commit a91e627e3f0ed820b11d86cdc04df38f65f33a70 upstream.
One of the many faults of the QinHeng CH345 USB MIDI interface chip is
that it does not handle received SysEx messages correctly -- every second
event packet has a wrong code index number, which is the one from the last
seen message, instead of 4. For example, the two messages "FE F0 01 02 03
04 05 06 07 08 09 0A 0B 0C 0D 0E F7" result in the following event
packets:
correct: CH345:
0F FE 00 00 0F FE 00 00
04 F0 01 02 04 F0 01 02
04 03 04 05 0F 03 04 05
04 06 07 08 04 06 07 08
04 09 0A 0B 0F 09 0A 0B
04 0C 0D 0E 04 0C 0D 0E
05 F7 00 00 05 F7 00 00
A class-compliant driver must interpret an event packet with CIN 15 as
having a single data byte, so the other two bytes would be ignored. The
message received by the host would then be missing two bytes out of six;
in this example, "F0 01 02 03 06 07 08 09 0C 0D 0E F7".
These corrupted SysEx event packages contain only data bytes, while the
CH345 uses event packets with a correct CIN value only for messages with
a status byte, so it is possible to distinguish between these two cases by
checking for the presence of this status byte.
(Other bugs in the CH345's input handling, such as the corruption resulting
from running status, cannot be worked around.)
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 1ca8b201309d842642f221db7f02f71c0af5be2d upstream.
The CH345 USB MIDI chip has two output ports. However, they are
multiplexed through one pin, and the number of ports cannot be reduced
even for hardware that implements only one connector, so for those
devices, data sent to either port ends up on the same hardware output.
This becomes a problem when both ports are used at the same time, as
longer MIDI commands (such as SysEx messages) are likely to be
interrupted by messages from the other port, and thus to get lost.
It would not be possible for the driver to detect how many ports the
device actually has, except that in practice, _all_ devices built with
the CH345 have only one port. So we can just ignore the device's
descriptors, and hardcode one output port.
commit 98d362becb6621bebdda7ed0eac7ad7ec6c37898 upstream.
commit 638148e20c7f8f6e95017fdc13bce8549a6925e0 upstream.
Thomas reports
4gsystems sells two total different LTE-surfsticks under the same name.
The newer version of XS Stick W100 is from "omega"
Under windows the driver switches to the same ID, and uses MI03\6 for
network and MI01\6 for modem.
echo "1c9e 9b01" > /sys/bus/usb/drivers/qmi_wwan/new_id
echo "1c9e 9b01" > /sys/bus/usb-serial/drivers/option1/new_id
T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1c9e ProdID=9b01 Rev=02.32
S: Manufacturer=USB Modem
S: Product=USB Modem
S: SerialNumber=
C: #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
I: If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
Now all important things are there:
wwp0s29f7u2i3 (net), ttyUSB2 (at), cdc-wdm0 (qmi), ttyUSB1 (at)
There is also ttyUSB0, but it is not usable, at least not for at.
The device works well with qmi and ModemManager-NetworkManager.
Reported-by: Thomas Schäfer <tschaefer@t-online.de>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit e07af133c3e2716db25e3e1e1d9f10c2088e9c1a upstream.
Also known as Verizon U620L.
The device is modeswitched from 1410:9020 to 1410:9022 by selecting the
4th USB configuration:
$ sudo usb_modeswitch –v 0x1410 –p 0x9020 –u 4
This configuration provides a ECM interface as well as TTYs ('Enterprise
Mode' according to the U620 Linux integration guide).
Signed-off-by: Aleksander Morgado <aleksander@aleksander.es>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 705e63d2b29c8bbf091119084544d353bda70393 upstream.
There is a bit of a mess in the order of arguments to the ulpi write
callback. There is
int ulpi_write(struct ulpi *ulpi, u8 addr, u8 val)
in drivers/usb/common/ulpi.c;
struct usb_phy_io_ops {
int (*write)(struct usb_phy *x, u32 val, u32 reg);
in include/linux/usb/phy.h.
The callback registered by the musb driver has to comply to the latter,
but up to now had "offset" first which effectively made the function
broken for correct users. So flip the order and while at it also
switch to the parameter names of struct usb_phy_io_ops's write.
Fixes: ffb865b1e460 ("usb: musb: add ulpi access operations")
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 19cd80a214821f4b558560ebd76bfb2c38b4f3d8 upstream.
It is not permitted to set task state before lock. usblp_wwait sets
the state to TASK_INTERRUPTIBLE and calls mutex_lock_interruptible.
Upon return from that function, the state will be TASK_RUNNING again.
This is clearly a bug and a warning is generated with LOCKDEP too:
WARNING: CPU: 1 PID: 5109 at kernel/sched/core.c:7404 __might_sleep+0x7d/0x90()
do not call blocking ops when !TASK_RUNNING; state=1 set at [<ffffffffa0c588d0>] usblp_wwait+0xa0/0x310 [usblp]
Modules linked in: ...
CPU: 1 PID: 5109 Comm: captmon Tainted: G W 4.2.5-0.gef2823b-default #1
Hardware name: LENOVO 23252SG/23252SG, BIOS G2ET33WW (1.13 ) 07/24/2012
ffffffff81a4edce ffff880236ec7ba8 ffffffff81716651 0000000000000000
ffff880236ec7bf8 ffff880236ec7be8 ffffffff8106e146 0000000000000282
ffffffff81a50119 000000000000028b 0000000000000000 ffff8802dab7c508
Call Trace:
[<ffffffff8106e1c6>] warn_slowpath_fmt+0x46/0x50
[<ffffffff8109a8bd>] __might_sleep+0x7d/0x90
[<ffffffff8171b20f>] mutex_lock_interruptible_nested+0x2f/0x4b0
[<ffffffffa0c588fc>] usblp_wwait+0xcc/0x310 [usblp]
[<ffffffffa0c58bb2>] usblp_write+0x72/0x350 [usblp]
[<ffffffff8121ed98>] __vfs_write+0x28/0xf0
Commit 7f477358e2384c54b190cc3b6ce28277050a041b (usblp: Implement the
ENOSPC convention) moved the set prior locking. So move it back after
the lock.
Fixes: 7f477358e2 ("usblp: Implement the ENOSPC convention")
Acked-By: Pete Zaitcev <zaitcev@yahoo.com>
commit 5accd17d0eb523350c9ef754d655e379c9bb93b3 upstream.
For reasons not entirely apparent, but now enshrined in history, the
architectural mapping of AArch32 banked registers to AArch64 registers
actually orders SP_<mode> and LR_<mode> backwards compared to the
intuitive r13/r14 order, for all modes except FIQ.
Fix the compat_<reg>_<mode> macros accordingly, in the hope of avoiding
subtle bugs with KVM and AArch32 guests.
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
commit 7cecd9ab80f43972c056dc068338f7bcc407b71c upstream.
According to SJA1000 data sheet error-warning (EI) interrupt is not
cleared by setting the controller in to reset-mode.
Then if we have the following case:
- system is suspended (echo mem > /sys/power/state) and SJA1000 is left
in operating state
- A bus error condition occurs which activates EI interrupt, system is
still suspended which means EI interrupt will be not be handled nor
cleared.
If the above two events occur, on resume there is no way to return the
SJA1000 to operating state, except to cycle power to it.
By simply reading the IR register on start we will clear any previous
conditions that could be present.
Signed-off-by: Mirza Krak <mirza.krak@hostmobility.com>
Reported-by: Christian Magnusson <Christian.Magnusson@semcon.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 660f0fc07d21114549c1862e67e78b1cf0c90c29 upstream.
The HIDP specs define an idle-timeout which automatically disconnects a
device. This has always been implemented in the HIDP layer and forced a
synchronous shutdown of the hidp-scheduler. This works just fine, but
lacks a forced disconnect on the underlying l2cap channels. This has been
broken since:
commit 5205185d461d5902325e457ca80bd421127b7308
Author: David Herrmann <dh.herrmann@gmail.com>
Date: Sat Apr 6 20:28:47 2013 +0200
Bluetooth: hidp: remove old session-management
The old session-management always forced an l2cap error on the ctrl/intr
channels when shutting down. The new session-management skips this, as we
don't want to enforce channel policy on the caller. In other words, if
user-space removes an HIDP device, the underlying channels (which are
*owned* and *referenced* by user-space) are still left active. User-space
needs to call shutdown(2) or close(2) to release them.
Unfortunately, this does not work with idle-timeouts. There is no way to
signal user-space that the HIDP layer has been stopped. The API simply
does not support any event-passing except for poll(2). Hence, we restore
old behavior and force EUNATCH on the sockets if the HIDP layer is
disconnected due to idle-timeouts (behavior of explicit disconnects
remains unmodified). User-space can still call
getsockopt(..., SO_ERROR, ...)
..to retrieve the EUNATCH error and clear sk_err. Hence, the channels can
still be re-used (which nobody does so far, though). Therefore, the API
still supports the new behavior, but with this patch it's also compatible
to the old implicit channel shutdown.
Reported-by: Mark Haun <haunma@keteu.org>
Reported-by: Luiz Augusto von Dentz <luiz.dentz@gmail.com>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 1e6e63283691a2a9048a35d9c6c59cf0abd342e4 upstream.
This adds the USB ID for the Sitecom WLA2100. The Windows 10 inf file
was checked to verify that the addition is correct.
Reported-by: Frans van de Wiel <fvdw@fvdw.eu>
Cc: Frans van de Wiel <fvdw@fvdw.eu>
commit 1f9c6e1bc1ba5f8a10fcd6e99d170954d7c6d382 upstream.
There were several bugs here.
1) The done label was in the wrong place so we didn't copy any
information out when there was no command given.
2) We were using PAGE_SIZE as the size of the buffer instead of
"PAGE_SIZE - pos".
3) snprintf() returns the number of characters that would have been
printed if there were enough space. If there was not enough space
(and we had fixed the memory corruption bug #2) then it would result
in an information leak when we do simple_read_from_buffer(). I've
changed it to use scnprintf() instead.
I also removed the initialization at the start of the function, because
I thought it made the code a little more clear.
Fixes: 5e6e3a92b9a4 ('wireless: mwifiex: initial commit for Marvell mwifiex driver')
Acked-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 2502d0ef272da7058ef303b849a2c8dc324c2e2e upstream.
The CPU_MAP register is duplicated for each CPUs at different addresses,
each instance being at a different address.
However, the code so far was using CONFIG_NR_CPUS to initialise the CPU_MAP
registers for each registers, while the SoCs embed at most 4 CPUs.
This is especially an issue with multi_v7_defconfig, where CONFIG_NR_CPUS
is currently set to 16, resulting in writes to registers that are not
CPU_MAP.
Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP network unit")
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 8ec6d97871f37e4743678ea4a455bd59580aa0f4 upstream.
The ifmgd->ave_beacon_signal value cannot be taken as is for
comparisons, it must be divided by since it's represented
like that for better accuracy of the EWMA calculations. This
would lead to invalid driver RSSI events. Fix the used value.
Fixes: 615f7b9bb1f8 ("mac80211: add driver RSSI threshold events")
commit 581b7f158fe0383b492acd1ce3fb4e99d4e57808 upstream.
There appears to be no formal statement of what pv_irq_ops.save_fl() is
supposed to return precisely. Native returns the full flags, while lguest and
Xen only return the Interrupt Flag, and both have comments by the
implementations stating that only the Interrupt Flag is looked at. This may
have been true when initially implemented, but no longer is.
To make matters worse, the Xen PVOP leaves the upper bits undefined, making
the BUG_ON() undefined behaviour. Experimentally, this now trips for 32bit PV
guests on Broadwell hardware. The BUG_ON() is consistent for an individual
build, but not consistent for all builds. It has also been a sitting timebomb
since SMAP support was introduced.
Use native_save_fl() instead, which will obtain an accurate view of the AC
flag.
Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: <lguest@lists.ozlabs.org>
Cc: Xen-devel <xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/1433323874-6927-1-git-send-email-andrew.cooper3@citrix.com
commit 04633df0c43d710e5f696b06539c100898678235 upstream.
When we get loaded by a 64-bit bootloader, kernel entry point is
startup_64 in head_64.S. We don't trust any and all bootloaders because
some will fiddle with CPU configuration so we go ahead and massage each
CPU into sanity again.
For example, some dell BIOSes have this XD disable feature which set
IA32_MISC_ENABLE[34] and disable NX. This might be some dumb workaround
for other OSes but Linux sure doesn't need it.
A similar thing is present in the Surface 3 firmware - see
https://bugzilla.kernel.org/show_bug.cgi?id=106051 - which sets this bit
only on the BSP:
# rdmsr -a 0x1a0
400850089
850089
850089
850089
I know, right?!
There's not even an off switch in there.
So fix all those cases by sanitizing the 64-bit entry point too. For
that, make verify_cpu() callable in 64-bit mode also.
Requested-and-debugged-by: "H. Peter Anvin" <hpa@zytor.com>
Reported-and-tested-by: Bastien Nocera <bugzilla@hadess.net>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Link: http://lkml.kernel.org/r/1446739076-21303-1-git-send-email-bp@alien8.de
commit 68accac392d859d24adcf1be3a90e41f978bd54c upstream.
The commit f5f3497cad8c extended the low identity mapping. However, if
the kernel uses more than 2 GB (VMSPLIT_2G_OPT or VMSPLIT_1G memory
split), the normal memory mapping is overwritten by the low identity
mapping causing a crash. To avoid overwritting, limit the low identity
map to cover only memory before kernel range (PAGE_OFFSET).
Fixes: f5f3497cad8c "x86/setup: Extend low identity map to cover whole kernel range
Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net>
Cc: Laszlo Ersek <lersek@redhat.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/r/1446815916-22105-1-git-send-email-krzysiek@podlesie.net
commit f5f3497cad8c8416a74b9aaceb127908755d020a upstream.
On 32-bit systems, the initial_page_table is reused by
efi_call_phys_prolog as an identity map to call
SetVirtualAddressMap. efi_call_phys_prolog takes care of
converting the current CPU's GDT to a physical address too.
For PAE kernels the identity mapping is achieved by aliasing the
first PDPE for the kernel memory mapping into the first PDPE
of initial_page_table. This makes the EFI stub's trick "just work".
However, for non-PAE kernels there is no guarantee that the identity
mapping in the initial_page_table extends as far as the GDT; in this
case, accesses to the GDT will cause a page fault (which quickly becomes
a triple fault). Fix this by copying the kernel mappings from
swapper_pg_dir to initial_page_table twice, both at PAGE_OFFSET and at
identity mapping.
For some reason, this is only reproducible with QEMU's dynamic translation
mode, and not for example with KVM. However, even under KVM one can clearly
see that the page table is bogus:
$ qemu-system-i386 -pflash OVMF.fd -M q35 vmlinuz0 -s -S -daemonize
$ gdb
(gdb) target remote localhost:1234
(gdb) hb *0x02858f6f
Hardware assisted breakpoint 1 at 0x2858f6f
(gdb) c
Continuing.
Breakpoint 1, 0x02858f6f in ?? ()
(gdb) monitor info registers
GDT= 0724e000 000000ff
IDT= fffbb000 000007ff
CR0=0005003b CR2=ff896000 CR3=032b7000 CR4=00000690
The page directory is sane:
(gdb) x/4wx 0x32b7000
0x32b7000: 0x03398063 0x03399063 0x0339a063 0x0339b063
(gdb) x/4wx 0x3398000
0x3398000: 0x00000163 0x00001163 0x00002163 0x00003163
(gdb) x/4wx 0x3399000
0x3399000: 0x00400003 0x00401003 0x00402003 0x00403003
but our particular page directory entry is empty:
(gdb) x/1wx 0x32b7000 + (0x724e000 >> 22) * 4
0x32b7070: 0x00000000
[ It appears that you can skate past this issue if you don't receive
any interrupts while the bogus GDT pointer is loaded, or if you avoid
reloading the segment registers in general.
Andy Lutomirski provides some additional insight:
"AFAICT it's entirely permissible for the GDTR and/or LDT
descriptor to point to unmapped memory. Any attempt to use them
(segment loads, interrupts, IRET, etc) will try to access that memory
as if the access came from CPL 0 and, if the access fails, will
generate a valid page fault with CR2 pointing into the GDT or
LDT."
Up until commit 23a0d4e8fa6d ("efi: Disable interrupts around EFI
calls, not in the epilog/prolog calls") interrupts were disabled
around the prolog and epilog calls, and the functional GDT was
re-installed before interrupts were re-enabled.
Which explains why no one has hit this issue until now. ]
Reported-by: Laszlo Ersek <lersek@redhat.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
[ Updated changelog. ]
commit d836ace65ee98d7079bc3c5afdbcc0e27dca20a3 upstream.
DSA expects the host_dev pointer to be the device structure associated
with the MDIO bus controller driver. First commit breaking that was
c3a07134e6aa ("mv643xx_eth: convert to use the Marvell Orion MDIO
driver"), and then, it got completely under the radar for a while.
Fixes: c3a07134e6aa ("mv643xx_eth: convert to use the Marvell Orion MDIO driver")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit 7e31210349e9e03a9a4dff31ab5f2bc83e8e84f5 upstream.
IOMMU-based dma_mmap() implementation lacked proper support for offset
parameter used in mmap call (it always assumed that mapping starts from
offset zero). This patch adds support for offset parameter to IOMMU-based
implementation.
commit 371f0f085f629fc0f66695f572373ca4445a67ad upstream.
dma_mmap() function in IOMMU-based dma-mapping implementation lacked
a check for valid range of mmap parameters (offset and buffer size), what
might have caused access beyond the allocated buffer. This patch fixes
this issue.
[ Upstream commit 74e98eb085889b0d2d4908f59f6e00026063014f ]
There was no verification that an underlying transport exists when creating
a connection, this would cause dereferencing a NULL ptr.
It might happen on sockets that weren't properly bound before attempting to
send a message, which will cause a NULL ptr deref:
[135546.047719] kasan: GPF could be caused by NULL-ptr deref or user memory accessgeneral protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN
[135546.051270] Modules linked in:
[135546.051781] CPU: 4 PID: 15650 Comm: trinity-c4 Not tainted 4.2.0-next-20150902-sasha-00041-gbaa1222-dirty #2527
[135546.053217] task: ffff8800835bc000 ti: ffff8800bc708000 task.ti: ffff8800bc708000
[135546.054291] RIP: __rds_conn_create (net/rds/connection.c:194)
[135546.055666] RSP: 0018:ffff8800bc70fab0 EFLAGS: 00010202
[135546.056457] RAX: dffffc0000000000 RBX: 0000000000000f2c RCX: ffff8800835bc000
[135546.057494] RDX: 0000000000000007 RSI: ffff8800835bccd8 RDI: 0000000000000038
[135546.058530] RBP: ffff8800bc70fb18 R08: 0000000000000001 R09: 0000000000000000
[135546.059556] R10: ffffed014d7a3a23 R11: ffffed014d7a3a21 R12: 0000000000000000
[135546.060614] R13: 0000000000000001 R14: ffff8801ec3d0000 R15: 0000000000000000
[135546.061668] FS: 00007faad4ffb700(0000) GS:ffff880252000000(0000) knlGS:0000000000000000
[135546.062836] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[135546.063682] CR2: 000000000000846a CR3: 000000009d137000 CR4: 00000000000006a0
[135546.064723] Stack:
[135546.065048] ffffffffafe2055c ffffffffafe23fc1 ffffed00493097bf ffff8801ec3d0008
[135546.066247] 0000000000000000 00000000000000d0 0000000000000000 ac194a24c0586342
[135546.067438] 1ffff100178e1f78 ffff880320581b00 ffff8800bc70fdd0 ffff880320581b00
[135546.068629] Call Trace:
[135546.069028] ? __rds_conn_create (include/linux/rcupdate.h:856 net/rds/connection.c:134)
[135546.069989] ? rds_message_copy_from_user (net/rds/message.c:298)
[135546.071021] rds_conn_create_outgoing (net/rds/connection.c:278)
[135546.071981] rds_sendmsg (net/rds/send.c:1058)
[135546.072858] ? perf_trace_lock (include/trace/events/lock.h:38)
[135546.073744] ? lockdep_init (kernel/locking/lockdep.c:3298)
[135546.074577] ? rds_send_drop_to (net/rds/send.c:976)
[135546.075508] ? __might_fault (./arch/x86/include/asm/current.h:14 mm/memory.c:3795)
[135546.076349] ? __might_fault (mm/memory.c:3795)
[135546.077179] ? rds_send_drop_to (net/rds/send.c:976)
[135546.078114] sock_sendmsg (net/socket.c:611 net/socket.c:620)
[135546.078856] SYSC_sendto (net/socket.c:1657)
[135546.079596] ? SYSC_connect (net/socket.c:1628)
[135546.080510] ? trace_dump_stack (kernel/trace/trace.c:1926)
[135546.081397] ? ring_buffer_unlock_commit (kernel/trace/ring_buffer.c:2479 kernel/trace/ring_buffer.c:2558 kernel/trace/ring_buffer.c:2674)
[135546.082390] ? trace_buffer_unlock_commit (kernel/trace/trace.c:1749)
[135546.083410] ? trace_event_raw_event_sys_enter (include/trace/events/syscalls.h:16)
[135546.084481] ? do_audit_syscall_entry (include/trace/events/syscalls.h:16)
[135546.085438] ? trace_buffer_unlock_commit (kernel/trace/trace.c:1749)
[135546.085515] rds_ib_laddr_check(): addr 36.74.25.172 ret -99 node type -1
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit 48900cb6af4282fa0fb6ff4d72a81aa3dadb5c39 ]
virtio declares support for NETIF_F_FRAGLIST, but assumes
that there are at most MAX_SKB_FRAGS + 2 fragments which isn't
always true with a fraglist.
A longer fraglist in the skb will make the call to skb_to_sgvec overflow
the sg array, leading to memory corruption.
Drop NETIF_F_FRAGLIST so we only get what we can handle.
Cc: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit d69bbf88c8d0b367cf3e3a052f6daadf630ee566 ]
Only cpu seeing dst refcount going to 0 can safely
dereference dst->flags.
Otherwise an other cpu might already have freed the dst.
Fixes: 27b75c95f10d ("net: avoid RCU for NOCACHE dst")
Reported-by: Greg Thelen <gthelen@google.com>
[ Upstream commit 8fa677d2706d325d71dab91bf6e6512c05214e37 ]
Under low memory conditions, tcp_sk_init() and icmp_sk_init()
can both iterate on all possible cpus and call inet_ctl_sock_destroy(),
with eventual NULL pointer.
in preemptible context.
[ Upstream commit 44f49dd8b5a606870a1f21101522a0f9c4414784 ]
Fixes the following kernel BUG :
BUG: using __this_cpu_add() in preemptible [00000000] code: bash/2758
caller is __this_cpu_preempt_check+0x13/0x15
CPU: 0 PID: 2758 Comm: bash Tainted: P O 3.18.19 #2
ffffffff8170eaca ffff880110d1b788 ffffffff81482b2a 0000000000000000
0000000000000000 ffff880110d1b7b8 ffffffff812010ae ffff880007cab800
ffff88001a060800 ffff88013a899108 ffff880108b84240 ffff880110d1b7c8
Call Trace:
[<ffffffff81482b2a>] dump_stack+0x52/0x80
[<ffffffff812010ae>] check_preemption_disabled+0xce/0xe1
[<ffffffff812010d4>] __this_cpu_preempt_check+0x13/0x15
[<ffffffff81419d60>] ipmr_queue_xmit+0x647/0x70c
[<ffffffff8141a154>] ip_mr_forward+0x32f/0x34e
[<ffffffff8141af76>] ip_mroute_setsockopt+0xe03/0x108c
[<ffffffff810553fc>] ? get_parent_ip+0x11/0x42
[<ffffffff810e6974>] ? pollwake+0x4d/0x51
[<ffffffff81058ac0>] ? default_wake_function+0x0/0xf
[<ffffffff810613d9>] ? __wake_up_common+0x45/0x77
[<ffffffff81486ea9>] ? _raw_spin_unlock_irqrestore+0x1d/0x32
[<ffffffff810618bc>] ? __wake_up_sync_key+0x4a/0x53
[<ffffffff8139a519>] ? sock_def_readable+0x71/0x75
[<ffffffff813dd226>] do_ip_setsockopt+0x9d/0xb55
[<ffffffff81429818>] ? unix_seqpacket_sendmsg+0x3f/0x41
[<ffffffff813963fe>] ? sock_sendmsg+0x6d/0x86
[<ffffffff813959d4>] ? sockfd_lookup_light+0x12/0x5d
[<ffffffff8139650a>] ? SyS_sendto+0xf3/0x11b
[<ffffffff810d5738>] ? new_sync_read+0x82/0xaa
[<ffffffff813ddd19>] compat_ip_setsockopt+0x3b/0x99
[<ffffffff813fb24a>] compat_raw_setsockopt+0x11/0x32
[<ffffffff81399052>] compat_sock_common_setsockopt+0x18/0x1f
[<ffffffff813c4d05>] compat_SyS_setsockopt+0x1a9/0x1cf
[<ffffffff813c4149>] compat_SyS_socketcall+0x180/0x1e3
[<ffffffff81488ea1>] cstar_dispatch+0x7/0x1e
Signed-off-by: Ani Sinha <ani@arista.com>
[ Upstream commit e6dbe1eb2db0d7a14991c06278dd3030c45fb825 ]
priv->hwts_*_en indicate if timestamping is enabled/disabled at run
time. But priv->dma_cap.time_stamp and priv->dma_cap.atime_stamp
indicates HW is support for PTPv1/PTPv2.
Signed-off-by: Phil Reid <preid@electromag.com.au>
Acked-by: Richard Cochran <richardcochran@gmail.com>
[ Upstream commit c02b05011fadf8e409e41910217ca689f2fc9d91 ]
When doing memcpy/memset of EQEs, we should use sizeof struct
mlx4_eqe as the base size and not caps.eqe_size which could be bigger.
If caps.eqe_size is bigger than the struct mlx4_eqe then we corrupt
data in the master context.
When using a 64 byte stride, the memcpy copied over 63 bytes to the
slave_eq structure. This resulted in copying over the entire eqe of
interest, including its ownership bit -- and also 31 bytes of garbage
into the next WQE in the slave EQ -- which did NOT include the ownership
bit (and therefore had no impact).
However, once the stride is increased to 128, we are overwriting the
ownership bits of *three* eqes in the slave_eq struct. This results
in an incorrect ownership bit for those eqes, which causes the eq to
seem to be full. The issue therefore surfaced only once 128-byte EQEs
started being used in SRIOV and (overarchitectures that have 128/256
byte cache-lines such as PPC) - e.g after commit 77507aa249ae
"net/mlx4_core: Enable CQE/EQE stride support".
Fixes: 08ff32352d6f ('mlx4: 64-byte CQE/EQE support')
Signed-off-by: Carol L Soto <clsoto@linux.vnet.ibm.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
rds_tcp_data_recv
[ Upstream commit 8ce675ff39b9958d1c10f86cf58e357efaafc856 ]
Either of pskb_pull() or pskb_trim() may fail under low memory conditions.
If rds_tcp_data_recv() ignores such failures, the application will
receive corrupted data because the skb has not been correctly
carved to the RDS datagram size.
Avoid this by handling pskb_pull/pskb_trim failure in the same
manner as the skb_clone failure: bail out of rds_tcp_data_recv(), and
retry via the deferred call to rds_send_worker() that gets set up on
ENOMEM from rds_tcp_read_sock()
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
[ Upstream commit 1acea4f6ce1b1c0941438aca75dd2e5c6b09db60 ]
We can't rely on PPPOX_ZOMBIE to decide whether to clear po->pppoe_dev.
PPPOX_ZOMBIE can be set by pppoe_disc_rcv() even when po->pppoe_dev is
NULL. So we have no guarantee that (sk->sk_state & PPPOX_ZOMBIE) implies
(po->pppoe_dev != NULL).
Since we're releasing a PPPoE socket, we want to release the pppoe_dev
if it exists and reset sk_state to PPPOX_DEAD, no matter the previous
value of sk_state. So we can just check for po->pppoe_dev and avoid any
assumption on sk->sk_state.
Fixes: 2b018d57ff18 ("pppoe: drop PPPOX_ZOMBIEs in pppoe_release")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 50010c20597d14667eff0fdb628309986f195230 ]
This is decrementing the pointer, instead of the value stored in the
pointer. KASan detects it as an out of bounds reference.
Reported-by: "Berry Cheng 程君(成淼)" <chengmiao.cj@alibaba-inc.com>
Fixes the backport of 0b34a166f291d255755be46e43ed5497cdd194f2 upstream
Commit 0b34a166f291d255755be46e43ed5497cdd194f2 "x86/xen: Support
kexec/kdump in HVM guests by doing a soft reset" has been added to the
4.2-stable tree" needed to correct the CONFIG variable, as
CONFIG_KEXEC_CORE only showed up in 4.3.
Reported-by: David Vrabel <david.vrabel@citrix.com>
Reported-by: Luis Henriques <luis.henriques@canonical.com>
commit 0ca81a2840f77855bbad1b9f172c545c4dc9e6a4 upstream.
ib_send_cm_sidr_rep could sometimes erase the node from the sidr
(depending on errors in the process). Since ib_send_cm_sidr_rep is
called both from cm_sidr_req_handler and cm_destroy_id, cm_id_priv
could be either erased from the rb_tree twice or not erased at all.
Fixing that by making sure it's erased only once before freeing
cm_id_priv.
Fixes: a977049dacde ('[PATCH] IB: Add the kernel CM implementation')
Signed-off-by: Doron Tsur <doront@mellanox.com>
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 2280521719e81919283b82902ac24058f87dfc1b upstream.
When pci_pool_alloc fails in mvs_task_prep then task->lldd_task stays
NULL but it's later used in mvs_abort_task as slot which is passed
to mvs_slot_task_free causing NULL pointer dereference.
Just return from mvs_slot_task_free when passed with NULL slot.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=101891
Signed-off-by: Dāvis Mosāns <davispuh@gmail.com>
Reviewed-by: Tomas Henzl <thenzl@redhat.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
commit 681ab4696062f5aa939c9e04d058732306a97176 upstream.
This was introduced with 9e882242c6193ae6f416f2d8d8db0d9126bd996b
which changed the return value of submit_bio_wait() to return != 0 on
error, but didn't update the caller accordingly.
Fixes: 9e882242c6 ("block: Add submit_bio_wait(), remove from md")
Reported-by: Bill Kuzeja <William.Kuzeja@stratus.com>
Signed-off-by: Jes Sorensen <Jes.Sorensen@redhat.com>
Signed-off-by: NeilBrown <neilb@suse.com>
commit 203d27b0226a05202438ddb39ef0ef1acb14a759 upstream.
commit 3fc89adb9fa4beff31374a4bf50b3d099d88ae83 upstream.
Currently a number of Crypto API operations may fail when a signal
occurs. This causes nasty problems as the caller of those operations
are often not in a good position to restart the operation.
In fact there is currently no need for those operations to be
interrupted by user signals at all. All we need is for them to
be killable.
This patch replaces the relevant calls of signal_pending with
fatal_signal_pending, and wait_for_completion_interruptible with
wait_for_completion_killable, respectively.
commit 275d7d44d802ef271a42dc87ac091a495ba72fc5 upstream.
Poma (on the way to another bug) reported an assertion triggering:
[<ffffffff81150529>] module_assert_mutex_or_preempt+0x49/0x90
[<ffffffff81150822>] __module_address+0x32/0x150
[<ffffffff81150956>] __module_text_address+0x16/0x70
[<ffffffff81150f19>] symbol_put_addr+0x29/0x40
[<ffffffffa04b77ad>] dvb_frontend_detach+0x7d/0x90 [dvb_core]
Laura Abbott <labbott@redhat.com> produced a patch which lead us to
inspect symbol_put_addr(). This function has a comment claiming it
doesn't need to disable preemption around the module lookup
because it holds a reference to the module it wants to find, which
therefore cannot go away.
This is wrong (and a false optimization too, preempt_disable() is really
rather cheap, and I doubt any of this is on uber critical paths,
otherwise it would've retained a pointer to the actual module anyway and
avoided the second lookup).
While its true that the module cannot go away while we hold a reference
on it, the data structure we do the lookup in very much _CAN_ change
while we do the lookup. Therefore fix the comment and add the
required preempt_disable().
Reported-by: poma <pomidorabelisima@gmail.com>
Fixes: a6e6abd575fc ("module: remove module_text_address()")
commit a54c8f0f2d7df525ff997e2afe71866a1a013064 upstream.
xen-blkfront will crash if the check to talk_to_blkback()
in blkback_changed()(XenbusStateInitWait) returns an error.
The driver data is freed and info is set to NULL. Later during
the close process via talk_to_blkback's call to xenbus_dev_fatal()
the null pointer is passed to and dereference in blkfront_closing.
Signed-off-by: Cathy Avery <cathy.avery@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 3b4739b8951d650becbcd855d7d6f18ac98a9a85 upstream.
If a host fails to wake up a isochronous SuperSpeed device from U1/U2
in time for a isoch transfer it will generate a "No ping response error"
Host will then move to the next transfer descriptor.
Handle this case in the same way as missed service errors, tag the
current TD as skipped and handle it on the next transfer event.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 4dcb8b57df3593dcb20481d9d6cf79d1dc1534be upstream.
btree_split_beneath()'s error path had an outstanding FIXME that speaks
directly to the potential for _not_ cleaning up a previously allocated
bufio-backed block.
Fix this by releasing the previously allocated bufio block using
unlock_block().
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Joe Thornber <thornber@redhat.com>
commit 2871c69e025e8bc507651d5a9cf81a8a7da9d24b upstream.
Commit 4c7e309340ff ("dm btree remove: fix bug in redistribute3") wasn't
a complete fix for redistribute3().
The redistribute3 function takes 3 btree nodes and shares out the entries
evenly between them. If the three nodes in total contained
(MAX_ENTRIES * 3) - 1 entries between them then this was erroneously getting
rebalanced as (MAX_ENTRIES - 1) on the left and right, and (MAX_ENTRIES + 1) in
the center.
Fix this issue by being more careful about calculating the target number
of entries for the left and right nodes.
Unit tested in userspace using this program:
https://github.com/jthornber/redistribute3-test/blob/master/redistribute3_t.c
Signed-off-by: Joe Thornber <ejt@redhat.com>
commit 9702970c7bd3e2d6fecb642a190269131d4ac16c upstream.
This reverts commit e306dfd06fcb44d21c80acb8e5a88d55f3d1cf63.
With this patch applied, we were the only architecture making this sort
of adjustment to the PC calculation in the unwinder. This causes
problems for ftrace, where the PC values are matched against the
contents of the stack frames in the callchain and fail to match any
records after the address adjustment.
Whilst there has been some effort to change ftrace to workaround this,
those patches are not yet ready for mainline and, since we're the odd
architecture in this regard, let's just step in line with other
architectures (like arch/arm/) for now.
commit 6d69bb536bac0d403d83db1ca841444981b280cd upstream.
Mapping an image with a long parent chain (e.g. image foo, whose parent
is bar, whose parent is baz, etc) currently leads to a kernel stack
overflow, due to the following recursion in the reply path:
rbd_osd_req_callback()
rbd_obj_request_complete()
rbd_img_obj_callback()
rbd_img_parent_read_callback()
Limit the parent chain to 16 images, which is ~5K worth of stack. When
the above recursion is eliminated, this limit can be lifted.
Fixes: http://tracker.ceph.com/issues/12538
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Josh Durgin <jdurgin@redhat.com>
[idryomov@gmail.com: backport to 3.10: rbd_dev->opts, context]
commit 1f2c6651f69c14d0d3a9cfbda44ea101b02160ba upstream.
Currently we leak parent_spec and trigger a "parent reference
underflow" warning if rbd_dev_create() in rbd_dev_probe_parent() fails.
The problem is we take the !parent out_err branch and that only drops
refcounts; parent_spec that would've been freed had we called
rbd_dev_unparent() remains and triggers rbd_warn() in
rbd_dev_parent_put() - at that point we have parent_spec != NULL and
parent_ref == 0, so counter ends up being -1 after the decrement.
Redo rbd_dev_probe_parent() to fix this.
[idryomov@gmail.com: backport to < 4.2: rbd_dev->opts]
Reviewed-by: Alex Elder <elder@linaro.org>
commit bae818ee1577c27356093901a0ea48f672eda514 upstream.
rbd requires stable pages, as it performs a crc of the page data before
they are send to the OSDs.
But since kernel 3.9 (patch 1d1d1a767206fbe5d4c69493b7e6d2a8d08cc0a0
"mm: only enforce stable page writes if the backing device requires
it") it is not assumed anymore that block devices require stable pages.
This patch sets the necessary flag to get stable pages back for rbd.
In a ceph installation that provides multiple ext4 formatted rbd
devices "bad crc" messages appeared regularly (ca 1 message every 1-2
minutes on every OSD that provided the data for the rbd) in the
OSD-logs before this patch. After this patch this messages are pretty
much gone (only ca 1-2 / month / OSD).
Signed-off-by: Ronny Hegewald <Ronny.Hegewald@online.de>
[idryomov@gmail.com: require stable pages only in crc case, changelog]
[idryomov@gmail.com: backport to 3.9-3.17: context]
commit 2a6c521bb41ce862e43db46f52e7681d33e8d771 upstream.
On nv50+, we restrict the valid domains to just the one where the buffer
was originally created. However after the buffer is evicted to system
memory, we might move it back to a different domain that was not
originally valid. When sharing the buffer and retrieving its GEM_INFO
data, we still want the domain that will be valid for this buffer in a
pushbuf, not the one where it currently happens to be.
This resolves fdo#92504 and several others. These are due to suspend
evicting all buffers, making it more likely that they temporarily end up
in the wrong place.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=92504
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit 296291cdd1629c308114504b850dc343eabc2782 upstream.
Currently a simple program below issues a sendfile(2) system call which
takes about 62 days to complete in my test KVM instance.
int fd;
off_t off = 0;
fd = open("file", O_RDWR | O_TRUNC | O_SYNC | O_CREAT, 0644);
ftruncate(fd, 2);
lseek(fd, 0, SEEK_END);
sendfile(fd, fd, &off, 0xfffffff);
Now you should not ask kernel to do a stupid stuff like copying 256MB in
2-byte chunks and call fsync(2) after each chunk but if you do, sysadmin
should have a way to stop you.
We actually do have a check for fatal_signal_pending() in
generic_perform_write() which triggers in this path however because we
always succeed in writing something before the check is done, we return
value > 0 from generic_perform_write() and thus the information about
signal gets lost.
Fix the problem by doing the signal check before writing anything. That
way generic_perform_write() returns -EINTR, the error gets propagated up
and the sendfile loop terminates early.
Signed-off-by: Jan Kara <jack@suse.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
