__cfqq = next;
However, there is a hole in this logic. Consider the following (and
keep in mind that each I/O keeps a reference to the cfqq):
q1->new_cfqq = q2 // q2 now has 2 process references
q3->new_cfqq = q2 // q2 now has 3 process references
// the process associated with q2 exits
// queue 1 exits, drops its reference on q2
// q2 now has 1 process reference
// q3 exits, so has 0 process references, and hence drops its references
// to q2, which leaves q2 also with 0 process references
q4 comes along and wants to merge with q3
q3->new_cfqq still points at q2! We follow that link and end up at an
already freed cfqq.
So, the fix is to not follow a merge chain if the top-most queue does
not have a process reference, otherwise any queue in the chain could be
already freed. I also changed the logic to disallow merging with a
queue that does not have any process references. Previously, we did
this check for one of the merge candidates, but not the other. That
doesn't really make sense.
Without the attached patch, my system would BUG within a couple of
seconds of running the reproducer program. With the patch applied, my
system ran the program for over an hour without issues.
This addresses the following bugzilla:
https://bugzilla.kernel.org/show_bug.cgi?id=16217
Thanks a ton to Phil Carns for providing the bug report and an excellent
reproducer.
[ Note for stable: this applies to 2.6.32/33/34 ].
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Reported-by: Phil Carns <carns@mcs.anl.gov>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de>
commit e00ef7997195e4f8e10593727a6286e2e2802159 upstream
We need to rework this logic post the cooperating cfq_queue merging,
for now just get rid of it and Jeff Moyer will fix the fall out.
