2015-12-06Linux 2.6.32.69v2.6.32.69Willy Tarreau
Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06splice: sendfile() at once fails for big filesChristophe Leroy
commit 0ff28d9f4674d781e492bcff6f32f0fe48cf0fed upstream. Using sendfile with below small program to get MD5 sums of some files, it appear that big files (over 64kbytes with 4k pages system) get a wrong MD5 sum while small files get the correct sum. This program uses sendfile() to send a file to an AF_ALG socket for hashing. /* md5sum2.c */ #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <string.h> #include <fcntl.h> #include <sys/socket.h> #include <sys/stat.h> #include <sys/types.h> #include <linux/if_alg.h> int main(int argc, char **argv) { int sk = socket(AF_ALG, SOCK_SEQPACKET, 0); struct stat st; struct sockaddr_alg sa = { .salg_family = AF_ALG, .salg_type = "hash", .salg_name = "md5", }; int n; bind(sk, (struct sockaddr*)&sa, sizeof(sa)); for (n = 1; n < argc; n++) { int size; int offset = 0; char buf[4096]; int fd; int sko; int i; fd = open(argv[n], O_RDONLY); sko = accept(sk, NULL, 0); fstat(fd, &st); size = st.st_size; sendfile(sko, fd, &offset, size); size = read(sko, buf, sizeof(buf)); for (i = 0; i < size; i++) printf("%2.2x", buf[i]); printf(" %s\n", argv[n]); close(fd); close(sko); } exit(0); } Test below is done using official linux patch files. First result is with a software based md5sum. Second result is with the program above. root@vgoip:~# ls -l patch-3.6.* -rw-r--r-- 1 root root 64011 Aug 24 12:01 patch-3.6.2.gz -rw-r--r-- 1 root root 94131 Aug 24 12:01 patch-3.6.3.gz root@vgoip:~# md5sum patch-3.6.* b3ffb9848196846f31b2ff133d2d6443 patch-3.6.2.gz c5e8f687878457db77cb7158c38a7e43 patch-3.6.3.gz root@vgoip:~# ./md5sum2 patch-3.6.* b3ffb9848196846f31b2ff133d2d6443 patch-3.6.2.gz 5fd77b24e68bb24dcc72d6e57c64790e patch-3.6.3.gz After investivation, it appears that sendfile() sends the files by blocks of 64kbytes (16 times PAGE_SIZE). The problem is that at the end of each block, the SPLICE_F_MORE flag is missing, therefore the hashing operation is reset as if it was the end of the file. This patch adds SPLICE_F_MORE to the flags when more data is pending. With the patch applied, we get the correct sums: root@vgoip:~# md5sum patch-3.6.* b3ffb9848196846f31b2ff133d2d6443 patch-3.6.2.gz c5e8f687878457db77cb7158c38a7e43 patch-3.6.3.gz root@vgoip:~# ./md5sum2 patch-3.6.* b3ffb9848196846f31b2ff133d2d6443 patch-3.6.2.gz c5e8f687878457db77cb7158c38a7e43 patch-3.6.3.gz Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit fcb2781782b61631db4ed31e98757795eacd31cb) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06net: avoid NULL deref in inet_ctl_sock_destroy()Eric Dumazet
[ Upstream commit 8fa677d2706d325d71dab91bf6e6512c05214e37 ] Under low memory conditions, tcp_sk_init() and icmp_sk_init() can both iterate on all possible cpus and call inet_ctl_sock_destroy(), with eventual NULL pointer. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit f79c83d6c41930362bc66fc71489e92975a2facf) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06ipmr: fix possible race resulting from improper usage of IP_INC_STATS_BH() ↵Ani Sinha
in preemptible context. [ Upstream commit 44f49dd8b5a606870a1f21101522a0f9c4414784 ] Fixes the following kernel BUG : BUG: using __this_cpu_add() in preemptible [00000000] code: bash/2758 caller is __this_cpu_preempt_check+0x13/0x15 CPU: 0 PID: 2758 Comm: bash Tainted: P O 3.18.19 #2 ffffffff8170eaca ffff880110d1b788 ffffffff81482b2a 0000000000000000 0000000000000000 ffff880110d1b7b8 ffffffff812010ae ffff880007cab800 ffff88001a060800 ffff88013a899108 ffff880108b84240 ffff880110d1b7c8 Call Trace: [<ffffffff81482b2a>] dump_stack+0x52/0x80 [<ffffffff812010ae>] check_preemption_disabled+0xce/0xe1 [<ffffffff812010d4>] __this_cpu_preempt_check+0x13/0x15 [<ffffffff81419d60>] ipmr_queue_xmit+0x647/0x70c [<ffffffff8141a154>] ip_mr_forward+0x32f/0x34e [<ffffffff8141af76>] ip_mroute_setsockopt+0xe03/0x108c [<ffffffff810553fc>] ? get_parent_ip+0x11/0x42 [<ffffffff810e6974>] ? pollwake+0x4d/0x51 [<ffffffff81058ac0>] ? default_wake_function+0x0/0xf [<ffffffff810553fc>] ? get_parent_ip+0x11/0x42 [<ffffffff810613d9>] ? __wake_up_common+0x45/0x77 [<ffffffff81486ea9>] ? _raw_spin_unlock_irqrestore+0x1d/0x32 [<ffffffff810618bc>] ? __wake_up_sync_key+0x4a/0x53 [<ffffffff8139a519>] ? sock_def_readable+0x71/0x75 [<ffffffff813dd226>] do_ip_setsockopt+0x9d/0xb55 [<ffffffff81429818>] ? unix_seqpacket_sendmsg+0x3f/0x41 [<ffffffff813963fe>] ? sock_sendmsg+0x6d/0x86 [<ffffffff813959d4>] ? sockfd_lookup_light+0x12/0x5d [<ffffffff8139650a>] ? SyS_sendto+0xf3/0x11b [<ffffffff810d5738>] ? new_sync_read+0x82/0xaa [<ffffffff813ddd19>] compat_ip_setsockopt+0x3b/0x99 [<ffffffff813fb24a>] compat_raw_setsockopt+0x11/0x32 [<ffffffff81399052>] compat_sock_common_setsockopt+0x18/0x1f [<ffffffff813c4d05>] compat_SyS_setsockopt+0x1a9/0x1cf [<ffffffff813c4149>] compat_SyS_socketcall+0x180/0x1e3 [<ffffffff81488ea1>] cstar_dispatch+0x7/0x1e Signed-off-by: Ani Sinha <ani@arista.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 3.2: ipmr doesn't implement IPSTATS_MIB_OUTOCTETS] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 33cf84ba8c25b40c7de52029efc8d4372725c95f) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06RDS-TCP: Recover correctly from pskb_pull()/pksb_trim() failure in ↵Sowmini Varadhan
rds_tcp_data_recv [ Upstream commit 8ce675ff39b9958d1c10f86cf58e357efaafc856 ] Either of pskb_pull() or pskb_trim() may fail under low memory conditions. If rds_tcp_data_recv() ignores such failures, the application will receive corrupted data because the skb has not been correctly carved to the RDS datagram size. Avoid this by handling pskb_pull/pskb_trim failure in the same manner as the skb_clone failure: bail out of rds_tcp_data_recv(), and retry via the deferred call to rds_send_worker() that gets set up on ENOMEM from rds_tcp_read_sock() Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit f114d9374ba3e42c86b112c8b4dbcba50a7330e7) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06binfmt_elf: Don't clobber passed executable's file headerMaciej W. Rozycki
commit b582ef5c53040c5feef4c96a8f9585b6831e2441 upstream. Do not clobber the buffer space passed from `search_binary_handler' and originally preloaded by `prepare_binprm' with the executable's file header by overwriting it with its interpreter's file header. Instead keep the buffer space intact and directly use the data structure locally allocated for the interpreter's file header, fixing a bug introduced in 2.1.14 with loadable module support (linux-mips.org commit beb11695 [Import of Linux/MIPS 2.1.14], predating kernel.org repo's history). Adjust the amount of data read from the interpreter's file accordingly. This was not an issue before loadable module support, because back then `load_elf_binary' was executed only once for a given ELF executable, whether the function succeeded or failed. With loadable module support supported and enabled, upon a failure of `load_elf_binary' -- which may for example be caused by architecture code rejecting an executable due to a missing hardware feature requested in the file header -- a module load is attempted and then the function reexecuted by `search_binary_handler'. With the executable's file header replaced with its interpreter's file header the executable can then be erroneously accepted in this subsequent attempt. Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit beebd9fa9d8aeb8f1a3028acc1987c808b601e7d) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06devres: fix a for loop bounds checkDan Carpenter
commit 1f35d04a02a652f14566f875aef3a6f2af4cb77b upstream. The iomap[] array has PCIM_IOMAP_MAX (6) elements and not DEVICE_COUNT_RESOURCE (16). This bug was found using a static checker. It may be that the "if (!(mask & (1 << i)))" check means we never actually go past the end of the array in real life. Fixes: ec04b075843d ('iomap: implement pcim_iounmap_regions()') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit e7102453150c7081a27744989374c474d2ebea8e) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06HID: core: Avoid uninitialized buffer accessRichard Purdie
commit 79b568b9d0c7c5d81932f4486d50b38efdd6da6d upstream. hid_connect adds various strings to the buffer but they're all conditional. You can find circumstances where nothing would be written to it but the kernel will still print the supposedly empty buffer with printk. This leads to corruption on the console/in the logs. Ensure buf is initialized to an empty string. Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org> [dvhart: Initialize string to "" rather than assign buf[0] = NULL;] Cc: Jiri Kosina <jikos@kernel.org> Cc: linux-input@vger.kernel.org Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 604bfd00358e3d7fce8dc789fe52d2f2be0fa4c7) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06ethtool: Use kcalloc instead of kmalloc for ethtool_get_stringsJoe Perches
[ Upstream commit 077cb37fcf6f00a45f375161200b5ee0cd4e937b ] It seems that kernel memory can leak into userspace by a kmalloc, ethtool_get_strings, then copy_to_user sequence. Avoid this by using kcalloc to zero fill the copied buffer. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 68c3e59aa9cdf2d8870d8fbe4f37b1a509d0abeb) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06mvsas: Fix NULL pointer dereference in mvs_slot_task_freeDāvis Mosāns
commit 2280521719e81919283b82902ac24058f87dfc1b upstream. When pci_pool_alloc fails in mvs_task_prep then task->lldd_task stays NULL but it's later used in mvs_abort_task as slot which is passed to mvs_slot_task_free causing NULL pointer dereference. Just return from mvs_slot_task_free when passed with NULL slot. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=101891 Signed-off-by: Dāvis Mosāns <davispuh@gmail.com> Reviewed-by: Tomas Henzl <thenzl@redhat.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit cc1875ecbc3c9fb2774097e03870280c91c1e0e1) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06tty: fix stall caused by missing memory barrier in drivers/tty/n_tty.cKosuke Tatsukawa
commit e81107d4c6bd098878af9796b24edc8d4a9524fd upstream. My colleague ran into a program stall on a x86_64 server, where n_tty_read() was waiting for data even if there was data in the buffer in the pty. kernel stack for the stuck process looks like below. #0 [ffff88303d107b58] __schedule at ffffffff815c4b20 #1 [ffff88303d107bd0] schedule at ffffffff815c513e #2 [ffff88303d107bf0] schedule_timeout at ffffffff815c7818 #3 [ffff88303d107ca0] wait_woken at ffffffff81096bd2 #4 [ffff88303d107ce0] n_tty_read at ffffffff8136fa23 #5 [ffff88303d107dd0] tty_read at ffffffff81368013 #6 [ffff88303d107e20] __vfs_read at ffffffff811a3704 #7 [ffff88303d107ec0] vfs_read at ffffffff811a3a57 #8 [ffff88303d107f00] sys_read at ffffffff811a4306 #9 [ffff88303d107f50] entry_SYSCALL_64_fastpath at ffffffff815c86d7 There seems to be two problems causing this issue. First, in drivers/tty/n_tty.c, __receive_buf() stores the data and updates ldata->commit_head using smp_store_release() and then checks the wait queue using waitqueue_active(). However, since there is no memory barrier, __receive_buf() could return without calling wake_up_interactive_poll(), and at the same time, n_tty_read() could start to wait in wait_woken() as in the following chart. __receive_buf() n_tty_read() ------------------------------------------------------------------------ if (waitqueue_active(&tty->read_wait)) /* Memory operations issued after the RELEASE may be completed before the RELEASE operation has completed */ add_wait_queue(&tty->read_wait, &wait); ... if (!input_available_p(tty, 0)) { smp_store_release(&ldata->commit_head, ldata->read_head); ... timeout = wait_woken(&wait, TASK_INTERRUPTIBLE, timeout); ------------------------------------------------------------------------ The second problem is that n_tty_read() also lacks a memory barrier call and could also cause __receive_buf() to return without calling wake_up_interactive_poll(), and n_tty_read() to wait in wait_woken() as in the chart below. __receive_buf() n_tty_read() ------------------------------------------------------------------------ spin_lock_irqsave(&q->lock, flags); /* from add_wait_queue() */ ... if (!input_available_p(tty, 0)) { /* Memory operations issued after the RELEASE may be completed before the RELEASE operation has completed */ smp_store_release(&ldata->commit_head, ldata->read_head); if (waitqueue_active(&tty->read_wait)) __add_wait_queue(q, wait); spin_unlock_irqrestore(&q->lock,flags); /* from add_wait_queue() */ ... timeout = wait_woken(&wait, TASK_INTERRUPTIBLE, timeout); ------------------------------------------------------------------------ There are also other places in drivers/tty/n_tty.c which have similar calls to waitqueue_active(), so instead of adding many memory barrier calls, this patch simply removes the call to waitqueue_active(), leaving just wake_up*() behind. This fixes both problems because, even though the memory access before or after the spinlocks in both wake_up*() and add_wait_queue() can sneak into the critical section, it cannot go past it and the critical section assures that they will be serialized (please see "INTER-CPU ACQUIRING BARRIER EFFECTS" in Documentation/memory-barriers.txt for a better explanation). Moreover, the resulting code is much simpler. Latency measurement using a ping-pong test over a pty doesn't show any visible performance drop. Signed-off-by: Kosuke Tatsukawa <tatsu@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: - Use wake_up_interruptible(), not wake_up_interruptible_poll() - There are only two spurious uses of waitqueue_active() to remove] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 80910ccdd3ee35e4131df38bc73b86ee60abdf0b) [wt: file is drivers/char/n_tty.c in 2.6.32] Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06mm: hugetlbfs: skip shared VMAs when unmapping private pages to satisfy a faultMel Gorman
commit 2f84a8990ebbe235c59716896e017c6b2ca1200f upstream. SunDong reported the following on https://bugzilla.kernel.org/show_bug.cgi?id=103841 I think I find a linux bug, I have the test cases is constructed. I can stable recurring problems in fedora22(4.0.4) kernel version, arch for x86_64. I construct transparent huge page, when the parent and child process with MAP_SHARE, MAP_PRIVATE way to access the same huge page area, it has the opportunity to lead to huge page copy on write failure, and then it will munmap the child corresponding mmap area, but then the child mmap area with VM_MAYSHARE attributes, child process munmap this area can trigger VM_BUG_ON in set_vma_resv_flags functions (vma - > vm_flags & VM_MAYSHARE). There were a number of problems with the report (e.g. it's hugetlbfs that triggers this, not transparent huge pages) but it was fundamentally correct in that a VM_BUG_ON in set_vma_resv_flags() can be triggered that looks like this vma ffff8804651fd0d0 start 00007fc474e00000 end 00007fc475e00000 next ffff8804651fd018 prev ffff8804651fd188 mm ffff88046b1b1800 prot 8000000000000027 anon_vma (null) vm_ops ffffffff8182a7a0 pgoff 0 file ffff88106bdb9800 private_data (null) flags: 0x84400fb(read|write|shared|mayread|maywrite|mayexec|mayshare|dontexpand|hugetlb) ------------ kernel BUG at mm/hugetlb.c:462! SMP Modules linked in: xt_pkttype xt_LOG xt_limit [..] CPU: 38 PID: 26839 Comm: map Not tainted 4.0.4-default #1 Hardware name: Dell Inc. PowerEdge R810/0TT6JF, BIOS 2.7.4 04/26/2012 set_vma_resv_flags+0x2d/0x30 The VM_BUG_ON is correct because private and shared mappings have different reservation accounting but the warning clearly shows that the VMA is shared. When a private COW fails to allocate a new page then only the process that created the VMA gets the page -- all the children unmap the page. If the children access that data in the future then they get killed. The problem is that the same file is mapped shared and private. During the COW, the allocation fails, the VMAs are traversed to unmap the other private pages but a shared VMA is found and the bug is triggered. This patch identifies such VMAs and skips them. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Reported-by: SunDong <sund_sky@126.com> Reviewed-by: Michal Hocko <mhocko@suse.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: David Rientjes <rientjes@google.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 846bc2d8bef1e0d253cdfabfe707f37fc8cd836d) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06x86/process: Add proper bound checks in 64bit get_wchan()Thomas Gleixner
commit eddd3826a1a0190e5235703d1e666affa4d13b96 upstream. Dmitry Vyukov reported the following using trinity and the memory error detector AddressSanitizer (https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel). [ 124.575597] ERROR: AddressSanitizer: heap-buffer-overflow on address ffff88002e280000 [ 124.576801] ffff88002e280000 is located 131938492886538 bytes to the left of 28857600-byte region [ffffffff81282e0a, ffffffff82e0830a) [ 124.578633] Accessed by thread T10915: [ 124.579295] inlined in describe_heap_address ./arch/x86/mm/asan/report.c:164 [ 124.579295] #0 ffffffff810dd277 in asan_report_error ./arch/x86/mm/asan/report.c:278 [ 124.580137] #1 ffffffff810dc6a0 in asan_check_region ./arch/x86/mm/asan/asan.c:37 [ 124.581050] #2 ffffffff810dd423 in __tsan_read8 ??:0 [ 124.581893] #3 ffffffff8107c093 in get_wchan ./arch/x86/kernel/process_64.c:444 The address checks in the 64bit implementation of get_wchan() are wrong in several ways: - The lower bound of the stack is not the start of the stack page. It's the start of the stack page plus sizeof (struct thread_info) - The upper bound must be: top_of_stack - TOP_OF_KERNEL_STACK_PADDING - 2 * sizeof(unsigned long). The 2 * sizeof(unsigned long) is required because the stack pointer points at the frame pointer. The layout on the stack is: ... IP FP ... IP FP. So we need to make sure that both IP and FP are in the bounds. Fix the bound checks and get rid of the mix of numeric constants, u64 and unsigned long. Making all unsigned long allows us to use the same function for 32bit as well. Use READ_ONCE() when accessing the stack. This does not prevent a concurrent wakeup of the task and the stack changing, but at least it avoids TOCTOU. Also check task state at the end of the loop. Again that does not prevent concurrent changes, but it avoids walking for nothing. Add proper comments while at it. Reported-by: Dmitry Vyukov <dvyukov@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Based-on-patch-from: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@alien8.de> Reviewed-by: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Kostya Serebryany <kcc@google.com> Cc: Alexander Potapenko <glider@google.com> Cc: kasan-dev <kasan-dev@googlegroups.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de> Link: http://lkml.kernel.org/r/20150930083302.694788319@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [bwh: Backported to 3.2: - s/READ_ONCE/ACCESS_ONCE/ - Remove use of TOP_OF_KERNEL_STACK_PADDING, not defined here and would be defined as 0] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 5311d93d0d33ae878d5fbb35ea5693b9c813ba04) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06module: Fix locking in symbol_put_addr()Peter Zijlstra
commit 275d7d44d802ef271a42dc87ac091a495ba72fc5 upstream. Poma (on the way to another bug) reported an assertion triggering: [<ffffffff81150529>] module_assert_mutex_or_preempt+0x49/0x90 [<ffffffff81150822>] __module_address+0x32/0x150 [<ffffffff81150956>] __module_text_address+0x16/0x70 [<ffffffff81150f19>] symbol_put_addr+0x29/0x40 [<ffffffffa04b77ad>] dvb_frontend_detach+0x7d/0x90 [dvb_core] Laura Abbott <labbott@redhat.com> produced a patch which lead us to inspect symbol_put_addr(). This function has a comment claiming it doesn't need to disable preemption around the module lookup because it holds a reference to the module it wants to find, which therefore cannot go away. This is wrong (and a false optimization too, preempt_disable() is really rather cheap, and I doubt any of this is on uber critical paths, otherwise it would've retained a pointer to the actual module anyway and avoided the second lookup). While its true that the module cannot go away while we hold a reference on it, the data structure we do the lookup in very much _CAN_ change while we do the lookup. Therefore fix the comment and add the required preempt_disable(). Reported-by: poma <pomidorabelisima@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Fixes: a6e6abd575fc ("module: remove module_text_address()") Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 3895ff2d13043ecd091813b67a485ec487870b63) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06net: add length argument to skb_copy_and_csum_datagram_iovecSabrina Dubroca
Without this length argument, we can read past the end of the iovec in memcpy_toiovec because we have no way of knowing the total length of the iovec's buffers. This is needed for stable kernels where 89c22d8c3b27 ("net: Fix skb csum races when peeking") has been backported but that don't have the ioviter conversion, which is almost all the stable trees <= 3.18. This also fixes a kernel crash for NFS servers when the client uses -onfsvers=3,proto=udp to mount the export. Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org> [bwh: Backported to 3.2: adjust context in include/linux/skbuff.h] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 127500d724f8c43f452610c9080444eedb5eaa6c) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06net: Fix skb csum races when peekingHerbert Xu
[ Upstream commit 89c22d8c3b278212eef6a8cc66b570bc840a6f5a ] When we calculate the checksum on the recv path, we store the result in the skb as an optimisation in case we need the checksum again down the line. This is in fact bogus for the MSG_PEEK case as this is done without any locking. So multiple threads can peek and then store the result to the same skb, potentially resulting in bogus skb states. This patch fixes this by only storing the result if the skb is not shared. This preserves the optimisations for the few cases where it can be done safely due to locking or other reasons, e.g., SIOCINQ. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 58a5897a53d535bf95523e6f381f88116217f5ca) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06RDS: verify the underlying transport exists before creating a connectionSasha Levin
commit 74e98eb085889b0d2d4908f59f6e00026063014f upstream. There was no verification that an underlying transport exists when creating a connection, this would cause dereferencing a NULL ptr. It might happen on sockets that weren't properly bound before attempting to send a message, which will cause a NULL ptr deref: [135546.047719] kasan: GPF could be caused by NULL-ptr deref or user memory accessgeneral protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN [135546.051270] Modules linked in: [135546.051781] CPU: 4 PID: 15650 Comm: trinity-c4 Not tainted 4.2.0-next-20150902-sasha-00041-gbaa1222-dirty #2527 [135546.053217] task: ffff8800835bc000 ti: ffff8800bc708000 task.ti: ffff8800bc708000 [135546.054291] RIP: __rds_conn_create (net/rds/connection.c:194) [135546.055666] RSP: 0018:ffff8800bc70fab0 EFLAGS: 00010202 [135546.056457] RAX: dffffc0000000000 RBX: 0000000000000f2c RCX: ffff8800835bc000 [135546.057494] RDX: 0000000000000007 RSI: ffff8800835bccd8 RDI: 0000000000000038 [135546.058530] RBP: ffff8800bc70fb18 R08: 0000000000000001 R09: 0000000000000000 [135546.059556] R10: ffffed014d7a3a23 R11: ffffed014d7a3a21 R12: 0000000000000000 [135546.060614] R13: 0000000000000001 R14: ffff8801ec3d0000 R15: 0000000000000000 [135546.061668] FS: 00007faad4ffb700(0000) GS:ffff880252000000(0000) knlGS:0000000000000000 [135546.062836] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [135546.063682] CR2: 000000000000846a CR3: 000000009d137000 CR4: 00000000000006a0 [135546.064723] Stack: [135546.065048] ffffffffafe2055c ffffffffafe23fc1 ffffed00493097bf ffff8801ec3d0008 [135546.066247] 0000000000000000 00000000000000d0 0000000000000000 ac194a24c0586342 [135546.067438] 1ffff100178e1f78 ffff880320581b00 ffff8800bc70fdd0 ffff880320581b00 [135546.068629] Call Trace: [135546.069028] ? __rds_conn_create (include/linux/rcupdate.h:856 net/rds/connection.c:134) [135546.069989] ? rds_message_copy_from_user (net/rds/message.c:298) [135546.071021] rds_conn_create_outgoing (net/rds/connection.c:278) [135546.071981] rds_sendmsg (net/rds/send.c:1058) [135546.072858] ? perf_trace_lock (include/trace/events/lock.h:38) [135546.073744] ? lockdep_init (kernel/locking/lockdep.c:3298) [135546.074577] ? rds_send_drop_to (net/rds/send.c:976) [135546.075508] ? __might_fault (./arch/x86/include/asm/current.h:14 mm/memory.c:3795) [135546.076349] ? __might_fault (mm/memory.c:3795) [135546.077179] ? rds_send_drop_to (net/rds/send.c:976) [135546.078114] sock_sendmsg (net/socket.c:611 net/socket.c:620) [135546.078856] SYSC_sendto (net/socket.c:1657) [135546.079596] ? SYSC_connect (net/socket.c:1628) [135546.080510] ? trace_dump_stack (kernel/trace/trace.c:1926) [135546.081397] ? ring_buffer_unlock_commit (kernel/trace/ring_buffer.c:2479 kernel/trace/ring_buffer.c:2558 kernel/trace/ring_buffer.c:2674) [135546.082390] ? trace_buffer_unlock_commit (kernel/trace/trace.c:1749) [135546.083410] ? trace_event_raw_event_sys_enter (include/trace/events/syscalls.h:16) [135546.084481] ? do_audit_syscall_entry (include/trace/events/syscalls.h:16) [135546.085438] ? trace_buffer_unlock_commit (kernel/trace/trace.c:1749) [135546.085515] rds_ib_laddr_check(): addr 36.74.25.172 ret -99 node type -1 Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 987ad6eef35223b149baf453171b74917c372cbc) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06x86/paravirt: Replace the paravirt nop with a bona fide empty functionAndy Lutomirski
commit fc57a7c68020dcf954428869eafd934c0ab1536f upstream. PARAVIRT_ADJUST_EXCEPTION_FRAME generates this code (using nmi as an example, trimmed for readability): ff 15 00 00 00 00 callq *0x0(%rip) # 2796 <nmi+0x6> 2792: R_X86_64_PC32 pv_irq_ops+0x2c That's a call through a function pointer to regular C function that does nothing on native boots, but that function isn't protected against kprobes, isn't marked notrace, and is certainly not guaranteed to preserve any registers if the compiler is feeling perverse. This is bad news for a CLBR_NONE operation. Of course, if everything works correctly, once paravirt ops are patched, it gets nopped out, but what if we hit this code before paravirt ops are patched in? This can potentially cause breakage that is very difficult to debug. A more subtle failure is possible here, too: if _paravirt_nop uses the stack at all (even just to push RBP), it will overwrite the "NMI executing" variable if it's called in the NMI prologue. The Xen case, perhaps surprisingly, is fine, because it's already written in asm. Fix all of the cases that default to paravirt_nop (including adjust_exception_frame) with a big hammer: replace paravirt_nop with an asm function that is just a ret instruction. The Xen case may have other problems, so document them. This is part of a fix for some random crashes that Sasha saw. Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andy Lutomirski <luto@kernel.org> Link: http://lkml.kernel.org/r/8f5d2ba295f9d73751c33d97fda03e0495d9ade0.1442791737.git.luto@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [bwh: Backported to 3.2: adjust filename, context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 81fbc9a5dd000126ef727dcdaea3ef5714d1e898) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06hfs: fix B-tree corruption after insertion at position 0Hin-Tak Leung
commit b4cc0efea4f0bfa2477c56af406cfcf3d3e58680 upstream. Fix B-tree corruption when a new record is inserted at position 0 in the node in hfs_brec_insert(). This is an identical change to the corresponding hfs b-tree code to Sergei Antonov's "hfsplus: fix B-tree corruption after insertion at position 0", to keep similar code paths in the hfs and hfsplus drivers in sync, where appropriate. Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Sergei Antonov <saproj@gmail.com> Cc: Joe Perches <joe@perches.com> Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Anton Altaparmakov <anton@tuxera.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit d46a34909db526644edf8ae62058d8371dd5f7e9) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06hfs,hfsplus: cache pages correctly between bnode_create and bnode_freeHin-Tak Leung
commit 7cb74be6fd827e314f81df3c5889b87e4c87c569 upstream. Pages looked up by __hfs_bnode_create() (called by hfs_bnode_create() and hfs_bnode_find() for finding or creating pages corresponding to an inode) are immediately kmap()'ed and used (both read and write) and kunmap()'ed, and should not be page_cache_release()'ed until hfs_bnode_free(). This patch fixes a problem I first saw in July 2012: merely running "du" on a large hfsplus-mounted directory a few times on a reasonably loaded system would get the hfsplus driver all confused and complaining about B-tree inconsistencies, and generates a "BUG: Bad page state". Most recently, I can generate this problem on up-to-date Fedora 22 with shipped kernel 4.0.5, by running "du /" (="/" + "/home" + "/mnt" + other smaller mounts) and "du /mnt" simultaneously on two windows, where /mnt is a lightly-used QEMU VM image of the full Mac OS X 10.9: $ df -i / /home /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /dev/mapper/fedora-root 3276800 551665 2725135 17% / /dev/mapper/fedora-home 52879360 716221 52163139 2% /home /dev/nbd0p2 4294967295 1387818 4293579477 1% /mnt After applying the patch, I was able to run "du /" (60+ times) and "du /mnt" (150+ times) continuously and simultaneously for 6+ hours. There are many reports of the hfsplus driver getting confused under load and generating "BUG: Bad page state" or other similar issues over the years. [1] The unpatched code [2] has always been wrong since it entered the kernel tree. The only reason why it gets away with it is that the kmap/memcpy/kunmap follow very quickly after the page_cache_release() so the kernel has not had a chance to reuse the memory for something else, most of the time. The current RW driver appears to have followed the design and development of the earlier read-only hfsplus driver [3], where-by version 0.1 (Dec 2001) had a B-tree node-centric approach to read_cache_page()/page_cache_release() per bnode_get()/bnode_put(), migrating towards version 0.2 (June 2002) of caching and releasing pages per inode extents. When the current RW code first entered the kernel [2] in 2005, there was an REF_PAGES conditional (and "//" commented out code) to switch between B-node centric paging to inode-centric paging. There was a mistake with the direction of one of the REF_PAGES conditionals in __hfs_bnode_create(). In a subsequent "remove debug code" commit [4], the read_cache_page()/page_cache_release() per bnode_get()/bnode_put() were removed, but a page_cache_release() was mistakenly left in (propagating the "REF_PAGES <-> !REF_PAGE" mistake), and the commented-out page_cache_release() in bnode_release() (which should be spanned by !REF_PAGES) was never enabled. References: [1]: Michael Fox, Apr 2013 http://www.spinics.net/lists/linux-fsdevel/msg63807.html ("hfsplus volume suddenly inaccessable after 'hfs: recoff %d too large'") Sasha Levin, Feb 2015 http://lkml.org/lkml/2015/2/20/85 ("use after free") https://bugs.launchpad.net/ubuntu/+source/linux/+bug/740814 https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1027887 https://bugzilla.kernel.org/show_bug.cgi?id=42342 https://bugzilla.kernel.org/show_bug.cgi?id=63841 https://bugzilla.kernel.org/show_bug.cgi?id=78761 [2]: http://git.kernel.org/cgit/linux/kernel/git/tglx/history.git/commit/\ fs/hfs/bnode.c?id=d1081202f1d0ee35ab0beb490da4b65d4bc763db commit d1081202f1d0ee35ab0beb490da4b65d4bc763db Author: Andrew Morton <akpm@osdl.org> Date: Wed Feb 25 16:17:36 2004 -0800 [PATCH] HFS rewrite http://git.kernel.org/cgit/linux/kernel/git/tglx/history.git/commit/\ fs/hfsplus/bnode.c?id=91556682e0bf004d98a529bf829d339abb98bbbd commit 91556682e0bf004d98a529bf829d339abb98bbbd Author: Andrew Morton <akpm@osdl.org> Date: Wed Feb 25 16:17:48 2004 -0800 [PATCH] HFS+ support [3]: http://sourceforge.net/projects/linux-hfsplus/ http://sourceforge.net/projects/linux-hfsplus/files/Linux%202.4.x%20patch/hfsplus%200.1/ http://sourceforge.net/projects/linux-hfsplus/files/Linux%202.4.x%20patch/hfsplus%200.2/ http://linux-hfsplus.cvs.sourceforge.net/viewvc/linux-hfsplus/linux/\ fs/hfsplus/bnode.c?r1=1.4&r2=1.5 Date: Thu Jun 6 09:45:14 2002 +0000 Use buffer cache instead of page cache in bnode.c. Cache inode extents. [4]: http://git.kernel.org/cgit/linux/kernel/git/\ stable/linux-stable.git/commit/?id=a5e3985fa014029eb6795664c704953720cc7f7d commit a5e3985fa014029eb6795664c704953720cc7f7d Author: Roman Zippel <zippel@linux-m68k.org> Date: Tue Sep 6 15:18:47 2005 -0700 [PATCH] hfs: remove debug code Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net> Signed-off-by: Sergei Antonov <saproj@gmail.com> Reviewed-by: Anton Altaparmakov <anton@tuxera.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Sougata Santra <sougata@tuxera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit dd04e674cde34f570509b9e2a6b549af89897640) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06pagemap: hide physical addresses from non-privileged usersKonstantin Khlebnikov
commit 1c90308e7a77af6742a97d1021cca923b23b7f0d upstream. This patch makes pagemap readable for normal users and hides physical addresses from them. For some use-cases PFN isn't required at all. See http://lkml.kernel.org/r/1425935472-17949-1-git-send-email-kirill@shutemov.name Fixes: ab676b7d6fbf ("pagemap: do not leak physical addresses to non-privileged userspace") Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Mark Williamson <mwilliamson@undo-software.com> Tested-by: Mark Williamson <mwilliamson@undo-software.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: - Add the same check in the places where we look up a PFN - Add struct pagemapread * parameters where necessary - Open-code file_ns_capable() - Delete pagemap_open() entirely, as it would always return 0] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit b1fb185f26e85f76e3ac6ce557398d78797c9684) [wt: adjusted context, no pagemap_hugetlb_range() in 2.6.32, needs cred argument to security_capable(), tested OK ] Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06security: add cred argument to security_capable()Chris Wright
commit 6037b715d6fab139742c3df8851db4c823081561 upstream. Expand security_capable() to include cred, so that it can be usable in a wider range of call sites. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <jmorris@namei.org> [wt: needed by next patch only] Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06Input: evdev - do not report errors form flush()Takashi Iwai
commit eb38f3a4f6e86f8bb10a3217ebd85ecc5d763aae upstream. We've got bug reports showing the old systemd-logind (at least system-210) aborting unexpectedly, and this turned out to be because of an invalid error code from close() call to evdev devices. close() is supposed to return only either EINTR or EBADFD, while the device returned ENODEV. logind was overreacting to it and decided to kill itself when an unexpected error code was received. What a tragedy. The bad error code comes from flush fops, and actually evdev_flush() returns ENODEV when device is disconnected or client's access to it is revoked. But in these cases the fact that flush did not actually happen is not an error, but rather normal behavior. For non-disconnected devices result of flush is also not that interesting as there is no potential of data loss and even if it fails application has no way of handling the error. Because of that we are better off always returning success from evdev_flush(). Also returning EINTR from flush()/close() is discouraged (as it is not clear how application should handle this error), so let's stop taking evdev->mutex interruptibly. Bugzilla: http://bugzilla.suse.com/show_bug.cgi?id=939834 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> [bwh: Backported to 3.2: there's no revoked flag to test] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit a6706174cfe9fa100651b5012aec9796006a884b) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06SUNRPC: xs_reset_transport must mark the connection as disconnectedTrond Myklebust
commit 0c78789e3a030615c6650fde89546cadf40ec2cc upstream. In case the reconnection attempt fails. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> [bwh: Backported to 3.2: add local variable xprt] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 9434e4855e90d2af3751cd93b47b4a3e40bc2dc1) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06xfs: Fix xfs_attr_leafblock definitionJan Kara
commit ffeecc5213024ae663377b442eedcfbacf6d0c5d upstream. struct xfs_attr_leafblock contains 'entries' array which is declared with size 1 altough it can in fact contain much more entries. Since this array is followed by further struct members, gcc (at least in version 4.8.3) thinks that the array has the fixed size of 1 element and thus may optimize away all accesses beyond the end of array resulting in non-working code. This problem was only observed with userspace code in xfsprogs, however it's better to be safe in kernel as well and have matching kernel and xfsprogs definitions. Signed-off-by: Jan Kara <jack@suse.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com> [bwh: Backported to 3.2: adjust filename] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 86cbc0072fa4fc7906dd8abfa6489638014300bb) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06windfarm: decrement client count when unregisteringPaul Bolle
commit fe2b592173ff0274e70dc44d1d28c19bb995aa7c upstream. wf_unregister_client() increments the client count when a client unregisters. That is obviously incorrect. Decrement that client count instead. Fixes: 75722d3992f5 ("[PATCH] ppc64: Thermal control for SMU based machines") Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 48c46d4aed1c27f363e4673e988212340e82e1bb) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06devres: fix devres_get()Masahiro Yamada
commit 64526370d11ce8868ca495723d595b61e8697fbf upstream. Currently, devres_get() passes devres_free() the pointer to devres, but devres_free() should be given with the pointer to resource data. Fixes: 9ac7849e35f7 ("devres: device resource management") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit ebc0ae5a7159086a992f7904dc9ad849a13eecfc) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06ipc,sem: fix use after free on IPC_RMID after a task using same semaphore ↵Herton R. Krzesinski
set exits commit 602b8593d2b4138c10e922eeaafe306f6b51817b upstream. The current semaphore code allows a potential use after free: in exit_sem we may free the task's sem_undo_list while there is still another task looping through the same semaphore set and cleaning the sem_undo list at freeary function (the task called IPC_RMID for the same semaphore set). For example, with a test program [1] running which keeps forking a lot of processes (which then do a semop call with SEM_UNDO flag), and with the parent right after removing the semaphore set with IPC_RMID, and a kernel built with CONFIG_SLAB, CONFIG_SLAB_DEBUG and CONFIG_DEBUG_SPINLOCK, you can easily see something like the following in the kernel log: Slab corruption (Not tainted): kmalloc-64 start=ffff88003b45c1c0, len=64 000: 6b 6b 6b 6b 6b 6b 6b 6b 00 6b 6b 6b 6b 6b 6b 6b kkkkkkkk.kkkkkkk 010: ff ff ff ff 6b 6b 6b 6b ff ff ff ff ff ff ff ff ....kkkk........ Prev obj: start=ffff88003b45c180, len=64 000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ 010: ff ff ff ff ff ff ff ff c0 fb 01 37 00 88 ff ff ...........7.... Next obj: start=ffff88003b45c200, len=64 000: 00 00 00 00 ad 4e ad de ff ff ff ff 5a 5a 5a 5a .....N......ZZZZ 010: ff ff ff ff ff ff ff ff 68 29 a7 3c 00 88 ff ff ........h).<.... BUG: spinlock wrong CPU on CPU#2, test/18028 general protection fault: 0000 [#1] SMP Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib] CPU: 2 PID: 18028 Comm: test Not tainted 4.2.0-rc5+ #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 RIP: spin_dump+0x53/0xc0 Call Trace: spin_bug+0x30/0x40 do_raw_spin_unlock+0x71/0xa0 _raw_spin_unlock+0xe/0x10 freeary+0x82/0x2a0 ? _raw_spin_lock+0xe/0x10 semctl_down.clone.0+0xce/0x160 ? __do_page_fault+0x19a/0x430 ? __audit_syscall_entry+0xa8/0x100 SyS_semctl+0x236/0x2c0 ? syscall_trace_leave+0xde/0x130 entry_SYSCALL_64_fastpath+0x12/0x71 Code: 8b 80 88 03 00 00 48 8d 88 60 05 00 00 48 c7 c7 a0 2c a4 81 31 c0 65 8b 15 eb 40 f3 7e e8 08 31 68 00 4d 85 e4 44 8b 4b 08 74 5e <45> 8b 84 24 88 03 00 00 49 8d 8c 24 60 05 00 00 8b 53 04 48 89 RIP [<ffffffff810d6053>] spin_dump+0x53/0xc0 RSP <ffff88003750fd68> ---[ end trace 783ebb76612867a0 ]--- NMI watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [test:18053] Modules linked in: 8021q mrp garp stp llc nf_conntrack_ipv4 nf_defrag_ipv4 ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables binfmt_misc ppdev input_leds joydev parport_pc parport floppy serio_raw virtio_balloon virtio_rng virtio_console virtio_net iosf_mbi crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr qxl ttm drm_kms_helper drm snd_hda_codec_generic i2c_piix4 snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore crc32c_intel virtio_pci virtio_ring virtio pata_acpi ata_generic [last unloaded: speedstep_lib] CPU: 3 PID: 18053 Comm: test Tainted: G D 4.2.0-rc5+ #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 RIP: native_read_tsc+0x0/0x20 Call Trace: ? delay_tsc+0x40/0x70 __delay+0xf/0x20 do_raw_spin_lock+0x96/0x140 _raw_spin_lock+0xe/0x10 sem_lock_and_putref+0x11/0x70 SYSC_semtimedop+0x7bf/0x960 ? handle_mm_fault+0xbf6/0x1880 ? dequeue_task_fair+0x79/0x4a0 ? __do_page_fault+0x19a/0x430 ? kfree_debugcheck+0x16/0x40 ? __do_page_fault+0x19a/0x430 ? __audit_syscall_entry+0xa8/0x100 ? do_audit_syscall_entry+0x66/0x70 ? syscall_trace_enter_phase1+0x139/0x160 SyS_semtimedop+0xe/0x10 SyS_semop+0x10/0x20 entry_SYSCALL_64_fastpath+0x12/0x71 Code: 47 10 83 e8 01 85 c0 89 47 10 75 08 65 48 89 3d 1f 74 ff 7e c9 c3 0f 1f 44 00 00 55 48 89 e5 e8 87 17 04 00 66 90 c9 c3 0f 1f 00 <55> 48 89 e5 0f 31 89 c1 48 89 d0 48 c1 e0 20 89 c9 48 09 c8 c9 Kernel panic - not syncing: softlockup: hung tasks I wasn't able to trigger any badness on a recent kernel without the proper config debugs enabled, however I have softlockup reports on some kernel versions, in the semaphore code, which are similar as above (the scenario is seen on some servers running IBM DB2 which uses semaphore syscalls). The patch here fixes the race against freeary, by acquiring or waiting on the sem_undo_list lock as necessary (exit_sem can race with freeary, while freeary sets un->semid to -1 and removes the same sem_undo from list_proc or when it removes the last sem_undo). After the patch I'm unable to reproduce the problem using the test case [1]. [1] Test case used below: #include <stdio.h> #include <sys/types.h> #include <sys/ipc.h> #include <sys/sem.h> #include <sys/wait.h> #include <stdlib.h> #include <time.h> #include <unistd.h> #include <errno.h> #define NSEM 1 #define NSET 5 int sid[NSET]; void thread() { struct sembuf op; int s; uid_t pid = getuid(); s = rand() % NSET; op.sem_num = pid % NSEM; op.sem_op = 1; op.sem_flg = SEM_UNDO; semop(sid[s], &op, 1); exit(EXIT_SUCCESS); } void create_set() { int i, j; pid_t p; union { int val; struct semid_ds *buf; unsigned short int *array; struct seminfo *__buf; } un; /* Create and initialize semaphore set */ for (i = 0; i < NSET; i++) { sid[i] = semget(IPC_PRIVATE , NSEM, 0644 | IPC_CREAT); if (sid[i] < 0) { perror("semget"); exit(EXIT_FAILURE); } } un.val = 0; for (i = 0; i < NSET; i++) { for (j = 0; j < NSEM; j++) { if (semctl(sid[i], j, SETVAL, un) < 0) perror("semctl"); } } /* Launch threads that operate on semaphore set */ for (i = 0; i < NSEM * NSET * NSET; i++) { p = fork(); if (p < 0) perror("fork"); if (p == 0) thread(); } /* Free semaphore set */ for (i = 0; i < NSET; i++) { if (semctl(sid[i], NSEM, IPC_RMID)) perror("IPC_RMID"); } /* Wait for forked processes to exit */ while (wait(NULL)) { if (errno == ECHILD) break; }; } int main(int argc, char **argv) { pid_t p; srand(time(NULL)); while (1) { p = fork(); if (p < 0) { perror("fork"); exit(EXIT_FAILURE); } if (p == 0) { create_set(); goto end; } /* Wait for forked processes to exit */ while (wait(NULL)) { if (errno == ECHILD) break; }; } end: return 0; } [akpm@linux-foundation.org: use normal comment layout] Signed-off-by: Herton R. Krzesinski <herton@redhat.com> Acked-by: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Rafael Aquini <aquini@redhat.com> CC: Aristeu Rozanski <aris@redhat.com> Cc: David Jeffery <djeffery@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit a1c4fb80c5d94ef61a77c1e891cae616a50d8d3c) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06net: Fix skb_set_peeked use-after-free bugHerbert Xu
commit a0a2a6602496a45ae838a96db8b8173794b5d398 upstream. The commit 738ac1ebb96d02e0d23bc320302a6ea94c612dec ("net: Clone skb before setting peeked flag") introduced a use-after-free bug in skb_recv_datagram. This is because skb_set_peeked may create a new skb and free the existing one. As it stands the caller will continue to use the old freed skb. This patch fixes it by making skb_set_peeked return the new skb (or the old one if unchanged). Fixes: 738ac1ebb96d ("net: Clone skb before setting peeked flag") Reported-by: Brenden Blanco <bblanco@plumgrid.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Brenden Blanco <bblanco@plumgrid.com> Reviewed-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit e553622ccb6b6e06079f980f55cf04128db3420c) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06net: Clone skb before setting peeked flagHerbert Xu
commit 738ac1ebb96d02e0d23bc320302a6ea94c612dec upstream. Shared skbs must not be modified and this is crucial for broadcast and/or multicast paths where we use it as an optimisation to avoid unnecessary cloning. The function skb_recv_datagram breaks this rule by setting peeked without cloning the skb first. This causes funky races which leads to double-free. This patch fixes this by cloning the skb and replacing the skb in the list when setting skb->peeked. Fixes: a59322be07c9 ("[UDP]: Only increment counter on first peek/recv") Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 72e6f0680249f5e0a87f2b282d033baefd90d84e) [wt: adjusted context for 2.6.32. Introduces a bug, see next commit] Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06rds: fix an integer overflow test in rds_info_getsockopt()Dan Carpenter
commit 468b732b6f76b138c0926eadf38ac88467dcd271 upstream. "len" is a signed integer. We check that len is not negative, so it goes from zero to INT_MAX. PAGE_SIZE is unsigned long so the comparison is type promoted to unsigned long. ULONG_MAX - 4095 is a higher than INT_MAX so the condition can never be true. I don't know if this is harmful but it seems safe to limit "len" to INT_MAX - 4095. Fixes: a8c879a7ee98 ('RDS: Info and stats') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit f3a66bdc88c3261f55b942453476e623056b92d9) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06xhci: fix off by one error in TRB DMA address boundary checkMathias Nyman
commit 7895086afde2a05fa24a0e410d8e6b75ca7c8fdd upstream. We need to check that a TRB is part of the current segment before calculating its DMA address. Previously a ring segment didn't use a full memory page, and every new ring segment got a new memory page, so the off by one error in checking the upper bound was never seen. Now that we use a full memory page, 256 TRBs (4096 bytes), the off by one didn't catch the case when a TRB was the first element of the next segment. This is triggered if the virtual memory pages for a ring segment are next to each in increasing order where the ring buffer wraps around and causes errors like: [ 106.398223] xhci_hcd 0000:00:14.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 0 comp_code 1 [ 106.398230] xhci_hcd 0000:00:14.0: Looking for event-dma fffd3000 trb-start fffd4fd0 trb-end fffd5000 seg-start fffd4000 seg-end fffd4ff0 The trb-end address is one outside the end-seg address. Tested-by: Arkadiusz Miśkiewicz <arekm@maven.pl> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit 6e3ae6256145b5597bee0296eb5fc384cd86aa3d) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06Initialize msg/shm IPC objects before doing ipc_addid()Linus Torvalds
commit b9a532277938798b53178d5a66af6e2915cb27cf upstream. As reported by Dmitry Vyukov, we really shouldn't do ipc_addid() before having initialized the IPC object state. Yes, we initialize the IPC object in a locked state, but with all the lockless RCU lookup work, that IPC object lock no longer means that the state cannot be seen. We already did this for the IPC semaphore code (see commit e8577d1f0329: "ipc/sem.c: fully initialize sem_array before making it visible") but we clearly forgot about msg and shm. Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dbueso@suse.de> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 2.6.32: - Adjust context - The error path being moved looks a little different] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06ipc/sem.c: fully initialize sem_array before making it visibleManfred Spraul
commit e8577d1f0329d4842e8302e289fb2c22156abef4 upstream. ipc_addid() makes a new ipc identifier visible to everyone. New objects start as locked, so that the caller can complete the initialization after the call. Within struct sem_array, at least sma->sem_base and sma->sem_nsems are accessed without any locks, therefore this approach doesn't work. Thus: Move the ipc_addid() to the end of the initialization. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Rik van Riel <riel@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 2.6.32: - Adjust context - The error path being moved looks a little different] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06USB: whiteheat: fix potential null-deref at probeJohan Hovold
commit cbb4be652d374f64661137756b8f357a1827d6a4 upstream. Fix potential null-pointer dereference at probe by making sure that the required endpoints are present. The whiteheat driver assumes there are at least five pairs of bulk endpoints, of which the final pair is used for the "command port". An attempt to bind to an interface with fewer bulk endpoints would currently lead to an oops. Fixes CVE-2015-5257. Reported-by: Moein Ghasemzadeh <moein@istuary.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06virtio-net: drop NETIF_F_FRAGLISTJason Wang
commit 48900cb6af4282fa0fb6ff4d72a81aa3dadb5c39 upstream. virtio declares support for NETIF_F_FRAGLIST, but assumes that there are at most MAX_SKB_FRAGS + 2 fragments which isn't always true with a fraglist. A longer fraglist in the skb will make the call to skb_to_sgvec overflow the sg array, leading to memory corruption. Drop NETIF_F_FRAGLIST so we only get what we can handle. Cc: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 2.6.32: there's only a single features field] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06ipv6: addrconf: validate new MTU before applying itMarcelo Leitner
commit 77751427a1ff25b27d47a4c36b12c3c8667855ac upstream. Currently we don't check if the new MTU is valid or not and this allows one to configure a smaller than minimum allowed by RFCs or even bigger than interface own MTU, which is a problem as it may lead to packet drops. If you have a daemon like NetworkManager running, this may be exploited by remote attackers by forging RA packets with an invalid MTU, possibly leading to a DoS. (NetworkManager currently only validates for values too small, but not for too big ones.) The fix is just to make sure the new value is valid. That is, between IPV6_MIN_MTU and interface's MTU. Note that similar check is already performed at ndisc_router_discovery(), for when kernel itself parses the RA. Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 2.6.32: - Add a strategy for the sysctl as we don't get a default strategy - Adjust context, spacing] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06md: use kzalloc() when bitmap is disabledBenjamin Randazzo
commit b6878d9e03043695dbf3fa1caa6dfc09db225b16 upstream. In drivers/md/md.c get_bitmap_file() uses kmalloc() for creating a mdu_bitmap_file_t called "file". 5769 file = kmalloc(sizeof(*file), GFP_NOIO); 5770 if (!file) 5771 return -ENOMEM; This structure is copied to user space at the end of the function. 5786 if (err == 0 && 5787 copy_to_user(arg, file, sizeof(*file))) 5788 err = -EFAULT But if bitmap is disabled only the first byte of "file" is initialized with zero, so it's possible to read some bytes (up to 4095) of kernel space memory from user space. This is an information leak. 5775 /* bitmap disabled, zero the first byte and copy out */ 5776 if (!mddev->bitmap_info.file) 5777 file->pathname[0] = '\0'; Signed-off-by: Benjamin Randazzo <benjamin@randazzo.fr> Signed-off-by: NeilBrown <neilb@suse.com> [bwh: Backported to 2.6.32: patch both possible allocation calls] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06Failing to send a CLOSE if file is opened WRONLY and server reboots on a 4.x ↵Olga Kornievskaia
mount commit a41cbe86df3afbc82311a1640e20858c0cd7e065 upstream. A test case is as the description says: open(foobar, O_WRONLY); sleep() --> reboot the server close(foobar) The bug is because in nfs4state.c in nfs4_reclaim_open_state() a few line before going to restart, there is clear_bit(NFS4CLNT_RECLAIM_NOGRACE, &state->flags). NFS4CLNT_RECLAIM_NOGRACE is a flag for the client states not open owner states. Value of NFS4CLNT_RECLAIM_NOGRACE is 4 which is the value of NFS_O_WRONLY_STATE in nfs4_state->flags. So clearing it wipes out state and when we go to close it, “call_close” doesn’t get set as state flag is not set and CLOSE doesn’t go on the wire. Signed-off-by: Olga Kornievskaia <aglo@umich.edu> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06vfs: Test for and handle paths that are unreachable from their mnt_rootEric W. Biederman
commit 397d425dc26da728396e66d392d5dcb8dac30c37 upstream. In rare cases a directory can be renamed out from under a bind mount. In those cases without special handling it becomes possible to walk up the directory tree to the root dentry of the filesystem and down from the root dentry to every other file or directory on the filesystem. Like division by zero .. from an unconnected path can not be given a useful semantic as there is no predicting at which path component the code will realize it is unconnected. We certainly can not match the current behavior as the current behavior is a security hole. Therefore when encounting .. when following an unconnected path return -ENOENT. - Add a function path_connected to verify path->dentry is reachable from path->mnt.mnt_root. AKA to validate that rename did not do something nasty to the bind mount. To avoid races path_connected must be called after following a path component to it's next path component. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-12-06dcache: Handle escaped paths in prepend_pathEric W. Biederman
commit cde93be45a8a90d8c264c776fab63487b5038a65 upstream. A rename can result in a dentry that by walking up d_parent will never reach it's mnt_root. For lack of a better term I call this an escaped path. prepend_path is called by four different functions __d_path, d_absolute_path, d_path, and getcwd. __d_path only wants to see paths are connected to the root it passes in. So __d_path needs prepend_path to return an error. d_absolute_path similarly wants to see paths that are connected to some root. Escaped paths are not connected to any mnt_root so d_absolute_path needs prepend_path to return an error greater than 1. So escaped paths will be treated like paths on lazily unmounted mounts. getcwd needs to prepend "(unreachable)" so getcwd also needs prepend_path to return an error. d_path is the interesting hold out. d_path just wants to print something, and does not care about the weird cases. Which raises the question what should be printed? Given that <escaped_path>/<anything> should result in -ENOENT I believe it is desirable for escaped paths to be printed as empty paths. As there are not really any meaninful path components when considered from the perspective of a mount tree. So tweak prepend_path to return an empty path with an new error code of 3 when it encounters an escaped path. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> [bwh: For 2.6.32, implement the "(unreachable)" string in __d_path()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-09-18Linux 2.6.32.68v2.6.32.68Willy Tarreau
2015-09-18ipv6: Fix return of xfrm6_tunnel_rcv()David S. Miller
commit 6ac3f6649223d916bbdf1e823926f8f3b34b5d99 upstream. Like ipv4, just return xfrm6_rcv_spi()'s return value directly. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-09-18dmaengine: fix missing 'cnt' in ?: in dmatestDr. David Alan Gilbert
commit d07a74a546981a09ba490936645fbf0d1340b96c upstream. Hi, On the latest tree my compiler has started giving the warning: drivers/dma/dmatest.c:575:28: warning: the omitted middle operand in ?: will always be ?true?, suggest explicit middle operand [-Wparentheses] The following patch fixes the missing middle clause with the same fix that Nicolas Ferre used in the similar clauses. (There seems to have been a race between him fixing that and the extra clause going in a little later). I don't actually know the dmatest code/structures, nor do I own any hardware to test it on (assuming it needs a DMA engine); but this patch builds, the existing code is almost certainly wrong and the fix is the same as the corresponding lines above it. (WTH is x=y?:z legal C anyway?) Signed-off-by: Dr. David Alan Gilbert <linux@treblig.org> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-09-18dccp: catch failed request_module call in dccp_probe initWang Weidong
commit 965cdea825693c821d200e38fac9402cde6dce6a upstream. Check the return value of request_module during dccp_probe initialisation, bail out if that call fails. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Wang Weidong <wangweidong1@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-09-18dccp: Fix compile warning in probe code.David S. Miller
commit d984e6197ecd2babc1537f42dc1e676133005cda upstream. Commit 1386be55e32a3c5d8ef4a2b243c530a7b664c02c ("dccp: fix auto-loading of dccp(_probe)") fixed a bug but created a new compiler warning: net/dccp/probe.c: In function ‘dccpprobe_init’: net/dccp/probe.c:166:2: warning: the omitted middle operand in ?: will always be ‘true’, suggest explicit middle operand [-Wparentheses] try_then_request_module() is built for situations where the "existence" test is some lookup function that returns a non-NULL object on success, and with a reference count of some kind held. Here we're looking for a success return of zero from the jprobe registry. Instead of fighting the way try_then_request_module() works, simply open code what we want to happen in a local helper function. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-09-18dccp: fix auto-loading of dccp(_probe)Gerrit Renker
commit 1386be55e32a3c5d8ef4a2b243c530a7b664c02c upstream. This fixes commit (38ff3e6bb987ec583268da8eb22628293095d43b) ("dccp_probe: Fix module load dependencies between dccp and dccp_probe", from 15 Jan). It fixes the construction of the first argument of try_then_request_module(), where only valid return codes from the first argument should be returned. What we do now is assign the result of register_jprobe() to ret, without the side effect of the comparison. Acked-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-09-18x86/xen: Probe target addresses in set_aliased_prot() before the hypercallAndy Lutomirski
commit aa1acff356bbedfd03b544051f5b371746735d89 upstream. The update_va_mapping hypercall can fail if the VA isn't present in the guest's page tables. Under certain loads, this can result in an OOPS when the target address is in unpopulated vmap space. While we're at it, add comments to help explain what's going on. This isn't a great long-term fix. This code should probably be changed to use something like set_memory_ro. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andrew Cooper <andrew.cooper3@citrix.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: David Vrabel <dvrabel@cantab.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: security@kernel.org <security@kernel.org> Cc: xen-devel <xen-devel@lists.xen.org> Link: http://lkml.kernel.org/r/0b0e55b995cda11e7829f140b833ef932fcabe3a.1438291540.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit b48d6a721ba2cb475aea937c707f577aafa660a2) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-09-18libata: increase the timeout when setting transfer modeMikulas Patocka
commit d531be2ca2f27cca5f041b6a140504999144a617 upstream. I have a ST4000DM000 disk. If Linux is booted while the disk is spun down, the command that sets transfer mode causes the disk to spin up. The spin-up takes longer than the default 5s timeout, so the command fails and timeout is reported. Fix this by increasing the timeout to 15s, which is enough for the disk to spin up. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit d6ded32444c070ce41ad0d64fce8957d18009d72) Signed-off-by: Willy Tarreau <w@1wt.eu>
2015-09-18s390/process: fix sfpc inline assemblyHeiko Carstens
commit e47994dd44bcb4a77b4152bd0eada585934703c0 upstream. The sfpc inline assembly within execve_tail() may incorrectly set bits 28-31 of the sfpc instruction to a value which is not zero. These bits however are currently unused and therefore should be zero so we won't get surprised if these bits will be used in the future. Therefore remove the second operand from the inline assembly. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> (cherry picked from commit b411a8a3b44d76e782ba4bc6893068f3f590fe8a) Signed-off-by: Willy Tarreau <w@1wt.eu>
