2011-07-13Linux 2.6.33.16v2.6.33.16Greg Kroah-Hartman
2011-07-13mm: prevent concurrent unmap_mapping_range() on the same inodeMiklos Szeredi
commit 2aa15890f3c191326678f1bd68af61ec6b8753ec upstream. Michael Leun reported that running parallel opens on a fuse filesystem can trigger a "kernel BUG at mm/truncate.c:475" Gurudas Pai reported the same bug on NFS. The reason is, unmap_mapping_range() is not prepared for more than one concurrent invocation per inode. For example: thread1: going through a big range, stops in the middle of a vma and stores the restart address in vm_truncate_count. thread2: comes in with a small (e.g. single page) unmap request on the same vma, somewhere before restart_address, finds that the vma was already unmapped up to the restart address and happily returns without doing anything. Another scenario would be two big unmap requests, both having to restart the unmapping and each one setting vm_truncate_count to its own value. This could go on forever without any of them being able to finish. Truncate and hole punching already serialize with i_mutex. Other callers of unmap_mapping_range() do not, and it's difficult to get i_mutex protection for all callers. In particular ->d_revalidate(), which calls invalidate_inode_pages2_range() in fuse, may be called with or without i_mutex. This patch adds a new mutex to 'struct address_space' to prevent running multiple concurrent unmap_mapping_range() on the same mapping. [ We'll hopefully get rid of all this with the upcoming mm preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex lockbreak" patch in particular. But that is for 2.6.39 ] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Michael Leun <lkml20101129@newton.leun.net> Reported-by: Gurudas Pai <gurudas.pai@oracle.com> Tested-by: Gurudas Pai <gurudas.pai@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13udp/recvmsg: Clear MSG_TRUNC flag when starting over for a new packetXufeng Zhang
[ Upstream commit 9cfaa8def1c795a512bc04f2aec333b03724ca2e ] Consider this scenario: When the size of the first received udp packet is bigger than the receive buffer, MSG_TRUNC bit is set in msg->msg_flags. However, if checksum error happens and this is a blocking socket, it will goto try_again loop to receive the next packet. But if the size of the next udp packet is smaller than receive buffer, MSG_TRUNC flag should not be set, but because MSG_TRUNC bit is not cleared in msg->msg_flags before receive the next packet, MSG_TRUNC is still set, which is wrong. Fix this problem by clearing MSG_TRUNC flag when starting over for a new packet. Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13ipv6/udp: Use the correct variable to determine non-blocking conditionXufeng Zhang
[ Upstream commit 32c90254ed4a0c698caa0794ebb4de63fcc69631 ] udpv6_recvmsg() function is not using the correct variable to determine whether or not the socket is in non-blocking operation, this will lead to unexpected behavior when a UDP checksum error occurs. Consider a non-blocking udp receive scenario: when udpv6_recvmsg() is called by sock_common_recvmsg(), MSG_DONTWAIT bit of flags variable in udpv6_recvmsg() is cleared by "flags & ~MSG_DONTWAIT" in this call: err = sk->sk_prot->recvmsg(iocb, sk, msg, size, flags & MSG_DONTWAIT, flags & ~MSG_DONTWAIT, &addr_len); i.e. with udpv6_recvmsg() getting these values: int noblock = flags & MSG_DONTWAIT int flags = flags & ~MSG_DONTWAIT So, when udp checksum error occurs, the execution will go to csum_copy_err, and then the problem happens: csum_copy_err: ............... if (flags & MSG_DONTWAIT) return -EAGAIN; goto try_again; ............... But it will always go to try_again as MSG_DONTWAIT has been cleared from flags at call time -- only noblock contains the original value of MSG_DONTWAIT, so the test should be: if (noblock) return -EAGAIN; This is also consistent with what the ipv4/udp code does. Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13net/ipv4: Check for mistakenly passed in non-IPv4 addressMarcus Meissner
[ Upstream commit d0733d2e29b652b2e7b1438ececa732e4eed98eb ] Check against mistakenly passing in IPv6 addresses (which would result in an INADDR_ANY bind) or similar incompatible sockaddrs. Signed-off-by: Marcus Meissner <meissner@suse.de> Cc: Reinhard Max <max@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13af_packet: prevent information leakEric Dumazet
[ Upstream commit 13fcb7bd322164c67926ffe272846d4860196dc6 ] In 2.6.27, commit 393e52e33c6c2 (packet: deliver VLAN TCI to userspace) added a small information leak. Add padding field and make sure its zeroed before copy to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13net: filter: Use WARN_RATELIMITJoe Perches
[ Upstream commit 6c4a5cb219520c7bc937ee186ca53f03733bd09f ] A mis-configured filter can spam the logs with lots of stack traces. Rate-limit the warnings and add printout of the bogus filter information. Original-patch-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13bug.h: Add WARN_RATELIMITJoe Perches
[ Upstream commit b3eec79b0776e5340a3db75b34953977c7e5086e ] Add a generic mechanism to ratelimit WARN(foo, fmt, ...) messages using a hidden per call site static struct ratelimit_state. Also add an __WARN_RATELIMIT variant to be able to use a specific struct ratelimit_state. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13PM / Hibernate: Fix free_unnecessary_pages()Rafael J. Wysocki
commit 4d4cf23cdde2f8f9324f5684a7f349e182039529 upstream. There is a bug in free_unnecessary_pages() that causes it to attempt to free too many pages in some cases, which triggers the BUG_ON() in memory_bm_clear_bit() for copy_bm. Namely, if count_data_pages() is initially greater than alloc_normal, we get to_free_normal equal to 0 and "save" greater from 0. In that case, if the sum of "save" and count_highmem_pages() is greater than alloc_highmem, we subtract a positive number from to_free_normal. Hence, since to_free_normal was 0 before the subtraction and is an unsigned int, the result is converted to a huge positive number that is used as the number of pages to free. Fix this bug by checking if to_free_normal is actually greater than or equal to the number we're going to subtract from it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13PM / Hibernate: Avoid hitting OOM during preallocation of memoryRafael J. Wysocki
commit 6715045ddc7472a22be5e49d4047d2d89b391f45 upstream. There is a problem in hibernate_preallocate_memory() that it calls preallocate_image_memory() with an argument that may be greater than the total number of available non-highmem memory pages. If that's the case, the OOM condition is guaranteed to trigger, which in turn can cause significant slowdown to occur during hibernation. To avoid that, make preallocate_image_memory() adjust its argument before calling preallocate_image_pages(), so that the total number of saveable non-highem pages left is not less than the minimum size of a hibernation image. Change hibernate_preallocate_memory() to try to allocate from highmem if the number of pages allocated by preallocate_image_memory() is too low. Modify free_unnecessary_pages() to take all possible memory allocation patterns into account. Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: M. Vefa Bicakci <bicave@superonline.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13inet_diag: fix inet_diag_bc_audit()Eric Dumazet
[ Upstream commit eeb1497277d6b1a0a34ed36b97e18f2bd7d6de0d ] A malicious user or buggy application can inject code and trigger an infinite loop in inet_diag_bc_audit() Also make sure each instruction is aligned on 4 bytes boundary, to avoid unaligned accesses. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13netlink: Make nlmsg_find_attr take a const nlmsghdr*.Nelson Elhage
commit 6b8c92ba07287578718335ce409de8e8d7217e40 upstream. This will let us use it on a nlmsghdr stored inside a netlink_callback. Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13um: os-linux/mem.c needs sys/stat.hLiu Aleaxander
commit fb967ecc584c20c74a007de749ca597068b0fcac upstream. The os-linux/mem.c file calls fchmod function, which is declared in sys/stat.h header file, so include it. Fixes build breakage under FC13. Signed-off-by: Liu Aleaxander <Aleaxander@gmail.com> Acked-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13uml: fix CONFIG_STATIC_LINK=y build failure with newer glibcRoland McGrath
commit aa5fb4dbfd121296ca97c68cf90043a7ea97579d upstream. With glibc 2.11 or later that was built with --enable-multi-arch, the UML link fails with undefined references to __rel_iplt_start and similar symbols. In recent binutils, the default linker script defines these symbols (see ld --verbose). Fix the UML linker scripts to match the new defaults for these sections. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13USB: don't let the hub driver prevent system sleepAlan Stern
commit cbb330045e5df8f665ac60227ff898421fc8fb92 upstream. This patch (as1465) continues implementation of the policy that errors during suspend or hibernation should not prevent the system from going to sleep. In this case, failure to turn on the Suspend feature for a hub port shouldn't be reported as an error. There are situations where this does actually occur (such as when the device plugged into that port was disconnected in the recent past), and it turns out to be harmless. There's no reason for it to prevent a system sleep. Also, don't allow the hub driver to fail a system suspend if the downstream ports aren't all suspended. This is also harmless (and should never happen, given the change mentioned above); printing a warning message in the kernel log is all we really need to do. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13USB: don't let errors prevent system sleepAlan Stern
commit 0af212ba8f123c2eba151af7726c34a50b127962 upstream. This patch (as1464) implements the recommended policy that most errors during suspend or hibernation should not prevent the system from going to sleep. In particular, failure to suspend a USB driver or a USB device should not prevent the sleep from succeeding: Failure to suspend a device won't matter, because the device will automatically go into suspend mode when the USB bus stops carrying packets. (This might be less true for USB-3.0 devices, but let's not worry about them now.) Failure of a driver to suspend might lead to trouble later on when the system wakes up, but it isn't sufficient reason to prevent the system from going to sleep. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13taskstats: don't allow duplicate entries in listener modeVasiliy Kulikov
commit 26c4caea9d697043cc5a458b96411b86d7f6babd upstream. Currently a single process may register exit handlers unlimited times. It may lead to a bloated listeners chain and very slow process terminations. Eg after 10KK sent TASKSTATS_CMD_ATTR_REGISTER_CPUMASKs ~300 Mb of kernel memory is stolen for the handlers chain and "time id" shows 2-7 seconds instead of normal 0.003. It makes it possible to exhaust all kernel memory and to eat much of CPU time by triggerring numerous exits on a single CPU. The patch limits the number of times a single process may register itself on a single CPU to one. One little issue is kept unfixed - as taskstats_exit() is called before exit_files() in do_exit(), the orphaned listener entry (if it was not explicitly deregistered) is kept until the next someone's exit() and implicit deregistration in send_cpu_listeners(). So, if a process registered itself as a listener exits and the next spawned process gets the same pid, it would inherit taskstats attributes. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-136pack,mkiss: fix lock inconsistencyArnd Bergmann
commit 6e4e2f811bade330126d4029c88c831784a7efd9 upstream. Lockdep found a locking inconsistency in the mkiss_close function: > kernel: [ INFO: inconsistent lock state ] > kernel: 2.6.39.1 #3 > kernel: --------------------------------- > kernel: inconsistent {IN-SOFTIRQ-R} -> {SOFTIRQ-ON-W} usage. > kernel: ax25ipd/2813 [HC0[0]:SC0[0]:HE1:SE1] takes: > kernel: (disc_data_lock){+++?.-}, at: [<ffffffffa018552b>] mkiss_close+0x1b/0x90 [mkiss] > kernel: {IN-SOFTIRQ-R} state was registered at: The message hints that disc_data_lock is aquired with softirqs disabled, but does not itself disable softirqs, which can in rare circumstances lead to a deadlock. The same problem is present in the 6pack driver, this patch fixes both by using write_lock_bh instead of write_lock. Reported-by: Bernard F6BVP <f6bvp@free.fr> Tested-by: Bernard F6BVP <f6bvp@free.fr> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ralf Baechle<ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13SUNRPC: Ensure the RPC client only quits on fatal signalsTrond Myklebust
commit 5afa9133cfe67f1bfead6049a9640c9262a7101c upstream. Fix a couple of instances where we were exiting the RPC client on arbitrary signals. We should only do so on fatal signals. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13md: avoid endless recovery loop when waiting for fail device to complete.NeilBrown
commit 4274215d24633df7302069e51426659d4759c5ed upstream. If a device fails in a way that causes pending request to take a while to complete, md will not be able to immediately remove it from the array in remove_and_add_spares. It will then incorrectly look like a spare device and md will try to recover it even though it is failed. This leads to a recovery process starting and instantly aborting over and over again. We should check if the device is faulty before considering it to be a spare. This will avoid trying to start a recovery that cannot proceed. This bug was introduced in 2.6.26 so that patch is suitable for any kernel since then. Reported-by: Jim Paradis <james.paradis@stratus.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13i2c-taos-evm: Fix log messagesJean Delvare
commit 9b640f2e154268cb516efcaf9c434f2e73c6783e upstream. * Print all error and information messages even when debugging is disabled. * Don't use adapter device to log messages before it is ready. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13cfq-iosched: fix a rcu warningShaohua Li
commit 3181faa85bda3dc3f5e630a1846526c9caaa38e3 upstream. I got a rcu warnning at boot. the ioc->ioc_data is rcu_deferenced, but doesn't hold rcu_read_lock. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13cfq-iosched: fix locking around ioc->ioc_data assignmentJens Axboe
commit ab4bd22d3cce6977dc039664cc2d052e3147d662 upstream. Since we are modifying this RCU pointer, we need to hold the lock protecting it around it. This fixes a potential reuse and double free of a cfq io_context structure. The bug has been in CFQ for a long time, it hit very few people but those it did hit seemed to see it a lot. Tracked in RH bugzilla here: https://bugzilla.redhat.com/show_bug.cgi?id=577968 Credit goes to Paul Bolle for figuring out that the issue was around the one-hit ioc->ioc_data cache. Thanks to his hard work the issue is now fixed. Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13debugobjects: Fix boot crash when kmemleak and debugobjects enabledMarcin Slusarz
commit 161b6ae0e067e421b20bb35caf66bdb405c929ac upstream. Order of initialization look like this: ... debugobjects kmemleak ...(lots of other subsystems)... workqueues (through early initcall) ... debugobjects use schedule_work for batch freeing of its data and kmemleak heavily use debugobjects, so when it comes to freeing and workqueues were not initialized yet, kernel crashes: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff810854d1>] __queue_work+0x29/0x41a [<ffffffff81085910>] queue_work_on+0x16/0x1d [<ffffffff81085abc>] queue_work+0x29/0x55 [<ffffffff81085afb>] schedule_work+0x13/0x15 [<ffffffff81242de1>] free_object+0x90/0x95 [<ffffffff81242f6d>] debug_check_no_obj_freed+0x187/0x1d3 [<ffffffff814b6504>] ? _raw_spin_unlock_irqrestore+0x30/0x4d [<ffffffff8110bd14>] ? free_object_rcu+0x68/0x6d [<ffffffff8110890c>] kmem_cache_free+0x64/0x12c [<ffffffff8110bd14>] free_object_rcu+0x68/0x6d [<ffffffff810b58bc>] __rcu_process_callbacks+0x1b6/0x2d9 ... because system_wq is NULL. Fix it by checking if workqueues susbystem was initialized before using. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20110528112342.GA3068@joi.lan Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13watchdog: mtx1-wdt: request gpio before using itFlorian Fainelli
commit 9b19d40aa3ebaf1078779da10555da2ab8512422 upstream. Otherwise, the gpiolib autorequest feature will produce a WARN_ON(): WARNING: at drivers/gpio/gpiolib.c:101 0x8020ec6c() autorequest GPIO-215 [...] Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13uvcvideo: Remove buffers from the queues when freeingSjoerd Simons
commit 8ca2c80b170c47eeb55f0c2a0f2b8edf85f35d49 upstream. When freeing memory for the video buffers also remove them from the irq & main queues. This fixes an oops when doing the following: open ("/dev/video", ..) VIDIOC_REQBUFS VIDIOC_QBUF VIDIOC_REQBUFS close () As the second VIDIOC_REQBUFS will cause the list entries of the buffers to be cleared while they still hang around on the main and irc queues Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13mm: fix negative commitlimit when gigantic hugepages are allocatedRafael Aquini
commit b0320c7b7d1ac1bd5c2d9dff3258524ab39bad32 upstream. When 1GB hugepages are allocated on a system, free(1) reports less available memory than what really is installed in the box. Also, if the total size of hugepages allocated on a system is over half of the total memory size, CommitLimit becomes a negative number. The problem is that gigantic hugepages (order > MAX_ORDER) can only be allocated at boot with bootmem, thus its frames are not accounted to 'totalram_pages'. However, they are accounted to hugetlb_total_pages() What happens to turn CommitLimit into a negative number is this calculation, in fs/proc/meminfo.c: allowed = ((totalram_pages - hugetlb_total_pages()) * sysctl_overcommit_ratio / 100) + total_swap_pages; A similar calculation occurs in __vm_enough_memory() in mm/mmap.c. Also, every vm statistic which depends on 'totalram_pages' will render confusing values, as if system were 'missing' some part of its memory. Impact of this bug: When gigantic hugepages are allocated and sysctl_overcommit_memory == OVERCOMMIT_NEVER. In a such situation, __vm_enough_memory() goes through the mentioned 'allowed' calculation and might end up mistakenly returning -ENOMEM, thus forcing the system to start reclaiming pages earlier than it would be ususal, and this could cause detrimental impact to overall system's performance, depending on the workload. Besides the aforementioned scenario, I can only think of this causing annoyances with memory reports from /proc/meminfo and free(1). [akpm@linux-foundation.org: standardize comment layout] Reported-by: Russ Anderson <rja@sgi.com> Signed-off-by: Rafael Aquini <aquini@linux.com> Acked-by: Russ Anderson <rja@sgi.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13ath5k: fix memory leak when fewer than N_PD_CURVES are in useEugene A. Shatokhin
commit a0b8de350be458b33248e48b2174d9af8a4c4798 upstream. We would free the proper number of curves, but in the wrong slots, due to a missing level of indirection through the pdgain_idx table. It's simpler just to try to free all four slots, so do that. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13PM: Free memory bitmaps if opening /dev/snapshot failsMichal Kubecek
commit 8440f4b19494467883f8541b7aa28c7bbf6ac92b upstream. When opening /dev/snapshot device, snapshot_open() creates memory bitmaps which are freed in snapshot_release(). But if any of the callbacks called by pm_notifier_call_chain() returns NOTIFY_BAD, open() fails, snapshot_release() is never called and bitmaps are not freed. Next attempt to open /dev/snapshot then triggers BUG_ON() check in create_basic_memory_bitmaps(). This happens e.g. when vmwatchdog module is active on s390x. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13xhci: Reject double add of active endpoints.Sarah Sharp
commit fa75ac379e63c2864e9049b5e8615e40f65c1e70 upstream. While trying to switch a UAS device from the BOT configuration to the UAS configuration via the bConfigurationValue file, Tanya ran into an issue in the USB core. usb_disable_device() sets entries in udev->ep_out and udev->ep_out to NULL, but doesn't call into the xHCI bandwidth management functions to remove the BOT configuration endpoints from the xHCI host's internal structures. The USB core would then attempt to add endpoints for the UAS configuration, and some of the endpoints had the same address as endpoints in the BOT configuration. The xHCI driver blindly added the endpoints again, but the xHCI host controller rejected the Configure Endpoint command because active endpoints were added without being dropped. Make the xHCI driver reject calls to xhci_add_endpoint() that attempt to add active endpoints without first calling xhci_drop_endpoint(). This should be backported to kernels as old as 2.6.31. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Reported-by: Tanya Brokhman <tlinder@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13TTY: ldisc, do not close until there are readersJiri Slaby
commit 92f6fa09bd453ffe3351fa1f1377a1b7cfa911e6 upstream. We restored tty_ldisc_wait_idle in 100eeae2c5c (TTY: restore tty_ldisc_wait_idle). We used it in the ldisc changing path to fix the case where there are tasks in n_tty_read waiting for data and somebody tries to change ldisc. Similar to the case above, there may be also tasks waiting in n_tty_read while hangup is performed. As 65b770468e98 (tty-ldisc: turn ldisc user count into a proper refcount) removed the wait-until-idle from all paths, hangup path won't wait for them to disappear either now. So add it back even to the hangup path. There is a difference, we need uninterruptible sleep as there is obviously HUP signal pending. So tty_ldisc_wait_idle now sleeps without possibility to be interrupted. This is what original tty_ldisc_wait_idle did. After the wait idle reintroduction (100eeae2c5c), we have had interruptible sleeps for the ldisc changing path. But as there is a 5s timeout anyway, we don't allow it to be interrupted from now on. It's not worth the added complexity of deciding what kind of sleep we want. Before 65b770468e98 tty_ldisc_release was called also from tty_ldisc_release. It is called from tty_release, so I don't think we need to restore that one. This is nicely reproducible after constifying the timing when drivers/tty/n_tty.c is patched as follows ("TTY: ntty, add one more sanity check" patch is needed to actually see it explode): %% -1548,6 +1549,7 @@ static int n_tty_open(struct tty_struct *tty) /* These are ugly. Currently a malloc failure here can panic */ if (!tty->read_buf) { + msleep(100); tty->read_buf = kzalloc(N_TTY_BUF_SIZE, GFP_KERNEL); if (!tty->read_buf) return -ENOMEM; %% -1785,6 +1788,7 @@ do_it_again: break; } timeout = schedule_timeout(timeout); + msleep(20); continue; } __set_current_state(TASK_RUNNING); ===== With a process: ===== while (1) { int fd = open(argv[1], O_RDWR); read(fd, buf, sizeof(buf)); close(fd); } ===== and its child: ===== setsid(); while (1) { int fd = open(tty, O_RDWR|O_NOCTTY); ioctl(fd, TIOCSCTTY, 1); vhangup(); close(fd); usleep(100 * (10 + random() % 1000)); } ===== EOF ===== References: https://bugzilla.novell.com/show_bug.cgi?id=693374 References: https://bugzilla.novell.com/show_bug.cgi?id=694509 Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13clocksource: Make watchdog robust vs. interruptionThomas Gleixner
commit b5199515c25cca622495eb9c6a8a1d275e775088 upstream. The clocksource watchdog code is interruptible and it has been observed that this can trigger false positives which disable the TSC. The reason is that an interrupt storm or a long running interrupt handler between the read of the watchdog source and the read of the TSC brings the two far enough apart that the delta is larger than the unstable treshold. Move both reads into a short interrupt disabled region to avoid that. Reported-and-tested-by: Vernon Mauery <vernux@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13xen: partially revert "xen: set max_pfn_mapped to the last pfn mapped"Stefano Stabellini
commit a91d92875ee94e4703fd017ccaadb48cfb344994 upstream. We only need to set max_pfn_mapped to the last pfn mapped on x86_64 to make sure that cleanup_highmap doesn't remove important mappings at _end. We don't need to do this on x86_32 because cleanup_highmap is not called on x86_32. Besides lowering max_pfn_mapped on x86_32 has the unwanted side effect of limiting the amount of memory available for the 1:1 kernel pagetable allocation. This patch reverts the x86_32 part of the original patch. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13migrate: don't account swapcache as shmemAndrea Arcangeli
commit 99a15e21d96f6857dafab1e5167e5e8183215c9c upstream. swapcache will reach the below code path in migrate_page_move_mapping, and swapcache is accounted as NR_FILE_PAGES but it's not accounted as NR_SHMEM. Hugh pointed out we must use PageSwapCache instead of comparing mapping to &swapper_space, to avoid build failure with CONFIG_SWAP=n. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13ksm: fix NULL pointer dereference in scan_get_next_rmap_item()Hugh Dickins
commit 2b472611a32a72f4a118c069c2d62a1a3f087afd upstream. Andrea Righi reported a case where an exiting task can race against ksmd::scan_get_next_rmap_item (http://lkml.org/lkml/2011/6/1/742) easily triggering a NULL pointer dereference in ksmd. ksm_scan.mm_slot == &ksm_mm_head with only one registered mm CPU 1 (__ksm_exit) CPU 2 (scan_get_next_rmap_item) list_empty() is false lock slot == &ksm_mm_head list_del(slot->mm_list) (list now empty) unlock lock slot = list_entry(slot->mm_list.next) (list is empty, so slot is still ksm_mm_head) unlock slot->mm == NULL ... Oops Close this race by revalidating that the new slot is not simply the list head again. Andrea's test case: #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <sys/mman.h> #define BUFSIZE getpagesize() int main(int argc, char **argv) { void *ptr; if (posix_memalign(&ptr, getpagesize(), BUFSIZE) < 0) { perror("posix_memalign"); exit(1); } if (madvise(ptr, BUFSIZE, MADV_MERGEABLE) < 0) { perror("madvise"); exit(1); } *(char *)NULL = 0; return 0; } Reported-by: Andrea Righi <andrea@betterlinux.com> Tested-by: Andrea Righi <andrea@betterlinux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23Linux 2.6.33.15v2.6.33.15Greg Kroah-Hartman
2011-06-23Revert "iwlagn: Support new 5000 microcode."Greg Kroah-Hartman
This reverts commit 6f63415fc1b690cb50c2ad48ba6e9e6e88e271b4. It turns out this is not what we want to have happen for the .32 and .33-longterm kernels as it does not work properly at all. This was reported by Gentoo, Arch, and Canonical developers as causing problems for their users: https://bugs.archlinux.org/task/24302 http://bugs.gentoo.org/show_bug.cgi?id=359445 https://bugs.launchpad.net/ubuntu/+source/linux/+bug/796336 Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Gordon Malm <gengor@gentoo.org> Cc: Don Fry <donald.h.fry@intel.com> Cc: Wey-Yi Guy <wey-yi.w.guy@intel.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23netfilter: IPv6: fix DSCP mangle codeFernando Luis Vazquez Cao
commit 1ed2f73d90fb49bcf5704aee7e9084adb882bfc5 upstream. The mask indicates the bits one wants to zero out, so it needs to be inverted before applying to the original TOS field. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23netfilter: IPv6: initialize TOS field in REJECT target moduleFernando Luis Vazquez Cao
commit 4319cc0cf5bb894b7368008cdf6dd20eb8868018 upstream. The IPv6 header is not zeroed out in alloc_skb so we must initialize it properly unless we want to see IPv6 packets with random TOS fields floating around. The current implementation resets the flow label but this could be changed if deemed necessary. We stumbled upon this issue when trying to apply a mangle rule to the RST packet generated by the REJECT target module. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23xfs: properly account for reclaimed inodesJohannes Weiner
commit 081003fff467ea0e727f66d5d435b4f473a789b3 upstream. When marking an inode reclaimable, a per-AG counter is increased, the inode is tagged reclaimable in its per-AG tree, and, when this is the first reclaimable inode in the AG, the AG entry in the per-mount tree is also tagged. When an inode is finally reclaimed, however, it is only deleted from the per-AG tree. Neither the counter is decreased, nor is the parent tree's AG entry untagged properly. Since the tags in the per-mount tree are not cleared, the inode shrinker iterates over all AGs that have had reclaimable inodes at one point in time. The counters on the other hand signal an increasing amount of slab objects to reclaim. Since "70e60ce xfs: convert inode shrinker to per-filesystem context" this is not a real issue anymore because the shrinker bails out after one iteration. But the problem was observable on a machine running v2.6.34, where the reclaimable work increased and each process going into direct reclaim eventually got stuck on the xfs inode shrinking path, trying to scan several million objects. Fix this by properly unwinding the reclaimable-state tracking of an inode when it is reclaimed. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com> Backported-by: Stefan Priebe <s.priebe@profihost.ag> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23pata_cm64x: fix boot crash on pariscJames Bottomley
commit 9281b16caac1276817b77033c5b8a1f5ca30102c upstream. The old IDE cmd64x checks the status of the CNTRL register to see if the ports are enabled before probing them. pata_cmd64x doesn't do this, which causes a HPMC on parisc when it tries to poke at the secondary port because apparently the BAR isn't wired up (and a non-responding piece of memory causes a HPMC). Fix this by porting the CNTRL register port detection logic from IDE cmd64x. In addition, following converns from Alan Cox, add a check to see if a mobility electronics bridge is the immediate parent and forgo the check if it is (prevents problems on hotplug controllers). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23pata_cmd64x: remove unused definitionsBartlomiej Zolnierkiewicz
commit c754d9b6e04371fb398cdd2f5e77be895126be20 upstream. s/ARTIM2/ARTTIM23/ in cmd648_bmdma_stop() while at it Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23pata_cmd64x: cmd648_bmdma_stop() fixBartlomiej Zolnierkiewicz
commit 03a849e6ddb604ff6a220b78637ee8e122ffc796 upstream. Clear the primary channel pending interrupt bit instead of the reserved one. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23pata_cmd64x: fix PIO setupBartlomiej Zolnierkiewicz
commit a2bd62207af4be8f5fe815ff90cc309056407829 upstream. Fix incorrect handling of recovery clocks value == 16 resulting in overclocked recovery timings & potentially underclocked active timings. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23md/raid5: fix raid5_set_bi_hw_segmentsNamhyung Kim
commit 9b2dc8b665932a8e681a7ab3237f60475e75e161 upstream. The @bio->bi_phys_segments consists of active stripes count in the lower 16 bits and processed stripes count in the upper 16 bits. So logical-OR operator should be bitwise one. This bug has been present since 2.6.27 and the fix is suitable for any -stable kernel since then. Fortunately the bad code is only used on error paths and is relatively unlikely to be hit. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23md: check ->hot_remove_disk when removing diskNamhyung Kim
commit 01393f3d5836b7d62e925e6f4658a7eb22b83a11 upstream. Check pers->hot_remove_disk instead of pers->hot_add_disk in slot_store() during disk removal. The linear personality only has ->hot_add_disk and no ->hot_remove_disk, so that removing disk in the array resulted to following kernel bug: $ sudo mdadm --create /dev/md0 --level=linear --raid-devices=4 /dev/loop[0-3] $ echo none | sudo tee /sys/block/md0/md/dev-loop2/slot BUG: unable to handle kernel NULL pointer dereference at (null) IP: [< (null)>] (null) PGD c9f5d067 PUD 8575a067 PMD 0 Oops: 0010 [#1] SMP CPU 2 Modules linked in: linear loop bridge stp llc kvm_intel kvm asus_atk0110 sr_mod cdrom sg Pid: 10450, comm: tee Not tainted 3.0.0-rc1-leonard+ #173 System manufacturer System Product Name/P5G41TD-M PRO RIP: 0010:[<0000000000000000>] [< (null)>] (null) RSP: 0018:ffff880085757df0 EFLAGS: 00010282 RAX: ffffffffa00168e0 RBX: ffff8800d1431800 RCX: 000000000000006e RDX: 0000000000000001 RSI: 0000000000000002 RDI: ffff88008543c000 RBP: ffff880085757e48 R08: 0000000000000002 R09: 000000000000000a R10: 0000000000000000 R11: ffff88008543c2e0 R12: 00000000ffffffff R13: ffff8800b4641000 R14: 0000000000000005 R15: 0000000000000000 FS: 00007fe8c9e05700(0000) GS:ffff88011fa00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000000 CR3: 00000000b4502000 CR4: 00000000000406e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process tee (pid: 10450, threadinfo ffff880085756000, task ffff8800c9f08000) Stack: ffffffff8138496a ffff8800b4641000 ffff88008543c268 0000000000000000 ffff8800b4641000 ffff88008543c000 ffff8800d1431868 ffffffff81a78a90 ffff8800b4641000 ffff88008543c000 ffff8800d1431800 ffff880085757e98 Call Trace: [<ffffffff8138496a>] ? slot_store+0xaa/0x265 [<ffffffff81384bae>] rdev_attr_store+0x89/0xa8 [<ffffffff8115a96a>] sysfs_write_file+0x108/0x144 [<ffffffff81106b87>] vfs_write+0xb1/0x10d [<ffffffff8106e6c0>] ? trace_hardirqs_on_caller+0x111/0x135 [<ffffffff81106cac>] sys_write+0x4d/0x77 [<ffffffff814fe702>] system_call_fastpath+0x16/0x1b Code: Bad RIP value. RIP [< (null)>] (null) RSP <ffff880085757df0> CR2: 0000000000000000 ---[ end trace ba5fc64319a826fb ]--- Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23CPUFREQ: Remove cpufreq_stats sysfs entries on module unload.Dave Jones
commit 13f067537f34456443f61c950cd6dc37d1d5f3ee upstream. cpufreq_stats leaves behind its sysfs entries, which causes a panic when something stumbled across them. (Discovered by unloading cpufreq_stats while powertop was loaded). Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23oprofile, dcookies: Fix possible circular locking dependencyRobert Richter
commit fe47ae7f53e179d2ef6771024feb000cbb86640f upstream. The lockdep warning below detects a possible A->B/B->A locking dependency of mm->mmap_sem and dcookie_mutex. The order in sync_buffer() is mm->mmap_sem/dcookie_mutex, while in sys_lookup_dcookie() it is vice versa. Fixing it in sys_lookup_dcookie() by unlocking dcookie_mutex before copy_to_user(). oprofiled/4432 is trying to acquire lock: (&mm->mmap_sem){++++++}, at: [<ffffffff810b444b>] might_fault+0x53/0xa3 but task is already holding lock: (dcookie_mutex){+.+.+.}, at: [<ffffffff81124d28>] sys_lookup_dcookie+0x45/0x149 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (dcookie_mutex){+.+.+.}: [<ffffffff8106557f>] lock_acquire+0xf8/0x11e [<ffffffff814634f0>] mutex_lock_nested+0x63/0x309 [<ffffffff81124e5c>] get_dcookie+0x30/0x144 [<ffffffffa0000fba>] sync_buffer+0x196/0x3ec [oprofile] [<ffffffffa0001226>] task_exit_notify+0x16/0x1a [oprofile] [<ffffffff81467b96>] notifier_call_chain+0x37/0x63 [<ffffffff8105803d>] __blocking_notifier_call_chain+0x50/0x67 [<ffffffff81058068>] blocking_notifier_call_chain+0x14/0x16 [<ffffffff8105a718>] profile_task_exit+0x1a/0x1c [<ffffffff81039e8f>] do_exit+0x2a/0x6fc [<ffffffff8103a5e4>] do_group_exit+0x83/0xae [<ffffffff8103a626>] sys_exit_group+0x17/0x1b [<ffffffff8146ad4b>] system_call_fastpath+0x16/0x1b -> #0 (&mm->mmap_sem){++++++}: [<ffffffff81064dfb>] __lock_acquire+0x1085/0x1711 [<ffffffff8106557f>] lock_acquire+0xf8/0x11e [<ffffffff810b4478>] might_fault+0x80/0xa3 [<ffffffff81124de7>] sys_lookup_dcookie+0x104/0x149 [<ffffffff8146ad4b>] system_call_fastpath+0x16/0x1b other info that might help us debug this: 1 lock held by oprofiled/4432: #0: (dcookie_mutex){+.+.+.}, at: [<ffffffff81124d28>] sys_lookup_dcookie+0x45/0x149 stack backtrace: Pid: 4432, comm: oprofiled Not tainted 2.6.39-00008-ge5a450d #9 Call Trace: [<ffffffff81063193>] print_circular_bug+0xae/0xbc [<ffffffff81064dfb>] __lock_acquire+0x1085/0x1711 [<ffffffff8102ef13>] ? get_parent_ip+0x11/0x42 [<ffffffff810b444b>] ? might_fault+0x53/0xa3 [<ffffffff8106557f>] lock_acquire+0xf8/0x11e [<ffffffff810b444b>] ? might_fault+0x53/0xa3 [<ffffffff810d7d54>] ? path_put+0x22/0x27 [<ffffffff810b4478>] might_fault+0x80/0xa3 [<ffffffff810b444b>] ? might_fault+0x53/0xa3 [<ffffffff81124de7>] sys_lookup_dcookie+0x104/0x149 [<ffffffff8146ad4b>] system_call_fastpath+0x16/0x1b References: https://bugzilla.kernel.org/show_bug.cgi?id=13809 Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23ALSA: hda: Fix quirk for Dell Inspiron 910Daniel T Chen
commit 0a1896b27b030529ec770aefd790544a1bdb7d5a upstream. BugLink: https://launchpad.net/bugs/792712 The original reporter states that sound from the internal speakers is inaudible until using the model=auto quirk. This symptom is due to an existing quirk mask for 0x102802b* that uses the model=dell quirk. To limit the possible regressions, leave the existing quirk mask but add a higher priority specific mask for the reporter's PCI SSID. Reported-and-tested-by: rodni hipp Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-23USB: xhci - fix interval calculation for FS isoc endpointsDmitry Torokhov
commit cd3c18ba2fac14b34d03cae111f215009735ea06 upstream. Full-speed isoc endpoints specify interval in exponent based form in frames, not microframes, so we need to adjust accordingly. NEC xHCI host controllers will return an error code of 0x11 if a full speed isochronous endpoint is added with the Interval field set to something less than 3 (2^3 = 8 microframes, or one frame). It is impossible for a full speed device to have an interval smaller than one frame. This was always an issue in the xHCI driver, but commit dfa49c4ad120a784ef1ff0717168aa79f55a483a "USB: xhci - fix math in xhci_get_endpoint_interval()" removed the clamping of the minimum value in the Interval field, which revealed this bug. This needs to be backported to stable kernels back to 2.6.31. Reported-by: Matt Evans <matt@ozlabs.org> Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
