[ Upstream commit e4c89a508f4385a0cd8681c2749a2cd2fa476e40 ]
Commit b298d289
"PM / Sleep: Fix freezer failures due to racy usermodehelper_is_disabled()"
added read_unlock_usermodehelper() but read_unlock_usermodehelper() is called
without read_lock_usermodehelper() when kmalloc() failed.
Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
[ Upstream commit b298d289c79211508f11cb50749b0d1d54eb244a ]
Commit a144c6a (PM: Print a warning if firmware is requested when tasks
are frozen) introduced usermodehelper_is_disabled() to warn and exit
immediately if firmware is requested when usermodehelpers are disabled.
However, it is racy. Consider the following scenario, currently used in
drivers/base/firmware_class.c:
if (usermodehelper_is_disabled())
goto out;
/* Do actual work */
out:
return err;
Nothing prevents someone from disabling usermodehelpers just after the check
in the 'if' condition, which means that it is quite possible to try doing the
"actual work" with usermodehelpers disabled, leading to undesirable
consequences.
In particular, this race condition in _request_firmware() causes task freezing
failures whenever suspend/hibernation is in progress because, it wrongly waits
to get the firmware/microcode image from userspace when actually the
usermodehelpers are disabled or userspace has been frozen.
Some of the example scenarios that cause freezing failures due to this race
are those that depend on userspace via request_firmware(), such as x86
microcode module initialization and microcode image reload.
Previous discussions about this issue can be found at:
http://thread.gmane.org/gmane.linux.kernel/1198291/focus=1200591
This patch adds proper synchronization to fix this issue.
It is to be noted that this patchset fixes the freezing failures but doesn't
remove the warnings. IOW, it does not attempt to add explicit synchronization
to x86 microcode driver to avoid requesting microcode image at inopportune
moments. Because, the warnings were introduced to highlight such cases, in the
first place. And we need not silence the warnings, since we take care of the
*real* problem (freezing failure) and hence, after that, the warnings are
pretty harmless anyway.
[ Upstream commit caca9510ff4e5d842c0589110243d60927836222 ]
In commit a144c6a6c924 ("PM: Print a warning if firmware is requested
when tasks are frozen") we not only printed a warning if somebody tried
to load the firmware when tasks are frozen - we also failed the load.
But that check was done before the check for built-in firmware, and then
when we disallowed usermode helpers during bootup (commit 288d5abec831:
"Boot up with usermodehelper disabled"), that actually means that
built-in modules can no longer load their firmware even if the firmware
is built in too. Which used to work, and some people depended on it for
the R100 driver.
So move the test for usermodehelper_is_disabled() down, to after
checking the built-in firmware.
This should fix:
https://bugzilla.kernel.org/show_bug.cgi?id=40952
Reported-by: James Cloos <cloos@hjcloos.com>
Bisected-by: Elimar Riesebieter <riesebie@lxtec.de>
Cc: Michel Dänzer <michel@daenzer.net>
Cc: Rafael Wysocki <rjw@sisk.pl>
Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu>
[ Upstream commit a144c6a6c924aa1da04dd77fb84b89927354fdff ]
Some drivers erroneously use request_firmware() from their ->resume()
(or ->thaw(), or ->restore()) callbacks, which is not going to work
unless the firmware has been built in. This causes system resume to
stall until the firmware-loading timeout expires, which makes users
think that the resume has failed and reboot their machines
unnecessarily. For this reason, make _request_firmware() print a
warning and return immediately with error code if it has been called
when tasks are frozen and it's impossible to start any new usermode
helpers.
Reviewed-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
commit 048cd4e51d24ebf7f3552226d03c769d6ad91658 upstream.
The new is_compat_task() define for the !COMPAT case in
include/linux/compat.h conflicts with a similar define in
arch/s390/include/asm/compat.h.
This is the minimal patch which fixes the build issues.
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit 3c761ea05a8900a907f32b628611873f6bef24b2 upstream.
The autofs compat handling fix caused a compile failure when
CONFIG_COMPAT isn't defined.
Instead of adding random #ifdef'fery in autofs, let's just make the
compat helpers earlier to use: without CONFIG_COMPAT, is_compat_task()
just hardcodes to zero.
We could probably do something similar for a number of other cases where
we have #ifdef's in code, but this is the low-hanging fruit.
Reported-and-tested-by: Andreas Schwab <schwab@linux-m68k.org>
commit a32744d4abae24572eff7269bc17895c41bd0085 upstream.
When the autofs protocol version 5 packet type was added in commit
5c0a32fc2cd0 ("autofs4: add new packet type for v5 communications"), it
obvously tried quite hard to be word-size agnostic, and uses explicitly
sized fields that are all correctly aligned.
However, with the final "char name[NAME_MAX+1]" array at the end, the
actual size of the structure ends up being not very well defined:
because the struct isn't marked 'packed', doing a "sizeof()" on it will
align the size of the struct up to the biggest alignment of the members
it has.
And despite all the members being the same, the alignment of them is
different: a "__u64" has 4-byte alignment on x86-32, but native 8-byte
alignment on x86-64. And while 'NAME_MAX+1' ends up being a nice round
number (256), the name[] array starts out a 4-byte aligned.
End result: the "packed" size of the structure is 300 bytes: 4-byte, but
not 8-byte aligned.
As a result, despite all the fields being in the same place on all
architectures, sizeof() will round up that size to 304 bytes on
architectures that have 8-byte alignment for u64.
Note that this is *not* a problem for 32-bit compat mode on POWER, since
there __u64 is 8-byte aligned even in 32-bit mode. But on x86, 32-bit
and 64-bit alignment is different for 64-bit entities, and as a result
the structure that has exactly the same layout has different sizes.
So on x86-64, but no other architecture, we will just subtract 4 from
the size of the structure when running in a compat task. That way we
will write the properly sized packet that user mode expects.
Not pretty. Sadly, this very subtle, and unnecessary, size difference
has been encoded in user space that wants to read packets of *exactly*
the right size, and will refuse to touch anything else.
Reported-and-tested-by: Thomas Meyer <thomas@m3y3r.de>
Signed-off-by: Ian Kent <raven@themaw.net>
commit 822bfa51ce44f2c63c300fdb76dc99c4d5a5ca9f upstream.
"nframes" comes from the user and "nframes * CD_FRAMESIZE_RAW" can wrap
on 32 bit systems. That would have been ok if we used the same wrapped
value for the copy, but we use a shifted value. We should just use the
checked version of copy_to_user() because it's not going to make a
difference to the speed.
commit 07850552b92b3637fa56767b5e460b4238014447 upstream.
eCryptfs wasn't clearing the eCryptfs inode's i_nlink after a successful
vfs_rmdir() on the lower directory. This resulted in the inode evict and
destroy paths to be missed.
https://bugs.launchpad.net/ecryptfs/+bug/723518
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
Signed-off-by: Colin King <colin.king@canonical.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit 35ffa948b2f7bdf79e488cd496232935d095087a upstream.
vfs_rmdir() already calls d_delete() on the lower dentry. That was being
duplicated in ecryptfs_rmdir() and caused a NULL pointer dereference
when NFSv3 was the lower filesystem.
BugLink: http://bugs.launchpad.net/bugs/723518
commit 5f3ef64f4da1c587cdcfaaac72311225b7df094c upstream.
When truncating inodes in the lower filesystem, eCryptfs directly
invoked vmtruncate(). As Christoph Hellwig pointed out, vmtruncate() is
a filesystem helper function, but filesystems may need to do more than
just a call to vmtruncate().
This patch moves the lower inode truncation out of ecryptfs_truncate()
and renames the function to truncate_upper(). truncate_upper() updates
an iattr for the lower inode to indicate if the lower inode needs to be
truncated upon return. ecryptfs_setattr() then calls notify_change(),
using the updated iattr for the lower inode, to complete the truncation.
For eCryptfs functions needing to truncate, ecryptfs_truncate() is
reintroduced as a simple way to truncate the upper inode to a specified
size and then truncate the lower inode accordingly.
https://bugs.launchpad.net/bugs/451368
Reported-by: Christoph Hellwig <hch@lst.de>
Acked-by: Dustin Kirkland <kirkland@canonical.com>
Cc: ecryptfs-devel@lists.launchpad.net
Cc: linux-fsdevel@vger.kernel.org
commit afa159538af61f1a65d48927f4e949fe514fb4fc upstream.
status has to be set to STREAMING before the streaming worker is
queued. hdpvr_transmit_buffers() will exit immediately otherwise.
Reported-by: Joerg Desch <vvd.joede@googlemail.com>
commit 340a3504fd39dad753ba908fb6f894ee81fc3ae2 upstream.
The xHCI 0.96 spec says that HS bulk and control endpoint NAK rate must
be encoded as an exponent of two number of microframes. The endpoint
descriptor has the NAK rate encoded in number of microframes. We were
just copying the value from the endpoint descriptor into the endpoint
context interval field, which was not correct. This lead to the VIA
host rejecting the add of a bulk OUT endpoint from any USB 2.0 mass
storage device.
The fix is to use the correct encoding. Refactor the code to convert
number of frames to an exponential number of microframes, and make sure
we convert the number of microframes in HS bulk and control endpoints to
an exponent.
This should be back ported to kernels as old as 2.6.31, that contain the
commit dfa49c4ad120a784ef1ff0717168aa79f55a483a "USB: xhci - fix math
in xhci_get_endpoint_interval"
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Tested-by: Felipe Contreras <felipe.contreras@gmail.com>
Suggested-by: Andiry Xu <andiry.xu@amd.com>
commit cab928ee1f221c9cc48d6615070fefe2e444384a upstream.
On some systems with an Intel Panther Point xHCI host controller, the
BIOS disables the xHCI PCI device during boot, and switches the xHCI
ports over to EHCI. This allows the BIOS to access USB devices without
having xHCI support.
The downside is that the xHCI BIOS handoff mechanism will fail because
memory mapped I/O is not enabled for the disabled PCI device.
Jesse Barnes says this is expected behavior. The PCI core will enable
BARs before quirks run, but it will leave it in an undefined state, and
it may not have memory mapped I/O enabled.
Make the generic USB quirk handler call pci_enable_device() to re-enable
MMIO, and call pci_disable_device() once the host-specific BIOS handoff
is finished. This will balance the ref counts in the PCI core. When
the PCI probe function is called, usb_hcd_pci_probe() will call
pci_enable_device() again.
This should be back ported to kernels as old as 2.6.31. That was the
first kernel with xHCI support, and no one has complained about BIOS
handoffs failing due to memory mapped I/O being disabled on other hosts
(EHCI, UHCI, or OHCI).
Acked-by: Oliver Neukum <oneukum@suse.de>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
commit c6c1e4491dc8d1ed2509fa6aacffa7f34614fc38 upstream.
Signed-off-by: Bruno Thomsen <bruno.thomsen@gmail.com>
commit 8e43a905dd574f54c5715d978318290ceafbe275 upstream.
Bootup with lockdep enabled has been broken on v7 since b46c0f74657d
("ARM: 7321/1: cache-v7: Disable preemption when reading CCSIDR").
This is because v7_setup (which is called very early during boot) calls
v7_flush_dcache_all, and the save_and_disable_irqs added by that patch
ends up attempting to call into lockdep C code (trace_hardirqs_off())
when we are in no position to execute it (no stack, MMU off).
Fix this by using a notrace variant of save_and_disable_irqs. The code
already uses the notrace variant of restore_irqs.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Rabin Vincent <rabin@rab.in>
commit b46c0f74657d1fe1c1b0c1452631cc38a9e6987f upstream.
armv7's flush_cache_all() flushes caches via set/way. To
determine the cache attributes (line size, number of sets,
etc.) the assembly first writes the CSSELR register to select a
cache level and then reads the CCSIDR register. The CSSELR register
is banked per-cpu and is used to determine which cache level CCSIDR
reads. If the task is migrated between when the CSSELR is written and
the CCSIDR is read the CCSIDR value may be for an unexpected cache
level (for example L1 instead of L2) and incorrect cache flushing
could occur.
Disable interrupts across the write and read so that the correct
cache attributes are read and used for the cache flushing
routine. We disable interrupts instead of disabling preemption
because the critical section is only 3 instructions and we want
to call v7_dcache_flush_all from __v7_setup which doesn't have a
full kernel stack with a struct thread_info.
This fixes a problem we see in scm_call() when flush_cache_all()
is called from preemptible context and sometimes the L2 cache is
not properly flushed out.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit 53ca353594a254e6bd45ccf2d405aa31bcbb7091 upstream.
This small patch fixes a bug in the 3w-9xxx driver where it would load
an invalid sgl address in the ioctl path even if request length was zero.
Signed-off-by: Adam Radford <aradford@gmail.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 323ef68faf1bbd9b1e66aea268fd09d358d7e8ab upstream.
read() calls against a file descriptor connected to a directory are
incorrectly returning EINVAL rather than EISDIR:
[EISDIR]
[XSI] [Option Start] The fildes argument refers to a directory and the
implementation does not allow the directory to be read using read()
or pread(). The readdir() function should be used instead. [Option End]
This occurs because we do not have a .read operation defined for
ecryptfs directories. Connect this up to generic_read_dir().
BugLink: http://bugs.launchpad.net/bugs/719691
Signed-off-by: Andy Whitcroft <apw@canonical.com>
commit b7f5b7dec3d539a84734f2bcb7e53fbb1532a40b upstream.
MSI_REARM_EN register is a write only trigger register.
There is no need RMW when re-arming.
May fix:
https://bugs.freedesktop.org/show_bug.cgi?id=41668
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit f2ea0f5f04c97b48c88edccba52b0682fbe45087 upstream.
Use standard ror64() instead of hand-written.
There is no standard ror64, so create it.
The difference is shift value being "unsigned int" instead of uint64_t
(for which there is no reason). gcc starts to emit native ROR instructions
which it doesn't do for some reason currently. This should make the code
faster.
Patch survives in-tree crypto test and ping flood with hmac(sha512) on.
CVE-2011-1833
(backported from commit 764355487ea220fdc2faf128d577d7f679b91f97)
Close a TOCTOU race for mounts done via ecryptfs-mount-private. The mount
source (device) can be raced when the ownership test is done in userspace.
Provide Ecryptfs a means to force the uid check at mount time.
BugLink: http://bugs.launchpad.net/bugs/732628
Signed-off-by: John Johansen <john.johansen@canonical.com>
Signed-off-by: Tyler Hicks <tyler.hicks@canonical.com>
(cherry picked from commit 4403158ba295c8e36f6736b1bb12d0f7e1923dac)
This is a seriously simplified patch from Eric Sandeen; copy of
rationale follows:
mounting stacked ecryptfs on ecryptfs has been shown to lead to bugs
in testing. For crypto info in xattr, there is no mechanism for handling
this at all, and for normal file headers, we run into other trouble:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffffa015b0b3>] ecryptfs_d_revalidate+0x43/0xa0 [ecryptfs]
There doesn't seem to be any good usecase for this, so I'd suggest just
disallowing the configuration.
Based on a patch originally, I believe, from Mike Halcrow.
backported from 38e3eaeedcac75360af8a92e7b66956ec4f334e5
Adrian reported that mkfontscale didn't work inside of eCryptfs mounts.
Strace revealed the following:
open("./", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY|O_CLOEXEC) = 3
fcntl64(3, F_GETFD) = 0x1 (flags FD_CLOEXEC)
open("./fonts.scale", O_WRONLY|O_CREAT|O_TRUNC, 0666) = 4
getdents(3, /* 80 entries */, 32768) = 2304
open("./.", O_RDONLY) = 5
fcntl64(5, F_SETFD, FD_CLOEXEC) = 0
fstat64(5, {st_mode=S_IFDIR|0755, st_size=16384, ...}) = 0
mmap2(NULL, 16384, PROT_READ, MAP_PRIVATE, 5, 0) = 0xb7fcf000
close(5) = 0
--- SIGBUS (Bus error) @ 0 (0) ---
+++ killed by SIGBUS +++
The mmap2() on a directory was successful, resulting in a SIGBUS
signal later. This patch removes mmap() from the list of possible
ecryptfs_dir_fops so that mmap() isn't possible on eCryptfs directory
files.
http://bugs.launchpad.net/bugs/400443
Reported-by: Adrian C. <anrxc@sysphere.org>
commit 3a92d687c8015860a19213e3c102cad6b722f83c upstream.
Unfortunately in reducing W from 80 to 16 we ended up unrolling
the loop twice. As gcc has issues dealing with 64-bit ops on
i386 this means that we end up using even more stack space (>1K).
This patch solves the W reduction by moving LOAD_OP/BLEND_OP
into the loop itself, thus avoiding the need to duplicate it.
While the stack space still isn't great (>0.5K) it is at least
in the same ball park as the amount of stack used for our C sha1
implementation.
Note that this patch basically reverts to the original code so
the diff looks bigger than it really is.
commit 58d7d18b5268febb8b1391c6dffc8e2aaa751fcd upstream.
The previous patch used the modulus operator over a power of 2
unnecessarily which may produce suboptimal binary code. This
patch changes changes them to binary ands instead.
commit 09e87e5c4f9af656af2a8a3afc03487c5d9287c3 upstream.
In order to enable temperature mode aka automatic mode for the F75373 and
F75375 chips, the two FANx_MODE bits in the fan configuration register
need be set to 01, not 10.
Signed-off-by: Nikolaus Schulz <mail@microschulz.de>
commit d8521fcc5e0ad3e79bbc4231bb20a6cdc2b50164 upstream.
ratelimit_state initialization of printk_ratelimited() seems broken. This
fixes it by using DEFINE_RATELIMIT_STATE() to initialize spinlock
properly.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Joe Perches <joe@perches.com>
Cc: Sven-Haegar Koch <haegar@sdinet.de>
commit bb1dc0bacb8ddd7ba6a5906c678a5a5a110cf695 upstream.
When __ratelimit() returns 1 this means that we can go ahead.
Signed-off-by: Yong Zhang <yong.zhang@windriver.com>
commit 07ae2dfcf4f7143ce191c6436da1c33f179af0d6 upstream.
The current code checks for stored_mpdu_num > 1, causing
the reorder_timer to be triggered indefinitely, but the
frame is never timed-out (until the next packet is received)
Signed-off-by: Eliad Peller <eliad@wizery.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
commit f6302f1bcd75a042df69866d98b8d775a668f8f1 upstream.
"subbuf_size" and "n_subbufs" come from the user and they need to be
capped to prevent an integer overflow.
commit 3310225dfc71a35a2cc9340c15c0e08b14b3c754 upstream.
PROP_MAX_SHIFT should be set to <=32 on 64-bit box. This fixes two bugs
in the below lines of bdi_dirty_limit():
bdi_dirty *= numerator;
do_div(bdi_dirty, denominator);
1) divide error: do_div() only uses the lower 32 bit of the denominator,
which may trimmed to be 0 when PROP_MAX_SHIFT > 32.
2) overflow: (bdi_dirty * numerator) could easily overflow if numerator
used up to 48 bits, leaving only 16 bits to bdi_dirty
Reported-by: Ilya Tumaykin <librarian_rus@yahoo.com>
Tested-by: Ilya Tumaykin <librarian_rus@yahoo.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
commit eb2f255b2d360df3f500042a2258dcf2fcbe89a2 upstream.
In order to extract the high byte of the 16-bit word, shift the word to
the right, not to the left.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit e57b6886f555ab57f40a01713304e2053efe51ec upstream.
According to a bug report, it doesn't have one.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44263
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Keith Packard <keithp@keithp.com>
commit b1faf5666438090a4dc4fceac8502edc7788b7e3 upstream.
Correct sk_forward_alloc handling for error_queue would need to use a
backlog of frames that softirq handler could not deliver because socket
is owned by user thread. Or extend backlog processing to be able to
process normal and error packets.
Another possibility is to not use mem charge for error queue, this is
what I implemented in this patch.
Note: this reverts commit 29030374
(net: fix sk_forward_alloc corruptions), since we dont need to lock
socket anymore.
Cc: 单卫 <shanwei88@gmail.com>
commit 2903037400a26e7c0cc93ab75a7d62abfacdf485 upstream.
As David found out, sock_queue_err_skb() should be called with socket
lock hold, or we risk sk_forward_alloc corruption, since we use non
atomic operations to update this field.
This patch adds bh_lock_sock()/bh_unlock_sock() pair to three spots.
(BH already disabled)
1) skb_tstamp_tx()
2) Before calling ip_icmp_error(), in __udp4_lib_err()
3) Before calling ipv6_icmp_error(), in __udp6_lib_err()
Reported-by: Anton Blanchard <anton@samba.org>
commit b5266ea675c5a041e2852c7ccec4cf2d4f5e0cf4 upstream.
Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
commit 90451e6973a5da155c6f315a409ca0a8d3ce6b76 upstream.
Signed-off-by: Milan Kocian <milon@wq.cz>
commit e4436a7c17ac2b5e138f93f83a541cba9b311685 upstream.
The Netlogic XLP SoC's on-chip USB controller appears as a PCI
USB device, but does not need the EHCI/OHCI handoff done in
usb/host/pci-quirks.c.
The pci-quirks.c is enabled for all vendors and devices, and is
enabled if USB and PCI are configured.
If we do not skip the qurik handling on XLP, the readb() call in
ehci_bios_handoff() will cause a crash since byte access is not
supported for EHCI registers in XLP.
Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 683da59d7b8ae04891636d4b59893cd4e9b0b7e5 upstream.
ab943a2e125b (USB: gadget: gadget zero uses new suspend/resume hooks)
introduced a copy-paste error where f_loopback.c writes to a variable
declared in f_sourcesink.c. This prevents one from creating gadgets
that only have a loopback function.
Signed-off-by: Timo Juhani Lindfors <timo.lindfors@iki.fi>
Signed-off-by: Felipe Balbi <balbi@ti.com>
processes
commit bd1eff9741af27378b241b347041c724bb28e857 upstream.
Opening the binder driver and sharing the file returned with
other processes (e.g. by calling fork) can crash the kernel.
Prevent these crashes with the following changes:
- Add a mutex to protect against two processes mmapping the
same binder_proc.
- After locking mmap_sem, check that the vma we want to access
(still) points to the same mm_struct.
- Use proc->tsk instead of current to get the files struct since
this is where we get the rlimit from.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
commit 3c1b86f17068cf6476fb2d022b9c8b44dedea2e5 upstream.
If user-space partially unmaps the driver, binder_vma_open
would dump the kernel stack. This is not a kernel bug however
and will be treated as if the whole area was unmapped once
binder_vma_close gets called.
commit 635032cb397b396241372fa0ff36ae758e658b23 upstream.
Programming an image was broken, because odev->buf_offs was not advanced
for val == 0 in append_values(). This regression was introduced in:
commit 1ff12a4aa354bed093a0240d5e6347b1e27601bc
Author: Kevin A. Granade <kevin.granade@gmail.com>
Date: Sat Sep 5 01:03:39 2009 -0500
Staging: asus_oled: Cleaned up checkpatch issues.
Fix the image processing by special-casing val == 0.
I have tested this change on an Asus G50V laptop only.
Cc: Jakub Schmidtke <sjakub@gmail.com>
Cc: Kevin A. Granade <kevin.granade@gmail.com>
Signed-off-by: Pekka Paalanen <pq@iki.fi>
commit 9f1065032ceb7e86c7c9f16bb86518857e88a172 upstream.
An error was existing in the saving of CONTRAST_CTR register
across suspend/resume.
Signed-off-by: Hubert Feurstein <h.feurstein@gmail.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
commit 684a3ff7e69acc7c678d1a1394fe9e757993fd34 upstream.
ecryptfs_write() can enter an infinite loop when truncating a file to a
size larger than 4G. This only happens on architectures where size_t is
represented by 32 bits.
This was caused by a size_t overflow due to it incorrectly being used to
store the result of a calculation which uses potentially large values of
type loff_t.
[tyhicks@canonical.com: rewrite subject and commit message]
Signed-off-by: Li Wang <liwang@nudt.edu.cn>
Signed-off-by: Yunchuan Wen <wenyunchuan@kylinos.com.cn>
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
commit 23bd15ec662344dc10e9918fdd0dbc58bc71526d upstream.
TV Out refresh rate was half of the specification for almost all modes.
Due to this reason pixel clock was so low for some modes causing flickering screen.
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
commit 853a0c25baf96b028de1654bea1e0c8857eadf3d upstream.
When we hit EIO while writing LVID, the buffer uptodate bit is cleared.
This then results in an anoying warning from mark_buffer_dirty() when we
write the buffer again. So just set uptodate flag unconditionally.
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
Cc: Dave Jones <davej@redhat.com>
commit 5fe46e9d733f19a880ef7e516002bd4c2b833e14 upstream.
If NFSv4 client send a request before connect, or the old connection was broken
because a ETIMEOUT error catched by call_status, ->send_request will return
ENOSOCK, but rpc layer can not deal with it, so make sure ->send_request can
translate ENOSOCK into ENOCONN.
Signed-off-by: Bian Naimeng <biannm@cn.fujitsu.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Chuck Lever <chuck.lever@oracle.com>
